2006-06-22[ALSA] Fix pcm-draining of capture stream in PCM middle layerTakashi Iwai
Fix the draining of PCM capture stream in the PCM middle layer. snd_pcm_drain() ignored capture streams, but it should change the state to SNDRV_PCM_DRAINING. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-06-22[ALSA] Fix description of snd-hda-intel driver in documentTakashi Iwai
Fixed the description of snd-hda-intel driver in ALSA-Configuration.txt document. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-06-22[ALSA] hda - Add support for the ATI RS600 HDMI audio deviceFelix Kuehling
Add support for the ATI RS600 HDMI audio device. It has a one-stream pure digital stereo codec that isn't handled by the generic codec support. Signed-off-by: Felix Kuehling <fkuehlin@ati.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-06-22[ALSA] azt3328.c: use kernel coding styleAndreas Mohr
Scope braces were not done the One True Kernel Way. Signed-off-by: Andreas Mohr <andi@lisas.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-06-22[ALSA] azt3328.c: add 3D sound mixer switch/rename controlsAndreas Mohr
- add 3D sound pre-3D/post-3D switch, as seen in standard AC-97 - rename controls to shorter and more accurate strings Signed-off-by: Andreas Mohr <andi@lisas.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-06-22[ALSA] azt3328.c: add suspend/resume supportAndreas Mohr
- add suspend/resume handlers - fix problem (private_data members not set) Playing a file while suspending will resume correctly with this patch, so I assume the hardware to get fully correctly reinitialized with this patch. Signed-off-by: Andreas Mohr <andi@lisas.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-06-22[ALSA] Fix rwlock around snd_iprintf() in sound coreTakashi Iwai
Fixed rwlock around snd_iprintf() in sound core part. Replaced with mutex. Also, make mutex and flags static variables with addition of snd_card_locked() function (just for sound.c). Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-06-22[ALSA] hda-codec - Fix handling of capture controls on ALC882 3/6-stack modelsTakashi Iwai
Fixed the handling of capture controls on ALC882 3/6-stack models. Now the driver checks the availability of NID 07h. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-06-22[ALSA] Remove obsolete description from ALSA-Configuration.txtTakashi Iwai
Remove obsolete descriptions about the dependency on CONFIG_ISA for vxpocket and pdaudiocf drivers. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-06-22[ALSA] hda-codec - Add support for Sony Vaio VGN-S3HPTakashi Iwai
Added the missing support for Sony Vaio VGN-S3HP with ALC260 codec. The patch taken from ALSA bug#2101. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-06-22[ALSA] rme96 - Fix OSS full-duplexTakashi Iwai
Fixed a bug in rme96 driver that the full-duplex on OSS emulation doesn't work due to the invalid period size parameter. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-06-22[ALSA] hda-codec - Add support for Apple Mac Mini (early 2006)Sam Revitch
Add support for some audio quirks of the Apple Mac Mini (early 2006) Signed-off-by: Sam Revitch <samr7@cs.washington.edu> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-06-22[ALSA] add support for SB Live! 24-Bit External remote controlRaimonds Cicans
This patch rewrites the remote control code to use a table for the peculiarities of the various SB models, and adds support for a third model. Signed-off-by: Raimonds Cicans <ray@vardes.lv> Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2006-06-22[ALSA] cmipci - Disable integrated mpu401 as defaultTakashi Iwai
Enable the support of mpu401 PCI port only when mpu_port=1 module option is given, i.e. disabled as default. It turned out that the check of integrated midi port isn't perfect and caused hang-ups on some boards. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-06-22[ALSA] Fix a typo in writing-an-alsa-driver documentTakashi Iwai
Fixed a typo in writing-an-alsa-driver document. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-06-22[ALSA] au88x0 - Init before create componentsAlan Horstmann
Change the order in vortex_probe to set the card details before creating the components, meaning for example that card->shortname is available when registering the midi port. I have also added extra to card->shortname, and a line to overwrite the midi name following snd_mpu401_uart_new. Signed-off-by: Alan Horstmann <gineera@aspect135.co.uk> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-06-22[ALSA] hda: add sigmatel 9227/9228/9229 idsMatt Porter
Adds support for the 9227/9228/9229 sigmatel hda codecs. Signed-off-by: Matt Porter <mporter@embeddedalley.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-06-22[ALSA] hda-codec - Fix mute switch on VAIO laptops with STAC7661Takashi Iwai
Fixed the master mute switch on VAIO laptops with STAC7661 codec chip. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-06-22[ALSA] cs5535audio - Add missing module_param*() and MODULE_PARM_DESC()Takashi Iwai
Added missing module_param*() and MODULE_PARM_DESC() for cs5535audio driver. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-06-22[ALSA] Add a workaround for ASUS A6KMTakashi Iwai
Added a workaround for ASUS A6KM board that requires EAPD rather than SPDIF-in. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-06-22[ALSA] hda-codec - Add support for LG S1 laptopTakashi Iwai
Added the model entry for LG S1 laptop. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-06-22[ALSA] rawmidi: add get_port_info callback for sequencer information flagsClemens Ladisch
Add a get_port_info callback to the snd_rawmidi_global_ops structure to allow the USB MIDI driver to supply information flags for the sequencer ports created by seq_midi. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2006-06-22[ALSA] add more sequencer port type information bitsClemens Ladisch
Add four new information flags SNDRV_SEQ_PORT_TYPE_HARDWARE, _SOFTWARE, _SYNTHESIZER, _PORT for sequencer ports. This makes it easier for apps like Rosegarden to make policy decisions based on the port type. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2006-06-22[ALSA] fix port type bitsClemens Ladisch
Fix the port information about non-MIDI messages that had wrong values for some OPL3 and EmuX ports. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2006-06-22[ALSA] fix a wrong lockClemens Ladisch
fix a typo in the info locking code Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2006-06-22[ALSA] Fix compile warning in timer.cTakashi Iwai
Fix a compile warning in timer.c due to unused variables. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-06-22[ALSA] Fix mmap_count with O_APPEND opened streamsTakashi Iwai
Move mmap_count to snd_pcm_substream instead of runtime struct so that multiplly opened substreams via O_APPEND can be handled correctly. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-06-22[ALSA] Add O_APPEND flag support to PCMTakashi Iwai
Added O_APPEND flag support to PCM to enable shared substreams among multiple processes. This mechanism is used by dmix and dsnoop plugins. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-06-22[ALSA] Insert might_sleep() in snd_iprintf()Takashi Iwai
Inserted might_sleep() in snd_iprintf() for sanity check. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-06-22[ALSA] Remove spinlocks around proc printsTakashi Iwai
Don't lock during showing proc read. snd_iprintf() might sleep. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-06-22[ALSA] Remove unneeded read/write_size fields in proc text opsTakashi Iwai
Remove unneeded read/write_size fields in proc text ops. snd_info_set_text_ops() is fixed, too. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-06-22[ALSA] Make buffer size of proc text interface variableTakashi Iwai
Make the read/write buffer size of proc text interface variable. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-06-22[ALSA] Clean up ugly hacks in pcm_lib.cTakashi Iwai
Clean up ugly hacks for sync with alsa-lib code in pcm_lib.c. Also, optimize snd_pcm_hw_params_choose() with a loop. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-06-22[ALSA] Move OSS-specific hw_params helper to snd-pcm-oss moduleTakashi Iwai
Move EXPORT_SYMBOL()s to places adjacent to functions/variables. Also move OSS-specific hw_params helper functions to pcm_oss.c. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-06-22[ALSA] hda-codec - Move EXPORT_SYMBOL() to adjacent to each functionTakashi Iwai
Move EXPORT_SYMBOL() to adjacent to each exported function/variable. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-06-22[ALSA] i2c - Move EXPORT_SYMBOL() to adjacent to each functionTakashi Iwai
2006-06-22[ALSA] vx - Move EXPORT_SYMBOL() to adjacent to each functionTakashi Iwai
2006-06-22[ALSA] emux - Move EXPORT_SYMBOL() to adjacent to each functionTakashi Iwai
2006-06-22[ALSA] trident - Move EXPORT_SYMBOL() to adjacent to each functionTakashi Iwai
2006-06-22[ALSA] emu10k1 - Move EXPORT_SYMBOL() to adjacent to each functionTakashi Iwai
2006-06-22[ALSA] opl4 - Move EXPORT_SYMBOL() to adjacent to each functionTakashi Iwai
2006-06-22[ALSA] opl3 - Move EXPORT_SYMBOL() to adjacent to each functionTakashi Iwai
2006-06-22[ALSA] ac97 - Move EXPORT_SYMBOL() to adjacent to each functionTakashi Iwai
2006-06-22[ALSA] Clean up EXPORT_SYMBOL()s in snd-seq moduleTakashi Iwai
Move EXPORT_SYMBOL()s to places adjacent to functions/variables. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-06-22[ALSA] Clean up EXPORT_SYMBOL()s in snd moduleTakashi Iwai
2006-06-22[ALSA] Clean up ugly hacks in pcm_params.hTakashi Iwai
Clean up ugly hacks for sync with alsa-lib in pcm_params.h. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-06-22[ALSA] PM support for cs5535audioJaya Kumar
Appended is my patch adding PM support to the cs5535audio driver. I also added the ac97 quirk but it's not yet confirmed which boards need to be in the quirk list. The patch also includes some Kconfig and misc cleanup. Signed-off-by: Jaya Kumar <jayakumar.alsa@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-06-22[ALSA] hda-codec - Add support for Sony Vaio VGN-A790 laptopKenneth Crudup
Added the model entry for Sony Vaio VGN-A790 laptop with ALC260 codec. From: Kenneth Crudup <kenny@panix.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-06-22[ALSA] ice1712 - Provides specified midi port names instead of defaultsAlan Horstmann
Patch provides for the ice1712 card driver to overwrite the midi port name string given by default in mpu401_uart, with one specified in snd_ice1712_card_info. Signed-off-by: Alan Horstmann <gineera@aspect135.co.uk> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-06-22[ALSA] Change seq_midi.c so client name is card, rather than port, specificAlan Horstmann
Change snd_seq_midisynth_register_port() in seq_midi.c so that if a new client is created, the client name string is based on card->shortname not (port-specific) info->name. Signed-off-by: Alan Horstmann <gineera@aspect135.co.uk> Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
