2012-02-02Merge 3.3-rc2 into the driver-core-next branch.Greg Kroah-Hartman
This was done to resolve a merge and build problem with the drivers/acpi/processor_driver.c file. Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-01-31Linux 3.3-rc2v3.3-rc2Linus Torvalds
2012-01-31sysfs: Update the name hash when renaming sysfs entriesEric W. Biederman
This fixes a bug introduced with sysfs name hashes where renaming a network device appears to succeed but silently makes the sysfs files for that network device inaccessible. In at least one configuration this bug has stopped networking from coming up during boot. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Tested-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-31Merge tag 'for-linus' of git://github.com/prasad-joshi/logfs_upstreamLinus Torvalds
There are few important bug fixes for LogFS * tag 'for-linus' of git://github.com/prasad-joshi/logfs_upstream: Logfs: Allow NULL block_isbad() methods logfs: Grow inode in delete path logfs: Free areas before calling generic_shutdown_super() logfs: remove useless BUG_ON MAINTAINERS: Add Prasad Joshi in LogFS maintiners logfs: Propagate page parameter to __logfs_write_inode logfs: set superblock shutdown flag after generic sb shutdown logfs: take write mutex lock during fsync and sync logfs: Prevent memory corruption logfs: update page reference count for pined pages Fix up conflict in fs/logfs/dev_mtd.c due to semantic change in what "mtd->block_isbad" means in commit f2933e86ad93: "Logfs: Allow NULL block_isbad() methods" clashing with the abstraction changes in the commits 7086c19d0742: "mtd: introduce mtd_block_isbad interface" and d58b27ed58a3: "logfs: do not use 'mtd->block_isbad' directly". This resolution takes the semantics from commit f2933e86ad93, and just makes mtd_block_isbad() return zero (false) if the 'block_isbad' function is NULL. But that also means that now "mtd_can_have_bb()" always returns 0. Now, "mtd_block_markbad()" will obviously return an error if the low-level driver doesn't support bad blocks, so this is somewhat non-symmetric, but it actually makes sense if a NULL "block_isbad" function is considered to mean "I assume that all my blocks are always good".
2012-01-30Merge branch 'hwmon-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging * 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging: hwmon: (w83627ehf) Disable setting DC mode for pwm2, pwm3 on NCT6776F hwmon: (sht15) fix bad error code MAINTAINERS: Drop maintainer for MAX1668 hwmon driver MAINTAINERS: Add hwmon entries for Wolfson hwmon: (f71805f) Fix clamping of temperature limits
2012-01-30Merge branch 'for-torvalds' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl Here are some fixes to the pin control system that has accumulated since -rc1. Mainly Tony Lindgren fixed the module load/unload logic and the rest are minor fixes and documentation. * 'for-torvalds' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl: pinctrl: add checks for empty function names pinctrl: fix pinmux_hog_maps when ctrl_dev_name is not set pinctrl: fix some pinmux typos pinctrl: free debugfs entries when unloading a pinmux driver pinctrl: unbreak error messages Documentation/pinctrl: fix a few syntax errors in code examples pinctrl: fix pinconf_pins_show iteration
2012-01-30Merge tag 'tty-3.3-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty Here are some tty/serial patches for 3.3-rc1 Big thing here is the movement of the 8250 serial drivers to their own directory, now that the patch churn has calmed down. Other than that, only minor stuff (omap patches were reverted as they were found to be wrong), and another broken driver removed from the system. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> * tag 'tty-3.3-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: serial: Kill off Moorestown code Revert "tty: serial: OMAP: ensure FIFO levels are set correctly in non-DMA mode" Revert "tty: serial: OMAP: transmit FIFO threshold interrupts don't wake the chip" serial: Fix wakeup init logic to speed up startup docbook: don't use serial_core.h in device-drivers book serial: amba-pl011: lock console writes against interrupts amba-pl011: do not disable RTS during shutdown tty: serial: OMAP: transmit FIFO threshold interrupts don't wake the chip tty: serial: OMAP: ensure FIFO levels are set correctly in non-DMA mode omap-serial: make serial_omap_restore_context depend on CONFIG_PM_RUNTIME omap-serial :Make the suspend/resume functions depend on CONFIG_PM_SLEEP. TTY: fix UV serial console regression jsm: Fixed EEH recovery error Updated TTY MAINTAINERS info serial: group all the 8250 related code together
2012-01-30Merge tag 'usb-3.3-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb Here are a bunch of USB patches for 3.3-rc1. Nothing major, largest thing here is the removal of some drivers that did not work at all. Other than that, the normal collection of bugfixes and new device ids. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> * tag 'usb-3.3-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (52 commits) uwb & wusb: fix kconfig error USB: Realtek cr: fix autopm scheduling while atomic USB: ftdi_sio: Add more identifiers xHCI: Cleanup isoc transfer ring when TD length mismatch found usb: musb: omap2430: minor cleanups. qcaux: add more Pantech UML190 and UML290 ports Revert "drivers: usb: Fix dependency for USB_HWA_HCD" usb: mv-otg - Fix build if CONFIG_USB is not set USB: cdc-wdm: Avoid hanging on interface with no USB_CDC_DMM_TYPE usb: add support for STA2X11 host driver drivers: usb: Fix dependency for USB_HWA_HCD kernel-doc: fix new warning in usb.h USB: OHCI: fix new compiler warnings usb: serial: kobil_sct: fix compile warning: drivers/usb/host/ehci-fsl.c: add missing iounmap USB: cdc-wdm: better allocate a buffer that is at least as big as we tell the USB core USB: cdc-wdm: call wake_up_all to allow driver to shutdown on device removal USB: cdc-wdm: use two mutexes to allow simultaneous read and write USB: cdc-wdm: updating desc->length must be protected by spin_lock USB: usbsevseg: fix max length ...
2012-01-30Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
1) Setting link attributes can modify the size of the attributes that would be reported on a subsequent getlink netlink operation, therefore min_ifinfo_dump_size needs to be adjusted. From Stefan Gula. 2) Resegmentation of TSO frames while trimming can violate invariants expected by callers, namely that the number of segments can only stay the same or decrease, never increase. If MSS changes, however, we can trim data but then end up with more segments. Fix this by only segmenting to the MSS already recorded in the SKB. That's the simplest fix for now and if we want to get more fancy in the future that's a more involved change. This probably explains some retransmit counter inaccuracies. From Neal Cardwell. 3) Fix too-many-wakeups in POLL with AF_UNIX sockets, from Eric Dumazet. 4) Fix CAIF crashes wrt. namespace handling. From Eric Dumazet and Eric W. Biederman. 5) TCP port selection fixes from Flavio Leitner. 6) More socket memory cgroup build fixes in certain randonfig situations. From Glauber Costa. 7) Fix TCP memory sysctl regression reported by Ingo Molnar, also from Glauber Costa. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: af_unix: fix EPOLLET regression for stream sockets tcp: fix tcp_trim_head() to adjust segment count with skb MSS net/tcp: Fix tcp memory limits initialization when !CONFIG_SYSCTL net caif: Register properly as a pernet subsystem. netns: Fail conspicously if someone uses net_generic at an inappropriate time. net: explicitly add jump_label.h header to sock.h net: RTNETLINK adjusting values of min_ifinfo_dump_size ipv6: Fix ip_gre lockless xmits. xen-netfront: correct MAX_TX_TARGET calculation. netns: fix net_alloc_generic() tcp: bind() optimize port allocation tcp: bind() fix autoselection to share ports l2tp: l2tp_ip - fix possible oops on packet receive iwlwifi: fix PCI-E transport "inta" race mac80211: set bss_conf.idle when vif is connected mac80211: update oper_channel on ibss join
2012-01-30Merge tag 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator This fixes an integration issue with the regulator device tree bindings which shook out in -rc. The bindings were overly enthusiatic when deciding to set a voltage on a regulator and would try to set zero volts on an unconfigured regulator which isn't supported. * tag 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator: regulator: Set apply_uV only when min and max voltages are defined
2012-01-30af_unix: fix EPOLLET regression for stream socketsEric Dumazet
Commit 0884d7aa24 (AF_UNIX: Fix poll blocking problem when reading from a stream socket) added a regression for epoll() in Edge Triggered mode (EPOLLET) Appropriate fix is to use skb_peek()/skb_unlink() instead of skb_dequeue(), and only call skb_unlink() when skb is fully consumed. This remove the need to requeue a partial skb into sk_receive_queue head and the extra sk->sk_data_ready() calls that added the regression. This is safe because once skb is given to sk_receive_queue, it is not modified by a writer, and readers are serialized by u->readlock mutex. This also reduce number of spinlock acquisition for small reads or MSG_PEEK users so should improve overall performance. Reported-by: Nick Mathewson <nickm@freehaven.net> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Alexey Moiseytsev <himeraster@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-01-30tcp: fix tcp_trim_head() to adjust segment count with skb MSSNeal Cardwell
This commit fixes tcp_trim_head() to recalculate the number of segments in the skb with the skb's existing MSS, so trimming the head causes the skb segment count to be monotonically non-increasing - it should stay the same or go down, but not increase. Previously tcp_trim_head() used the current MSS of the connection. But if there was a decrease in MSS between original transmission and ACK (e.g. due to PMTUD), this could cause tcp_trim_head() to counter-intuitively increase the segment count when trimming bytes off the head of an skb. This violated assumptions in tcp_tso_acked() that tcp_trim_head() only decreases the packet count, so that packets_acked in tcp_tso_acked() could underflow, leading tcp_clean_rtx_queue() to pass u32 pkts_acked values as large as 0xffffffff to ca_ops->pkts_acked(). As an aside, if tcp_trim_head() had really wanted the skb to reflect the current MSS, it should have called tcp_set_skb_tso_segs() unconditionally, since a decrease in MSS would mean that a single-packet skb should now be sliced into multiple segments. Signed-off-by: Neal Cardwell <ncardwell@google.com> Acked-by: Nandita Dukkipati <nanditad@google.com> Acked-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-01-30net/tcp: Fix tcp memory limits initialization when !CONFIG_SYSCTLGlauber Costa
sysctl_tcp_mem() initialization was moved to sysctl_tcp_ipv4.c in commit 3dc43e3e4d0b52197d3205214fe8f162f9e0c334, since it became a per-ns value. That code, however, will never run when CONFIG_SYSCTL is disabled, leading to bogus values on those fields - causing hung TCP sockets. This patch fixes it by keeping an initialization code in tcp_init(). It will be overwritten by the first net namespace init if CONFIG_SYSCTL is compiled in, and do the right thing if it is compiled out. It is also named properly as tcp_init_mem(), to properly signal its non-sysctl side effect on TCP limits. Reported-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Glauber Costa <glommer@parallels.com> Cc: David S. Miller <davem@davemloft.net> Link: http://lkml.kernel.org/r/4F22D05A.8030604@parallels.com [ renamed the function, tidied up the changelog a bit ] Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-01-30Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: [S390] dasd: revalidate server for new pathgroup [S390] dasd: revert LCU optimization [S390] cleanup entry point definition
2012-01-30Merge branch 'next' of git://git.monstr.eu/linux-2.6-microblazeLinus Torvalds
* 'next' of git://git.monstr.eu/linux-2.6-microblaze: microblaze: generic atomic64 support
2012-01-30Merge branch 'drm-fixes' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
* 'drm-fixes' of git://people.freedesktop.org/~airlied/linux: vmwgfx: Fix assignment in vmw_framebuffer_create_handle drm/radeon/kms: Fix device tree linkage of i2c buses drm: Pass the real error code back during GEM bo initialisation Revert "drm/i810: cleanup reclaim_buffers"
2012-01-30Merge tag 'nfs-for-3.3-3' of git://git.linux-nfs.org/projects/trondmy/linux-nfsLinus Torvalds
NFS client bugfixes for Linux 3.3 (pull 3) * tag 'nfs-for-3.3-3' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: SUNRPC: Fix machine creds in generic_create_cred and generic_match
2012-01-30Merge tag 'pm-fix-for-3.3-rc2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Power management fix for 3.3-rc2 Fix for a hibernate (s2disk) regression introduced during the 3.2 merge window that causes s2disk to trigger BUG_ON() in freeze_workqueues_begin() if there is not enough swap space to save the image. * tag 'pm-fix-for-3.3-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: PM / Hibernate: Fix s2disk regression related to freezing workqueues
2012-01-30vmwgfx: Fix assignment in vmw_framebuffer_create_handleRyan Mallon
The assignment of handle in vmw_framebuffer_create_handle doesn't actually do anything useful and is incorrectly assigning an integer value to a pointer argument. It appears that this is a typo and should be dereferencing handle rather than assigning to it directly. This fixes a bug where an undefined handle value is potentially returned to user-space. Signed-off-by: Ryan Mallon <rmallon@gmail.com> Reviewed-by: Jakob Bornecrantz<jakob@vmware.com> Cc: stable@vger.kernel.org Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-01-30drm/radeon/kms: Fix device tree linkage of i2c busesJean Delvare
Properly set the parent device of i2c buses before registering them so that they will show at the right place in the device tree (rather than in /sys/devices directly.) Signed-off-by: Jean Delvare <jdelvare@suse.de> Cc: Dave Airlie <airlied@gmail.com> Reviewed-by: Alex Deucher <alexdeucher@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-01-30drm: Pass the real error code back during GEM bo initialisationChris Wilson
In particular, I found I was hitting the max-file limit in the VFS, and the EFILE was being magically transformed into ENOMEM. Confusion reigns. Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-01-30Revert "drm/i810: cleanup reclaim_buffers"Daniel Vetter
This reverts commit 87499ffdcb1c70f66988cd8febc4ead0ba2f9118. Where is that paper bag ... ah here. I've failed to take an odd interaction between my other cleanups and this reclaim_buffers patch into account and also failed to properly test it. Looks like there are more dragons and hidden trapdoors in the drm release path than actual lines of code. Until I get a clue, let's just revert this. Signed-Off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-01-29hwmon: (w83627ehf) Disable setting DC mode for pwm2, pwm3 on NCT6776FGuenter Roeck
NCT6776F only supports pwm mode for pwm2 and pwm3. Return error if an attempt is made to set those pwm channels to DC mode. Signed-off-by: Guenter Roeck <linux@roeck-us.net> Acked-by: Jean Delvare <khali@linux-fr.org> Cc: stable@vger.kernel.org # 3.0+ Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
2012-01-29PM / Hibernate: Fix s2disk regression related to freezing workqueuesRafael J. Wysocki
Commit 2aede851ddf08666f68ffc17be446420e9d2a056 PM / Hibernate: Freeze kernel threads after preallocating memory introduced a mechanism by which kernel threads were frozen after the preallocation of hibernate image memory to avoid problems with frozen kernel threads not responding to memory freeing requests. However, it overlooked the s2disk code path in which the SNAPSHOT_CREATE_IMAGE ioctl was run directly after SNAPSHOT_FREE, which caused freeze_workqueues_begin() to BUG(), because it saw that worqueues had been already frozen. Although in principle this issue might be addressed by removing the relevant BUG_ON() from freeze_workqueues_begin(), that would reintroduce the very problem that commit 2aede851ddf08666f68ffc17be4 attempted to avoid into that particular code path. For this reason, to fix the issue at hand, introduce thaw_kernel_threads() and make the SNAPSHOT_FREE ioctl execute it. Special thanks to Srivatsa S. Bhat for detailed analysis of the problem. Reported-and-tested-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Cc: stable@kernel.org
2012-01-29hwmon: (sht15) fix bad error codeVivien Didelot
When no platform data was supplied, returned error code was 0. Signed-off-by: Vivien Didelot <vivien.didelot@savoirfairelinux.com> Cc: stable@vger.kernel.org # 2.6.32+ Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
2012-01-28Merge tag 'driver-core-3.3-rc1-bugfixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Here are some patches for the 3.3-rc1 tree. It contains the removal of the sysdev code, now that all users of it are gone, as well as some sysfs bugfixes that have been reported by users. There are also some documentation updates here as well. * tag 'driver-core-3.3-rc1-bugfixes' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: sysfs: Complain bitterly about attempts to remove files from nonexistent directories. stable: update documentation to ask for kernel version base/core.c:fix typo in comment in function device_add Documentation: devres: add allocation functions to list of supported calls Documentation update for the driver model core kernel-doc: fix new warnings in driver-core kernel-doc: fix new warnings in debugfs kernel-doc: fix new warnings in device.h driver core: remove drivers/base/sys.c and include/linux/sysdev.h
2012-01-28Merge tag 'for-linus' of git://github.com/rustyrussell/linuxLinus Torvalds
* tag 'for-linus' of git://github.com/rustyrussell/linux: lguest: remove reference from Documentation/virtual/00-INDEX virtio: correct the memory barrier in virtqueue_kick_prepare() virtio: fix typos of memory barriers
2012-01-28Merge branch 'stable/for-linus-fixes-3.3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen * 'stable/for-linus-fixes-3.3' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: xen/granttable: Disable grant v2 for HVM domains. x86: xen: size struct xen_spinlock to always fit in arch_spinlock_t
2012-01-28Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs: Btrfs: fix reservations in btrfs_page_mkwrite Btrfs: advance window_start if we're using a bitmap btrfs: mask out gfp flags in releasepage Btrfs: fix enospc error caused by wrong checks of the chunk Btrfs: do not defrag a file partially Btrfs: fix warning for 32-bit build of fs/btrfs/check-integrity.c Btrfs: use cluster->window_start when allocating from a cluster bitmap Btrfs: Check for NULL page in extent_range_uptodate btrfs: Fix busyloops in transaction waiting code Btrfs: make sure a bitmap has enough bytes Btrfs: fix uninit warning in backref.c
2012-01-28Merge git://www.linux-watchdog.org/linux-watchdogLinus Torvalds
* git://www.linux-watchdog.org/linux-watchdog: watchdog: iTCO_wdt: add Intel Lynx Point DeviceIDs watchdog: via_wdt: Set min_timeout and max_timeout for wdt_dev watchdog: Fix typo "unexpectdly" watchdog: wafer5823wdt: Fix handling WDIOS_DISABLECARD/WDIOS_ENABLECARD options watchdog: wm8350_wdt: Fix handling WDIOS_DISABLECARD/WDIOS_ENABLECARD options watchdog: Return proper error in nuc900wdt_probe if misc_register fails watchdog: Staticise nuc900_wdt watchdog: via_wdt: Staticise wdt_pci_table watchdog: omap_wdt.c: Fix the mismatch of pm_runtime enable and disable watchdog: dw_wdt.c: use devm_request_and_ioremap watchdog: imx2_wdt.c: use devm_request_and_ioremap
2012-01-28Merge branch 'fixes' of git://git.linaro.org/people/rmk/linux-armLinus Torvalds
* 'fixes' of git://git.linaro.org/people/rmk/linux-arm: (31 commits) ARM: 7304/1: ioremap: fix boundary check when reusing static mapping ARM: 7301/1: Rename the T() macro to TUSER() to avoid namespace conflicts ARM: 7299/1: ftrace: clear zero bit in reported IPs for Thumb-2 ARM: 7298/1: realview: fix mapping of MPCore private memory region PCMCIA: fix sa1111 oops on remove ARM: 7288/1: mach-sa1100: add missing module_init() call ARM: 7297/1: smp_twd: make sure timer is stopped before registering it ARM: 7296/1: proc-v7.S: remove HARVARD_CACHE preprocessor guards ARM: 7295/1: cortex-a7: move proc_info out of !CONFIG_ARM_LPAE block ARM: 7293/1: logical_cpu_map: decouple CPU mapping from SMP ARM: 7291/1: cache: assume 64-byte L1 cachelines for ARMv7 CPUs ARM: 7290/1: vmlinux.lds.S: align the exception fixup table to a 4-byte boundary ARM: 7289/1: vmlinux.lds.S: do not hardcode cacheline size as 32 bytes MFD: ucb1x00-ts: fix resume failure MFD: ucb1x00-core: fix gpiolib direction_output handling MFD: ucb1x00-core: fix missing restore of io output data on resume MFD: mcp-core: fix mcp_priv() to be more type safe MFD: mcp-core: fix complaints from the genirq layer Revert "ARM: sa11x0: Implement autoloading of codec and codec pdata for mcp bus." Revert "ARM: sa1100: Refactor mcp-sa11x0 to use platform resources." ... Fix up conflict due to arch/arm/mach-mx5/Kconfig having been merged into mach-imx5 (commit 784a90c0a7d8: "ARM i.MX: Merge i.MX5 support into mach-imx"), but the ARM_L1_CACHE_SHIFT_6 entry was moved to be driven by the CPU_V7 logic from it in the old location in rmk's branch (commit a092f2b15399: "ARM: 7291/1: cache: assume 64-byte L1 cachelines for ARMv7 CPUs").
2012-01-28Merge tag 'fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc arm-soc fixes for 3.3-rc: AT91 needed reset fixes which resulted in some minor code refactoring, it also adds a feature-removal for one of their platforms for 3.4. The USB patches have been acked by Greg K-H. i.MX and ux500 both have some minor fixes, nothing controversial. * tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: arch/arm/mach-imx/mach-mx53_ard.c: add missing iounmap ARM: imx: iomux-v1.h: Fix build error due to __init annotation ARM: at91: Fix at91sam9g45 and at91cap9 reset ARM: at91: make rstc soc independent ARM: at91: introduce AT91_SAM9_ALT_RESET to select the at91sam9 alternative reset ARM: at91: merge at91cap9_ddrsdr.h in at91sam9_ddrsdr.h ARM: at91: fix cap9 ddrsdr register ARM/USB: at91/ohci-at91: rename vbus_pin_inverted to vbus_pin_active_low USB: at91: fix clk_get error handling ARM: at91: removal of CAP9 SoC family ARM: at91: fix at91rm9200 soc subtype handling mach-ux500: no MMC_CAP_SD_HIGHSPEED on Snowball mach-ux500: enable ARM errata 764369 mach-ux500: do not override outer.inv_all mach-ux500: musb: now musb is always in OTG mode ARM: imx6: add missing twd_clk for imx6q clock
2012-01-28Logfs: Allow NULL block_isbad() methodsJoern Engel
Not all mtd drivers define block_isbad(). Let's assume no bad blocks instead of refusing to mount. Signed-off-by: Joern Engel <joern@logfs.org>
2012-01-28logfs: Grow inode in delete pathJoern Engel
Can be necessary if an inode gets deleted (through -ENOSPC) before being written. Might be better to move this into logfs_write_rec(), but for now go with the stupid&safe patch. Signed-off-by: Joern Engel <joern@logfs.org>
2012-01-28logfs: Free areas before calling generic_shutdown_super()Joern Engel
Or hit an assertion in map_invalidatepage() instead. Signed-off-by: Joern Engel <joern@logfs.org>
2012-01-28logfs: remove useless BUG_ONJoern Engel
It prevents write sizes >4k. Signed-off-by: Joern Engel <joern@logfs.org>
2012-01-28MAINTAINERS: Add Prasad Joshi in LogFS maintinersPrasad Joshi
Acked-by: Joern Engel <joern@logfs.org> Signed-off-by: Prasad Joshi <prasadjoshi.linux@gmail.com>
2012-01-28logfs: Propagate page parameter to __logfs_write_inodePrasad Joshi
During GC LogFS has to rewrite each valid block to a separate segment. Rewrite operation reads data from an old segment and writes it to a newly allocated segment. Since every write operation changes data block pointers maintained in inode, inode should also be rewritten. In GC path to avoid AB-BA deadlock LogFS marks a page with PG_pre_locked in addition to locking the page (PG_locked). The page lock is ignored iff the page is pre-locked. LogFS uses a special file called segment file. The segment file maintains an 8 bytes entry for every segment. It keeps track of erase count, level etc. for every segment. Bad things happen with a segment belonging to the segment file is GCed ------------[ cut here ]------------ kernel BUG at /home/prasad/logfs/readwrite.c:297! invalid opcode: 0000 [#1] SMP Modules linked in: logfs joydev usbhid hid psmouse e1000 i2c_piix4 serio_raw [last unloaded: logfs] Pid: 20161, comm: mount Not tainted 3.1.0-rc3+ #3 innotek GmbH VirtualBox EIP: 0060:[<f809132a>] EFLAGS: 00010292 CPU: 0 EIP is at logfs_lock_write_page+0x6a/0x70 [logfs] EAX: 00000027 EBX: f73f5b20 ECX: c16007c8 EDX: 00000094 ESI: 00000000 EDI: e59be6e4 EBP: c7337b28 ESP: c7337b18 DS: 007b ES: 007b FS: 00d8 GS: 00e0 SS: 0068 Process mount (pid: 20161, ti=c7336000 task=eb323f70 task.ti=c7336000) Stack: f8099a3d c7337b24 f73f5b20 00001002 c7337b50 f8091f6d f8099a4d f80994e4 00000003 00000000 c7337b68 00000000 c67e4400 00001000 c7337b80 f80935e5 00000000 00000000 00000000 00000000 e1fcf000 0000000f e59be618 c70bf900 Call Trace: [<f8091f6d>] logfs_get_write_page.clone.16+0xdd/0x100 [logfs] [<f80935e5>] logfs_mod_segment_entry+0x55/0x110 [logfs] [<f809460d>] logfs_get_segment_entry+0x1d/0x20 [logfs] [<f8091060>] ? logfs_cleanup_journal+0x50/0x50 [logfs] [<f809521b>] ostore_get_erase_count+0x1b/0x40 [logfs] [<f80965b8>] logfs_open_area+0xc8/0x150 [logfs] [<c141a7ec>] ? kmemleak_alloc+0x2c/0x60 [<f809668e>] __logfs_segment_write.clone.16+0x4e/0x1b0 [logfs] [<c10dd563>] ? mempool_kmalloc+0x13/0x20 [<c10dd563>] ? mempool_kmalloc+0x13/0x20 [<f809696f>] logfs_segment_write+0x17f/0x1d0 [logfs] [<f8092e8c>] logfs_write_i0+0x11c/0x180 [logfs] [<f8092f35>] logfs_write_direct+0x45/0x90 [logfs] [<f80934cd>] __logfs_write_buf+0xbd/0xf0 [logfs] [<c102900e>] ? kmap_atomic_prot+0x4e/0xe0 [<f809424b>] logfs_write_buf+0x3b/0x60 [logfs] [<f80947a9>] __logfs_write_inode+0xa9/0x110 [logfs] [<f8094cb0>] logfs_rewrite_block+0xc0/0x110 [logfs] [<f8095300>] ? get_mapping_page+0x10/0x60 [logfs] [<f8095aa0>] ? logfs_load_object_aliases+0x2e0/0x2f0 [logfs] [<f808e57d>] logfs_gc_segment+0x2ad/0x310 [logfs] [<f808e62a>] __logfs_gc_once+0x4a/0x80 [logfs] [<f808ed43>] logfs_gc_pass+0x683/0x6a0 [logfs] [<f8097a89>] logfs_mount+0x5a9/0x680 [logfs] [<c1126b21>] mount_fs+0x21/0xd0 [<c10f6f6f>] ? __alloc_percpu+0xf/0x20 [<c113da41>] ? alloc_vfsmnt+0xb1/0x130 [<c113db4b>] vfs_kern_mount+0x4b/0xa0 [<c113e06e>] do_kern_mount+0x3e/0xe0 [<c113f60d>] do_mount+0x34d/0x670 [<c10f2749>] ? strndup_user+0x49/0x70 [<c113fcab>] sys_mount+0x6b/0xa0 [<c142d87c>] syscall_call+0x7/0xb Code: f8 e8 8b 93 39 c9 8b 45 f8 3e 0f ba 28 00 19 d2 85 d2 74 ca eb d0 0f 0b 8d 45 fc 89 44 24 04 c7 04 24 3d 9a 09 f8 e8 09 92 39 c9 <0f> 0b 8d 74 26 00 55 89 e5 3e 8d 74 26 00 8b 10 80 e6 01 74 09 EIP: [<f809132a>] logfs_lock_write_page+0x6a/0x70 [logfs] SS:ESP 0068:c7337b18 ---[ end trace 96e67d5b3aa3d6ca ]--- The patch passes locked page to __logfs_write_inode. It calls function logfs_get_wblocks() to pre-lock the page. This ensures any further attempts to lock the page are ignored (esp from get_erase_count). Acked-by: Joern Engel <joern@logfs.org> Signed-off-by: Prasad Joshi <prasadjoshi.linux@gmail.com>
2012-01-28logfs: set superblock shutdown flag after generic sb shutdownPrasad Joshi
While unmounting the file system LogFS calls generic_shutdown_super. The function does file system independent superblock shutdown. However, it might result in call file system specific inode eviction. LogFS marks FS shutting down by setting bit LOGFS_SB_FLAG_SHUTDOWN in super->s_flags. Since, inode eviction might call truncate on inode, following BUG is observed when file system is unmounted: ------------[ cut here ]------------ kernel BUG at /home/prasad/logfs/segment.c:362! invalid opcode: 0000 [#1] PREEMPT SMP CPU 3 Modules linked in: logfs binfmt_misc ppdev virtio_blk parport_pc lp parport psmouse floppy virtio_pci serio_raw virtio_ring virtio Pid: 1933, comm: umount Not tainted 3.0.0+ #4 Bochs Bochs RIP: 0010:[<ffffffffa008c841>] [<ffffffffa008c841>] logfs_segment_write+0x211/0x230 [logfs] RSP: 0018:ffff880062d7b9e8 EFLAGS: 00010202 RAX: 000000000000000e RBX: ffff88006eca9000 RCX: 0000000000000000 RDX: ffff88006fd87c40 RSI: ffffea00014ff468 RDI: ffff88007b68e000 RBP: ffff880062d7ba48 R08: 8000000020451430 R09: 0000000000000000 R10: dead000000100100 R11: 0000000000000000 R12: ffff88006fd87c40 R13: ffffea00014ff468 R14: ffff88005ad0a460 R15: 0000000000000000 FS: 00007f25d50ea760(0000) GS:ffff88007fd80000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b CR2: 0000000000d05e48 CR3: 0000000062c72000 CR4: 00000000000006e0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process umount (pid: 1933, threadinfo ffff880062d7a000, task ffff880070b44500) Stack: ffff880062d7ba38 ffff88005ad0a508 0000000000001000 0000000000000000 8000000020451430 ffffea00014ff468 ffff880062d7ba48 ffff88005ad0a460 ffff880062d7bad8 ffffea00014ff468 ffff88006fd87c40 0000000000000000 Call Trace: [<ffffffffa0088fee>] logfs_write_i0+0x12e/0x190 [logfs] [<ffffffffa0089360>] __logfs_write_rec+0x140/0x220 [logfs] [<ffffffffa0089312>] __logfs_write_rec+0xf2/0x220 [logfs] [<ffffffffa00894a4>] logfs_write_rec+0x64/0xd0 [logfs] [<ffffffffa0089616>] __logfs_write_buf+0x106/0x110 [logfs] [<ffffffffa008a19e>] logfs_write_buf+0x4e/0x80 [logfs] [<ffffffffa008a6b8>] __logfs_write_inode+0x98/0x110 [logfs] [<ffffffffa008a7c4>] logfs_truncate+0x54/0x290 [logfs] [<ffffffffa008abfc>] logfs_evict_inode+0xdc/0x190 [logfs] [<ffffffff8115eef5>] evict+0x85/0x170 [<ffffffff8115f126>] iput+0xe6/0x1b0 [<ffffffff8115b4a8>] shrink_dcache_for_umount_subtree+0x218/0x280 [<ffffffff8115ce91>] shrink_dcache_for_umount+0x51/0x90 [<ffffffff8114796c>] generic_shutdown_super+0x2c/0x100 [<ffffffffa008cc47>] logfs_kill_sb+0x57/0xf0 [logfs] [<ffffffff81147de5>] deactivate_locked_super+0x45/0x70 [<ffffffff811487ea>] deactivate_super+0x4a/0x70 [<ffffffff81163934>] mntput_no_expire+0xa4/0xf0 [<ffffffff8116469f>] sys_umount+0x6f/0x380 [<ffffffff814dd46b>] system_call_fastpath+0x16/0x1b Code: 55 c8 49 8d b6 a8 00 00 00 45 89 f9 45 89 e8 4c 89 e1 4c 89 55 b8 c7 04 24 00 00 00 00 e8 68 fc ff ff 4c 8b 55 b8 e9 3c ff ff ff <0f> 0b 0f 0b c7 45 c0 00 00 00 00 e9 44 fe ff ff 66 66 66 66 66 RIP [<ffffffffa008c841>] logfs_segment_write+0x211/0x230 [logfs] RSP <ffff880062d7b9e8> ---[ end trace fe6b040cea952290 ]--- Therefore, move super->s_flags setting after the fs-indenpendent work has been finished. Reviewed-by: Joern Engel <joern@logfs.org> Signed-off-by: Prasad Joshi <prasadjoshi.linux@gmail.com>
2012-01-28logfs: take write mutex lock during fsync and syncPrasad Joshi
LogFS uses super->s_write_mutex while writing data to disk. Taking the same mutex lock in sync and fsync code path solves the following BUG: ------------[ cut here ]------------ kernel BUG at /home/prasad/logfs/dev_bdev.c:134! Pid: 2387, comm: flush-253:16 Not tainted 3.0.0+ #4 Bochs Bochs RIP: 0010:[<ffffffffa007deed>] [<ffffffffa007deed>] bdev_writeseg+0x25d/0x270 [logfs] Call Trace: [<ffffffffa007c381>] logfs_open_area+0x91/0x150 [logfs] [<ffffffff8128dcb2>] ? find_level.clone.9+0x62/0x100 [<ffffffffa007c49c>] __logfs_segment_write.clone.20+0x5c/0x190 [logfs] [<ffffffff810ef005>] ? mempool_kmalloc+0x15/0x20 [<ffffffff810ef383>] ? mempool_alloc+0x53/0x130 [<ffffffffa007c7a4>] logfs_segment_write+0x1d4/0x230 [logfs] [<ffffffffa0078f8e>] logfs_write_i0+0x12e/0x190 [logfs] [<ffffffffa0079300>] __logfs_write_rec+0x140/0x220 [logfs] [<ffffffffa0079444>] logfs_write_rec+0x64/0xd0 [logfs] [<ffffffffa00795b6>] __logfs_write_buf+0x106/0x110 [logfs] [<ffffffffa007a13e>] logfs_write_buf+0x4e/0x80 [logfs] [<ffffffffa0073e33>] __logfs_writepage+0x23/0x80 [logfs] [<ffffffffa007410c>] logfs_writepage+0xdc/0x110 [logfs] [<ffffffff810f5ba7>] __writepage+0x17/0x40 [<ffffffff810f6208>] write_cache_pages+0x208/0x4f0 [<ffffffff810f5b90>] ? set_page_dirty+0x70/0x70 [<ffffffff810f653a>] generic_writepages+0x4a/0x70 [<ffffffff810f75d1>] do_writepages+0x21/0x40 [<ffffffff8116b9d1>] writeback_single_inode+0x101/0x250 [<ffffffff8116bdbd>] writeback_sb_inodes+0xed/0x1c0 [<ffffffff8116c5fb>] writeback_inodes_wb+0x7b/0x1e0 [<ffffffff8116cc23>] wb_writeback+0x4c3/0x530 [<ffffffff814d984d>] ? sub_preempt_count+0x9d/0xd0 [<ffffffff8116cd6b>] wb_do_writeback+0xdb/0x290 [<ffffffff814d984d>] ? sub_preempt_count+0x9d/0xd0 [<ffffffff814d6208>] ? _raw_spin_unlock_irqrestore+0x18/0x40 [<ffffffff8105aa5a>] ? del_timer+0x8a/0x120 [<ffffffff8116cfac>] bdi_writeback_thread+0x8c/0x2e0 [<ffffffff8116cf20>] ? wb_do_writeback+0x290/0x290 [<ffffffff8106d2e6>] kthread+0x96/0xa0 [<ffffffff814de514>] kernel_thread_helper+0x4/0x10 [<ffffffff8106d250>] ? kthread_worker_fn+0x190/0x190 [<ffffffff814de510>] ? gs_change+0xb/0xb RIP [<ffffffffa007deed>] bdev_writeseg+0x25d/0x270 [logfs] ---[ end trace 0211ad60a57657c4 ]--- Reviewed-by: Joern Engel <joern@logfs.org> Signed-off-by: Prasad Joshi <prasadjoshi.linux@gmail.com>
2012-01-28logfs: Prevent memory corruptionJoern Engel
This is a bad one. I wonder whether we were so far protected by no_free_segments(sb) usually being smaller than LOGFS_NO_AREAS. Found by Dan Carpenter <dan.carpenter@oracle.com> using smatch. Signed-off-by: Joern Engel <joern@logfs.org> Signed-off-by: Prasad Joshi <prasadjoshi.linux@gmail.com>
2012-01-28logfs: update page reference count for pined pagesPrasad Joshi
LogFS sets PG_private flag to indicate a pined page. We assumed that marking a page as private is enough to ensure its existence. But instead it is necessary to hold a reference count to the page. The change resolves the following BUG BUG: Bad page state in process flush-253:16 pfn:6a6d0 page flags: 0x100000000000808(uptodate|private) Suggested-and-Acked-by: Joern Engel <joern@logfs.org> Signed-off-by: Prasad Joshi <prasadjoshi.linux@gmail.com>
2012-01-27net caif: Register properly as a pernet subsystem.Eric W. Biederman
caif is a subsystem and as such it needs to register with register_pernet_subsys instead of register_pernet_device. Among other problems using register_pernet_device was resulting in net_generic being called before the caif_net structure was allocated. Which has been causing net_generic to fail with either BUG_ON's or by return NULL pointers. A more ugly problem that could be caused is packets in flight why the subsystem is shutting down. To remove confusion also remove the cruft cause by inappropriately trying to fix this bug. With the aid of the previous patch I have tested this patch and confirmed that using register_pernet_subsys makes the failure go away as it should. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Sjur Brændeland <sjur.brandeland@stericsson.com> Tested-by: Sasha Levin <levinsasha928@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-01-27netns: Fail conspicously if someone uses net_generic at an inappropriate time.Eric W. Biederman
By definition net_generic should never be called when it can return NULL. Fail conspicously with a BUG_ON to make it clear when people mess up that a NULL return should never happen. Recently there was a bug in the CAIF subsystem where it was registered with register_pernet_device instead of register_pernet_subsys. It was erroneously concluded that net_generic could validly return NULL and that net_assign_generic was buggy (when it was just inefficient). Hopefully this BUG_ON will prevent people to coming to similar erroneous conclusions in the futrue. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Tested-by: Sasha Levin <levinsasha928@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-01-27Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless
2012-01-27PCI/XEN: Fix bug introduced by a recent changeAlan Stern
This patch (as1516) fixes a bug introduced during the removal of put_driver() and get_driver() from drivers/pci/xen-pcifront.c. Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-28lguest: remove reference from Documentation/virtual/00-INDEXRusty Russell
We're in tools/lguest now. Reported-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-01-28virtio: correct the memory barrier in virtqueue_kick_prepare()Jason Wang
Use virtio_mb() to make sure the available index to be exposed before checking the the avail event. Otherwise we may get stale value of avail event in guest and never kick the host after. Note: this fixes a bug introduced by ee7cd8981e15bcb365fc762afe3fc47b8242f630. Signed-off-by: Jason Wang <jasowang@redhat.com> Acked-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: stable@kernel.org
2012-01-28virtio: fix typos of memory barriersJason Wang
Note: this fixes a bug introduced recently in 7b21e34fd1c272e3a8c3846168f2f6287a4cd72b. Signed-off-by: Jason Wang <jasowang@redhat.com> Acked-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-01-27ARM: 7304/1: ioremap: fix boundary check when reusing static mappingPawel Moll
Since commit 576d2f2525612ecb5af029a76f21f22a3b82563d "ARM: add generic ioremap optimization by reusing static mappings" ioremap() is trying to reuse existing static mapping when possible. The condition checking boundaries of the requested and existing mappings didn't take in-page offset into consideration though, which lead to obscure and hard to debug problems when requested mapping crossed end of the static one. Signed-off-by: Pawel Moll <pawel.moll@arm.com> Acked-by: Nicolas Pitre <nico@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
