2009-03-20PCI: Introduce /sys/bus/pci/rescanAlex Chiang
This interface allows the user to force a rescan of all PCI buses in system, and rediscover devices that have been removed earlier. pci_bus_attrs implementation from Trent Piepho. Thanks to Vegard Nossum for discovering locking issues with the sysfs interface. Cc: Trent Piepho <xyzzy@speakeasy.org> Signed-off-by: Alex Chiang <achiang@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-03-20PCI: Introduce pci_rescan_bus()Alex Chiang
This API is used by the PCI core to rescan a bus and rediscover newly added devices. Over time, it is expected that the various PCI hotplug drivers will migrate to this interface and away from the old pci_do_scan_bus() interface. Signed-off-by: Alex Chiang <achiang@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-03-20PCI: do not enable bridges more than onceAlex Chiang
In preparation for PCI core hotplug, we need to ensure that we do not attempt to re-enable bridges that have already been enabled. Reported-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Alex Chiang <achiang@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-03-20PCI: do not initialize bridges more than onceAlex Chiang
In preparation for PCI core hotplug, we need to ensure that we do not attempt to re-initialize bridges that have already been initialized. We only need to worry about non-root buses, since we will not allow root bus removal. Reported-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Alex Chiang <achiang@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-03-20PCI: always scan child busesAlex Chiang
While scanning bridges, we stop our scan if we encounter a bus that we've seen before, to work around some buggy chipsets. This is a good idea, but prevents us from fully scanning the PCI bus at a future time (to find newly hot-added devices, for example). Change the logic so that we skip _re-adding_ an existing bus that we've seen before, but also allow the scan to descend to all child buses. Now that we're potentially scanning our child buses again, we also need to be sure not to attempt re-initializing their BARs so we avoid that. This patch lays the groundwork to allow the user to issue a rescan of the PCI bus at any time. Signed-off-by: Alex Chiang <achiang@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-03-20PCI: pci_scan_slot() returns newly found devicesTrent Piepho
pci_scan_slot() has been rewritten to be less complex and will now return the number of *new* devices found. Existing callers need not worry because they already assume that they can't call pci_scan_slot() on an already-scanned slot. Thus, there is no semantic change for existing callers: returning newly found devices (this patch) is exactly equal to returning all found devices (before this patch). This patch adds some more groundwork to allow us to rescan the PCI bus during runtime to discover newly added devices. Signed-off-by: Trent Piepho <xyzzy@speakeasy.org> Reviewed-by: Alex Chiang <achiang@hp.com> Signed-off-by: Alex Chiang <achiang@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-03-20PCI: don't scan existing devicesTrent Piepho
pci_scan_single_device is supposed to add newly discovered devices to pci_bus->devices, but doesn't check to see if the device has already been added. This can cause problems if we ever want to use this interface to rescan the PCI bus. If the device is already added, just return it. Signed-off-by: Trent Piepho <xyzzy@speakeasy.org> Signed-off-by: Alex Chiang <achiang@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-03-20PCI: pci_is_root_bus helperKenji Kaneshige
Introduce pci_is_root_bus helper function. This will help make code more consistent, as well as prevent incorrect assumptions (such as pci_bus->self == NULL on a root bus, which is not always true). Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Alex Chiang <achiang@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-03-20x86/PCI: host mmconfig detect clean upYinghai Lu
Fix mmconfig detection to not assume a single mmconfig space in the northbridge, paving the way for AMD fam10h + mcp55 CPUs. On those, the MSR has some range, but the mcp55 pci config will have another one. Also helps the mcp55 + io55 case, where every one will have one range. If it is mcp55, exclude the range that is used by CPU MSR, in other words , if the CPU claims busses 0-255, the range in mcp55 is dropped, because CPU HW will not route those ranges to mcp55 mmconfig to handle it. Signed-off-by: Yinghai Lu <yinghai.lu@kernel.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-03-20PCI MSI: Add example request loop to MSI-HOWTO.txtMichael Ellerman
Encourage driver writers to think about supporting a variable number of MSI-X interrupts, and give an example of how to do such a request. Acked-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-03-20x86/PCI: Detect mmconfig on nVidia MCP55Ed Swierk
Detect and enable memory-mapped PCI configuration space on the nVidia MCP55 southbridge. Tested against 2.6.27.4 on an Arista Networks development board with one MCP55, Coreboot firmware, no ACPI. Signed-off-by: Ed Swierk <eswierk@aristanetworks.com> Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-03-20PCI: manual for SR-IOV user and driver developerYu Zhao
Reviewed-by: Randy Dunlap <rdunlap@xenotime.net> Reviewed-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Yu Zhao <yu.zhao@intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-03-20PCI: document SR-IOV sysfs entriesYu Zhao
2009-03-20PCI: handle SR-IOV Virtual Function MigrationYu Zhao
Add or remove a Virtual Function after receiving a Migrate In or Out Request. Reviewed-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Yu Zhao <yu.zhao@intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-03-20PCI: add SR-IOV API for Physical Function driverYu Zhao
Add or remove the Virtual Function when the SR-IOV is enabled or disabled by the device driver. This can happen anytime rather than only at the device probe stage. Reviewed-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Yu Zhao <yu.zhao@intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-03-20PCI: centralize device setup codeYu Zhao
Move the device setup stuff into pci_setup_device() which will be used to setup the Virtual Function later. Reviewed-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Yu Zhao <yu.zhao@intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-03-20PCI: reserve bus range for SR-IOV deviceYu Zhao
Reserve the bus number range used by the Virtual Function when pcibios_assign_all_busses() returns true. Reviewed-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Yu Zhao <yu.zhao@intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-03-20PCI: restore saved SR-IOV stateYu Zhao
Restore the volatile registers in the SR-IOV capability after the D3->D0 transition. Reviewed-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Yu Zhao <yu.zhao@intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-03-20PCI: initialize and release SR-IOV capabilityYu Zhao
If a device has the SR-IOV capability, initialize it (set the ARI Capable Hierarchy in the lowest numbered PF if necessary; calculate the System Page Size for the VF MMIO, probe the VF Offset, Stride and BARs). A lock for the VF bus allocation is also initialized if a PF is the lowest numbered PF. Reviewed-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Yu Zhao <yu.zhao@intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-03-20PCI: Compaq Evo D510 SMBus quirk using USB instead of VGADavid O'Shea
On the Compaq Evo D510 SFF/CMT, a PCI quirk activated the SMBus device based on detection of the on-board VGA controller, but the on-board VGA is disabled if an AGP card is inserted, so look for one of the USB controllers instead. Signed-off-by: David O'Shea <dcoshea@hotmail.com> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-03-20PCI: expose boot VGA device via sysfs.Dave Airlie
X really would like to know which VGA device was considered the boot device by the system. The x86 PCI fixups have support for discovering this but we provide no way to expose it to userspace. This adds a sysfs file per VGA class device which has the value 0 for non the boot device or unknown, and 1 if the VGA device is the boot device. Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-03-20PCI/x86: detect host bridge config space size w/o using quirksYinghai Lu
Many host bridges support a 4k config space, so check them directy instead of using quirks to add them. We only need to do this extra check for host bridges at this point, because only host bridges are known to have extended address space without also having a PCI-X/PCI-E caps. Other devices with this property could be done with quirks (if there are any). As a bonus, we can remove the quirks for AMD host bridges with family 10h and 11h since they're not needed any more. With this patch, we can get correct pci cfg size of new Intel CPUs/IOHs with host bridges. Signed-off-by: Yinghai Lu <yinghai@kernel.org> Acked-by: H. Peter Anvin <hpa@zytor.com> Reviewed-by: Matthew Wilcox <willy@linux.intel.com> Cc: <stable@kernel.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-03-20PCIe: portdrv: call pci_disable_device during removeAlex Chiang
The PCIe port driver calls pci_enable_device when registering ports, but never calls pci_disable_device during removal. Acked-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Alex Chiang <achiang@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-03-20PCI: PCIe portdrv: eliminate double kfree in remove pathAlex Chiang
Commit 55633af3 (PCIe portdrv: Use driver data to simplify code) added a kfree of the driver private data in pcie_port_device_remove but forgot to remove the old kfree from pcie_portdrv_remove. Acked-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Alex Chiang <achiang@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-03-20PCI: Use kzalloc() in pci_create_bus()Geert Uytterhoeven
Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-03-20PCI: allow assignment of memory resources with a specified alignmentYuji Shimada
This patch allows memory resources to be assigned with a specified alignment at boot-time or run-time. The patch is useful when we use PCI pass-through, because page-aligned memory resources are required to securely share PCI resources with guest drivers. If you want to assign the resource at boot time, please set "pci=resource_alignment=" boot parameter. This is format of "pci=resource_alignment=" boot parameter: [<order of align>@][<domain>:]<bus>:<slot>.<func>[; ...] Specifies alignment and device to reassign aligned memory resources. If <order of align> is not specified, PAGE_SIZE is used as alignment. PCI-PCI bridge can be specified, if resource windows need to be expanded. This is example: pci=resource_alignment=20@07:00.0;18@0f:00.0;00:1d.7 If you want to assign the resource at run-time, please set "/sys/bus/pci/resource_alignment" file, and hot-remove the device and hot-add the device. For this purpose, fakephp or PCI hotplug interfaces can be used. The format of "/sys/bus/pci/resource_alignment" file is the same with boot parameter. You can use "," instead of ";". For example: # cd /sys/bus/pci # echo -n 20@12:00.0 > resource_alignment # echo 1 > devices/0000:12:00.0/remove # echo 1 > rescan Reviewed-by: Alex Chiang <achiang@hp.com> Reviewed-by: Yu Zhao <yu.zhao@intel.com> Signed-off-by: Yuji Shimada <shimada-yxb@necst.nec.co.jp> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-03-20PCI MSI: Add support for multiple MSIMatthew Wilcox
Add the new API pci_enable_msi_block() to allow drivers to request multiple MSI and reimplement pci_enable_msi in terms of pci_enable_msi_block. Ensure that the architecture back ends don't have to know about multiple MSI. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-03-20PCI MSI: Refactor interrupt masking codeMatthew Wilcox
Since most of the callers already know whether they have an MSI or an MSI-X capability, split msi_set_mask_bits() into msi_mask_irq() and msix_mask_irq(). The only callers which don't (mask_msi_irq() and unmask_msi_irq()) can share code in msi_set_mask_bit(). This then becomes the only caller of msix_flush_writes(), so we can inline it. The flushing read can be to any address that belongs to the device, so we can eliminate the calculation too. We can also get rid of maskbits_mask from struct msi_desc and simply recalculate it on the rare occasion that we need it. The single-bit 'masked' element is replaced by a copy of the 32-bit 'masked' register, so this patch does not affect the size of msi_desc. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-03-20PCI MSI: Use mask_pos instead of mask_base when appropriateMatthew Wilcox
MSI interrupts have a mask_pos where MSI-X have a mask_base. Use a transparent union to get rid of some ugly casts. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-03-20PCI MSI: msi_desc->dev is always initialisedMatthew Wilcox
By passing the pci_dev into alloc_msi_entry() we can be sure that the ->dev entry is always assigned and so we don't need to check it. Also, we used kzalloc() so we don't need to initialise ->irq to 0. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-03-20PCI MSI: Replace 'type' with 'is_msix'Matthew Wilcox
By changing from a 5-bit field to a 1-bit field, we free up some bits that can be used by a later patch. Also rearrange the fields for better packing on 64-bit platforms (reducing the size of msi_desc from 72 bytes to 64 bytes). Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-03-20Rewrite MSI-HOWTOMatthew Wilcox
I didn't find the previous version very useful, so I rewrote it. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Reviewed-by: Randy Dunlap <randy.dunlap@oracle.com> Reviewed-by: Grant Grundler <grundler@parisc-linunx.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-03-20PCI: add remove_id sysfs entryChris Wright
This adds a remove_id sysfs entry to allow users of new_id to later remove the added dynid. One use case is management tools that want to dynamically bind/unbind devices to pci-stub driver while devices are assigned to KVM guests. Rather than having to track which driver was originally bound to the driver, a mangement tool can simply: Guest uses device Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-03-20x86: use dev_printk in quirk messageBjorn Helgaas
This patch changes a VIA PCI quirk to use dev_info() rather than printk(). Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgek.org>
2009-03-20PCI: fix incorrect mask of PM No_Soft_Reset bitYu Zhao
Reviewed-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: Yu Zhao <yu.zhao@intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-03-20PCI: fix wrong assumption in pci_common_swizzleKenji Kaneshige
Current pci_common_swizzle() seems to have a assumption that pci_bus->self is NULL on the pci root bus. But it might not be true on some platforms. Because of this wrong assumption, pci_common_swizzle() might cause endless loop. We must check pci_bus->parent instead. Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-03-20PCI: fix wrong assumption in pci_get_interrupt_pinKenji Kaneshige
Current pci_get_interrupt_pin() seems to have an assumption that pci_bus->self is NULL on the root pci bus. But it might not be true on some platforms. Because of this wrong assumption, current pci_get_interrupt_pin() might cause endless loop. We must check pci_bus->parent instead. Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-03-20PCI: fix wrong assumption in pci_read_bridge_basesKenji Kaneshige
Current pci_read_bridge_bases() has an assumption that pci_bus->self is NULL on the pci root bus (It checks pci_bus->self to see if the pci bus is root bus). But is might not true on some platforms. We must check pci_bus->parent instead. Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-03-20PCI: fix wrong assumption in pci_find_upstream_pcie_bridgeKenji Kaneshige
Current pci_find_upstream_pcie_bridge() has a wrong assumption that pci_bus->self is NULL on the root pci bus. But it might not true on some platforms. Because of this wrong assumption, current pci_find_upstream_pcie_bridge() might cause endless loop. We must check pci_bus->parent instead. Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-03-20PCI hotplug: fix wrong assumption in acpi_get_hp_hw_control_from_firmwareKenji Kaneshige
Current acpi_get_hp_hw_control_from_firmware() has a assumption that pci_bus->self is NULL on a PCI root bus. But it might not be true on some platforms. Because of this wrong assumption, current acpi_get_hp_hw_control_from_firmware() might cause endless loop. We must check pci_bus->parent instead. Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-03-20PCI hotplug: fix wrong assumption in acpi_get_hp_params_from_firmwareKenji Kaneshige
Current acpi_get_hp_params_from_firmware() has a assumption that pci_bus->self is NULL on the root pci bus. But it might not true on some platforms. Because of this wrong assumption, current acpi_get_hp_params_from_firmware() might cause endless loop. We must check pci_bus->parent instead. Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-03-20PCI/ACPI: fix wrong assumption in acpi_find_root_bridge_handleKenji Kaneshige
Current acpi_find_root_bridge_handle() has a assumption that pci_bus->self is NULL on the root pci bus. But it might not be true on some platforms. Because of this wrong assumption, current acpi_find_root_bridge_handle() might cause endless loop. We must check pci_bus->parent instead. Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-03-20PCI/ACPI: fix wrong assumption in acpi_pci_get_bridge_handleKenji Kaneshige
Current acpi_pci_get_bridge_handle() has an assumption that pci_bus->self is NULL on the root pci bus. But it might not true on some platforms. Because of this wrong assumption, current acpi_pci_get_bridge_handle() might return improper ACPI handle. We must check pci_bus->parent instead. This bug is the root cause of the following kernel panic reported by James Bottomley. This problem was introduced by the commit e8c331e963c58b83db24b7d0e39e8c07f687dbc6. The immediate cause was acpi_pci_get_bridge_handle() returned NULL unexpectedly and it was passed as the second argument of acpi_walk_namespace(). pci_hotplug: PCI Hot Plug PCI Core version: 0.5 acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5 BUG: unable to handle kernel NULL pointer dereference at 0000000000000010 IP: [<ffffffff8039646f>] acpi_ns_get_next_node+0xb/0x3c PGD 0 Oops: 0000 [#1] SMP last sysfs file: CPU 0 Modules linked in: Pid: 1, comm: swapper Not tainted 2.6.28 #1 RIP: 0010:[<ffffffff8039646f>] [<ffffffff8039646f>] acpi_ns_get_next_node+0xb/0x3c RSP: 0018:ffff88007f87fd30 EFLAGS: 00010246 RAX: 0000000000000000 RBX: 0000000000000000 RCX: 0000000000000000 RDX: 0000000000000000 RSI: 0000000000000000 RDI: 0000000000000000 RBP: 0000000000000000 R08: ffffffff8037d260 R09: ffff88007f87fdfc R10: 0000000000000000 R11: 0000000000000000 R12: 0000000000000001 R13: 0000000000000000 R14: 0000000000000001 R15: 0000000000000000 FS: 0000000000000000(0000) GS:ffffffff80742040(0000) knlGS:0000000000000000 CS: 0010 DS: 0018 ES: 0018 CR0: 000000008005003b CR2: 0000000000000010 CR3: 0000000000201000 CR4: 00000000000006a0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process swapper (pid: 1, threadinfo ffff88007f87e000, task ffff88007f875040) Stack: 0000000000000000 ffffffff803964f5 ffff88007f81b728 0000000000001001 ffff88007f87fdfc ffffffff8037d260 0000000600000001 0000000000000000 ffffffff8037d260 0000000000000000 0000000000000001 ffff88007f87fdfc Call Trace: [<ffffffff803964f5>] acpi_ns_walk_namespace+0x55/0x138 [<ffffffff8037d260>] is_pci_dock_device+0x0/0x20 [<ffffffff8037d260>] is_pci_dock_device+0x0/0x20 [<ffffffff80394a9e>] acpi_walk_namespace+0x5f/0x83 [<ffffffff8037dd33>] detect_ejectable_slots+0x53/0x70 [<ffffffff8037de38>] add_bridge+0xe8/0x200 [<ffffffff80394aaa>] acpi_walk_namespace+0x6b/0x83 [<ffffffff803a4ad1>] acpi_pci_register_driver+0x48/0x61 [<ffffffff806fc5df>] acpiphp_init+0x0/0x58 [<ffffffff806fc732>] acpiphp_glue_init+0x4c/0x5a [<ffffffff806fc616>] acpiphp_init+0x37/0x58 [<ffffffff8020903b>] _stext+0x3b/0x180 [<ffffffff80312598>] create_proc_entry+0x58/0xa0 [<ffffffff802815d1>] register_irq_proc+0xc1/0xe0 [<ffffffff806db64b>] kernel_init+0x152/0x1ac [<ffffffff8023d970>] finish_task_switch+0x0/0x110 [<ffffffff8020ca7a>] child_rip+0xa/0x20 [<ffffffff8020c47c>] restore_args+0x0/0x30 [<ffffffff806db4f9>] kernel_init+0x0/0x1ac [<ffffffff8020ca70>] child_rip+0x0/0x20 Code: 89 c2 48 8b 00 48 85 c0 75 f5 48 8b 45 00 48 89 02 44 88 65 09 48 89 5d 00 31 c0 5b 5d 41 5c c3 53 48 85 d2 89 fb 48 89 d7 75 06 <48> 8b 56 10 eb 08 e8 73 f1 ff ff 48 89 c2 85 db 74 1a eb 13 0f RIP [<ffffffff8039646f>] acpi_ns_get_next_node+0xb/0x3c RSP <ffff88007f87fd30> CR2: 0000000000000010 ---[ end trace a7919e7f17c0a725 ]--- Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-03-20PCI: PCIe portdrv: Implement pm objectRafael J. Wysocki
Implement pm object for the PCI Express port driver in order to use the new power management framework and reduce the code size. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-03-20PCI: pcie_portdriver: fix pcie_port_device_removeEric W. Biederman
pcie_port_device_remove currently calls the remove method of port drivers twice. Ouch! We are calling device_for_each_child multiple times for no apparent reason. So make it simple. Place put_device and device_unregister into remove_iter, and throw out the rest. Only call device_for_each_child once. The code is simpler and actually works! Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-03-19PCI/alpha: pci sysfs resourcesIvan Kokshaysky
This closes http://bugzilla.kernel.org/show_bug.cgi?id=10893 which is a showstopper for X development on alpha. The generic HAVE_PCI_MMAP code (drivers/pci-sysfs.c) is not very useful since we have to deal with three different types of MMIO address spaces: sparse and dense mappings for old ev4/ev5 machines and "normal" 1:1 MMIO space (bwx) for ev56 and later. Also "write combine" mappings are meaningless on alpha - roughly speaking, alpha does write combining, IO reordering and other optimizations by default, unless user splits IO accesses with memory barriers. I think the cleanest way to deal with resource files on alpha is to convert the default no-op pci_create_resource_files() and pci_remove_resource_files() for !HAVE_PCI_MMAP case into __weak functions and override them with alpha specific ones. Another alpha hook is needed for "legacy_" resource files to handle sparse addressing (pci_adjust_legacy_attr). With the "standard" resourceN files on ev56/ev6 libpciaccess works "out of the box". Handling of resourceN_sparse/resourceN_dense files on older machines obviously requires some userland work. Sparse/dense stuff has been tested on sx164 (pca56/pyxis, normally uses bwx IO) with the kernel hacked into "cia compatible" mode. Signed-off-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-03-19PCI: constify pci_bus_assign_resources()Andrew Morton
drivers/pci/hotplug/fakephp.c: In function 'pci_rescan_bus': drivers/pci/hotplug/fakephp.c:271: warning: passing argument 1 of 'pci_bus_assign_resources' discards qualifiers from pointer target type Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-03-19PCI: constify pci_bus_add_devices()akpm@linux-foundation.org
drivers/pci/hotplug/fakephp.c:283: warning: passing argument 1 of 'pci_bus_add_devices' discards qualifiers from pointer target type Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-03-19PCI/MSI: Allow arch code to return the number of MSI-X availableMichael Ellerman
There is code in msix_capability_init() which, when the requested number of MSI-X couldn't be allocated, calculates how many MSI-X /could/ be allocated and returns that to the driver. That allows the driver to then make a second request, with a number of MSIs that should succeed. The current code requires the arch code to setup as many msi_descs as it can, and then return to the generic code. On some platforms the arch code may already know how many MSI-X it can allocate, before it sets up any of the msi_descs. So change the logic such that if the arch code returns a positive error code, that is taken to be the number of MSI-X that could be allocated. If the error code is negative we still calculate the number available using the old method. Because it's a little subtle, make sure the error return code from arch_setup_msi_irq() is always negative. That way only implementations of arch_setup_msi_irqs() need to be careful about returning a positive error code. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-03-19PCI hotplug: shpchp: fix bus number check to avoid false positiveRoel Kluin
With for (busnr = 0; busnr <= end; busnr++) { ... } busnr reaches end + 1 after the loop. So fix the "no busses available" check to look for just busnr > end rather than >=. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
