2008-01-25IPoIB: improve IPv4/IPv6 to IB mcast mapping functionsRolf Manderscheid
An IPoIB subnet on an IB fabric that spans multiple IB subnets can't use link-local scope in multicast GIDs. The existing routines that map IP/IPv6 multicast addresses into IB link-level addresses hard-code the scope to link-local, and they also leave the partition key field uninitialised. This patch adds a parameter (the link-level broadcast address) to the mapping routines, allowing them to initialise both the scope and the P_Key appropriately, and fixes up the call sites. The next step will be to add a way to configure the scope for an IPoIB interface. Signed-off-by: Rolf Manderscheid <rvm@obsidianresearch.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-01-25IB/ipath: Changes for fields moving from devdata to portdataDave Olson
This patch moves some arrays that were defined per-device to be variables defined in the per context data structure, thus avoiding extra kzalloc() calls. Signed-off-by: Dave Olson <dave.olson@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-01-25IB/ipath: Generalize some xxx_SHIFT macrosDave Olson
In preparation for upcoming chips that have different values for INFINIPATH_R_PORTENABLE_SHIFT, INFINIPATH_R_INTRAVAIL_SHIFT, INFINIPATH_R_TAILUPD_SHIFT, and portcfg_shift, remove the shared #defines and use device-specific variables instead. Signed-off-by: Dave Olson <dave.olson@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-01-25IB/ipath: kreceive uses portdata rather than devdataRalph Campbell
kreceive is now portdata * instead of devdata * and other kreceive related cleanups.... Signed-off-by: Ralph Campbell <ralph.campbell@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-01-25IB/ipath: Cleanup ipath_get_egrbuf()Ralph Campbell
Remove an unused parameter and fix up the comment. Signed-off-by: Ralph Campbell <ralph.campbell@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-01-25IB/ipath: Fix RNR NAK handlingRalph Campbell
This patch fixes a couple of minor problems with RNR NAK handling: - The insertion sort was causing extra delay when inserting ahead vs. behind an existing entry on the list. - A resend of a first packet of a message which is still not ready, needs another RNR NAK (i.e., it was suppressed when it shouldn't). - Also, the resend tasklet doesn't need to be woken up unless the ACK/NAK actually indicates progress has been made. Signed-off-by: Ralph Campbell <ralph.campbell@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-01-25IB/ehca: Forward event client-reregister-required to registered clientsHoang-Nam Nguyen
This patch allows ehca to forward event client-reregister-required to registered clients. One such event is generated by a switch eg. after its reboot. Signed-off-by: Hoang-Nam Nguyen <hnguyen@de.ibm.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-01-25IB/mlx4: Micro-optimize mlx4_ib_poll_one()Roland Dreier
Rather than byte-swapping cqe->g_mlpath_rqpn each time we extract a field from it, byte-swap it once into a temporary variable. This results in smaller, better code -- eg, on 32-bit x86: add/remove: 0/0 grow/shrink: 0/1 up/down: 0/-5 (-5) function old new delta mlx4_ib_poll_cq 1188 1183 -5 Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-01-25IB/mthca: Remove MSI support as scheduledAdrian Bunk
Remove MSI support from the mthca driver, as scheduled. There is no reason to use MSI instead of MSI-X, since MSI-X performs better. No one has spoken up since MSI support was deprecated in commit f6be6fbe ("IB/mthca: Schedule MSI support for removal"), so apparently the MSI support is unused. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-01-25IB/iser: Typo fix (s/destory/destroy/)Oliver Pinter
Signed-off-by: Oliver Pinter <oliver.pntr@gmail.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-01-25IB/iser: update URLs of iSER docsErez Zilber
Signed-off-by: Erez Zilber <erezz@voltaire.com>
2008-01-25RDMA/cma: add support for rdma_migrate_id() Sean Hefty
This is based on user feedback from Doug Ledford at RedHat: Events that occur on an rdma_cm_id are reported to userspace through an event channel. Connection request events are reported on the event channel associated with the listen. When the connection is accepted, a new rdma_cm_id is created and automatically uses the listen event channel. This is suboptimal where the user only wants listen events on that channel. Additionally, it may be desirable to have events related to connection establishment use a different event channel than those related to already established connections. Allow the user to migrate an rdma_cm_id between event channels. All pending events associated with the rdma_cm_id are moved to the new event channel. Signed-off-by: Sean Hefty <sean.hefty@intel.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-01-25RDMA/cma: Reenable device removal on passive sideVladimir Sokolovsky
Enable conn_id remove on the passive side after connection establishment. This corrects an issue where the IB driver can't be unloaded after running applications over RDS. The 'dev_remove' counter does not reach 0 for established connections on the passive side. This problem is limited to device removal, and only occurs on the passive side if there are established connections. Signed-off-by: Vladimir Sokolovsky <vlad@mellanox.co.il> Reviewed-by: Sean Hefty <sean.hefty@intel.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-01-25IB/mad: Fix incorrect access to items on local_listSean Hefty
In cancel_mads(), MADs are moved from the wait_list and local_list to a cancel_list for processing. However, the structures on these two lists are not the same. The wait_list references struct ib_mad_send_wr_private, but local_list references struct ib_mad_local_private. Cancel_mads() treats all items moved to the cancel_list as struct ib_mad_send_wr_private. This leads to a system crash when requests are moved from the local_list to the cancel_list. Fix this by leaving local_list alone. All requests on the local_list have completed are just awaiting processing by a queued worker thread. Bug (crash) reported by Dotan Barak <dotanb@dev.mellanox.co.il>. Problem with local_list access reported by Robert Reynolds <rreynolds@opengridcomputing.com>. Signed-off-by: Sean Hefty <sean.hefty@intel.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-01-25IB/cm: Add basic performance countersSean Hefty
Add performance/debug counters to track sent/received messages, retries, and duplicates. Counters are tracked per CM message type, per port. The counters are always enabled, so intrusive state tracking is not done. Signed-off-by: Sean Hefty <sean.hefty@intel.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-01-25IB/mad: Report number of times a mad was retriedSean Hefty
To allow ULPs to tune timeout values and capture retry statistics, report the number of times that a mad send operation was retried. For RMPP mads, report the total number of times that the any portion (send window) of the send operation was retried. Signed-off-by: Sean Hefty <sean.hefty@intel.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-01-25IB/multicast: Report errors on multicast groups if P_key changesSean Hefty
P_key changes can invalidate multicast groups. Report errors on all multicast groups affected by a pkey change. Signed-off-by: Sean Hefty <sean.hefty@intel.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-01-25IB: Spelling fixes in commentsJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-01-25mlx4_core: Fix max_eqs masking in QUERY_DEV_CAPJack Morgenstein
log_max_eqs is a 4-bit field, not a 3-bit field in the response to the QUERY_DEV_CAP FW command, so we should mask with 0xf instead of 0x7 when reading it. Found by Yossi Leybovitch of Mellanox. Signed-off-by: Jack Morgenstein <jackm@dev.mellanox.co.il> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-01-25IB/ipath: Convert from .nopage to .faultNick Piggin
Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-01-25IB/ipath: Add the work completion error code to the QP error debug outputRalph Campbell
Add the work completion error code to the QP error debug output. This makes it easier to determine the cause of the error. Signed-off-by: Ralph Campbell <ralph.campbell@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-01-25IB/ipath: Better comment for rmb() in ipath_intr()Arthur Jones
An internal code review found the comment here lacking -- update it with more specifics of how and why the rmb() is there. Signed-off-by: Arthur Jones <arthur.jones@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-01-25IB/ipath: Fix comments for ipath_create_srq()Ralph Campbell
During a code review, someone noticed the comments didn't match the code. Signed-off-by: Ralph Campbell <ralph.campbell@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-01-25IB/ipath: Fix error returned from ib_resize_cq if new size smaller than # ↵Ralph Campbell
entries The gen2_basic tests check for the errno value when a CQ is resized smaller than the number of outstanding completions queue on the CQ. This patch changes ib_ipath to return EINVAL which is what ib_mthca returns and what gen2_basic expects. Signed-off-by: Ralph Campbell <ralph.campbell@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-01-25IB/ipath: Fix sendctrl lockingJohn Gregor
Code review pointed out that the locking around uses of ipath_sendctrl and kr_sendctrl were, in several places, incorrect and/or inconsistent. Signed-off-by: John Gregor <john.gregor@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-01-25IB/ipath: Remove dead code for user process waiting for send bufferRalph Campbell
At one point in time there was code to allow a user process to wait for a send buffer if none were available. This feature was never used and most of the code was removed. This removes some missed unused code. Signed-off-by: Ralph Campbell <ralph.campbell@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-01-25RDMA/cxgb3: Support version 5.0 firmwareSteve Wise
The 5.0 firmware now supports translating sgls in recv work requests, so remove the host driver logic currently doing the translation. Note: this change requires 5.0 firmware. Signed-off-by: Steve Wise <swise@opengridcomputing.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-01-25RDMA/cxgb3: Hold rtnl_lock() around ethtool get_drvinfo callSteve Wise
Currently the call into cxgb3 to get the driver info is not serialized. The iw_cxgb3 module needs to hold the rtnl_lock around the ethtool ops call like dev_ioctl() does. Signed-off-by: Steve Wise <swise@opengridcomputing.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-01-25drivers/infiniband: Add missing "space"Joe Perches
Add missing spaces in the middle of format strings. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-01-25IB/ipath: Convert ipath_eep_sem semaphore to a mutexMatthias Kaehlcke
Signed-off-by: Matthias Kaehlcke <matthias.kaehlcke@gmail.com> Acked-by: Michael Albaugh <Michael.Albaugh@qlogic.com> Tested-by: Arthur Jones <arthur.jones@qlogic.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-01-25IB/mad: Enable loopback of DR SMP responses from userspaceSteve Welch
The local loopback of an outgoing DR SMP response is limited to those that originate at the driver specific SMA implementation during the driver specific process_mad() function. This patch enables a returning DR SMP originating in userspace (or elsewhere) to be delivered to the local managment stack. In this specific case the driver process_mad() function does not consume or process the MAD, so a reponse mad has not be created and the original MAD must manually be copied to the MAD buffer that is to be handed off to the local agent. Signed-off-by: Steve Welch <swelch@systemfabricworks.com> Acked-by: Hal Rosenstock <hal@xsigo.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-01-25IB/ipath: Enable loopback of DR SMP responses from userspaceRalph Campbell
This patch is in response to reviewing a patch to the core MAD processing which fixes loopback of directed route packets to/from user level MAD agents. This change enables the core code to work for ib_ipath by fixing the return code from the ipath process_mad method. Signed-off-by: Ralph Campbell <ralph.campbell@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-01-25IB/mad: Remove redundant NULL pointer check in ib_mad_recv_done_handler()Ralph Campbell
In ib_mad_recv_done_handler(), the response pointer is checked for NULL after allocating it. It is then checked again in the local process_mad() path but there is no possibility of it changing in between. Signed-off-by: Ralph Campbell <ralph.campbell@qlogic.com> Acked-by: Hal Rosenstock <hal@xsigo.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-01-25RDMA/iwcm: Set initiator depth and responder resources to device max valuesSteve Wise
Set the initiator depth and responder resources to the device max values for new connect request events in the iWARP connection manager. Signed-off-by: Steve Wise <swise@opengridcomputing.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-01-25IB/ipath: Improve interrupt handler cache footprintDave Olson
Improve interrupt handler cache footprint by noinline'ing error functions that are rarely called. Signed-off-by: Dave Olson <dave.olson@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-01-25IPoIB/cm: Add connected mode support for devices without SRQsPradeep Satyanarayana
Some IB adapters (notably IBM's eHCA) do not implement SRQs (shared receive queues). The current IPoIB connected mode support only works on devices that support SRQs. Fix this by adding support for using the receive queue of each connected mode receive QP. The disadvantage of this compared to using an SRQ is that it means a full queue of receives must be posted for each remote connected mode peer, which means that total memory usage is potentially much higher than when using SRQs. To manage this, add a new module parameter "max_nonsrq_conn_qp" that limits the number of connections allowed per interface. The rest of the changes are fairly straightforward: we use a table of struct ipoib_cm_rx to hold all the active connections, and put the table index of the connection in the high bits of receive WR IDs. This is needed because we cannot rely on the struct ib_wc.qp field for non-SRQ receive completions. Most of the rest of the changes just test whether or not an SRQ is available, and post receives or find received packets in the right place depending on the answer. Cleaning up dead connections actually becomes simpler, because we do not have to do the "last WQE reached" dance that is required to destroy QPs attached to an SRQ. We just move the QP to the error state and wait for all pending receives to be flushed. Signed-off-by: Pradeep Satyanarayana <pradeeps@linux.vnet.ibm.com> [ Completely rewritten and split up, based on Pradeep's work. Several bugs fixed and no doubt several bugs introduced. - Roland ] Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-01-25IPoIB/cm: Factor out ipoib_cm_free_rx_reap_list()Roland Dreier
Factor out the code for going through the rx_reap list of struct ipoib_cm_rx and freeing each one. This consolidates the code duplicated between ipoib_cm_dev_stop() and ipoib_cm_rx_reap() and reduces the risk of error when adding additional accounting. Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-01-25IPoIB/cm: Factor out ipoib_cm_create_srq()Roland Dreier
Factor out the code to create an SRQ and allocate the receive ring in ipoib_cm_dev_init() into a new function ipoib_cm_create_srq(). This will make the code neater when support for devices that don't implement SRQs is added. Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-01-25IPoIB/cm: Factor out ipoib_cm_free_rx_ring()Roland Dreier
Factor out the code to unmap/free skbs and free the receive ring in ipoib_cm_dev_cleanup() into a new function ipoib_cm_free_rx_ring(). This function will be called from a couple of other places when support for devices that don't implement SRQs is added. Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-01-25IPoIB: Trivial formatting cleanupsRoland Dreier
Fix whitespace blunders, convert "foo* bar" to "foo *bar", etc. Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-01-25IB/ipath: Fix crash on unload introduced by sysfs changesRoland Dreier
Commit 23b9c1ab ("Infiniband: make ipath driver use default driver groups.") introduced a bug in the ipath driver where ipath_device_create_group() fell through into the error path, even on success, which meant that the sysfs groups it created would always get removed right away. This made ipath_device_remove_group() hit the BUG_ON() in sysfs_remove_group() when it tried to remove those groups a second time. Correct the return path so that the groups stick around until they are supposed to be cleaned up. Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-01-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/selinux-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/selinux-2.6: selinux: make mls_compute_sid always polyinstantiate security/selinux: constify function pointer tables and fields security: add a secctx_to_secid() hook security: call security_file_permission from rw_verify_area security: remove security_sb_post_mountroot hook Security: remove security.h include from mm.h Security: remove security_file_mmap hook sparse-warnings (NULL as 0). Security: add get, set, and cloning of superblock security information security/selinux: Add missing "space"
git://git.kernel.org/pub/scm/linux/kernel/git/hskinnemoen/avr32-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/hskinnemoen/avr32-2.6: [AVR32] extint: Set initial irq type to low level [AVR32] extint: change set_irq_type() handling [AVR32] NMI debugging [AVR32] constify function pointer tables [AVR32] ATNGW100: Update defconfig [AVR32] ATSTK1002: Update defconfig [AVR32] Kconfig: Choose daughterboard instead of CPU [AVR32] Add support for ATSTK1003 and ATSTK1004 [AVR32] Clean up external DAC setup code [AVR32] ATSTK1000: Move gpio-leds setup to setup.c [AVR32] Add support for AT32AP7001 and AT32AP7002 [AVR32] Provide more CPU information in /proc/cpuinfo and dmesg [AVR32] Oprofile support [AVR32] Include instrumentation menu Disable VGA text console for AVR32 architecture [AVR32] Enable debugging only when needed ptrace: Call arch_ptrace_attach() when request=PTRACE_TRACEME [AVR32] Remove redundant try_to_freeze() call from do_signal() [AVR32] Drop GFP_COMP for DMA memory allocations
2008-01-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/steve/gfs2-2.6-nmwLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/steve/gfs2-2.6-nmw: (56 commits) [GFS2] Allow journal recovery on read-only mount [GFS2] Lockup on error [GFS2] Fix page_mkwrite truncation race path [GFS2] Fix typo [GFS2] Fix write alloc required shortcut calculation [GFS2] gfs2_alloc_required performance [GFS2] Remove unneeded i_spin [GFS2] Reduce inode size by moving i_alloc out of line [GFS2] Fix assert in log code [GFS2] Fix problems relating to execution of files on GFS2 [GFS2] Initialize extent_list earlier [GFS2] Allow page migration for writeback and ordered pages [GFS2] Remove unused variable [GFS2] Fix log block mapper [GFS2] Minor correction [GFS2] Eliminate the no longer needed sd_statfs_mutex [GFS2] Incremental patch to fix compiler warning [GFS2] Function meta_read optimization [GFS2] Only fetch the dinode once in block_map [GFS2] Reorganize function gfs2_glmutex_lock ...
2008-01-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (125 commits) [CRYPTO] twofish: Merge common glue code [CRYPTO] hifn_795x: Fixup container_of() usage [CRYPTO] cast6: inline bloat-- [CRYPTO] api: Set default CRYPTO_MINALIGN to unsigned long long [CRYPTO] tcrypt: Make xcbc available as a standalone test [CRYPTO] xcbc: Remove bogus hash/cipher test [CRYPTO] xcbc: Fix algorithm leak when block size check fails [CRYPTO] tcrypt: Zero axbuf in the right function [CRYPTO] padlock: Only reset the key once for each CBC and ECB operation [CRYPTO] api: Include sched.h for cond_resched in scatterwalk.h [CRYPTO] salsa20-asm: Remove unnecessary dependency on CRYPTO_SALSA20 [CRYPTO] tcrypt: Add select of AEAD [CRYPTO] salsa20: Add x86-64 assembly version [CRYPTO] salsa20_i586: Salsa20 stream cipher algorithm (i586 version) [CRYPTO] gcm: Introduce rfc4106 [CRYPTO] api: Show async type [CRYPTO] chainiv: Avoid lock spinning where possible [CRYPTO] seqiv: Add select AEAD in Kconfig [CRYPTO] scatterwalk: Handle zero nbytes in scatterwalk_map_and_copy [CRYPTO] null: Allow setkey on digest_null ...
2008-01-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-2.6Linus Torvalds
This can be broken down into these major areas: - Documentation updates (language translations and fixes, as well as kobject and kset documenatation updates.) - major kset/kobject/ktype rework and fixes. This cleans up the kset and kobject and ktype relationship and architecture, making sense of things now, and good documenation and samples are provided for others to use. Also the attributes for kobjects are much easier to handle now. This cleaned up a LOT of code all through the kernel, making kobjects easier to use if you want to. - struct bus_type has been reworked to now handle the lifetime rules properly, as the kobject is properly dynamic. - struct driver has also been reworked, and now the lifetime issues are resolved. - the block subsystem has been converted to use struct device now, and not "raw" kobjects. This patch has been in the -mm tree for over a year now, and finally all the issues are worked out with it. Older distros now properly work with new kernels, and no userspace updates are needed at all. - nozomi driver is added. This has also been in -mm for a long time, and many people have asked for it to go in. It is now in good enough shape to do so. - lots of class_device conversions to use struct device instead. The tree is almost all cleaned up now, only SCSI and IB is the remaining code to fix up... * git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-2.6: (196 commits) Driver core: coding style fixes Kobject: fix coding style issues in kobject c files Kobject: fix coding style issues in kobject.h Driver core: fix coding style issues in device.h spi: use class iteration api scsi: use class iteration api rtc: use class iteration api power supply : use class iteration api ieee1394: use class iteration api Driver Core: add class iteration api Driver core: Cleanup get_device_parent() in device_add() and device_move() UIO: constify function pointer tables Driver Core: constify the name passed to platform_device_register_simple driver core: fix build with SYSFS=n sysfs: make SYSFS_DEPRECATED depend on SYSFS Driver core: use LIST_HEAD instead of call to INIT_LIST_HEAD in __init kobject: add sample code for how to use ksets/ktypes/kobjects kobject: add sample code for how to use kobjects in a simple manner. kobject: update the kobject/kset documentation kobject: remove old, outdated documentation. ...
2008-01-25slab: fix bootstrap on memoryless nodePekka Enberg
If the node we're booting on doesn't have memory, bootstrapping kmalloc() caches resorts to fallback_alloc() which requires ->nodelists set for all nodes. Fix that by calling set_up_list3s() for CACHE_CACHE in kmem_cache_init(). As kmem_getpages() is called with GFP_THISNODE set, this used to work before because of breakage in 2.6.22 and before with GFP_THISNODE returning pages from the wrong node if a node had no memory. So it may have worked accidentally and in an unsafe manner because the pages would have been associated with the wrong node which could trigger bug ons and locking troubles. Tested-by: Mel Gorman <mel@csn.ul.ie> Tested-by: Olaf Hering <olaf@aepfle.de> Reviewed-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> [ With additional one-liner by Olaf Hering - Linus ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-25fix oops on rmmod capidrvKarsten Keil
Fix overwriting the stack with the version string (it is currently 10 bytes + zero) when unloading the capidrv module. Safeguard against overwriting it should the version string grow in the future. Should fix Kernel Bug Tracker Bug 9696. Signed-off-by: Gerd v. Egidy <gerd.von.egidy@intra2net.com> Acked-by: Karsten Keil <kkeil@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-25[GFS2] Allow journal recovery on read-only mountAbhijith Das
This patch allows gfs2 to perform journal recovery even if it is mounted read-only. Strictly speaking, a read-only mount should not be writing to the filesystem, but we do this only to perform journal recovery. A read-only mount will fail if we don't recover the dirty journal. Also, when gfs2 is used as a root filesystem, it will be mounted read-only before being mounted read-write during the boot sequence. A failed read-only mount will panic the machine during bootup. Signed-off-by: Abhijith Das <adas@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2008-01-25[GFS2] Lockup on errorBob Peterson
I spotted this bug while I was digging around. Looks like it could cause a lockup in some rare error condition. Signed-off-by: Bob Peterson <rpeterso@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
