IPoIB uses a two layer neighboring scheme, such that for each struct neighbour
whose device is an ipoib one, there is a struct ipoib_neigh buddy which is
created on demand at the tx flow by an ipoib_neigh_alloc(skb->dst->neighbour)
call.
When using the bonding driver, neighbours are created by the net stack on behalf
of the bonding (master) device. On the tx flow the bonding code gets an skb such
that skb->dev points to the master device, it changes this skb to point on the
slave device and calls the slave hard_start_xmit function.
Under this scheme, ipoib_neigh_destructor assumption that for each struct
neighbour it gets, n->dev is an ipoib device and hence netdev_priv(n->dev)
can be casted to struct ipoib_dev_priv is buggy.
To fix it, this patch adds a dev field to struct ipoib_neigh which is used
instead of the struct neighbour dev one, when n->dev->flags has the
IFF_MASTER bit set.
Signed-off-by: Moni Shoua <monis at voltaire.com>
Signed-off-by: Or Gerlitz <ogerlitz at voltaire.com>
Acked-by: Roland Dreier <rdreier@cisco.com>
Signed-off-by: Jeff Garzik <jeff@garzik.org>
pci_enable_device() is __must_check so do that in natsemi_resume().
Signed-off-by: Mark Brown <broonie@sirena.org.uk>
Unless we have failed to fill the RX ring the timer used by the natsemi
driver is not particularly urgent and can use round_jiffies() to allow
grouping with other timers.
* git://git.linux-nfs.org/pub/linux/nfs-2.6: (131 commits)
NFSv4: Fix a typo in nfs_inode_reclaim_delegation
NFS: Add a boot parameter to disable 64 bit inode numbers
NFS: nfs_refresh_inode should clear cache_validity flags on success
NFS: Fix a connectathon regression in NFSv3 and NFSv4
NFS: Use nfs_refresh_inode() in ops that aren't expected to change the inode
SUNRPC: Don't call xprt_release in call refresh
SUNRPC: Don't call xprt_release() if call_allocate fails
SUNRPC: Fix buggy UDP transmission
[23/37] Clean up duplicate includes in
[2.6 patch] net/sunrpc/rpcb_clnt.c: make struct rpcb_program static
SUNRPC: Use correct type in buffer length calculations
SUNRPC: Fix default hostname created in rpc_create()
nfs: add server port to rpc_pipe info file
NFS: Get rid of some obsolete macros
NFS: Simplify filehandle revalidation
NFS: Ensure that nfs_link() returns a hashed dentry
NFS: Be strict about dentry revalidation when doing exclusive create
NFS: Don't zap the readdir caches upon error
NFS: Remove the redundant nfs_reval_fsid()
NFSv3: Always use directory post-op attributes in nfs3_proc_lookup
Fix up trivial conflict due to sock_owned_by_user() cleanup manually in
net/sunrpc/xprtsock.c
git://git.kernel.org/pub/scm/linux/kernel/git/peterz/linux-2.6-lockdep
* 'v2.6.24-lockdep' of git://git.kernel.org/pub/scm/linux/kernel/git/peterz/linux-2.6-lockdep:
lockdep: annotate dir vs file i_mutex
lockdep: per filesystem inode lock class
lockdep: annotate kprobes irq fiddling
lockdep: annotate rcu_read_{,un}lock{,_bh}
lockdep: annotate journal_start()
lockdep: s390: connect the sysexit hook
lockdep: x86_64: connect the sysexit hook
lockdep: i386: connect the sysexit hook
lockdep: syscall exit check
lockdep: fixup mutex annotations
lockdep: fix mismatched lockdep_depth/curr_chain_hash
lockdep: Avoid /proc/lockdep & lock_stat infinite output
lockdep: maintainers
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6
* 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6:
[IA64] update sn2_defconfig
[IA64] Fix kernel hangup in kdump on INIT
[IA64] Fix kernel panic in kdump on INIT
[IA64] Remove vector from ia64_machine_kexec()
[IA64] Fix race when multiple cpus go through MCA
[IA64] Remove needless delay in MCA rendezvous
[IA64] add driver for ACPI methods to call native firmware
[IA64] abstract SAL_CALL wrapper to allow other firmware entry points
[IA64] perfmon: Remove exit_pfm_fs()
[IA64] tree-wide: Misc __cpu{initdata, init, exit} annotations
Commit 5a7ad7f044941316dc98eda2a087a12a7a50649d removed all uses of
'retval', but didn't remove the variable itself.
Update defonfig file for sn2 to match recent changes in config options.
Signed-off-by: Jes Sorensen <jes@sgi.com>
Signed-off-by: Tony Luck <tony.luck@intel.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/mingo/linux-2.6-sched: (140 commits)
sched: sync wakeups preempt too
sched: affine sync wakeups
sched: guest CPU accounting: maintain guest state in KVM
sched: guest CPU accounting: maintain stats in account_system_time()
sched: guest CPU accounting: add guest-CPU /proc/<pid>/stat fields
sched: guest CPU accounting: add guest-CPU /proc/stat field
sched: domain sysctl fixes: add terminator comment
sched: domain sysctl fixes: do not crash on allocation failure
sched: domain sysctl fixes: unregister the sysctl table before domains
sched: domain sysctl fixes: use for_each_online_cpu()
sched: domain sysctl fixes: use kcalloc()
Make scheduler debug file operations const
sched: enable wake-idle on CONFIG_SCHED_MC=y
sched: reintroduce topology.h tunings
sched: allow the immediate migration of cache-cold tasks
sched: debug, improve migration statistics
sched: debug: increase width of debug line
sched: activate task_hot() only on fair-scheduled tasks
sched: reintroduce cache-hot affinity
sched: speed up context-switches a bit
* master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (207 commits)
[SCSI] gdth: fix CONFIG_ISA build failure
[SCSI] esp_scsi: remove __dev{init,exit}
[SCSI] gdth: !use_sg cleanup and use of scsi accessors
[SCSI] gdth: Move members from SCp to gdth_cmndinfo, stage 2
[SCSI] gdth: Setup proper per-command private data
[SCSI] gdth: Remove gdth_ctr_tab[]
[SCSI] gdth: switch to modern scsi host registration
[SCSI] gdth: gdth_interrupt() gdth_get_status() & gdth_wait() fixes
[SCSI] gdth: clean up host private data
[SCSI] gdth: Remove virt hosts
[SCSI] gdth: Reorder scsi_host_template intitializers
[SCSI] gdth: kill gdth_{read,write}[bwl] wrappers
[SCSI] gdth: Remove 2.4.x support, in-kernel changelog
[SCSI] gdth: split out pci probing
[SCSI] gdth: split out eisa probing
[SCSI] gdth: split out isa probing
gdth: Make one abuse of scsi_cmnd less obvious
[SCSI] NCR5380: Use scsi_eh API for REQUEST_SENSE invocation
[SCSI] usb storage: use scsi_eh API in REQUEST_SENSE execution
[SCSI] scsi_error: Refactoring scsi_error to facilitate in synchronous REQUEST_SENSE
master.kernel.org:/pub/scm/linux/kernel/git/airlied/agp-2.6
* 'agp-patches' of master.kernel.org:/pub/scm/linux/kernel/git/airlied/agp-2.6:
fix use after free in amd create gatt pages
AGP fix race condition between unmapping and freeing pages
ssh://master.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6
* 'drm-patches' of ssh://master.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6:
via invalid device ids removal
radeon: Commit the ring after each partial texture upload blit.
i915: fix vbl swap allocation size.
drm: Replace DRM_IOCTL_ARGS with (dev, data, file_priv) and remove DRM_DEVICE.
drm: remove XFREE86_VERSION macros.
drm: Replace filp in ioctl arguments with drm_file *file_priv.
drm: Remove DRM_ERR OS macro.
* 'nfs-server-stable' of git://linux-nfs.org/~bfields/linux:
knfsd: query filesystem for NFSv4 getattr of FATTR4_MAXNAME
knfsd: nfsv4 delegation recall should take reference on client
knfsd: don't shutdown callbacks until nfsv4 client is freed
knfsd: let nfsd manage timing out its own leases
knfsd: Add source address to sunrpc svc errors
knfsd: 64 bit ino support for NFS server
svcgss: move init code into separate function
knfsd: remove code duplication in nfsd4_setclientid()
nfsd warning fix
knfsd: fix callback rpc cred
knfsd: move nfsv4 slab creation/destruction to module init/exit
knfsd: spawn kernel thread to probe callback channel
knfsd: nfs4 name->id mapping not correctly parsing negative downcall
knfsd: demote some printk()s to dprintk()s
knfsd: cleanup of nfsd4 cmp_* functions
knfsd: delete code made redundant by map_new_errors
nfsd: fix horrible indentation in nfsd_setattr
nfsd: remove unused cache_for_each macro
nfsd: tone down inaccurate dprintk
Kill unused variables
Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com>
Fix bogus copying of data into userspace when HIDIOCGRDESC is issued.
HID-transport layer makes sure that dev->hid->rdesc is not larger than
HID_MAX_DESCRIPTOR_SIZE.
Noticed-by: Al Viro <viro@ftp.linux.org.uk>
make sure sync wakeups preempt too - the scheduler will not
overschedule as we've got various throttles against that.
As a result, sync wakeups can be used more widely in the kernel
(to signal wakeup affinity between tasks), and no arbitrary
latencies will be introduced either.
make sync wakeups affine for cache-cold tasks: if a cache-cold task
is woken up by a sync wakeup then use the opportunity to migrate it
straight away. (the two tasks are 'related' because they communicate)
Modify KVM to update guest time accounting.
[ mingo@elte.hu: ported to 2.6.24 KVM. ]
Signed-off-by: Laurent Vivier <Laurent.Vivier@bull.net>
Acked-by: Avi Kivity <avi@qumranet.com>
modify account_system_time() to add cputime to cpustat->guest if we are
running a VCPU. We add this cputime to cpustat->user instead of
cpustat->system because this part of KVM code is in fact user code
although it is executed in the kernel. We duplicate VCPU time between
guest and user to allow an unmodified "top(1)" to display correct value.
A modified "top(1)" is able to display good cpu user time and cpu guest
time by subtracting cpu guest time from cpu user time. Update "gtime" in
task_struct accordingly.
like for cpustat, introduce the "gtime" (guest time of the task) and
"cgtime" (guest time of the task children) fields for the
tasks. Modify signal_struct and task_struct.
Modify /proc/<pid>/stat to display these new fields.
as recent CPUs introduce a third running state, after "user" and
"system", we need a new field, "guest", in cpustat to store the time
used by the CPU to run virtual CPU. Modify /proc/stat to display this
new field.
we had an incorrect-terminator bug in sd_alloc_ctl_domain_table()
before, so add a comment that documents it.
Signed-off-by: Milton Miller <miltonm@bga.com>
Now that we are calling this at runtime, a more relaxed error path is
suggested. If an allocation fails, we just register the partial table,
which will show empty directories.
Unregister and free the sysctl table before destroying domains, then
rebuild and register after creating the new domains. This prevents the
sysctl table from pointing to freed memory for root to write.
init_sched_domain_sysctl was walking cpus 0-n and referencing per_cpu
variables. If the cpus_possible mask is not contigious this will result
in a crash referencing unallocated data. If the online mask is not
contigious then we would show offline cpus and miss online ones.
kcalloc checks for n * sizeof(element) overflows and it zeros.
In general, struct file_operations are const in the kernel, to not have
false cacheline sharing and to catch bugs at compiletime with accidental
writes to them. The new scheduler code introduces a new non-const one;
fix this up.
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
most multicore CPUs today have shared L2 caches, so tune things so
that the spreading amongst cores is more aggressive.
reintroduce the 2.6.22 topology.h tunings again - they result in
slightly better balancing.
allow the immediate migration of cache-cold tasks.
add new migration statistics when SCHED_DEBUG and SCHEDSTATS
is enabled. Available in /proc/<PID>/sched.
increase width of debug line - in preparation of more debugging info.
activate task_hot() only for fair-scheduled tasks (i.e. disable it
for RT tasks).
reintroduce a simplified version of cache-hot/cold scheduling
affinity. This improves performance with certain SMP workloads,
such as sysbench.
speed up context-switches a bit by not clearing p->exec_start.
(as a side-effect, this also makes p->exec_start a universal timestamp
available to cache-hot estimations.)
do not wakeup-preempt with SCHED_BATCH tasks, their preemption
is batched too, driven by the tick.
Generate uevents when a user is being created/destroyed. These events
can be used to configure cpu share of a new user.
Signed-off-by: Srivatsa Vaddagiri <vatsa@linux.vnet.ibm.com>
Signed-off-by: Dhaval Giani <dhaval@linux.vnet.ibm.com>
do not normalize kernel threads via SysRq-N: the migration threads,
softlockup threads, etc. might be essential for the system to
function properly. So only zap user tasks.
pointed out by Andi Kleen.
remove stale comment from sched_group_set_shares().
Function never returns -EINVAL.
Signed-off-by: Andi Kleen <ak@suse.de>
clean up is_migration_thread() and turn it into an inline function.
Replace a particularly ugly ifdef with an inline and a new macro.
Also split up the function to be easier to read.
Refactor common code of sleep_on / wait_for_completion
These functions were largely cut'n'pasted. This moves
the common code into single helpers instead. Advantage
is about 1k less code on x86-64 and 91 lines of code removed.
It adds one function call to the non timeout version of
the functions; i don't expect this to be measurable.
Replace loops implemented with gotos with real loops.
Replace err = ...; goto x; x: return err; with return ...;
No functional changes.
update comment: clarify time-slices and remove obsolete tuning detail.
Prevent wakeup over-scheduling. Once a task has been preempted by a
task of the same or lower priority, it becomes ineligible for repeated
preemption by same until it has been ticked, or slept. Instead, the
task is marked for preemption at the next tick. Tasks of higher
priority still preempt immediately.
Signed-off-by: Mike Galbraith <efault@gmx.de>
Implement feature bit to disable forced preemption. This way
it can be checked whether a workload is overscheduling or not.
The following patch (sched: disable sleeper_fairness on SCHED_BATCH)
seems to break GROUP_SCHED. Although, it may be 'oops'-less due to the
possibility of 'p' being always a valid address.
Signed-off-by: Dmitry Adamushko <dmitry.adamushko@gmail.com>
cache_nice_tries and flags entry do not appear in proc fs sched_domain
directory, because ctl_table entry is skipped.
This patch fixes the issue.
Signed-off-by: Zou Nan hai <nanhai.zou@intel.com>
yield() in wait_task_inactive(), can cause a high priority thread to be
scheduled back in, and there by loop forever while it is waiting for some
lower priority thread which is unfortunately still on the runqueue.
Use schedule_timeout_uninterruptible(1) instead.
Signed-off-by: Gautham R Shenoy <ego@in.ibm.com>
Credit: Oleg Nesterov <oleg@tv-sign.ru>
Add tunables in sysfs to modify a user's cpu share.
A directory is created in sysfs for each new user in the system.
/sys/kernel/uids/<uid>/cpu_share
Reading this file returns the cpu shares granted for the user.
Writing into this file modifies the cpu share for the user. Only an
administrator is allowed to modify a user's cpu share.
Ex:
# cd /sys/kernel/uids/
# cat 512/cpu_share
1024
# echo 2048 > 512/cpu_share
# cat 512/cpu_share
2048
