commit 6207119444595d287b1e9e83a2066c17209698f3 upstream.
With this reproducer:
struct sockaddr_alg alg = {
.salg_family = 0x26,
.salg_type = "hash",
.salg_feat = 0xf,
.salg_mask = 0x5,
.salg_name = "digest_null",
int sock, sock2;
sock = socket(AF_ALG, SOCK_SEQPACKET, 0);
bind(sock, (struct sockaddr *)&alg, sizeof(alg));
sock2 = accept(sock, NULL, NULL);
setsockopt(sock, SOL_ALG, ALG_SET_KEY, "\x9b\xca", 2);
accept(sock2, NULL, NULL);
==== 8< ======== 8< ======== 8< ======== 8< ====
one can immediatelly see an UBSAN warning:
UBSAN: Undefined behaviour in crypto/algif_hash.c:187:7
variable length array bound value 0 <= 0
CPU: 0 PID: 15949 Comm: syz-executor Tainted: G E 4.4.30-0-default #1
Call Trace:
[<ffffffff81d598fd>] ? __ubsan_handle_vla_bound_not_positive+0x13d/0x188
[<ffffffff81d597c0>] ? __ubsan_handle_out_of_bounds+0x1bc/0x1bc
[<ffffffffa0e2204d>] ? hash_accept+0x5bd/0x7d0 [algif_hash]
[<ffffffffa0e2293f>] ? hash_accept_nokey+0x3f/0x51 [algif_hash]
[<ffffffffa0e206b0>] ? hash_accept_parent_nokey+0x4a0/0x4a0 [algif_hash]
[<ffffffff8235c42b>] ? SyS_accept+0x2b/0x40
It is a correct warning, as hash state is propagated to accept as zero,
but creating a zero-length variable array is not allowed in C.
Fix this as proposed by Herbert -- do "?: 1" on that site. No sizeof or
similar happens in the code there, so we just allocate one byte even
though we do not use the array.
Cc: Herbert Xu <herbert@gondor.apana.org.au>
Cc: "David S. Miller" <davem@davemloft.net> (maintainer:CRYPTO API)
Reported-by: Sasha Levin <sasha.levin@oracle.com>
commit 8aac7f34369726d1a158788ae8aff3002d5eb528 upstream.
fbcon can deal with vc_hi_font_mask (the upper 256 chars) and adjust
the vc attrs dynamically when vc_hi_font_mask is changed at
fbcon_init(). When the vc_hi_font_mask is set, it remaps the attrs in
the existing console buffer with one bit shift up (for 9 bits), while
it remaps with one bit shift down (for 8 bits) when the value is
cleared. It works fine as long as the font gets updated after fbcon
was initialized.
However, we hit a bizarre problem when the console is switched to
another fb driver (typically from vesafb or efifb to drmfb). At
switching to the new fb driver, we temporarily rebind the console to
the dummy console, then rebind to the new driver. During the
switching, we leave the modified attrs as is. Thus, the new fbcon
takes over the old buffer as if it were to contain 8 bits chars
(although the attrs are still shifted for 9 bits), and effectively
this results in the yellow color texts instead of the original white
color, as found in the bugzilla entry below.
An easy fix for this is to re-adjust the attrs before leaving the
fbcon at con_deinit callback. Since the code to adjust the attrs is
already present in the current fbcon code, in this patch, we simply
factor out the relevant code, and call it from fbcon_deinit().
Bugzilla: https://bugzilla.suse.com/show_bug.cgi?id=1000619
Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
From: Gabriel Krisman Bertazi <krisman@linux.vnet.ibm.com>
[ Upstream commit f209fa03fc9d131b3108c2e4936181eabab87416 ]
During a PCI error recovery, like the ones provoked by EEH in the ppc64
platform, all IO to the device must be blocked while the recovery is
completed. Current 8250_pci implementation only suspends the port
instead of detaching it, which doesn't prevent incoming accesses like
TIOCMGET and TIOCMSET calls from reaching the device. Those end up
racing with the EEH recovery, crashing it. Similar races were also
observed when opening the device and when shutting it down during
recovery.
This patch implements a more robust IO blockage for the 8250_pci
recovery by unregistering the port at the beginning of the procedure and
re-adding it afterwards. Since the port is detached from the uart
layer, we can be sure that no request will make through to the device
during recovery. This is similar to the solution used by the JSM serial
driver.
I thank Peter Hurley <peter@hurleysoftware.com> for valuable input on
this one over one year ago.
Signed-off-by: Gabriel Krisman Bertazi <krisman@linux.vnet.ibm.com>
Signed-off-by: Sumit Semwal <sumit.semwal@linaro.org>
[ Upstream commit 708f5dcc21ae9b35f395865fc154b0105baf4de4 ]
The Dell Latitude 3350's ethernet card attempts to use a reserved
IRQ (18), resulting in ACPI being unable to enable the ethernet.
Adding it to acpi_rev_dmi_table[] helps to work around this problem.
Signed-off-by: Michael Pobega <mpobega@neverware.com>
[ rjw: Changelog ]
[ Upstream commit 9523b9bf6dceef6b0215e90b2348cd646597f796 ]
Precision 5520 and 3520 either hang at login and during suspend or reboot.
It turns out that that adding them to acpi_rev_dmi_table[] helps to work
around those issues.
Signed-off-by: Alex Hung <alex.hung@canonical.com>
[ rjw: Changelog ]
[ Upstream commit e950267ab802c8558f1100eafd4087fd039ad634 ]
Some devices have invalid baSourceID references, causing uvc_scan_chain()
to fail, but if we just take the entities we can find and put them
together in the most sensible chain we can think of, turns out they do
work anyway. Note: This heuristic assumes there is a single chain.
At the time of writing, devices known to have such a broken chain are
- Acer Integrated Camera (5986:055a)
- Realtek rtl157a7 (0bda:57a7)
Signed-off-by: Henrik Ingo <henrik.ingo@avoinelama.fi>
Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
From: Harald Freudenberger <freude@linux.vnet.ibm.com>
[ Upstream commit b3e8652bcbfa04807e44708d4d0c8cdad39c9215 ]
Signed-off-by: Harald Freudenberger <freude@linux.vnet.ibm.com>
From: Mauricio Faria de Oliveira <mauricfo@linux.vnet.ibm.com>
[ Upstream commit 25cdb64510644f3e854d502d69c73f21c6df88a9 ]
The WRITE_SAME commands are not present in the blk_default_cmd_filter
write_ok list, and thus are failed with -EPERM when the SG_IO ioctl()
is executed without CAP_SYS_RAWIO capability (e.g., unprivileged users).
[ sg_io() -> blk_fill_sghdr_rq() > blk_verify_command() -> -EPERM ]
The problem can be reproduced with the sg_write_same command
# sg_write_same --num 1 --xferlen 512 /dev/sda
# capsh --drop=cap_sys_rawio -- -c \
'sg_write_same --num 1 --xferlen 512 /dev/sda'
Write same: pass through os error: Operation not permitted
For comparison, the WRITE_VERIFY command does not observe this problem,
since it is in that list:
'sg_write_verify --num 1 --ilen 512 --lba 0 /dev/sda'
So, this patch adds the WRITE_SAME commands to the list, in order
for the SG_IO ioctl to finish successfully:
That case happens to be exercised by QEMU KVM guests with 'scsi-block' devices
(qemu "-device scsi-block" [1], libvirt "<disk type='block' device='lun'>" [2]),
which employs the SG_IO ioctl() and runs as an unprivileged user (libvirt-qemu).
In that scenario, when a filesystem (e.g., ext4) performs its zero-out calls,
which are translated to write-same calls in the guest kernel, and then into
SG_IO ioctls to the host kernel, SCSI I/O errors may be observed in the guest:
[...] sd 0:0:0:0: [sda] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[...] sd 0:0:0:0: [sda] tag#0 Sense Key : Aborted Command [current]
[...] sd 0:0:0:0: [sda] tag#0 Add. Sense: I/O process terminated
[...] sd 0:0:0:0: [sda] tag#0 CDB: Write Same(10) 41 00 01 04 e0 78 00 00 08 00
[...] blk_update_request: I/O error, dev sda, sector 17096824
Links:
[1] http://git.qemu.org/?p=qemu.git;a=commit;h=336a6915bc7089fb20fea4ba99972ad9a97c5f52
[2] https://libvirt.org/formatdomain.html#elementsDisks (see 'disk' -> 'device')
Signed-off-by: Mauricio Faria de Oliveira <mauricfo@linux.vnet.ibm.com>
Signed-off-by: Brahadambal Srinivasan <latha@linux.vnet.ibm.com>
Reported-by: Manjunatha H R <manjuhr1@in.ibm.com>
Signed-off-by: Jens Axboe <axboe@fb.com>
[ Upstream commit 39701e56f5f16ea0cf8fc9e8472e645f8de91d23 ]
The iommu_table struct manages a hardware TCE table and a vmalloc'd
table with corresponding userspace addresses. Both are allocated when
the default DMA window is created and this happens when the very first
group is attached to a container.
As we are going to allow the userspace to configure container in one
memory context and pas container fd to another, we have to postpones
such allocations till a container fd is passed to the destination
user process so we would account locked memory limit against the actual
container user constrainsts.
This postpones the it_userspace array allocation till it is used first
time for mapping. The unmapping patch already checks if the array is
allocated.
Signed-off-by: Alexey Kardashevskiy <aik@ozlabs.ru>
Reviewed-by: David Gibson <david@gibson.dropbear.id.au>
Acked-by: Alex Williamson <alex.williamson@redhat.com>
[ Upstream commit f40ec3c748c6912f6266c56a7f7992de61b255ed ]
Previously we enabled VFs and enable their memory space before calling
pcibios_sriov_enable(). But pcibios_sriov_enable() may update the VF BARs:
for example, on PPC PowerNV we may change them to manage the association of
VFs to PEs.
Because 64-bit BARs cannot be updated atomically, it's unsafe to update
them while they're enabled. The half-updated state may conflict with other
devices in the system.
Call pcibios_sriov_enable() before enabling the VFs so any BAR updates
happen while the VF BARs are disabled.
[bhelgaas: changelog]
Tested-by: Carol Soto <clsoto@us.ibm.com>
Signed-off-by: Gavin Shan <gwshan@linux.vnet.ibm.com>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
[ Upstream commit 63880b230a4af502c56dde3d4588634c70c66006 ]
VF BARs are read-only zero, so updating VF BARs will not have any effect.
See the SR-IOV spec r1.1, sec 3.4.1.11.
We already ignore these updates because of 70675e0b6a1a ("PCI: Don't try to
restore VF BARs"); this merely restructures it slightly to make it easier
to split updates for standard and SR-IOV BARs.
Reviewed-by: Gavin Shan <gwshan@linux.vnet.ibm.com>
[ Upstream commit 45d004f4afefdd8d79916ee6d97a9ecd94bb1ffe ]
The BAR property bits (0-3 for memory BARs, 0-1 for I/O BARs) are supposed
to be read-only, but we do save them in res->flags and include them when
updating the BAR.
Mask the I/O property bits with ~PCI_BASE_ADDRESS_IO_MASK (0x3) instead of
PCI_REGION_FLAG_MASK (0xf) to make it obvious that we can't corrupt bits
2-3 of I/O addresses.
Use PCI_ROM_ADDRESS_MASK for ROM BARs. This means we'll only check the top
21 bits (instead of the 28 bits we used to check) of a ROM BAR to see if
the update was successful.
[ Upstream commit 546ba9f8f22f71b0202b6ba8967be5cc6dae4e21 ]
If we update a VF BAR while it's enabled, there are two potential problems:
1) Any driver that's using the VF has a cached BAR value that is stale
after the update, and
2) We can't update 64-bit BARs atomically, so the intermediate state
(new lower dword with old upper dword) may conflict with another
device, and an access by a driver unrelated to the VF may cause a bus
error.
Warn about attempts to update VF BARs while they are enabled. This is a
programming error, so use dev_WARN() to get a backtrace.
[ Upstream commit 7a6d312b50e63f598f5b5914c4fd21878ac2b595 ]
Remove the assumption that IORESOURCE_ROM_ENABLE == PCI_ROM_ADDRESS_ENABLE.
PCI_ROM_ADDRESS_ENABLE is the ROM enable bit defined by the PCI spec, so if
we're reading or writing a BAR register value, that's what we should use.
IORESOURCE_ROM_ENABLE is a corresponding bit in struct resource flags.
[ Upstream commit 0b457dde3cf8b7c76a60f8e960f21bbd4abdc416 ]
pci_update_resource() updates a hardware BAR so its address matches the
kernel's struct resource UNLESS it's a disabled ROM BAR. We only update
those when we enable the ROM.
It's not obvious from the code why ROM BARs should be handled specially.
Apparently there are Matrox devices with defective ROM BARs that read as
zero when disabled. That means that if pci_enable_rom() reads the disabled
BAR, sets PCI_ROM_ADDRESS_ENABLE (without re-inserting the address), and
writes it back, it would enable the ROM at address zero.
Add comments and references to explain why we can't make the code look more
rational.
The code changes are from 755528c860b0 ("Ignore disabled ROM resources at
setup") and 8085ce084c0f ("[PATCH] Fix PCI ROM mapping").
Link: https://lkml.org/lkml/2005/8/30/138
[sumits: minor fixup in rom.c for 4.4.y]
[ Upstream commit 286c2378aaccc7343ebf17ec6cd86567659caf70 ]
pci_std_update_resource() only deals with standard BARs, so we don't have
to worry about the complications of VF BARs in an SR-IOV capability.
Compute the BAR address inline and remove pci_resource_bar(). That makes
pci_iov_resource_bar() unused, so remove that as well.
[ Upstream commit 6ffa2489c51da77564a0881a73765ea2169f955d ]
Previously pci_update_resource() used the same code path for updating
standard BARs and VF BARs in SR-IOV capabilities.
Split the VF BAR update into a new pci_iov_update_resource() internal
interface, which makes it simpler to compute the BAR address (we can get
rid of pci_resource_bar() and pci_iov_resource_bar()).
This patch:
- Renames pci_update_resource() to pci_std_update_resource(),
- Adds pci_iov_update_resource(),
- Makes pci_update_resource() a wrapper that calls the appropriate one,
No functional change intended.
[ Upstream commit 59107e2f48831daedc46973ce4988605ab066de3 ]
There is a feature in Hyper-V ('Debug-VM --InjectNonMaskableInterrupt')
which injects NMI to the guest. We may want to crash the guest and do kdump
on this NMI by enabling unknown_nmi_panic. To make kdump succeed we need to
allow the kdump kernel to re-establish VMBus connection so it will see
VMBus devices (storage, network,..).
To properly unload VMBus making it possible to start over during kdump we
need to do the following:
- Send an 'unload' message to the hypervisor. This can be done on any CPU
so we do this the crashing CPU.
- Receive the 'unload finished' reply message. WS2012R2 delivers this
message to the CPU which was used to establish VMBus connection during
module load and this CPU may differ from the CPU sending 'unload'.
Receiving a VMBus message means the following:
- There is a per-CPU slot in memory for one message. This slot can in
theory be accessed by any CPU.
- We get an interrupt on the CPU when a message was placed into the slot.
- When we read the message we need to clear the slot and signal the fact
to the hypervisor. In case there are more messages to this CPU pending
the hypervisor will deliver the next message. The signaling is done by
writing to an MSR so this can only be done on the appropriate CPU.
To avoid doing cross-CPU work on crash we have vmbus_wait_for_unload()
function which checks message slots for all CPUs in a loop waiting for the
'unload finished' messages. However, there is an issue which arises when
these conditions are met:
- We're crashing on a CPU which is different from the one which was used
to initially contact the hypervisor.
- The CPU which was used for the initial contact is blocked with interrupts
disabled and there is a message pending in the message slot.
In this case we won't be able to read the 'unload finished' message on the
crashing CPU. This is reproducible when we receive unknown NMIs on all CPUs
simultaneously: the first CPU entering panic() will proceed to crash and
all other CPUs will stop themselves with interrupts disabled.
The suggested solution is to handle unknown NMIs for Hyper-V guests on the
first CPU which gets them only. This will allow us to rely on VMBus
interrupt handler being able to receive the 'unload finish' message in
case it is delivered to a different CPU.
The issue is not reproducible on WS2016 as Debug-VM delivers NMI to the
boot CPU only, WS2012R2 and earlier Hyper-V versions are affected.
Signed-off-by: Vitaly Kuznetsov <vkuznets@redhat.com>
Acked-by: K. Y. Srinivasan <kys@microsoft.com>
Cc: devel@linuxdriverproject.org
Cc: Haiyang Zhang <haiyangz@microsoft.com>
Link: http://lkml.kernel.org/r/20161202100720.28121-1-vkuznets@redhat.com
[ Upstream commit 5bc8c230e2a993b49244f9457499f17283da9ec7 ]
i210 and i211 share the same PHY but have different PCI IDs. Don't
forget i211 for any i210 workarounds.
Signed-off-by: Todd Fujinaka <todd.fujinaka@intel.com>
Tested-by: Aaron Brown <aaron.f.brown@intel.com>
[ Upstream commit 4e684f59d760a2c7c716bb60190783546e2d08a1 ]
Sometimes firmware may not properly initialize I347AT4_PAGE_SELECT causing
the probe of an igb i210 NIC to fail. This patch adds an addition zeroing
of this register during igb_get_phy_id to workaround this issue.
Thanks for Jochen Henneberg for the idea and original patch.
Signed-off-by: Chris J Arges <christopherarges@gmail.com>
[ Upstream commit c74fd80f2f41d05f350bb478151021f88551afe8 ]
Revert the main part of commit:
af42b8d12f8a ("xen: fix MSI setup and teardown for PV on HVM guests")
That commit introduced reading the pci device's msi message data to see
if a pirq was previously configured for the device's msi/msix, and re-use
that pirq. At the time, that was the correct behavior. However, a
later change to Qemu caused it to call into the Xen hypervisor to unmap
all pirqs for a pci device, when the pci device disables its MSI/MSIX
vectors; specifically the Qemu commit:
c976437c7dba9c7444fb41df45468968aaa326ad
("qemu-xen: free all the pirqs for msi/msix when driver unload")
Once Qemu added this pirq unmapping, it was no longer correct for the
kernel to re-use the pirq number cached in the pci device msi message
data. All Qemu releases since 2.1.0 contain the patch that unmaps the
pirqs when the pci device disables its MSI/MSIX vectors.
This bug is causing failures to initialize multiple NVMe controllers
under Xen, because the NVMe driver sets up a single MSIX vector for
each controller (concurrently), and then after using that to talk to
the controller for some configuration data, it disables the single MSIX
vector and re-configures all the MSIX vectors it needs. So the MSIX
setup code tries to re-use the cached pirq from the first vector
for each controller, but the hypervisor has already given away that
pirq to another controller, and its initialization fails.
This is discussed in more detail at:
https://lists.xen.org/archives/html/xen-devel/2017-01/msg00447.html
Fixes: af42b8d12f8a ("xen: fix MSI setup and teardown for PV on HVM guests")
Signed-off-by: Dan Streetman <dan.streetman@canonical.com>
Reviewed-by: Stefano Stabellini <sstabellini@kernel.org>
Acked-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Signed-off-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
commit 2aa6ba7b5ad3189cc27f14540aa2f57f0ed8df4b upstream.
If we try to allocate memory pages to back an xfs_buf that we're trying
to read, it's possible that we'll be so short on memory that the page
allocation fails. For a blocking read we'll just wait, but for
readahead we simply dump all the pages we've collected so far.
Unfortunately, after dumping the pages we neglect to clear the
_XBF_PAGES state, which means that the subsequent call to xfs_buf_free
thinks that b_pages still points to pages we own. It then double-frees
the b_pages pages.
This results in screaming about negative page refcounts from the memory
manager, which xfs oughtn't be triggering. To reproduce this case,
mount a filesystem where the size of the inodes far outweighs the
availalble memory (a ~500M inode filesystem on a VM with 300MB memory
did the trick here) and run bulkstat in parallel with other memory
eating processes to put a huge load on the system. The "check summary"
phase of xfs_scrub also works for this purpose.
Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com>
Reviewed-by: Eric Sandeen <sandeen@redhat.com>
Cc: Ivan Kozik <ivan@ludios.org>
commit 687e0687f71ec00e0132a21fef802dee88c2f1ad upstream.
USBTMC devices are required to have a bulk-in and a bulk-out endpoint,
but the driver failed to verify this, something which could lead to the
endpoint addresses being taken from uninitialised memory.
Make sure to zero all private data as part of allocation, and add the
missing endpoint sanity check.
Note that this also addresses a more recently introduced issue, where
the interrupt-in-presence flag would also be uninitialised whenever the
optional interrupt-in endpoint is not present. This in turn could lead
to an interrupt urb being allocated, initialised and submitted based on
uninitialised values.
Fixes: dbf3e7f654c0 ("Implement an ioctl to support the USMTMC-USB488 READ_STATUS_BYTE operation.")
Fixes: 5b775f672cc9 ("USB: add USB test and measurement class driver")
Signed-off-by: Johan Hovold <johan@kernel.org>
[ johan: backport to v4.4 ]
commit ea90e0dc8cecba6359b481e24d9c37160f6f524f upstream.
Sowmini pointed out Dmitry's RTNL deadlock report to me, and it turns out
to be perfectly accurate - there are various error paths that miss unlock
of the RTNL.
To fix those, change the locking a bit to not be conditional in all those
nl80211_prepare_*_dump() functions, but make those require the RTNL to
start with, and fix the buggy error paths. This also let me use sparse
(by appropriately overriding the rtnl_lock/rtnl_unlock functions) to
validate the changes.
Reported-by: Sowmini Varadhan <sowmini.varadhan@oracle.com>
commit 4dfce57db6354603641132fac3c887614e3ebe81 upstream.
There have been several reports over the years of NULL pointer
dereferences in xfs_trans_log_inode during xfs_fsr processes,
when the process is doing an fput and tearing down extents
on the temporary inode, something like:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000018
PID: 29439 TASK: ffff880550584fa0 CPU: 6 COMMAND: "xfs_fsr"
[exception RIP: xfs_trans_log_inode+0x10]
#9 [ffff8800a57bbbe0] xfs_bunmapi at ffffffffa037398e [xfs]
#10 [ffff8800a57bbce8] xfs_itruncate_extents at ffffffffa0391b29 [xfs]
#11 [ffff8800a57bbd88] xfs_inactive_truncate at ffffffffa0391d0c [xfs]
#12 [ffff8800a57bbdb8] xfs_inactive at ffffffffa0392508 [xfs]
#13 [ffff8800a57bbdd8] xfs_fs_evict_inode at ffffffffa035907e [xfs]
#14 [ffff8800a57bbe00] evict at ffffffff811e1b67
#15 [ffff8800a57bbe28] iput at ffffffff811e23a5
#16 [ffff8800a57bbe58] dentry_kill at ffffffff811dcfc8
#17 [ffff8800a57bbe88] dput at ffffffff811dd06c
#18 [ffff8800a57bbea8] __fput at ffffffff811c823b
#19 [ffff8800a57bbef0] ____fput at ffffffff811c846e
#20 [ffff8800a57bbf00] task_work_run at ffffffff81093b27
#21 [ffff8800a57bbf30] do_notify_resume at ffffffff81013b0c
#22 [ffff8800a57bbf50] int_signal at ffffffff8161405d
As it turns out, this is because the i_itemp pointer, along
with the d_ops pointer, has been overwritten with zeros
when we tear down the extents during truncate. When the in-core
inode fork on the temporary inode used by xfs_fsr was originally
set up during the extent swap, we mistakenly looked at di_nextents
to determine whether all extents fit inline, but this misses extents
generated by speculative preallocation; we should be using if_bytes
instead.
This mistake corrupts the in-memory inode, and code in
xfs_iext_remove_inline eventually gets bad inputs, causing
it to memmove and memset incorrect ranges; this became apparent
because the two values in ifp->if_u2.if_inline_ext[1] contained
what should have been in d_ops and i_itemp; they were memmoved due
to incorrect array indexing and then the original locations
were zeroed with memset, again due to an array overrun.
Fix this by properly using i_df.if_bytes to determine the number
of extents, not di_nextents.
Thanks to dchinner for looking at this with me and spotting the
root cause.
[nborisov: backported to 4.4]
Cc: stable@vger.kernel.org
Signed-off-by: Eric Sandeen <sandeen@redhat.com>
Reviewed-by: Brian Foster <bfoster@redhat.com>
Signed-off-by: Dave Chinner <david@fromorbit.com>
Signed-off-by: Nikolay Borisov <nborisov@suse.com>
fs/xfs/xfs_bmap_util.c | 7 +++++--
1 file changed, 5 insertions(+), 2 deletions(-)
commit ef388e2054feedaeb05399ed654bdb06f385d294 upstream.
The on-disk field di_size is used to set i_size, which is a signed
integer of loff_t. If the high bit of di_size is set, we'll end up with
a negative i_size, which will cause all sorts of problems. Since the
VFS won't let us create a file with such length, we should catch them
here in the verifier too.
Reviewed-by: Dave Chinner <dchinner@redhat.com>
Cc: Nikolay Borisov <n.borisov.lkml@gmail.com>
commit b581a5854eee4b7851dedb0f8c2ceb54fb902c06 upstream.
Since ceph.git commit 4e28f9e63644 ("osd/OSDMap: clear osd_info,
osd_xinfo on osd deletion"), weight is set to IN when OSD is deleted.
This changes the result of applying an incremental for clients, not
just OSDs. Because CRUSH computations are obviously affected,
pre-4e28f9e63644 servers disagree with post-4e28f9e63644 clients on
object placement, resulting in misdirected requests.
Mirrors ceph.git commit a6009d1039a55e2c77f431662b3d6cc5a8e8e63f.
Fixes: 930c53286977 ("libceph: apply new_state before new_up_client on incrementals")
Link: http://tracker.ceph.com/issues/19122
Signed-off-by: Ilya Dryomov <idryomov@gmail.com>
Reviewed-by: Sage Weil <sage@redhat.com>
commit 9b622e2bbcf049c82e2550d35fb54ac205965f50 upstream.
md pending write counter must be incremented after bio is split,
otherwise it gets decremented too many times in end bio callback and
becomes negative.
Signed-off-by: Tomasz Majchrzak <tomasz.majchrzak@intel.com>
Reviewed-by: Artur Paszkiewicz <artur.paszkiewicz@intel.com>
Signed-off-by: Shaohua Li <shli@fb.com>
commit ff010472fb75670cb5c08671e820eeea3af59c87 upstream.
On CPU online the cpufreq core restores the previous governor (or
the previous "policy" setting for ->setpolicy drivers), but it does
not restore the min/max limits at the same time, which is confusing,
inconsistent and real pain for users who set the limits and then
suspend/resume the system (using full suspend), in which case the
limits are reset on all CPUs except for the boot one.
Fix this by making cpufreq_online() restore the limits when an inactive
policy is brought online.
The commit log and patch are inspired from Rafael's earlier work.
Reported-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
commit b1708b72a0959a032cd2eebb77fa9086ea3e0c84 upstream.
The dmas/dma-names properties are added to the UART nodes. Note that additional
properties are needed to enable them at the board level: check bindings for
details.
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
commit 60b89f1928af80b546b5c3fd8714a62f6f4b8844 upstream.
On some DDR controllers, compatible with the sama5d3 one,
the sequence to enter/exit/re-enter the self-refresh mode adds
more constrains than what is currently written in the at91_idle
driver. An actual access to the DDR chip is needed between exit
and re-enter of this mode which is somehow difficult to implement.
This sequence can completely hang the SoC. It is particularly
experienced on parts which embed a L2 cache if the code run
between IDLE calls fits in it...
Moreover, as the intention is to enter and exit pretty rapidly
from IDLE, the power-down mode is a good candidate.
So now we use power-down instead of self-refresh. As we can
simplify the code for sama5d3 compatible DDR controllers,
we instantiate a new sama5d3_ddr_standby() function.
Signed-off-by: Nicolas Ferre <nicolas.ferre@microchip.com>
Fixes: 017b5522d5e3 ("ARM: at91: Add new binding for sama5d3-ddramc")
commit 5003ae1e735e6bfe4679d9bed6846274f322e77e upstream.
The function device_to_iommu() in the Intel VT-d driver
lacks a NULL-ptr check, resulting in this oops at boot on
some platforms:
BUG: unable to handle kernel NULL pointer dereference at 00000000000007ab
IP: [<ffffffff8132234a>] device_to_iommu+0x11a/0x1a0
PGD 0
Call Trace:
? find_or_alloc_domain.constprop.29+0x1a/0x300
? dw_dma_probe+0x561/0x580 [dw_dmac_core]
? __get_valid_domain_for_dev+0x39/0x120
? __intel_map_single+0x138/0x180
? intel_alloc_coherent+0xb6/0x120
? sst_hsw_dsp_init+0x173/0x420 [snd_soc_sst_haswell_pcm]
? mutex_lock+0x9/0x30
? kernfs_add_one+0xdb/0x130
? devres_add+0x19/0x60
? hsw_pcm_dev_probe+0x46/0xd0 [snd_soc_sst_haswell_pcm]
? platform_drv_probe+0x30/0x90
? driver_probe_device+0x1ed/0x2b0
? __driver_attach+0x8f/0xa0
? driver_probe_device+0x2b0/0x2b0
? bus_for_each_dev+0x55/0x90
? bus_add_driver+0x110/0x210
? 0xffffffffa11ea000
? driver_register+0x52/0xc0
? do_one_initcall+0x32/0x130
? free_vmap_area_noflush+0x37/0x70
? kmem_cache_alloc+0x88/0xd0
? do_init_module+0x51/0x1c4
? load_module+0x1ee9/0x2430
? show_taint+0x20/0x20
? kernel_read_file+0xfd/0x190
? SyS_finit_module+0xa3/0xb0
? do_syscall_64+0x4a/0xb0
? entry_SYSCALL64_slow_path+0x25/0x25
Code: 78 ff ff ff 4d 85 c0 74 ee 49 8b 5a 10 0f b6 9b e0 00 00 00 41 38 98 e0 00 00 00 77 da 0f b6 eb 49 39 a8 88 00 00 00 72 ce eb 8f <41> f6 82 ab 07 00 00 04 0f 85 76 ff ff ff 0f b6 4d 08 88 0e 49
RIP [<ffffffff8132234a>] device_to_iommu+0x11a/0x1a0
RSP <ffffc90001457a78>
CR2: 00000000000007ab
---[ end trace 16f974b6d58d0aad ]---
Add the missing pointer check.
Fixes: 1c387188c60f53b338c20eee32db055dfe022a9b ("iommu/vt-d: Fix IOMMU lookup for SR-IOV Virtual Functions")
Signed-off-by: Koos Vriezen <koos.vriezen@gmail.com>
Signed-off-by: Joerg Roedel <jroedel@suse.de>
commit 1914f0cd203c941bba72f9452c8290324f1ef3dc upstream.
This was broken in commit cd979883b9ed ("xen/acpi-processor:
fix enabling interrupts on syscore_resume"). do_suspend (from
xen/manage.c) and thus xen_resume_notifier never get called on
the initial-domain at resume (it is if running as guest.)
The rationale for the breaking change was that upload_pm_data()
potentially does blocking work in syscore_resume(). This patch
addresses the original issue by scheduling upload_pm_data() to
execute in workqueue context.
Cc: Stanislaw Gruszka <sgruszka@redhat.com>
Based-on-patch-by: Konrad Wilk <konrad.wilk@oracle.com>
Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Reviewed-by: Stanislaw Gruszka <sgruszka@redhat.com>
Signed-off-by: Ankur Arora <ankur.a.arora@oracle.com>
commit e2ebfb2142acefecc2496e71360f50d25726040b upstream.
Disabling interrupts for even a millisecond can cause problems for some
devices. That can happen when sdhci changes clock frequency because it
waits for the clock to become stable under a spin lock.
The spin lock is not necessary here. Anything that is racing with changes
to the I/O state is already broken. The mmc core already provides
synchronization via "claiming" the host.
Although the spin lock probably should be removed from the code paths that
lead to this point, such a patch would touch too much code to be suitable
for stable trees. Consequently, for this patch, just drop the spin lock
while waiting.
Signed-off-by: Adrian Hunter <adrian.hunter@intel.com>
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
Tested-by: Ludovic Desroches <ludovic.desroches@microchip.com>
commit b9cf625d6ecde0d372e23ae022feead72b4228a6 upstream.
If ext4_convert_inline_data() was called on a directory with inline
data, the filesystem was left in an inconsistent state (as considered by
e2fsck) because the file size was not increased to cover the new block.
This happened because the inode was not marked dirty after i_disksize
was updated. Fix this by marking the inode dirty at the end of
ext4_finish_convert_inline_dir().
This bug was probably not noticed before because most users mark the
inode dirty afterwards for other reasons. But if userspace executed
FS_IOC_SET_ENCRYPTION_POLICY with invalid parameters, as exercised by
'kvm-xfstests -c adv generic/396', then the inode was never marked dirty
after updating i_disksize.
Fixes: 3c47d54170b6a678875566b1b8d6dcf57904e49b
Signed-off-by: Theodore Ts'o <tytso@mit.edu>
commit 03270c6ac6207fc55bbf9d20d195029dca210c79 upstream.
Usually every parallel port will have a single pardev registered with
it. But ppdev driver is an exception. This userspace parallel port
driver allows to create multiple parrallel port devices for a single
parallel port. And as a result we were having a nice warning like:
"sysctl table check failed:
/dev/parport/parport0/devices/ppdev0/timeslice Sysctl already exists"
Use the same logic as used in parport_register_device() and register
the proc files only once for each parallel port.
Fixes: 6fa45a226897 ("parport: add device-model to parport subsystem")
Bugzilla: https://bugzilla.redhat.com/show_bug.cgi?id=1414656
Bugzilla: https://bugs.archlinux.org/task/52322
Tested-by: James Feeney <james@nurealm.net>
Signed-off-by: Sudip Mukherjee <sudip.mukherjee@codethink.co.uk>
sensor properties losing after resume from S3
commit 3bec247474469f769af41e8c80d3a100dd97dd76 upstream.
In function _hid_sensor_power_state(), when hid_sensor_read_poll_value()
is called, sensor's all properties will be updated by the value from
sensor hardware/firmware.
In some implementation, sensor hardware/firmware will do a power cycle
during S3. In this case, after resume, once hid_sensor_read_poll_value()
is called, sensor's all properties which are kept by driver during S3
will be changed to default value.
But instead, if a set feature function is called first, sensor
hardware/firmware will be recovered to the last status. So change the
sensor_hub_set_feature() calling order to behind of set feature function
to avoid sensor properties lose.
Signed-off-by: Song Hongyan <hongyan.song@intel.com>
Acked-by: Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com>
Signed-off-by: Jonathan Cameron <jic23@kernel.org>
commit e83bb3e6f3efa21f4a9d883a25d0ecd9dfb431e1 upstream.
The tiadc_irq_h(int irq, void *private) function is handling FIFO
overruns by clearing flags, disabling and enabling the ADC to
recover.
If the ADC is running in continuous mode a FIFO overrun happens
regularly. If the disabling of the ADC happens concurrently with
a new conversion. It might happen that the enabling of the ADC
is ignored by the hardware. This stops the ADC permanently. No
more interrupts are triggered.
According to the AM335x Reference Manual (SPRUH73H October 2011 -
Revised April 2013 - Chapter 12.4 and 12.5) it is necessary to
check the ADC FSM bits in REG_ADCFSM before enabling the ADC
again. Because the disabling of the ADC is done right after the
current conversion has been finished.
To trigger this bug it is necessary to run the ADC in continuous
mode. The ADC values of all channels need to be read in an endless
loop. The bug appears within the first 6 hours (~5.4 million
handled FIFO overruns). The user space application will hang on
reading new values from the character device.
Fixes: ca9a563805f7a ("iio: ti_am335x_adc: Add continuous sampling support")
Signed-off-by: Michael Engl <michael.engl@wjw-solutions.com>
commit 181302dc7239add8ab1449c23ecab193f52ee6ab upstream.
Make sure to check the number of endpoints to avoid dereferencing a
NULL-pointer should a malicious device lack endpoints.
Fixes: 53f3a9e26ed5 ("mmc: USB SD Host Controller (USHC) driver")
Cc: David Vrabel <david.vrabel@csr.com>
commit daf229b15907fbfdb6ee183aac8ca428cb57e361 upstream.
Note that the dereference happens in the start callback which is called
during probe.
Fixes: de520b8bd552 ("uwb: add HWA radio controller driver")
Cc: Inaky Perez-Gonzalez <inaky.perez-gonzalez@intel.com>
commit 4ce362711d78a4999011add3115b8f4b0bc25e8c upstream.
Note that the dereference happens in the cmd and wait_init_done
callbacks which are called during probe.
Fixes: 1ba47da52712 ("uwb: add the i1480 DFU driver")
commit 7b2db29fbb4e766fcd02207eb2e2087170bd6ebc upstream.
If usb_get_bos_descriptor() returns an error, usb->bos will be NULL.
Nevertheless, it is dereferenced unconditionally in
hub_set_initial_usb2_lpm_policy() if usb2_hw_lpm_capable is set.
This results in a crash.
usb 5-1: unable to get BOS descriptor
Unable to handle kernel NULL pointer dereference at virtual address 00000008
pgd = ffffffc00165f000
[00000008] *pgd=000000000174f003, *pud=000000000174f003,
*pmd=0000000001750003, *pte=00e8000001751713
Internal error: Oops: 96000005 [#1] PREEMPT SMP
Modules linked in: uinput uvcvideo videobuf2_vmalloc cmac [ ... ]
CPU: 5 PID: 3353 Comm: kworker/5:3 Tainted: G B 4.4.52 #480
Hardware name: Google Kevin (DT)
Workqueue: events driver_set_config_work
task: ffffffc0c3690000 ti: ffffffc0ae9a8000 task.ti: ffffffc0ae9a8000
PC is at hub_port_init+0xc3c/0xd10
LR is at hub_port_init+0xc3c/0xd10
Call trace:
[<ffffffc0007fbbfc>] hub_port_init+0xc3c/0xd10
[<ffffffc0007fbe2c>] usb_reset_and_verify_device+0x15c/0x82c
[<ffffffc0007fc5e0>] usb_reset_device+0xe4/0x298
[<ffffffbffc0e3fcc>] rtl8152_probe+0x84/0x9b0 [r8152]
[<ffffffc00080ca8c>] usb_probe_interface+0x244/0x2f8
[<ffffffc000774a24>] driver_probe_device+0x180/0x3b4
[<ffffffc000774e48>] __device_attach_driver+0xb4/0xe0
[<ffffffc000772168>] bus_for_each_drv+0xb4/0xe4
[<ffffffc0007747ec>] __device_attach+0xd0/0x158
[<ffffffc000775080>] device_initial_probe+0x24/0x30
[<ffffffc0007739d4>] bus_probe_device+0x50/0xe4
[<ffffffc000770bd0>] device_add+0x414/0x738
[<ffffffc000809fe8>] usb_set_configuration+0x89c/0x914
[<ffffffc00080a120>] driver_set_config_work+0xc0/0xf0
[<ffffffc000249bb8>] process_one_work+0x390/0x6b8
[<ffffffc00024abcc>] worker_thread+0x480/0x610
[<ffffffc000251a80>] kthread+0x164/0x178
[<ffffffc0002045d0>] ret_from_fork+0x10/0x40
Since we don't know anything about LPM capabilities without BOS descriptor,
don't attempt to enable LPM if it is not available.
Fixes: 890dae886721 ("xhci: Enable LPM support only for hardwired ...")
Cc: Mathias Nyman <mathias.nyman@linux.intel.com>
Acked-by: Mathias Nyman <mathias.nyman@linux.intel.com>
commit 0090114d336a9604aa2d90bc83f20f7cd121b76c upstream.
The CPPI 4.1 driver polls register to workaround the premature TX
interrupt issue, but it causes audio playback underrun when triggered in
Isoch transfers.
Isoch doesn't do back-to-back transfers, the TX should be done by the
time the next transfer is scheduled. So skip this polling workaround for
Isoch transfer.
Fixes: a655f481d83d6 ("usb: musb: musb_cppi41: handle pre-mature TX complete interrupt")
Reported-by: Alexandre Bailon <abailon@baylibre.com>
Acked-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Tested-by: Alexandre Bailon <abailon@baylibre.com>
Signed-off-by: Bin Liu <b-liu@ti.com>
commit 03ace948a4eb89d1cf51c06afdfc41ebca5fdb27 upstream.
NULL-pointer or accessing memory beyond the endpoint array should a
malicious device lack the expected endpoints.
This specifically fixes the NULL-pointer dereference when probing HWA HC
devices.
Fixes: df3654236e31 ("wusb: add the Wire Adapter (WA) core")
commit b0addd3fa6bcd119be9428996d5d4522479ab240 upstream.
Fixes: 1da177e4c3f4 ("Linux-2.6.12-rc2")
commit 1dc56c52d2484be09c7398a5207d6b11a4256be9 upstream.
NULL-pointer should the probed device lack endpoints.
Note that this driver does not bind to any devices by default.
Fixes: ce21bfe603b3 ("USB: Add LVS Test device driver")
Cc: Pratyush Anand <pratyush.anand@gmail.com>
commit f259ca3eed6e4b79ac3d5c5c9fb259fb46e86217 upstream.
Note that the endpoint access that causes the NULL-deref is currently
only used for debugging purposes during probe so the oops only happens
when dynamic debugging is enabled. This means the driver could be
rewritten to continue to accept device with only two endpoints, should
such devices exist.
commit 3243367b209faed5c320a4e5f9a565ee2a2ba958 upstream.
Some USB 2.0 devices erroneously report millisecond values in
bInterval. The generic config code manages to catch most of them,
but in some cases it's not completely enough.
The case at stake here is a USB 2.0 braille device, which wants to
announce 10ms and thus sets bInterval to 10, but with the USB 2.0
computation that yields to 64ms. It happens that one can type fast
enough to reach this interval and get the device buffers overflown,
leading to problematic latencies. The generic config code does not
catch this case because the 64ms is considered a sane enough value.
This change thus adds a USB_QUIRK_LINEAR_FRAME_INTR_BINTERVAL quirk
to mark devices which actually report milliseconds in bInterval,
and marks Vario Ultra devices as needing it.
Signed-off-by: Samuel Thibault <samuel.thibault@ens-lyon.org>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
commit 09424c50b7dff40cb30011c09114404a4656e023 upstream.
The streaming_maxburst module parameter is 0 offset (0..15)
so we must add 1 while using it for wBytesPerInterval
calculation for the SuperSpeed companion descriptor.
Without this host uvcvideo driver will always see the wrong
wBytesPerInterval for SuperSpeed uvc gadget and may not find
a suitable video interface endpoint.
e.g. for streaming_maxburst = 0 case it will always
fail as wBytePerInterval was evaluating to 0.
Reviewed-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Signed-off-by: Roger Quadros <rogerq@ti.com>
Signed-off-by: Felipe Balbi <felipe.balbi@linux.intel.com>
