2008-09-29hrtimer: mark migration stateThomas Gleixner
Impact: during migration active hrtimers can be seen as inactive The migration code removes the hrtimers from the queues of the dead CPU and sets the state temporary to INACTIVE. The enqueue code sets it to ACTIVE/PENDING again. Prevent that the wrong state can be seen by using a separate migration state bit. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-09-29hrtimer: fix migration of CB_IRQSAFE_NO_SOFTIRQ hrtimersThomas Gleixner
Impact: Stale timers after a CPU went offline. commit 37bb6cb4097e29ffee970065b74499cbf10603a3 hrtimer: unlock hrtimer_wakeup changed the hrtimer sleeper callback mode to CB_IRQSAFE_NO_SOFTIRQ due to locking problems. A result of this change is that when enqueue is called for an already expired hrtimer the callback function is not longer called directly from the enqueue code. The normal callers have been fixed in the code, but the migration code which moves hrtimers from a dead CPU to a live CPU was not made aware of this. This can be fixed by checking the timer state after the call to enqueue in the migration code. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-09-29hrtimer: migrate pending list on cpu offlineThomas Gleixner
Impact: hrtimers which are on the pending list are not migrated at cpu offline and can be stale forever Add the pending list migration when CONFIG_HIGH_RES_TIMERS is enabled Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-09-25IPoIB: Fix crash when path record fails after path flushRoland Dreier
Commit ee1e2c82 ("IPoIB: Refresh paths instead of flushing them on SM change events") changed how paths are flushed on an SM event. This change introduces a problem if the path record query triggered by fails, causing path->ah to become NULL. A later successful path query will then trigger WARN_ON() in path_rec_completion(), and crash because path->ah has already been freed, so the ipoib_put_ah() inside the lock in path_rec_completion() may actually drop the last reference (contrary to the comment that claims this is safe). Fix this by updating path->ah and freeing old_ah only when the path record query is successful. This prevents the neighbour AH and that path AH from getting out of sync. This fixes <https://bugs.openfabrics.org/show_bug.cgi?id=1194> Reported-by: Rabah Salem <ravah@mellanox.com> Debugged-by: Eli Cohen <eli@mellanox.co.il> Signed-off-by: Roland Dreier <rolandd@cisco.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-09-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: netfilter: ip6t_{hbh,dst}: Rejects not-strict mode on rule insertion ath9k: disable MIB interrupts to fix interrupt storm [Bluetooth] Fix USB disconnect handling of btusb driver [Bluetooth] Fix wrong URB handling of btusb driver [Bluetooth] Fix I/O errors on MacBooks with Broadcom chips
2008-09-24Merge branch 'i2c-for-linus' of git://jdelvare.pck.nerim.net/jdelvare-2.6Linus Torvalds
* 'i2c-for-linus' of git://jdelvare.pck.nerim.net/jdelvare-2.6: i2c: Fix mailing lists in two MAINTAINERS entries i2c-dev: Return correct error code on class_create() failure i2c-powermac: Fix section for probe and remove functions
2008-09-24Merge branch 'timers-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86: prevent stale state of c1e_mask across CPU offline/online, fix
2008-09-24Merge branch 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linusLinus Torvalds
* 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linus: [MIPS] Fixe the definition of PTRS_PER_PGD [MIPS] au1000: Fix gpio direction
2008-09-24MN10300: Make sched_clock() report time since bootDavid Howells
Make sched_clock() report time since boot rather than time since last timer interrupt. Make sched_clock() expand and scale the 32-bit TSC value running at IOCLK speed (~33MHz) to a 64-bit nanosecond counter, using cnt32_to_63() acquired from the ARM arch and without using slow DIVU instructions every call. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-09-24MN10300: Move asm-arm/cnt32_to_63.h to include/linux/David Howells
Move asm-arm/cnt32_to_63.h to include/linux/ so that MN10300 can make use of it too. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-09-24Merge branch 'master' of ↵David S. Miller
2008-09-24netfilter: ip6t_{hbh,dst}: Rejects not-strict mode on rule insertionYasuyuki Kozakai
The current code ignores rules for internal options in HBH/DST options header in packet processing if 'Not strict' mode is specified (which is not implemented). Clearly it is not expected by user. Kernel should reject HBH/DST rule insertion with 'Not strict' mode in the first place. Signed-off-by: Yasuyuki Kozakai <yasuyuki.kozakai@toshiba.co.jp> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-24Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs: 9p: fix put_data error handling 9p: use an IS_ERR test rather than a NULL test 9p: introduce missing kfree 9p-trans_fd: fix and clean up module init/exit paths 9p-trans_fd: don't do fs segment mangling in p9_fd_poll() 9p-trans_fd: clean up p9_conn_create() 9p-trans_fd: fix trans_fd::p9_conn_destroy() 9p: implement proper trans module refcounting and unregistration
2008-09-249p: fix put_data error handlingEric Van Hensbergen
Abhishek Kulkarni pointed out an inconsistency in the way errors are returned from p9_put_data. On deeper exploration it seems the error handling for this path was completely wrong. This patch adds checks for allocation problems and propagates errors correctly. Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2008-09-249p: use an IS_ERR test rather than a NULL testJulien Brunel
In case of error, the function p9_client_walk returns an ERR pointer, but never returns a NULL pointer. So a NULL test that comes after an IS_ERR test should be deleted. The semantic match that finds this problem is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @match_bad_null_test@ expression x, E; statement S1,S2; @@ x = p9_client_walk(...) ... when != x = E * if (x != NULL) S1 else S2 // </smpl> Signed-off-by: Julien Brunel <brunel@diku.dk> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2008-09-249p: introduce missing kfreeJulia Lawall
Error handling code following a kmalloc should free the allocated data. The semantic match that finds the problem is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @r exists@ local idexpression x; statement S; expression E; identifier f,l; position p1,p2; expression *ptr != NULL; @@ ( if ((x@p1 = \(kmalloc\|kzalloc\|kcalloc\)(...)) == NULL) S | x@p1 = \(kmalloc\|kzalloc\|kcalloc\)(...); ... if (x == NULL) S ) <... when != x when != if (...) { <+...x...+> } x->f = E ...> ( return \(0\|<+...x...+>\|ptr\); | return@p2 ...; ) @script:python@ p1 << r.p1; p2 << r.p2; @@ print "* file: %s kmalloc %s return %s" % (p1[0].file,p1[0].line,p2[0].line) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2008-09-249p-trans_fd: fix and clean up module init/exit pathsTejun Heo
trans_fd leaked p9_mux_wq on module unload. Fix it. While at it, collapse p9_mux_global_init() into p9_trans_fd_init(). It's easier to follow this way and the global poll_tasks array is about to removed anyway. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2008-09-249p-trans_fd: don't do fs segment mangling in p9_fd_poll()Tejun Heo
p9_fd_poll() is never called with user pointers and f_op->poll() doesn't expect its arguments to be from userland. There's no need to set kernel ds before calling f_op->poll() from p9_fd_poll(). Remove it. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2008-09-249p-trans_fd: clean up p9_conn_create()Tejun Heo
* Use kzalloc() to allocate p9_conn and remove 0/NULL initializations. * Clean up error return paths. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2008-09-249p-trans_fd: fix trans_fd::p9_conn_destroy()Tejun Heo
p9_conn_destroy() first kills all current requests by calling p9_conn_cancel(), then waits for the request list to be cleared by waiting on p9_conn->equeue. After that, polling is stopped and the trans is destroyed. This sequence has a few problems. * Read and write works were never cancelled and the p9_conn can be destroyed while the works are running as r/w works remove requests from the list and dereference the p9_conn from them. * The list emptiness wait using p9_conn->equeue wouldn't trigger because p9_conn_cancel() always clears all the lists and the only way the wait can be triggered is to have another task to issue a request between the slim window between p9_conn_cancel() and the wait, which isn't safe under the current implementation with or without the wait. This patch fixes the problem by first stopping poll, which can schedule r/w works, first and cancle r/w works which guarantees that r/w works are not and will not run from that point and then calling p9_conn_cancel() and do the rest of destruction. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2008-09-249p: implement proper trans module refcounting and unregistrationTejun Heo
9p trans modules aren't refcounted nor were they unregistered properly. Fix it. * Add 9p_trans_module->owner and reference the module on each trans instance creation and put it on destruction. * Protect v9fs_trans_list with a spinlock. This isn't strictly necessary as the list is manipulated only during module loading / unloading but it's a good idea to make the API safe. * Unregister trans modules when the corresponding module is being unloaded. * While at it, kill unnecessary EXPORT_SYMBOL on p9_trans_fd_init(). Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2008-09-24ath9k: disable MIB interrupts to fix interrupt stormLuis R. Rodriguez
Enabling the MIB interrupts has proven to cause an interrupt storm after 7 hours of run. We will make use of the MIB interrupt once we have ANI supported added so for now to cure this we disable the interrupt. The interrupt storm can be seen as follows after 7 hours of run as reported by Steven Noonan <steven@uplinklabs.net>: 18:28:38 sum 1106.00 18:28:39 sum 1037.62 18:28:40 sum 1069.00 18:28:41 sum 1167.00 18:28:42 sum 1155.00 18:28:43 sum 1339.00 18:28:44 sum 18355.00 18:28:45 sum 17845.45 18:28:46 sum 15285.00 18:28:47 sum 17511.00 18:28:48 sum 17568.69 18:28:49 sum 17704.04 18:28:50 sum 18566.67 18:28:51 sum 18913.13 at 18:28:44 the MIB interrupt kicked off and caused huge latency which can be seen even on a video he submitted: http://www.youtube.com/watch?v=4GeCx1gZMpA Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-09-24i2c: Fix mailing lists in two MAINTAINERS entriesJean Delvare
Two MAINTAINER entries (I2C/SMBUS STUB DRIVER and SIS 96X I2C/SMBUS DRIVER) were improperly pointing to the lm-sensors mailing list instead of the i2c mailing list. Fix them. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Mark M. Hoffman <mhoffman@lightlink.com>
2008-09-24i2c-dev: Return correct error code on class_create() failureSven Wegener
We need to convert the error pointer from class_create(), else we'll return the successful return code from register_chrdev() on failure. Signed-off-by: Sven Wegener <sven.wegener@stealer.net> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-09-24i2c-powermac: Fix section for probe and remove functionsUwe Kleine-Koenig
__devexit for i2c_powermac_probe is obviously wrong. In the definition of struct platform_driver i2c_powermac_driver the remove function i2c_powermac_remove is wrapped in __devexit_p, so it should be defined using __devexit. Signed-off-by: Uwe Kleine-Koenig <ukleinek@informatik.uni-freiburg.de> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-09-24x86: prevent stale state of c1e_mask across CPU offline/online, fixMarc Dionne
Fix build error introduced by commit 4faac97d44ac27 ("x86: prevent stale state of c1e_mask across CPU offline/online"). process_32.c needs to include idle.h to get the prototype for c1e_remove_cpu() Signed-off-by: Marc Dionne <marc.c.dionne@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-09-24[MIPS] Fixe the definition of PTRS_PER_PGDJack Tan
When we use > 4KB's page size the original definition is not consistent with PGDIR_SIZE. For exeample, if we use 16KB page size the PGDIR_SHIFT is (14-2) + 14 = 26, PGDIR_SIZE is 2^26,so the PTRS_PER_PGD should be: 2^32/2^26 = 2^6 but the original definition of PTRS_PER_PGD is 4096 (PGDIR_ORDER = 0). So, this definition needs to be consistent with the PGDIR_SIZE. And the new definition is consistent with the PGD init in pagetable_init(). Signed-off-by: Dajie Tan <jiankemeng@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-09-24[MIPS] au1000: Fix gpio directionBruno Randolf
When setting the direction of one GPIO pin we have to keep the state of the other pins, hence use binary OR. Also gpio_direction_output() wants to set an initial value, so add that too. This fixes a problem with the USB power switch on mtx-1 boards. Signed-off-by: Bruno Randolf <br1@einfach.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-09-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (23 commits) USB: revert recovery from transient errors usb: unusual devs patch for Nokia 5310 Music Xpress usb: ftdi_sio: add support for Domintell devices USB: drivers/usb/musb/: disable it on SuperH USB Serial: Sierra: Add MC8785 VID/PID USB: serial: add ZTE CDMA Tech id to option driver USB: ftdi_sio: Add 0x5050/0x0900 USB IDs (Papouch Quido USB 4/4) usb serial: ti_usb_3410_5052 obviously broken by firmware changes USB: fsl_usb2_udc: fix VDBG() format string USB: unusual_devs addition for RockChip MP3 player USB: SERIAL CP2101 add device IDs usb-serial: Add Siemens EF81 to PL-2303 hack triggers USB: fix EHCI periodic transfers usb: musb: fix include path USB: Fixing Nokia 3310c in storage mode usb gadget: fix omap_udc DMA regression USB: update of Documentation/usb/anchors.txt USB: fix hcd interrupt disabling USB: Correct Sierra Wireless USB EVDO Modem Device ID USB: Fix the Nokia 6300 storage-mode. ...
2008-09-23Merge branch 'timers-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: timers: fix build error in !oneshot case x86: c1e_idle: don't mark TSC unstable if CPU has invariant TSC x86: prevent C-states hang on AMD C1E enabled machines clockevents: prevent mode mismatch on cpu online clockevents: check broadcast device not tick device clockevents: prevent stale tick_next_period for onlining CPUs x86: prevent stale state of c1e_mask across CPU offline/online clockevents: prevent cpu online to interfere with nohz
2008-09-23Merge branch 'sched-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'sched-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: sched: fix init_hrtick() section mismatch warning
2008-09-23Merge branch 'x86-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86: fix 27-rc crash on vsmp due to paravirt during module load x86, oprofile: BUG scheduling while atomic AMD IOMMU: protect completion wait loop with iommu lock AMD IOMMU: set iommu sunc flag after command queuing
2008-09-23USB: revert recovery from transient errorsAlan Stern
This patch (as1135) essentially reverts the major parts of two earlier patches to usbcore, because they ended up causing a regression. Trying to recover from transient communication errors can lead to other problems, because operations that failed during the error period are not always retried. The simplest example is the initial Set-Config request sent after device enumeration; if it gets lost then it will not be retried and the device will remain unconfigured. This patch restores the old behavior in which any port disconnect or port disable causes the entire device structure to be removed, fixing a reported regression. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Tested-by: Frans Pop <elendil@planet.nl> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-09-23usb: unusual devs patch for Nokia 5310 Music XpressDavid Almaroad
The Nokia 5310 Music Xpress phone reports one too many sectors in usb-storage mode. This patch resolves that. Signed-off-by: David Almaroad <dalmaroad@gmail.com> Cc: Matthew Dharm <mdharm-usb@one-eyed-alien.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-09-23usb: ftdi_sio: add support for Domintell devicesGaetan Carlier
Support for Domintell devices (FTDI FT232BM based) : DGQG and DUSB01 module. PIDs were missing. Signed-off-by: Gaetan Carlier <gcpatch@gmail.com> Cc: Greg Kroah-Hartman <gregkh@suse.de> Cc: Ian Abbott <abbotti@mev.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-09-23USB: drivers/usb/musb/: disable it on SuperHAndrew Morton
In file included from drivers/usb/musb/musb_core.h:59, from drivers/usb/musb/musb_core.c:108: drivers/usb/musb/musb_io.h:42: error: conflicting types for '__raw_readsl' /usr/src/devel/arch/sh/include/asm/io.h:112: error: previous declaration of '__raw_readsl' was here drivers/usb/musb/musb_io.h:42: error: conflicting types for '__raw_readsl' /usr/src/devel/arch/sh/include/asm/io.h:112: error: previous declaration of '__raw_readsl' was here drivers/usb/musb/musb_io.h:44: error: conflicting types for 'readsw' /usr/src/devel/arch/sh/include/asm/io.h:164: error: previous definition of 'readsw' was here drivers/usb/musb/musb_io.h:46: error: conflicting types for 'readsb' /usr/src/devel/arch/sh/include/asm/io.h:163: error: previous definition of 'readsb' was here drivers/usb/musb/musb_io.h:49: error: conflicting types for '__raw_writesl' /usr/src/devel/arch/sh/include/asm/io.h:111: error: previous declaration of '__raw_writesl' was here drivers/usb/musb/musb_io.h:49: error: conflicting types for '__raw_writesl' /usr/src/devel/arch/sh/include/asm/io.h:111: error: previous declaration of '__raw_writesl' was here drivers/usb/musb/musb_io.h:51: error: conflicting types for 'writesw' /usr/src/devel/arch/sh/include/asm/io.h:164: error: previous definition of 'writesw' was here drivers/usb/musb/musb_io.h:53: error: conflicting types for 'writesb' /usr/src/devel/arch/sh/include/asm/io.h:163: error: previous definition of 'writesb' was here Cc: Karsten Keil <kkeil@suse.de> Cc: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-09-23USB Serial: Sierra: Add MC8785 VID/PIDKevin Lloyd
Add another MC8785 VID/PID Signed-off-by: Kevin Lloyd <klloyd@sierrawireless.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-09-23USB: serial: add ZTE CDMA Tech id to option driverOtavio Salvador
Signed-off-by: Otavio Salvador <otavio@ossystems.com.br> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-09-23USB: ftdi_sio: Add 0x5050/0x0900 USB IDs (Papouch Quido USB 4/4)Jaroslav Kysela
USB: ftdi_sio: Add 0x5050/0x0900 USB IDs (Papouch Quido USB 4/4) Signed-off-by: Jaroslav Kysela <perex@perex.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-09-23usb serial: ti_usb_3410_5052 obviously broken by firmware changesChris Adams
While making some other changes to ti_usb_3410_5052, I noticed that the changes made to move the firmware loading to a separate function are broken (in ti_download_firmware(), status is set to -ENOMEM and never changed). This means the driver will never initialize the device properly. It looks like status was supposed to get the result of ti_do_download(). Signed-off-by: Chris Adams <cmadams@hiwaay.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-09-23USB: fsl_usb2_udc: fix VDBG() format stringPeter Korsgaard
Fixes: drivers/usb/gadget/fsl_usb2_udc.c: In function 'dr_controller_setup': drivers/usb/gadget/fsl_usb2_udc.c:229: warning: format '%p' expects type 'void *', but argument 3 has type 'int' Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-09-23USB: unusual_devs addition for RockChip MP3 playerAlan Stern
This patch (as1136) adds an unusual_devs entry for a version of the RockChip MP3 player which can't handle the MODE SENSE command used for write-protect detection. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-09-23USB: SERIAL CP2101 add device IDsCraig Shelley
Signed-off-by: Craig Shelley <craig@microtron.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-09-23usb-serial: Add Siemens EF81 to PL-2303 hack triggersAndreas Bombe
This hardware needs the pl2303 hack in order to work properly :( Signed-off-by: Andreas Bombe <aeb@debian.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-09-23USB: fix EHCI periodic transfersDavid Brownell
As noted by Stefan Neis <Stefan.Neis@kobil.com>, we had a recent regression with EHCI periodic transfers, in some (seemingly not all that common) cases. The root cause was that the schedule activation was only loosely coupled to the addition or removal of transfers, so two different execution contexts could both think they had to deactivate (or conversely activate) the schedule. So this fix tightens that coupling, managing it more like a refcount. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-09-23usb: musb: fix include pathFelipe Balbi
headers were moved, fixing. Signed-off-by: Felipe Balbi <felipe.balbi@nokia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-09-23USB: Fixing Nokia 3310c in storage modeFilip Joelsson
I had trouble connecting my cell phone as a storage device - so I added it to the unusual_devs.h list. I had trouble with the bcdDeviceMin and Max values - so after some experimenting I made it pretty inclusive. From: Filip Joelsson <filip@blueturtle.nu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-09-23usb gadget: fix omap_udc DMA regressionDavid Brownell
This resolves another regression caused by the "use omap_read/write instead of __REG" patch: the hardware address used for DMA to/from the UDC became wrong. Bug noted by Russell King. Reported-by: Russell King <rmk@arm.linux.org.uk> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-09-23USB: update of Documentation/usb/anchors.txtOliver Neukum
The extended anchor API is documented Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-09-23USB: fix hcd interrupt disablingGeoff Levand
Commit de85422b94ddb23c021126815ea49414047c13dc, 'USB: fix interrupt disabling for HCDs with shared interrupt handlers' changed usb_add_hcd() to strip IRQF_DISABLED from irqflags prior to calling request_irq() with the justification that such a removal was necessary for shared interrupts to work properly. Unfortunately, the change in that commit unconditionally removes the IRQF_DISABLED flag, causing problems on platforms that don't use a shared interrupt but require IRQF_DISABLED. This change adds a check for IRQF_SHARED prior to removing the IRQF_DISABLED flag. Fixes the PS3 system startup hang reported with recent Fedora and OpenSUSE kernels. Note that this problem is hidden when CONFIG_LOCKDEP=y (ps3_defconfig), as local_irq_enable_in_hardirq() is defined as a null statement for that config. CC: stable <stable@kernel.org> Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: Stefan Becker <Stefan.Becker@nokia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
