MTD has recently been upgraded for 64-bit support, see commit
number 69423d99fc182a81f3c5db3eb5c140acc6fc64be in the
mtd-2.6.git tree (git://git.infradead.org/mtd-2.6.git)
or see this URL:
http://git.infradead.org/mtd-2.6.git?a=commit;h=69423d99fc182a81f3c5db3eb5c140acc6fc64be
Some variables in MTD data structures which were 32-bit
became 64-bit. Namely, the 'size' field in 'struct mtd_info'
and the 'addr'/'len' fields in 'struct erase_info'. This
means we have to use 'do_div' to divide them.
This patch fixes the following linking error:
ERROR: "__udivdi3" [drivers/mtd/devices/mtd_dataflash.ko] undefined!
ERROR: "__umoddi3" [drivers/mtd/devices/mtd_dataflash.ko] undefined!
This patch changes divisions of 64-bit variable so that they use
'do_div'. This patch also change some print placeholders to
get rid of gcc warnings.
Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
Cc: David Brownell <david-b@pacbell.net>
Cc: Nicolas Pitre <nico@cam.org>
The ECCM maybe set in bootloader, Get ECCM settings from the bootloader,
can avoid the image written by bootloader cannot read out by kernel.
But the limitation of doing it this way is that, it could break large page
NAND if it is written with NAND disabled in u-boot and read with NAND
enabled, or vice versa.
Signed-off-by: Jason Jin <Jason.jin@freescale.com>
Acked-by: Scott Wood <scottwood@freescale.com>
Delete extra kernel-doc notation for struct fields and function
parameters that don't exist:
Warning(include/linux/mtd/nand.h:428): Excess struct/union/enum/typedef member 'wq' description in 'nand_chip'
Warning(include/linux/mtd/nand.h:428): Excess struct/union/enum/typedef member 'datbuf' description in 'nand_chip'
Warning(include/linux/mtd/nand.h:428): Excess struct/union/enum/typedef member 'oobbuf' description in 'nand_chip'
Warning(include/linux/mtd/nand.h:428): Excess struct/union/enum/typedef member 'oobdirty' description in 'nand_chip'
Warning(include/linux/mtd/nand.h:428): Excess struct/union/enum/typedef member 'data_poi' description in 'nand_chip'
Warning(drivers/mtd/nand/nand_base.c:2527): Excess function parameter 'maxchips' description in 'nand_scan_tail'
The mtd partition parser returns an allocated pointer array of
mtd_partition. The caller must free it. The array is used only for
add_mtd_partitions(), so free it just after the call.
Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
Cc: Mike Frysinger <vapier.adi@gmail.com>
ARRAY_SIZE is more concise to use when the size of an array is divided by
the size of its type or the size of its first element.
The semantic patch that makes this change is as follows:
(http://www.emn.fr/x-info/coccinelle/)
// <smpl>
@i@
#include <linux/kernel.h>
@depends on i using "paren.iso"@
type T;
T[] E;
- (sizeof(E)/sizeof(E[...]))
+ ARRAY_SIZE(E)
// </smpl>
The current method for always showing physmap compat address, size, and
width is a bit confusing. If length is set to 0, then the address and
width are still shown but silently unused. The physmap code itself
already has logic which sets compat based on length, so just pull that out
and into the Kconfig to make everything clear.
Cc: Bryan Wu <Bryan.Wu@analog.com>
git://git.kernel.org/pub/scm/linux/kernel/git/lumag/tosa-2.6
Base versions handle constant folding just fine.
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
Triggered by a smaller cleanup from Jianjun Kong <jianjun@zeuux.org>
MTD internal API presently uses 32-bit values to represent
device size. This patch updates them to 64-bits but leaves
the external API unchanged. Extending the external API
is a separate issue for several reasons. First, no one
needs it at the moment. Secondly, whether the implementation
is done with IOCTLs, sysfs or both is still debated. Thirdly
external API changes require the internal API to be accepted
first.
Note that although the MTD API will be able to support 64-bit
device sizes, existing drivers do not and are not required
to do so, although NAND base has been updated.
In general, changing from 32-bit to 64-bit values cause little
or no changes to the majority of the code with the following
exceptions:
- printk message formats
- division and modulus of 64-bit values
- NAND base support
- 32-bit local variables used by mtdpart and mtdconcat
- naughtily assuming one structure maps to another
in MEMERASE ioctl
Signed-off-by: Adrian Hunter <ext-adrian.hunter@nokia.com>
Nandsim consumes ~2x more RAM than the density of simulated device.
It becomes critical if we need to simulate 256MB NAND and run stress tests
on it.
We investigated the reasons. nandsim allocates space for pages using kmalloc
function. The size of LP nand page is 2112 bytes.
kmalloc gets space from slab pools by chunks 2^n. So if we need to kmalloc
2112 bytes, 4096 bytes will be consumed by system.
The best way to avoid this issue would be using kmem_cache allocations. AFAIK
this mechanism specially designed to handle cases when arrays of allocations
are used.
Signed-off-by: Alexey Korolev <akorolev@infradead.org>
Tested-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
Acked-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
Add a new module parameter 'cache_file' which causes nandsim
to use that file instead of memory to cache nand data.
Using a file allows the simulation of NAND that is bigger
than the available memory.
nand_base sometimes reads only 2 bytes of a 4 byte id.
It is OK. Do not print a warning in that case.
The function init_impa7 does not need to be global, and
this patch makes it static by adding the needed keyword
to drivers/mtd/maps/impa7.c.
Signed-off-by: Dmitri Vorobiev <dmitri.vorobiev@movial.fi>
The function init_redwood_flash is needlessly defined global,
make it static by this patch.
The function init_msp_flash, which is not used outside of
drivers/mtd/maps/pmcmsp-flash.c, can become static. This
patch adds the needed keyword.
The function h720x_mtd_init is not used outside of the file
drivers/mtd/maps/h720x-flash.c and can therefore become static.
This patch adds the necessary keyword.
The function init_mbx can become static, because it is not used
outside the file drivers/mtd/maps/mbx860.c. This patch adds the
needed keyword.
The function init_vmax301 is needlessly defined global in
drivers/mtd/maps/vmax301.c, and this patch makes it static.
The symbol init_fortunet is needlessly defined global in
drivers/mtd/maps/fortunet.c. Make it static and clean up
the kernel global namespace.
The symbol alchemy_mtd_init does not need to be global, so make it
static in drivers/mtd/maps/alchemy-flash.c.
The symbol ipaq_mtd_init is not used anywhere outside of
drivers/mtd/maps/ipaq-flash.c, so make it static.
The symbol init_dbox2_flash is not used outside of the file
drivers/mtd/maps/dbox2-flash.c, so make it static.
The module init function init_flagadm does not need to be global,
so add the needed keyword to drivers/mtd/maps/cfi_flagadm.c.
The function init_oct5066 is needlessly defined global in
drivers/mtd/maps/octagon-5066.c. Make it static.
The init_edb7312nor function is needlessly defined global in
drivers/mtd/maps/edb7312.c, and this patch makes it static.
The function init_sbc82xx_flash is needlessly defined global in
drivers/mtd/maps/wr_sbc82xx_flash.c, and this patch makes it static.
The function init_rpxlite, which is not used outside of
drivers/mtd/maps/rpxlite.c, can become static. Add the
needed keyword.
The init_tqm_mtd function does not need to be defined globally
in drivers/mtd/maps/tqm8xxl.c. Make it static.
The functions uclinux_mtd_cleanup and uclinux_mtd_init do
not heed to be global. Add the needed keyword to the file
drivers/mtd/maps/uclinux.c to make these functions static.
The symbols lart_flash_init, lart_flash_exit are needlessly
defined global in drivers/mtd/devices/lart.c, so make them
static.
The function init_sbc8240_mtd is not called from outside the
module drivers/mtd/maps/sbc8240.c where it is defined, so it
can become static. Add the needed keyword.
The function init_sharpsl is needlessly defined global.
Make it static by adding the needed keyword to the file
drivers/mtd/maps/sharpsl-flash.c, where the function is
defined.
* git://git.infradead.org/mtd-2.6:
[MTD] [NAND] fix OOPS accessing flash operations over STM flash on PXA
[MTD] [NAND] drivers/mtd/nand/pasemi_nand.c: Add missing pci_dev_put
[MTD] [NAND] fsl_upm: fix build problem with 2.6.28-rc2
[MTD] physmap: fix memory leak on physmap_flash_remove by using devres
[MTD] m25p80: chip erase != block erase != sector erase
[MTD] m25p80: fix detection of m25p16 flashes
[MTD] m25p80: fix detection of SPI parts
[MTD] [NAND] OMAP: OneNAND: header file relocation (part 2)
git://git.kernel.org/pub/scm/linux/kernel/git/viro/audit-current
* 'audit.b59' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/audit-current:
[PATCH] fix broken timestamps in AVC generated by kernel threads
[patch 1/1] audit: remove excess kernel-doc
[PATCH] asm/generic: fix bug - kernel fails to build when enable some common audit code on Blackfin
[PATCH] return records for fork() both to child and parent
[PATCH] Audit: make audit=0 actually turn off audit
git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev
* 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev:
ata: Fix experimental tags
pata_ninja32: update ID table
pata_sis: Remove bogus cable match
ATA: piix, fix pointer deref on suspend
pata_hpt366: fix clock detection
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6
* 'drm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6:
drm/i915: Disable the GM965 MSI errata workaround.
drm/i915: Don't return error in evict_everything when we get to the end.
drm/radeon: don't actually enable the IRQ regs until irq is enabled
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc
* 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc:
powerpc/virtex5: Fix Virtex5 machine check handling
This new color expansion acceleration for radeonfb appears to trigger
problems with X on VT switch and suspend/resume on some machines. It
might be a problem in the VT layer or in X, but I haven't quite found
it yet, so in the meantime, this disables the acceleration by default,
reverting to 2.6.27 state. It can be enabled using the "accel_cexp"
module parameter or fbdev argument.
Timestamp in audit_context is valid only if ->in_syscall is set.
Delete excess kernel-doc notation in kernel/auditsc.c:
Warning(linux-2.6.27-git10//kernel/auditsc.c:1481): Excess function parameter or struct member 'tsk' description in 'audit_syscall_entry'
Warning(linux-2.6.27-git10//kernel/auditsc.c:1564): Excess function parameter or struct member 'tsk' description in 'audit_syscall_exit'
Cc: Eric Paris <eparis@redhat.com>
If you enable some common audit code, the kernel fails to build.
In file included from lib/audit.c:17:
include/asm-generic/audit_write.h:3: error: '__NR_swapon' undeclared here (not in a function)
make[1]: *** [lib/audit.o] Error 1
make: *** [lib] Error 2
So do not use __NR_swapon if it isnt defined for a port.
Signed-off-by: Mike Frysinger <vapier.adi@gmail.com>
Signed-off-by: Bryan Wu <cooloney@kernel.org>
Currently audit=0 on the kernel command line does absolutely nothing.
Audit always loads and always uses its resources such as creating the
kernel netlink socket. This patch causes audit=0 to actually disable
audit. Audit will use no resources and starting the userspace auditd
daemon will not cause the kernel audit system to activate.
Signed-off-by: Eric Paris <eparis@redhat.com>
Various tags are now way out of date
Signed-off-by: Alan Cox <alan@redhat.com>
Some systems report SIS 5513 as both vendor/id and subvendor/id
string. In that case we can't distinguish the system by the id
svid/sdid and in fact the entry here breaks some boxes. At some
point we need to find another way to detect the Targa Visionary 1000,
until then this trades a hang for some users with lower performance
for others.
Closes: #12092
