Just pass struct file *. Methods are happier that way...
There's no need to return struct file * from finish_open() now,
so let it return int. Next: saner prototypes for parts in
namei.c
->filp->f_path is there for purpose...
Change of calling conventions:
old new
NULL 1
file 0
ERR_PTR(-ve) -ve
Caller *knows* that struct file *; no need to return it.
make put_filp() conditional on flag set by finish_open()
... and let finish_open() report having opened the file via that sucker.
Next step: don't modify od->filp at all.
[AV: FILE_CREATE was already used by cifs; Miklos' fix folded]
Perform open_check_o_direct() in a common place in do_last after opening the
file.
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
Move the lookup retry logic to the bottom of the function to make the normal
case simpler to read.
Reported-by: David Howells <dhowells@redhat.com>
Consistently use bool for boolean values in do_last().
All users of open intents have been converted to use ->atomic_{open,create}.
This patch gets rid of nd->intent.open and related infrastructure.
Add an ->atomic_open implementation which replaces the atomic open+create
operation implemented via ->create. No functionality is changed.
CC: Eric Van Hensbergen <ericvh@gmail.com>
Add an ->atomic_open implementation which replaces the atomic lookup+open+create
operation implemented via ->lookup and ->create operations.
CC: Sage Weil <sage@newdream.net>
What was the purpose of this?
CC: Steve French <sfrench@samba.org>
is_atomic_open() is now only used by nfs4_lookup_revalidate() to check whether
it's okay to skip normal revalidation.
It does a racy check for mount read-onlyness and falls back to normal
revalidation if the open would fail. This makes little sense now that this
function isn't used for determining whether to actually open the file or not.
The d_mountpoint() check still makes sense since it is an indication that we
might be following a mount and so open may not revalidate the dentry.
CC: Trond Myklebust <Trond.Myklebust@netapp.com>
Instead check LOOKUP_EXCL in nd->flags, which is basically what the open intent
flags were used for.
Don't pass nfs_open_context() to ->create(). Only the NFS4 implementation
needed that and only because it wanted to return an open file using open
intents. That task has been replaced by ->atomic_open so it is not necessary
anymore to pass the context to the create rpc operation.
Despite nfs4_proc_create apparently being okay with a NULL context it Oopses
somewhere down the call chain. So allocate a context here.
Replace NFS4 specific ->lookup implementation with ->atomic_open impelementation
and use the generic nfs_lookup for other lookups.
Add a new inode operation which is called on the last component of an open.
Using this the filesystem can look up, possibly create and open the file in one
atomic operation. If it cannot perform this (e.g. the file type turned out to
be wrong) it may signal this by returning NULL instead of an open struct file
pointer.
i_op->atomic_open() is only called if the last component is negative or needs
lookup. Handling cached positive dentries here doesn't add much value: these
can be opened using f_op->open(). If the cached file turns out to be invalid,
the open can be retried, this time using ->atomic_open() with a fresh dentry.
For now leave the old way of using open intents in lookup and revalidate in
place. This will be removed once all the users are converted.
David Howells noticed that if ->atomic_open() opens the file but does not create
it, handle_truncate() will be called on it even if it is not a regular file.
Fix this by checking the file type in this case too.
Copy __lookup_hash() into lookup_open(). The next patch will insert the atomic
open call just before the real lookup.
Split out lookup + maybe create from do_last(). This is the part under i_mutex
protection.
The function is called lookup_open() and returns a filp even though the open
part is not used yet.
Make the slow lookup part of O_CREAT and non-O_CREAT opens common.
This allows atomic_open to be hooked into the slow lookup part.
Check O_CREAT on the slow lookup paths where necessary. This allows the rest to
be shared with plain open.
Copy lookup_slow() into do_last().
no need for kludgy "set cookie to ERR_PTR(...) because we failed
before we did actual ->follow_link() and want to suppress put_link()",
no pointless check in put_link() itself.
Callers checked if follow_link() has failed anyway; might as well
break out of their loops if that happened, without bothering
to call put_link() first.
[AV: folded fixes from hch]
and add a comment on what it's doing
we used to need to clean it in RCU callback freeing an inode;
in 3.2 that requirement went away. Unfortunately, it hadn't
been reflected in Documentation/filesystems/porting.
we'll initialize it in inode_init_always() when we allocate that
object again.
don't rely on proc_mounts->m being the first field; container_of()
is there for purpose. No need to bother with ->private, while
we are at it - the same container_of will do nicely.
it's enough to set ->mnt_ns of internal vfsmounts to something
distinct from all struct mnt_namespace out there; then we can
just use the check for ->mnt_ns != NULL in the fast path of
mntput_no_expire()
READ is 0, so the result of the bit-and operation is 0. Rewrite with == as
done elsewhere in the same file.
This problem was found using Coccinelle (http://coccinelle.lip6.fr/).
Reviewed-by: Jeff Moyer <jmoyer@redhat.com>
This patch makes affs stop using the VFS '->write_super()' method along with
the 's_dirt' superblock flag, because they are on their way out.
The whole "superblock write-out" VFS infrastructure is served by the
'sync_supers()' kernel thread, which wakes up every 5 (by default) seconds and
writes out all dirty superblocks using the '->write_super()' call-back. But the
problem with this thread is that it wastes power by waking up the system every
5 seconds, even if there are no diry superblocks, or there are no client
file-systems which would need this (e.g., btrfs does not use
'->write_super()'). So we want to kill it completely and thus, we need to make
file-systems to stop using the '->write_super()' VFS service, and then remove
it together with the kernel thread.
Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
Add an 'sb' VFS superblock back-reference to the 'struct affs_sb_info' data
structure - we will need to find the VFS superblock from a 'struct
affs_sb_info' object in the next patch, so this change is jut a preparation.
The VFS's 'lock_super()' and 'unlock_super()' calls are deprecated and unwanted
and just wait for a brave knight who'd kill them. This patch makes AFFS stop
using them and use the buffer-head's own lock instead.
AFFS wants to serialize the superblock (the root block in AFFS terms) updates
and uses 'lock_super()/unlock_super()' for these purposes. This patch pushes the
locking down to the 'affs_commit_super()' from the callers.
We do not need to write out the superblock from '->remount_fs()' because
VFS has already called '->sync_fs()' by this time and the superblock has
already been written out. Thus, remove the 'affs_write_super()'
infocation from 'affs_remount()'.
We do not need to write out the superblock from '->put_super()' because VFS has
already called '->sync_fs()' by this time and the superblock has already been
written out. Thus, remove the 'affs_commit_super()' infocation from
'affs_put_super()'.
AFFS stores values '1' and '2' in 'bm_flags', and I fail to see any logic when
it prefers one or another. AFFS writes '1' only from '->put_super()', while
'->sync_fs()' and '->write_super()' store value '2'. So on the first glance,
it looks like we want to have '1' if we unmount. However, this does not really
happen in these cases:
1. superblock is written via 'write_super()' then we unmount;
2. we re-mount R/O, then unmount.
which are quite typical.
I could not find good documentation describing this field, except of one random
piece of documentation in the internet which says that -1 means that the root
block is valid, which is not consistent with what we have in the Linux AFFS
driver.
Jan Kara commented on this: "I have some vague recollection that on Amiga
boolean was usually encoded as: 0 == false, ~0 == -1 == true. But it has been
ages..."
Thus, my conclusion is that value of '1' is as good as value of '2' and we can
just always use '2'. An Jan Kara suggested to go further: "generally bm_flags
handling looks strange. If they are 0, we mount fs read only and thus cannot
change them. If they are != 0, we write 2 there. So IMHO if you just removed
bm_flags setting, nothing will really happen."
So this patch removes the bm_flags setting completely. This makes the "clean"
argument of the 'affs_commit_super()' function unneeded, so it is also removed.
Pull use-after-free RAID1 bugfix from NeilBrown.
* tag 'md-3.5-fixes' of git://neil.brown.name/md:
md/raid1: fix use-after-free bug in RAID1 data-check code.
Pull the leap second fixes from Thomas Gleixner:
"It's a rather large series, but well discussed, refined and reviewed.
It got a massive testing by John, Prarit and tip.
In theory we could split it into two parts. The first two patches
f55a6faa3843: hrtimer: Provide clock_was_set_delayed()
4873fa070ae8: timekeeping: Fix leapsecond triggered load spike issue
are merely preventing the stuff loops forever issues, which people
have observed.
But there is no point in delaying the other 4 commits which achieve
full correctness into 3.6 as they are tagged for stable anyway. And I
rather prefer to have the full fixes merged in bulk than a "prevent
the observable wreckage and deal with the hidden fallout later"
approach."
* 'timers-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
hrtimer: Update hrtimer base offsets each hrtimer_interrupt
timekeeping: Provide hrtimer update function
hrtimers: Move lock held region in hrtimer_interrupt()
timekeeping: Maintain ktime_t based offsets for hrtimers
If a seccomp filter program is installed, older static binaries and
distributions with older libc implementations (glibc 2.13 and earlier)
that rely on vsyscall use will be terminated regardless of the filter
program policy when executing time, gettimeofday, or getcpu. This is
only the case when vsyscall emulation is in use (vsyscall=emulate is the
default).
This patch emulates system call entry inside a vsyscall=emulate by
populating regs->ax and regs->orig_ax with the system call number prior
to calling into seccomp such that all seccomp-dependencies function
normally. Additionally, system call return behavior is emulated in line
with other vsyscall entrypoints for the trace/trap cases.
[ v2: fixed ip and sp on SECCOMP_RET_TRAP/TRACE (thanks to luto@mit.edu) ]
Reported-and-tested-by: Owen Kibel <qmewlo@gmail.com>
Signed-off-by: Will Drewry <wad@chromium.org>
