2006-10-03Fix typos in Documentation/: 'Q'-'R'Matt LaPlante
This patch fixes typos in various Documentation txts. The patch addresses some words starting with the letters 'Q'-'R'. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Fix "can not" in Documentation and KconfigMatt LaPlante
Randy brought it to my attention that in proper english "can not" should always be written "cannot". I donot see any reason to argue, even if I mightnot understand why this rule exists. This patch fixes "can not" in several Documentation files as well as three Kconfigs. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Fix typos in Documentation/: 'N'-'P'Matt LaPlante
This patch fixes typos in various Documentation txts. The patch addresses some words starting with the letters 'N'-'P'. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Fix typos in Documentation/: 'H'-'M'Matt LaPlante
This patch fixes typos in various Documentation txts. The patch addresses some words starting with the letters 'H'-'M'. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Fix typos in Documentation/: 'F'-'G'Matt LaPlante
This patch fixes typos in various Documentation txts. The patch addresses some words starting with the letters 'F'-'G'. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Fix typos in Documentation/: 'D'-'E'Matt LaPlante
This patch fixes typos in various Documentation txts. This patch addresses some words starting with the letters 'D'-'E'. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Fix typos in Documentation/: 'B'-'C'Matt LaPlante
This patch fixes typos in various Documentation txts. This patch addresses some words starting with the letters 'B'-'C'. There are also a few grammar fixes thrown in for Randy. ;) Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Fix some typos in Documentation/: 'A'Matt LaPlante
This patch fixes typos in various Documentation txts. This patch addresses some words starting with the letter 'A'. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Still more typo fixesMatt LaPlante
2006-10-03more misc typo fixesMatt LaPlante
2006-10-03Fix several typos in drivers/Matt LaPlante
2006-10-03fix drivers/acpi/Kconfig typosMatt LaPlante
2006-10-03fix an arch/alpha/Kconfig typoMatt LaPlante
2006-10-03Typos in fs/KconfigMatt LaPlante
2006-10-03Attack of "the the"s in archMatt LaPlante
The patch below corrects multiple occurances of "the the" typos across several files, both in source comments and KConfig files. There is no actual code changed, only text. Note this only affects the /arch directory, and I believe I could find many more elsewhere. :) Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03remove mentionings of devfs in documentationAdrian Bunk
Now that devfs is removed, there's no longer any need to document how to do this or that with devfs. This patch includes some improvements by Joe Perches. Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03input: remove obsolete contact informationAdrian Bunk
This patch removes some obsolete contact information from Documentation/input/input.txt Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03x86: Fix booting with "no387 nofxsr"Linus Torvalds
Jesper Juhl reported that testing the software math-emulation by forcing "no387" doesn't work on modern CPU's. The reason was two-fold: - you also need to pass in "nofxsr" to make sure that we not only don't touch the old i387 legacy hardware, it also needs to disable the modern XMM/FXSR sequences - "nofxsr" didn't actually clear the capability bits immediately, leaving the early boot sequence still using FXSR until we got to the identify_cpu() stage. This fixes the "nofxsr" flag to take effect immediately on the boot CPU. Debugging by Randy Dunlap Acked-by: Randy Dunlap <rdunlap@xenotime.net> Cc: Jesper Juhl <jesper.juhl@gmail.com> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-03Merge branch 'devel' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'devel' of master.kernel.org:/home/rmk/linux-2.6-arm: [ARM] 3848/1: pxafb: Add option of fixing video modes and spitz QVGA mode support [ARM] 3880/1: remove the last trace of iop31x support [ARM] 3879/1: ep93xx: instantiate platform devices for ep93xx ethernet [ARM] 3809/3: get rid of 4 megabyte kernel image size limit [ARM] Fix XIP_KERNEL build error in arch/arm/mm/mmu.c [ARM] 3874/1: Remove leftover usage of asm/timeofday.h
2006-10-03Merge branch 'devel' of master.kernel.org:/home/rmk/linux-2.6-serialLinus Torvalds
* 'devel' of master.kernel.org:/home/rmk/linux-2.6-serial: (21 commits) [SERIAL] add PNP IDs for FPI based touchscreens [SERIAL] Magic SysRq SAK does nothing on serial consoles [SERIAL] tickle NMI watchdog on serial output. [SERIAL] Fix oops when removing suspended serial port [SERIAL] Fix resume handling bug [SERIAL] Remove wrong asm/serial.h inclusions [SERIAL] CONFIG_PM=n slim: drivers/serial/8250_pci.c [SERIAL] OMAP1510 serial fix for 115200 baud [SERIAL] returning proper error from serial core driver [SERIAL] Make uart_line_info() correctly tell MMIO from I/O port [SERIAL] suspend/resume handlers don't have level arg anymore [SERIAL] 8250 resourse management fixes [SERIAL] serial_cs: Add quirk for brainboxes 2-port RS232 card [SERIAL] serial_cs: handle Nokia multi->single port bodge via config quirk [SERIAL] serial_cs: add configuration quirk [SERIAL] serial_cs: Convert Oxford 950 / Possio GCC wakeup quirk [SERIAL] serial_cs: convert IBM post-init handling to a quirk [SERIAL] serial_cs: allow wildcarded quirks [SERIAL] serial_cs: convert multi-port table to quirk table [SERIAL] serial_cs: Use clean up multiport card detection ...
2006-10-03Merge master.kernel.org:/pub/scm/linux/kernel/git/lethal/sh-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/lethal/sh-2.6: sh: Fixup __raw_read_trylock(). sh: Kill off remaining config.h references. sh: Initial gitignore list sh: build fixes for defconfigs. sh: Kill off more dead headers. sh: Set pclk default for SH7705. sh: defconfig updates.
2006-10-03Merge master.kernel.org:/pub/scm/linux/kernel/git/lethal/sh64-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/lethal/sh64-2.6: sh64: Remove me from sh64 maintainers. sh64: Update cayman defconfig.
2006-10-03Merge master.kernel.org:/pub/scm/linux/kernel/git/davem/sparc-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/davem/sparc-2.6: [SPARC64]: Update defconfig. [SPARC64]: Do not include compat.h from asm-sparc64/signal.h any more. [SPARC64]: Move signal compat bits to new header file.
2006-10-03Merge git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpcLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: (29 commits) [POWERPC] Fix rheap alignment problem [POWERPC] Use check_legacy_ioport() for ISAPnP [POWERPC] Avoid NULL pointer in gpio1_interrupt [POWERPC] Enable generic rtc hook for the MPC8349 mITX [POWERPC] Add powerpc get/set_rtc_time interface to new generic rtc class [POWERPC] Create a "wrapper" script and use it in arch/powerpc/boot [POWERPC] fix spin lock nesting in hvc_iseries [POWERPC] EEH failure to mark pci slot as frozen. [POWERPC] update powerpc defconfig files after libata kconfig breakage [POWERPC] enable sysrq in pmac32_defconfig [POWERPC] UPIO_TSI cleanup [POWERPC] rewrite mkprep and mkbugboot in sane C [POWERPC] maple/pci iomem annotations [POWERPC] powerpc oprofile __user annotations [POWERPC] cell spufs iomem annotations [POWERPC] NULL noise removal: spufs [POWERPC] ppc math-emu needs -fno-builtin-fabs for math.c and fabs.c [POWERPC] update mpc8349_itx_defconfig and remove some debug settings [POWERPC] Always call cede in pseries dedicated idle loop [POWERPC] Fix loop logic in irq_alloc_virt() ...
2006-10-03Merge git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuildLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild: kbuild: trivial documentation fixes kconfig: fix saving alternate kconfig file in parent dir kbuild: make modpost processing configurable kconfig/menuconfig: do not let ncurses clutter screen on exit kconfig/lxdialog: clear long menu lines kbuild: do not build mconf & lxdialog unless needed kconfig/lxdialog: fix make mrproper kconfig/lxdialog: support resize kconfig/lxdialog: let <ESC><ESC> behave as expected kconfig/menuconfig: lxdialog is now built-in kconfig/lxdialog: add a new theme bluetitle which is now default kconfig/lxdialog: add support for color themes and add blackbg theme kconfig/lxdialog: refactor color support
2006-10-03[PATCH] pr_debug: check pr_debug() argumentsZach Brown
check pr_debug() arguments When DEBUG isn't defined pr_debug() is defined away as an empty macro. By throwing away the arguments we allow completely incorrect code to build. Instead let's make it an empty inline which checks arguments and mark it so gcc can check the format specification. This results in a seemingly insignificant code size increase. A x86-64 allyesconfig: text data bss dec hex filename 25354768 7191098 4854720 37400586 23ab00a vmlinux.before 25354945 7191138 4854720 37400803 23ab0e3 vmlinux Signed-off-by: Zach Brown <zach.brown@oracle.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-03[PATCH] isdn: more pr_debug() fixesAndrew Morton
drivers/isdn/sc/event.c: In function 'indicate_status': drivers/isdn/sc/event.c:49: error: 'events' undeclared (first use in this function) drivers/isdn/sc/event.c:49: error: (Each undeclared identifier is reported only once drivers/isdn/sc/event.c:49: error: for each function it appears in.) drivers/isdn/sc/event.c:49: warning: format '%d' expects type 'int', but argument 4 has type 'ulong' drivers/isdn/sc/interrupt.c: In function 'interrupt_handler': drivers/isdn/sc/interrupt.c:97: warning: format '%x' expects type 'unsigned int', but argument 4 has type 'long unsigned int' drivers/isdn/sc/timer.c: In function 'check_reset': drivers/isdn/sc/timer.c:80: warning: format '%d' expects type 'int', but argument 3 has type 'long unsigned int' Acked-by: Karsten Keil <kkeil@suse.de> Cc: Zach Brown <zach.brown@oracle.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-03[PATCH] isdn-debug-build-fixAndrew Morton
When pr_debug() is enabled: drivers/isdn/sc/command.c: In function 'command': drivers/isdn/sc/command.c:107: error: 'commands' undeclared (first use in this function) drivers/isdn/sc/command.c:107: error: (Each undeclared identifier is reported only once drivers/isdn/sc/command.c:107: error: for each function it appears in.) drivers/isdn/sc/command.c:122: warning: format '%x' expects type 'unsigned int', but argument 3 has type 'long unsigned int' drivers/isdn/sc/command.c: In function 'dial': drivers/isdn/sc/command.c:199: warning: format '%d' expects type 'int', but argument 4 has type 'long unsigned int' drivers/isdn/sc/command.c: In function 'answer': drivers/isdn/sc/command.c:221: warning: format '%s' expects type 'char *', but argument 3 has type 'long unsigned int' drivers/isdn/sc/command.c: In function 'hangup': drivers/isdn/sc/command.c:244: warning: format '%d' expects type 'int', but argument 3 has type 'long unsigned int' drivers/isdn/sc/command.c: In function 'setl2': drivers/isdn/sc/command.c:265: error: 'l2protos' undeclared (first use in this function) drivers/isdn/sc/command.c: In function 'setl3': drivers/isdn/sc/command.c:297: error: 'l3protos' undeclared (first use in this function) drivers/isdn/sc/command.c:297: warning: format '%d' expects type 'int', but argument 3 has type 'long unsigned int' drivers/isdn/sc/command.c: In function 'acceptb': drivers/isdn/sc/command.c:315: warning: format '%d' expects type 'int', but argument 3 has type 'long unsigned int' drivers/isdn/sc/command.c: In function 'clreaz': drivers/isdn/sc/command.c:330: warning: format '%d' expects type 'int', but argument 3 has type 'long unsigned int' drivers/isdn/sc/command.c: In function 'seteaz': drivers/isdn/sc/command.c:345: warning: format '%d' expects type 'int', but argument 3 has type 'long unsigned int' Cc: Zach Brown <zach.brown@oracle.com> Acked-by: Karsten Keil <kkeil@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-03[PATCH] arm build fail: vfpsingle.cFrederik Deweerdt
It looks like Zach Brown's patch pr_debug-check-pr_debug-arguments worked as inteded. That is, it doesn't "allow completely incorrect code to build." :). The arm build fails with the following message: CC arch/arm/vfp/vfpsingle.o arch/arm/vfp/vfpsingle.c: In function `__vfp_single_normaliseround': arch/arm/vfp/vfpsingle.c:201: error: `func' undeclared (first use in this function) arch/arm/vfp/vfpsingle.c:201: error: (Each undeclared identifier is reported only once arch/arm/vfp/vfpsingle.c:201: error: for each function it appears in.) make[1]: *** [arch/arm/vfp/vfpsingle.o] Error 1 make: *** [arch/arm/vfp] Error 2 The following patch fixes the issue by using func only when DEBUG is defined. Signed-off-by: Frederik Deweerdt <frederik.deweerdt@gmail.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Zach Brown <zach.brown@oracle.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-03[PATCH] pr_debug: trident: use size_t length modifier in pr_debug format ↵Zach Brown
arguments trident: use size_t length modifier in pr_debug format arguments Signed-off-by: Zach Brown <zach.brown@oracle.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-03[PATCH] pr_debug: ifb: replace missing comma to separate pr_debug argumentsZach Brown
ifb: replace missing comma to separate pr_debug arguments Signed-off-by: Zach Brown <zach.brown@oracle.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-03[PATCH] pr_debug: dell_rbu: fix pr_debug argument warningsZach Brown
dell_rbu: fix pr_debug argument warnings Use size_t length modifier when outputting size_t and use %p instead of %lu for 'u8 *'. Signed-off-by: Zach Brown <zach.brown@oracle.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-03[PATCH] pr_debug: tipar: repair nonexistant pr_debug argument useZach Brown
tipar: repair nonexistant pr_debug argument use I guessed what the pr_debug meant by 'data'. Signed-off-by: Zach Brown <zach.brown@oracle.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-03[PATCH] pr_debug: umem: repair nonexistant bh pr_debug referenceZach Brown
umem: repair nonexistant bh pr_debug reference Signed-off-by: Zach Brown <zach.brown@oracle.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-03[PATCH] pr_debug: sysfs: use size_t length modifier in pr_debug format argumentsZach Brown
sysfs: use size_t length modifier in pr_debug format arguments Signed-off-by: Zach Brown <zach.brown@oracle.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-03[PATCH] pr_debug: configfs: use size_t length modifier in pr_debug format ↵Zach Brown
argument configfs: use size_t length modifier in pr_debug format argument Signed-off-by: Zach Brown <zach.brown@oracle.com> Acked-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-03[PATCH] pr_debug: aio: use size_t length modifier in pr_debug format argumentsZach Brown
aio: use size_t length modifier in pr_debug format arguments Signed-off-by: Zach Brown <zach.brown@oracle.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-03[PATCH] md: add error reporting to superblock write failureNeilBrown
Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-03[PATCH] md: allow SET_BITMAP_FILE to work on 64bit kernel with 32bit userspacePaul Clements
2006-10-03[PATCH] md: use ffz instead of find_first_set to convert multiplier to shiftPaul Clements
find_first_set doesn't find the least-significant bit on bigendian machines, so it is really wrong to use it. ffs is closer, but takes an 'int' and we have a 'unsigned long'. So use ffz(~X) to convert a chunksize into a chunkshift. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-03[PATCH] md: remove 'experimental' classification from raid5 reshapeNeilBrown
I have had enough success reports not to believe that this is safe for 2.6.19. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-03[PATCH] md: remove MAX_MD_DEVS which is an arbitrary limitNeilBrown
Once upon a time we needed to fixed limit to the number of md devices, probably because we preallocated some array. This need no longer exists, but we still have an arbitrary limit. So remove MAX_MD_DEVS and allow as many devices as we can fit into the 'minor' part of a device number. Also remove some useless noise at init time (which reports MAX_MD_DEVS) and remove MD_THREAD_NAME_MAX which hasn't been used for a while. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-03[PATCH] md: fix duplicity of levels in md.txtNeilBrown
md.txt has two sections describing the 'level' sysfs attribute, and some of the text is out-of-date. So make just one section, and make it right. Cc: Christian Kujau <evil@g-house.de> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-03[PATCH] md: make messages about resync/recovery etc more specificNeilBrown
It is possible to request a 'check' of an md/raid array where the whole array is read and consistancies are reported. This uses the same mechanisms as 'resync' and so reports in the kernel logs that a resync is being started. This understandably confuses/worries people. Also the text in /proc/mdstat suggests a 'resync' is happen when it is just a check. This patch changes those messages to be more specific about what is happening. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-03[PATCH] md: add a ->congested_fn function for raid5/6NeilBrown
This is very different from other raid levels and all requests go through a 'stripe cache', and it has congestion management already. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-03[PATCH] md: define ->congested_fn for raid1, raid10, and multipathNeilBrown
raid1, raid10 and multipath don't report their 'congested' status through bdi_*_congested, but should. This patch adds the appropriate functions which just check the 'congested' status of all active members (with appropriate locking). raid1 read_balance should be modified to prefer devices where bdi_read_congested returns false. Then we could use the '&' branch rather than the '|' branch. However that should would need some benchmarking first to make sure it is actually a good idea. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-03[PATCH] md: define backing_dev_info.congested_fn for raid0 and linearNeilBrown
Each backing_dev needs to be able to report whether it is congested, either by modulating BDI_*_congested in ->state, or by defining a ->congested_fn. md/raid did neither of these. This patch add a congested_fn which simply checks all component devices to see if they are congested. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-03[PATCH] md: Improve locking around error handlingNeilBrown
The error handling routines don't use proper locking, and so two concurrent errors could trigger a problem. So: - use test-and-set and test-and-clear to synchonise the In_sync bits with the ->degraded count - use the spinlock to protect updates to the degraded count (could use an atomic_t but that would be a bigger change in code, and isn't really justified) - remove un-necessary locking in raid5 Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-03[PATCH] md: Remove working_disks from raid1 state dataNeilBrown
It is equivalent to conf->raid_disks - conf->mddev->degraded. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-03[PATCH] md: Factor out part of raid1d into a separate functionNeilBrown
raid1d has toooo many nested block, so take the fix_read_error functionality out into a separate function. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
