2011-04-12vxge: update driver versionJon Mason
Update vxge driver version to 2.5.3 Signed-off-by: Jon Mason <jdmason@kudzu.us> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-12vxge: spin-lock issueJon Mason
In vxge_hw_vpath_close, __vxge_hw_vp_terminate memsets the vpath which clobbers the spin lock state, then the driver attempts to acquire the spin lock. Resolve this by not zeroing the lock part of vpath struct, clean-up vpath locking in init, close, and fix locking hole in fw_api call. Issue found by Bob Picco <bpicco@redhat.com> Signed-off-by: Jon Mason <jdmason@kudzu.us> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-12vxge: always enable hardware time stampJon Mason
Hardware time stamp calculation can only be enabled by the privileged function. Enable it always by default and simply use the ethtool interface to set a flag to indicate whether or not the respective function driver should indicate the timestamp along with the received packet. Also, make certain fields in vxge_hw_device_config bit-fields to reduce the size of the struct. Signed-off-by: Jon Mason <jdmason@kudzu.us> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-12s2io: Fix warnings due to -Wunused-but-set-variable.David S. Miller
Most of these are cases where we are trying to read back a register after a write to ensure completion. Simply pre-fixing the readl() or readq() with "(void)" is sufficient because these are volatile operations and the compiler cannot eliminate them just because no real assignment takes place. The case of free_rxd_blk()'s assignments to "struct buffAdd *ba" is a real spurious assignment as this variable is completely otherwise unused. Signed-off-by: David S. Miller <davem@davemloft.net> Acked-by: Jon Mason <jdmason@kudzu.us>
2011-04-11niu: Fix warnings due to -Wunused-but-set-variableDavid S. Miller
Most of these were legitimate, and once case was a real bug (not propagating errors from ->xcvr_init() methods). Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-11caif: Add BUG_ON if dev_info is missing in packetSjur Brændeland
Signed-off-by: Sjur Brændeland <sjur.brandeland@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-11caif: Don't resend if dev_queue_xmit fails.Sjur Brændeland
If CAIF Link Layer returns an error, we no longer try to re-build the CAIF packet and resend it. Instead, we simply return any transmission errors to the socket client. Signed-off-by: Sjur Brændeland <sjur.brandeland@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-11caif: code cleanupStephen Hemminger
Cleanup of new CAIF code. * make local functions static * remove code that is never used * expand get_caif_conf() since wrapper is no longer needed * make args to comparison functions const * rename connect_req_to_link_param to keep exported names consistent Compile tested only. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Acked-by: Sjur Brændeland <sjur.brandeland@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/smsc911x.c
2011-04-11niu: Recognise original ethtool class code for AH/ESP flow hashingBen Hutchings
When the RX network flow classification interface was originally defined for reporting and controlling of flow hashing, AH and ESP were not given distinct flow class codes (apparently because the Sun Neptune hardware treats them very similarly). For flow steering, they must be distinguished, so new and separate flow class codes were added for AH and ESP. But for backward- compatibility, flow hash operations should continue to support the original class codes. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-11gianfar: Clean up implementation of RX network flow classificationBen Hutchings
This code was cribbed from niu, so gfar_set_hash_opts() begins by converting the ethtool flow class code into a class code for Sun Neptune hardware, then does the same thing again for the hardware it's really dealing with. It may also return -1 (-EPERM) for some unhandled ethtool flow class codes. Remove the useless code and definitions, and fix the error code. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-11qlge: use ethtool set_phys_idstephen hemminger
This is a stab at replacing old ethtool phys_id with set_phys_id on the Qlogic 10Gb driver. Compile tested only. Not sure if set_led_cfg will flash continuously, or needs to be replaced by ETHTOOL_ID_ON/ETHTOOL_ID_OFF Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Ron Mercer <ron.mercer@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-11v3 ethtool: add ntuple flow specifier data to network flow classifierAlexander Duyck
This change is meant to add an ntuple data extensions to the rx network flow classification specifiers. The idea is to allow ntuple to be displayed via the network flow classification interface. The first patch had some left over stuff from the original flow extension flags I had added. That bit is removed in this patch. The second had some left over comments that stated we ignored bits in the masks when we actually match them. This work is based on input from Ben Hutchings. Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com> Reviewed-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-11ethtool: prevent null pointer dereference with NTUPLE set but no set_rx_ntupleAlexander Duyck
This change is meant to prevent a possible null pointer dereference if NETIF_F_NTUPLE is defined but the set_rx_ntuple function pointer is not. The main motivation behind this patch is to eventually replace the ntuple interfaces entirely with the network flow classifier interfaces. This allows the device drivers to maintain the ntuple check internally while using the network flow classifier interface for setting up and displaying rules. Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-11caif: performance bugfix - allow radio stack to prioritize packets.Sjur Brændeland
In the CAIF Payload message the Packet Type indication must be set to UNCLASSIFIED in order to allow packet prioritization in the modem's network stack. Otherwise TCP-Ack is not prioritized in the modems transmit queue. Signed-off-by: Sjur Brændeland <sjur.brandeland@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-11caif: Bugfix use for_each_safe when removing list nodes.Sjur Brændeland
2011-04-11netxen: limit skb frags for non tso packetamit salecha
Machines are getting deadlock in four node cluster environment. All nodes are accessing (find /gfs2 -depth -print|cpio -ocv > /dev/null) 200 GB storage on a GFS2 filesystem. This result in memory fragmentation and driver receives 18 frags for 1448 byte packets. For non tso packet, fw drops the tx request, if it has >14 frags. Fixing it by pulling extra frags. Cc: stable@kernel.org Signed-off-by: Amit Kumar Salecha <amit.salecha@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-11bonding:fix two typosPeter Pan(潘卫平)
replace relpy with reply. replace premanent with permanent. Signed-off-by: Weiping Pan(潘卫平) <panweiping3@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-11net: fix tranmitted/tranmitting typoPeter Pan(潘卫平)
replace tranmitted with transmitted. replace tranmitting with transmitting. Signed-off-by: Weiping Pan(潘卫平) <panweiping3@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-11bonding:delete unused rlb_interval_counterPeter Pan(潘卫平)
Now, alb_bond_info uses rx_ntt,rlb_update_delay_counter and rlb_update_retry_counter to decide when to call rlb_update_rx_clients(). Signed-off-by: Weiping Pan(潘卫平) <panweiping3@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-11bonding:delete unused alb_timerPeter Pan(潘卫平)
Now bonding-alb uses delayed_work instead of timer_list. Signed-off-by: Weiping Pan(潘卫平) <panweiping3@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-11bonding:set save_load to 0 when initializingPeter Pan(潘卫平)
It is unnecessary to set save_load to 1 here, as the tx_hashtbl is just kzalloced. Signed-off-by: Weiping Pan(潘卫平) <panweiping3@gmail.com> Signed-off-by: Jay Vosburgh <fubar@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-11stmmac: fix Transmit Underflow errorGiuseppe CAVALLARO
On some old MAC chips without COE sometime the Transmit Underflow error is issued. The driver aborted all the transmission process and initialized it from scratch. This breaks the network activity as raised by Nachiketa on a SPEAr board. The patch is to fix this rare underflow event. The driver will only clear the interrupt and the Tx DMA will go out the Suspend state as soon as the descriptor is fetched again. The driver will continue to bump-up the DMA FIFO threshold that, indeed, helped somebody to prevent this kind of error in the past as well. Reported-by: Nachiketa Prachanda <nprachanda@ncomputing.com> Signed-off-by: Giuseppe Cavallaro <peppe.cavallaro@st.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-11stmmac: fix open funct when exit on errorGiuseppe CAVALLARO
This patch reviews the open function and fixes some errors when exit with an error state. It also moves the request_irq after core is initialized when interrupts are properly masked. Signed-off-by: Shiraz Hashim <shiraz.hashim@st.com> Hacked-by: Giuseppe Cavallaro <peppe.cavallaro@st.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-11stmmac: fixed dma lib build when turn-on the debug optionGiuseppe CAVALLARO
This patch fixes a compilation error when build the dwmac_lib with the DEBUG option enabled. Signed-off-by: Giuseppe Cavallaro <peppe.cavallaro@st.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-11iwlegacy: make iwl3945 and iwl4965 select IWLWIFI_LEGACYJohn W. Linville
Otherwise, IWLWIFI_LEGACY has to be selected independently before the drivers are made available. Reported-by: Dave Airlie <airlied@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Cc: Stanislaw Gruszka <sgruszka@redhat.com> Cc: Wey-Yi Guy <wey-yi.w.guy@intel.com>
2011-04-11pci: fix PCI bus allocation alignment handlingLinus Torvalds
In commit 13583b16592a ("PCI: refactor io size calculation code") Ram had a thinko in the refactorization of the code: the end result used the variable 'align' for the bus alignment, but the original code used 'min_align'. Since then, another use of that 'align' variable got introduced by commit c8adf9a3e873 ("PCI: pre-allocate additional resources to devices only after successful allocation of essential resources.") Fix both of those uses to use 'min_align' as they should. Daniel Hellstrom <daniel@gaisler.com> Acked-by: Ram Pai <linuxram@us.ibm.com> Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-04-11Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (34 commits) net: Add support for SMSC LAN9530, LAN9730 and LAN89530 mlx4_en: Restoring RX buffer pointer in case of failure mlx4: Sensing link type at device initialization ipv4: Fix "Set rt->rt_iif more sanely on output routes." MAINTAINERS: add entry for Xen network backend be2net: Fix suspend/resume operation be2net: Rename some struct members for clarity pppoe: drop PPPOX_ZOMBIEs in pppoe_flush_dev dsa/mv88e6131: add support for mv88e6085 switch ipv6: Enable RFS sk_rxhash tracking for ipv6 sockets (v2) be2net: Fix a potential crash during shutdown. bna: Fix for handling firmware heartbeat failure can: mcp251x: Allow pass IRQ flags through platform data. smsc911x: fix mac_lock acquision before calling smsc911x_mac_read iwlwifi: accept EEPROM version 0x423 for iwl6000 rt2x00: fix cancelling uninitialized work rtlwifi: Fix some warnings/bugs p54usb: IDs for two new devices wl12xx: fix potential buffer overflow in testmode nvs push zd1211rw: reset rx idle timer from tasklet ...
2011-04-10net: Add support for SMSC LAN9530, LAN9730 and LAN89530Steve Glendinning
This patch adds support for SMSC's LAN9530, LAN9730 and LAN89530 USB ethernet controllers to the existing smsc95xx driver by adding their new USB VID/PID pairs. Signed-off-by: Steve Glendinning <steve.glendinning@smsc.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-10net: bnx2: convert to hw_featuresMichał Mirosław
Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-10net: via-velocity: convert to hw_featuresMichał Mirosław
Trivial conversion. This also enables toggling TX VLAN offload and fixes TX checksumming race with offload changes. Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-10net: ksz884x: convert to hw_featuresMichał Mirosław
This also fixes possible race when changing receive checksum state and removes IPV6_CSUM_GEN_HACK as it's always set. BTW, The claim about fake IPV6 checksum looks dubious. If that were true, then there's a problem in networking core and should be fixed there and not in random drivers. BTW#2, there's no MAINTAINERS entry for this driver. I assume this driver is supported by Micrel? Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-10net: stmmac: convert to hw_featuresMichał Mirosław
This also removes TSO as it's made fully in software --- better to leave this to networking core. If the MAC features can be detected at probe time and not at open, then stmmac_fix_features could be simplified by limiting hw_features. That's also better for users as they don't see offloads being togglable but never turned on. Redundant fallbacks for TX csum are removed as it's already handled by network core. Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-10net: 8139cp: convert to hw_featuresMichał Mirosław
2011-04-10net: r8169: convert to hw_featuresMichał Mirosław
Simple conversion with a bit of needed cleanup. This also fixes: - confusion around vlan_features in rtl8169_vlan_mode(), - problem with broken TSO for too big MTU (the limit is set at 0xFFF --- max MSS field value). SG+IP_CSUM+TSO is left disabled by default, based on suggestion by David Dillow. Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-10net: benet: convert to hw_features - fixupMichał Mirosław
Fix up after merge with NETIF_F_RXHASH implementation. This allows to toggle NETIF_F_RXHASH and NETIF_F_HW_VLAN_TX. Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-10net: Remove invalid offloadsMichał Mirosław
Remove offload changing ethtool ops which drivers don't really support: - fs_enet - ucc_geth Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-10Disable rp_filter for IPsec packetsMichael Smith
The reverse path filter interferes with IPsec subnet-to-subnet tunnels, especially when the link to the IPsec peer is on an interface other than the one hosting the default route. With dynamic routing, where the peer might be reachable through eth0 today and eth1 tomorrow, it's difficult to keep rp_filter enabled unless fake routes to the remote subnets are configured on the interface currently used to reach the peer. IPsec provides a much stronger anti-spoofing policy than rp_filter, so this patch disables the rp_filter for packets with a security path. Signed-off-by: Michael Smith <msmith@cbnco.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-10fib_validate_source(): pass sk_buff instead of markMichael Smith
This makes sk_buff available for other use in fib_validate_source(). Signed-off-by: Michael Smith <msmith@cbnco.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-10usb: plusb: Add debug to reset functionsimon
This patch adds some debug to the reset function to print out the reason why it fails. Signed-off-by: Simon Wood <simon@mungewell.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-10usb: plusb: Add support for PL-25A1simon
This patch adds support for the PL-25A1 by adding the appropriate USB ID's. This chip is used in the Belkin 'Windows Easy Transfer' Cables. Signed-off-by: Simon Wood <simon@mungewell.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-10usb: plusb: Whitespacesimon
This patch cleans up a couple of instances of incorrect whitespace Signed-off-by: Simon Wood <simon@mungewell.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-10Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: ALSA: hda - Don't query connections for widgets have no connections ALSA: HDA: Fix single internal mic on ALC275 (Sony Vaio VPCSB1C5E) ALSA: hda - HDMI: Fix MCP7x audio infoframe checksums ALSA: usb-audio: define another USB ID for a buggy USB MIDI cable ALSA: HDA: Fix dock mic for Lenovo X220-tablet ASoC: format_register_str: Don't clip register values ASoC: PXA: Fix oops in __pxa2xx_pcm_prepare ASoC: zylonite: set .codec_dai_name in initializer
2011-04-09Merge git://git.infradead.org/mtd-2.6Linus Torvalds
* git://git.infradead.org/mtd-2.6: mtd: atmel_nand: use CPU I/O when buffer is in vmalloc(ed) region mtd: atmel_nand: modify test case for using DMA operations mtd: atmel_nand: fix support for CPUs that do not support DMA access mtd: atmel_nand: trivial: change DMA usage information trace mtd: mtdswap: fix printk format warning
2011-04-09Merge branch 'fix/hda' into for-linusTakashi Iwai
2011-04-09Merge branch 'fix/asoc' into for-linusTakashi Iwai
2011-04-08cxgb4vf: drop phys_id interface and implement the newer set_phys_idDimitris Michailidis
Signed-off-by: Dimitris Michailidis <dm@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-08cxgb4: drop phys_id interface and implement the newer set_phys_idDimitris Michailidis
2011-04-08cnic: Fix rtnl deadlockMichael Chan
When cnic_stop_hw() -> cnic_cm_stop_bnx2x_hw() is called under rtnl_lock() from NETDEV_DOWN event, it waits for cnic_delete_task() to complete. It will deadlock when cnic_delete_task() takes rtnl_lock() before calling cnic_ulp_stop_one(). We fix it by removing the rtnl_lock() in cnic_delete_task(). cnic_ulp_stop_one() has mutex and atomic bit ops to prevent important operations from being done more than once, so it is not necessary to take rtnl_lock(). Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
