Now, ir_input_free does more than just freeing the keytab. Better to
rename it as ir_input_unregister.
Move non-V4L specific stuff from ir-functions ir_input_init() into
a new function to register ir devices: ir_input_register().
Split the ir-common into two separate modules:
- ir-core: it is the IR-independent functions;
- ir-common: has the common part used by V4L drivers.
This is the first step of creating a common code for IR that can be
used by other input devices.
For now, keep IR dir at drivers/media, to easy the movement of the IR files,
but later patches may move it to drivers/IR or drivers/input/IR.
No functional changes is done on this patch.
Memset should be given the size of the structure, not the size of the pointer.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
type T;
T *x;
expression E;
memset(x, E, sizeof(
x))
// </smpl>
Signed-off-by: Douglas Schilling Landgraf <dougsland@redhat.com>
// <smpl>
type T;
T *x;
expression E;
x))
// </smpl>
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Add automatic probing of ports 0x284 and 0x384 to radio-sf16fmi if no card is
found using PnP.
Signed-off-by: Ondrej Zary <linux@rainbow-software.org>
Fix completely broken mute handling radio-sf16fmi.
The sound was muted immediately after tuning in KRadio.
Also fix typos and add SF16-FMP to the texts.
Acked-by: Petr Vandrovec <petr@vandrovec.name>
The function vpif_remove is used only wrapped by __devexit_p so define
it using __devexit.
The function vpfe_remove is used only wrapped by __devexit_p so define
it using __devexit.
sh_mobile_ceu_remove
The function sh_mobile_ceu_remove is defined using __devexit, so don't
use __exit_p but __devexit_p to wrap it.
The function vpss_remove is used only wrapped by __devexit_p so define
it using __devexit.
Currently, i2c_debug shows up w/o a desc in modinfo, and i2c_hw shows
up with i2c_debug's desc. Fix that.
[dougsland@redhat.com: fixed checkpatch.pl warning (space between MODULE_PARM_DESC arguments)]
Signed-off-by: Jarod Wilson <jarod@redhat.com>
This patch is to support PM of the si470x i2c driver.
Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com>
Acked-by: Tobias Lorenz <tobias.lorenz@gmx.net>
This patch is to support RDS on si470x i2c driver. The routine of RDS
operation is almost same with thing of usb driver, but this uses RDS
interrupt.
The read and poll file operations of the si470x usb driver can be used
also equally on the si470x i2c driver, so they go to the common file.
If a USERPTR address that is not aligned to page boundary is passed to the
videobuf_dma_contig_user_get() function, it saves a page aligned address to
the dma_handle. This is not correct. This issue is observed when using USERPTR
IO machism for buffer exchange.
Updates from last version:-
Adding offset for size calculation as per comment from Magnus Damm. This
ensures the last page is also included for checking if memory is
contiguous.
Signed-off-by: Muralidharan Karicheri <m-karicheri2@ti.com>
Acked-by: Magnus Damm <damm@opensource.se>
There are old bttv-driven Hauppauge WinTV series cards that have
their IR part at i2c addr 0x71, which doesn't get considered in the
new 2.6.31 i2c code.
From a 2.6.29 kernel:
lirc_i2c: chip 0x10005 found @ 0x71 (Hauppauge PVR150)
Minor cosmetic glitch, the card in question isn't actually a PVR-150, its:
03:06.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
Subsystem: Hauppauge computer works Inc. WinTV Series
Flags: bus master, medium devsel, latency 32, IRQ 19
Memory at f4ffe000 (32-bit, prefetchable) [size=4K]
Capabilities: [44] Vital Product Data
Capabilities: [4c] Power Management version 2
Kernel driver in use: bttv
Kernel modules: bttv
Device ID: 0x109e:0x036e, Sub-Device ID: 0x0070:0x13eb
This simply adds 0x71 to the list of addresses i2c_new_probed_device should
consider, which gets IR working on this card again.
Reported-by: Adam Williamson <awilliam@redhat.com>
Tested-by: Adam Williamson <awilliam@redhat.com>
This was found with a static checker and has not been tested, but it seems
pretty clear that the mutex_lock() was supposed to be mutex_unlock()
Replace MAKE_STRING to __stringify macro
Signed-off-by: Thiago Farina <tfransosi@gmail.com>
This patch fixes a small issue where modinfo says the parameter "trace" is always available, while
it only works if CONFIG_USB_PWC_DEBUG is enabled.
Signed-off-by: Andrea Odetti <mariofutire@googlemail.com>
write sequence
This patch fixes the behaviour of the dibusb-i2c-access which was previously changed to avoid accidental EEprom writes:
Now it allow i2c-reads without prepended i2c-writes, but it is still not doing anything in case the EEprom is addressed.
Thanks to Mario Bachmann for testing.
Tested-by: Mario Bachmann <grafgrimm77@gmx.de>
Cc: Mario Bachmann <grafgrimm77@gmx.de>
Signed-off-by: Patrick Boettcher <pboettcher@kernellabs.com>
saa7134: Add support for IR reciever on card LifeView FlyDVB Trio
To unsubscribe from this list: send the line "unsubscribe linux-media" in
the body of a message to majordomo@vger.kernel.org
More majordomo info at http://vger.kernel.org/majordomo-info.html
[mchehab@redhat.com: CodingStyle fixes and ported upstream]
Tested-by: Petr Fiala <petr.fiala@gmail.com>
Signed-off-by: Lukas Karas <lukas.karas@centrum.cz>
X-Patchwork-Id: 62090
Merge two ifs: the condition is the same. The second if
uses the ncoeff which is initialized in the first if.
Cc: Patrick Boettcher <pboettcher@kernellabs.com>
Signed-off-by: Márton Németh <nm127@freemail.hu>
Enhance status lock behaviour.
Signed-off-by: Olivier Grenie <olivier.grenie@dibcom.fr>
Add parameter to change the buffer size. This buffer size is specified
in number of Ts packet. This parameter is stored inside the state.
For firmware higher than 1.21, the xfer buffer size can be changed
inside the dib0700 usb bridge the firware version is stored inside the
state
STK807xPVR: correct the enumeration
previous patch
This patch changes most of the Codingstyle violations which were
introduced by the previous patch. Line length less that 80 chars are
not corrected.
Signed-off-by: Olivier Grenie <Olivier.Grenie@dibcom.fr>
This patchs adds support for the DiBcom DiB0090 RF tuner and for
DiBcom's reference design STK8096GP. Small extracts of the DiB0070 and
the DiB8000-driver into a common codebase.
The PCTV 74e is not a design based on the dib0700-USB-device
controller thus we should not have its USB IDs inside.
This reverts partly:
Add support for PCTV 74e (Pinnacle) + fix USB vendor IDs
This patch adds support for PCTV 74e (Pinnacle) and it fixes the USB vendor IDs for PCTV (f.k.a Pinnacle).
For convenience all new PCTV USB product IDs are also existing with Pinnacle's USB vendor ID.
The device is bootingcorrectly, but no frontend is attached.
This patch corrects this behaviour.
Signed-off-by: Pedro Andres Aranda Gutierrez <paaguti@gmail.com>
Genpix is demodulating DVB-S-like signal with 8PSK modulation used) -
this non-standard behaviour was broken by rejecting 8PSK in a standard
DVB-S tune request. This problem is fixed by simply reverting back to
the drivers original behavior with this patch.
This patch adds a fix to accept frequency with its center shifted.
The driver used to accept center frequencies of the normal UHF band channels,
but in ISDB-T, center frequency is shifted with 1/7MHz.
It was shifted internally in the driver,
but this patch enables to accept both types of frequency.
Signed-off-by: Akihiro Tsukada <tskd2@yahoo.co.jp>
initialized drvdata
As reported by Sander Eikelenboom <linux@eikelemboon.it>:
> Tried to update my v4l-dvb modules today, but got a bug with my pinnacle
> card, seems to be related to the recent changes in the ir code.
> Dec 5 23:30:25 security kernel: [ 5.735698] BUG: unable to handle kernel NULL pointer dereference at 0000000000000000
> Dec 5 23:30:25 security kernel: [ 5.735716] IP: [<ffffffffa00997be>] :ir_common:ir_input_free+0x26/0x3e
Thanks-to: Sander Eikelenboom <linux@eikelemboon.it> for reporting and testing the fix.
USB2
This device uses an i2c chip to retrieve the keycode from a RC5 remote.
Instead of just getting 6 bits, improve the routine to get 11 bits.
This means that the complete RC5 table for Hauppauge Grey IR can be used
with this device.
Unfortunately, it seems that this IR receiver is not capable of getting
the full 14 (or 13 bits) from the RC5 protocol.
At lest now, with the new code, it is possible to replace this IR table
by another RC5 table.
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl>
This patch updates the v4l2-dvb documentation for the new video timings API added.
Also updated the document based on comments from Hans Verkuil.
This adds the above APIs to the v4l2 core. This is based on version v1.2
of the RFC titled "V4L - Support for video timings at the input/output interface"
Following new ioctls are added:-
- VIDIOC_ENUM_DV_PRESETS
- VIDIOC_S_DV_PRESET
- VIDIOC_G_DV_PRESET
- VIDIOC_QUERY_DV_PRESET
- VIDIOC_S_DV_TIMINGS
- VIDIOC_G_DV_TIMINGS
Please refer to the RFC for the details. This code was tested using vpfe
capture driver on TI's DM365. Following is the test configuration used :-
Blu-Ray HD DVD source -> TVP7002 -> DM365 (VPFE) ->DDR
A draft version of the TVP7002 driver (currently being reviewed in the mailing
list) was used that supports V4L2_DV_1080I60 & V4L2_DV_720P60 presets.
A loopback video capture application was used for testing these APIs. This calls
following IOCTLS :-
- verify the new v4l2_input capabilities flag added
- Enumerate available presets using VIDIOC_ENUM_DV_PRESETS
- Set one of the supported preset using VIDIOC_S_DV_PRESET
- Get current preset using VIDIOC_G_DV_PRESET
- Detect current preset using VIDIOC_QUERY_DV_PRESET
- Using stub functions in tvp7002, verify VIDIOC_S_DV_TIMINGS
and VIDIOC_G_DV_TIMINGS ioctls are received at the sub device.
- Tested on 64bit platform by Hans Verkuil
Reviewed-by: Randy Dunlap <randy.dunlap@oracle.com>
Hauppauge USB IDs
Add support for five new Hauppauge Device USB IDs:
2040:b980
2040:b990
2040:c010
2040:c080
2040:c090
Signed-off-by: Michael Krufky <mkrufky@kernellabs.com>
Signed-off-by: Jean-Francois Moine <moinejf@free.fr>
Some drivers support multiple frameintervals (framerates), make gspca able to
enumerate them.
Signed-off-by: Antonio Ospite <ospite@studenti.unina.it>
- probe the webcam (probe sequence from ms-win trace)
- update tax5130c init sequences from ms-win newer driver
- update tas5130c sequences from ms-win trace
- add some comments in the probe code
Calling gspca_set_alt0() in gspca_dev_probe() is not needed as gspca_set_alt0()
will do nothing because gspca_dev->alt is always zero at that time.
