The driver core clears the driver data to NULL after device_release
or on probe failure, since commit 0998d0631001288a5974afc0b2a5f568bcdecb4d
(device-core: Ensure drvdata = NULL when no driver is bound).
Thus, it is not needed to manually clear the device driver data to NULL.
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
Signed-off-by: Vinod Koul <vinod.koul@intel.com>
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Fix the following sparse warning:
drivers/dma/mxs-dma.c:696:17: warning: symbol 'mxs_dma_xlate' was not declared. Should it be static?
Acked-by: Shawn Guo <shawn.guo@linaro.org>
Use the wrapper functions for getting and setting the driver data using
platform_device instead of using dev_{get,set}_drvdata() with &pdev->dev,
so we can directly pass a struct platform_device.
Also, unnecessary dev_set_drvdata() is removed, because the driver core
clears the driver data to NULL after device_release or on probe failure.
Add support for returning the residue for current transfer cookie by
reading the transfered buffer size(BTSIZE) in CTRLA register.
For a single buffer cookie, the descriptor length minus BTSIZE
can get the residue.
For a lli cookie, remain_desc will record remain descriptor length
when last descriptor finish, the remain_desc minus BTSIZE can get the
current residue.
If the cookie has completed successfully, the residue will be zero.
If the cookie is in progress, it will be the number of bytes yet to be transferred.
If get residue error, the cookie will be turn into error status.
Check dma fifo to see if data remain, let issue pending finish remain work if there is.
Signed-off-by: Elen Song <elen.song@atmel.com>
In one dma transfer, the data transfer width can be configured and it is limited by source or destination peripheral width,
tx_width will save the transfer width, but for memcpy, either source or destination transfer width is taken as tx_width.
No modification in CFG register configuration, just rearrange
bits directives to group logically and make it more readable.
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
Peripheral handshaking identification numbers can be bigger than 15, so new
fields have been created in the CFG register.
Add macros to take this modification into account and use them in
at_dma_xlate() function.
imxdma->dev is used for dev_warn before it was set.
Signed-off-by: Markus Pargmann <mpa@pengutronix.de>
Reviewed-by: Shawn Guo <shawn.guo@linaro.org>
Acked-by: Sascha Hauer <s.hauer@pengutronix.de>
Adding devicetree support for imx-dma driver. Use driver name for
function 'imx_dma_is_general_purpose' because the devicename for
devicetree initialized devices is different.
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
Both of_dma_nbcells field of the of_dma_controller and the args_count field of
the dma_spec are initialized by parsing the #dma-cells attribute of their device
tree node. So if the device tree nodes of a DMA controller and the dma_spec
match this means that of_dma_nbcells and args_count will also match. So the
second test in the of_dma_find_controller loop is redundant because given the
first test yields true the second test will also yield true. So we can safely
remove the test whether of_dma_nbcells matches args_count. Since this was the
last user of the of_dma_nbcells field we can remove it altogether.
There is no sensible reason why #dma-cells shouldn't be allowed to be 0. It is
completely up to the DMA controller how many additional parameters, besides the
phandle, it needs to identify a channel. E.g. for DMA controller with only one
channel or for DMA controllers which don't have a restriction on which channel
can be used for which peripheral it completely legitimate to not require any
additional parameters.
Also fixes the following warning:
drivers/dma/of-dma.c: In function 'of_dma_controller_register':
drivers/dma/of-dma.c:67:7: warning: 'nbcells' may be used uninitialized in this function
This patch fixes warnings due to missing lock on write error path.
WARNING: at fs/hpfs/hpfs_fn.h:353 hpfs_truncate+0x75/0x80 [hpfs]()
Hardware name: empty
Pid: 26563, comm: dd Tainted: P O 3.9.4 #12
Call Trace:
hpfs_write_begin+0x84/0x90 [hpfs]
_hpfs_bmap+0x10/0x10 [hpfs]
generic_file_buffered_write+0x121/0x2c0
__generic_file_aio_write+0x1c7/0x3f0
generic_file_aio_write+0x7c/0x100
do_sync_write+0x98/0xd0
hpfs_file_write+0xd/0x50 [hpfs]
vfs_write+0xa2/0x160
sys_write+0x51/0xa0
page_fault+0x22/0x30
system_call_fastpath+0x1a/0x1f
Signed-off-by: Mikulas Patocka <mikulas@artax.karlin.mff.cuni.cz>
Cc: stable@kernel.org # 2.6.39+
Pull timer fixes from Thomas Gleixner:
- Trivial: unused variable removal
- Posix-timers: Add the clock ID to the new proc interface to make it
useful. The interface is new and should be functional when we reach
the final 3.10 release.
- Cure a false positive warning in the tick code introduced by the
overhaul in 3.10
- Fix for a persistent clock detection regression introduced in this
cycle
* 'timers-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
timekeeping: Correct run-time detection of persistent_clock.
ntp: Remove unused variable flags in __hardpps
posix-timers: Show clock ID in proc file
tick: Cure broadcast false positive pending bit warning
Pull irqdomain bug fixes from Grant Likely:
"This branch contains a set of straight forward bug fixes to the
irqdomain code and to a couple of drivers that make use of it."
* tag 'irqdomain-for-linus' of git://git.secretlab.ca/git/linux:
irqchip: Return -EPERM for reserved IRQs
irqdomain: document the simple domain first_irq
kernel/irq/irqdomain.c: before use 'irq_data', need check it whether valid.
irqdomain: export irq_domain_add_simple
The irqdomain core will report a log message for any attempted map call
that fails unless the error code is -EPERM. This patch changes the
Versatile irq controller drivers to use -EPERM because it is normal for
a subset of the IRQ inputs to be marked as reserved on the various
Versatile platforms.
Signed-off-by: Grant Likely <grant.likely@linaro.org>
The first_irq needs to be zero to get a linear domain and that
comes with special semantics. We want to simplify this going
forward but some documentation never hurts.
Since irq_data may be NULL, if so, we WARN_ON(), and continue, 'hwirq'
which related with 'irq_data' has to initialize later, or it will cause
issue.
Signed-off-by: Chen Gang <gang.chen@asianux.com>
All other irq_domain_add_* functions are exported already, and apparently
this one got left out by mistake, which causes build errors for ARM
allmodconfig kernels:
ERROR: "irq_domain_add_simple" [drivers/gpio/gpio-rcar.ko] undefined!
ERROR: "irq_domain_add_simple" [drivers/gpio/gpio-em.ko] undefined!
Acked-by: Simon Horman <horms+renesas@verge.net.au>
Pull ARM SoC fixes from Olof Johansson:
"Another week, another batch of fixes for arm-soc platforms.
Nothing controversial here, a handful of fixes for regressions and/or
serious problems across several of the platforms. Things are slowing
down nicely on fix rates for 3.10"
* tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc:
ARM: exynos: add debug_ll_io_init() call in exynos_init_io()
ARM: EXYNOS: uncompress - print debug messages if DEBUG_LL is defined
ARM: shmobile: sh73a0: Update CMT clockevent rating to 80
sh-pfc: r8a7779: Don't group USB OVC and PENC pins
ARM: mxs: icoll: Fix interrupts gpio bank 0
ARM: imx: clk-imx6q: AXI clock select index is incorrect
ARM: bcm2835: override the HW UART periphid
ARM: mvebu: Fix bug in coherency fabric low level init function
ARM: Kirkwood: TS219: Fix crash by double PCIe instantiation
ARM: ux500: Provide supplies for AUX1, AUX2 and AUX3
ARM: ux500: Only configure wake-up reasons on ux500 based platforms
ARM: dts: imx: fix clocks for cspi
ARM i.MX6q: fix for ldb_di_sels
Pull MIPS fixes from Ralf Baechle:
"MIPS fixes across the field. The only area that's standing out is the
exception handling which received it's dose of breakage as part of the
microMIPS patchset"
* 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus:
MIPS: ralink: add missing SZ_1M multiplier
MIPS: Compat: Fix cputime_to_timeval() arguments in compat binfmt_elf.
MIPS: OCTEON: Improve _machine_halt implementation.
MIPS: rtlx: Fix implicit declaration of function set_vi_handler()
MIPS: Trap exception handling fixes
MIPS: Quit exposing Kconfig symbols in uapi headers.
MIPS: Remove duplicate definition of check_for_high_segbits.
git://git.kernel.org/pub/scm/linux/kernel/git/gerg/m68knommu
Pull m68knommu fix from Greg Ungerer:
"A single fix for compilation breakage to many of the ColdFire CPU
targets"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gerg/m68knommu:
m68k: only use local gpio_request_one if not using GPIOLIB
Pull drm fixes from Dave Airlie:
"Regression fixers for the big 3:
- nouveau: hdmi audio, dac load detect, s/r regressions fixed
- radeon: long standing system hang fixed, hdmi audio and rs780 fast
fb fixes
- intel: one old regression, a WARN removal, and a stop X dying fix
Otherwise one mgag200 fix, a couple of arm build fixes, and a core use
after free fix."
* 'drm-fixes' of git://people.freedesktop.org/~airlied/linux:
drm/nv50/kms: use dac loadval from vbios, where it's available
drm/nv50/disp: force dac power state during load detect
drm/nv50-nv84/fifo: fix resume regression introduced by playlist race fix
drm/nv84/disp: Fix HDMI audio regression
drm/i915/sdvo: Use &intel_sdvo->ddc instead of intel_sdvo->i2c for DDC.
drm/radeon: don't allow audio on DCE6
drm/radeon: Use direct mapping for fast fb access on RS780/RS880 (v2)
radeon: Fix system hang issue when using KMS with older cards
drm/i915: no lvds quirk for hp t5740
drm/i915: Quirk the pipe A quirk in the modeset state checker
drm/i915: Fix spurious -EIO/SIGBUS on wedged gpus
drm/mgag200: Add missing write to index before accessing data register
drm/nouveau: use mdelay instead of large udelay constants
drm/tilcd: select BACKLIGHT_LCD_SUPPORT
drm: fix a use-after-free when GPU acceleration disabled
Pull slave-dmaengine fixes from Vinod Koul:
"Fix from Andy is for dmatest regression reported by Will and Rabin has
fixed runtime ref counting for st_dma40"
* 'fixes' of git://git.infradead.org/users/vkoul/slave-dma:
dmatest: do not allow to interrupt ongoing tests
dmaengine: ste_dma40: fix pm runtime ref counting
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace
Pull tracing fixes from Steven Rostedt:
"This contains 4 fixes.
The first two fix the case where full RCU debugging is enabled,
enabling function tracing causes a live lock of the system. This is
due to the added debug checks in rcu_dereference_raw() that is used by
the function tracer. These checks are also traced by the function
tracer as well as cause enough overhead to the function tracer to slow
down the system enough that the time to finish an interrupt can take
longer than when the next interrupt is triggered, causing a live lock
from the timer interrupt.
Talking this over with Paul McKenney, we came up with a fix that adds
a new rcu_dereference_raw_notrace() that does not perform these added
checks, and let the function tracer use that.
The third commit fixes a failed compile when branch tracing is
enabled, due to the conversion of the trace_test_buffer() selftest
that the branch trace wasn't converted for.
The forth patch fixes a bug caught by the RCU lockdep code where a
rcu_read_lock() is performed when rcu is disabled (either going to or
from idle, or user space). This happened on the irqsoff tracer as it
calls task_uid(). The fix here was to use current_uid() when possible
that doesn't use rcu locking. Which luckily, is always used when
irqsoff calls this code."
* tag 'trace-fixes-v3.10-rc3-v3' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace:
tracing: Use current_uid() for critical time tracing
tracing: Fix bad parameter passed in branch selftest
ftrace: Use the rcu _notrace variants for rcu_dereference_raw() and friends
rcu: Add _notrace variation of rcu_dereference_raw() and hlist_for_each_entry_rcu()
Commit 9f29ab11ddbf ("ACPI / scan: do not match drivers against objects
having scan handlers") introduced a boot regression on Tony's ia64 HP
rx2600. Tony says:
"It panics with the message:
Kernel panic - not syncing: Unable to find SBA IOMMU: Try a generic or DIG kernel
[...] my problem comes from arch/ia64/hp/common/sba_iommu.c
where the code in sba_init() says:
acpi_bus_register_driver(&acpi_sba_ioc_driver);
if (!ioc_list) {
but because of this change we never managed to call ioc_init()
so ioc_list doesn't get set up, and we die."
Revert it to avoid this breakage and we'll fix the problem it attempted
to address later.
Reported-by: Tony Luck <tony.luck@gmail.com>
Cc: 3.9+ <stable@vger.kernel.org>
into fixes
From Shawn Guo, mxs fixes for 3.10:
- Since the time we move to MULTI_IRQ_HANDLER, the 0x7f polling for no
interrupt in icoll_handle_irq() becomes insane, because 0x7f is an
valid interrupt number, the irq of gpio bank 0. That unnecessary
polling results in the driver not detecting when irq 0x7f is active
which makes the machine effectively dead lock. The fix removes the
interrupt poll loop and allows usage of gpio0 interrupt without an
infinite loop.
* tag 'mxs-fixes-3.10' of git://git.linaro.org/people/shawnguo/linux-2.6:
git://git.linaro.org/people/shawnguo/linux-2.6 into fixes
From Shawn Guo, imx fixes for 3.10, take 2:
- One device tree fix for all spi node to have per clock added.
The clock is needed by spi driver to calculate bit rate divisor.
The spi node in the current device trees either does not have the
clock or is defined as dummy clock, in which case the driver probe
will fail or spi will run at a wrong bit rate.
- Two imx6q clock fixes, which correct axi_sels and ldb_di_sels.
* tag 'imx-fixes-3.10-2' of git://git.linaro.org/people/shawnguo/linux-2.6:
If the early MMU mapping of the UART happens to get booted out of the
TLB between the start of paging_init() and when we finally re-add the
UART at the very end of s3c_init_cpu(), we'll get a hang at bootup if
we've got early_printk enabled. Avoid this hang by calling
debug_ll_io_init() early.
Without this patch, you can reliably reproduce a hang when early
printk is enabled by adding flush_tlb_all() at the start of
exynos_init_io(). After this patch the hang goes away.
Signed-off-by: Doug Anderson <dianders@chromium.org>
Acked-by: Kukjin Kim <kgene.kim@samsung.com>
git://git.kernel.org/pub/scm/linux/kernel/git/horms/renesas into fixes
From Simon Horman, Renesas ARM based SoC fixes for v3.10:
- Correction to USB OVC and PENC pin groupings on r8a7779 SoC.
This avoids conflicts when the USB_OVCn pins are used by another function.
This has been observed to be a problem in v3.10-rc1.
- Update CMT clock rating for sh73a0 SoC to resolve boot failure
on kzm9g-reference. This resolves a regression between v3.9 and v3.10-rc1.
* tag 'renesas-fixes-for-v3.10' of git://git.kernel.org/pub/scm/linux/kernel/git/horms/renesas:
Printing low-level debug messages make an assumption that the specified
UART port has been preconfigured by the bootloader. Incorrectly
specified UART port results in system getting stalled while printing the
message "Uncompressing Linux... done, booting the kernel"
This UART port number is specified through S3C_LOWLEVEL_UART_PORT. Since
the UART port might different for different board, it is not possible to
specify it correctly for every board that use a common defconfig file.
Calling this print subroutine only when DEBUG_LL fixes the problem. By
disabling DEBUG_LL in default config file, we would be able to boot
multiple boards with different default UART ports.
With this current approach, we miss the print "Uncompressing Linux...
done, booting the kernel." when DEBUG_LL is not defined.
Signed-off-by: Tushar Behera <tushar.behera@linaro.org>
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband
Pull infiniband fixes from Roland Dreier:
- qib RCU/lockdep fix
- iser device removal fix, plus doc fixes
* tag 'rdma-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband:
IB/qib: Fix lockdep splat in qib_alloc_lkey()
MAINTAINERS: Add entry for iSCSI Extensions for RDMA (iSER) initiator
IB/iser: Add Mellanox copyright
IB/iser: Fix device removal flow
Pull vfio fix from Alex Williamson:
"fix rmmod crash"
* tag 'vfio-v3.10-rc5' of git://github.com/awilliam/linux-vfio:
vfio: fix crash on rmmod
git://git.kernel.org/pub/scm/linux/kernel/git/tyhicks/ecryptfs
Pull ecryptfs fixes from Tyler Hicks:
- Fixes how eCryptfs handles msync to sync both the upper and lower
file
- A couple of MAINTAINERS updates
* tag 'ecryptfs-3.10-rc5-msync' of git://git.kernel.org/pub/scm/linux/kernel/git/tyhicks/ecryptfs:
eCryptfs: Check return of filemap_write_and_wait during fsync
Update eCryptFS maintainers
ecryptfs: fixed msync to flush data
Pull CIFS fix from Steve French:
"Fix one byte buffer overrun with prefixpaths on cifs mounts which can
cause a problem with mount depending on the string length"
* 'for-3.10' of git://git.samba.org/sfrench/cifs-2.6:
cifs: fix off-by-one bug in build_unc_path_to_root
When user interrupts ongoing transfers the dmatest may end up with console
lockup, oops, or data mismatch. This patch prevents user to abort any ongoing
test.
Documentation is updated accordingly.
Reported-by: Will Deacon <will.deacon@arm.com>
Tested-by: Will Deacon <will.deacon@arm.com>
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound
Pull sound fixes from Takashi Iwai:
- A pile of small regression fix patches for HD-audio VIA codecs
- Quirks for HD-aduio and USB-audio devices
- A trivial SIS7019 error path fix
* tag 'sound-3.10' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound:
ALSA: usb-audio - Fix invalid volume resolution on Logitech HD webcam c270
ALSA: usb-audio - Apply Logitech QuickCam Pro 9000 quirk only to audio iface
ALSA: hda/via - Clean up duplicated codes
ALSA: hda/via - Fix wrongly cleared pins after suspend on VT1802
ALSA: hda - Add keep_eapd_on flag to generic parser
ALSA: hda - Allow setting automute/automic hooks after parsing
ALSA: hda/via - Disable broken dynamic power control
ALSA: usb-audio: fix Roland/Cakewalk UM-3G support
ALSA: hda - Add headset quirk for two Dell machines
ALSA: hda - add dock support for Thinkpad T431s
ALSA: sis7019: fix error return code in sis_chip_create()
Pull power management and ACPI fixes from Rafael J Wysocki:
- Fix for an ACPI PM regression causing Toshiba P870-303 to crash
during boot from Rafael J Wysocki.
- ACPI fix for an issue causing some drivers to attempt to bind to
devices they shouldn't touch from Aaron Lu.
- Fix for a recent cpufreq regression related to a possible race with
CPU offline from Michael Wang.
- ACPI cpufreq regression fix for an issue causing turbo frequencies to
be underutilized in some cases from Ross Lagerwall.
- cpufreq-cpu0 driver fix related to incorrect clock ACPI usage from
Guennadi Liakhovetski.
- HP WMI driver fix for an issue causing GPS initialization and
poweroff failures on HP Elitebook 6930p from Lan Tianyu.
- APEI (ACPI Platform Error Interface) fix for an issue in the error
code path in ghes_probe() from Wei Yongjun.
- New ACPI video driver blacklist entries for HP m4 and HP Pavilion g6
from Alex Hung and Ash Willis.
* tag 'pm+acpi-3.10-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm:
ACPI / PM: Do not execute _PS0 for devices without _PSC during initialization
cpufreq: cpufreq-cpu0: use the exact frequency for clk_set_rate()
cpufreq: protect 'policy->cpus' from offlining during __gov_queue_work()
ACPI / scan: do not match drivers against objects having scan handlers
ACPI / APEI: fix error return code in ghes_probe()
acpi-cpufreq: set current frequency based on target P-State
ACPI / video: ignore BIOS initial backlight value for HP Pavilion g6
ACPI / video: ignore BIOS initial backlight value for HP m4
x86 / platform / hp_wmi: Fix bluetooth_rfkill misuse in hp_wmi_rfkill_setup()
* pm-fixes:
* acpi-fixes:
Commit b378549 (ACPI / PM: Do not power manage devices in unknown
initial states) added code to force devices without _PSC, but having
_PS0 defined in the ACPI namespace, into ACPI power state D0 by
executing _PS0 for them. That turned out to break Toshiba P870-303,
however, so revert that code.
References: https://bugzilla.kernel.org/show_bug.cgi?id=58201
Reported-and-tested-by: Jerome Cantenot <jerome.cantenot@gmail.com>
Tracked-down-by: Lan Tianyu <tianyu.lan@intel.com>
Pull networking fix from David Miller:
"This is a quick one commit pull request to cure the regression
introduced by the MSG_CMSG_COMPAT change."
(Background: commit 1be374a0518a completely broke 32-bit COMPAT handling
by not only disallowing MSG_CMSG_COMPAT from user APIs, but clearing it
in our own internal use too!)
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net:
net: Unbreak compat_sys_{send,recv}msg
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging
Pull staging driver fixes from Greg Kroah-Hartman:
"Here are some staging and IIO driver fixes for the 3.10-rc5 release.
All of them are tiny, and fix a number of reported issues (build and
runtime)"
* tag 'staging-3.10-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging:
iio:inkern: Fix typo/bug in convert raw to processed.
iio: frequency: ad4350: Fix bug / typo in mask
inkern: iio_device_put after incorrect return/goto
staging: alarm-dev: information leak in alarm_compat_ioctl()
iio:callback buffer: free the scan_mask
staging: alarm-dev: information leak in alarm_ioctl()
drivers: staging: zcache: fix compile error
staging: dwc2: fix value of dma_mask
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty
Pull tty/serial driver fixes from Greg Kroah-Hartman:
"Here are some small bugfixes, and one revert, of serial driver issues
that have been reported"
* tag 'tty-3.10-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty:
Revert "serial: 8250: Make SERIAL_8250_RUNTIME_UARTS work correctly"
serial: samsung: enable clock before clearing pending interrupts during init
serial/imx: disable hardware flow control at startup
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb
Pull USB fixes from Greg Kroah-Hartman:
"Here are a number of USB bugfixes and new device ids for the 3.10-rc5
tree.
Nothing major here, a number of new device ids (and movement from the
option to the zte_ev driver of a number of ids that we had previously
gotten wrong, some xhci bugfixes, some usb-serial driver fixes that
were recently found, some host controller fixes / reverts, and a
variety of smaller other things"
* tag 'usb-3.10-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (29 commits)
USB: option,zte_ev: move most ZTE CDMA devices to zte_ev
USB: option: blacklist network interface on Huawei E1820
USB: whiteheat: fix broken port configuration
USB: serial: fix TIOCMIWAIT return value
USB: mos7720: fix hardware flow control
USB: keyspan: remove unused endpoint-array access
USB: keyspan: fix bogus array index
USB: zte_ev: fix broken open
USB: serial: Add Option GTM681W to qcserial device table.
USB: Serial: cypress_M8: Enable FRWD Dongle hidcom device
USB: EHCI: fix regression related to qh_refresh()
usbfs: Increase arbitrary limit for USB 3 isopkt length
USB: zte_ev: fix control-message timeouts
USB: mos7720: fix message timeouts
USB: iuu_phoenix: fix bulk-message timeout
USB: ark3116: fix control-message timeout
USB: mos7840: fix DMA to stack
USB: mos7720: fix DMA to stack
USB: visor: fix initialisation of Treo/Kyocera devices
USB: serial: fix Treo/Kyocera interrrupt-in urb context
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci
Pull PCI fixes from Bjorn Helgaas:
"This fixes a crash when booting a 32-bit kernel via the EFI boot stub.
PCI ROM from EFI
x86/PCI: Map PCI setup data with ioremap() so it can be in highmem"
* tag 'pci-v3.10-fixes-3' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci:
Pull more xfs updates from Ben Myers:
"Here are several fixes for filesystems with CRC support turned on:
fixes for quota, remote attributes, and recovery. There is also some
feature work related to CRCs: the implementation of CRCs for the inode
unlinked lists, disabling noattr2/attr2 options when appropriate, and
bumping the maximum number of ACLs.
I would have preferred to defer this last category of items to 3.11.
This would require setting a feature bit for the on-disk changes, so
there is some pressure to get these in 3.10. I believe this
represents the end of the CRC related queue.
- Rework of dquot CRCs
- Fix for remote attribute invalidation of a leaf
- Fix ordering of transaction replay in recovery
- Implement CRCs for inode unlinked list
- Disable noattr2/attr2 mount options when CRCs are enabled
- Bump the limitation of ACL entries for v5 superblocks"
* tag 'for-linus-v3.10-rc5' of git://oss.sgi.com/xfs/xfs:
xfs: increase number of ACL entries for V5 superblocks
xfs: disable noattr2/attr2 mount options for CRC enabled filesystems
xfs: inode unlinked list needs to recalculate the inode CRC
xfs: fix log recovery transaction item reordering
xfs: fix remote attribute invalidation for a leaf
xfs: rework dquot CRCs
I broke them in this commit:
commit 1be374a0518a288147c6a7398792583200a67261
Author: Andy Lutomirski <luto@amacapital.net>
Date: Wed May 22 14:07:44 2013 -0700
net: Block MSG_CMSG_COMPAT in send(m)msg and recv(m)msg
This patch adds __sys_sendmsg and __sys_sendmsg as common helpers that accept
MSG_CMSG_COMPAT and blocks MSG_CMSG_COMPAT at the syscall entrypoints. It
also reverts some unnecessary checks in sys_socketcall.
Apparently I was suffering from underscore blindness the first time around.
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
Tested-by: Eric Dumazet <edumazet@google.com>
