The commit 83ba9ea8a04b72dfee2515428c15e7414ba4fc61 ommitted the return
line for the old synaptics model accidentally. This resulted in a wrong
check, namely, the dimensions are checked for the old devices that don't
support the query properly.
This patch adds the return line back.
Otherwise we may run into following:
drivers/platform/built-in.o: In function `i8042_lock_chip':
/home/test/ws2/projects/linux-2.6/include/linux/i8042.h:50: multiple definition of `i8042_lock_chip'
drivers/input/serio/built-in.o:/home/test/ws2/projects/linux-2.6/include/linux/i8042.h:50: first defined here
make[1]: *** [drivers/built-in.o] Error 1
make: *** [drivers] Error 2
Signed-off-by: Feng Tang <feng.tang@intel.com>
This patch adds a maintainer for the input multitouch (MT) protocol,
such that get_maintainer.pl selects it whenever an MT event is present
in the patch.
Signed-off-by: Henrik Rydberg <rydberg@euromail.se>
Cintiq 21UX2 added 8 more bits for the tool serial number and more
buttons for the expresskey. We did not enable them properly in the
last patch.
Signed-off-by: Ping Cheng <pingc@wacom.com>
Some of the recent X86_MRST additions make some "select"s
conditional on X86_MRST but missed some related kconfig symbols,
causing:
drivers/built-in.o: In function `ps2_end_command':
(.text+0x257ab2): undefined reference to `i8042_check_port_owner'
(.text+0x257ae1): undefined reference to `i8042_unlock_chip'
drivers/built-in.o: In function `ps2_begin_command':
(.text+0x257b40): undefined reference to `i8042_check_port_owner'
(.text+0x257b6f): undefined reference to `i8042_lock_chip'
when SERIO_I8042=m, SERIO_LIBPS2=y, KEYBOARD_ATKBD=y.
We need to make i8042 dependant upon !X86_MRST and allow deselecting
atkbd on Moorestown even when !CONFIG_EMBEDDED.
Cc: Jacob Pan <jacob.jun.pan@intel.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6:
wimax/i2400m: fix missing endian correction read in fw loader
net8139: fix a race at the end of NAPI
pktgen: Fix accuracy of inter-packet delay.
pkt_sched: gen_estimator: add a new lock
net: deliver skbs on inactive slaves to exact matches
ipv6: fix ICMP6_MIB_OUTERRORS
r8169: fix mdio_read and update mdio_write according to hw specs
gianfar: Revive the driver for eTSEC devices (disable timestamping)
caif: fix a couple range checks
phylib: Add support for the LXT973 phy.
net: Print num_rx_queues imbalance warning only when there are allocated queues
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6
* 'pm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6:
PM / x86: Save/restore MISC_ENABLE register
git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable:
Btrfs: The file argument for fsync() is never null
Btrfs: handle ERR_PTR from posix_acl_from_xattr()
Btrfs: avoid BUG when dropping root and reference in same transaction
Btrfs: prohibit a operation of changing acl's mask when noacl mount option used
Btrfs: should add a permission check for setfacl
Btrfs: btrfs_lookup_dir_item() can return ERR_PTR
Btrfs: btrfs_read_fs_root_no_name() returns ERR_PTRs
Btrfs: unwind after btrfs_start_transaction() errors
Btrfs: btrfs_iget() returns ERR_PTR
Btrfs: handle kzalloc() failure in open_ctree()
Btrfs: handle error returns from btrfs_lookup_dir_item()
Btrfs: Fix BUG_ON for fs converted from extN
Btrfs: Fix null dereference in relocation.c
Btrfs: fix remap_file_pages error
Btrfs: uninitialized data is check_path_shared()
Btrfs: fix fallocate regression
Btrfs: fix loop device on top of btrfs
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6:
PCI: clear bridge resource range if BIOS assigned bad one
PCI: hotplug/cpqphp, fix NULL dereference
Revert "PCI: create function symlinks in /sys/bus/pci/slots/N/"
PCI: change resource collision messages from KERN_ERR to KERN_INFO
Yannick found that video does not work with 2.6.34. The cause of this
bug was that the BIOS had assigned the wrong range to the PCI bridge
above the video device. Before 2.6.34 the kernel would have shrunk
the size of the bridge window, but since
d65245c PCI: don't shrink bridge resources
the kernel will avoid shrinking BIOS ranges.
So zero out the old range if we fail to claim it at boot time; this will
cause us to allocate a new range at startup, restoring the 2.6.34
behavior.
Fixes regression https://bugzilla.kernel.org/show_bug.cgi?id=16009.
Reported-by: Yannick <yannick.roehlly@free.fr>
Acked-by: Bjorn Helgaas <bjorn.helgaas@hp.com>
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
There are devices out there which are PCI Hot-plug controllers with
compaq PCI IDs, but are not bridges, hence have pdev->subordinate
NULL. But cpqphp expects the pointer to be non-NULL.
Add a check to the probe function to avoid oopses like:
BUG: unable to handle kernel NULL pointer dereference at 00000050
IP: [<f82e3c41>] cpqhpc_probe+0x951/0x1120 [cpqphp]
*pdpt = 0000000033779001 *pde = 0000000000000000
The device here was:
00:0b.0 PCI Hot-plug controller [0804]: Compaq Computer Corporation PCI Hotplug Controller [0e11:a0f7] (rev 11)
Subsystem: Compaq Computer Corporation Device [0e11:a2f8]
Cc: Greg KH <greg@kroah.com>
This reverts commit 75568f8094eb0333e9c2109b23cbc8b82d318a3c.
Since they're just a convenience anyway, remove these symlinks since
they're causing duplicate filename errors in the wild.
Acked-by: Alex Chiang <achiang@canonical.com>
We can often deal with PCI resource issues by moving devices around. In
that case, there's no point in alarming the user with messages like these.
There are many bug reports where the message itself is the only problem,
e.g., https://bugs.launchpad.net/ubuntu/+source/linux/+bug/413419 .
Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com>
The "file" argument for fsync is never null so we can remove this check.
What drew my attention here is that 7ea8085910e: "drop unused dentry
argument to ->fsync" introduced an unconditional dereference at the
start of the function and that generated a smatch warning.
Signed-off-by: Chris Mason <chris.mason@oracle.com>
posix_acl_from_xattr() returns both ERR_PTRs and null, but it's OK to
pass null values to set_cached_acl()
If btrfs_ioctl_snap_destroy() deletes a snapshot but finishes
with end_transaction(), the cleaner kthread may come in and
drop the root in the same transaction. If that's the case, the
root's refs still == 1 in the tree when btrfs_del_root() deletes
the item, because commit_fs_roots() hasn't updated it yet (that
happens during the commit).
This wasn't a problem before only because
btrfs_ioctl_snap_destroy() would commit the transaction before dropping
the dentry reference, so the dead root wouldn't get queued up until
after the fs root item was updated in the btree.
Since it is not an error to drop the root reference and the root in the
same transaction, just drop the BUG_ON() in btrfs_del_root().
Signed-off-by: Sage Weil <sage@newdream.net>
when used Posix File System Test Suite(pjd-fstest) to test btrfs,
some cases about setfacl failed when noacl mount option used.
I simplified used commands in pjd-fstest, and the following steps
can reproduce it.
# cd btrfs-part/
# mkdir aaa
# setfacl -m m::rw aaa <- successed, but not expected by pjd-fstest.
I checked ext3, a warning message occured, like as:
setfacl: aaa/: Operation not supported
Certainly, it's expected by pjd-fstest.
So, i compared acl.c of btrfs and ext3. Based on that, a patch created.
Fortunately, it works.
Signed-off-by: Shi Weihua <shiwh@cn.fujitsu.com>
On btrfs, do the following
# su user1
# cd btrfs-part/
# touch aaa
# getfacl aaa
# file: aaa
# owner: user1
# group: user1
user::rw-
group::rw-
other::r--
# su user2
# cd btrfs-part/
# setfacl -m u::rwx aaa
# getfacl aaa
# file: aaa
# owner: user1
# group: user1
user::rwx <- successed to setfacl
group::rw-
other::r--
but we should prohibit it that user2 changing user1's acl.
In fact, on ext3 and other fs, a message occurs:
setfacl: aaa: Operation not permitted
This patch fixed it.
btrfs_lookup_dir_item() can return either ERR_PTRs or null.
btrfs_read_fs_root_no_name() returns ERR_PTRs on error so I added a
check for that. It's not clear to me if it can also return NULL
pointers or not so I left the original NULL pointer check as is.
This was added by a22285a6a3: "Btrfs: Integrate metadata reservation
with start_transaction". If we goto out here then we skip all the
unwinding and there are locks still held etc.
btrfs_iget() returns an ERR_PTR() on failure and not null.
Unwind and return -ENOMEM if the allocation fails here.
If btrfs_lookup_dir_item() fails, we should can just let the mount fail
with an error.
Tree blocks can live in data block groups in FS converted from extN.
So it's easy to trigger the BUG_ON.
Signed-off-by: Yan Zheng <zheng.yan@oracle.com>
Fix a potential null dereference in relocation.c
Acked-by: Dan Carpenter <error27@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/inaky/wimax
i2400m_fw_hdr_check() was accessing hardware field
bcf_hdr->module_type (little endian 32) without converting to host
byte sex.
Reported-by: Данилин Михаил <mdanilin@nsg.net.ru>
Signed-off-by: Inaky Perez-Gonzalez <inaky@linux.intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6
* 'rc-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6:
kbuild: Create output directory in Makefile.modbuiltin
kbuild: Generate modules.builtin in make modules
git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6
* 'urgent' of git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6:
pcmcia: avoid validate_cis failure on CIS override
pcmcia: dev_node removal bugfix
pcmcia: yenta_socket.c Remove extra #ifdef CONFIG_YENTA_TI
pcmcia: only keep saved I365_CSCINT flag if there is no PCI irq
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client:
ceph: try to send partial cap release on cap message on missing inode
ceph: release cap on import if we don't have the inode
ceph: fix misleading/incorrect debug message
ceph: fix atomic64_t initialization on ia64
ceph: fix lease revocation when seq doesn't match
ceph: fix f_namelen reported by statfs
ceph: fix memory leak in statfs
ceph: fix d_subdirs ordering problem
when we use remap_file_pages() to remap a file, remap_file_pages always return
error. It is because btrfs didn't set VM_CAN_NONLINEAR for vma.
Signed-off-by: Miao Xie <miaox@cn.fujitsu.com>
refs can be used with uninitialized data if btrfs_lookup_extent_info()
fails on the first pass through the loop. In the original code if that
happens then check_path_shared() probably returns 1, this patch
changes it to return 1 for safety.
Seems that when btrfs_fallocate was converted to use the new ENOSPC stuff we
dropped passing the mode to the function that actually does the preallocation.
This breaks anybody who wants to use FALLOC_FL_KEEP_SIZE. Thanks,
Signed-off-by: Josef Bacik <josef@redhat.com>
We cannot use the loop device which has been connected to a file in the btrf
The reproduce steps is following:
# dd if=/dev/zero of=vdev0 bs=1M count=1024
# losetup /dev/loop0 vdev0
# mkfs.btrfs /dev/loop0
failed to zero device start -5
The reason is that the btrfs don't implement either ->write_begin or ->write
the VFS API, so we fix it by setting ->write to do_sync_write().
fix a race at the end of NAPI complete processing, it had
better do __napi_complete() first before re-enable interrupt.
Signed-off-by:Figo.zhang <figo1802@gmail.com>
This patch correct a bug in the delay of pktgen.
It makes sure the inter-packet interval is accurate.
Signed-off-by: Daniel Turull <daniel.turull@gmail.com>
Signed-off-by: Robert Olsson <robert.olsson@its.uu.se>
gen_kill_estimator() / gen_new_estimator() is not always called with
RTNL held.
net/netfilter/xt_RATEEST.c is one user of these API that do not hold
RTNL, so random corruptions can occur between "tc" and "iptables".
Add a new fine grained lock instead of trying to use RTNL in netfilter.
Currently, the accelerated receive path for VLAN's will
drop packets if the real device is an inactive slave and
is not one of the special pkts tested for in
skb_bond_should_drop(). This behavior is different then
the non-accelerated path and for pkts over a bonded vlan.
For example,
vlanx -> bond0 -> ethx
will be dropped in the vlan path and not delivered to any
packet handlers at all. However,
bond0 -> vlanx -> ethx
and
bond0 -> ethx
will be delivered to handlers that match the exact dev,
because the VLAN path checks the real_dev which is not a
slave and netif_recv_skb() doesn't drop frames but only
delivers them to exact matches.
This patch adds a sk_buff flag which is used for tagging
skbs that would previously been dropped and allows the
skb to continue to skb_netif_recv(). Here we add
logic to check for the deliver_no_wcard flag and if it
is set only deliver to handlers that match exactly. This
makes both paths above consistent and gives pkt handlers
a way to identify skbs that come from inactive slaves.
Without this patch in some configurations skbs will be
delivered to handlers with exact matches and in others
be dropped out right in the vlan path.
I have tested the following 4 configurations in failover modes
and load balancing modes.
# bond0 -> ethx
# vlanx -> bond0 -> ethx
# bond0 -> vlanx -> ethx
# bond0 -> ethx
vlanx -> --
Signed-off-by: John Fastabend <john.r.fastabend@intel.com>
If we have enough memory to allocate a new cap release message, do so, so
that we can send a partial release message immediately. This keeps us from
making the MDS wait when the cap release it needs is in a partially full
release message.
If we fail because of ENOMEM, oh well, they'll just have to wait a bit
longer.
If we get an IMPORT that give us a cap, but we don't have the inode, queue
a release (and try to send it immediately) so that the MDS doesn't get
stuck waiting for us.
Nothing is released here: the caps message is simply ignored in this case.
bdi_seq is an atomic_long_t but we're using ATOMIC_INIT, which causes
build failures on ia64. This patch fixes it to use ATOMIC_LONG_INIT.
Signed-off-by: Jeff Mahoney <jeffm@suse.com>
The data in the cmd_block buffers may reach the main memory after the
writel() to the device ports. This patch introduces two calls to wmb()
to ensure the relative ordering.
Tested-by: Colin Tuckley <colin.tuckley@arm.com>
Cc: Tejun Heo <tj@kernel.org>
Cc: Jeff Garzik <jeff@garzik.org>
cb->atapi.cdb is an array of 16 u8 elements. The call too memset()
would set the first part of the sge array to zero as well. It's not
a packed struct.
This one has been around for five years. I found it with Smatch. I
think the reason no one has seen it before is because we normally call
sil24_fill_sg() and that overwrites sge with proper information?
* 'kvm-updates/2.6.35' of git://git.kernel.org/pub/scm/virt/kvm/kvm:
KVM: read apic->irr with ioapic lock held
KVM: ia64: Add missing spin_unlock in kvm_arch_hardware_enable()
KVM: Fix order passed to iommu_unmap
KVM: MMU: Remove user access when allowing kernel access to gpte.w=0 page
KVM: MMU: invalidate and flush on spte small->large page size change
KVM: SVM: Implement workaround for Erratum 383
KVM: SVM: Handle MCEs early in the vmexit process
KVM: powerpc: fix init/exit annotation
Read ioapic->irr inside ioapic->lock protected section.
KVM-Stable-Tag
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
* 'for-linus2' of git://git.kernel.dk/linux-2.6-block:
pipe: fix check in "set size" fcntl
pipe: fix pipe buffer resizing
block: remove duplicate BUG_ON() in bd_finish_claiming()
block: bd_start_claiming cleanup
block: bd_start_claiming fix module refcount
