2009-12-09Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid: HID: add multi-input quirk for NextWindow Touchscreen. HID: add support for Acan FG-8100 barcode reader HID: make Media key on Logitech DiNovo Mini work HID: support Logitech/3DConnexion SpaceTraveler and SpaceNavigator HID: remove BKL from hiddev_ioctl_usage() HID: fixup quirk for NCR devices HID: pidff - fix unnecessary loop iterations on reset HID: add NOGET quirk for another device from CH Products HID: remove useless DRIVER_VERSION macro HID: fix MODULE_AUTHOR usage in HID modules HID: blacklist Acer Ferrari 4005 optical mouse
2009-12-09Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (222 commits) [SCSI] zfcp: Remove flag ZFCP_STATUS_FSFREQ_TMFUNCNOTSUPP [SCSI] zfcp: Activate fc4s attributes for zfcp in FC transport class [SCSI] zfcp: Block scsi_eh thread for rport state BLOCKED [SCSI] zfcp: Update FSF error reporting [SCSI] zfcp: Improve ELS ADISC handling [SCSI] zfcp: Simplify handling of ct and els requests [SCSI] zfcp: Remove ZFCP_DID_MASK [SCSI] zfcp: Move WKA port to zfcp FC code [SCSI] zfcp: Use common code definitions for FC CT structs [SCSI] zfcp: Use common code definitions for FC ELS structs [SCSI] zfcp: Update FCP protocol related code [SCSI] zfcp: Dont fail SCSI commands when transitioning to blocked fc_rport [SCSI] zfcp: Assign scheduled work to driver queue [SCSI] zfcp: Remove STATUS_COMMON_REMOVE flag as it is not required anymore [SCSI] zfcp: Implement module unloading [SCSI] zfcp: Merge trace code for fsf requests in one function [SCSI] zfcp: Access ports and units with container_of in sysfs code [SCSI] zfcp: Remove suspend callback [SCSI] zfcp: Remove global config_mutex [SCSI] zfcp: Replace local reference counting with common kref ...
git://git.kernel.org/pub/scm/linux/kernel/git/gerg/m68knommu * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gerg/m68knommu: m68knommu: export clk_* symbols in clk.c m68knommu: Split the .init section into INIT_TEXT_SECTION and INIT_DATA_SECTION. m68knommu: Move __init_end out of the .init section. m68knommu: Move __init_begin out of the .init section. m68knommu: Use more macros inside the .init section. m68knommu: Use INIT_TASK_DATA and CACHELINE_ALIGNED_DATA. m68knommu: Make THREAD_SIZE available to assembly files. m68knommu: Don't hardcode the value of PAGE_SIZE in the linker script. m68knommu: rename BSS define in linker script m68knommu: add a task_pt_regs() macro m68knommu: define arch_has_single_step() and friends m68knommu: add uboot commandline argument passing support m68knommu: Coldfire GPIO corrections m68knommu: move mcf_remove to .devexit.text Fixed up (?) conflict in arch/m68k/include/asm/ptrace.h
2009-12-09Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6: [IA64] Fix cut/paste detritus from unistd.h
2009-12-09Merge git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6: (137 commits) sh: include empty zero page in romImage sh: Make associative cache writes fatal on all SH-4A parts. sh: Drop associative writes for SH-4 cache flushes. sh: Partial revert of copy/clear_user_highpage() optimizations. sh: Add default uImage rule for se7724, ap325rxa, and migor. sh: allow runtime pm without suspend/resume callbacks sh: mach-ecovec24: Remove un-defined settings for VPU sh: mach-ecovec24: LCDC drive ability become high sh: fix sh7724 VEU3F resource size serial: sh-sci: Fix too early port disabling. sh: pfc: pr_info() -> pr_debug() cleanups. sh: pfc: Convert from ctrl_xxx() to __raw_xxx() I/O routines. sh: Improve kfr2r09 serial port setup code sh: Break out SuperH PFC code sh: Move KEYSC header file sh: convert /proc/cpu/aligmnent, /proc/cpu/kernel_alignment to seq_file sh: Add CPG save/restore code for sh7724 R-standby sh: Add SDHI power control support to Ecovec mfd: Add power control platform data to SDHI driver sh: mach-ecovec24: modify address map ...
2009-12-09Merge branch 'davinci-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/khilman/linux-davinci * 'davinci-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/khilman/linux-davinci: (69 commits) davinci: Initial support for Neuros OSD2 platform. davinci: remove unused variable in arch/arm/mach-davinci/board-sffsdr.c davinci: fix section mismatch warning in arch/arm/mach-davinci/board-dm646x-evm.c DaVinci: DM365: Enable DaVinci RTC support for DM365 EVM DA8xx/OMAP-L1xx: Add high speed SD/MMC capabilities davinci: DA8XX/OMAP-L1XX: enable cpuidle and regulator in defconfig davinci: DA850/OMAP-L138: avoid using separate initcall for initializing regulator davinci: DA850/OMAP-L138 EVM: register for cpuidle support davinci: DA8XX/OMAP-L1XX: add support for cpuidle driver register davinci: add CPU idle driver davinci: DA8XX/OMAP-L1XX: fix compiler warning davinci: DA850/OMAP-L138: eliminate static function declaration davinci: DA850/OMAP-L138 EVM: simplify configuration of emac in MII/RMII mode davinci: DA850/OMAP-L138 EVM: get rid of DA850_UI_EXP config option davinci: DA850/OMAP-L138 EVM: implement autodetect of RMII PHY davinci: DA830/OMAP-L137 EVM: do not configure NAND on UI card when MMC/SD is selected davinci: DA830/OMAP-L137 EVM: use runtime detection for UI card davinci: DA830/OMAP-L137 EVM: remove ifdefs inside da830_evm_init() davinci: DA830/OMAP-L137 EVM: fix warning with default config davinci: Add NAND support for DA830/OMAP-L137 EVM platform ...
2009-12-09Merge branch 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6Linus Torvalds
* 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6: (72 commits) [S390] 3215/3270 console: remove wrong comment [S390] dasd: remove BKL from extended error reporting code [S390] vmlogrdr: remove BKL [S390] vmur: remove BKL [S390] zcrypt: remove BKL [S390] 3270: remove BKL [S390] vmwatchdog: remove lock_kernel() from open() function [S390] monwriter: remove lock_kernel() from open() function [S390] monreader: remove lock_kernel() from open() function [S390] s390: remove unused nfsd #includes [S390] ftrace: build ftrace.o when CONFIG_FTRACE_SYSCALLS is set for s390 [S390] etr/stp: put correct per cpu variable [S390] tty3270: move keyboard compat ioctls [S390] sclp: improve servicability setting [S390] s390: use change recording override for kernel mapping [S390] MAINTAINERS: Add s390 drivers block [S390] use generic sockios.h header file [S390] use generic termbits.h header file [S390] smp: remove unused typedef and defines [S390] cmm: free pages on hibernate. ...
2009-12-09Doc: use misc-devices/ dir for driversJean Delvare
We have a directory for misc drivers documentation, let's use it. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: "Darrick J. Wong" <djwong@us.ibm.com> Cc: Rodolfo Giometti <giometti@linux.it> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-09Doc: better explanation of procs_runningLuis Garces-Erice
the description in Documentation/filesystems/proc.txt of the procs_running entry in /proc/stat is confusing (according to that description, it looks as if procs_running could only be a number between 0 and the number of CPUs). Changed it to a more accurate description in the patch attached. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-09correct gpio.txt typosDominik D. Geyer
Corrected sysfs gpio chip node name and fixed punctuation. Signed-off-by: Dominik D. Geyer <dominik.geyer@gmx.de> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-09docbook: fix signal_pending() argumentShawn Bohrer
Since signal_pending() takes a task_struct pointer as an argument, update the example to pass in 'current'. Signed-off-by: Shawn Bohrer <shawn.bohrer@gmail.com> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-09use DMA_BIT_MASK instead of inline constantMarin Mitov
Use DMA_BIT_MASK(24) instead of 0x00ffffff in DMA-mapping.txt Signed-off-by: Marin Mitov <mitov@issp.bas.bg> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-09Use KERN_WARNING instead of KERN_WARN, which does not existRandy Dunlap
Reported-by: Andrew Lyon <andrew.lyon@gmail.com> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-09nvram: Fix missing smp_lock.h in nvramFrederic Weisbecker
The bkl has been removed from nvram_llseek() and smp_lock.h was removed because another patch in the same tree zapped the remaining usage of bkl in the same file. But this patch must have been excluded later, then we still need the smp_lock.h headers for the bkl use in nvram_open(). This fixes the following build error: drivers/char/nvram.c: In function ‘nvram_open’: drivers/char/nvram.c:332: erreur: implicit declaration of function ‘lock_kernel’ drivers/char/nvram.c:339: erreur: implicit declaration of function ‘unlock_kernel’ make[2]: *** [drivers/char/nvram.o] Erreur 1 make[1]: *** [drivers/char] Erreur 2 make: *** [drivers] Erreur 2 Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-09Merge branch 'bkl-arch-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'bkl-arch-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: mn10300: Remove the BKL from sys_execve m68knommu: Remove the BKL from sys_execve m68k: Remove the BKL from sys_execve h83000: Remove BKL from sys_execve frv: Remove the BKL from sys_execve blackfin: Remove the BKL from sys_execve um: Remove BKL from mmapper um: Remove BKL from random s390: Remove BKL from prng
2009-12-09Merge branch 'bkl-drivers-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'bkl-drivers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: agp: Remove the BKL from agp_open inifiband: Remove BKL from ipath_open() mips: Remove BKL from tb0219 drivers: Remove BKL from scx200_gpio drivers: Remove BKL from pc8736x_gpio parisc: Remove BKL from eisa_eeprom rtc: Remove BKL from efirtc input: Remove BKL from hp_sdc_rtc hw_random: Remove BKL from core macintosh: Remove BKL from ans-lcd nvram: Drop the bkl from non-generic nvram_llseek() nvram: Drop the bkl from nvram_llseek() mem_class: Drop the bkl from memory_open() spi: Remove BKL from spidev_open drivers: Remove BKL from cs5535_gpio drivers: Remove BKL from misc_open
2009-12-09Merge branch 'bkl-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'bkl-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: sys: Remove BKL from sys_reboot pm_qos: clean up racy global "name" variable pm_qos: remove BKL
2009-12-09Merge branch 'reiserfs/kill-bkl' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/frederic/random-tracing * 'reiserfs/kill-bkl' of git://git.kernel.org/pub/scm/linux/kernel/git/frederic/random-tracing: (31 commits) kill-the-bkl/reiserfs: turn GFP_ATOMIC flag to GFP_NOFS in reiserfs_get_block() kill-the-bkl/reiserfs: drop the fs race watchdog from _get_block_create_0() kill-the-bkl/reiserfs: definitely drop the bkl from reiserfs_ioctl() kill-the-bkl/reiserfs: always lock the ioctl path kill-the-bkl/reiserfs: fix reiserfs lock to cpu_add_remove_lock dependency kill-the-bkl/reiserfs: Fix induced mm->mmap_sem to sysfs_mutex dependency kill-the-bkl/reiserfs: panic in case of lock imbalance kill-the-bkl/reiserfs: fix recursive reiserfs write lock in reiserfs_commit_write() kill-the-bkl/reiserfs: fix recursive reiserfs lock in reiserfs_mkdir() kill-the-bkl/reiserfs: fix "reiserfs lock" / "inode mutex" lock inversion dependency kill-the-bkl/reiserfs: move the concurrent tree accesses checks per superblock kill-the-bkl/reiserfs: acquire the inode mutex safely kill-the-bkl/reiserfs: unlock only when needed in search_by_key kill-the-bkl/reiserfs: use mutex_lock in reiserfs_mutex_lock_safe kill-the-bkl/reiserfs: factorize the locking in reiserfs_write_end() kill-the-bkl/reiserfs: reduce number of contentions in search_by_key() kill-the-bkl/reiserfs: don't hold the write recursively in reiserfs_lookup() kill-the-bkl/reiserfs: lock only once on reiserfs_get_block() kill-the-bkl/reiserfs: conditionaly release the write lock on fs_changed() kill-the-BKL/reiserfs: add reiserfs_cond_resched() ...
2009-12-08Merge branches 'timers-for-linus-ntp' and 'irq-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-for-linus-ntp' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: ntp: Provide compability defines (You say MOD_NANO, I say ADJ_NANO) * 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: genirq: do not execute DEBUG_SHIRQ when irq setup failed
2009-12-08Merge branch 'timers-for-linus-urgent' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-for-linus-urgent' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: hrtimer: Fix /proc/timer_list regression itimers: Fix racy writes to cpu_itimer fields timekeeping: Fix clock_gettime vsyscall time warp
2009-12-08Merge branch 'timers-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: timers, init: Limit the number of per cpu calibration bootup messages posix-cpu-timers: optimize and document timer_create callback clockevents: Add missing include to pacify sparse x86: vmiclock: Fix printk format x86: Fix printk format due to variable type change sparc: fix printk for change of variable type clocksource/events: Fix fallout of generic code changes nohz: Allow 32-bit machines to sleep for more than 2.15 seconds nohz: Track last do_timer() cpu nohz: Prevent clocksource wrapping during idle nohz: Type cast printk argument mips: Use generic mult/shift factor calculation for clocks clocksource: Provide a generic mult/shift factor calculation clockevents: Use u32 for mult and shift factors nohz: Introduce arch_needs_cpu nohz: Reuse ktime in sub-functions of tick_check_idle. time: Remove xtime_cache time: Implement logarithmic time accumulation
2009-12-08Merge branch 'timers-for-linus-hpet' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-for-linus-hpet' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86: hpet: Make WARN_ON understandable x86: arch specific support for remapping HPET MSIs intr-remap: generic support for remapping HPET MSIs x86, hpet: Simplify the HPET code x86, hpet: Disable per-cpu hpet timer if ARAT is supported
2009-12-08Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: hwrng: core - Prevent too-small buffer sizes hwrng: virtio-rng - Convert to new API hwrng: core - Replace u32 in driver API with byte array crypto: ansi_cprng - Move FIPS functions under CONFIG_CRYPTO_FIPS crypto: testmgr - Add ghash algorithm test before provide to users crypto: ghash-clmulni-intel - Put proper .data section in place crypto: ghash-clmulni-intel - Use gas macro for PCLMULQDQ-NI and PSHUFB crypto: aesni-intel - Use gas macro for AES-NI instructions x86: Generate .byte code for some new instructions via gas macro crypto: ghash-intel - Fix irq_fpu_usable usage crypto: ghash-intel - Add PSHUFB macros crypto: ghash-intel - Hard-code pshufb crypto: ghash-intel - Fix building failure on x86_32 crypto: testmgr - Fix warning crypto: ansi_cprng - Fix test in get_prng_bytes crypto: hash - Remove cra_u.{digest,hash} crypto: api - Remove digest case from procfs show handler crypto: hash - Remove legacy hash/digest code crypto: ansi_cprng - Add FIPS wrapper crypto: ghash - Add PCLMULQDQ accelerated implementation
2009-12-08Merge git://git.kernel.org/pub/scm/linux/kernel/git/wim/linux-2.6-watchdogLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/wim/linux-2.6-watchdog: [WATCHDOG] iTCO_wdt.c - cleanup chipset documentation [WATCHDOG] iTCO_wdt: Add support for Intel Ibex Peak [WATCHDOG] CPUFREQ: S3C24XX Watchdog frequency scaling support.
2009-12-08[IA64] Fix cut/paste detritus from unistd.hTony Luck
Build warning: <stdin>:1523:2: warning: #warning syscall recvmmsg not implemented Because when recvmmesg was added, the previous syscall define was cut&pasted, and a spurious "rt_" left in the name of the define. Signed-off-by: Tony Luck <tony.luck@intel.com>
2009-12-08Merge branch 'x86-xen-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-xen-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: cpumask: Use modern cpumask style in Xen
2009-12-08Merge branch 'x86-uv-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-uv-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86: UV RTC: Always enable RTC clocksource x86: UV RTC: Rename generic_interrupt to x86_platform_ipi x86: UV RTC: Clean up error handling x86: UV RTC: Add clocksource only boot option x86: UV RTC: Fix early expiry handling
2009-12-08Merge branch 'x86-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, mce: don't restart timer if disabled x86: Use -maccumulate-outgoing-args for sane mcount prologues x86: Prevent GCC 4.4.x (pentium-mmx et al) function prologue wreckage x86: AMD Northbridge: Verify NB's node is online x86 VSDO: Fix Kconfig help x86: Fix typo in Intel CPU cache size descriptor x86: Add new Intel CPU cache size descriptors
2009-12-08Merge branch 'x86-setup-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-setup-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: vgacon: Add support for setting the default cursor state vc: Add support for hiding the cursor when creating VTs x86, setup: Store the boot cursor state
2009-12-08Merge branch 'x86-reboot-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-reboot-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86/reboot: Add pci_dev_put in reboot_fixup_32.c for consistency
2009-12-08Merge branch 'x86-process-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-process-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86-64: merge the standard and compat start_thread() functions x86-64: make compat_start_thread() match start_thread()
2009-12-08Merge branch 'x86-pat-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-pat-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86: pat: Remove ioremap_default() x86: pat: Clean up req_type special case for reserve_memtype() x86: Relegate CONFIG_PAT and CONFIG_MTRR configurability to EMBEDDED
2009-12-08Merge branch 'x86-mm-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-mm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (36 commits) x86, mm: Correct the implementation of is_untracked_pat_range() x86/pat: Trivial: don't create debugfs for memtype if pat is disabled x86, mtrr: Fix sorting of mtrr after subtracting x86: Move find_smp_config() earlier and avoid bootmem usage x86, platform: Change is_untracked_pat_range() to bool; cleanup init x86: Change is_ISA_range() into an inline function x86, mm: is_untracked_pat_range() takes a normal semiclosed range x86, mm: Call is_untracked_pat_range() rather than is_ISA_range() x86: UV SGI: Don't track GRU space in PAT x86: SGI UV: Fix BAU initialization x86, numa: Use near(er) online node instead of roundrobin for NUMA x86, numa, bootmem: Only free bootmem on NUMA failure path x86: Change crash kernel to reserve via reserve_early() x86: Eliminate redundant/contradicting cache line size config options x86: When cleaning MTRRs, do not fold WP into UC x86: remove "extern" from function prototypes in <asm/proto.h> x86, mm: Report state of NX protections during boot x86, mm: Clean up and simplify NX enablement x86, pageattr: Make set_memory_(x|nx) aware of NX support x86, sleep: Always save the value of EFER ... Fix up conflicts (added both iommu_shutdown and is_untracked_pat_range) to 'struct x86_platform_ops') in arch/x86/include/asm/x86_init.h arch/x86/kernel/x86_init.c
2009-12-08Merge branch 'x86-microcode-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-microcode-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86: ucode-amd: Move family check to microcde_amd.c's init function x86, ucode-amd: Ensure ucode update on suspend/resume after CPU off/online cycle x86: ucode-amd: Convert printk(KERN_*...) to pr_*(...) x86: ucode-amd: Don't warn when no ucode is available for a CPU revision x86: ucode-amd: Load ucode-patches once and not separately of each CPU x86, amd-ucode: Remove needless log messages
2009-12-08Merge branch 'x86-entry-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-entry-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: core: Clean up user return notifers use of per_cpu
2009-12-08sysfs: deprecated features are to help old tools not to confuse themUwe Kleine-König
Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Greg KH <gregkh@suse.de> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-08sctp: fix compile error due to sysctl mismergeLinus Torvalds
I messed up the merge in d7fc02c7bae7b1cf69269992cf880a43a350cdaa, where the conflict in question wasn't just about CTL_UNNUMBERED being removed, but the 'strategy' field is too (sysctl handling is now done through the /proc interface, with no duplicate protocols for reading the data). Reported-by: Larry Finger <Larry.Finger@lwfinger.net> Reported-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-08Merge branch 'for-2.6.33' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.33' of git://git.kernel.dk/linux-2.6-block: (113 commits) cfq-iosched: Do not access cfqq after freeing it block: include linux/err.h to use ERR_PTR cfq-iosched: use call_rcu() instead of doing grace period stall on queue exit blkio: Allow CFQ group IO scheduling even when CFQ is a module blkio: Implement dynamic io controlling policy registration blkio: Export some symbols from blkio as its user CFQ can be a module block: Fix io_context leak after failure of clone with CLONE_IO block: Fix io_context leak after clone with CLONE_IO cfq-iosched: make nonrot check logic consistent io controller: quick fix for blk-cgroup and modular CFQ cfq-iosched: move IO controller declerations to a header file cfq-iosched: fix compile problem with !CONFIG_CGROUP blkio: Documentation blkio: Wait on sync-noidle queue even if rq_noidle = 1 blkio: Implement group_isolation tunable blkio: Determine async workload length based on total number of queues blkio: Wait for cfq queue to get backlogged if group is empty blkio: Propagate cgroup weight updation to cfq groups blkio: Drop the reference to queue once the task changes cgroup blkio: Provide some isolation between groups ...
2009-12-08Merge branch 'upstream-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev * 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev: (54 commits) Revert "pata_sis: Implement MWDMA for the UDMA 133 capable chips" libata: Clarify ata_set_lba_range_entries function libata: Report zeroed read after TRIM and max discard size pata_hpt3x2n: fix overclocked MWDMA0 timing pata_it8213: MWDMA0 is unsupported [libata] MWDMA0 is unsupported on PIIX-like PATA controllers pata_via: clear UDMA transfer mode bit for PIO and MWDMA pata_sis: Power Management fix pata_rz1000: Power Management fix pata_radisys: fix UDMA handling pata_ns87415: Power Management fix pata_marvell: fix marvell_pre_reset() documentation pata_legacy: add pointers to QDI65x0 documentation pata_legacy: fix access to control register for QDI6580 pata_legacy: fix QDI6580DP support pata_it8213: fix it8213_pre_reset() documentation pata_it8213: fix wrong MWDMA timings being programmed pata_it8213: fix PIO2 underclocking pata_it8213: fix wrong PIO timings being programmed pata_it8213: fix UDMA handling ...
2009-12-08Merge branch 'omap-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6 * 'omap-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6: (149 commits) arm: omap: Add omap3_defconfig AM35xx: Defconfig for AM3517 EVM board AM35xx: Add support for AM3517 EVM board omap: 3630sdp: defconfig creation omap: 3630sdp: introduce 3630 sdp board support omap3: Add defconfig for IGEP v2 board omap3: Add minimal IGEP v2 support omap3: Add CompuLab CM-T35 defconfig omap3: Add CompuLab CM-T35 board support omap3: rx51: Add wl1251 wlan driver support omap3: rx51: Add SDRAM init omap1: Add default kernel configuration for Herald omap1: Add board support and LCD for HTC Herald omap: zoom2: update defconfig for LL_DEBUG_NONE omap: zoom3: defconfig creation omap3: zoom: Introduce zoom3 board support omap3: zoom: Drop i2c-1 speed to 2400 omap3: zoom: rename zoom2 name to generic zoom omap3: zoom: split board file for software reuse omap3evm: MIgrate to smsc911x ethernet driver ... Fix trivial conflict (two unrelated config options added next to each other) in arch/arm/mach-omap2/Makefile
2009-12-08Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k: m68k: parport_mfc3 - Not makes it a bool before the comparison. m68k: don't export static inline functions fbdev: atafb - add palette register check m68k: Remove the BKL from sys_execve m68k: Cleanup linker scripts using new linker script macros. m68k: Make thread_info.h usable from assembly. m68knommu: define arch_has_single_step() and friends m68k: ptrace fixes m68k: use generic code for ptrace requests rtc: Add an RTC driver for the Ricoh RP5C01 rtc: Add an RTC driver for the Oki MSM6242
git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6: ieee1394: Use hweight32 firewire: cdev: reduce stack usage by ioctl_dispatch firewire: ohci: 0 may be a valid DMA address firewire: core: WARN on wrong usage of core transaction functions firewire: core: optimize Topology Map creation firewire: core: clarify generate_config_rom usage firewire: optimize config ROM creation firewire: cdev: normalize variable names firewire: normalize style of queue_work wrappers firewire: cdev: fix memory leak in an error path
2009-12-08Merge branch 'devel' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'devel' of master.kernel.org:/home/rmk/linux-2.6-arm: (272 commits) Fix soc_common PCMCIA configuration ARM: 5827/1: SA1100: h3100/h3600: emit messages on failed gpio_request ARM: 5826/1: SA1100: h3100/h3600: always build htc-egpio driver ARM: 5825/1: SA1100: h3600: update defconfig ARM: 5824/1: SA1100: reuse h3600 PCMCIA driver on h3100 ARM: 5823/1: SA1100: h3100/h3600: add support for gpio-keys ARM: 5822/1: SA1100: h3100/h3600: clean up #includes ARM: 5821/1: SA1100: h3100/h3600: revise copyright boilerplates ARM: 5820/1: SA1100: h3100/h3600: split h3600.c ARM: 5819/1: SA1100: h3100/h3600: merge h3600.h and h3600_gpio.h into h3xxx.h ARM: 5818/1: SA1100: h3100/h3600: drop old GPIO definitions ARM: 5817/1: SA1100: h3100/h3600: configure all unused gpios as inputs ARM: 5816/1: SA1100: h3600: remove IRQ_GPIO_* definitions ARM: 5815/1: SA1100: h3100/h3600: remove now unused assign_h3600_egpio handlers ARM: 5814/1: SA1100: h3100/h3600: convert all users of assign_h3600_egpio to gpiolib ARM: 5813/1: SA1100: h3100/h3600: add htc-egpio driver ARM: 5812/1: SA1100: h3100/h3600: separate machine-specific LCD helpers ARM: 5811/2: pcmcia: convert sa1100_h3600 driver to gpiolib ARM: 5799/1: SA1100: h3600: stop setting direction for LCD pins ARM: 5798/1: SA1100: h3600: remove unused cruft from h3600.h ...
2009-12-08Merge branch 'i2c-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging * 'i2c-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging: i2c-stub: Documentation update i2c-stub: Allow user to disable some commands i2c-stub: Implement I2C block support i2c: Refactor for_each callbacks i2c-i801: Retry on lost arbitration i2c: Remove big kernel lock from i2cdev_open ics932s401: Clean up detect function i2c: Simplify i2c_detect_address i2c: Drop probe, ignore and force module parameters i2c: Add missing __devinit markers to old i2c adapter drivers i2c: Bus drivers don't have to support I2C_M_REV_DIR_ADDR i2c: Prevent priority inversion on top of bus lock i2c-voodoo3: Delete i2c-powermac: Drop temporary name buffer i2c-powermac: Include the i2c_adapter in struct pmac_i2c_bus i2c-powermac: Log errors i2c-powermac: Refactor i2c_powermac_smbus_xfer i2c-powermac: Reject unsupported I2C transactions i2c/chips: Move ds1682 to drivers/misc
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6: PM: Add flag for devices capable of generating run-time wake-up events PM / Runtime: Remove unnecessary braces in __pm_runtime_set_status() PM / Runtime: Make documentation of runtime_idle() agree with the code PM / Runtime: Ensure timer_expires is nonzero in pm_schedule_suspend() PM / Runtime: Use deferred_resume flag in pm_request_resume PM / Runtime: Export the PM runtime workqueue PM / Runtime: Fix lockdep warning in __pm_runtime_set_status() PM / Hibernate: Swap, use KERN_CONT PM / Hibernate: Shift remaining code from swsusp.c to hibernate.c PM / Hibernate: Move swap functions to kernel/power/swap.c. PM / freezer: Don't get over-anxious while waiting
2009-12-08Merge branch 'kvm-updates/2.6.33' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
* 'kvm-updates/2.6.33' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (84 commits) KVM: VMX: Fix comparison of guest efer with stale host value KVM: s390: Fix prefix register checking in arch/s390/kvm/sigp.c KVM: Drop user return notifier when disabling virtualization on a cpu KVM: VMX: Disable unrestricted guest when EPT disabled KVM: x86 emulator: limit instructions to 15 bytes KVM: s390: Make psw available on all exits, not just a subset KVM: x86: Add KVM_GET/SET_VCPU_EVENTS KVM: VMX: Report unexpected simultaneous exceptions as internal errors KVM: Allow internal errors reported to userspace to carry extra data KVM: Reorder IOCTLs in main kvm.h KVM: x86: Polish exception injection via KVM_SET_GUEST_DEBUG KVM: only clear irq_source_id if irqchip is present KVM: x86: disallow KVM_{SET,GET}_LAPIC without allocated in-kernel lapic KVM: x86: disallow multiple KVM_CREATE_IRQCHIP KVM: VMX: Remove vmx->msr_offset_efer KVM: MMU: update invlpg handler comment KVM: VMX: move CR3/PDPTR update to vmx_set_cr3 KVM: remove duplicated task_switch check KVM: powerpc: Fix BUILD_BUG_ON condition KVM: VMX: Use shared msr infrastructure ... Trivial conflicts due to new Kconfig options in arch/Kconfig and kernel/Makefile
2009-12-08Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1815 commits) mac80211: fix reorder buffer release iwmc3200wifi: Enable wimax core through module parameter iwmc3200wifi: Add wifi-wimax coexistence mode as a module parameter iwmc3200wifi: Coex table command does not expect a response iwmc3200wifi: Update wiwi priority table iwlwifi: driver version track kernel version iwlwifi: indicate uCode type when fail dump error/event log iwl3945: remove duplicated event logging code b43: fix two warnings ipw2100: fix rebooting hang with driver loaded cfg80211: indent regulatory messages with spaces iwmc3200wifi: fix NULL pointer dereference in pmkid update mac80211: Fix TX status reporting for injected data frames ath9k: enable 2GHz band only if the device supports it airo: Fix integer overflow warning rt2x00: Fix padding bug on L2PAD devices. WE: Fix set events not propagated b43legacy: avoid PPC fault during resume b43: avoid PPC fault during resume tcp: fix a timewait refcnt race ... Fix up conflicts due to sysctl cleanups (dead sysctl_check code and CTL_UNNUMBERED removed) in kernel/sysctl_check.c net/ipv4/sysctl_net_ipv4.c net/ipv6/addrconf.c net/sctp/sysctl.c
2009-12-08Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-next-2.6: sparc: Set UTS_MACHINE correctly. sparc,leon: init_leon srmmu cleanup sparc32: Remove early interrupt enable. sparc, leon: Added Aeroflex Gaisler entry in manufacturer_info structure sparc64: Faster early-boot framebuffer console. Revert "sparc: Make atomic locks raw" sparc: remove unused nfsd #includes sparc: Fixup last users of irq_chip->typename Added sparc_leon3_snooping_enabled() and converted extern inline to static inline No auxio on LEON apbuart: Use of_find_node_by_path to find root node. sparc: Replace old style lock initializer sparc: Make atomic locks raw apbuart: Fix build and missing driver unregister. apbuart: Kill dependency on deprecated Sparc-only PROM interfaces. apbuart: Fix build warning. sparc: Support for GRLIB APBUART serial port watchdog: Remove BKL from rio watchdog driver sparc: Remove BKL from apc sparc,leon: Sparc-Leon SMP support
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (294 commits) S3C64XX: Staticise platform data for PCM devices ASoC: Rename controls with a / in wm_hubs snd-fm801: autodetect SF64-PCR (tuner-only) card ALSA: tea575x-tuner: fix mute ASoC: au1x: dbdma2: plug memleak in pcm device creation error path ASoC: au1x: dbdma2: fix oops on soc device removal. ALSA: hda - Fix memory leaks in the previous patch ALSA: hda - Add ALC661/259, ALC892/888VD support ALSA: opti9xx: remove snd_opti9xx fields ALSA: aaci - Clean up duplicate code ALSA: usb - Fix mixer map for Hercules Gamesurround Muse Pocket LT ALSA: hda - Add position_fix quirk for HP dv3 ALSA: hda - Add a pin-fix for FSC Amilo Pi1505 ALSA: hda - Fix Cxt5047 test mode ASoC: pxa/raumfeld: adopt new snd_soc_dai_set_pll() API ASoC: sh: fsi: Add runtime PM support sh: ms7724se: Add runtime PM support for FSI ALSA: hda - Add a position_fix quirk for MSI Wind U115 ALSA: opti-miro: add PnP detection ALSA: opti-miro: separate comon probing code ...
2009-12-08Merge branch 'next-devicetree' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'next-devicetree' of git://git.secretlab.ca/git/linux-2.6: of: merge of_find_all_nodes() implementations of: merge other miscellaneous prototypes of: merge of_*_flat_dt*() functions of: merge of_node_get(), of_node_put() and of_find_all_nodes() of: merge of_read_number() an of_read_ulong() of: merge of_node_*_flag() and set_node_proc_entry() of: merge struct boot_param_header from Microblaze and PowerPC of: add common header for flattened device tree representation of: Move OF_IS_DYNAMIC and OF_MARK_DYNAMIC macros to of.h of: merge struct device_node of: merge phandle, ihandle and struct property of: Rework linux/of.h and asm/prom.h include ordering
