git://people.freedesktop.org/~thomash/linux into drm-next
Two ttm regression fixes.
Pull request of 2014-02-05
* tag 'ttm-fixes-3.14-2014-02-05' of git://people.freedesktop.org/~thomash/linux:
drm/ttm: Don't clear page metadata of imported sg pages
drm/ttm: Fix TTM object open regression
I totally sign inverted my way out of this one.
Cc: stable@vger.kernel.org
Reported-by: "Sabrina Dubroca" <sd@queasysnail.net>
These page pointers shouldn't be visible to TTM in the first place, but
until we fix that up, don't clear the page metadata because that
will upset the exporter.
Reported-and-tested-by: Cristoph Haag <haagch.christoph@googleemail.com>
Signed-off-by: Thomas Hellstrom <thellstrom@vmware.com>
Reviewed-by: Jakob Bornecrantz <jakob@vmware.com>
Commit drm/ttm: ttm object security fixes for render nodes introduced a
regression where, if a TTM object was opened multiple times from the same
open file, the caller would spin uninterruptibly in the kernel.
Fix this.
mode->mdev otherwise the bw limits never kick in.
Reported in RHEL testing.
git://git.kernel.org/pub/scm/linux/kernel/git/deller/parisc-linux
Pull parisc updates from Helge Deller:
"The three major changes in this patchset is a implementation for
flexible userspace memory maps, cache-flushing fixes (again), and a
long-discussed ABI change to make EWOULDBLOCK the same value as
EAGAIN.
parisc has been the only platform where we had EWOULDBLOCK != EAGAIN
to keep HP-UX compatibility. Since we will probably never implement
full HP-UX support, we prefer to drop this compatibility to make it
easier for us with Linux userspace programs which mostly never checked
for both values. We don't expect major fall-outs because of this
change, and if we face some, we will simply rebuild the necessary
applications in the debian archives"
* 'parisc-3.14' of git://git.kernel.org/pub/scm/linux/kernel/git/deller/parisc-linux:
parisc: add flexible mmap memory layout support
parisc: Make EWOULDBLOCK be equal to EAGAIN on parisc
parisc: convert uapi/asm/stat.h to use native types only
parisc: wire up sched_setattr and sched_getattr
parisc: fix cache-flushing
parisc/sti_console: prefer Linux fonts over built-in ROM fonts
HPFS needs to load 4 consecutive 512-byte sectors when accessing the
directory nodes or bitmaps. We can't switch to 2048-byte block size
because files are allocated in the units of 512-byte sectors.
Previously, the driver would allocate a 2048-byte area using kmalloc,
copy the data from four buffers to this area and eventually copy them
back if they were modified.
In the current implementation of the buffer cache, buffers are allocated
in the pagecache. That means that 4 consecutive 512-byte buffers are
stored in consecutive areas in the kernel address space. So, we don't
need to allocate extra memory and copy the content of the buffers there.
This patch optimizes the code to avoid copying the buffers. It checks
if the four buffers are stored in contiguous memory - if they are not,
it falls back to allocating a 2048-byte area and copying data there.
Signed-off-by: Mikulas Patocka <mikulas@artax.karlin.mff.cuni.cz>
Previously, hpfs scanned all bitmaps each time the user asked for free
space using statfs. This patch changes it so that hpfs scans the
bitmaps only once, remembes the free space and on next invocation of
statfs it returns the value instantly.
New versions of wine are hammering on the statfs syscall very heavily,
making some games unplayable when they're stored on hpfs, with load
times in minutes.
This should be backported to the stable kernels because it fixes
user-visible problem (excessive level load times in wine).
Add support for the flexible mmap memory layout (as described in
http://lwn.net/Articles/91829). This is especially very interesting on
parisc since we currently only support 32bit userspace (even with a
64bit Linux kernel).
Signed-off-by: Helge Deller <deller@gmx.de>
On Linux, only parisc uses a different value for EWOULDBLOCK which
causes a lot of troubles for applications not checking for both values.
Since the hpux compat is long dead, make EWOULDBLOCK behave the same as
all other architectures.
Signed-off-by: Guy Martin <gmsoft@tuxicoman.be>
The stat.h header file is exported to userspace. Some userspace
applications failed to compile due to missing/unknown types, so we
better convert it to use native types only (like it's done on other
architectures too).
This commit:
f8dae00684d678afa13041ef170cecfd1297ed40: parisc: Ensure full cache coherency for kmap/kunmap
caused negative caching side-effects, e.g. hanging processes with expect and
too many inequivalent alias messages from flush_dcache_page() on Debian 5 systems.
This patch now partly reverts it and has been in production use on our debian buildd
makeservers since a week without any major problems.
Signed-off-by: John David Anglin <dave.anglin@bell.net>
Cc: stable@vger.kernel.org # v3.9+
The built-in ROM fonts lack many necessary ASCII characters, which is
why it makes sens to prefer the Linux fonts instead if they are
available. This makes consoles on STI graphics cards which are not
supported by the stifb driver (e.g. Visualize FXe) looks much nicer.
Cc: stable@vger.kernel.org # v3.13
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging
Pull hwmon kconfig fixes from Jean Delvare.
* 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging:
hwmon: Fix SENSORS_TMP102 dependencies to eliminate build errors
hwmon: Fix SENSORS_LM75 dependencies to eliminate build errors
git://git.kernel.org/pub/scm/linux/kernel/git/penberg/linux
Pull SLAB changes from Pekka Enberg:
"Random bug fixes that have accumulated in my inbox over the past few
months"
* 'slab/next' of git://git.kernel.org/pub/scm/linux/kernel/git/penberg/linux:
mm: Fix warning on make htmldocs caused by slab.c
mm: slub: work around unneeded lockdep warning
mm: sl[uo]b: fix misleading comments
slub: Fix possible format string bug.
slub: use lockdep_assert_held
slub: Fix calculation of cpu slabs
slab.h: remove duplicate kmalloc declaration and fix kernel-doc warnings
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux
Pull turbostat updates from Len Brown.
* 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux:
tools/power turbostat: introduce -s to dump counters
tools/power turbostat: remove unused command line option
turbostat: Add option to report joules consumed per sample
turbostat: run on HSX
turbostat: Add a .gitignore to ignore the compiled turbostat binary
turbostat: Clean up error handling; disambiguate error messages; use err and errx
turbostat: Factor out common function to open file and exit on failure
turbostat: Add a helper to parse a single int out of a file
turbostat: Check return value of fscanf
turbostat: Use GCC's CPUID functions to support PIC
turbostat: Don't attempt to printf an off_t with %zx
turbostat: Don't put unprocessed uapi headers in the include path
Pull ARM SoC fixes from Olof Johansson:
"Here's a set of patches for (hopefully) -rc1. Some of them are fixes,
but a good number of them also do things such as enable new drivers in
the defconfigs for platforms that have such devices, increases
coverage of the multiplatform defconfig and some DTS changes that
plumbs up some of the devices that now have bindings and driver
support.
The commit dates are recent; we've mostly collected these fixes in the
last few days but I also had to rebuild the branch yesterday to sort
out some internal conflicts which reset the timestamps. The changes
should have been tested by each platform maintainer already (and few
of them have cross-platform impact) so I'm personally not too
concerned by it at this time"
* tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (23 commits)
ARM: multi_v7_defconfig: remove redundant entries and re-enable TI_EDMA
ARM: multi_v7_defconfig: add mvebu drivers
clocksource: kona: Add basic use of external clock
drivers: bus: fix CCI driver kcalloc call parameters swap
ARM: dts: bcm28155-ap: Fix Card Detection GPIO
ARM: multi_v7_defconfig: Select CONFIG_AT803X_PHY
ARM: keystone: config: fix build warning when CONFIG_DMADEVICES is not set
MAINTAINERS: ARM: SiRF: use regex patterns to involve all SiRF drivers
ARM: dts: zynq: Add SDHCI nodes
ARM: hisi: don't select SMP
ARM: tegra: rebuild tegra_defconfig to add DEBUG_FS
ARM: multi_v7: copy most options from tegra_defconfig
ARM: iop32x: fix power off handling for the EM7210 board
ARM: integrator: restore static map on the CP
ARM: msm_defconfig: Enable MSM clock drivers
ARM: dts: msm: Add clock controller nodes and hook into uart
ARM: OMAP4+: move errata initialization to omap4_pm_init_early
ARM: OMAP4460: cpuidle: Extend PM_OMAP4_ROM_SMP_BOOT_ERRATUM_GICD on cpuidle
ARM: mvebu: fix compilation warning on Armada 370 (i.e. non-SMP)
ARM: shmobile: r8a7790.dtsi: ficx i2c[0-3] clock reference
Similar to what was done for the lm75 driver.
Add depends on THERMAL since that is what provides the
register/unregister functions above, but only if THERMAL_OF was
selected as this is an optional feature of the driver.
Cc: Randy Dunlap <rdunlap@infradead.org>
Acked-by: Eduardo Valentin <eduardo.valentin@ti.com>
Reviewed-by: Guenter Roeck <linux@roeck-us.net>
Based on an earlier attempt by Randy Dunlap.
Fix SENSORS_LM75 dependencies to eliminate build errors:
drivers/built-in.o: In function `lm75_remove':
lm75.c:(.text+0x12bd8c): undefined reference to `thermal_zone_of_sensor_unregister'
drivers/built-in.o: In function `lm75_probe':
lm75.c:(.text+0x12c123): undefined reference to `thermal_zone_of_sensor_register'
The new option allows just run turbostat and get dump of counter values. It's
useful when we have something more than one program to test.
Signed-off-by: Len Brown <len.brown@intel.com>
The -s is not used, let's remove it, and update quick help accordingly.
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild
Pull misc kbuild changes from Michal Marek:
"The non-critical part of kbuild is small this time:
- Three fixes for make deb-pkg
- A new coccinelle check
One of the deb-pkg fixes is a leftover from the last merge window,
hence the merge commit"
* 'misc' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild:
deb-pkg: Fix building for MIPS big-endian or ARM OABI
deb-pkg: Fix cross-building linux-headers package
scripts: Coccinelle script for pm_runtime_* return checks with IS_ERR_VALUE
deb-pkg: Inhibit initramfs builders if CONFIG_BLK_DEV_INITRD is not set
Both proc files are writeable and used for configuring cells. But
there is missing correct mode flag for writeable files. Without
this patch both proc files are read only.
[ It turns out they aren't really read-only, since root can write to
them even if the write bit isn't set due to CAP_DAC_OVERRIDE ]
Signed-off-by: Pali Rohár <pali.rohar@gmail.com>
With commit d8d14bd09cdd ("fs/compat: fix lookup_dcookie() parameter
handling") I changed the type of the len parameter of the
lookup_dcookie() syscall.
However I missed that there was still a stale declaration in
arch/tile/.. which now causes a compile error on tile:
In file included from fs/dcookies.c:28:0:
include/linux/compat.h:425:17: error: conflicting types for 'compat_sys_lookup_dcookie'
fs/dcookies.c:207:1: error: conflicting types for 'compat_sys_lookup_dcookie'
Simply remove the declaration in the tile architecture, which is only a
leftover from before the different compat lookup_dcookie() versions have
been merged. The correct declaration is now in include/linux/compat.h
The build error was reported by Fenguang's build bot.
Acked-by: Chris Metcalf <cmetcalf@tilera.com>
Pull cifs fixes from Steve French:
"A set of cifs fixes (mostly for symlinks, and SMB2 xattrs) and
cleanups"
* 'for-linus' of git://git.samba.org/sfrench/cifs-2.6:
cifs: Fix check for regular file in couldbe_mf_symlink()
[CIFS] Fix SMB2 mounts so they don't try to set or get xattrs via cifs
CIFS: Cleanup cifs open codepath
CIFS: Remove extra indentation in cifs_sfu_type
CIFS: Cleanup cifs_mknod
CIFS: Cleanup CIFSSMBOpen
cifs: Add support for follow_link on dfs shares under posix extensions
cifs: move unix extension call to cifs_query_symlink()
cifs: Re-order M-F Symlink code
cifs: Add create MFSymlinks to protocol ops struct
cifs: use protocol specific call for query_mf_symlink()
cifs: Rename MF symlink function names
cifs: Rename and cleanup open_query_close_cifs_symlink()
cifs: Fix memory leak in cifs_hardlink()
Pull vfs fixes from Al Viro:
"Several obvious fixes"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
Fix mountpoint reference leakage in linkat
hfsplus: use xattr handlers for removexattr
Typo in compat_sys_lseek() declaration
fs/super.c: sync ro remount after blocking writers
vfs: unexport the getname() symbol
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging
Pull rtl8812ae staging wireless driver from Greg KH:
"Here's a single staging driver for a wireless chipset that has shown
up in the SteamBox hardware. It is merged separately from the "main"
staging pull request to sync up with the wireless api changes that
came in from the networking tree.
It's self-contained and works for me and others. Larry will be
replacing it with a "real" driver for 3.15, but for now this one is
needed"
* tag 'staging-3.14-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging:
staging: r8821ae: Enable build by reverting BROKEN marking
staging: r8821ae: Fix build problems
Staging: rtl8812ae: disable due to build errors
Staging: rtl8821ae: add TODO file
Staging: rtl8821ae: removed unused functions and variables
Staging: rtl8821ae: rc.c: fix up function prototypes
Staging: rtl8812ae: Add Realtek 8821 PCI WIFI driver
Revert commit ef83b0781a73 "PCI: Remove from bus_list and release
resources in pci_release_dev()" that made some nasty race conditions
become possible. For example, if a Thunderbolt link is unplugged
and then replugged immediately, the pci_release_dev() resulting from
the hot-remove code path may be racing with the hot-add code path
which after that commit causes various kinds of breakage to happen
(up to and including a hard crash of the whole system).
Moreover, the problem that commit ef83b0781a73 attempted to address
cannot happen any more after commit 8a4c5c329de7 "PCI: Check parent
kobject in pci_destroy_dev()", because pci_destroy_dev() will now
return immediately if it has already been executed for the given
device.
Note, however, that the invocation of msi_remove_pci_irq_vectors()
removed by commit ef83b0781a73 from pci_free_resources() along with
the other changes made by it is not added back because of subsequent
code changes depending on that modification.
Fixes: ef83b0781a73 (PCI: Remove from bus_list and release resources in pci_release_dev())
Reported-by: Mika Westerberg <mika.westerberg@linux.intel.com>
TI_EDMA fell out of automatically selected options in the multi_v7
defconfig due to a select being removed from the davinci Kconfig entry. So
we need to re-enable explicitly to not regress some platforms.
The rest is just the result of running 'make multi_v7_defconfig + make
savedefconfig' to remove entries that are no longer needed due to changed
dependencies/selects or defaults.
Recent boot farm testing has highlighted some issues with mvebu and
multiplatform kernels. Increase the test coverage so we can discover
these issues earlier.
Signed-off-by: Jason Cooper <jason@lakedaemon.net>
When an clock is specified in the device tree, enable it and use it to
determine the external clock frequency.
Signed-off-by: Tim Kryger <tim.kryger@linaro.org>
Reviewed-by: Markus Mayer <markus.mayer@linaro.org>
Reviewed-by: Matt Porter <matt.porter@linaro.org>
Reviewed-by: Christian Daudt <bcm@fixthebug.org>
Acked-by: Daniel Lezcano <daniel.lezcano@linaro.org>
Signed-off-by: Christian Daudt <bcm@fixthebug.org>
Pull NFS client bugfixes from Trond Myklebust:
"Highlights:
- Fix several races in nfs_revalidate_mapping
- NFSv4.1 slot leakage in the pNFS files driver
- Stable fix for a slot leak in nfs40_sequence_done
- Don't reject NFSv4 servers that support ACLs with only ALLOW aces"
* tag 'nfs-for-3.14-2' of git://git.linux-nfs.org/projects/trondmy/linux-nfs:
nfs: initialize the ACL support bits to zero.
NFSv4.1: Cleanup
NFSv4.1: Clean up nfs41_sequence_done
NFSv4: Fix a slot leak in nfs40_sequence_done
NFSv4.1 free slot before resending I/O to MDS
nfs: add memory barriers around NFS_INO_INVALID_DATA and NFS_INO_INVALIDATING
NFS: Fix races in nfs_revalidate_mapping
sunrpc: turn warn_gssd() log message into a dprintk()
NFS: fix the handling of NFS_INO_INVALID_DATA flag in nfs_revalidate_mapping
nfs: handle servers that support only ALLOW ACE type.
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound
Pull sound fixes from Takashi Iwai:
"The big chunks here are the updates for oxygen driver for Xonar DG
devices, which were slipped from the previous pull request. They are
device-specific and thus not too dangerous.
Other than that, all patches are small bug fixes, mainly for Samsung
build fixes, a few HD-audio enhancements, and other misc ASoC fixes.
(And this time ASoC merge is less than Octopus, lucky seven :)"
* tag 'sound-fix-3.14-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (42 commits)
ALSA: hda/hdmi - allow PIN_OUT to be dynamically enabled
ALSA: hda - add headset mic detect quirks for another Dell laptop
ALSA: oxygen: Xonar DG(X): cleanup and minor changes
ALSA: oxygen: Xonar DG(X): modify high-pass filter control
ALSA: oxygen: Xonar DG(X): modify input select functions
ALSA: oxygen: Xonar DG(X): modify capture volume functions
ALSA: oxygen: Xonar DG(X): use headphone volume control
ALSA: oxygen: Xonar DG(X): modify playback output select
ALSA: oxygen: Xonar DG(X): capture from I2S channel 1, not 2
ALSA: oxygen: Xonar DG(X): move the mixer code into another file
ALSA: oxygen: modify CS4245 register dumping function
ALSA: oxygen: modify adjust_dg_dac_routing function
ALSA: oxygen: Xonar DG(X): modify DAC/ADC parameters function
ALSA: oxygen: Xonar DG(X): modify initialization functions
ALSA: oxygen: Xonar DG(X): add new CS4245 SPI functions
ALSA: oxygen: additional definitions for the Xonar DG/DGX card
ALSA: oxygen: change description of the xonar_dg.c file
ALSA: oxygen: export oxygen_update_dac_routing symbol
ALSA: oxygen: add mute mask for the OXYGEN_PLAY_ROUTING register
ALSA: oxygen: modify the SPI writing function
git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending
Pull SCSI target updates from Nicholas Bellinger:
"The highlights this round include:
- add support for SCSI Referrals (Hannes)
- add support for T10 DIF into target core (nab + mkp)
- add support for T10 DIF emulation in FILEIO + RAMDISK backends (Sagi + nab)
- add support for T10 DIF -> bio_integrity passthrough in IBLOCK backend (nab)
- prep changes to iser-target for >= v3.15 T10 DIF support (Sagi)
- add support for qla2xxx N_Port ID Virtualization - NPIV (Saurav + Quinn)
- allow percpu_ida_alloc() to receive task state bitmask (Kent)
- fix >= v3.12 iscsi-target session reset hung task regression (nab)
- fix >= v3.13 percpu_ref se_lun->lun_ref_active race (nab)
- fix a long-standing network portal creation race (Andy)"
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: (51 commits)
target: Fix percpu_ref_put race in transport_lun_remove_cmd
target/iscsi: Fix network portal creation race
target: Report bad sector in sense data for DIF errors
iscsi-target: Convert gfp_t parameter to task state bitmask
iscsi-target: Fix connection reset hang with percpu_ida_alloc
percpu_ida: Make percpu_ida_alloc + callers accept task state bitmask
iscsi-target: Pre-allocate more tags to avoid ack starvation
qla2xxx: Configure NPIV fc_vport via tcm_qla2xxx_npiv_make_lport
qla2xxx: Enhancements to enable NPIV support for QLOGIC ISPs with TCM/LIO.
qla2xxx: Fix scsi_host leak on qlt_lport_register callback failure
IB/isert: pass scatterlist instead of cmd to fast_reg_mr routine
IB/isert: Move fastreg descriptor creation to a function
IB/isert: Avoid frwr notation, user fastreg
IB/isert: seperate connection protection domains and dma MRs
tcm_loop: Enable DIF/DIX modes in SCSI host LLD
target/rd: Add DIF protection into rd_execute_rw
target/rd: Add support for protection SGL setup + release
target/rd: Refactor rd_build_device_space + rd_release_device_space
target/file: Add DIF protection support to fd_execute_rw
target/file: Add DIF protection init/format support
This patch fixes a bug/typo in the CCI driver kcalloc usage
that inadvertently swapped the parameters order in the
kcalloc call and went unnoticed.
Reported-by: Xia Feng <xiafeng@allwinnertech.com>
Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
The board schematic states that the "SD_CARD_DET_N gets pulled to GND
when card is inserted" so the polarity has been updated to active low.
Polarity is now specified with a GPIO define instead of a magic number.
git://git.kernel.org/pub/scm/linux/kernel/git/horms/renesas into fixes
Second Round of Renesas ARM Based SoC DT Fixes for v3.14
Correct i2c clock references for r8a7790 (R-Car H2) SoC
The error was introduced in 72197ca7a1cb1cea5 ("ARM: shmobile: r8a7790:
Reference clocks") which is queued up for v3.14.
* tag 'renesas-dt-fixes2-for-v3.14' of git://git.kernel.org/pub/scm/linux/kernel/git/horms/renesas:
Select CONFIG_AT803X_PHY so that we can boot hummingboard via NFS.
Drop automatic selection of TI_EDMA from Keystone Kconfig file,
as it produces build warning in case if CONFIG_DMADEVICES is not set:
warning: (ARCH_KEYSTONE) selects TI_EDMA which has unmet direct dependencies (DMADEVICES && (ARCH_DAVINCI || ARCH_OMAP || ARCH_KEYSTONE))
Instead enable TI EDMA support from defconfig.
Reported-by: Russell King <rmk+kernel@arm.linux.org.uk>
Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com>
Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
instead of listing drivers one by one, use regex patterns to involve all
SiRF drivers directly.
this also adds sirf UART and watchdog drivers automatically from:
drivers/tty/serial/sirfsoc_uart.*
drivers/watchdog/sirfsoc_wdt.c
Cc: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
Cc: Wim Van Sebroeck <wim@iguana.be>
Signed-off-by: Barry Song <Baohua.Song@csr.com>
mvebu fixes for v3.13 (incremental #2)
- allow building and booting DT and non-DT plat-orion SoCs
- catch proper return value for kirkwood_pm_init()
- properly check return of of_iomap to solve boot hangs (mirabox, others)
- remove a compile warning on Armada 370 with non-SMP.
* tag 'mvebu-fixes-3.13-2' of git://git.infradead.org/linux-mvebu:
ARM: mvebu: Fix kernel hang in mvebu_soc_id_init() when of_iomap failed
ARM: kirkwood: kirkwood_pm_init() should return void
ARM: orion: provide C-style interrupt handler for MULTI_IRQ_HANDLER
Add nodes for the Arasan SDHCI controller to Zynq dts files.
Signed-off-by: Soren Brinkmann <soren.brinkmann@xilinx.com>
SMP is a user configurable option, not a hardware feature and should not
be selected.
Signed-off-by: Rob Herring <robh@kernel.org>
DEBUG_FS used to be selected by COMMON_CLK_DEBUG, which was enabled
by tegra_defconfig. However, this config option no longer exists, so
no longer selects DEBUG_FS, and nothing else selects it either. So,
"make tegra_defconfig" no longer enables DEBUG_FS in .config.
Rebuild tegra_defconfig on top of next-20140424, while manually
re-enabling DEBUG_FS.
Reasons for removed entries are:
- I2C_MUX: selected by MEDIA_SUBDRV_AUTOSELECT
- DRM_PANEL: selected by DRM_TEGRA
- NEW_LEDS: selected by many things; at least VT
- LEDS_CLASS: selected by many things; at least VT
- LEDS_TRIGGERS: selected by many things; at least VT
- COMMON_CLK_DEBUG: no longer exists
Signed-off-by: Kevin Hilman <khilman@linaro.org>
multi_v7_defconfig was missing a large number of options that were in
tegra_defconfig. This patch adds them. The changes fall into the
following categories:
* Enable more Tegra SoC options/drivers.
* Enable more drivers for Tegra boards.
* Enable more options that are useful for running distros.
The patch removes a few lines as well, simply because those options are
now selected by something else, and "make savedefconfig" removes them. I
verified that the options appear in .config after
"make multi_v7_defconfig".
This board was missed when converting all the others to proper
abstracted GPIO handling. Fix it up the right way by requesting
and driving GPIO line 0 high through gpiolib to power off the
machine.
Cc: Arnaud Patard <arnaud.patard@rtp-net.org>
Commit 78d1632183454dba46ca8295484a5e7603acdc18 deleted the
static mappings of the core modules, but this static map is
still needed on the Integrator/CP (not the Integrator/AP).
Restore the static map on the Integrator/CP.
Reported-by: Will Deacon <will.deacon@arm.com>
This allows us to probe the clock controller devices and boot to a
serial console on all DT enabled MSM platforms.
Cc: David Brown <davidb@codeaurora.org>
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
