Alexey Dobriyan reported trouble with LTP with the new fast-gup code,
and Johannes Weiner debugged it to non-page-aligned addresses, where the
new get_user_pages_fast() code would do all the wrong things, including
just traversing past the end of the requested area due to 'addr' never
matching 'end' exactly.
This is not a pretty fix, and we may actually want to move the alignment
into generic code, leaving just the core code per-arch, but Alexey
verified that the vmsplice01 LTP test doesn't crash with this.
Reported-and-tested-by: Alexey Dobriyan <adobriyan@gmail.com>
Debugged-by: Johannes Weiner <hannes@saeurebad.de>
Cc: Nick Piggin <npiggin@suse.de>
arch/x86/mm/pgtable.c: In function 'pgd_mop_up_pmds':
arch/x86/mm/pgtable.c:194: warning: unused variable 'pmd'
The computed color value is never actually written to hardware
colormap register.
Signed-off-by: Manuel Lauss <mano@roarinelk.homelinux.net>
Cc: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com>
Cc: Munakata Hisao <munakata.hisao@renesas.com>
With SLUB debugging turned on in 2.6.26, I was getting memory corruption
when testing eCryptfs. The root cause turned out to be that eCryptfs was
doing kmalloc(PAGE_CACHE_SIZE); virt_to_page() and treating that as a nice
page-aligned chunk of memory. But at least with SLUB debugging on, this
is not always true, and the page we get from virt_to_page does not
necessarily match the PAGE_CACHE_SIZE worth of memory we got from kmalloc.
My simple testcase was 2 loops doing "rm -f fileX; cp /tmp/fileX ." for 2
different multi-megabyte files. With this change I no longer see the
corruption.
Signed-off-by: Eric Sandeen <sandeen@redhat.com>
Acked-by: Michael Halcrow <mhalcrow@us.ibm.com>
Cc: <stable@kernel.org> [2.6.25.x, 2.6.26.x]
If CONFIG_GENERIC_GPIO=y && CONFIG_GPIO_SYSFS=n, gpio_export() in
asm-generic/gpio.h refers -ENOSYS and causes build error.
Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
Acked-by: David Brownell <dbrownell@users.sourceforge.net>
I got section mismatch message about bio_integrity_init_slab().
WARNING: fs/built-in.o(__ksymtab+0xb60): Section mismatch in reference from the variable __ksymtab_bio_integrity_init_slab to the function .init.text:bio_integrity_init_slab()
The symbol bio_integrity_init_slab is exported and annotated __init Fix
this by removing the __init annotation of bio_integrity_init_slab or drop
the export.
It only call from init_bio(). The EXPORT_SYMBOL() can be removed.
Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp>
Cc: "Martin K. Petersen" <martin.petersen@oracle.com>
Cc: Jens Axboe <jens.axboe@oracle.com>
When we read some part of a file through pagecache, if there is a
pagecache of corresponding index but this page is not uptodate, read IO
is issued and this page will be uptodate.
I think this is good for pagesize == blocksize environment but there is
room for improvement on pagesize != blocksize environment. Because in
this case a page can have multiple buffers and even if a page is not
uptodate, some buffers can be uptodate.
So I suggest that when all buffers which correspond to a part of a file
that we want to read are uptodate, use this pagecache and copy data from
this pagecache to user buffer even if a page is not uptodate. This can
reduce read IO and improve system throughput.
I wrote a benchmark program and got result number with this program.
This benchmark do:
1: mount and open a test file.
2: create a 512MB file.
3: close a file and umount.
4: mount and again open a test file.
5: pwrite randomly 300000 times on a test file. offset is aligned
by IO size(1024bytes).
6: measure time of preading randomly 100000 times on a test file.
The result was:
2.6.26
330 sec
2.6.26-patched
226 sec
Arch:i386
Filesystem:ext3
Blocksize:1024 bytes
Memory: 1GB
On ext3/4, a file is written through buffer/block. So random read/write
mixed workloads or random read after random write workloads are optimized
with this patch under pagesize != blocksize environment. This test result
showed this.
The benchmark program is as follows:
#include <stdio.h>
#include <sys/types.h>
#include <sys/stat.h>
#include <fcntl.h>
#include <unistd.h>
#include <time.h>
#include <stdlib.h>
#include <string.h>
#include <sys/mount.h>
#define LEN 1024
#define LOOP 1024*512 /* 512MB */
main(void)
unsigned long i, offset, filesize;
int fd;
char buf[LEN];
time_t t1, t2;
if (mount("/dev/sda1", "/root/test1/", "ext3", 0, 0) < 0) {
perror("cannot mount\n");
exit(1);
memset(buf, 0, LEN);
fd = open("/root/test1/testfile", O_CREAT|O_RDWR|O_TRUNC);
if (fd < 0) {
perror("cannot open file\n");
exit(1);
for (i = 0; i < LOOP; i++)
write(fd, buf, LEN);
close(fd);
if (umount("/root/test1/") < 0) {
perror("cannot umount\n");
exit(1);
exit(1);
fd = open("/root/test1/testfile", O_RDWR);
if (fd < 0) {
exit(1);
filesize = LEN * LOOP;
for (i = 0; i < 300000; i++){
offset = (random() % filesize) & (~(LEN - 1));
pwrite(fd, buf, LEN, offset);
printf("start test\n");
time(&t1);
for (i = 0; i < 100000; i++){
pread(fd, buf, LEN, offset);
time(&t2);
printf("%ld sec\n", t2-t1);
close(fd);
exit(1);
Signed-off-by: Hisashi Hifumi <hifumi.hisashi@oss.ntt.co.jp>
Cc: Nick Piggin <nickpiggin@yahoo.com.au>
Cc: Jan Kara <jack@ucw.cz>
Cc: <linux-ext4@vger.kernel.org>
kexec-tools
Signed-off-by: Simon Horman <horms@verge.net.au>
Acked-by: Vivek Goyal <vgoyal@redhat.com>
The original "Pass the bus number we expect the S3C24XX SPI driver to
attach to via the platform data." [1] patch was mis-sent, and missed two
important parts of the diff, which was to actually set the bus_num field
and add the relevant field to the platform data.
The previous commit 50f426b55d919dd017af35bb6a08753d1f262920 promised to
add a bus_num field, but failed to include the two hunks that added this
field to include/asm-arm/arch-s3c2410/spi.h and then pass it to the spi
core when creating the new master field in drivers/spi/spi_s3c24xx.c.
[1] git commit 50f426b55d919dd017af35bb6a08753d1f262920
Signed-off-by: Ben Dooks <ben-linux@fluff.org>
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
The block transfer routine in the mpc52xx psc spi driver misinterpret
the datasheet. According to the processor datasheet the chipselect is
held as long as the EOF is not written.
Theoretically blocks of any sizes can be transferred in this way. The
old routine however writes an EOF after every word, which has the size
of size_of_word. This makes the transfer slow.
Also fixed some duplicate code.
Signed-off-by: Luotao Fu <l.fu@pengutronix.de>
This patch fixes the following build error on sh caused by commit
aa888a74977a8f2120ae9332376e179c39a6b07d ("hugetlb: support larger than
MAX_ORDER"):
mm/hugetlb.c: In function 'alloc_bootmem_huge_page':
mm/hugetlb.c:958: error: implicit declaration of function 'virt_to_phys'
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Cc: Hirokazu Takata <takata@linux-m32r.org>
With KVM/GFP/XPMEM there isn't just the primary CPU MMU pointing to pages.
There are secondary MMUs (with secondary sptes and secondary tlbs) too.
sptes in the kvm case are shadow pagetables, but when I say spte in
mmu-notifier context, I mean "secondary pte". In GRU case there's no
actual secondary pte and there's only a secondary tlb because the GRU
secondary MMU has no knowledge about sptes and every secondary tlb miss
event in the MMU always generates a page fault that has to be resolved by
the CPU (this is not the case of KVM where the a secondary tlb miss will
walk sptes in hardware and it will refill the secondary tlb transparently
to software if the corresponding spte is present). The same way
zap_page_range has to invalidate the pte before freeing the page, the spte
(and secondary tlb) must also be invalidated before any page is freed and
reused.
Currently we take a page_count pin on every page mapped by sptes, but that
means the pages can't be swapped whenever they're mapped by any spte
because they're part of the guest working set. Furthermore a spte unmap
event can immediately lead to a page to be freed when the pin is released
(so requiring the same complex and relatively slow tlb_gather smp safe
logic we have in zap_page_range and that can be avoided completely if the
spte unmap event doesn't require an unpin of the page previously mapped in
the secondary MMU).
The mmu notifiers allow kvm/GRU/XPMEM to attach to the tsk->mm and know
when the VM is swapping or freeing or doing anything on the primary MMU so
that the secondary MMU code can drop sptes before the pages are freed,
avoiding all page pinning and allowing 100% reliable swapping of guest
physical address space. Furthermore it avoids the code that teardown the
mappings of the secondary MMU, to implement a logic like tlb_gather in
zap_page_range that would require many IPI to flush other cpu tlbs, for
each fixed number of spte unmapped.
To make an example: if what happens on the primary MMU is a protection
downgrade (from writeable to wrprotect) the secondary MMU mappings will be
invalidated, and the next secondary-mmu-page-fault will call
get_user_pages and trigger a do_wp_page through get_user_pages if it
called get_user_pages with write=1, and it'll re-establishing an updated
spte or secondary-tlb-mapping on the copied page. Or it will setup a
readonly spte or readonly tlb mapping if it's a guest-read, if it calls
get_user_pages with write=0. This is just an example.
This allows to map any page pointed by any pte (and in turn visible in the
primary CPU MMU), into a secondary MMU (be it a pure tlb like GRU, or an
full MMU with both sptes and secondary-tlb like the shadow-pagetable layer
with kvm), or a remote DMA in software like XPMEM (hence needing of
schedule in XPMEM code to send the invalidate to the remote node, while no
need to schedule in kvm/gru as it's an immediate event like invalidating
primary-mmu pte).
At least for KVM without this patch it's impossible to swap guests
reliably. And having this feature and removing the page pin allows
several other optimizations that simplify life considerably.
Dependencies:
1) mm_take_all_locks() to register the mmu notifier when the whole VM
isn't doing anything with "mm". This allows mmu notifier users to keep
track if the VM is in the middle of the invalidate_range_begin/end
critical section with an atomic counter incraese in range_begin and
decreased in range_end. No secondary MMU page fault is allowed to map
any spte or secondary tlb reference, while the VM is in the middle of
range_begin/end as any page returned by get_user_pages in that critical
section could later immediately be freed without any further
->invalidate_page notification (invalidate_range_begin/end works on
ranges and ->invalidate_page isn't called immediately before freeing
the page). To stop all page freeing and pagetable overwrites the
mmap_sem must be taken in write mode and all other anon_vma/i_mmap
locks must be taken too.
2) It'd be a waste to add branches in the VM if nobody could possibly
run KVM/GRU/XPMEM on the kernel, so mmu notifiers will only enabled if
CONFIG_KVM=m/y. In the current kernel kvm won't yet take advantage of
mmu notifiers, but this already allows to compile a KVM external module
against a kernel with mmu notifiers enabled and from the next pull from
kvm.git we'll start using them. And GRU/XPMEM will also be able to
continue the development by enabling KVM=m in their config, until they
submit all GRU/XPMEM GPLv2 code to the mainline kernel. Then they can
also enable MMU_NOTIFIERS in the same way KVM does it (even if KVM=n).
This guarantees nobody selects MMU_NOTIFIER=y if KVM and GRU and XPMEM
are all =n.
The mmu_notifier_register call can fail because mm_take_all_locks may be
interrupted by a signal and return -EINTR. Because mmu_notifier_reigster
is used when a driver startup, a failure can be gracefully handled. Here
an example of the change applied to kvm to register the mmu notifiers.
Usually when a driver startups other allocations are required anyway and
-ENOMEM failure paths exists already.
struct kvm *kvm_arch_create_vm(void)
struct kvm *kvm = kzalloc(sizeof(struct kvm), GFP_KERNEL);
+ int err;
if (!kvm)
return ERR_PTR(-ENOMEM);
INIT_LIST_HEAD(&kvm->arch.active_mmu_pages);
+ kvm->arch.mmu_notifier.ops = &kvm_mmu_notifier_ops;
+ err = mmu_notifier_register(&kvm->arch.mmu_notifier, current->mm);
+ if (err) {
+ kfree(kvm);
+ return ERR_PTR(err);
return kvm;
mmu_notifier_unregister returns void and it's reliable.
The patch also adds a few needed but missing includes that would prevent
kernel to compile after these changes on non-x86 archs (x86 didn't need
them by luck).
[akpm@linux-foundation.org: fix mm/filemap_xip.c build]
[akpm@linux-foundation.org: fix mm/mmu_notifier.c build]
Signed-off-by: Andrea Arcangeli <andrea@qumranet.com>
Signed-off-by: Nick Piggin <npiggin@suse.de>
Signed-off-by: Christoph Lameter <cl@linux-foundation.org>
Cc: Jack Steiner <steiner@sgi.com>
Cc: Robin Holt <holt@sgi.com>
Cc: Kanoj Sarcar <kanojsarcar@yahoo.com>
Cc: Roland Dreier <rdreier@cisco.com>
Cc: Steve Wise <swise@opengridcomputing.com>
Cc: Avi Kivity <avi@qumranet.com>
Cc: Hugh Dickins <hugh@veritas.com>
Cc: Anthony Liguori <aliguori@us.ibm.com>
Cc: Chris Wright <chrisw@redhat.com>
Cc: Marcelo Tosatti <marcelo@kvack.org>
Cc: Eric Dumazet <dada1@cosmosbay.com>
Cc: "Paul E. McKenney" <paulmck@us.ibm.com>
Cc: Izik Eidus <izike@qumranet.com>
mm_take_all_locks holds off reclaim from an entire mm_struct. This allows
mmu notifiers to register into the mm at any time with the guarantee that
no mmu operation is in progress on the mm.
This operation locks against the VM for all pte/vma/mm related operations
that could ever happen on a certain mm. This includes vmtruncate,
try_to_unmap, and all page faults.
The caller must take the mmap_sem in write mode before calling
mm_take_all_locks(). The caller isn't allowed to release the mmap_sem
until mm_drop_all_locks() returns.
mmap_sem in write mode is required in order to block all operations that
could modify pagetables and free pages without need of altering the vma
layout (for example populate_range() with nonlinear vmas). It's also
needed in write mode to avoid new anon_vmas to be associated with existing
vmas.
A single task can't take more than one mm_take_all_locks() in a row or it
would deadlock.
mm_take_all_locks() and mm_drop_all_locks are expensive operations that
may have to take thousand of locks.
mm_take_all_locks() can fail if it's interrupted by signals.
When mmu_notifier_register returns, we must be sure that the driver is
notified if some task is in the middle of a vmtruncate for the 'mm' where
the mmu notifier was registered (mmu_notifier_invalidate_range_start/end
is run around the vmtruncation but mmu_notifier_register can run after
mmu_notifier_invalidate_range_start and before
mmu_notifier_invalidate_range_end). Same problem for rmap paths. And
we've to remove page pinning to avoid replicating the tlb_gather logic
inside KVM (and GRU doesn't work well with page pinning regardless of
needing tlb_gather), so without mm_take_all_locks when vmtruncate frees
the page, kvm would have no way to notice that it mapped into sptes a page
that is going into the freelist without a chance of any further
mmu_notifier notification.
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Introduce list_del_init_rcu() and document it.
This fixes a merge goof whereby ARCH_EP93XX got the "select HAVE_CLK" line
which belongs instead with ARCH_AT91.
Cc: Dave Young <hidave.darkstar@gmail.com>
SuSE's insserve initscript ordering program hits kernel BUG at mm/shmem.c:814
on 2.6.26. It's using posix_fadvise on directories, and the shmem_readpage
method added in 2.6.23 is letting POSIX_FADV_WILLNEED allocate useless pages
to a tmpfs directory, incrementing i_blocks count but never decrementing it.
Fix this by assigning shmem_aops (pointing to readpage and writepage and
set_page_dirty) only when it's needed, on a regular file or a long symlink.
Many thanks to Kel for outstanding bugreport and steps to reproduce it.
Reported-by: Kel Modderman <kel@otaku42.de>
Tested-by: Kel Modderman <kel@otaku42.de>
Signed-off-by: Hugh Dickins <hugh@veritas.com>
Fix compilation errors on avr32 and without CONFIG_SWAP, introduced by
ba92a43dbaee339cf5915ef766d3d3ffbaaf103c ("exec: remove some includes")
In file included from include/asm/tlb.h:24,
from fs/exec.c:55:
include/asm-generic/tlb.h: In function 'tlb_flush_mmu':
include/asm-generic/tlb.h:76: error: implicit declaration of function 'release_pages'
include/asm-generic/tlb.h: In function 'tlb_remove_page':
include/asm-generic/tlb.h:105: error: implicit declaration of function 'page_cache_release'
make[1]: *** [fs/exec.o] Error 1
This straightforward part-revert is nobody's favourite patch to address
the underlying tlb.h needs swap.h needs pagemap.h (but sparc won't like
that) mess; but appropriate to fix the build now before any overhaul.
Reported-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp>
Reported-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
Tested-by: Adrian Bunk <bunk@kernel.org>
* 'cpus4096-v2' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
cpu masks: optimize and clean up cpumask_of_cpu()
cpumask: export cpumask_of_cpu_map
cpumask: change cpumask_of_cpu_ptr to use new cpumask_of_cpu
cpumask: put cpumask_of_cpu_map in the initdata section
cpumask: make cpumask_of_cpu_map generic
There's a brown paper bag compile failure introduced by this patch
commit a01386924874c4d6d67f8a34e66f04452c2abb69
Author: David Sterba <dsterba@suse.cz>
Date: Mon Jul 28 16:53:32 2008 +0200
ipwireless: Preallocate received packet buffers with MRU size
Really, it can't ever have been even compile tested. It looks like the
closing bracket is in the wrong place, so this is the fix.
Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
kernel/stop_machine.c
Clean up and optimize cpumask_of_cpu(), by sharing all the zero words.
Instead of stupidly generating all possible i=0...NR_CPUS 2^i patterns
creating a huge array of constant bitmasks, realize that the zero words
can be shared.
In other words, on a 64-bit architecture, we only ever need 64 of these
arrays - with a different bit set in one single world (with enough zero
words around it so that we can create any bitmask by just offsetting in
that big array). And then we just put enough zeroes around it that we
can point every single cpumask to be one of those things.
So when we have 4k CPU's, instead of having 4k arrays (of 4k bits each,
with one bit set in each array - 2MB memory total), we have exactly 64
arrays instead, each 8k bits in size (64kB total).
And then we just point cpumask(n) to the right position (which we can
calculate dynamically). Once we have the right arrays, getting
"cpumask(n)" ends up being:
static inline const cpumask_t *get_cpu_mask(unsigned int cpu)
const unsigned long *p = cpu_bit_bitmap[1 + cpu % BITS_PER_LONG];
p -= cpu / BITS_PER_LONG;
return (const cpumask_t *)p;
This brings other advantages and simplifications as well:
- we are not wasting memory that is just filled with a single bit in
various different places
- we don't need all those games to re-create the arrays in some dense
format, because they're already going to be dense enough.
if we compile a kernel for up to 4k CPU's, "wasting" that 64kB of memory
is a non-issue (especially since by doing this "overlapping" trick we
probably get better cache behaviour anyway).
[ mingo@elte.hu:
Converted Linus's mails into a commit. See:
http://lkml.org/lkml/2008/7/27/156
http://lkml.org/lkml/2008/7/28/320
Also applied a family filter - which also has the side-effect of leaving
out the bits where Linus calls me an idio... Oh, never mind ;-)
Cc: Al Viro <viro@ZenIV.linux.org.uk>
Cc: Mike Travis <travis@sgi.com>
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input:
Input: add driver for Atmel integrated touchscreen controller
Input: ads7846 - optimize order of calculating Rt in ads7846_rx()
Input: ads7846 - fix sparse endian warnings
Input: uinput - remove duplicate include
Input: serio - offload resume to kseriod
Input: serio - mark serio_register_driver() __must_check
git://git.kernel.org/pub/scm/linux/kernel/git/teigland/dlm
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/teigland/dlm:
dlm: fix uninitialized variable for search_rsb_list callers
dlm: release socket on error
dlm: fix basts for granted CW waiting PR/CW
dlm: check for null in device_write
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc
* 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (25 commits)
powerpc: Disable 64K hugetlb support when doing 64K SPU mappings
powerpc/powermac: Fixup default serial port device for pmac_zilog
powerpc/powermac: Use sane default baudrate for SCC debugging
powerpc/mm: Implement _PAGE_SPECIAL & pte_special() for 64-bit
powerpc: Show processor cache information in sysfs
powerpc: Make core id information available to userspace
powerpc: Make core sibling information available to userspace
powerpc/vio: More fallout from dma_mapping_error API change
ibmveth: Fix multiple errors with dma_mapping_error conversion
powerpc/pseries: Fix CMO sysdev attribute API change fallout
powerpc: Enable tracehook for the architecture
powerpc: Add TIF_NOTIFY_RESUME support for tracehook
powerpc: Add asm/syscall.h with the tracehook entry points
powerpc: Make syscall tracing use tracehook.h helpers
powerpc: Call tracehook_signal_handler() when setting up signal frames
powerpc: Update cpu_sibling_maps dynamically
powerpc: register_cpu_online should be __cpuinit
powerpc: kill useless SMT code in prom_hold_cpus
powerpc: Fix 8xx build failure
powerpc: Fix vio build warnings
* git://git.kernel.org/pub/scm/linux/kernel/git/kkeil/ISDN-2.6:
Remove deprecated virt_to_bus()
* git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6: (72 commits)
sh: SuperH Mobile CEU and camera platform data for AP325RXA
sh: Update smc911x platform data for AP325RXA
sh: SuperH Mobile LCDC platform data for AP325RXA
sh: Add SuperH Mobile CEU platform data for Migo-R
sh: Add SuperH Mobile LCDC platform data for Migo-R
sh: Move asid_cache() out of ifdef to fix SH-3/4 nommu build.
sh: Workaround for __put_user_asm() bug with gcc 4.x on big-endian.
sh: Wire up new syscalls.
sh: fix uImage Entry Point
sh_keysc: remove request_mem_region() and release_mem_region()
sh: Don't miss pending signals returning to user mode after signal processing
sh: Use clk_always_enable() on sh7366
sh: Use clk_always_enable() on sh7343 / SE77343
sh: Use clk_always_enable() on sh7722 / Migo-R / SE7722
sh: Use clk_always_enable() on sh7723 / ap325rxa
sh: Introduce clk_always_enable() function
sh: Show all clocks and their state in /proc/clocks
sh: Merge sh7343 and sh7722 clock code
sh: Add SuperH Mobile MSTPCR bits to clock framework
sh: Use arch_flags to simplify sh7722 siu clock code
* git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus:
stop_machine: fix up ftrace.c
stop_machine: Wean existing callers off stop_machine_run()
stop_machine(): stop_machine_run() changed to use cpu mask
Hotplug CPU: don't check cpu_online after take_cpu_down
Simplify stop_machine
stop_machine: add ALL_CPUS option
module: fix build warning with !CONFIG_KALLSYMS
* git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/v4l-dvb: (98 commits)
V4L/DVB (8549): mxl5007: Fix an error at include file
V4L/DVB (8548): pwc: Fix compilation
V4L/DVB (8546): add tuner-3036 and dpc7146 drivers to feature-removal-schedule.txt
V4L/DVB (8546): saa7146: fix read from uninitialized memory
V4L/DVB (8544): gspca: probe/open race.
V4L/DVB (8543): em28xx: Rename #define for Compro VideoMate ForYou/Stereo
V4L/DVB (8542): em28xx: AMD ATI TV Wonder HD 600 entry at cards struct is duplicated
V4L/DVB (8541): em28xx: HVR-950 entry is duplicated.
V4L/DVB (8540): em28xx-cards: Add Compro VideoMate ForYou/Stereo model
V4L/DVB (8539): em28xx-cards: New supported IDs for analog models
V4L/DVB (8538): em28xx-cards: Add GrabBeeX+ USB2800 model
V4L/DVB (8534): remove select's of FW_LOADER
V4L/DVB (8522): videodev2: Fix merge conflict
V4L/DVB (8532): mxl5007t: remove excessive locks
V4L/DVB (8531): mxl5007t: move i2c gate handling outside of mutex protected code blocks
V4L/DVB (8530): au0828: add support for new revision of HVR950Q
V4L/DVB (8529): mxl5007t: enable _init and _sleep power management functionality
V4L/DVB (8528): add support for MaxLinear MxL5007T silicon tuner
V4L/DVB (8526): saa7146: fix VIDIOC_ENUM_FMT
V4L/DVB (8525): fix a few assorted spelling mistakes.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6:
sparc: Set CONFIG_HAVE_ARCH_TRACEHOOK
sparc: Add task_pt_regs().
sparc: Add call to tracehook_signal_handler().
sparc: Create and use TIF_NOTIFY_RESUME.
sparc: Use tracehook routines in syscall_trace().
sparc64: tracehook: CONFIG_HAVE_ARCH_TRACEHOOK
sparc: Add user_stack_pointer().
sparc64: tracehook_signal_handler
sparc64: tracehook: TIF_NOTIFY_RESUME
sparc: Add asm/syscall.h
sparc64: tracehook syscall
sparc: enable headers_export again
sparc, sparc64: use arch/sparc/include
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6:
net: missing bits of net-namespace / sysctl
ipcomp: Fix warnings after ipcomp consolidation.
dccp: Add check for truncated ICMPv6 DCCP error packets
dccp: Fix incorrect length check for ICMPv4 packets
dccp: Add check for sequence number in ICMPv6 message
dccp: Fix sequence number check for ICMPv4 packets
dccp: Bug-Fix - AWL was never updated
dccp: Allow to distinguish original and retransmitted packets
Add git pull command info and diffstat summary info so that we don't
have to search email archives for it repeatedly.
Noticed because of this warning:
drivers/base/memory.c:279: warning: initialization from incompatible pointer type
pm_idle_save resp. pm_idle_old can be NULL when the restore code in
acpi_processor_cst_has_changed() resp. cpuidle_uninstall_idle_handler()
is called. This can set pm_idle unconditinally to NULL, which causes the
kernel to panic when calling pm_idle in the x86 idle code. This was
covered by an extra check for !pm_idle in the x86 idle code, which was
removed during the x86 idle code refactoring.
Instead of restoring the pm_idle check in the x86 code prevent the
acpi/cpuidle code to set pm_idle to NULL.
Reported by: Dhaval Giani http://lkml.org/lkml/2008/7/2/309
Based on a debug patch from Ingo Molnar
* 'i2c-for-linus' of git://aeryn.fluff.org.uk/bjdooks/linux:
i2c: Blackfin I2C Driver: Functional power management support
i2c: Documentation: upgrading clients HOWTO
i2c: S3C24XX I2C frequency scaling support.
i2c: i2c_gpio: keep probe resident for hotplugged devices.
i2c: S3C2410: Pass the I2C bus number via drivers platform data
Packets are assembled from link size (~300 bytes) up to PPP MRU
(1500 by default). Try to preallocate full size rather than
repeatedly advance buffer size by 256 bytes.
Signed-off-by: David Sterba <dsterba@suse.cz>
ipwireless: Put packets to pool start
Put packets to pool start, try to reuse cached memory.
ipwireless: Increase PPP outgoing queue size
Increase default size of PPP outgoing queue. Currently set to 1, which
means that a packet quickly following another pushed by PPP must wait
until hardware actually sends the previous and PPP has to be waken up
by ppp_wakeup(). This slows down upstream.
Now PPP can push more packets at once which get buffered inside driver
and pushed immediatelly to hardware when previous packet is out.
Experiments show that size = 10 is quite good for all connection types
(GPRS/EDGE/UMTS) and gains 4 KB/sec of upload for UMTS for batch uploads.
Need for higher queue size than 10 occures in only < 0.1 % of cases.
ipwireless: Explicitly request io and mem regions
Documentation/pcmcia/driver-changes.txt says, that driver should call request_region
for used memory/io regions since PCMCIA does not do this (since 2.6.8).
ipwireless: Constify buffer variables
ipwireless: Do not return value from sending funcs
Do not return value from do_send_fragment and do_send_packet, it's not used.
The packet size checks are not useful too:
* zero length packet will never be sent, caller always passes packet_header
size which is either 1 or 3
* MTU check is done in caller, no need to repeat
ipwireless: Remove endian-dependent bitfields
Remove endian-dependent bitfields and use bitmasks to transform
packet header bitfields from/to machine order.
ipwireless: Glue splitted printk strings back
ipwireless: Remove pt_regs from interrupt handler
ipwireless: Rename spinlock variables to lock
ipwireless: Remove unused defines
Remove unused defines, defines hiding variables, defines hiding 0.
ipwireless: Misc cleanups
- remove likely() and some extra () in ifs
- use unsigned in for loops
- remove useless typecasts
- remove obvious comments
- add () around ?:
PM_SUSPEND_MEM: Blackfin does not maintain register state through
Hibernate. Save and restore peripheral base initialization during
PM transitions.
Signed-off-by: Michael Hennerich <michael.hennerich@analog.com>
Signed-off-by: Bryan Wu <cooloney@kernel.org>
Add a document describing how i2c clients on Linux 2.6 can be
moved from the old to the new driver model.
