2009-04-23[S390] omit frame pointers on s390 when possibleHeiko Carstens
Always omit frame pointers on s390. They aren't too useful for the kernel since we have already the kernel stack backchain which allows us to walk the kernel stack. So eleminate the extra code for frame pointers. Only allow the extra code for the function tracer since the gcc compile options -pg and -fomit-frame-pointer are incompatible. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-04-23[S390] Use tape_generic_offline directly.Frank Munzert
tape_3590_offline and tape_34xx_offline are removed and tape_generic_offline is called directly instead. Signed-off-by: Frank Munzert <munzert@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-04-23[S390] /proc/stat idle field for idle cpusMartin Schwidefsky
The cpu idle field in the output of /proc/stat is too small for cpus that have been idle for more than a tick. Add the architecture hook arch_idle_time that allows to add the not accounted idle time of a sleeping cpu without waking the cpu. The s390 implementation of arch_idle_time uses the already existing s390_idle_data per_cpu variable to find the sleep time of a neighboring idle cpu. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-04-23[S390] appldata: avoid deadlock with appldata_memGerald Schaefer
The appldata_ops callbacks are called with a spin_lock held. But the appldata_mem callback then calls all_vm_events(), which calls get_online_cpus(), which might sleep. This possible deadlock is fixed by using a mutex instead of a spin_lock. Signed-off-by: Gerald Schaefer <gerald.schaefer@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-04-23[S390] ipl: fix compile breakageHeiko Carstens
Fix this for !CONFIG_SMP: arch/s390/kernel/ipl.c: In function 'stop_run': arch/s390/kernel/ipl.c:1461: error: implicit declaration of function 'signal_processor' Reported-by: Sachin Sant <sachinp@in.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-04-21Linux 2.6.30-rc3v2.6.30-rc3Linus Torvalds
2009-04-21driver synchronization: make scsi_wait_scan more advancedArjan van de Ven
There is currently only one way for userspace to say "wait for my storage device to get ready for the modules I just loaded": to load the scsi_wait_scan module. Expectations of userspace are that once this module is loaded, all the (storage) devices for which the drivers were loaded before the module load are present. Now, there are some issues with the implementation, and the async stuff got caught in the middle of this: The existing code only waits for the scsy async probing to finish, but it did not take into account at all that probing might not have begun yet. (Russell ran into this problem on his computer and the fix works for him) This patch fixes this more thoroughly than the previous "fix", which had some bad side effects (namely, for kernel code that wanted to wait for the scsi scan it would also do an async sync, which would deadlock if you did it from async context already.. there's a report about that on lkml): The patch makes the module first wait for all device driver probes, and then it will wait for the scsi parallel scan to finish. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Tested-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-21Trivial: fix a typo in slow-work.hJonathan Corbet
Fix a comment typo in slow-work.h ...a trivial mistake, but it will mess up kerneldoc if nothing else. Signed-off-by: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-21PERCPU: Collect the DECLARE/DEFINE declarations togetherDavid Howells
Collect the DECLARE/DEFINE declarations together in linux/percpu-defs.h so that they're in one place, and give them descriptive comments, particularly the SHARED_ALIGNED variant. It would be nice to collect these in linux/percpu.h, but that's not possible without sorting out the severe #include recursion between the x86 arch headers and the general headers (and possibly other arches too). Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-21FRV: Fix the section attribute on UP DECLARE_PER_CPU()David Howells
In non-SMP mode, the variable section attribute specified by DECLARE_PER_CPU() does not agree with that specified by DEFINE_PER_CPU(). This means that architectures that have a small data section references relative to a base register may throw up linkage errors due to too great a displacement between where the base register points and the per-CPU variable. On FRV, the .h declaration says that the variable is in the .sdata section, but the .c definition says it's actually in the .data section. The linker throws up the following errors: kernel/built-in.o: In function `release_task': kernel/exit.c:78: relocation truncated to fit: R_FRV_GPREL12 against symbol `per_cpu__process_counts' defined in .data section in kernel/built-in.o kernel/exit.c:78: relocation truncated to fit: R_FRV_GPREL12 against symbol `per_cpu__process_counts' defined in .data section in kernel/built-in.o To fix this, DECLARE_PER_CPU() should simply apply the same section attribute as does DEFINE_PER_CPU(). However, this is made slightly more complex by virtue of the fact that there are several variants on DEFINE, so these need to be matched by variants on DECLARE. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-21Merge git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstableLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable: Btrfs: fix btrfs fallocate oops and deadlock Btrfs: use the right node in reada_for_balance Btrfs: fix oops on page->mapping->host during writepage Btrfs: add a priority queue to the async thread helpers Btrfs: use WRITE_SYNC for synchronous writes
2009-04-21Merge branch 'i2c-for-linus' of git://jdelvare.pck.nerim.net/jdelvare-2.6Linus Torvalds
* 'i2c-for-linus' of git://jdelvare.pck.nerim.net/jdelvare-2.6: go7007: Convert to the new i2c device binding model
2009-04-21bfin_5xx: misplaced parenthesesRoel Kluin
`!' has a higher precedence than `&', parentheses are misplaced. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Acked-by: Sonic Zhang <sonic.zhang@analog.com> Cc: Bryan Wu <cooloney@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-21vmscan,memcg: reintroduce sc->may_swapKOSAKI Motohiro
Commit a6dc60f8975ad96d162915e07703a4439c80dcf0 ("vmscan: rename sc.may_swap to may_unmap") removed the may_swap flag, but memcg had used it as a flag for "we need to use swap?", as the name indicate. And in the current implementation, memcg cannot reclaim mapped file caches when mem+swap hits the limit. re-introduce may_swap flag and handle it at get_scan_ratio(). This patch doesn't influence any scan_control users other than memcg. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-21edac: ppc mpc85xx fix mc err detectDave Jiang
Error found by Jeff Haran. The error detect register is 0s when no errors are detected. The check code is incorrect, so reverse check sense. Reported-by: Jeff Haran <jharan@Brocade.COM> Signed-off-by: Dave Jiang <djiang@mvista.com> Signed-off-by: Doug Thompson <dougthompson@xmission.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-21scsi: mpt: suppress debugobjects warningEric Paris
Addresses http://bugzilla.kernel.org/show_bug.cgi?id=13133 ODEBUG: object is on stack, but not annotated ------------[ cut here ]------------ WARNING: at lib/debugobjects.c:253 __debug_object_init+0x1f3/0x276() Hardware name: VMware Virtual Platform Modules linked in: mptspi(+) mptscsih mptbase scsi_transport_spi ext3 jbd mbcache Pid: 540, comm: insmod Not tainted 2.6.28-mm1 #2 Call Trace: [<c042c51c>] warn_slowpath+0x74/0x8a [<c0469600>] ? start_critical_timing+0x96/0xb7 [<c060c8ea>] ? _spin_unlock_irqrestore+0x2f/0x3c [<c0446fad>] ? trace_hardirqs_off_caller+0x18/0xaf [<c044704f>] ? trace_hardirqs_off+0xb/0xd [<c060c8ea>] ? _spin_unlock_irqrestore+0x2f/0x3c [<c042cb84>] ? release_console_sem+0x1a5/0x1ad [<c05013e6>] __debug_object_init+0x1f3/0x276 [<c0501494>] debug_object_init+0x13/0x17 [<c0433c56>] init_timer+0x10/0x1a [<e08e5b54>] mpt_config+0x1c1/0x2b7 [mptbase] [<e08e3b82>] ? kmalloc+0x8/0xa [mptbase] [<e08e3b82>] ? kmalloc+0x8/0xa [mptbase] [<e08e6fa2>] mpt_do_ioc_recovery+0x950/0x1212 [mptbase] [<c04496c2>] ? __lock_acquire+0xa69/0xacc [<c060c8f1>] ? _spin_unlock_irqrestore+0x36/0x3c [<c060c3af>] ? _spin_unlock_irq+0x22/0x26 [<c04f2d8b>] ? string+0x2b/0x76 [<c04f310e>] ? vsnprintf+0x338/0x7b3 [<c04496c2>] ? __lock_acquire+0xa69/0xacc [<c060c8ea>] ? _spin_unlock_irqrestore+0x2f/0x3c [<c04496c2>] ? __lock_acquire+0xa69/0xacc [<c044897d>] ? debug_check_no_locks_freed+0xeb/0x105 [<c060c8f1>] ? _spin_unlock_irqrestore+0x36/0x3c [<c04488bc>] ? debug_check_no_locks_freed+0x2a/0x105 [<c0446b8c>] ? lock_release_holdtime+0x43/0x48 [<c043f742>] ? up_read+0x16/0x29 [<c05076f8>] ? pci_get_slot+0x66/0x72 [<e08e89ca>] mpt_attach+0x881/0x9b1 [mptbase] [<e091c8e5>] mptspi_probe+0x11/0x354 [mptspi] Noticing that every caller of mpt_config has its CONFIGPARMS struct declared on the stack and thus the &pCfg->timer is always on the stack I changed init_timer() to init_timer_on_stack() and it seems to have shut up..... Cc: "Moore, Eric Dean" <Eric.Moore@lsil.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: Thomas Gleixner <tglx@linutronix.de> Acked-by: "Desai, Kashyap" <Kashyap.Desai@lsi.com> Cc: <stable@kernel.org> [2.6.29.x] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-21sgi-xp/sgi-gru: allow modules to load on non-uv systemsRobin Holt
For an upcoming distro release, we need to have the xp kernel module loadable even when not on UV equipment. The xpc module will not load. This will allow one set of modules dependent upon xp to work on either UV or non-UV equipment. Signed-off-by: Robin Holt <holt@sgi.com> Signed-off-by: Jack Steiner <steiner@sgi.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-21uml: kill a kconfig warningWANG Cong
Got this warning from Kconfig: boolean symbol INPUT tested for 'm'? test forced to 'n' because INPUT is tristate, not bool. Signed-off-by: WANG Cong <xiyou.wangcong@gmail.com> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-21frv: insert PCI root bus resources for the MB93090 devel motherboardDavid Howells
Insert PCI root bus resources for the FRV-based MB93090 development kit motherboard. This is required because the CPU's window onto the PCI bus address space is considerably smaller than the CPU's full address space and non-PCI devices lie outside of the PCI window that we might want to access. Without this patch, the PCI root bus uses the platform-level bus resources, and these are then confined to the PCI window, thus making platform_device_add() reject devices outside of this window. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-21rtc-cmos: fix printk outputKrzysztof Halasa
With no IRQ available/defined, RTC-CMOS driver prints something like: rtc0: alarms up to one no, y3k, 114 bytes nvram ^^^^ I guess the following is a bit easier to understand: rtc0: no alarms, y3k, 114 bytes nvram Signed-off-by: Krzysztof Halasa <khc@pm.waw.pl> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-21spi: documentation: emphasise spi_master.setup() semanticsDavid Brownell
This is a doc-only patch which I hope will reduce the number of spi_master controller driver patches starting out with a common implementation bug. (As in: almost every spi_master driver I see starts out with its version of this bug. Sigh.) It just re-emphasizes that the setup() method may be called for one device while a transfer is active on another ... which means that most driver implementations shouldn't touch any registers. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-21MAINTAINERS: add a more searchable string for the H8300 architecture.Robert P. J. Day
Add a parenthesized string of "H8300" for more convenient searchability in the MAINTAINERS file. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-21MAINTAINERS: add Matt Mackall to embedded maintainersMatt Mackall
Impact: make more work for myself Signed-off-by: Matt Mackall <mpm@selenic.com> Cc: David Woodhouse <dwmw2@infradead.org> Acked-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-21spi: pxa2xx: limit reaches -1Roel Kluin
On line 944 the return value of flush() is considered as a boolean, but limit reaches -1 upon timeout which evaluates to true. On 540, 594, 720 the same occurs for wait_ssp_rx_stall() On 536 the same occurs for wait_dma_channel_stop() Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Acked-by: Eric Miao <eric.miao@marvell.com> Cc: David Brownell <david-b@pacbell.net> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-21MAINTAINERS: update KMEMTRACE pattern after file renameJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Acked-by: Eduard - Gabriel Munteanu <eduard.munteanu@linux360.ro> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-21MAINTAINERS: remove include/asm-*/suspend* file patternsJoe Perches
There are no more arches with suspend support using these directories. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-21pxa2xx_spi: restore DRCMR on resumeDaniel Ribeiro
If DMA is enabled, any spi_sync call after suspend/resume would block forever, because DRCMR is lost on suspend. This patch restores DRCMR to the same values set by probe. Signed-off-by: Daniel Ribeiro <drwyrm@gmail.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-21drivers/input/serio/hp_sdc.c: fix crash when removing hp_sdc moduleHelge Deller
On parisc machines, which don't have HIL, removing the hp_sdc module panics the kernel. Fix this by returning early in hp_sdc_exit() if no HP SDC controller was found. Add functionality to probe for the hp_sdc_mlc kernel module (which takes care of the upper layer HIL functionality on parisc) after two seconds. This is needed to get all the other HIL drivers (keyboard / mouse/ ..) drivers automatically loaded by udev later as well. Signed-off-by: Helge Deller <deller@gmx.de> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Frans Pop <elendil@planet.nl> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Grant Grundler <grundler@parisc-linux.org> Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-21memcg: use rcu_dereference to access mm->ownerKAMEZAWA Hiroyuki
mm->owner should be accessed with rcu_dereference(). Reported-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-21hugetlbfs: return negative error code for bad mount optionAkinobu Mita
This fixes the following BUG: # mount -o size=MM -t hugetlbfs none /huge hugetlbfs: Bad value 'MM' for mount option 'size=MM' ------------[ cut here ]------------ kernel BUG at fs/super.c:996! Due to BUG_ON(!mnt->mnt_sb); in vfs_kern_mount(). Also, remove unused #include <linux/quotaops.h> Cc: William Irwin <wli@holomorphy.com> Cc: <stable@kernel.org> Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-21ipmi: add oem message handlingdann frazier
Enable userspace to receive messages that a BMC transmits using an OEM medium. This is used by the HP iLO2. Based on code originally written by Patrick Schoeller. Signed-off-by: dann frazier <dannf@hp.com> Signed-off-by: Corey Minyard <cminyard@mvista.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-21ipmi: fix statistics counting issuesCorey Minyard
Bela Lubkin noticed that the statistics for send IPMB and LAN commands in the IPMI driver could be incremented even if an error occurred. Move the increments to the proper place to avoid this. Also add some statistics for retransmissions that failed, and some little helper functions to neaten up the code a little. Signed-off-by: Corey Minyard <cminyard@mvista.com> Cc: Bela Lubkin <blubkin@vmware.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-21ipmi: test for event buffer before usingCorey Minyard
The IPMI driver would attempt to use the event buffer even if that didn't exist on the BMC. This patch modified the IPMI driver to check for the event buffer's existence before trying to use it. Signed-off-by: Corey Minyard <minyard@acm.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-21ipmi: fix platform return checkCorey Minyard
The wrong return value is being tested when allocating a platform device in the IPMI SI code. Check the right value. Signed-off-by: Corey Minyard <minyard@acm.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-21clocksource: add enable() and disable() callbacksMagnus Damm
Add enable() and disable() callbacks for clocksources. This allows us to put unused clocksources in power save mode. The functions clocksource_enable() and clocksource_disable() wrap the callbacks and are inserted in the timekeeping code to enable before use and disable after switching to a new clocksource. Signed-off-by: Magnus Damm <damm@igel.co.jp> Acked-by: John Stultz <johnstul@us.ibm.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-21clocksource: pass clocksource to read() callbackMagnus Damm
Pass clocksource pointer to the read() callback for clocksources. This allows us to share the callback between multiple instances. [hugh@veritas.com: fix powerpc build of clocksource pass clocksource mods] [akpm@linux-foundation.org: cleanup] Signed-off-by: Magnus Damm <damm@igel.co.jp> Acked-by: John Stultz <johnstul@us.ibm.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-21pxafb: lcsr1 is unused without CONFIG_FB_PXA_OVERLAYDenis V. Lunev
Fixes the warning: drivers/video/pxafb.c: In function 'pxafb_handle_irq': drivers/video/pxafb.c:1442: warning: unused variable 'lcsr1' [akpm@linux-foundation.org: save an ifdef] Signed-off-by: Denis V. Lunev <den@openvz.org> Cc: Eric Miao <eric.miao@marvell.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-21asiliantfb: add missing return statementVlada Peric
Commit 032220ba (asiliantfb: fix cmap memory leaks) changed the function init_asiliant from void to int, resulting in the following compile warning: drivers/video/asiliantfb.c: In function `init_asiliant': drivers/video/asiliantfb.c:536: warning: control reaches end of non-void function Fix the warning by returning 0. Signed-off-by: Vlada Peric <vlada.peric@gmail.com> Cc: Andres Salomon <dilinger@debian.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-21go7007: Convert to the new i2c device binding modelJean Delvare
Move the go7007 driver away from the legacy i2c binding model, which is going away really soon now. The I2C addresses of the audio and video chips in s2250-board didn't look quite right, apparently they were left-aligned values when Linux wants right-aligned values, so I fixed them too. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Greg Kroah-Hartman <gregkh@suse.de>
2009-04-21Btrfs: fix btrfs fallocate oops and deadlockChris Mason
Btrfs fallocate was incorrectly starting a transaction with a lock held on the extent_io tree for the file, which could deadlock. Strictly speaking it was using join_transaction which would be safe, but it is better to move the transaction outside of the lock. When preallocated extents are overwritten, btrfs_mark_buffer_dirty was being called on an unlocked buffer. This was triggering an assertion and oops because the lock is supposed to be held. The bug was calling btrfs_mark_buffer_dirty on a leaf after btrfs_del_item had been run. btrfs_del_item takes care of dirtying things, so the solution is a to skip the btrfs_mark_buffer_dirty call in this case. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-04-21Merge git://git.kernel.org/pub/scm/linux/kernel/git/steve/gfs2-2.6-fixesLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/steve/gfs2-2.6-fixes: GFS2: Fix page_mkwrite() return code GFS2: Clear dirty bit at end of inode glock sync
2009-04-21Merge branch 'sh/for-2.6.30' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6 * 'sh/for-2.6.30' of git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6: sh: Fix mmap2 for handling differing PAGE_SIZEs. sh: sh7723: Don't default enable the RTC clock. sh: sh7722: Don't default enable the RTC clock. rtc: rtc-sh: clock framework support.
2009-04-21Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: reiserfs: fix j_last_flush_trans_id type fs: Mark get_filesystem_list() as __init function. kill vfs_stat_fd / vfs_lstat_fd Separate out common fstatat code into vfs_fstatat ecryptfs: use memdup_user() ncpfs: use memdup_user() xfs: use memdup_user() sysfs: use memdup_user() btrfs: use memdup_user() xattr: use memdup_user() autofs4: use memchr() in invalid_string() Documentation/filesystems: remove out of date reference to BKL being held Fix i_mutex vs. readdir handling in nfsd fs/compat_ioctl: fix build when !BLOCK Fix autofs_expire() No need for crossing to mountpoint in audit_tag_tree() Safer nfsd_cross_mnt() Touch all affected namespaces on propagation of mount Fix AUTOFS_DEV_IOCTL_REQUESTER_CMD
2009-04-21Fix SYSCALL_ALIAS for older MIPS assemblerThomas Bogendoerfer
Older MIPS assembler don't support .set for defining aliases. Using = works for old and new assembers. Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Acked-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-21NFS: Fix the XDR iovec calculation in nfs3_xdr_setaclargsTrond Myklebust
Commit ae46141ff08f1965b17c531b571953c39ce8b9e2 (NFSv3: Fix posix ACL code) introduces a bug in the calculation of the XDR header iovec. In the case where we are inlining the acls, we need to adjust the length of the iovec req->rq_svec, in addition to adjusting the total buffer length. Tested-by: Leonardo Chiquitto <leonardo.lists@gmail.com> Tested-by: Suresh Jayaraman <sjayaraman@suse.de> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-21Merge branch 'sh/stable-updates' into sh/for-2.6.30Paul Mundt
2009-04-20reiserfs: fix j_last_flush_trans_id typeAl Viro
Conversion in commit 600ed41675d8c384519d8f0b3c76afed39ef2f4b had missed that one, but converted format from %lu to %u. As the result, /proc/..../journal got buggered on 64bit boxen. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-04-20fs: Mark get_filesystem_list() as __init function.Tetsuo Handa
"int get_filesystem_list(char * buf)" is called by only "static void __init get_fs_names(char *page)". We can mark get_filesystem_list() as "__init". Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-04-20kill vfs_stat_fd / vfs_lstat_fdChristoph Hellwig
There's really no reason to keep vfs_stat_fd and vfs_lstat_fd with Oleg's vfs_fstatat. Use vfs_fstatat for the few cases having the directory fd, and switch all others to vfs_stat / vfs_lstat. Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-04-20Separate out common fstatat code into vfs_fstatatOleg Drokin
This is a version incorporating Christoph's suggestion. Separate out common *fstatat functionality into a single function instead of duplicating it all over the code. Signed-off-by: Oleg Drokin <green@linuxhacker.ru> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
