This is V2 of the platform driver power management late/early
callback removal patch. The callbacks ->suspend_late() and
->resume_early() are removed since all in-tree users now have
been migrated to dev_pm_ops.
Signed-off-by: Magnus Damm <damm@igel.co.jp>
Acked-by: Pavel Machek <pavel@ucw.cz>
This patch reworks platform driver power management code
for musb from legacy callbacks to dev_pm_ops.
The callbacks are converted for CONFIG_SUSPEND like this:
suspend() -> suspend()
resume_early() -> resume_noirq()
This is V2 of the i2c-s3c2410 dev_pm_ops patch.
suspend_late() -> suspend_noirq()
resume() -> resume()
for i2c-pxa from legacy late/early callbacks to dev_pm_ops.
for txx9dmac from legacy late/early callbacks to dev_pm_ops.
for dw_dmac from legacy late/early callbacks to dev_pm_ops.
for omap drivers using late/early legacy callbacks.
Allow architecture specific data in struct platform_device V3.
With this patch struct pdev_archdata is added to struct
platform_device, similar to struct dev_archdata in found in
struct device. Useful for architecture code that needs to
keep extra data associated with each platform device.
Struct pdev_archdata is different from dev.platform_data, the
convention is that dev.platform_data points to driver-specific
data. It may or may not be required by the driver. The format
of this depends on driver but is the same across architectures.
The structure pdev_archdata is a place for architecture specific
data. This data is handled by architecture specific code (for
example runtime PM), and since it is architecture specific it
should _never_ be touched by device driver code. Exactly like
struct dev_archdata but for platform devices.
[rjw: This change is for power management mostly and that's why it
goes through the suspend tree.]
Acked-by: Kevin Hilman <khilman@deeprootsystems.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-fixes:
vmlinux.lds.h: restructure BSS linker script macros
kconfig: initialize the screen before using curses(3) functions
kconfig: variable argument lists needs `stdarg.h'
kbuild, deb-pkg: fix install scripts for posix sh
git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs:
9p: Fix incorrect parameters to v9fs_file_readn.
9p: Possible regression in p9_client_stat
9p: default 9p transport module fix
* git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6:
cifs: free nativeFileSystem field before allocating a new one
[CIFS] Distinguish posix opens and mkdirs from legacy mkdirs in stats
git://git.kernel.org/pub/scm/linux/kernel/git/vapier/blackfin
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/vapier/blackfin: (21 commits)
Blackfin: define HARDIRQ_BITS again for now
arch/blackfin: Add kmalloc NULL tests
Blackfin: add CPLB entries for Core B on-chip L1 SRAM regions
Blackfin: work around anomaly 05000189
Blackfin: drop per-cpu loops_per_jiffy tracking
Blackfin: fix bugs in GPIO resume code
Blackfin: bf537-stamp: fix irq decl for AD7142
Blackfin: fix handling of IPEND in interrupt context save
Blackfin: drop duplicate runtime checking of anomaly 05000448
Blackfin: fix incomplete renaming of the bfin-twi-lcd driver
Blackfin: fix wrong CTS inversion
Blackfin: update handling of anomaly 364 (wrong rev id in BF527-0.1)
Blackfin: fix early_dma_memcpy() handling of busy channels
Blackfin: handle BF561 Core B memory regions better when SMP=n
Blackfin: fix miscompilation in lshrdi3
Blackfin: fix silent crash when no uClinux MTD filesystem exists
Blackfin: restore exception banner when dumping crash info
Blackfin: work around anomaly 05000281
Blackfin: update anomaly lists to match latest sheets/usage
Blackfin: drop dead flash_probe call
Standard data flow for MMC/SD/SDIO cards requires that the mvsdio
controller be set for big endian operation. This is causing problems
with buffers which length is not a multiple of 4 bytes as the last
partial word doesn't get shifted all the way and stored properly in
memory. Let's compensate for this.
Signed-off-by: Nicolas Pitre <nico@marvell.com>
CC: stable@kernel.org
The Blackfin serial headers were inverting the CTS value leading to wrong
handling of the CTS line which broke CTS/RTS handling completely.
Signed-off-by: Sonic Zhang <sonic.zhang@analog.com>
Signed-off-by: Alan Cox <alan@linux.intel.com>
This function does not have an error return and returning an error is
instead interpreted as having a lot of pending bytes.
Reported by Jeff Harris who provided a list of some of the remaining
offenders.
If spin_lock_irqsave is called twice in a row with the same second
argument, the interrupt state at the point of the second call overwrites
the value saved by the first call. Indeed, the second call does not
need to save the interrupt state, so it is changed to a simple
spin_lock.
The semantic match that finds this problem is as follows:
(http://www.emn.fr/x-info/coccinelle/)
// <smpl>
expression lock1,lock2;
expression flags;
*spin_lock_irqsave(lock1,flags)
... when != flags
*spin_lock_irqsave(lock2,flags)
// </smpl>
The buffer for the consoles are unconditionally allocated at con_init()
time, which miss the creation of the vcs(a) devices.
Since 2.6.30 (commit 4995f8ef9d3aac72745e12419d7fbaa8d01b1d81, 'vcs:
hook sysfs devices into object lifetime instead of "binding"' to be
exact) these devices are no longer created at open() and removed on
close(), but controlled by the lifetime of the buffers.
Reported-by: Gerardo Exequiel Pozzi <vmlinuz386@yahoo.com.ar>
Tested-by: Gerardo Exequiel Pozzi <vmlinuz386@yahoo.com.ar>
Cc: stable@kernel.org
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
...otherwise, we'll leak this memory if we have to reconnect (e.g. after
network failure).
Signed-off-by: Jeff Layton <jlayton@redhat.com>
CC: Stable <stable@kernel.org>
Signed-off-by: Steve French <sfrench@us.ibm.com>
* master.kernel.org:/home/rmk/linux-2.6-arm:
ARM: Realview & Versatile: Fix i2c_board_info definitions
[ARM] 5608/1: Updated U300 defconfig
[ARM] 5606/1: Fix ep93xx watchdog driver headers
[ARM] 5594/1: Correct U300 VIC init PM setting
[ARM] 5595/1: ep93xx: missing header in dma-m2p.c
[ARM] Kirkwood: Correct header define
[ARM] pxa: fix ULPI_{DIR,NXT,STP} MFP defines
backlight: fix pwm_bl.c to notify platform code when suspending
[ARM] pxa: use kzalloc() in pxa_init_gpio_chip()
[ARM] pxa: correct I2CPWR clock for pxa3xx
pxamci: correct DMA flow control
ARM: add support for the EET board, based on the i.MX31 pcm037 module
pcm037: add MT9T031 camera support
Armadillo 500 add NAND flash device support (resend).
ARM MXC: Armadillo 500 add NOR flash device support (resend).
mx31: remove duplicated #include
Fix i2c_board_info definitions - we were defining the 'type' field
of these structures twice since the first argument of I2C_BOARD_INFO
sets this field. Move the second definition into I2C_BOARD_INFO().
Acked-by: Jean Delvare <khali@linux-fr.org>
Acked-by: Ben Dooks <ben-linux@fluff.org>
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6
* 'drm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6:
drm: Move a dereference below a NULL test
fb/intelfb: conflict with DRM_I915 and hide by default
drm/ttm: fix misplaced parentheses
drm/via: Fix vblank IRQ on VIA hardware.
drm: drm_gem, check kzalloc retval
drm: drm_debugfs, check kmalloc retval
drm/radeon: add some missing pci ids
The BSS section macros in vmlinux.lds.h currently place the .sbss
input section outside the bounds of [__bss_start, __bss_end]. On all
architectures except for microblaze that handle both .sbss and
__bss_start/__bss_end, this is wrong: the .sbss input section is
within the range [__bss_start, __bss_end]. Relatedly, the example
code at the top of the file actually has __bss_start/__bss_end defined
twice; I believe the right fix here is to define them in the
BSS_SECTION macro but not in the BSS macro.
Another problem with the current macros is that several
architectures have an ALIGN(4) or some other small number just before
__bss_stop in their linker scripts. The BSS_SECTION macro currently
hardcodes this to 4; while it should really be an argument. It also
ignores its sbss_align argument; fix that.
mn10300 is the only user at present of any of the macros touched by
this patch. It looks like mn10300 actually was incorrectly converted
to use the new BSS() macro (the alignment of 4 prior to conversion was
a __bss_stop alignment, but the argument to the BSS macro is a start
alignment). So fix this as well.
I'd like acks from Sam and David on this one. Also CCing Paul, since
he has a patch from me which will need to be updated to use
BSS_SECTION(0, PAGE_SIZE, 4) once this gets merged.
Signed-off-by: Tim Abbott <tabbott@ksplice.com>
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
This is needed on non ncurses based implementation to get a properly
initialized `stdscr' in main().
Cc: Roman Zippel <zippel@linux-m68k.org>
Fix build on non GNU based platforms.
bash versus dash and posh disagree on expanding $@ within double quotes:
export x="$@"
see http://bugs.debian.org/381091 for details
just use the arglist with $*.
dpkg: error processing linux-image-2.6.31-rc1_2.6.31-rc1-18_i386.deb (--install):
subprocess pre-installation script returned error exit status 2
export: 6: 2.6.31-rc1-18: bad variable name
fixes http://bugzilla.kernel.org/show_bug.cgi?id=13567
seen on Ubuntu as there dash is the default sh,
versus bash on Debian.
Reported-by: Pauli <suokkos@gmail.com>
Cc: Frans Pop <elendil@planet.nl>
Signed-off-by: maximilian attems <max@stro.at>
Acked-By: Andres Salomon <dilinger@collabora.co.uk>
git://git.kernel.org/pub/scm/linux/kernel/git/fyu/linux-2.6
* 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/fyu/linux-2.6:
Revert "Neither asm/types.h nor linux/types.h is required for arch/ia64/include/asm/fpu.h"
Add dma_debug_init() for ia64
Fix ia64 compilation IS_ERR and PTE_ERR errors.
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6:
x86/pci: insert ioapic resource before assigning unassigned resources
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6:
ALSA: riptide - proper handling of pci_register_driver for joystick
sound: usb-audio: add workaround for Blue Microphones devices
ALSA: hda_intel: more strict alc880_parse_auto_config dig_nid checking
ASoC: Fix NULL pointer dereference in __pxa2xx_pcm_hw_free
* git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus:
virtio_net: Sync header with qemu
virtio-pci: correctly unregister root device on error
virtio_blk: ioctl return value fix
virtio_blk: don't bounce highmem requests
lguest: restrict CPUID to avoid perf counter wrmsr
lguest: remove unnecessary forward struct declaration
lguest: fix journey
* 'tracing-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
tracing/function: Fix the return value of ftrace_trace_onoff_callback()
Whoops.. fortunately not many people use this yet.
asm/fpu.h uses the __IA64_UL macro which is declared in asm/types.h, so
this include is really required. Without it, GNU libc fails to build.
This reverts commit 2678c07b07ac2076675e5d57653bdf02e9af1950.
Signed-off-by: Aurelien Jarno <aurelien@aurel32.net>
Acked-by: Fenghua Yu <fenghua.yu@intel.com>
The commit 9916219579d078c80377dd3988c2cc213536d868 was supposed to
add CONFIG_DMA_API_DEBUG support to IA64 however I forgot to add
dma_debug_init().
Signed-off-by: fujita <fujita@tulip.osrg.net>
When building ia64 kernel with CONFIG_XEN_SYS_HYPERVISOR, compiler reports
errors:
drivers/xen/sys-hypervisor.c: In function ‘uuid_show’:
drivers/xen/sys-hypervisor.c:125: error: implicit declaration of function ‘IS_ERR’
drivers/xen/sys-hypervisor.c:126: error: implicit declaration of function ‘PTR_ERR’
This patch fixes the errors.
Signed-off-by: Fenghua Yu <fenghua.yu@intel.com>
Acked-by: Isaku Yamahata <yamahata@valinux.co.jp>
Removed the LBD support that isn't of any use right now at least,
then remove remnants of the TCM config flags that somehow crept
in by mistake (not yet merged patch for 2.6.32) and then the usual
defconfig noise from updated menus.
Signed-off-by: Linus Walleij <linus.walleij@stericsson.com>
Fix a number of build errors in the ep93xx watchdog driver due
to missing io.h
Signed-off-by: Ryan Mallon <ryan@bluewatersys.com>
Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com>
Qemu added support for a few extra RX modes that Linux doesn't
currently make use of. Sync the headers to maintain consistency.
Signed-off-by: Alex Williamson <alex.williamson@hp.com>
If pci_register_driver() fails we're incorrectly unregistering the root
device with device_unregister() rather than root_device_unregister().
Reported-by: Don Zickus <dzickus@redhat.com>
Signed-off-by: Mark McLoughlin <markmc@redhat.com>
Block driver ioctl methods must return ENOTTY and not -ENOIOCTLCMD if
they expect the block layer to handle generic ioctls.
This triggered a BLKROSET failure in xfsqa #200.
By default a block driver bounces highmem requests, but virtio-blk is
perfectly fine with any request that fit into it's 64 bit addressing scheme,
mapped in the kernel virtual space or not.
Besides improving performance on highmem systems this also makes the
reproducible oops in __bounce_end_io go away (but hiding the real cause).
Avoid the following:
[ 0.012093] WARNING: at arch/x86/kernel/apic/apic.c:249 native_apic_write_dummy+0x2f/0x40()
Rather than chase each new cpuid-detected feature, just lie about the highest
valid CPUID so this code is never run.
While fixing lg.h to drop the fwd declaration, I noticed
there's another one ;)
fix: "make Guest" was complaining about duplicated G:032
Signed-off-by: Matias Zabaljauregui <zabaljauregui@gmail.com>
ftrace_trace_onoff_callback() will return an error even if we do the
right operation, for example:
# echo _spin_*:traceon:10 > set_ftrace_filter
-bash: echo: write error: Invalid argument
# cat set_ftrace_filter
#### all functions enabled ####
_spin_trylock_bh:traceon:count=10
_spin_unlock_irq:traceon:count=10
_spin_unlock_bh:traceon:count=10
_spin_lock_irq:traceon:count=10
_spin_unlock:traceon:count=10
_spin_trylock:traceon:count=10
_spin_unlock_irqrestore:traceon:count=10
_spin_lock_irqsave:traceon:count=10
_spin_lock_bh:traceon:count=10
_spin_lock:traceon:count=10
We want to set _spin_*:traceon:10 to set_ftrace_filter, it complains
with "Invalid argument", but the operation is successful.
This is because ftrace_process_regex() returns the number of functions that
matched the pattern. If the number is not 0, this value is returned
by ftrace_regex_write() whereas we want to return the number of bytes
virtually written.
Also the file offset pointer is not updated in this case.
If the number of matched functions is lower than the number of bytes written
by the user, this results to a reprocessing of the string given by the user with
a lower size, leading to a malformed ftrace regex and then a -EINVAL returned.
So, this patch fixes it by returning 0 if no error occured.
The fix also applies on 2.6.30
Signed-off-by: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com>
Reviewed-by: Li Zefan <lizf@cn.fujitsu.com>
The default values of HARDIRQ_BITS and PREEMPT_BITS in common code leads to
build failure:
In file included from include/linux/interrupt.h:12,
from include/linux/kernel_stat.h:8,
from arch/blackfin/kernel/asm-offsets.c:32:
include/linux/hardirq.h:66:2: error: #error PREEMPT_ACTIVE is too low!
So until that gets resolved, just declare our own default value again.
git://git.kernel.org/pub/scm/linux/kernel/git/peterz/linux-2.6-sched
* 'sched-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/peterz/linux-2.6-sched:
sched: Fix bug in SCHED_IDLE interaction with group scheduling
sched: Fix rt_rq->pushable_tasks initialization in init_rt_rq()
sched: Reset sched stats on fork()
sched_rt: Fix overload bug on rt group scheduling
sched: Documentation/sched-rt-group: Fix style issues & bump version
* 'timers-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
timer stats: fix quick check optimization
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc
* 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc:
powerpc: Fix another bug in move of altivec code to vector.S
powerpc: Fix booke user_disable_single_step()
If a tty in N_TTY mode with echo enabled manages to get itself into a state
where
- echo characters are pending
- FASYNC is enabled
- tty_write_wakeup is called from either
- a device write path (pty)
- an IRQ (serial)
then it either deadlocks or explodes taking a mutex in the IRQ path.
On the serial side it is almost impossible to reproduce because you have to
go from a full serial port to a near empty one with echo characters
pending. The pty case happens to have become possible to trigger using
emacs and ptys, the pty changes having created a scenario which shows up
this bug.
The code path is
n_tty:process_echoes() (takes mutex)
tty_io:tty_put_char()
pty:pty_write (or serial paths)
tty_wakeup (from pty_write or serial IRQ)
n_tty_write_wakeup()
process_echoes()
*KABOOM*
