Change d_hash so it may be called from lock-free RCU lookups. See similar
patch for d_compare for details.
For in-tree filesystems, this is just a mechanical change.
Signed-off-by: Nick Piggin <npiggin@kernel.dk>
Change d_compare so it may be called from lock-free RCU lookups. This
does put significant restrictions on what may be done from the callback,
however there don't seem to have been any problems with in-tree fses.
If some strange use case pops up that _really_ cannot cope with the
rcu-walk rules, we can just add new rcu-unaware callbacks, which would
cause name lookup to drop out of rcu-walk mode.
smpfs and ncpfs want to update a live dentry name in-place. Rather than
have them open code the locking, provide a documented dcache API.
Use vfat's method for dealing with negative dentries to preserve case,
rather than overwrite dentry name in d_revalidate, which is a bit ugly
and also gets in the way of doing lock-free path walking.
Change d_delete from a dentry deletion notification to a dentry caching
advise, more like ->drop_inode. Require it to be constant and idempotent,
and not take d_lock. This is how all existing filesystems use the callback
anyway.
This makes fine grained dentry locking of dput and dentry lru scanning
much simpler.
Remove redundant (and incorrect, since dcache RCU lookup) dentry locking
documentation and point to the canonical document.
Switching d_op on a live dentry is racy in general, so avoid it. In this case
it is a negative dentry, which is safer, but there are still concurrent ops
which may be called on d_op in that case (eg. d_revalidate). So in general
a filesystem may not do this. Fix configfs so as not to do this.
a filesystem may not do this. Fix cgroupfs so as not to do this.
percpu_counter library generates quite nasty code, so unless you need
to dynamically allocate counters or take fast approximate value, a
simple per cpu set of counters is much better.
The percpu_counter can never be made to work as well, because it has an
indirection from pointer to percpu memory, and it can't use direct
this_cpu_inc interfaces because it doesn't use static PER_CPU data, so
code will always be worse.
In the fastpath, it is the difference between this:
incl %gs:nr_dentry # nr_dentry
and this:
movl percpu_counter_batch(%rip), %edx # percpu_counter_batch,
movl $1, %esi #,
movq $nr_dentry, %rdi #,
call __percpu_counter_add # (plus I clobber registers)
__percpu_counter_add:
pushq %rbp #
movq %rsp, %rbp #,
subq $32, %rsp #,
movq %rbx, -24(%rbp) #,
movq %r12, -16(%rbp) #,
movq %r13, -8(%rbp) #,
movq %rdi, %rbx # fbc, fbc
#APP
# 216 "/home/npiggin/usr/src/linux-2.6/arch/x86/include/asm/thread_info.h" 1
movq %gs:kernel_stack,%rax #, pfo_ret__
# 0 "" 2
#NO_APP
incl -8124(%rax) # <variable>.preempt_count
movq 32(%rdi), %r12 # <variable>.counters, tcp_ptr__
#APP
# 78 "lib/percpu_counter.c" 1
add %gs:this_cpu_off, %r12 # this_cpu_off, tcp_ptr__
# 0 "" 2
#NO_APP
movslq (%r12),%r13 #* tcp_ptr__, tmp73
movslq %edx,%rax # batch, batch
addq %rsi, %r13 # amount, count
cmpq %rax, %r13 # batch, count
jge .L27 #,
negl %edx # tmp76
movslq %edx,%rdx # tmp76, tmp77
cmpq %rdx, %r13 # tmp77, count
jg .L28 #,
.L27:
movq %rbx, %rdi # fbc,
call _raw_spin_lock #
addq %r13, 8(%rbx) # count, <variable>.count
movl $0, (%r12) #,* tcp_ptr__
call _raw_spin_unlock #
.L29:
#APP
# 0 "" 2
#NO_APP
decl -8124(%rax) # <variable>.preempt_count
movq -8136(%rax), %rax #, D.14625
testb $8, %al #, D.14625
jne .L32 #,
.L31:
movq -24(%rbp), %rbx #,
movq -16(%rbp), %r12 #,
movq -8(%rbp), %r13 #,
leave
ret
.p2align 4,,10
.p2align 3
.L28:
movl %r13d, (%r12) # count,*
jmp .L29 #
.L32:
call preempt_schedule #
.p2align 4,,6
jmp .L31 #
.size __percpu_counter_add, .-__percpu_counter_add
.p2align 4,,15
The nr_unused counters count the number of objects on an LRU, and as such they
are synchronized with LRU object insertion and removal and scanning, and
protected under the LRU lock.
Making it per-cpu does not actually get any concurrency improvements because of
this lock, and summing the counter is much slower, and
incrementing/decrementing it costs more code size and is slower too.
These counters should stay per-LRU, which currently means global.
This is a nasty and error prone API. It is no longer used, remove it.
d_validate has been broken for a long time.
kmem_ptr_validate does not guarantee that a pointer can be dereferenced
if it can go away at any time. Even rcu_read_lock doesn't help, because
the pointer might be queued in RCU callbacks but not executed yet.
So the parent cannot be checked, nor the name hashed. The dentry pointer
can not be touched until it can be verified under lock. Hashing simply
cannot be used.
Instead, verify the parent/child relationship by traversing parent's
d_child list. It's slow, but only ncpfs and the destaged smbfs care
about it, at this point.
This reverts commit 3825bdb7ed920845961f32f364454bee5f469abb.
You cannot dget() a dentry without having a reference, or holding
a lock that guarantees it remains valid.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6:
ipv4/route.c: respect prefsrc for local routes
bridge: stp: ensure mac header is set
bridge: fix br_multicast_ipv6_rcv for paged skbs
atl1: fix oops when changing tx/rx ring params
drivers/atm/atmtcp.c: add missing atm_dev_put
starfire: Fix dma_addr_t size test for MIPS
tg3: fix return value check in tg3_read_vpd()
Broadcom CNIC core network driver: fix mem leak on allocation failures in cnic_alloc_uio_rings()
ISDN, Gigaset: Fix memory leak in do_disconnect_req()
CAN: Use inode instead of kernel address for /proc file
skfp: testing the wrong variable in skfp_driver_init()
ppp: allow disabling multilink protocol ID compression
ehea: Avoid changing vlan flags
ueagle-atm: fix PHY signal initialization race
The preferred source address is currently ignored for local routes,
which results in all local connections having a src address that is the
same as the local dst address. Fix this by respecting the preferred source
address when it is provided for local routes.
This bug can be demonstrated as follows:
# ifconfig dummy0 192.168.0.1
# ip route show table local | grep local.*dummy0
local 192.168.0.1 dev dummy0 proto kernel scope host src 192.168.0.1
# ip route change table local local 192.168.0.1 dev dummy0 \
proto kernel scope host src 127.0.0.1
local 192.168.0.1 dev dummy0 proto kernel scope host src 127.0.0.1
We now establish a local connection and verify the source IP
address selection:
# nc -l 192.168.0.1 3128 &
# nc 192.168.0.1 3128 &
# netstat -ant | grep 192.168.0.1:3128.*EST
tcp 0 0 192.168.0.1:3128 192.168.0.1:33228 ESTABLISHED
tcp 0 0 192.168.0.1:33228 192.168.0.1:3128 ESTABLISHED
Signed-off-by: Joel Sing <jsing@google.com>
The ->trim_fs has been removed meanwhile, so remove it from the documentation
as well.
Reported-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
* master.kernel.org:/home/rmk/linux-2.6-arm:
ARM: pxa: fix page table corruption on resume
ARM: it8152: add IT8152_LAST_IRQ definition to fix build error
ARM: pxa: PXA_ESERIES depends on FB_W100.
ARM: 6605/1: Add missing include "asm/memory.h"
ARM: 6540/1: Stop irqsoff trace on return to user
ARM: 6537/1: update Nomadik, U300 and Ux500 maintainers
ARM: 6536/1: Add missing SZ_{32,64,128}
ARM: fix cache-feroceon-l2 after stack based kmap_atomic()
ARM: fix cache-xsc3l2 after stack based kmap_atomic()
ARM: get rid of kmap_high_l1_vipt()
ARM: smp: avoid incrementing mm_users on CPU startup
Addresses https://bugzilla.kernel.org/show_bug.cgi?id=25702
Reported-by: Martin Ettl <ettl.martin@gmx.de>
If security_filter_rule_init() doesn't return a rule, then not everything
is as fine as the return code implies.
This bug only occurs when the LSM (eg. SELinux) is disabled at runtime.
Adding an empty LSM rule causes ima_match_rules() to always succeed,
ignoring any remaining rules.
default IMA TCB policy:
# PROC_SUPER_MAGIC
dont_measure fsmagic=0x9fa0
# SYSFS_MAGIC
dont_measure fsmagic=0x62656572
# DEBUGFS_MAGIC
dont_measure fsmagic=0x64626720
# TMPFS_MAGIC
dont_measure fsmagic=0x01021994
# SECURITYFS_MAGIC
dont_measure fsmagic=0x73636673
< LSM specific rule >
dont_measure obj_type=var_log_t
measure func=BPRM_CHECK
measure func=FILE_MMAP mask=MAY_EXEC
measure func=FILE_CHECK mask=MAY_READ uid=0
Thus without the patch, with the boot parameters 'tcb selinux=0', adding
the above 'dont_measure obj_type=var_log_t' rule to the default IMA TCB
measurement policy, would result in nothing being measured. The patch
prevents the default TCB policy from being replaced.
Signed-off-by: Mimi Zohar <zohar@us.ibm.com>
Acked-by: Serge Hallyn <serge.hallyn@canonical.com>
Cc: David Safford <safford@watson.ibm.com>
Cc: <stable@kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/ycmiao/pxa-linux-2.6
commit bf9ae5386bca8836c16e69ab8fdbe46767d7452a
(llc: use dev_hard_header) removed the
skb_reset_mac_header call from llc_mac_hdr_init.
This seems fine itself, but br_send_bpdu() invokes ebtables LOCAL_OUT.
We oops in ebt_basic_match() because it assumes eth_hdr(skb) returns
a meaningful result.
Cc: acme@ghostprotocols.net
References: https://bugzilla.kernel.org/show_bug.cgi?id=24532
* 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
perf: Fix callchain hit bad cast on ascii display
arch/x86/oprofile/op_model_amd.c: Perform initialisation on a single CPU
watchdog: Improve initialisation error message and documentation
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6
* 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6:
[media] em28xx: radio_fops should also use unlocked_ioctl
[media] wm8775: Revert changeset fcb9757333 to avoid a regression
[media] cx25840: Prevent device probe failure due to volume control ERANGE error
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx
* 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx:
dmaengine: provide dummy functions for DMA_ENGINE=n
mv_xor: fix race in tasklet function
The function can't be __init itself (being called from some sysfs
handler), and hence none of the functions it calls can be either.
Signed-off-by: Jan Beulich <jbeulich@novell.com>
use pskb_may_pull to access ipv6 header correctly for paged skbs
It was omitted in the bridge code leading to crash in blind
__skb_pull
since the skb is cloned undonditionally we also simplify the
the exit path
this fixes bug https://bugzilla.kernel.org/show_bug.cgi?id=25202
Dec 15 14:36:40 User-PC hostapd: wlan0: STA 00:15:00:60:5d:34 IEEE 802.11: authenticated
Dec 15 14:36:40 User-PC hostapd: wlan0: STA 00:15:00:60:5d:34 IEEE 802.11: associated (aid 2)
Dec 15 14:36:40 User-PC hostapd: wlan0: STA 00:15:00:60:5d:34 RADIUS: starting accounting session 4D0608A3-00000005
Dec 15 14:36:41 User-PC kernel: [175576.120287] ------------[ cut here ]------------
Dec 15 14:36:41 User-PC kernel: [175576.120452] kernel BUG at include/linux/skbuff.h:1178!
Dec 15 14:36:41 User-PC kernel: [175576.120609] invalid opcode: 0000 [#1] SMP
Dec 15 14:36:41 User-PC kernel: [175576.120749] last sysfs file: /sys/devices/pci0000:00/0000:00:1f.2/host0/target0:0:0/0:0:0:0/block/sda/uevent
Dec 15 14:36:41 User-PC kernel: [175576.121035] Modules linked in: approvals binfmt_misc bridge stp llc parport_pc ppdev arc4 iwlagn snd_hda_codec_realtek iwlcore i915 snd_hda_intel mac80211 joydev snd_hda_codec snd_hwdep snd_pcm snd_seq_midi drm_kms_helper snd_rawmidi drm snd_seq_midi_event snd_seq snd_timer snd_seq_device cfg80211 eeepc_wmi usbhid psmouse intel_agp i2c_algo_bit intel_gtt uvcvideo agpgart videodev sparse_keymap snd shpchp v4l1_compat lp hid video serio_raw soundcore output snd_page_alloc ahci libahci atl1c
Dec 15 14:36:41 User-PC kernel: [175576.122712]
Dec 15 14:36:41 User-PC kernel: [175576.122769] Pid: 0, comm: kworker/0:0 Tainted: G W 2.6.37-rc5-wl+ #3 1015PE/1016P
Dec 15 14:36:41 User-PC kernel: [175576.123012] EIP: 0060:[<f83edd65>] EFLAGS: 00010283 CPU: 1
Dec 15 14:36:41 User-PC kernel: [175576.123193] EIP is at br_multicast_rcv+0xc95/0xe1c [bridge]
Dec 15 14:36:41 User-PC kernel: [175576.123362] EAX: 0000001c EBX: f5626318 ECX: 00000000 EDX: 00000000
Dec 15 14:36:41 User-PC kernel: [175576.123550] ESI: ec512262 EDI: f5626180 EBP: f60b5ca0 ESP: f60b5bd8
Dec 15 14:36:41 User-PC kernel: [175576.123737] DS: 007b ES: 007b FS: 00d8 GS: 00e0 SS: 0068
Dec 15 14:36:41 User-PC kernel: [175576.123902] Process kworker/0:0 (pid: 0, ti=f60b4000 task=f60a8000 task.ti=f60b0000)
Dec 15 14:36:41 User-PC kernel: [175576.124137] Stack:
Dec 15 14:36:41 User-PC kernel: [175576.124181] ec556500 f6d06800 f60b5be8 c01087d8 ec512262 00000030 00000024 f5626180
Dec 15 14:36:41 User-PC kernel: [175576.124181] f572c200 ef463440 f5626300 3affffff f6d06dd0 e60766a4 000000c4 f6d06860
Dec 15 14:36:41 User-PC kernel: [175576.124181] ffffffff ec55652c 00000001 f6d06844 f60b5c64 c0138264 c016e451 c013e47d
Dec 15 14:36:41 User-PC kernel: [175576.124181] Call Trace:
Dec 15 14:36:41 User-PC kernel: [175576.124181] [<c01087d8>] ? sched_clock+0x8/0x10
Dec 15 14:36:41 User-PC kernel: [175576.124181] [<c0138264>] ? enqueue_entity+0x174/0x440
Dec 15 14:36:41 User-PC kernel: [175576.124181] [<c016e451>] ? sched_clock_cpu+0x131/0x190
Dec 15 14:36:41 User-PC kernel: [175576.124181] [<c013e47d>] ? select_task_rq_fair+0x2ad/0x730
Dec 15 14:36:41 User-PC kernel: [175576.124181] [<c0524fc1>] ? nf_iterate+0x71/0x90
Dec 15 14:36:41 User-PC kernel: [175576.124181] [<f83e4914>] ? br_handle_frame_finish+0x184/0x220 [bridge]
Dec 15 14:36:41 User-PC kernel: [175576.124181] [<f83e4790>] ? br_handle_frame_finish+0x0/0x220 [bridge]
Dec 15 14:36:41 User-PC kernel: [175576.124181] [<f83e46e9>] ? br_handle_frame+0x189/0x230 [bridge]
Dec 15 14:36:41 User-PC kernel: [175576.124181] [<f83e4560>] ? br_handle_frame+0x0/0x230 [bridge]
Dec 15 14:36:41 User-PC kernel: [175576.124181] [<c04ff026>] ? __netif_receive_skb+0x1b6/0x5b0
Dec 15 14:36:41 User-PC kernel: [175576.124181] [<c04f7a30>] ? skb_copy_bits+0x110/0x210
Dec 15 14:36:41 User-PC kernel: [175576.124181] [<c0503a7f>] ? netif_receive_skb+0x6f/0x80
Dec 15 14:36:41 User-PC kernel: [175576.124181] [<f82cb74c>] ? ieee80211_deliver_skb+0x8c/0x1a0 [mac80211]
Dec 15 14:36:41 User-PC kernel: [175576.124181] [<f82cc836>] ? ieee80211_rx_handlers+0xeb6/0x1aa0 [mac80211]
Dec 15 14:36:41 User-PC kernel: [175576.124181] [<c04ff1f0>] ? __netif_receive_skb+0x380/0x5b0
Dec 15 14:36:41 User-PC kernel: [175576.124181] [<c016e242>] ? sched_clock_local+0xb2/0x190
Dec 15 14:36:41 User-PC kernel: [175576.124181] [<c012b688>] ? default_spin_lock_flags+0x8/0x10
Dec 15 14:36:41 User-PC kernel: [175576.124181] [<c05d83df>] ? _raw_spin_lock_irqsave+0x2f/0x50
Dec 15 14:36:41 User-PC kernel: [175576.124181] [<f82cd621>] ? ieee80211_prepare_and_rx_handle+0x201/0xa90 [mac80211]
Dec 15 14:36:41 User-PC kernel: [175576.124181] [<f82ce154>] ? ieee80211_rx+0x2a4/0x830 [mac80211]
Dec 15 14:36:41 User-PC kernel: [175576.124181] [<f815a8d6>] ? iwl_update_stats+0xa6/0x2a0 [iwlcore]
Dec 15 14:36:41 User-PC kernel: [175576.124181] [<f8499212>] ? iwlagn_rx_reply_rx+0x292/0x3b0 [iwlagn]
Dec 15 14:36:41 User-PC kernel: [175576.124181] [<f8483697>] ? iwl_rx_handle+0xe7/0x350 [iwlagn]
Dec 15 14:36:41 User-PC kernel: [175576.124181] [<f8486ab7>] ? iwl_irq_tasklet+0xf7/0x5c0 [iwlagn]
Dec 15 14:36:41 User-PC kernel: [175576.124181] [<c01aece1>] ? __rcu_process_callbacks+0x201/0x2d0
Dec 15 14:36:41 User-PC kernel: [175576.124181] [<c0150d05>] ? tasklet_action+0xc5/0x100
Dec 15 14:36:41 User-PC kernel: [175576.124181] [<c0150a07>] ? __do_softirq+0x97/0x1d0
Dec 15 14:36:41 User-PC kernel: [175576.124181] [<c05d910c>] ? nmi_stack_correct+0x2f/0x34
Dec 15 14:36:41 User-PC kernel: [175576.124181] [<c0150970>] ? __do_softirq+0x0/0x1d0
Dec 15 14:36:41 User-PC kernel: [175576.124181] <IRQ>
Dec 15 14:36:41 User-PC kernel: [175576.124181] [<c01508f5>] ? irq_exit+0x65/0x70
Dec 15 14:36:41 User-PC kernel: [175576.124181] [<c05df062>] ? do_IRQ+0x52/0xc0
Dec 15 14:36:41 User-PC kernel: [175576.124181] [<c01036b0>] ? common_interrupt+0x30/0x38
Dec 15 14:36:41 User-PC kernel: [175576.124181] [<c03a1fc2>] ? intel_idle+0xc2/0x160
Dec 15 14:36:41 User-PC kernel: [175576.124181] [<c04daebb>] ? cpuidle_idle_call+0x6b/0x100
Dec 15 14:36:41 User-PC kernel: [175576.124181] [<c0101dea>] ? cpu_idle+0x8a/0xf0
Dec 15 14:36:41 User-PC kernel: [175576.124181] [<c05d2702>] ? start_secondary+0x1e8/0x1ee
Cc: Johannes Berg <johannes@sipsolutions.net>
Cc: Stephen Hemminger <shemminger@vyatta.com>
Signed-off-by: Tomas Winkler <tomas.winkler@intel.com>
Commit 3f5a2a713aad28480d86b0add00c68484b54febc zeroes out the statistics
message block (SMB) and coalescing message block (CMB) when adapter ring
resources are freed. This is desirable behavior, but, as a side effect,
the commit leads to an oops when atl1_set_ringparam() attempts to alter
the number of rx or tx elements in the ring buffer (by using ethtool
-G, for example). We don't want SMB or CMB to change during this
operation.
Modify atl1_set_ringparam() to preserve SMB and CMB when changing ring
parameters.
Cc: stable@kernel.org
Signed-off-by: Jay Cliburn <jcliburn@gmail.com>
Reported-by: Tõnu Raitviir <jussuf@linux.ee>
git://git.kernel.org/pub/scm/linux/kernel/git/frederic/random-tracing into perf/urgent
Before this patch, the following error would sometimes occur after a
resume on pxa3xx:
/path/to/mm/memory.c:144: bad pmd 8040542e.
The problem was that a temporary page table mapping was being improperly
restored.
The PXA3xx resume code creates a temporary mapping of resume_turn_on_mmu
to avoid a prefetch abort. The pxa3xx_resume_after_mmu code requires
that the r1 register holding the address of this mapping not be
modified, however, resume_turn_on_mmu does modify it. It is mostly
correct in that r1 receives the base table address, but it may also
get other bits in 13:0. This results in pxa3xx_resume_after_mmu
restoring the original mapping to the wrong place, corrupting memory
and leaving the temporary mapping in place.
Signed-off-by: Matt Reimer <mreimer@sdgsystems.com>
Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
The commit 6ac6b817f3f4c23c5febd960d8deb343e13af5f3 (ARM: pxa: encode
IRQ number into .nr_irqs) removed definition of ITE_LAST_IRQ which
caused the following build error:
CC arch/arm/common/it8152.o
arch/arm/common/it8152.c: In function 'it8152_init_irq':
arch/arm/common/it8152.c:86: error: 'IT8152_LAST_IRQ' undeclared (first use in this function)
arch/arm/common/it8152.c:86: error: (Each undeclared identifier is reported only once
arch/arm/common/it8152.c:86: error: for each function it appears in.)
make[2]: *** [arch/arm/common/it8152.o] Error 1
Defining the IT8152_LAST_IRQ in the arch/arm/include/hardware/it8152.c
fixes the build.
Signed-off-by: Mike Rapoport <mike@compulab.co.il>
As arch/arm/mach-pxa/eseries.c references w100fb_gpio_{read,write}()
directly.
Signed-off-by: Lennert Buytenhek <buytenh@secretlab.ca>
ipchain__fprintf_graph() casts the number of hits in a branch as an
int, which means we lose its highests bits.
This results in meaningless number of callchain hits in perf.data
that have a high number of hits recorded, typically those that have
callchain branches hits appearing more than INT_MAX. This happens
easily as those are pondered by the event period.
Reported-by: Nick Piggin <npiggin@kernel.dk>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Disable preemption in init_ibs(). The function only checks the
ibs capabilities and sets up pci devices (if necessary). It runs
only on one cpu but operates with the local APIC and some MSRs,
thus it is better to disable preemption.
[ 7.034377] BUG: using smp_processor_id() in preemptible [00000000] code: modprobe/483
[ 7.034385] caller is setup_APIC_eilvt+0x155/0x180
[ 7.034389] Pid: 483, comm: modprobe Not tainted 2.6.37-rc1-20101110+ #1
[ 7.034392] Call Trace:
[ 7.034400] [<ffffffff812a2b72>] debug_smp_processor_id+0xd2/0xf0
[ 7.034404] [<ffffffff8101e985>] setup_APIC_eilvt+0x155/0x180
Addresses https://bugzilla.kernel.org/show_bug.cgi?id=22812
Reported-by: <atswartz@gmail.com>
Signed-off-by: Robert Richter <robert.richter@amd.com>
Cc: oprofile-list@lists.sourceforge.net <oprofile-list@lists.sourceforge.net>
Cc: Rafael J. Wysocki <rjw@sisk.pl>
Cc: Dan Carpenter <error27@gmail.com>
Cc: <stable@kernel.org> [2.6.37.x]
LKML-Reference: <20110103111514.GM4739@erda.amd.com>
[ small cleanups ]
em28xx uses core assisted locking, so it shouldn't use .ioctl.
The .ioctl callback was replaced by .unlocked_ioctl for video nodes,
but not for radio nodes. This is now corrected.
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl>
It seems that cx88 and ivtv use wm8775 on some different modes. The
patch that added support for a board with wm8775 broke ivtv boards with
this device. As we're too close to release 2.6.37, let's just revert
it.
Reported-by: Andy Walls <awalls@md.metrocast.net>
Reported-by: Eric Sharkey <eric@lisaneric.org>
Reported-by: Auric <auric@aanet.com.au>
Reported by: David Gesswein <djg@pdp8online.com>
This patch fixes a regression that crept into 2.6.36.
The volume control scale in the cx25840 driver has an unusual mapping
from register values to v4l2 volume control values. Enforce the mapping
limits, so that the default volume control setting does not fall out of
bounds to prevent the cx25840 module device probe from failing.
Signed-off-by: Andy Walls <awalls@md.metrocast.net>
Cc: Hans Verkuil <hverkuil@xs4all.nl>
This lets drivers, optionally using the dmaengine, build with DMA_ENGINE
unselected.
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
use mv_xor_slot_cleanup() instead of __mv_xor_slot_cleanup() as the former function
aquires the spin lock that needed to protect the drivers data.
Signed-off-by: Saeed Bishara <saeed@marvell.com>
This patch fixes below build error by adding the missing asm/memory.h,
which is needed for arch_is_coherent().
$ make pxa3xx_defconfig; make
CC init/do_mounts_rd.o
In file included from include/linux/list_bl.h:5,
from include/linux/rculist_bl.h:7,
from include/linux/dcache.h:7,
from include/linux/fs.h:381,
from init/do_mounts_rd.c:3:
include/linux/bit_spinlock.h: In function 'bit_spin_unlock':
include/linux/bit_spinlock.h:61: error: implicit declaration of function 'arch_is_coherent'
make[1]: *** [init/do_mounts_rd.o] Error 1
make: *** [init] Error 2
Acked-by: Peter Huewe <peterhuewe@gmx.de>
The error message 'NMI watchdog failed to create perf event...'
does not make it clear that this is a fatal error for the
watchdog. It also currently prints the error value as a
pointer, rather than extracting the error code with PTR_ERR().
Fix that.
Add a note to the description of the 'nowatchdog' kernel
parameter to associate it with this message.
Reported-by: Cesare Leonardi <celeonar@gmail.com>
Cc: 599368@bugs.debian.org
Cc: 608138@bugs.debian.org
Cc: Don Zickus <dzickus@redhat.com>
Cc: <stable@kernel.org> # .37.x and later
LKML-Reference: <1294009362.3167.126.camel@localhost>
The owner field was removed from struct attribute in
6fd69dc578fa0b1bbc3aad70ae3af9a137211707, so don't assign it anymore.
Signed-off-by: Maurus Cuelenaere <mcuelenaere@gmail.com>
Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
* 'kvm-updates/2.6.37' of git://git.kernel.org/pub/scm/virt/kvm/kvm:
KVM: i8259: initialize isr_ack
KVM: MMU: Fix incorrect direct gfn for unpaged mode shadow
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6:
ALSA: hda: Use LPIB quirk for Dell Inspiron m101z/1120
sound: Prevent buffer overflow in OSS load_mixer_volumes
ASoC: codecs: wm8753: Fix register cache incoherency
ASoC: codecs: wm9090: Fix register cache incoherency
ASoC: codecs: wm8962: Fix register cache incoherency
ASoC: codecs: wm8955: Fix register cache incoherency
ASoC: codecs: wm8904: Fix register cache incoherency
ASoC: codecs: wm8741: Fix register cache incoherency
ASoC: codecs: wm8523: Fix register cache incoherency
ASoC: codecs: max98088: Fix register cache incoherency
ASoC: codecs: Add missing control_type initialization
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6
* 'rc-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6:
kconfig: fix undesirable side effect of adding "visible" menu attribute
isr_ack is never initialized. So, until the first PIC reset, interrupts
may fail to be injected. This can cause Windows XP to fail to boot, as
reported in the fallout from the fix to
https://bugzilla.kernel.org/show_bug.cgi?id=21962.
Reported-and-tested-by: Nicolas Prochazka <prochazka.nicolas@gmail.com>
Signed-off-by: Avi Kivity <avi@redhat.com>
The earlier call to atm_dev_lookup increases the reference count of dev,
so decrease it on the way out.
The semantic match that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
expression x, E;
constant C;
x = atm_dev_lookup(...);
... when != false x != NULL
when != true x == NULL
when != \(E = x\|x = E\)
when != atm_dev_put(dev);
*return -C;
// </smpl>
Commit 56543af "starfire: use BUILD_BUG_ON for netdrv_addr_t" revealed
that the preprocessor condition used to find the size of dma_addr_t
yielded the wrong result for some architectures and configurations.
This was kluged for 64-bit PowerPC in commit 3e502e6 by adding yet
another case to the condition. However, 64-bit MIPS configurations
are not detected reliably either.
This should be fixed by using CONFIG_ARCH_DMA_ADDR_T_64BIT, but that
isn't yet defined everywhere it should be.
