2007-08-09ocfs2: check ia_size limits in setattrMark Fasheh
We have to manually check the requested truncate size as the check in vmtruncate() comes too late for Ocfs2. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-08-09ocfs2: Fix some casting errors related to file writesMark Fasheh
ocfs2_align_clusters_to_page_index() needs to cast the clusters shift to pgoff_t and ocfs2_file_buffered_write() needs loff_t when calculating destination start for memcpy. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-08-09ocfs2: use s_maxbytes directly in ocfs2_change_file_space()Mark Fasheh
There's no need to recalculate things via ocfs2_max_file_offset() as we've already done that to fill s_maxbytes, so use that instead. We can also un-export ocfs2_max_file_offset() then. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-08-09ocfs2: Restrict inode changes in ocfs2_update_inode_atime()Mark Fasheh
ocfs2_update_inode_atime() calls ocfs2_mark_inode_dirty() to push changes from the struct inode into the ocfs2 disk inode. The problem is, ocfs2_mark_inode_dirty() might change other fields, depending on what happened to the struct inode. Since we don't always have locking to serialize changes to other fields (like i_size, etc), just fix things up to only touch the atime field. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-08-09remove dubious legal statment from uio-howtoAlan Cox
UIO currently contains a rather dubious statement which wants removing. The actual questions around whether user space code that depends tightly on kernel GPL code designed to co-work with it are derivative works of the kernel is extremely complex, and since we don't have space for either a masters length essay on legal issues or need to start flamewars lets simply remove the comment and leave law to lawyers Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <tovalds@linux-foundation.org>
2007-08-09Fix Alpha O_CLOEXEC definitionRichard Henderson
The default definition in asm-generic conflicts with Alpha's O_DIRECT, so, like several other arches, it needs to be redefined. Signed-off-by: Richard Hendersion <rth@twiddle.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-09Merge git://git.linux-nfs.org/pub/linux/nfs-2.6Linus Torvalds
* git://git.linux-nfs.org/pub/linux/nfs-2.6: SUNRPC: Replace flush_workqueue() with cancel_work_sync() and friends NFS: Replace flush_scheduled_work with cancel_work_sync() and friends SUNRPC: Don't call gss_delete_sec_context() from an rcu context NFSv4: Don't call put_rpccred() from an rcu callback NFS: Fix NFSv4 open stateid regressions NFSv4: Fix a locking regression in nfs4_set_mode_locked() NFS: Fix put_nfs_open_context SUNRPC: Fix a race in rpciod_down()
2007-08-09hexdump: use const notationArtem Bityutskiy
Trivial fix: mark the buffer to hexdump as const so callers could avoid casting their const buffers when calling print_hex_dump(). The patch is really trivial and I suggest to consider it as a fix (it fixes GCC warnings) and push it to current tree. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-09Merge branch 'master' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 * 'master' of master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6: [TCP]: H-TCP maxRTT estimation at startup [NETFILTER]: nf_nat: add symbolic dependency on IPv4 conntrack [NETFILTER]: ctnetlink: return EEXIST instead of EINVAL for existing nat'ed conntracks [NETFILTER]: ipt_recent: avoid a possible NULL pointer deref in recent_seq_open() [NET] net/core/utils: fix sparse warning [NetLabel]: add missing rcu_dereference() calls in the LSM domain mapping hash table [PATCH] mac80211: don't allow scanning in monitor mode [PATCH] mac80211: Fix sparse error for sta_last_seq_ctrl_read [PATCH] mac80211: use do { } while (0) for multi-line macros [PATCH] mac80211: missing dev_put in ieee80211_master_start_xmit
master.kernel.org:/pub/scm/linux/kernel/git/davem/sparc-2.6 * 'master' of master.kernel.org:/pub/scm/linux/kernel/git/davem/sparc-2.6: [SPARC64]: Fix memory leak when cpu hotplugging. [SPARC64]: Do not assume sun4v chips have load-twin/store-init support. [SPARC64]: Fix hard-coding of cpu type output in /proc/cpuinfo on sun4v. [SPARC]: Centralize find_in_proplist() instead of duplicating N times.
2007-08-09Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/drzeus/mmc * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/drzeus/mmc: mmc: at91_mci: remove whitespace at the end of lines mmc: reorganize bounce buffer init wbsd: fix section mismatch warnings
2007-08-09Merge git://git.kernel.org/pub/scm/linux/kernel/git/mingo/linux-2.6-schedLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/mingo/linux-2.6-sched: (61 commits) sched: refine negative nice level granularity sched: fix update_stats_enqueue() reniced codepath sched: round a bit better sched: make the multiplication table more accurate sched: optimize update_rq_clock() calls in the load-balancer sched: optimize activate_task() sched: clean up set_curr_task_fair() sched: remove __update_rq_clock() call from entity_tick() sched: move the __update_rq_clock() call to scheduler_tick() sched debug: remove the 'u64 now' parameter from print_task()/_rq() sched: remove the 'u64 now' local variables sched: remove the 'u64 now' parameter from deactivate_task() sched: remove the 'u64 now' parameter from dequeue_task() sched: remove the 'u64 now' parameter from enqueue_task() sched: remove the 'u64 now' parameter from dec_nr_running() sched: remove the 'u64 now' parameter from inc_nr_running() sched: remove the 'u64 now' parameter from dec_load() sched: remove the 'u64 now' parameter from inc_load() sched: remove the 'u64 now' parameter from update_curr_load() sched: remove the 'u64 now' parameter from ->task_new() ...
2007-08-09lguest: avoid shared libraries mapped over guest memoryRonald G. Minnich
Some versions of ld.so mmap the shared libraries right in over guest memory, so compile lguest statically by default. [ FC7 maps shared libraries very low, where the launcher maps guest's physical memory. Quick fix is to link Launcher static, real fix is for 2.6.24. ] -static is a simple fix. I expect this problem will be more common than we like, as different distro's make different "improvements" to ld.so Signed-off-by: Ronald G. Minnich <rminnich@gmail.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-09lguest: Fix Malicious Guest GDT Host CrashRusty Russell
If a Guest makes hypercall which sets a GDT entry to not present, we currently set any segment registers using that GDT entry to 0. Unfortunately, this is not sufficient: there are other ways of altering GDT entries which will cause a fault. The correct solution to do what Linux does: let them set any GDT value they want and handle the #GP when popping causes a fault. This has the added benefit of making our Switcher slightly more robust in the case of any other bugs which cause it to fault. We kill the Guest if it causes a fault in the Switcher: it's the Guest's responsibility to make sure it's not using segments when it changes them. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-09Fix non-TSC guest clocksource lockupRusty Russell
lguest uses a host-supplied wallclock-based clocksource when the TSC is not reliable. As this is already in nanoseconds, I naively used a multiplier of 1 and a shift of 0. But update_wall_time() in its infinite wisdom decides to adjust the clock a little (where does it think it's getting a more accurate time from?) It will happily tweak the multiplier... to 0, then -1. So the "fix" is to use a shift of 22 like everyone else, and a multiplier of 1 << 22. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-09Revert "genirq: temporary fix for level-triggered IRQ resend"Linus Torvalds
This reverts commit 0fc4969b866671dfe39b1a9119d0fdc7ea0f63e5. It was always meant to be temporary, but it's generating more useless noise than anything else, and we probably should never have done it in the generic kernel (only had the people involved test it on their own). Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-09mmc: at91_mci: remove whitespace at the end of linesNicolas Ferre
Some cleanup with whitespace/tab at the end of lines. Signed-off-by: Nicolas Ferre <nicolas.ferre@rfo.atmel.com> Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2007-08-09mmc: reorganize bounce buffer initPierre Ossman
Reorganize the code that initializes mmc_block's bounce buffer in order to avoid warnings when MMC_BLOCK_BOUNCE isn't used. Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2007-08-09wbsd: fix section mismatch warningsGabriel C
This patch fixes the following section mismatch warnings ... WARNING: vmlinux.o(.init.text+0x29d40): Section mismatch: reference to .exit.text:wbsd_release_resources (between 'wbsd_init' and 'wbsd_probe') WARNING: vmlinux.o(.init.text+0x29d49): Section mismatch: reference to .exit.text:wbsd_free_mmc (between 'wbsd_init' and 'wbsd_probe') WARNING: vmlinux.o(.init.text+0x29f28): Section mismatch: reference to .exit.text:wbsd_free_mmc (between 'wbsd_init' and 'wbsd_probe') ... Signed-off-by: Gabriel Craciunescu <nix.or.die@googlemail.com> Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2007-08-09sched: refine negative nice level granularityIngo Molnar
refine the granularity of negative nice level tasks: let them reschedule more often to offset the effect of them consuming their wait_runtime proportionately slower. (This makes nice-0 task scheduling smoother in the presence of negatively reniced tasks.) Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-08-09sched: fix update_stats_enqueue() reniced codepathIngo Molnar
the key has to be rescaled to /weight even if it has a positive value. (this change only affects the scheduling of reniced tasks) Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-08-09sched: round a bit betterIngo Molnar
round a tiny bit better in high-frequency rescheduling scenarios, by rounding around zero instead of rounding down. (this is pretty theoretical though) Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-08-09sched: make the multiplication table more accurateIngo Molnar
do small deltas in the weight and multiplication constant table so that the worst-case numeric error is better than 1:100000000. (8 digits) the current error table is: nice mult * inv_mult error ------------------------------------------ -20: 88761 * 48388 -0.0000000065 -19: 71755 * 59856 -0.0000000037 -18: 56483 * 76040 0.0000000056 -17: 46273 * 92818 0.0000000042 -16: 36291 * 118348 -0.0000000065 -15: 29154 * 147320 -0.0000000037 -14: 23254 * 184698 -0.0000000009 -13: 18705 * 229616 -0.0000000037 -12: 14949 * 287308 -0.0000000009 -11: 11916 * 360437 -0.0000000009 -10: 9548 * 449829 -0.0000000009 -9: 7620 * 563644 -0.0000000037 -8: 6100 * 704093 0.0000000009 -7: 4904 * 875809 0.0000000093 -6: 3906 * 1099582 -0.0000000009 -5: 3121 * 1376151 -0.0000000058 -4: 2501 * 1717300 0.0000000009 -3: 1991 * 2157191 -0.0000000035 -2: 1586 * 2708050 0.0000000009 -1: 1277 * 3363326 0.0000000014 0: 1024 * 4194304 0.0000000000 1: 820 * 5237765 0.0000000009 2: 655 * 6557202 0.0000000033 3: 526 * 8165337 -0.0000000079 4: 423 * 10153587 0.0000000012 5: 335 * 12820798 0.0000000079 6: 272 * 15790321 0.0000000037 7: 215 * 19976592 -0.0000000037 8: 172 * 24970740 -0.0000000037 9: 137 * 31350126 -0.0000000079 10: 110 * 39045157 -0.0000000061 11: 87 * 49367440 -0.0000000037 12: 70 * 61356676 0.0000000056 13: 56 * 76695844 -0.0000000075 14: 45 * 95443717 -0.0000000072 15: 36 * 119304647 -0.0000000009 16: 29 * 148102320 -0.0000000037 17: 23 * 186737708 -0.0000000028 18: 18 * 238609294 -0.0000000009 19: 15 * 286331153 -0.0000000002 Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-08-09sched: optimize update_rq_clock() calls in the load-balancerIngo Molnar
optimize update_rq_clock() calls in the load-balancer: update them right after locking the runqueue(s) so that the pull functions do not have to call it. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-08-09sched: optimize activate_task()Ingo Molnar
optimize activate_task() by removing update_rq_clock() from it. (and add update_rq_clock() to all callsites of activate_task() that did not have it before.) Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-08-09sched: clean up set_curr_task_fair()Ingo Molnar
clean up set_curr_task_fair(). ( identity transformation that causes no change in functionality. ) text data bss dec hex filename 39170 3750 36 42956 a7cc sched.o.before 39170 3750 36 42956 a7cc sched.o.after Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-08-09sched: remove __update_rq_clock() call from entity_tick()Ingo Molnar
remove __update_rq_clock() call from entity_tick(). no change in functionality because scheduler_tick() already calls __update_rq_clock(). Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-08-09sched: move the __update_rq_clock() call to scheduler_tick()Ingo Molnar
move the __update_rq_clock() call from update_cpu_load() to scheduler_tick(). ( identity transformation that causes no change in functionality. ) this allows the direct use of rq->clock in ->task_tick() functions. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-08-09sched debug: remove the 'u64 now' parameter from print_task()/_rq()Ingo Molnar
remove the 'u64 now' parameter from sched_debug.c:print_task()/_rq(). ( identity transformation that causes no change in functionality. ) Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-08-09sched: remove the 'u64 now' local variablesIngo Molnar
final step: remove all (now superfluous) 'u64 now' variables. ( identity transformation that causes no change in functionality. ) Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-08-09sched: remove the 'u64 now' parameter from deactivate_task()Ingo Molnar
remove the 'u64 now' parameter from deactivate_task(). ( identity transformation that causes no change in functionality. ) Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-08-09sched: remove the 'u64 now' parameter from dequeue_task()Ingo Molnar
remove the 'u64 now' parameter from dequeue_task(). ( identity transformation that causes no change in functionality. ) Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-08-09sched: remove the 'u64 now' parameter from enqueue_task()Ingo Molnar
remove the 'u64 now' parameter from enqueue_task(). ( identity transformation that causes no change in functionality. ) Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-08-09sched: remove the 'u64 now' parameter from dec_nr_running()Ingo Molnar
remove the 'u64 now' parameter from dec_nr_running(). ( identity transformation that causes no change in functionality. ) Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-08-09sched: remove the 'u64 now' parameter from inc_nr_running()Ingo Molnar
remove the 'u64 now' parameter from inc_nr_running(). ( identity transformation that causes no change in functionality. ) Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-08-09sched: remove the 'u64 now' parameter from dec_load()Ingo Molnar
remove the 'u64 now' parameter from dec_load(). ( identity transformation that causes no change in functionality. ) Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-08-09sched: remove the 'u64 now' parameter from inc_load()Ingo Molnar
remove the 'u64 now' parameter from inc_load(). ( identity transformation that causes no change in functionality. ) Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-08-09sched: remove the 'u64 now' parameter from update_curr_load()Ingo Molnar
remove the 'u64 now' parameter from update_curr_load(). ( identity transformation that causes no change in functionality. ) Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-08-09sched: remove the 'u64 now' parameter from ->task_new()Ingo Molnar
remove the 'u64 now' parameter from ->task_new(). ( identity transformation that causes no change in functionality. ) Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-08-09sched: remove the 'u64 now' parameter from ->put_prev_task()Ingo Molnar
remove the 'u64 now' parameter from ->put_prev_task(). ( identity transformation that causes no change in functionality. ) Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-08-09sched: remove the 'u64 now' parameter from pick_next_task()Ingo Molnar
remove the 'u64 now' parameter from pick_next_task(). ( identity transformation that causes no change in functionality. ) Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-08-09sched: remove the 'u64 now' parameter from ->pick_next_task()Ingo Molnar
remove the 'u64 now' parameter from ->pick_next_task(). ( identity transformation that causes no change in functionality. ) Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-08-09sched: remove the 'u64 now' parameter from ->dequeue_task()Ingo Molnar
remove the 'u64 now' parameter from ->dequeue_task(). ( identity transformation that causes no change in functionality. ) Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-08-09sched: remove the 'u64 now' parameter from ->enqueue_task()Ingo Molnar
remove the 'u64 now' parameter from ->enqueue_task(). ( identity transformation that causes no change in functionality. ) Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-08-09sched: remove the 'u64 now' parameter from update_curr_rt()Ingo Molnar
remove the 'u64 now' parameter from update_curr_rt(). ( identity transformation that causes no change in functionality. ) Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-08-09sched: remove the 'u64 now' parameter from put_prev_entity()Ingo Molnar
remove the 'u64 now' parameter from put_prev_entity(). ( identity transformation that causes no change in functionality. ) Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-08-09sched: remove the 'u64 now' parameter from pick_next_entity()Ingo Molnar
remove the 'u64 now' parameter from pick_next_entity(). ( identity transformation that causes no change in functionality. ) Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-08-09sched: remove the 'u64 now' parameter from set_next_entity()Ingo Molnar
remove the 'u64 now' parameter from set_next_entity(). ( identity transformation that causes no change in functionality. ) Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-08-09sched: remove the 'u64 now' parameter from dequeue_entity()Ingo Molnar
remove the 'u64 now' parameter from dequeue_entity(). ( identity transformation that causes no change in functionality. ) Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-08-09sched: remove the 'u64 now' parameter from enqueue_entity()Ingo Molnar
remove the 'u64 now' parameter from enqueue_entity(). ( identity transformation that causes no change in functionality. ) Signed-off-by: Ingo Molnar <mingo@elte.hu>
