2006-01-10[PATCH] hrtimer: introduce nsec_t type and conversion functionsThomas Gleixner
- introduce the nsec_t type - basic nsec conversion routines: timespec_to_ns(), timeval_to_ns(), ns_to_timespec(), ns_to_timeval(). Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] hrtimer: validate timespec of do_sys_settimeofdayThomas Gleixner
Check if the timespec which is provided from user space is normalized. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] hrtimer: create and use timespec_valid macroThomas Gleixner
add timespec_valid(ts) [returns false if the timespec is denorm] Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] hrtimer: coding style and white space cleanup 2Thomas Gleixner
style/whitespace/macro cleanups of posix-timers.h Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] hrtimer: make clockid_t arguments constThomas Gleixner
add const arguments to the posix-timers.h API functions Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] hrtimer: coding style and white space cleanupIngo Molnar
style and whitespace cleanup of the rest of time.h. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] hrtimer: coding style clean up of clock constantsIngo Molnar
clean up the CLOCK_ portions of time.h Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] hrtimer: remove unused clock constantsThomas Gleixner
remove unused CLOCK_ constants from time.h Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] hrtimer: export deinlined mktimeAndrew Morton
This is now uninlined, but some modules use it. Make it a non-GPL export, since the inlined mktime() was also available that way. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] hrtimer: clean up mktime and make arguments constIngo Molnar
add 'const' to mktime arguments, and clean it up a bit Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] hrtimer: deinline mktime and set_normalized_timespecThomas Gleixner
mktime() and set_normalized_timespec() are large inline functions used in many places: deinline them. From: George Anzinger, off-by-1 bugfix Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] hrtimer: remove duplicate div_long_long_rem implementationThomas Gleixner
make posix-timers.c use the generic calc64.h facility Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] hrtimer: move div_long_long_rem out of jiffies.hThomas Gleixner
move div_long_long_rem() from jiffies.h into a new calc64.h include file, as it is a general math function useful for other things than the jiffy code. Convert it to an inline function Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] Generic ioctl.hBrian Gerst
Most arches copied the i386 ioctl.h. Combine them into a generic header. Signed-off-by: Brian Gerst <bgerst@didntduck.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] don't include ioctl32.h in driversChristoph Hellwig
These days ioctl32.h is only used for communication of fs/compat.c and fs/compat_ioctl.c and doesn't contain anything of interest to drivers. Remove inclusion in various drivers. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] per-mountpoint noatime/nodiratimeChristoph Hellwig
Turn noatime and nodiratime into per-mount instead of per-sb flags. After all the preparations this is a rather trivial patch. The mount code needs to treat the two options as per-mount instead of per-superblock, and touch_atime needs to be changed to check the new MNT_ flags in addition to the MS_ flags that are kept for filesystems that are always noatime/nodiratime but not user settable anymore. Besides that core code only nfs needed an update because it's leaving atime updates to the server and thus sets the S_NOATIME flag on every inode, but needs to know whether it's a real noatime mount for an getattr optimization. While we're at it I've killed the IS_NOATIME/IS_NODIRATIME macros that were only used by touch_atime. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] 9p: remove superflous MS_NODIRATIME assignmentChristoph Hellwig
MS_NOATIME implies MS_NODIRATIME Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Eric Van Hensbergen <ericvh@ericvh.myip.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] ntfs: remove superflous MS_NOATIME/MS_NODIRATIME assignmentsChristoph Hellwig
MS_RDONLU implies not atime updates at all, no need for the MS_NOATIME and MS_NODIRATIME flags. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Anton Altaparmakov <aia21@cantab.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] sanitize building of fs/compat_ioctl.cChristoph Hellwig
Now that all these entries in the arch ioctl32.c files are gone [1], we can build fs/compat_ioctl.c as a normal object and kill tons of cruft. We need a special do_ioctl32_pointer handler for s390 so the compat_ptr call is done. This is not needed but harmless on all other architectures. Also remove some superflous includes in fs/compat_ioctl.c Tested on ppc64. [1] parisc still had it's PPP handler left, which is not fully correct for ppp and besides that ppp uses the generic SIOCPRIV ioctl so it'd kick in for all netdevice users. We can introduce a proper handler in one of the next patch series by adding a compat_ioctl method to struct net_device but for now let's just kill it - parisc doesn't compile in mainline anyway and I don't want this to block this patchset. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Matthew Wilcox <willy@debian.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] add ->compat_ioctl to dasdChristoph Hellwig
Add a compat_ioctl method to the dasd driver so the last entries in arch/s390/kernel/compat_ioctl.c can go away. Unlike the previous attempt this one does not replace the ioctl method with an unlocked_ioctl method so that the ioctl_by_bdev calls in s390 partition code continue to work. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] move rtc compat ioctl handling to fs/compat_ioctl.cChristoph Hellwig
This patch implements generic handling of RTC_IRQP_READ32, RTC_IRQP_SET32, RTC_EPOCH_READ32 and RTC_EPOCH_SET32 in fs/compat_ioctl.c. It's based on the x86_64 code which needed a little massaging to be endian-clean. parisc used COMPAT_IOCTL or generic w_long handlers for these whichce is wrong and can't work because the ioctls encode sizeof(unsigned long) in their ioctl number. parisc also duplicated COMPAT_IOCTL entries for other rtc ioctls which I remove in this patch, too. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Matthew Wilcox <matthew@wil.cx> Acked-by: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] common compat_sys_timer_createChristoph Hellwig
The comment in compat.c is wrong, every architecture provides a get_compat_sigevent() for the IPC compat code already. This basically moves the x86_64 version to common code and removes all the others. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Paul Mackerras <paulus@samba.org> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Acked-by: Andi Kleen <ak@muc.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] ->compat_ioctl for 390 tape_charChristoph Hellwig
The only own ioctl, TAPE390_DISPLAY, is compat_clean, everything else is routed through common translation code. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] remove TIOCGSERIAL/TIOCSSERIAL compat_ioctl entries for 390Christoph Hellwig
These ioctls are definitely not compat clean, but we already have a proper handler in common code, over-riding it in architecture code is counter-productive. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] switch fs3270 to ->compat_ioctlChristoph Hellwig
Again easy because all ioctls are compat clean. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] __deprecated_for_modules the lookup_hash() prototypeAdrian Bunk
This patch __deprecated_for_modules the lookup_hash() prototype. Signed-off-by: Adrian Bunk <bunk@stusta.de> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] remove update_atimeChristoph Hellwig
All callers use touch_atime now which takes a vfsmount and allows us to implement per-mount noatime. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] switch autofs4 to touch_atime()Christoph Hellwig
After my lookup_hash patch ->d_revalidate always gets a valid struct nameidata passed (unless you use lookup_one_len which autofs4 doesn't), so we can switch it from update_atime to touch_atime. This is a bit of an academic excercise because autofs has a 1:1 vfsmount superblock relation, but I want to get rid of update_atime so filesystems authors can't easily screw up per-mountpoint noatime support. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Ian Kent <raven@themaw.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] replace inode_update_time with file_update_timeChristoph Hellwig
To allow various options to work per-mount instead of per-sb we need a struct vfsmount when updating ctime and mtime. This preparation patch replaces the inode_update_time routine with a file_update_atime routine so we can easily get at the vfsmount. (and the file makes more sense in this context anyway). Also get rid of the unused second argument - we always want to update the ctime when calling this routine. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@ftp.linux.org.uk> Cc: Anton Altaparmakov <aia21@cantab.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] remove xfs xattr permission checksChristoph Hellwig
remove checks now in the VFS XFS has an additional xattr interface through obscure ioctl. it requires raised capabilities but we need to add some read-only/immutable checks anyway Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Nathan Scott <nathans@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] remove reiserfs xattr permission checksChristoph Hellwig
remove checks now in the VFS Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] remove ext3 xattr permission checksakpm@osdl.org
) From: Christoph Hellwig <hch@lst.de> remove checks now in the VFS Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] remove ext2 xattr permission checksakpm@osdl.org
2006-01-10[PATCH] remove jfs xattr permission checksChristoph Hellwig
2006-01-10[PATCH] move xattr permission checks into the VFSakpm@osdl.org
) From: Christoph Hellwig <hch@lst.de> The xattr code has rather complex permission checks because the rules are very different for different attribute namespaces. This patch moves as much as we can into the generic code. Currently all the major disk based filesystems duplicate these checks, while many minor filesystems or network filesystems lack some or all of them. To do this we need defines for the extended attribute names in common code, I moved them up from JFS which had the nicest defintions. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] add vfs_* helpers for xattr operationsChristoph Hellwig
Add vfs_getxattr, vfs_setxattr and vfs_removexattr helpers for common checks around invocation of the xattr methods. NFSD already was missing some of the checks and there will be more soon. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: James Morris <jmorris@namei.org> (James, I haven't touched selinux yet because it's doing various odd things and I'm not sure how it would interact with the security attribute fallbacks you added. Could you investigate whether it could use vfs_getxattr or if not add a __vfs_getxattr helper to share the bits it is fine with?) For NFSv4: instead of just converting it add an nfsd_getxattr helper for the code shared by NFSv2/3 and NFSv4 ACLs. In fact that code isn't even NFS-specific, but I'll wait for more users to pop up first before moving it to common code. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Neil Brown <neilb@suse.de> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] Kdump documentation updateManeesh Soni
Update the kdump documentation to reflect the changes due to recent kernel config option changes for kexec and kdump. Signed-off-by: Maneesh Soni <maneesh@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] kexec: change CONFIG_PHYSICAL_START dependencyManeesh Soni
I have heard some complaints about people not finding CONFIG_CRASH_DUMP option and also some objections about its dependency on CONFIG_EMBEDDED. The following patch ends that dependency. I thought of hiding it under CONFIG_KEXEC, but CONFIG_PHYSICAL_START could also be used for some reasons other than kexec/kdump and hence left it visible. I will also update the documentation accordingly. o Following patch removes the config dependency of CONFIG_PHYSICAL_START on CONFIG_EMBEDDED. The reason being CONFIG_CRASH_DUMP option for kdump needs CONFIG_PHYSICAL_START which makes CONFIG_CRASH_DUMP depend on CONFIG_EMBEDDED. It is not always obvious for kdump users to choose CONFIG_EMBEDDED. o It also shifts the palce where this option appears, to make it closer to kexec and kdump options. Signed-off-by: Maneesh Soni <maneesh@in.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Haren Myneni <haren@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] kexec: increase max segment limitakpm@osdl.org
) From: Vivek Goyal <vgoyal@in.ibm.com> - In some cases, the number of segments, on a kexec load, exceeds the existing cap of 8. This patch increases the KEXEC_SEGMENT_MAX limit from 8 to 16. Signed-off-by: Rachita Kothiyal <rachita@in.ibm.com> Signed-off-by: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] kdump: read previous kernel's memoryVivek Goyal
- Moving the crash_dump.c file to arch dependent part as kmap_atomic_pfn is specific to i386 and highmem may not exist in other archs. - Use ioremap for x86_64 to map the previous kernel memory. - In copy_oldmem_page(), we now directly copy to the user/kernel buffer and avoid the unneccesary copy to a kmalloc'd page. Signed-off-by: Rachita Kothiyal <rachita@in.ibm.com> Signed-off-by: Vivek Goyal <vgoyal@in.ibm.com> Cc: Andi Kleen <ak@muc.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] kdump: x86_64 save cpu registers upon crashVivek Goyal
- Saving the cpu registers of all cpus before booting in to the crash kernel. - crash_setup_regs will save the registers of the cpu on which panic has occured. One of the concerns ppc64 folks raised is that after capturing the register states, one should not pop the current call frame and push new one. Hence it has been inlined. More call frames later get pushed on to stack (machine_crash_shutdown() and machine_kexec()), but one will not want to backtrace those. - Not very sure about the CFI annotations. With this patch I am getting decent backtrace with gdb. Assuming, compiler has generated enough debugging information for crash_kexec(). Coding crash_setup_regs() in pure assembly makes it tricky because then it can not be inlined and we don't want to return back after capturing register states we don't want to pop this call frame. - Saving the non-panicing cpus registers will be done in the NMI handler while shooting down them in machine_crash_shutdown. - Introducing CRASH_DUMP option in Kconfig for x86_64. Signed-off-by: Murali M Chakravarthy <muralim@in.ibm.com> Signed-off-by: Vivek Goyal <vgoyal@in.ibm.com> Cc: Andi Kleen <ak@muc.de> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] kdump: x86_64 kexec on panicakpm@osdl.org
) From: Vivek Goyal <vgoyal@in.ibm.com> - Implementing the machine_crash_shutdown for x86_64 which will be called by crash_kexec (called in case of a panic, sysrq etc.). Here we do things similar to i386. Disable the interrupts, shootdown the cpus and shutdown LAPIC and IOAPIC. Changes in this version: - As the Eric's APIC initialization patches are reverted back, reintroducing LAPIC and IOAPIC shutdown. - Added some comments on CPU hotplug, modified code as suggested by Andi kleen. Signed-off-by: Murali M Chakravarthy <muralim@in.ibm.com> Signed-off-by: Vivek Goyal <vgoyal@in.ibm.com> Cc: Andi Kleen <ak@muc.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] kdump: x86_64: add elfcorehdr command line optionVivek Goyal
- elfcorehdr= specifies the location of elf core header stored by the crashed kernel. This command line option will be passed by the kexec-tools to capture kernel. Changes in this version : - Added more comments in kernel-parameters.txt and in code. Signed-off-by: Murali M Chakravarthy <muralim@in.ibm.com> Signed-off-by: Vivek Goyal <vgoyal@in.ibm.com> Cc: Andi Kleen <ak@muc.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] kdump: x86_64: add memmmap command line optionakpm@osdl.org
) From: Vivek Goyal <vgoyal@in.ibm.com> - This patch introduces the memmap option for x86_64 similar to i386. - memmap=exactmap enables setting of an exact E820 memory map, as specified by the user. Changes in this version: - Used e820_end_of_ram() to find the max_pfn as suggested by Andi kleen. - removed PFN_UP & PFN_DOWN macros - Printing the user defined map also. Signed-off-by: Murali M Chakravarthy <muralim@in.ibm.com> Signed-off-by: Hariprasad Nellitheertha <nharipra@gmail.com> Signed-off-by: Vivek Goyal <vgoyal@in.ibm.com> Cc: Andi Kleen <ak@muc.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] Kdump: powerpc and s390 build failure fixakpm@osdl.org
) From: Vivek Goyal <vgoyal@in.ibm.com> crash_setup_regs() is an architecture dependent function which is called in architecture independent section. So every architecture supporting kexec should at least provide a dummy definition of crash_setup_regs() even if crash dumping is not implemented yet, to avoid build failures. Signed-off-by: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] Kdump: i386 compiler warning fixVivek Goyal
Fixes a compilation warning message in i386 Signed-off-by: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] kdump: save registers early (inline functions)Vivek Goyal
- If system panics then cpu register states are captured through funciton crash_get_current_regs(). This is not a inline function hence a stack frame is pushed on to the stack and then cpu register state is captured. Later this frame is popped and new frames are pushed (machine_kexec). - In theory this is not very right as we are capturing register states for a frame and that frame is no more valid. This seems to have created back trace problems for ppc64. - This patch fixes it up. The very first thing it does after entering crash_kexec() is to capture the register states. Anyway we don't want the back trace beyond crash_kexec(). crash_get_current_regs() has been made inline - crash_setup_regs() is the top architecture dependent function which should be responsible for capturing the register states as well as to do some architecture dependent tricks. For ex. fixing up ss and esp for i386. crash_setup_regs() has also been made inline to ensure no new call frame is pushed onto stack. Signed-off-by: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] kdump: export per cpu crash notes pointer through sysfs (fix)Vivek Goyal
Removes the call to get_cpu() and put_cpu() as it is not required. Signed-off-by: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] kdump: export per cpu crash notes pointer through sysfsVivek Goyal
- Kexec on panic functionality allocates memory for saving cpu registers in case of system crash event. Address of this allocated memory needs to be exported to user space, which is used by kexec-tools. - Previously, a single /sys/kernel/crash_notes entry was being exported as memory allocated was a single continuous array. Now memory allocation being dyanmic and per cpu based, address of per cpu buffer is exported through "/sys/devices/system/cpu/cpuX/crash_notes" Signed-off-by: Vivek Goyal <vgoyal@in.ibm.com> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] kdump: dynamic per cpu allocation of memory for saving cpu registersVivek Goyal
- In case of system crash, current state of cpu registers is saved in memory in elf note format. So far memory for storing elf notes was being allocated statically for NR_CPUS. - This patch introduces dynamic allocation of memory for storing elf notes. It uses alloc_percpu() interface. This should lead to better memory usage. - Introduced based on Andi Kleen's and Eric W. Biederman's suggestions. - This patch also moves memory allocation for elf notes from architecture dependent portion to architecture independent portion. Now crash_notes is architecture independent. The whole idea is that size of memory to be allocated per cpu (MAX_NOTE_BYTES) can be architecture dependent and allocation of this memory can be architecture independent. Signed-off-by: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
