2013-11-12Merge tag 'sound-3.13-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound updates from Takashi Iwai: "There are no too intrusive changes in this update batch. The biggest LOC is found in the new DICE driver, and other small changes are scattered over the whole sound subtree (which is a common pattern). Below are highlights: - ALSA core: * Memory allocation support with genpool * Fix blocking in drain ioctl of compress_offload - HD-audio: * Improved AMD HDMI supports * Intel HDMI detection improvements * thinkpad_acpi mute-key integration * New PCI ID, New ALC255,285,293 codecs, CX20952 - USB-audio: * New buffer size management * Clean up endpoint handling codes - ASoC: * Further work on the dmaengine helpers, including support for configuring the parameters for DMA by reading the capabilities of the DMA controller which removes some guesswork and magic numbers from drivers. * A refresh of the documentation. * Conversions of many drivers to direct regmap API usage in order to allow the ASoC level register I/O code to be removed, this will hopefully be completed by v3.14. * Support for using async register I/O in DAPM, reducing the time taken to implement power transitions on systems that support it. - Firewire: DICE driver - Lots of small fixes for bugs reported by Coverity" * tag 'sound-3.13-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (382 commits) ALSA: hda/realtek - Add new codec ALC255/ALC3234 UAJ supported ALSA: hda - Apply MacBook fixups for CS4208 correctly ASoC: fsl: imx-wm8962: remove an unneeded check ASoC: fsl: imx-pcm-fiq: Remove unused 'runtime' variable ALSA: hda/realtek - Make fixup regs persist after resume ALSA: hda_intel: ratelimit "spurious response" message ASoC: generic-dmaengine-pcm: Use SNDRV_DMA_TYPE_DEV_IRAM as default ASoC: dapm: Use WARN_ON() instead of BUG_ON() ASoC: wm_adsp: Fix BUG_ON() and WARN_ON() usages ASoC: Replace BUG() with WARN() ASoC: wm_hubs: Replace BUG() with WARN() ASoC: wm8996: Replace BUG() with WARN() ASoC: wm8962: Replace BUG() with WARN() ASoC: wm8958: Replace BUG() with WARN() ASoC: wm8904: Replace BUG() with WARN() ASoC: wm8900: Replace BUG() with WARN() ASoC: wm8350: Replace BUG() with WARN() ASoC: txx9: Use WARN_ON() instead of BUG_ON() ASoC: sh: Use WARN_ON() instead of BUG_ON() ASoC: rcar: Use WARN_ON() instead of BUG_ON() ...
2013-11-12Merge tag 'spi-v3.13' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/spi Pull spi updates from Mark Brown: "As well as the usual driver updates and cleanups there's a few improvements to the core here: - The start of some improvements to factor out more of the SPI message loop into the core. Right now this is just simplifying the code a bit but hopefully next time around we'll also have managed to roll out some noticable performance improvements which drivers can take advantage of. - Support for loading modules for ACPI enumerated SPI devices. - Managed registration for SPI controllers. - Helper for another common I/O pattern" * tag 'spi-v3.13' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/spi: (116 commits) spi/hspi: add device tree support spi: atmel: fix return value check in atmel_spi_probe() spi: spi-imx: only enable the clocks when we start to transfer a message spi/s3c64xx: Fix doubled clock disable on suspend spi/s3c64xx: Do not ignore return value of spi_master_resume/suspend spi: spi-mxs: Use u32 instead of uint32_t spi: spi-mxs: Don't set clock for each xfer spi: spi-mxs: Clean up setup_transfer function spi: spi-mxs: Remove check of spi mode bits spi: spi-mxs: Fix race in setup method spi: spi-mxs: Remove bogus setting of ssp clk rate field spi: spi-mxs: Remove full duplex check, spi core already does it spi: spi-mxs: Fix chip select control bits in DMA mode spi: spi-mxs: Fix extra CS pulses and read mode in multi-transfer messages spi: spi-mxs: Change flag arguments in txrx functions to bit flags spi: spi-mxs: Always clear INGORE_CRC, to keep CS asserted spi: spi-mxs: Remove mxs_spi_enable and mxs_spi_disable spi: spi-mxs: Always set LOCK_CS spi/s3c64xx: Add missing pm_runtime_put on setup fail spi/s3c64xx: Add missing pm_runtime_set_active() call in probe() ...
2013-11-12Merge tag 'regulator-v3.13' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator Pull regulator updates from Mark Brown: "Lots of driver updates here plus some nice new core features, the main one being the first: - Enable support for providing a dummy regulator when we know that one must exist for the device to be functional. This makes it much easier to add regulator support to drivers since we don't require that the machine integration for all systems using the device be updated to provide regulators. - Substantial reduction in the amount of busy waiting done while waiting for enables to complete. - Allow MFDs to distribute regulator supplies to child devices so we don't have to expose the internal structure of MFDs outside of the driver. - Managed registeration for regulators" * tag 'regulator-v3.13' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator: (113 commits) regulator: s5m8767: Modify parsing method of the voltage table of buck2/3/4 regulator: s5m8767: Modify parse_dt function to parse data related to ramp regulator: da9052: Revert se apply_[reg|bit] with regmap based voltage_sel operations mfd: arizona: Specify supply mappings for Arizona CODECs mfd: Allow mapping regulator supplies to MFD device from children regulator: core: Add ability to create a lookup alias for supply regulator: tps65910: Fix checkpatch issue regulator: tps65023: Fix checkpatch issue regulator: tps6105x: Fix checkpatch issue regulator: mc13783: Fix checkpatch issue regulator: max8997: Fix checkpatch issue regulator: lp3971: Fix checkpatch issue regulator: fixed: Fix checkpatch issue regulator: anatop: Fix checkpatch issue regulator: Add REGULATOR_LINEAR_RANGE macro regulator: Remove max_uV from struct regulator_linear_range regulator: ti-abb: Fix operator precedence typo regulator: tps65910: get regulators node from parent node only regulator: tps6586x: get regulators node from parent node only regulator: tps65090: get regulators node from parent node only ...
2013-11-12Merge tag 'regmap-v3.13' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regmap Pull regmap updates from Mark Brown: "The main thing this time around has been some improvments to async I/O. - Cleaned up the async I/O support and extended it to allow single register writes more easily. This is now used where possible for internally generated I/O, providing performance improvements for devices that can do async I/O. - An API for issuing a sequence of register writes as a single operation. Some devices and buses can take advantage of this to do the I/O faster. - Addition of regmap_field APIs which help drivers for devices with repeated IPs or which move registers around between revisions to share helpers. - Support for SPMI buses" * tag 'regmap-v3.13' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regmap: regmap: add SPMI support regmap: debugfs: Fix a boot time crash with early regmap init regmap: irq: clear status when disable irq regmap: Only send a single buffer for async I/O if writing one register regmap: spi: Handle async writes of only one buffer regmap: new API regmap_multi_reg_write() definition regmap: Use async I/O during cache sync regmap: Use async I/O for patch application regmap: Fix regmap_bulk_write single-rw mutex deadlock regmap: Provide asynchronous write and update bits operations regmap: Simplify the initiation of async I/O regmap: Don't generate gather writes for single register raw writes regmap: Cache async work structures regmap: add helper macro to set min/max range of register regmap: Add regmap_fields APIs regmap: add regmap_field_update_bits()
2013-11-12Merge tag 'hwmon-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging Pull hwmon updates from Guenter Roeck: "Introduce new hwmon API functions hwmon_device_register_with_groups and devm_hwmon_device_register_with_groups, and convert several drivers to use the new API. Add support for EMC1404, EMC1424, LTC2977, LTC2978A, LM25063 to existing drivers Various cleanups in several drivers" * tag 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging: (49 commits) hwmon: (w83793) Clean up a signedness issue hwmon: (nct6775) Remove an unused variable hwmon: (emc1403) Add support for EMC1404 and EMC1424 hwmon: (emc1403) Convert to use devm_hwmon_device_register_with_groups hwmon: (pmbus/ltc2978): Add support for LTC2978A hwmon: (pmbus/ltc2978): Add support for LTC2977 hwmon: (pmbus/lm25066) Add support for LM25063 hwmon: Correct some typos hwmon: (gpio-fan) Include linux/of.h header hwmon: (lm70) Remove redundant spi_set_drvdata hwmon: (adcxx) Remove redundant spi_set_drvdata hwmon: (jc42) fix coccinelle warnings hwmon: (ltc4261) fix coccinelle warnings hwmon: (lm95234) fix coccinelle warnings hwmon: (max6697) fix coccinelle warnings hwmon: (max6642 fix coccinelle warnings hwmon: (ds1621) fix coccinelle warnings hwmon: (nct6775) fix coccinelle warnings hwmon: (jc42) Convert to use devm_hwmon_device_register_with_groups hwmon: (ltc4261) Convert to use devm_hwmon_device_register_with_groups ...
2013-11-12Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc Pull powerpc updates from Benjamin Herrenschmidt: "The bulk of this is LE updates. One should now be able to build an LE kernel and even run some things in it. I'm still sitting on a handful of patches to enable the new ABI that I *might* still send this merge window around, but due to the incertainty (they are pretty fresh) I want to keep them separate. Other notable changes are some infrastructure bits to better handle PCI pass-through under KVM, some bits and pieces added to the new PowerNV platform support such as access to the CPU SCOM bus via sysfs, and support for EEH error handling on PHB3 (Power8 PCIe). We also grew arch_get_random_long() for both pseries and powernv when running on P7+ and P8, exploiting the HW rng. And finally various embedded updates from freescale" * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (154 commits) powerpc: Fix fatal SLB miss when restoring PPR powerpc/powernv: Reserve the correct PE number powerpc/powernv: Add PE to its own PELTV powerpc/powernv: Add support for indirect XSCOM via debugfs powerpc/scom: Improve debugfs interface powerpc/scom: Enable 64-bit addresses powerpc/boot: Properly handle the base "of" boot wrapper powerpc/bpf: Support MOD operation powerpc/bpf: Fix DIVWU instruction opcode of: Move definition of of_find_next_cache_node into common code. powerpc: Remove big endianness assumption in of_find_next_cache_node powerpc/tm: Remove interrupt disable in __switch_to() powerpc: word-at-a-time optimization for 64-bit Little Endian powerpc/bpf: BPF JIT compiler for 64-bit Little Endian powerpc: Only save/restore SDR1 if in hypervisor mode powerpc/pmu: Fix ADB_PMU_LED_IDE dependencies powerpc/nvram: Fix endian issue when using the partition length powerpc/nvram: Fix endian issue when reading the NVRAM size powerpc/nvram: Scan partitions only once powerpc/mpc512x: remove unnecessary #if ...
2013-11-12Merge tag 'microblaze-3.13-rc1' of git://git.monstr.eu/linux-2.6-microblazeLinus Torvalds
Pull microblaze updates from Michal Simek: - Get rid of NO_MMU Kconfig - mmap2 fixups - Some minor cleanups * tag 'microblaze-3.13-rc1' of git://git.monstr.eu/linux-2.6-microblaze: microblaze: Remove incorrect file path microblaze: Fix bug with mmap2 syscall MB implementation microblaze: Use predefined SYSCALL_DEFINE macro microblaze: Remove deprecated IRQF_DISABLED microblaze: Calculate kernel pad automatically microblaze: Remove unused NO_MMU Kconfig parameter
2013-11-12Merge tag 'metag-for-v3.13' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jhogan/metag Pull metag architecture changes from James Hogan: - A change to remove the last dependence on bootloader exception handlers so that QEMU can more easily boot an SMP Linux/Meta kernel image directly. - A fix for a minor off by one error in a BUG_ON condition found by Dan Carpenter. * tag 'metag-for-v3.13' of git://git.kernel.org/pub/scm/linux/kernel/git/jhogan/metag: metag: off by one in setup_bootmem_node() metag: handle low level kicks directly
2013-11-12Merge tag 'h8300-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging Pull h8300 platform removal from Guenter Roeck: "The patch series has been in -next for more than one relase cycle. I did get a number of Acks, and no objections. H8/300 has been dead for several years, the kernel for it has not compiled for ages, and recent versions of gcc for it are broken. Remove support for it" * tag 'h8300-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging: CREDITS: Add Yoshinori Sato for h8300 fs/minix: Drop dependency on H8300 Drop remaining references to H8/300 architecture Drop MAINTAINERS entry for H8/300 watchdog: Drop references to H8300 architecture net/ethernet: Drop H8/300 Ethernet driver net/ethernet: smsc9194: Drop conditional code for H8/300 ide: Drop H8/300 driver Drop support for Renesas H8/300 (h8300) architecture
2013-11-12Merge branch 'x86-uv-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 UV debug changes from Ingo Molnar: "Various SGI UV debuggability improvements, amongst them KDB support, with related core KDB enabling patches changing kernel/debug/kdb/" * 'x86-uv-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: Revert "x86/UV: Add uvtrace support" x86/UV: Add call to KGDB/KDB from NMI handler kdb: Add support for external NMI handler to call KGDB/KDB x86/UV: Check for alloc_cpumask_var() failures properly in uv_nmi_setup() x86/UV: Add uvtrace support x86/UV: Add kdump to UV NMI handler x86/UV: Add summary of cpu activity to UV NMI handler x86/UV: Update UV support for external NMI signals x86/UV: Move NMI support
2013-11-12Merge branch 'x86-uaccess-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 uaccess changes from Ingo Molnar: "A single change that micro-optimizes __copy_*_user_inatomic(), used by the futex code" * 'x86-uaccess-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86: Add 1/2/4/8 byte optimization to 64bit __copy_{from,to}_user_inatomic
2013-11-12Merge branch 'x86-reboot-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 reboot changes from Ingo Molnar: "Misc changes - the only one with functional impact should be commit 16c21ae5ca63 ("reboot: Allow specifying warm/cold reset for CF9 boot type") which extends cold/warm reboot handling to the 0xCF9 reboot method" * 'x86-reboot-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/reboot: Correct pr_info() log message in the set_bios/pci/kbd_reboot() x86/reboot: Sort reboot DMI quirks by vendor x86/reboot: Remove the duplicate C6100 entry in the reboot quirks list reboot: Allow specifying warm/cold reset for CF9 boot type
2013-11-12Merge branch 'x86-platform-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 platform fixlet from Ingo Molnar: "A single __initdata fix" * 'x86-platform-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/geode: Fix incorrect placement of __initdata tag
2013-11-12Merge branch 'x86-mm-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 mm fixlet from Ingo Molnar: "One cleanup that documents a particular detail in init_mem_mapping()" * 'x86-mm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/mm: Add 'step_size' comments to init_mem_mapping()
2013-11-12Merge branch 'x86-mce-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 RAS changes from Ingo Molnar: "The biggest change adds support for Intel 'CPER' (UEFI Common Platform Error Record) error logging, which builds upon an enhanced error logging mechanism available on Xeon processors. Full description is here: http://www.intel.com/content/www/us/en/architecture-and-technology/enhanced-mca-logging-xeon-paper.html This change provides a module (and support code) to check for an extended error log and prints extra details about the error on the console" * 'x86-mce-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: ACPI, x86: Fix extended error log driver to depend on CONFIG_X86_LOCAL_APIC dmi: Avoid unaligned memory access in save_mem_devices() Move cper.c from drivers/acpi/apei to drivers/firmware/efi EDAC, GHES: Update ghes error record info ACPI, APEI, CPER: Cleanup CPER memory error output format ACPI, APEI, CPER: Enhance memory reporting capability ACPI, APEI, CPER: Add UEFI 2.4 support for memory error DMI: Parse memory device (type 17) in SMBIOS ACPI, x86: Extended error log driver for x86 platform bitops: Introduce a more generic BITMASK macro ACPI, CPER: Update cper info ACPI, APEI, CPER: Fix status check during error printing
2013-11-12Merge branch 'x86-iommu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 iommu changes from Ingo Molnar: "Make it easier to turn off the old AMD GART code" * 'x86-iommu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/iommu: Clean up the CONFIG_GART_IOMMU config option a bit x86/iommu: Don't make AMD_GART depend on EXPERT and default y
2013-11-12Merge branch 'x86-intel-mid-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86/intel-mid changes from Ingo Molnar: "Update the 'intel mid' (mobile internet device) platform code as Intel is rolling out more SoC designs. This gets rid of most of the 'MRST' platform code in the process, mostly by renaming and shuffling code around into their respective 'intel-mid' platform drivers" * 'x86-intel-mid-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86, intel-mid: Do not re-introduce usage of obsolete __cpuinit intel_mid: Move platform device setups to their own platform_<device>.* files x86: intel-mid: Add section for sfi device table intel-mid: sfi: Allow struct devs_id.get_platform_data to be NULL intel_mid: Moved SFI related code to sfi.c intel_mid: Added custom handler for ipc devices intel_mid: Added custom device_handler support intel_mid: Refactored sfi_parse_devs() function intel_mid: Renamed *mrst* to *intel_mid* pci: intel_mid: Return true/false in function returning bool intel_mid: Renamed *mrst* to *intel_mid* mrst: Fixed indentation issues mrst: Fixed printk/pr_* related issues
2013-11-12Merge branch 'x86-hyperv-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86/hyperv changes from Ingo Molnar: "These changes enable Linux guests to boot as 'Modern VM' guest kernels on MS-Hyperv hosts" * 'x86-hyperv-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86, hyperv: Move a variable to avoid an unused variable warning x86, hyperv: Fix build error due to missing <asm/apic.h> include x86, hyperv: Correctly guard the local APIC calibration code x86, hyperv: Get the local APIC timer frequency from the hypervisor
2013-11-12Merge branch 'x86-efi-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 EFI changes from Ingo Molnar: "Main changes: - Add support for earlyprintk=efi which uses the EFI framebuffer. Very useful for debugging boot problems. - EFI stub support for large memory maps (more than 128 entries) - EFI ARM support - this was mostly done by generalizing x86 <-> ARM platform differences, such as by moving x86 EFI code into drivers/firmware/efi/ and sharing it with ARM. - Documentation updates - misc fixes" * 'x86-efi-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (26 commits) x86/efi: Add EFI framebuffer earlyprintk support boot, efi: Remove redundant memset() x86/efi: Fix config_table_type array termination x86 efi: bugfix interrupt disabling sequence x86: EFI stub support for large memory maps efi: resolve warnings found on ARM compile efi: Fix types in EFI calls to match EFI function definitions. efi: Renames in handle_cmdline_files() to complete generalization. efi: Generalize handle_ramdisks() and rename to handle_cmdline_files(). efi: Allow efi_free() to be called with size of 0 efi: use efi_get_memory_map() to get final map for x86 efi: generalize efi_get_memory_map() efi: Rename __get_map() to efi_get_memory_map() efi: Move unicode to ASCII conversion to shared function. efi: Generalize relocate_kernel() for use by other architectures. efi: Move relocate_kernel() to shared file. efi: Enforce minimum alignment of 1 page on allocations. efi: Rename memory allocation/free functions efi: Add system table pointer argument to shared functions. efi: Move common EFI stub code from x86 arch code to common location ...
2013-11-12Merge branch 'x86-cpu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 cpu changes from Ingo Molnar: "The biggest change that stands out is the increase of the CONFIG_NR_CPUS range from 4096 to 8192 - as real hardware out there already went beyond 4k CPUs ... We only allow more than 512 CPUs if offstack cpumasks are enabled. CONFIG_MAXSMP=y remains to be the 'you are nuts!' extreme testcase, which now means a max of 8192 CPUs" * 'x86-cpu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/cpu: Increase max CPU count to 8192 x86/cpu: Allow higher NR_CPUS values x86/cpu: Always print SMP information in /proc/cpuinfo x86/cpu: Track legacy CPU model data only on 32-bit kernels
2013-11-12Merge branch 'x86-cleanups-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 cleanups from Ingo Molnar: "Two small cleanups" * 'x86-cleanups-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86, msr: Use file_inode(), not f_mapping->host x86: mkpiggy.c: Explicitly close the output file
2013-11-12Merge branch 'x86-build-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 build changes from Ingo Molnar: "Two small changes" * 'x86-build-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86, defconfig: Add DEVTMPFS and DEVTMPFS_MOUNT to *86*_defconfig x86, build: move build output statistics away from stderr
2013-11-12Merge branch 'x86-boot-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 boot changes from Ingo Molnar: "Two changes that prettify and compactify the SMP bootup output from: smpboot: Booting Node 0, Processors #1 #2 #3 OK smpboot: Booting Node 1, Processors #4 #5 #6 #7 OK smpboot: Booting Node 2, Processors #8 #9 #10 #11 OK smpboot: Booting Node 3, Processors #12 #13 #14 #15 OK Brought up 16 CPUs to something like: x86: Booting SMP configuration: .... node #0, CPUs: #1 #2 #3 .... node #1, CPUs: #4 #5 #6 #7 .... node #2, CPUs: #8 #9 #10 #11 .... node #3, CPUs: #12 #13 #14 #15 x86: Booted up 4 nodes, 16 CPUs" * 'x86-boot-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/boot: Further compress CPUs bootup message x86: Improve the printout of the SMP bootup CPU table
2013-11-12Merge branch 'x86-asm-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 user access changes from Ingo Molnar: "This tree contains two copy_[from/to]_user() build time checking changes/enhancements from Jan Beulich. The desired outcome is to get better compiler warnings with CONFIG_DEBUG_STRICT_USER_COPY_CHECKS=y, to keep people from introducing bugs such as overflows and information leaks" * 'x86-asm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86: Unify copy_to_user() and add size checking to it x86: Unify copy_from_user() size checking
2013-11-12Merge branch 'x86-apic-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86/apic fix from Ingo Molnar: "A single fix to the IO-APIC / local-APIC shutdown sequence" * 'x86-apic-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/apic: Disable I/O APIC before shutdown of the local APIC
2013-11-12Merge branch 'timers-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull timer changes from Ingo Molnar: "Main changes in this cycle were: - Updated full dynticks support. - Event stream support for architected (ARM) timers. - ARM clocksource driver updates. - Move arm64 to using the generic sched_clock framework & resulting cleanup in the generic sched_clock code. - Misc fixes and cleanups" * 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (50 commits) x86/time: Honor ACPI FADT flag indicating absence of a CMOS RTC clocksource: sun4i: remove IRQF_DISABLED clocksource: sun4i: Report the minimum tick that we can program clocksource: sun4i: Select CLKSRC_MMIO clocksource: Provide timekeeping for efm32 SoCs clocksource: em_sti: convert to clk_prepare/unprepare time: Fix signedness bug in sysfs_get_uname() and its callers timekeeping: Fix some trivial typos in comments alarmtimer: return EINVAL instead of ENOTSUPP if rtcdev doesn't exist clocksource: arch_timer: Do not register arch_sys_counter twice timer stats: Add a 'Collection: active/inactive' line to timer usage statistics sched_clock: Remove sched_clock_func() hook arch_timer: Move to generic sched_clock framework clocksource: tcb_clksrc: Remove IRQF_DISABLED clocksource: tcb_clksrc: Improve driver robustness clocksource: tcb_clksrc: Replace clk_enable/disable with clk_prepare_enable/disable_unprepare clocksource: arm_arch_timer: Use clocksource for suspend timekeeping clocksource: dw_apb_timer_of: Mark a few more functions as __init clocksource: Put nodes passed to CLOCKSOURCE_OF_DECLARE callbacks centrally arm: zynq: Enable arm_global_timer ...
2013-11-12Merge branch 'sched-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler changes from Ingo Molnar: "The main changes in this cycle are: - (much) improved CONFIG_NUMA_BALANCING support from Mel Gorman, Rik van Riel, Peter Zijlstra et al. Yay! - optimize preemption counter handling: merge the NEED_RESCHED flag into the preempt_count variable, by Peter Zijlstra. - wait.h fixes and code reorganization from Peter Zijlstra - cfs_bandwidth fixes from Ben Segall - SMP load-balancer cleanups from Peter Zijstra - idle balancer improvements from Jason Low - other fixes and cleanups" * 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (129 commits) ftrace, sched: Add TRACE_FLAG_PREEMPT_RESCHED stop_machine: Fix race between stop_two_cpus() and stop_cpus() sched: Remove unnecessary iteration over sched domains to update nr_busy_cpus sched: Fix asymmetric scheduling for POWER7 sched: Move completion code from core.c to completion.c sched: Move wait code from core.c to wait.c sched: Move wait.c into kernel/sched/ sched/wait: Fix __wait_event_interruptible_lock_irq_timeout() sched: Avoid throttle_cfs_rq() racing with period_timer stopping sched: Guarantee new group-entities always have weight sched: Fix hrtimer_cancel()/rq->lock deadlock sched: Fix cfs_bandwidth misuse of hrtimer_expires_remaining sched: Fix race on toggling cfs_bandwidth_used sched: Remove extra put_online_cpus() inside sched_setaffinity() sched/rt: Fix task_tick_rt() comment sched/wait: Fix build breakage sched/wait: Introduce prepare_to_wait_event() sched/wait: Add ___wait_cond_timeout() to wait_event*_timeout() too sched: Remove get_online_cpus() usage sched: Fix race in migrate_swap_stop() ...
2013-11-12Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf updates from Ingo Molnar: "As a first remark I'd like to note that the way to build perf tooling has been simplified and sped up, in the future it should be enough for you to build perf via: cd tools/perf/ make install (ie without the -j option.) The build system will figure out the number of CPUs and will do a parallel build+install. The various build system inefficiencies and breakages Linus reported against the v3.12 pull request should now be resolved - please (re-)report any remaining annoyances or bugs. Main changes on the perf kernel side: * Performance optimizations: . perf ring-buffer code optimizations, by Peter Zijlstra . perf ring-buffer code optimizations, by Oleg Nesterov . x86 NMI call-stack processing optimizations, by Peter Zijlstra . perf context-switch optimizations, by Peter Zijlstra . perf sampling speedups, by Peter Zijlstra . x86 Intel PEBS processing speedups, by Peter Zijlstra * Enhanced hardware support: . for Intel Ivy Bridge-EP uncore PMUs, by Zheng Yan . for Haswell transactions, by Andi Kleen, Peter Zijlstra * Core perf events code enhancements and fixes by Oleg Nesterov: . for uprobes, if fork() is called with pending ret-probes . for uprobes platform support code * New ABI details by Andi Kleen: . Report x86 Haswell TSX transaction abort cost as weight Main changes on the perf tooling side (some of these tooling changes utilize the above kernel side changes): * 'perf report/top' enhancements: . Convert callchain children list to rbtree, greatly reducing the time taken for callchain processing, from Namhyung Kim. . Add new COMM infrastructure, further improving histogram processing, from Frédéric Weisbecker, one fix from Namhyung Kim. . Add /proc/kcore based live-annotation improvements, including build-id cache support, multi map 'call' instruction navigation fixes, kcore address validation, objdump workarounds. From Adrian Hunter. . Show progress on histogram collapsing, that can take a long time, from Namhyung Kim. . Add --max-stack option to limit callchain stack scan in 'top' and 'report', improving callchain processing when reducing the stack depth is an option, from Waiman Long. . Add new option --ignore-vmlinux for perf top, from Willy Tarreau. * 'perf trace' enhancements: . 'perf trace' now can can use a 'perf probe' dynamic tracepoints to hook into the userspace -> kernel pathname copy so that it can map fds to pathnames without reading /proc/pid/fd/ symlinks. From Arnaldo Carvalho de Melo. . Show VFS path associated with fd in live sessions, using a 'vfs_getname' 'perf probe' created dynamic tracepoint or by looking at /proc/pid/fd, from Arnaldo Carvalho de Melo. . Add 'trace' beautifiers for lots of syscall arguments, from Arnaldo Carvalho de Melo. . Implement more compact 'trace' output by suppressing zeroed args, from Arnaldo Carvalho de Melo. . Show thread COMM by default in 'trace', from Arnaldo Carvalho de Melo. . Add option to show full timestamp in 'trace', from David Ahern. . Add 'record' command in 'trace', to record raw_syscalls:*, from David Ahern. . Add summary option to dump syscall statistics in 'trace', from David Ahern. . Improve error messages in 'trace', providing hints about system configuration steps needed for using it, from Ramkumar Ramachandra. . 'perf trace' now emits hints as to why tracing is not possible, helping the user to setup the system to allow tracing in the desired permission granularity, telling if the problem is due to debugfs not being mounted or with not enough permission for !root, /proc/sys/kernel/perf_event_paranoit value, etc. From Arnaldo Carvalho de Melo. * 'perf record' enhancements: . Check maximum frequency rate for record/top, emitting better error messages, from Jiri Olsa. . 'perf record' code cleanups, from David Ahern. . Improve write_output error message in 'perf record', from Adrian Hunter. . Allow specifying B/K/M/G unit to the --mmap-pages arguments, from Jiri Olsa. . Fix command line callchain attribute tests to handle the new -g/--call-chain semantics, from Arnaldo Carvalho de Melo. * 'perf kvm' enhancements: . Disable live kvm command if timerfd is not supported, from David Ahern. . Fix detection of non-core features, from David Ahern. * 'perf list' enhancements: . Add usage to 'perf list', from David Ahern. . Show error in 'perf list' if tracepoints not available, from Pekka Enberg. * 'perf probe' enhancements: . Support "$vars" meta argument syntax for local variables, allowing asking for all possible variables at a given probe point to be collected when it hits, from Masami Hiramatsu. * 'perf sched' enhancements: . Address the root cause of that 'perf sched' stack initialization build slowdown, by programmatically setting a big array after moving the global variable back to the stack. Fix from Adrian Hunter. * 'perf script' enhancements: . Set up output options for in-stream attributes, from Adrian Hunter. . Print addr by default for BTS in 'perf script', from Adrian Juntmer * 'perf stat' enhancements: . Improved messages when doing profiling in all or a subset of CPUs using a workload as the session delimitator, as in: 'perf stat --cpu 0,2 sleep 10s' from Arnaldo Carvalho de Melo. . Add units to nanosec-based counters in 'perf stat', from David Ahern. . Remove bogus info when using 'perf stat' -e cycles/instructions, from Ramkumar Ramachandra. * 'perf lock' enhancements: . 'perf lock' fixes and cleanups, from Davidlohr Bueso. * 'perf test' enhancements: . Fixup PERF_SAMPLE_TRANSACTION handling in sample synthesizing and 'perf test', from Adrian Hunter. . Clarify the "sample parsing" test entry, from Arnaldo Carvalho de Melo. . Consider PERF_SAMPLE_TRANSACTION in the "sample parsing" test, from Arnaldo Carvalho de Melo. . Memory leak fixes in 'perf test', from Felipe Pena. * 'perf bench' enhancements: . Change the procps visible command-name of invididual benchmark tests plus cleanups, from Ingo Molnar. * Generic perf tooling infrastructure/plumbing changes: . Separating data file properties from session, code reorganization from Jiri Olsa. . Fix version when building out of tree, as when using one of these: $ make help | grep perf perf-tar-src-pkg - Build perf-3.12.0.tar source tarball perf-targz-src-pkg - Build perf-3.12.0.tar.gz source tarball perf-tarbz2-src-pkg - Build perf-3.12.0.tar.bz2 source tarball perf-tarxz-src-pkg - Build perf-3.12.0.tar.xz source tarball $ from David Ahern. . Enhance option parse error message, showing just the help lines of the options affected, from Namhyung Kim. . libtraceevent updates from upstream trace-cmd repo, from Steven Rostedt. . Always use perf_evsel__set_sample_bit to set sample_type, from Adrian Hunter. . Memory and mmap leak fixes from Chenggang Qin. . Assorted build fixes for from David Ahern and Jiri Olsa. . Speed up and prettify the build system, from Ingo Molnar. . Implement addr2line directly using libbfd, from Roberto Vitillo. . Separate the GTK support in a separate libperf-gtk.so DSO, that is only loaded when --gtk is specified, from Namhyung Kim. . perf bash completion fixes and improvements from Ramkumar Ramachandra. . Support for Openembedded/Yocto -dbg packages, from Ricardo Ribalda Delgado. And lots and lots of other fixes and code reorganizations that did not make it into the list, see the shortlog, diffstat and the Git log for details!" * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (300 commits) uprobes: Fix the memory out of bound overwrite in copy_insn() uprobes: Fix the wrong usage of current->utask in uprobe_copy_process() perf tools: Remove unneeded include perf record: Remove post_processing_offset variable perf record: Remove advance_output function perf record: Refactor feature handling into a separate function perf trace: Don't relookup fields by name in each sample perf tools: Fix version when building out of tree perf evsel: Ditch evsel->handler.data field uprobes: Export write_opcode() as uprobe_write_opcode() uprobes: Introduce arch_uprobe->ixol uprobes: Kill module_init() and module_exit() uprobes: Move function declarations out of arch perf/x86/intel: Add Ivy Bridge-EP uncore IRP box support perf/x86/intel/uncore: Add filter support for IvyBridge-EP QPI boxes perf: Factor out strncpy() in perf_event_mmap_event() tools/perf: Add required memory barriers perf: Fix arch_perf_out_copy_user default perf: Update a stale comment perf: Optimize perf_output_begin() -- address calculation ...
2013-11-12Merge branch 'irq-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull leftover IRQ fixes from Ingo Molnar: "Two (minor) fixlets that missed v3.12" * 'irq-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: genirq: Set the irq thread policy without checking CAP_SYS_NICE irq: DocBook/genericirq.tmpl: Correct various typos
2013-11-12Merge branch 'irq-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull IRQ changes from Ingo Molnar: "The biggest change this cycle are the softirq/hardirq stack interaction and nesting fixes, cleanups and reorganizations from Frederic. This is the longer followup story to the softirq nesting fix that is already upstream (commit ded797547548: "irq: Force hardirq exit's softirq processing on its own stack")" * 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: irqchip: bcm2835: Convert to use IRQCHIP_DECLARE macro powerpc: Tell about irq stack coverage x86: Tell about irq stack coverage irq: Optimize softirq stack selection in irq exit irq: Justify the various softirq stack choices irq: Improve a bit softirq debugging irq: Optimize call to softirq on hardirq exit irq: Consolidate do_softirq() arch overriden implementations x86/irq: Correct comment about i8259 initialization
2013-11-12Merge branch 'core-rcu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull RCU updates from Ingo Molnar: "The main RCU changes in this cycle are: - Idle entry/exit changes, to throttle callback execution and other refinements to speed up kbuild, primarily to address performance issues located by Tibor Billes. - Grace-period related changes, primarily to aid in debugging, inspired by an -rt debugging session. - Code reorganization moving RCU's source files into its own kernel/rcu/ directory. - RCU documentation updates - Miscellaneous fixes. Note, the following commit: 5c889690aa08 mm: Place preemption point in do_mlockall() loop is identical to the commit already in your tree via email: 22356f447ceb mm: Place preemption point in do_mlockall() loop [ Your version of the changelog nicely demonstrates it how kernel oops messages should be trimmed properly :-/ ]" * 'core-rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (30 commits) rcu: Move RCU-related source code to kernel/rcu directory rcu: Fix occurrence of "the the" in checklist.txt kthread: Add pointer to vmstat-avoidance patch rcu: Update stall-warning documentation rcu: Consistent rcu_is_watching() naming rcu: Change EXPORT_SYMBOL() to EXPORT_SYMBOL_GPL() rcu: Is it safe to enter an RCU read-side critical section? rcu: Throttle invoke_rcu_core() invocations due to non-lazy callbacks rcu: Throttle rcu_try_advance_all_cbs() execution rcu: Remove redundant code from rcu_cleanup_after_idle() rcu: Fix CONFIG_RCU_NOCB_CPU_ALL panic on machines with sparse CPU mask rcu: Avoid sparse warnings in rcu_nocb_wake trace event rcu: Track rcu_nocb_kthread()'s sleeping and awakening rcu: Distinguish between NOCB and non-NOCB rcu_callback trace events rcu: Add tracing for rcuo no-CBs CPU wakeup handshake rcu: Add tracing of normal (non-NOCB) grace-period requests rcu: Add tracing to rcu_gp_kthread() rcu: Flag lockless access to ->gp_flags with ACCESS_ONCE() rcu: Prevent spurious-wakeup DoS attack on rcu_gp_kthread() rcu: Improve grace-period start logic ...
2013-11-11Revert "x86/UV: Add uvtrace support"Ingo Molnar
This reverts commit 8eba18428ac926f436064ac281e76d36d51bd631. uv_trace() is not used by anything, nor is uv_trace_nmi_func, nor uv_trace_func. That's not how we do instrumentation code in the kernel: we add tracepoints, printk()s, etc. so that everyone not just those with magic kernel modules can debug a system. So remove this unused (and misguied) piece of code. Signed-off-by: Ingo Molnar <mingo@kernel.org> Cc: Mike Travis <travis@sgi.com> Cc: Dimitri Sivanich <sivanich@sgi.com> Cc: Hedi Berriche <hedi@sgi.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Cc: Jason Wessel <jason.wessel@windriver.com> Link: http://lkml.kernel.org/n/tip-tumfBffmr4jmnt8Gyxanoblg@git.kernel.org
2013-11-11ftrace, sched: Add TRACE_FLAG_PREEMPT_RESCHEDPeter Zijlstra
Since the introduction of PREEMPT_NEED_RESCHED in: f27dde8deef3 ("sched: Add NEED_RESCHED to the preempt_count") we need to be able to look at both TIF_NEED_RESCHED and PREEMPT_NEED_RESCHED to understand the full preemption behaviour. Add it to the trace output. Signed-off-by: Peter Zijlstra <peterz@infradead.org> Acked-by: Steven Rostedt <rostedt@goodmis.org> Cc: Fengguang Wu <fengguang.wu@intel.com> Cc: Huang Ying <ying.huang@intel.com> Cc: Yuanhan Liu <yuanhan.liu@linux.intel.com> Link: http://lkml.kernel.org/r/20131004152826.GP3081@twins.programming.kicks-ass.net Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-11-11stop_machine: Fix race between stop_two_cpus() and stop_cpus()Rik van Riel
There is a race between stop_two_cpus, and the global stop_cpus. It is possible for two CPUs to get their stopper functions queued "backwards" from one another, resulting in the stopper threads getting stuck, and the system hanging. This can happen because queuing up stoppers is not synchronized. This patch adds synchronization between stop_cpus (a rare operation), and stop_two_cpus. Reported-and-Tested-by: Prarit Bhargava <prarit@redhat.com> Signed-off-by: Rik van Riel <riel@redhat.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Acked-by: Mel Gorman <mgorman@suse.de> Link: http://lkml.kernel.org/r/20131101104146.03d1e043@annuminas.surriel.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-11-11ACPI, x86: Fix extended error log driver to depend on CONFIG_X86_LOCAL_APICLuck, Tony
Randconfig build by Fengguang's robot army reported: drivers/built-in.o: In function `extlog_print': >> acpi_extlog.c:(.text+0xcc719): undefined reference to `boot_cpu_physical_apicid' The config had CONFIG_SMP=n so we picked up this definition from: <asm/cpu.h>: #define cpu_physical_id(cpu) boot_cpu_physical_apicid But boot_cpu_physical_apicid is defined in arch/x86/kernel/apic/apic.c which is only built if CONFIG_X86_LOCAL_APIC=y. Reported-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: Tony Luck <tony.luck@intel.com> Cc: Chen Gong <gong.chen@linux.intel.com> Cc: Rafael J. Wysocki <rjw@rjwysocki.net> Link: http://lkml.kernel.org/r/6be3afdcad7968f7fb7c0b681e547b3e872e44dd.1383947368.git.tony.luck@intel.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-11-11Merge tag 'arc-v3.13-rc1-part1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/vgupta/arc Pull ARC changes from Vineet Gupta: - Towards a working SMP setup (ASID allocation, TLB Flush,...) - Support for TRACE_IRQFLAGS, LOCKDEP - cacheflush backend consolidation for I/D - Lots of allmodconfig fixlets from Chen - Other improvements/fixes * tag 'arc-v3.13-rc1-part1' of git://git.kernel.org/pub/scm/linux/kernel/git/vgupta/arc: (25 commits) ARC: [plat-arcfpga] defconfig update smp, ARC: kill SMP single function call interrupt ARC: [SMP] Disallow RTSC ARC: [SMP] Fix build failures for large NR_CPUS ARC: [SMP] enlarge possible NR_CPUS ARC: [SMP] TLB flush ARC: [SMP] ASID allocation arc: export symbol for pm_power_off in reset.c arc: export symbol for save_stack_trace() in stacktrace.c arc: remove '__init' for get_hw_config_num_irq() arc: remove '__init' for first_lines_of_secondary() arc: remove '__init' for setup_processor() and arc_init_IRQ() arc: kgdb: add default implementation for kgdb_roundup_cpus() ARC: Fix bogus gcc warning and micro-optimise TLB iteration loop ARC: Add support for irqflags tracing and lockdep ARC: Reset the value of Interrupt Priority Register ARC: Reduce #ifdef'ery for unaligned access emulation ARC: Change calling convention of do_page_fault() ARC: cacheflush optim - PTAG can be loop invariant if V-P is const ARC: cacheflush refactor #3: Unify the {d,i}cache flush leaf helpers ...
2013-11-11Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k Pull m68k updates from Geert Uytterhoeven: "Summary: - __put_user_unaligned may/will be used by btrfs - m68k part of a global cleanup" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k: m68k: Remove deprecated IRQF_DISABLED m68k/m68knommu: Implement __get_user_unaligned/__put_user_unaligned()
2013-11-11Merge branch 'parisc-3.13' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/deller/parisc-linux Pull parisc update from Helge Deller: - a bugfix for sticon (parisc text console driver) to not crash the 64bit kernel on machines with more than 4GB RAM - added kernel audit support - made udelay() implementation SMP-safe - "make install" now does not depend on vmlinux - added defconfigs for 32- and 64-kernels * 'parisc-3.13' of git://git.kernel.org/pub/scm/linux/kernel/git/deller/parisc-linux: parisc: add generic 32- and 64-bit defconfigs parisc: sticon - unbreak on 64bit kernel parisc: signal fixup - SIGBUS vs. SIGSEGV parisc: implement full version of access_ok() parisc: correctly display number of active CPUs parisc: do not count IPI calls twice parisc: make udelay() SMP-safe parisc: remove duplicate define parisc: make "make install" not depend on vmlinux parisc: add kernel audit feature parisc: provide macro to create exception table entries
2013-11-11Merge branch 'uprobes/core' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/oleg/misc into perf/core Pull uprobes fixes from Oleg Nesterov. Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-11-11Merge tag 'dt-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC DT updates from Olof Johansson: "Most of this branch consists of updates, additions and general churn of the device tree source files in the kernel (arch/arm/boot/dts). Besides that, there are a few things to point out: - Lots of platform conversion on OMAP2+, with removal of old board files for various platforms. - Final conversion of a bunch of ux500 (ST-Ericsson) platforms as well - Some updates to pinctrl and other subsystems. Most of these are for DT-enablement of the various platforms and acks have been collected" * tag 'dt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (385 commits) ARM: dts: bcm11351: Use GIC/IRQ defines for sdio interrupts ARM: dts: bcm: Add missing UARTs for bcm11351 (bcm281xx) ARM: dts: bcm281xx: Add card detect GPIO ARM: dts: rename ARCH_BCM to ARCH_BCM_MOBILE (dt) ARM: bcm281xx: Add device node for the GPIO controller ARM: mvebu: Add Netgear ReadyNAS 104 board ARM: tegra: fix Tegra114 IOMMU register address ARM: kirkwood: add support for OpenBlocks A7 platform ARM: dts: omap4-panda: add DPI pinmuxing ARM: dts: AM33xx: Add RNG node ARM: dts: AM33XX: Add hwspinlock node ARM: dts: OMAP5: Add hwspinlock node ARM: dts: OMAP4: Add hwspinlock node ARM: dts: use 'status' property for PCIe nodes ARM: dts: sirf: add missed address-cells and size-cells for prima2 I2C ARM: dts: sirf: add missed cell, cs and dma channel for SPI nodes ARM: dts: sirf: add missed graphics2d iobg in atlas6 dts ARM: dts: sirf: add missed chhifbg node in prima2 and atlas6 dts ARM: dts: sirf: add missed memcontrol-monitor node in prima2 and atlas6 dts ARM: mvebu: Add the core-divider clock to Armada 370/XP ...
2013-11-11Merge tag 'drivers-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM driver updates from Olof Johansson: "Updates of SoC-near drivers and other driver updates that makes more sense to take through our tree. In this case it's involved: - Some Davinci driver updates that has required corresponding platform code changes (gpio mostly) - CCI bindings and a few driver updates - Marvell mvebu patches for PCI MSI support (could have gone through the PCI tree for this release, but they were acked by Bjorn for 3.12 so we kept them through arm-soc). - Marvell dove switch-over to DT-based PCIe configuration - Misc updates for Samsung platform dmaengine drivers" * tag 'drivers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (32 commits) ARM: S3C24XX: add dma pdata for s3c2410, s3c2440 and s3c2442 dmaengine: s3c24xx-dma: add support for the s3c2410 type of controller ARM: S3C24XX: Fix possible dma selection warning PCI: mvebu: make local functions static PCI: mvebu: add I/O access wrappers PCI: mvebu: Dynamically detect if the PEX link is up to enable hot plug ARM: mvebu: fix gated clock documentation ARM: dove: remove legacy pcie and clock init ARM: dove: switch to DT probed mbus address windows ARM: SAMSUNG: set s3c24xx_dma_filter for s3c64xx-spi0 device ARM: S3C24XX: add platform-devices for new dma driver for s3c2412 and s3c2443 dmaengine: add driver for Samsung s3c24xx SoCs ARM: S3C24XX: number the dma clocks PCI: mvebu: add support for Marvell Dove SoCs PCI: mvebu: add support for reset on GPIO PCI: mvebu: remove subsys_initcall PCI: mvebu: increment nports only for registered ports PCI: mvebu: move clock enable before register access PCI: mvebu: add support for MSI irqchip: armada-370-xp: implement MSI support ...
2013-11-11Merge tag 'boards-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC board updates from Olof Johansson: "Board-related updates. This branch is getting smaller and smaller, which is the whole idea so that's reassuring. Right now by far most of the code is related to shmobile updates, and they are now switching over to removal of board code and migration to multiplatform, so we'll see their board code base shrink in the near future too, I hope. In addition to that is some defconfig updates, some display updates for OMAP and a bit of new board support for Rockchip boards" * tag 'boards-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (56 commits) ARM: rockchip: add support for rk3188 and Radxa Rock board ARM: rockchip: add dts for bqcurie2 tablet ARM: rockchip: enable arm-global-timer ARM: rockchip: move shared dt properties to common source file ARM: OMAP2+: display: Create omap_vout device inside omap_display_init ARM: OMAP2+: display: Create omapvrfb and omapfb devices inside omap_display_init ARM: OMAP2+: display: Create omapdrm device inside omap_display_init ARM: OMAP2+: drm: Don't build device for DMM ARM: tegra: defconfig updates RX-51: Add support for OMAP3 ROM Random Number Generator ARM: OMAP3: RX-51: ARM errata 430973 workaround ARM: OMAP3: Add secure function omap_smc3() which calling instruction smc #1 ARM: shmobile: marzen: enable INTC IRQ ARM: shmobile: bockw: add SMSC support on reference ARM: shmobile: Use SMP on Koelsch ARM: shmobile: Remove KZM9D reference DTS ARM: shmobile: Let KZM9D multiplatform boot with KZM9D DTB ARM: shmobile: Remove non-multiplatform KZM9D reference support ARM: shmobile: Use KZM9D without reference for multiplatform ARM: shmobile: Sync KZM9D DTS with KZM9D reference DTS ...
2013-11-11Merge tag 'soc-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC platform changes from Olof Johansson: "New and updated SoC support. Among the things new for this release are: - More support for the AM33xx platforms from TI - Tegra 124 support, and some updates to older tegra families as well - imx cleanups and updates across the board - A rename of Broadcom's Mobile platforms which were introduced as ARCH_BCM, and turned out to be too broad a name. New name is ARCH_BCM_MOBILE. - A whole bunch of updates and fixes for integrator, making the platform code more modern and switches over to DT-only booting. - Support for two new Renesas shmobile chipsets. Next up for them is more work on consolidation instead of introduction of new non-multiplatform SoCs, we're all looking forward to that! - Misc cleanups for older Samsung platforms, some Allwinner updates, etc" * tag 'soc-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (159 commits) ARM: bcm281xx: Add ARCH_BCM_MOBILE to bcm config ARM: bcm_defconfig: Run "make savedefconfig" ARM: bcm281xx: Add ARCH Timers to config rename ARCH_BCM to ARCH_BCM_MOBILE (mach-bcm) ARM: vexpress: Enable platform-specific options in defconfig ARM: vexpress: Make defconfig work again ARM: sunxi: remove .init_time hooks ARM: imx: enable suspend for imx6sl ARM: imx: ensure dsm_request signal is not asserted when setting LPM ARM: imx6q: call WB and RBC configuration from imx6q_pm_enter() ARM: imx6q: move low-power code out of clock driver ARM: imx: drop extern with function prototypes in common.h ARM: imx: reset core along with enable/disable operation ARM: imx: do not return from imx_cpu_die() call ARM: imx_v6_v7_defconfig: Select CONFIG_PROVE_LOCKING ARM: imx_v6_v7_defconfig: Enable LEDS_GPIO related options ARM: mxs_defconfig: Turn off CONFIG_DEBUG_GPIO ARM: imx: replace imx6q_restart() with mxc_restart() ARM: mach-imx: mm-imx5: Retrieve iomuxc base address from dt ARM: mach-imx: mm-imx5: Retrieve tzic base address from dt ...
2013-11-11Merge tag 'cleanup-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC cleanups from Olof Johansson: "This branch contains code cleanups, moves and removals for 3.13. Qualcomm msm targets had a bunch of code removal for legacy non-DT platforms. Nomadik saw more device tree conversions and cleanup of old code. Tegra has some code refactoring, etc. One longish patch series from Sebastian Hasselbarth changes the init_time hooks and tries to use a generic implementation for most platforms, since they were all doing more or less the same things. Finally the "shark" platform is removed in this release. It's been abandoned for a while and nobody seems to care enough to keep it around. If someone comes along and wants to resurrect it, the removal can easily be reverted and code brought back. Beyond this, mostly a bunch of removals of stale content across the board, etc" * tag 'cleanup-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (79 commits) ARM: gemini: convert to GENERIC_CLOCKEVENTS ARM: EXYNOS: remove CONFIG_MACH_EXYNOS[4, 5]_DT config options ARM: OMAP3: control: add API for setting IVA bootmode ARM: OMAP3: CM/control: move CM scratchpad save to CM driver ARM: OMAP3: McBSP: do not access CM register directly ARM: OMAP3: clock: add API to enable/disable autoidle for a single clock ARM: OMAP2: CM/PM: remove direct register accesses outside CM code MAINTAINERS: Add patterns for DTS files for AT91 ARM: at91: remove init_machine() as default is suitable ARM: at91/dt: split sama5d3 peripheral definitions ARM: at91/dt: split sam9x5 peripheral definitions ARM: Remove temporary sched_clock.h header ARM: clps711x: Use linux/sched_clock.h MAINTAINERS: Add DTS files to patterns for Samsung platform ARM: EXYNOS: remove unnecessary header inclusions from exynos4/5 dt machine file ARM: tegra: fix ARCH_TEGRA_114_SOC select sort order clk: nomadik: fix missing __init on nomadik_src_init ARM: drop explicit selection of HAVE_CLK and CLKDEV_LOOKUP ARM: S3C64XX: Kill CONFIG_PLAT_S3C64XX ASoC: samsung: Use CONFIG_ARCH_S3C64XX to check for S3C64XX support ...
2013-11-11Merge tag 'fixes-nc-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC low-priority fixes from Olof Johansson: "A set of fixes for various platforms that weren't considered bad enough to include in 3.12 (nor -stable). Mostly simple typo fixes, etc" * tag 'fixes-nc-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: ARM: OMAP2+: irq, AM33XX add missing register check ARM: OMAP2+: wakeupgen: AM43x adaptation ARM: OMAP1: Fix a bunch of GPIO related section warnings after initdata got corrected ARM: dts: fix PL330 MDMA1 address in DT for Universal C210 board ARM: dts: Work around lack of cpufreq regulator lookup for exynos4210-origen and trats boards ARM: dts: Fix typo earlyprintk in exynos5440-sd5v1 and ssdk5440 boards ARM: dts: Correct typo in use of samsung,pin-drv for exynos5250 ARM: rockchip: remove obsolete rockchip,config properties ARM: rockchip: fix wrong use of non-existent CONFIG_LOCAL_TIMERS ARM: mach-omap1: Fix omap1510_fpga_init_irq() implicit declarations. ARM: OMAP1: fix incorrect placement of __initdata tag ARM: OMAP: remove deprecated IRQF_DISABLED ARM: OMAP2+: throw the die id into the entropy pool
2013-11-11Merge tag 'arm64-upstream' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cmarinas/linux-aarch64 Pull ARM64 update from Catalin Marinas: "Main features: - Ticket-based spinlock implementation and lockless lockref support - Big endian support - CPU hotplug support, currently for PSCI (Power State Coordination Interface) capable firmware - Virtual address space extended to 42-bit in the 64K page configuration (maximum VA space with 2 levels of page tables) - Compat (AArch32) kuser helpers updated to ARMv8 (make use of load-acquire/store-release instructions) - Code cleanup, defconfig update and minor fixes" * tag 'arm64-upstream' of git://git.kernel.org/pub/scm/linux/kernel/git/cmarinas/linux-aarch64: (43 commits) ARM64: /proc/interrupts: display IPIs of online CPUs only arm64: locks: Remove CONFIG_GENERIC_LOCKBREAK arm64: KVM: vgic: byteswap GICv2 access on world switch if BE arm64: KVM: initialize HYP mode following the kernel endianness arm64: compat: Clear the IT state independent of the 32-bit ARM or Thumb-2 mode arm64: Use 42-bit address space with 64K pages arm64: module: ensure instruction is little-endian before manipulation arm64: defconfig: Enable CONFIG_PREEMPT by default arm64: fix access to preempt_count from assembly code arm64: move enabling of GIC before CPUs are set online arm64: use generic RW_DATA_SECTION macro in linker script arm64: Slightly improve the warning on CPU0 enable-method ARM64: simplify cpu_read_bootcpu_ops using OF/DT helper ARM64: DT: define ARM64 specific arch_match_cpu_phys_id arm64: allow ioremap_cache() to use existing RAM mappings arm64: update 32-bit kuser helpers to ARMv8 arm64: perf: fix event number mask arm64: kconfig: allow CPU_BIG_ENDIAN to be selected arm64: Fix the endianness of arch_spinlock_t arm64: big-endian: write CPU holding pen address as LE ...
2013-11-11Merge tag 'gfs2-merge-window' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/steve/gfs2-3.0-nmw Pull gfs2 updates from Steven Whitehouse: "The main feature of interest this time is quota updates. There are some clean ups and some patches to use the new generic lru list code. There is still plenty of scope for some further changes in due course - faster lookups of quota structures is very much on the todo list. Also, a start has been made towards the more tricky issue of using the generic lru code with glocks, but that will have to be completed in a subsequent merge window. The other, more minor feature, is that there have been a number of performance patches which relate to block allocation. In particular they will improve performance when the disk is nearly full" * tag 'gfs2-merge-window' of git://git.kernel.org/pub/scm/linux/kernel/git/steve/gfs2-3.0-nmw: GFS2: Use generic list_lru for quota GFS2: Rename quota qd_lru_lock qd_lock GFS2: Use reflink for quota data cache GFS2: Use lockref for glocks GFS2: Protect quota sync generation GFS2: Inline qd_trylock into gfs2_quota_unlock GFS2: Make two similar quota code fragments into a function GFS2: Remove obsolete quota tunable GFS2: Move gfs2_icbit_munge into quota.c GFS2: Speed up starting point selection for block allocation GFS2: Add allocation parameters structure GFS2: Clean up reservation removal GFS2: fix dentry leaks GFS2: new function gfs2_rbm_incr GFS2: Introduce rbm field bii GFS2: Do not reset flags on active reservations GFS2: introduce bi_blocks for optimization GFS2: optimize rbm_from_block wrt bi_start GFS2: d_splice_alias() can't return error
2013-11-09uprobes: Fix the memory out of bound overwrite in copy_insn()Oleg Nesterov
1. copy_insn() doesn't look very nice, all calculations are confusing and it is not immediately clear why do we read the 2nd page first. 2. The usage of inode->i_size is wrong on 32-bit machines. 3. "Instruction at end of binary" logic is simply wrong, it doesn't handle the case when uprobe->offset > inode->i_size. In this case "bytes" overflows, and __copy_insn() writes to the memory outside of uprobe->arch.insn. Yes, uprobe_register() checks i_size_read(), but this file can be truncated after that. All i_size checks are racy, we do this only to catch the obvious mistakes. Change copy_insn() to call __copy_insn() in a loop, simplify and fix the bytes/nbytes calculations. Note: we do not care if we read extra bytes after inode->i_size if we got the valid page. This is fine because the task gets the same page after page-fault, and arch_uprobe_analyze_insn() can't know how many bytes were actually read anyway. Signed-off-by: Oleg Nesterov <oleg@redhat.com>
2013-11-09uprobes: Fix the wrong usage of current->utask in uprobe_copy_process()Oleg Nesterov
Commit aa59c53fd459 "uprobes: Change uprobe_copy_process() to dup xol_area" has a stupid typo, we need to setup t->utask->vaddr but the code wrongly uses current->utask. Even with this bug dup_xol_work() works "in practice", but only because get_unmapped_area(NULL, TASK_SIZE - PAGE_SIZE) likely returns the same address every time. Signed-off-by: Oleg Nesterov <oleg@redhat.com>
2013-11-08Merge tag 'asoc-v3.13-fixes' of ↵Takashi Iwai
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into for-linus ASoC: Updates for v3.13 Some additional fixes for v3.13, the majority of which are removals and downgrades of BUG()s from Takashi.
