2011-07-23ata: Add and use ata_print_version_onceJoe Perches
Use a single mechanism to show driver version. Reduces text a tiny bit too. Remove uses of static int printed_version Add and use ata_print_version(const struct device *, const char *ver) and ata_print_version_once. $ size drivers/ata/built-in.* text data bss dec hex filename 544969 73893 116584 735446 b38d6 drivers/ata/built-in.allyesconfig.ata.o 543870 73893 116592 734355 b34ad drivers/ata/built-in.allyesconfig.print_once.o 141328 14689 4220 160237 271ed drivers/ata/built-in.defconfig.ata.o 141212 14689 4220 160121 27179 drivers/ata/built-in.defconfig.print_once.o Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2011-07-23ata: Convert ata_<foo>_printk(KERN_<LEVEL> to ata_<foo>_<level>Joe Perches
Saves text by removing nearly duplicated text format strings by creating ata_<foo>_printk functions and printf extension %pV. ata defconfig size shrinks ~5% (~8KB), allyesconfig ~2.5% (~13KB) Format string duplication comes from: #define ata_link_printk(link, lv, fmt, args...) do { \ if (sata_pmp_attached((link)->ap) || (link)->ap->slave_link) \ printk("%sata%u.%02u: "fmt, lv, (link)->ap->print_id, \ (link)->pmp , ##args); \ else \ printk("%sata%u: "fmt, lv, (link)->ap->print_id , ##args); \ } while(0) Coalesce long formats. $ size drivers/ata/built-in.* text data bss dec hex filename 544969 73893 116584 735446 b38d6 drivers/ata/built-in.allyesconfig.ata.o 558429 73893 117864 750186 b726a drivers/ata/built-in.allyesconfig.dev_level.o 141328 14689 4220 160237 271ed drivers/ata/built-in.defconfig.ata.o 149567 14689 4220 168476 2921c drivers/ata/built-in.defconfig.dev_level.o Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2011-07-23ata: Convert dev_printk(KERN_<LEVEL> to dev_<level>(Joe Perches
Saves a bit of text as the call takes fewer args. Coalesce a few formats. Convert a few bare printks to pr_cont. $ size drivers/ata/built-in.o* text data bss dec hex filename 558429 73893 117864 750186 b726a drivers/ata/built-in.o.allyesconfig.new 559574 73893 117888 751355 b76fb drivers/ata/built-in.o.allyesconfig.old 149567 14689 4220 168476 2921c drivers/ata/built-in.o.defconfig.new 149851 14689 4220 168760 29338 drivers/ata/built-in.o.defconfig.old Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2011-07-21Linux 3.0v3.0Linus Torvalds
2011-07-21Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jwessel/linux-2.6-kgdb * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jwessel/linux-2.6-kgdb: sparc,kgdbts: fix compile regression with kgdb test suite
2011-07-21sparc,kgdbts: fix compile regression with kgdb test suiteJason Wessel
Commit 63ab25ebbc (kgdbts: unify/generalize gdb breakpoint adjustment) introduced a compile regression on sparc. kgdbts.c: In function 'check_and_rewind_pc': kgdbts.c:307: error: implicit declaration of function 'instruction_pointer_set' Simply add the correct macro definition for instruction pointer on the Sparc architecture. Signed-off-by: Jason Wessel <jason.wessel@windriver.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Acked-by: David S. Miller <davem@davemloft.net>
2011-07-21Merge git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6: CIFS: Fix wrong length in cifs_iovec_read
2011-07-21Merge branch 'x86-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86: Make Dell Latitude E6420 use reboot=pci x86: Make Dell Latitude E5420 use reboot=pci
2011-07-21x86: Make Dell Latitude E6420 use reboot=pciH. Peter Anvin
Yet another variant of the Dell Latitude series which requires reboot=pci. From the E5420 bug report by Daniel J Blueman: > The E6420 is affected also (same platform, different casing and > features), which provides an external confirmation of the issue; I can > submit a patch for that later or include it if you prefer: > http://linux.koolsolutions.com/2009/08/04/howto-fix-linux-hangfreeze-during-reboots-and-restarts/ Reported-by: Daniel J Blueman <daniel.blueman@gmail.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com> Cc: <stable@kernel.org>
2011-07-21x86: Make Dell Latitude E5420 use reboot=pciDaniel J Blueman
Rebooting on the Dell E5420 often hangs with the keyboard or ACPI methods, but is reliable via the PCI method. [ hpa: this was deferred because we believed for a long time that the recent reshuffling of the boot priorities in commit 660e34cebf0a11d54f2d5dd8838607452355f321 fixed this platform. Unfortunately that turned out to be incorrect. ] Signed-off-by: Daniel J Blueman <daniel.blueman@gmail.com> Link: http://lkml.kernel.org/r/1305248699-2347-1-git-send-email-daniel.blueman@gmail.com Signed-off-by: H. Peter Anvin <hpa@zytor.com> Cc: <stable@kernel.org>
2011-07-21Merge branch 'drm-intel-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/keithp/linux-2.6 * 'drm-intel-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/keithp/linux-2.6: drm/i915: Fix unfenced alignment on pre-G33 hardware drm/i915: Add quirk to disable SSC on Lenovo U160 LVDS
2011-07-21vfs: drop conditional inode prefetch in __do_lookup_rcuLinus Torvalds
It seems to hurt performance in real life. Yes, the inode will be used later, but the conditional doesn't seem to predict all that well (negative dentries are not uncommon) and it looks like the cost of prefetching is simply higher than depending on the cache doing the right thing. As usual. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-21FS-Cache: Fix __fscache_uncache_all_inode_pages()'s outer loopJan Beulich
The compiler, at least for ix86 and m68k, validly warns that the comparison: next <= (loff_t)-1 is always true (and it's always true also for x86-64 and probably all other arches - as long as pgoff_t isn't wider than loff_t). The intention appears to be to avoid wrapping of "next", so rather than eliminating the pointless comparison, fix the loop to indeed get exited when "next" would otherwise wrap. On m68k the following warning is observed: fs/fscache/page.c: In function '__fscache_uncache_all_inode_pages': fs/fscache/page.c:979: warning: comparison is always false due to limited range of data type Reported-by: Geert Uytterhoeven <geert@linux-m68k.org> Reported-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: David Howells <dhowells@redhat.com> Cc: Suresh Jayaraman <sjayaraman@suse.de> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-21CIFS: Fix wrong length in cifs_iovec_readPavel Shilovsky
Signed-off-by: Pavel Shilovsky <piastryyy@gmail.com> Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-07-20Merge branch 'core-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: signal: align __lock_task_sighand() irq disabling and RCU softirq,rcu: Inform RCU of irq_exit() activity sched: Add irq_{enter,exit}() to scheduler_ipi() rcu: protect __rcu_read_unlock() against scheduler-using irq handlers rcu: Streamline code produced by __rcu_read_unlock() rcu: Fix RCU_BOOST race handling current->rcu_read_unlock_special rcu: decrease rcu_report_exp_rnp coupling with scheduler
2011-07-20Merge branch 'sched-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: sched: Avoid creating superfluous NUMA domains on non-NUMA systems sched: Allow for overlapping sched_domain spans sched: Break out cpu_power from the sched_group structure
2011-07-20Merge branch 'x86-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86. reboot: Make Dell Latitude E6320 use reboot=pci x86, doc only: Correct real-mode kernel header offset for init_size x86: Disable AMD_NUMA for 32bit for now
2011-07-20Merge branch 'rcu/urgent' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/paulmck/linux-2.6-rcu into core/urgent
2011-07-20signal: align __lock_task_sighand() irq disabling and RCUPaul E. McKenney
The __lock_task_sighand() function calls rcu_read_lock() with interrupts and preemption enabled, but later calls rcu_read_unlock() with interrupts disabled. It is therefore possible that this RCU read-side critical section will be preempted and later RCU priority boosted, which means that rcu_read_unlock() will call rt_mutex_unlock() in order to deboost itself, but with interrupts disabled. This results in lockdep splats, so this commit nests the RCU read-side critical section within the interrupt-disabled region of code. This prevents the RCU read-side critical section from being preempted, and thus prevents the attempt to deboost with interrupts disabled. It is quite possible that a better long-term fix is to make rt_mutex_unlock() disable irqs when acquiring the rt_mutex structure's ->wait_lock. Signed-off-by: Paul E. McKenney <paul.mckenney@linaro.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2011-07-20softirq,rcu: Inform RCU of irq_exit() activityPeter Zijlstra
The rcu_read_unlock_special() function relies on in_irq() to exclude scheduler activity from interrupt level. This fails because exit_irq() can invoke the scheduler after clearing the preempt_count() bits that in_irq() uses to determine that it is at interrupt level. This situation can result in failures as follows: $task IRQ SoftIRQ rcu_read_lock() /* do stuff */ <preempt> |= UNLOCK_BLOCKED rcu_read_unlock() --t->rcu_read_lock_nesting irq_enter(); /* do stuff, don't use RCU */ irq_exit(); sub_preempt_count(IRQ_EXIT_OFFSET); invoke_softirq() ttwu(); spin_lock_irq(&pi->lock) rcu_read_lock(); /* do stuff */ rcu_read_unlock(); rcu_read_unlock_special() rcu_report_exp_rnp() ttwu() spin_lock_irq(&pi->lock) /* deadlock */ rcu_read_unlock_special(t); Ed can simply trigger this 'easy' because invoke_softirq() immediately does a ttwu() of ksoftirqd/# instead of doing the in-place softirq stuff first, but even without that the above happens. Cure this by also excluding softirqs from the rcu_read_unlock_special() handler and ensuring the force_irqthreads ksoftirqd/# wakeup is done from full softirq context. [ Alternatively, delaying the ->rcu_read_lock_nesting decrement until after the special handling would make the thing more robust in the face of interrupts as well. And there is a separate patch for that. ] Cc: Thomas Gleixner <tglx@linutronix.de> Reported-and-tested-by: Ed Tomlinson <edt@aei.ca> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2011-07-20sched: Add irq_{enter,exit}() to scheduler_ipi()Peter Zijlstra
Ensure scheduler_ipi() calls irq_{enter,exit} when it does some actual work. Traditionally we never did any actual work from the resched IPI and all magic happened in the return from interrupt path. Now that we do do some work, we need to ensure irq_{enter,exit} are called so that we don't confuse things. This affects things like timekeeping, NO_HZ and RCU, basically everything with a hook in irq_enter/exit. Explicit examples of things going wrong are: sched_clock_cpu() -- has a callback when leaving NO_HZ state to take a new reading from GTOD and TSC. Without this callback, time is stuck in the past. RCU -- needs in_irq() to work in order to avoid some nasty deadlocks Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2011-07-20rcu: protect __rcu_read_unlock() against scheduler-using irq handlersPaul E. McKenney
The addition of RCU read-side critical sections within runqueue and priority-inheritance lock critical sections introduced some deadlock cycles, for example, involving interrupts from __rcu_read_unlock() where the interrupt handlers call wake_up(). This situation can cause the instance of __rcu_read_unlock() invoked from interrupt to do some of the processing that would otherwise have been carried out by the task-level instance of __rcu_read_unlock(). When the interrupt-level instance of __rcu_read_unlock() is called with a scheduler lock held from interrupt-entry/exit situations where in_irq() returns false, deadlock can result. This commit resolves these deadlocks by using negative values of the per-task ->rcu_read_lock_nesting counter to indicate that an instance of __rcu_read_unlock() is in flight, which in turn prevents instances from interrupt handlers from doing any special processing. This patch is inspired by Steven Rostedt's earlier patch that similarly made __rcu_read_unlock() guard against interrupt-mediated recursion (see https://lkml.org/lkml/2011/7/15/326), but this commit refines Steven's approach to avoid the need for preemption disabling on the __rcu_read_unlock() fastpath and to also avoid the need for manipulating a separate per-CPU variable. This patch avoids need for preempt_disable() by instead using negative values of the per-task ->rcu_read_lock_nesting counter. Note that nested rcu_read_lock()/rcu_read_unlock() pairs are still permitted, but they will never see ->rcu_read_lock_nesting go to zero, and will therefore never invoke rcu_read_unlock_special(), thus preventing them from seeing the RCU_READ_UNLOCK_BLOCKED bit should it be set in ->rcu_read_unlock_special. This patch also adds a check for ->rcu_read_unlock_special being negative in rcu_check_callbacks(), thus preventing the RCU_READ_UNLOCK_NEED_QS bit from being set should a scheduling-clock interrupt occur while __rcu_read_unlock() is exiting from an outermost RCU read-side critical section. Of course, __rcu_read_unlock() can be preempted during the time that ->rcu_read_lock_nesting is negative. This could result in the setting of the RCU_READ_UNLOCK_BLOCKED bit after __rcu_read_unlock() checks it, and would also result it this task being queued on the corresponding rcu_node structure's blkd_tasks list. Therefore, some later RCU read-side critical section would enter rcu_read_unlock_special() to clean up -- which could result in deadlock if that critical section happened to be in the scheduler where the runqueue or priority-inheritance locks were held. This situation is dealt with by making rcu_preempt_note_context_switch() check for negative ->rcu_read_lock_nesting, thus refraining from queuing the task (and from setting RCU_READ_UNLOCK_BLOCKED) if we are already exiting from the outermost RCU read-side critical section (in other words, we really are no longer actually in that RCU read-side critical section). In addition, rcu_preempt_note_context_switch() invokes rcu_read_unlock_special() to carry out the cleanup in this case, which clears out the ->rcu_read_unlock_special bits and dequeues the task (if necessary), in turn avoiding needless delay of the current RCU grace period and needless RCU priority boosting. It is still illegal to call rcu_read_unlock() while holding a scheduler lock if the prior RCU read-side critical section has ever had either preemption or irqs enabled. However, the common use case is legal, namely where then entire RCU read-side critical section executes with irqs disabled, for example, when the scheduler lock is held across the entire lifetime of the RCU read-side critical section. Signed-off-by: Paul E. McKenney <paul.mckenney@linaro.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2011-07-20sched: Avoid creating superfluous NUMA domains on non-NUMA systemsPeter Zijlstra
When creating sched_domains, stop when we've covered the entire target span instead of continuing to create domains, only to later find they're redundant and throw them away again. This avoids single node systems from touching funny NUMA sched_domain creation code and reduces the risks of the new SD_OVERLAP code. Requested-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Anton Blanchard <anton@samba.org> Cc: mahesh@linux.vnet.ibm.com Cc: benh@kernel.crashing.org Cc: linuxppc-dev@lists.ozlabs.org Link: http://lkml.kernel.org/r/1311180177.29152.57.camel@twins Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-07-20sched: Allow for overlapping sched_domain spansPeter Zijlstra
Allow for sched_domain spans that overlap by giving such domains their own sched_group list instead of sharing the sched_groups amongst each-other. This is needed for machines with more than 16 nodes, because sched_domain_node_span() will generate a node mask from the 16 nearest nodes without regard if these masks have any overlap. Currently sched_domains have a sched_group that maps to their child sched_domain span, and since there is no overlap we share the sched_group between the sched_domains of the various CPUs. If however there is overlap, we would need to link the sched_group list in different ways for each cpu, and hence sharing isn't possible. In order to solve this, allocate private sched_groups for each CPU's sched_domain but have the sched_groups share a sched_group_power structure such that we can uniquely track the power. Reported-and-tested-by: Anton Blanchard <anton@samba.org> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Link: http://lkml.kernel.org/n/tip-08bxqw9wis3qti9u5inifh3y@git.kernel.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-07-20sched: Break out cpu_power from the sched_group structurePeter Zijlstra
In order to prepare for non-unique sched_groups per domain, we need to carry the cpu_power elsewhere, so put a level of indirection in. Reported-and-tested-by: Anton Blanchard <anton@samba.org> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Link: http://lkml.kernel.org/n/tip-qkho2byuhe4482fuknss40ad@git.kernel.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-07-19Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: ceph: fix file mode calculation
2011-07-19Merge branch 'fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc * 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc: davinci: DM365 EVM: fix video input mux bits ARM: davinci: Check for NULL return from irq_alloc_generic_chip arm: davinci: Fix low level gpio irq handlers' argument
2011-07-19vmscan: fix a livelock in kswapdShaohua Li
I'm running a workload which triggers a lot of swap in a machine with 4 nodes. After I kill the workload, I found a kswapd livelock. Sometimes kswapd3 or kswapd2 are keeping running and I can't access filesystem, but most memory is free. This looks like a regression since commit 08951e545918c159 ("mm: vmscan: correct check for kswapd sleeping in sleeping_prematurely"). Node 2 and 3 have only ZONE_NORMAL, but balance_pgdat() will return 0 for classzone_idx. The reason is end_zone in balance_pgdat() is 0 by default, if all zones have watermark ok, end_zone will keep 0. Later sleeping_prematurely() always returns true. Because this is an order 3 wakeup, and if classzone_idx is 0, both balanced_pages and present_pages in pgdat_balanced() are 0. We add a special case here. If a zone has no page, we think it's balanced. This fixes the livelock. Signed-off-by: Shaohua Li <shaohua.li@intel.com> Acked-by: Mel Gorman <mgorman@suse.de> Cc: Minchan Kim <minchan.kim@gmail.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-19fs/libfs.c: fix simple_attr_write() on 32bit machinesAkinobu Mita
Assume that /sys/kernel/debug/dummy64 is debugfs file created by debugfs_create_x64(). # cd /sys/kernel/debug # echo 0x1234567812345678 > dummy64 # cat dummy64 0x0000000012345678 # echo 0x80000000 > dummy64 # cat dummy64 0xffffffff80000000 A value larger than INT_MAX cannot be written to the debugfs file created by debugfs_create_u64 or debugfs_create_x64 on 32bit machine. Because simple_attr_write() uses simple_strtol() for the conversion. To fix this, use simple_strtoll() instead. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: vfs: fix race in rcu lookup of pruned dentry Fix cifs_get_root() [ Edited the last commit to get rid of a 'unused variable "seq"' warning due to Al editing the patch. - Linus ]
2011-07-19vfs: fix race in rcu lookup of pruned dentryLinus Torvalds
Don't update *inode in __follow_mount_rcu() until we'd verified that there is mountpoint there. Kudos to Hugh Dickins for catching that one in the first place and eventually figuring out the solution (and catching a braino in the earlier version of patch). Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-19rcu: Streamline code produced by __rcu_read_unlock()Paul E. McKenney
Given some common flag combinations, particularly -Os, gcc will inline rcu_read_unlock_special() despite its being in an unlikely() clause. Use noinline to prohibit this misoptimization. In addition, move the second barrier() in __rcu_read_unlock() so that it is not on the common-case code path. This will allow the compiler to generate better code for the common-case path through __rcu_read_unlock(). Suggested-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
2011-07-19rcu: Fix RCU_BOOST race handling current->rcu_read_unlock_specialPaul E. McKenney
The RCU_BOOST commits for TREE_PREEMPT_RCU introduced an other-task write to a new RCU_READ_UNLOCK_BOOSTED bit in the task_struct structure's ->rcu_read_unlock_special field, but, as noted by Steven Rostedt, without correctly synchronizing all accesses to ->rcu_read_unlock_special. This could result in bits in ->rcu_read_unlock_special being spuriously set and cleared due to conflicting accesses, which in turn could result in deadlocks between the rcu_node structure's ->lock and the scheduler's rq and pi locks. These deadlocks would result from RCU incorrectly believing that the just-ended RCU read-side critical section had been preempted and/or boosted. If that RCU read-side critical section was executed with either rq or pi locks held, RCU's ensuing (incorrect) calls to the scheduler would cause the scheduler to attempt to once again acquire the rq and pi locks, resulting in deadlock. More complex deadlock cycles are also possible, involving multiple rq and pi locks as well as locks from multiple rcu_node structures. This commit fixes synchronization by creating ->rcu_boosted field in task_struct that is accessed and modified only when holding the ->lock in the rcu_node structure on which the task is queued (on that rcu_node structure's ->blkd_tasks list). This results in tasks accessing only their own current->rcu_read_unlock_special fields, making unsynchronized access once again legal, and keeping the rcu_read_unlock() fastpath free of atomic instructions and memory barriers. The reason that the rcu_read_unlock() fastpath does not need to access the new current->rcu_boosted field is that this new field cannot be non-zero unless the RCU_READ_UNLOCK_BLOCKED bit is set in the current->rcu_read_unlock_special field. Therefore, rcu_read_unlock() need only test current->rcu_read_unlock_special: if that is zero, then current->rcu_boosted must also be zero. This bug does not affect TINY_PREEMPT_RCU because this implementation of RCU accesses current->rcu_read_unlock_special with irqs disabled, thus preventing races on the !SMP systems that TINY_PREEMPT_RCU runs on. Maybe-reported-by: Dave Jones <davej@redhat.com> Maybe-reported-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Reported-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Paul E. McKenney <paul.mckenney@linaro.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Steven Rostedt <rostedt@goodmis.org>
2011-07-19rcu: decrease rcu_report_exp_rnp coupling with schedulerPaul E. McKenney
PREEMPT_RCU read-side critical sections blocking an expedited grace period invoke rcu_report_exp_rnp(). When the last such critical section has completed, rcu_report_exp_rnp() invokes the scheduler to wake up the task that invoked synchronize_rcu_expedited() -- needlessly holding the root rcu_node structure's lock while doing so, thus needlessly providing a way for RCU and the scheduler to deadlock. This commit therefore releases the root rcu_node structure's lock before calling wake_up(). Reported-by: Ed Tomlinson <edt@aei.ca> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2011-07-19ceph: fix file mode calculationSage Weil
open(2) must always include one of O_RDONLY, O_WRONLY, or O_RDWR. No need for any O_APPEND special case. Passing O_WRONLY|O_RDWR is undefined according to the man page, but the Linux VFS interprets this as O_RDWR, so we'll do the same. This fixes open(2) with flags O_RDWR|O_APPEND, which was incorrectly being translated to readonly. Reported-by: Fyodor Ustinov <ufm@ufm.su> Signed-off-by: Sage Weil <sage@newdream.net>
2011-07-19davinci: DM365 EVM: fix video input mux bitsJon Povey
Video input mux settings for tvp7002 and imager inputs were swapped. Comment was correct. Tested on EVM with tvp7002 input. Signed-off-by: Jon Povey <jon.povey@racelogic.co.uk> Acked-by: Manjunath Hadli <manjunath.hadli@ti.com> Cc: stable@kernel.org Signed-off-by: Sekhar Nori <nsekhar@ti.com>
2011-07-19ARM: davinci: Check for NULL return from irq_alloc_generic_chipTodd Poynor
Avoid NULL dereference of irq_alloc_generic_chip return in low memory conditions. Signed-off-by: Todd Poynor <toddpoynor@google.com> Signed-off-by: Sekhar Nori <nsekhar@ti.com>
2011-07-18drm/i915: Fix unfenced alignment on pre-G33 hardwareChris Wilson
Align unfenced buffers on older hardware to the power-of-two object size. The docs suggest that it should be possible to align only to a power-of-two tile height, but using the already computed fence size is easier and always correct. We also have to make sure that we unbind misaligned buffers upon tiling changes. In order to prevent a repetition of this bug, we change the interface to the alignment computation routines to force the caller to provide the requested alignment and size of the GTT binding rather than assume the current values on the object. Reported-and-tested-by: Sitosfe Wheeler <sitsofe@yahoo.com> Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=36326 Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Cc: stable@kernel.org Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Keith Packard <keithp@keithp.com>
2011-07-18Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: pppoe: Must flush connections when MAC address changes too. include/linux/sdla.h: remove the prototype of sdla() tulip: dmfe: Remove old log spamming pr_debugs
2011-07-18pppoe: Must flush connections when MAC address changes too.David S. Miller
Kernel bugzilla: 39252 Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-18include/linux/sdla.h: remove the prototype of sdla()WANG Cong
`make headers_check` complains that linux-2.6/usr/include/linux/sdla.h:116: userspace cannot reference function or variable defined in the kernel this is due to that there is no such a kernel function, void sdla(void *cfg_info, char *dev, struct frad_conf *conf, int quiet); I don't know why we have it in a kernel header, so remove it. Signed-off-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-18Fix cifs_get_root()Al Viro
Add missing ->i_mutex, convert to lookup_one_len() instead of (broken) open-coded analog, cope with getting something like a//b as relative pathname. Simplify the hell out of it, while we are there... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Reviewed-by: Jeff Layton <jlayton@redhat.com>
2011-07-18tulip: dmfe: Remove old log spamming pr_debugsJoe Perches
Commit 726b65ad444d ("tulip: Convert uses of KERN_DEBUG") enabled some old previously inactive uses of pr_debug converted by commit dde7c8ef1679 ("tulip/dmfe.c: Use dev_<level> and pr_<level>"). Remove these pr_debugs. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-18si4713-i2c: avoid potential buffer overflow on si4713Mauro Carvalho Chehab
While compiling it with Fedora 15, I noticed this issue: inlined from ‘si4713_write_econtrol_string’ at drivers/media/radio/si4713-i2c.c:1065:24: arch/x86/include/asm/uaccess_32.h:211:26: error: call to ‘copy_from_user_overflow’ declared with attribute error: copy_from_user() buffer size is not provably correct Cc: stable@kernel.org Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Acked-by: Sakari Ailus <sakari.ailus@maxwell.research.nokia.com> Acked-by: Eduardo Valentin <edubezval@gmail.com> Reviewed-by: Eugene Teo <eugeneteo@kernel.sg> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-18Merge branch 'fix/asoc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'fix/asoc' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: ASoC: Correct WM8994 MICBIAS supply widget hookup ASoC: Fix shift in WM8958 accessory detection default implementation ASoC: sh: fsi-hdmi: fixup snd_soc_card name ASoC: sh: fsi-da7210: fixup snd_soc_card name ASoC: sh: fsi-ak4642: fixup snd_soc_card name
2011-07-18Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: hppfs_lookup(): don't open-code lookup_one_len() hppfs: fix dentry leak cramfs: get_cramfs_inode() returns ERR_PTR() on failure ufs should use d_splice_alias() fix exofs ->get_parent() ceph analog of cifs build_path_from_dentry() race fix cifs: build_path_from_dentry() race fix
2011-07-18Merge branch 'hwmon-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging * 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging: hwmon: (max1111) Fix race condition causing NULL pointer exception hwmon: (it87) Fix label group removal hwmon: (asus_atk0110) Fix memory leak
2011-07-17hppfs_lookup(): don't open-code lookup_one_len()Al Viro
... and it's getting it wrong, too - missing ->d_revalidate() calls when it's dealing with filesystem (procfs) that has non-trivial ->d_revalidate()... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-17hppfs: fix dentry leakAl Viro
2011-07-17cramfs: get_cramfs_inode() returns ERR_PTR() on failureAl Viro
... and we want to report these failures in ->lookup() anyway. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
