The irqclass_sub_desc array and enum interruption_class are out of sync
thus /proc/interrupts is broken. Remove IRQIO_CLW.
Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com>
Signed-off-by: Ursula Braun <ursula.braun@de.ibm.com>
Move the declaration for external variables to sctp.h file avoiding
to repeatedly declare them with extern keyword.
Signed-off-by: Ying Xue <ying.xue@windriver.com>
ss should display ipv4 mapped request sockets like this :
tcp SYN-RECV 0 0 ::ffff:192.168.0.1:8080 ::ffff:192.0.2.1:35261
and not like this :
tcp SYN-RECV 0 0 192.168.0.1:8080 192.0.2.1:35261
We should init ireq->ireq_family based on listener sk_family,
not the actual protocol carried by SYN packet.
This means we can set ireq_family in inet_reqsk_alloc()
Fixes: 3f66b083a5b7 ("inet: introduce ireq_family")
The original comment was not really informative or funny
as well as sexist. Replace it with a better explanation of
why the driver does stop and what the impacts are.
Signed-off-by: Stephen Hemminger <stephen@networkplumber.org>
We now have K_VLANT, K_VLANP and K_VLANTPID. Clean them up into more
descriptive token, namely K_VLAN_TCI, K_VLAN_AVAIL and K_VLAN_TPID.
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
Eric Dumazet says:
tcp: listener refactor part 16
A CONFIG_PROVE_RCU=y build revealed an RCU splat I had to fix.
I added const qualifiers to various md5 methods, as I expect
to call them on behalf of request sock traffic even if
the listener socket is not locked. This seems ok, but adding
const makes the contract clearer. Note a good reduction
of code size thanks to request/establish sockets convergence.
With request socks convergence, we no longer need
different lookup methods. A request socket can
use generic lookup function.
Add const qualifier to 2nd tcp_v[46]_md5_lookup() parameter.
Since request and established sockets now have same base,
there is no need to pass two pointers to tcp_v4_md5_hash_skb()
or tcp_v6_md5_hash_skb()
Also add a const qualifier to their struct tcp_md5sig_key argument.
It is guaranteed that both tcp_v4_rcv() and tcp_v6_rcv()
run from rcu read locked sections :
ip_local_deliver_finish() and ip6_input_finish() both
use rcu_read_lock()
Also align tcp_v6_inbound_md5_hash() on tcp_v4_inbound_md5_hash()
by returning a boolean.
While timer handler effectively runs a rcu read locked section,
there is no explicit rcu_read_lock()/rcu_read_unlock() annotations
and lockdep can be confused here :
net/ipv4/tcp_ipv4.c-906- /* caller either holds rcu_read_lock() or socket lock */
net/ipv4/tcp_ipv4.c:907: md5sig = rcu_dereference_check(tp->md5sig_info,
net/ipv4/tcp_ipv4.c-908- sock_owned_by_user(sk) ||
net/ipv4/tcp_ipv4.c-909- lockdep_is_held(&sk->sk_lock.slock));
Let's explicitely acquire rcu_read_lock() in tcp_make_synack()
Before commit fa76ce7328b ("inet: get rid of central tcp/dccp listener
timer"), we were holding listener lock so lockdep was happy.
Fixes: fa76ce7328b ("inet: get rid of central tcp/dccp listener timer")
Signed-off-by: Eric DUmazet <edumazet@google.com>
Thomas Graf says:
rhashtable updates on top of Herbert's work
Patch 1 is a bugfix for an RCU splash I encountered while testing.
Patch 2 & 3 are pure cleanups. Patch 4 disables automatic shrinking
by default as discussed in previous thread. Patch 5 removes some
rhashtable internal knowledge from nft_hash and fixes another RCU
splash.
I've pushed various rhashtable tests (Netlink, nft) together with a
Makefile to a git tree [0] for easier stress testing.
[0] https://github.com/tgraf/rhashtable
rhashtable_destroy() variant which stops rehashes, iterates over
the table and calls a callback to release resources.
Avoids need for nft_hash to embed rhashtable internals and allows to
get rid of the being_destroyed flag. It also saves a 2nd mutex
lock upon destruction.
Also fixes an RCU lockdep splash on nft set destruction due to
calling rht_for_each_entry_safe() without holding bucket locks.
Open code this loop as we need know that no mutations may occur in
parallel.
Signed-off-by: Thomas Graf <tgraf@suug.ch>
Introduce a new bool automatic_shrinking to require the
user to explicitly opt-in to automatic shrinking of tables.
rhashtable_insert_rehash() requires RCU locks to be held in order
to access ht->tbl and traverse to the last table.
Fixes: ccd57b1bd324 ("rhashtable: Add immediate rehash during insertion")
If vlan offloading takes place then vlan header is removed from frame
and its contents, both vlan_tci and vlan_proto, is available to user
space via TPACKET interface. However, only vlan_tci can be used in BPF
filters.
This commit introduces a new BPF extension. It makes possible to load
the value of vlan_proto (vlan TPID) to register A. Support for classic
BPF and eBPF is being added, analogous to skb->protocol.
Cc: Daniel Borkmann <daniel@iogearbox.net>
Cc: Alexei Starovoitov <ast@plumgrid.com>
Cc: Jiri Pirko <jpirko@redhat.com>
Signed-off-by: Michal Sekletar <msekleta@redhat.com>
Acked-by: Daniel Borkmann <daniel@iogearbox.net>
Acked-by: Alexei Starovoitov <ast@plumgrid.com>
Reviewed-by: Jiri Pirko <jiri@resnulli.us>
Varun Prakash says:
FCoE support in cxgb4 driver
This patch series enables FCoE support in cxgb4 driver, it enables
FCOE_CRC and FCOE_MTU net device features.
This series is created against net-next tree.
Signed-off-by: Varun Prakash <varun@chelsio.com>
This patch adds cxgb4_fcoe.c and enables FCOE_CRC, FCOE_MTU
This patch adds new header file cxgb4_fcoe.h and defines new
macros for FCoE support in cxgb4 driver.
Those warnings reported by sparse endianness check (via kbuild test robot)
are harmless, nevertheless fix them up and make the code a little bit
easier to read.
Reported-by: kbuild test robot <fengguang.wu@intel.com>
Fixes: 622c81d57b392cc ("ipv6: generation of stable privacy addresses for link-local and autoconf")
When IPV6=m and TIPC=y, below error will appear during building kernel
image:
net/tipc/udp_media.c:196:
undefined reference to `ip6_dst_lookup'
make: *** [vmlinux] Error 1
As ip6_dst_lookup() is implemented in IPV6 and IPV6 is compiled as
module, ip6_dst_lookup() is not built-in core kernel image. As a
result, compiler cannot find 'ip6_dst_lookup' reference while
compiling TIPC code into core kernel image.
But with the method introduced by commit 5f81bd2e5d80 ("ipv6: export a
stub for IPv6 symbols used by vxlan"), we can avoid the compile error
through "ipv6_stub" pointer to access ip6_dst_lookup().
Fixes: d0f91938bede ("tipc: add ip/udp media type")
Suggested-by: Marcelo Ricardo Leitner <marcelo.leitner@gmail.com>
With dev group, we can change a batch of net devices,
so we should allow to delete them together too.
Group 0 is not allowed to be deleted since it is
the default group.
Cc: Stephen Hemminger <stephen@networkplumber.org>
This patch adds a comment on the choice of the value 16 as the
maximum chain length before we force a rehash.
drivers/net/usb/cx82310_eth.c:175:2-3: Unneeded semicolon
Removes unneeded semicolon.
Generated by: scripts/coccinelle/misc/semicolon.cocci
CC: Ondrej Zary <linux@rainbow-software.org>
Signed-off-by: Fengguang Wu <fengguang.wu@intel.com>
Commit f2f8036 ("tipc: add support for connect() on dgram/rdm sockets")
hasn't validated user input length for the sockaddr structure which allows
a user to overwrite kernel memory with arbitrary input.
Fixes: f2f8036 ("tipc: add support for connect() on dgram/rdm sockets")
Acked-by: Ying Xue <ying.xue@windriver.com>
Cc: John Fastabend <john.r.fastabend@intel.com>
net/netfilter/nf_tables_core.c
The nf_tables_core.c conflict was resolved using a conflict resolution
from Stephen Rothwell as a guide.
The commit 963ecbd41a1026d99ec7537c050867428c397b89 ("rhashtable:
Fix use-after-free in rhashtable_walk_stop") fixed a real bug
but created another one because we may end up sleeping inside an
RCU critical section.
This patch fixes it properly by replacing the mutex with a spin
lock that specifically protects the walker lists.
Reported-by: Sasha Levin <sasha.levin@oracle.com>
Hannes Frederic Sowa says:
ipv6: RFC7217 stable privacy addresses implementation
this is an implementation of basic support for RFC7217 stable privacy
addresses. Please review and consider for net-next.
v2:
* Correct references to RFC 7212 -> RFC 7217 in documentation patch (thanks, Eric!)
Cc: Erik Kline <ek@google.com>
Cc: Fernando Gont <fgont@si6networks.com>
Cc: Lorenzo Colitti <lorenzo@google.com>
Cc: YOSHIFUJI Hideaki/吉藤英明 <hideaki.yoshifuji@miraclelinux.com>
This is specified by RFC 7217.
If a DAD conflict is detected, we want to retry privacy stable address
generation up to idgen_retries (= 3) times with a delay of idgen_delay
(= 1 second). Add the logic to addrconf_dad_failure.
By design, we don't clean up dad failed permanent addresses.
We need to mark appropriate addresses so we can do retries in case their
DAD failed.
This patch implements the stable privacy address generation for
link-local and autoconf addresses as specified in RFC7217.
RID = F(Prefix, Net_Iface, Network_ID, DAD_Counter, secret_key)
is the RID (random identifier). As the hash function F we chose one
round of sha1. Prefix will be either the link-local prefix or the
router advertised one. As Net_Iface we use the MAC address of the
device. DAD_Counter and secret_key are implemented as specified.
We don't use Network_ID, as it couples the code too closely to other
subsystems. It is specified as optional in the RFC.
As Net_Iface we only use the MAC address: we simply have no stable
identifier in the kernel we could possibly use: because this code might
run very early, we cannot depend on names, as they might be changed by
user space early on during the boot process.
A new address generation mode is introduced,
IN6_ADDR_GEN_MODE_STABLE_PRIVACY. With iproute2 one can switch back to
none or eui64 address configuration mode although the stable_secret is
already set.
We refuse writes to ipv6/conf/all/stable_secret but only allow
ipv6/conf/default/stable_secret and the interface specific file to be
written to. The default stable_secret is used as the parameter for the
namespace, the interface specific can overwrite the secret, e.g. when
switching a network configuration from one system to another while
inheriting the secret.
This patch implements the procfs logic for the stable_address knob:
The secret is formatted as an ipv6 address and will be stored per
interface and per namespace. We track initialized flag and return EIO
errors until the secret is set.
We don't inherit the secret to newly created namespaces.
We need this symbol later on in ipv6.ko, thus export it via EXPORT_SYMBOL
like sha_transform already is.
Florian Fainelli says:
net: bcmgenet: integrated GPHY power up/down
This patch series implements integrated Gigabit PHY power up/down, which allows
us to save close to 300mW on some designs when the Gigabit PHY is known to be
unused (e.g: during bcmgenet_close or bcmgenet_suspend not doing Wake-on-LAN).
Changes in v2:
- drop an extra bcmgenet_ext_readl in bcmgenet_phy_power_set
In case the interface is not used, power down the integrated GPHY during
suspend. Similarly to bcmgenet_open(), bcmgenet_resume() powers on the GPHY
prior to any UniMAC activity.
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
Power up the GPHY while we are bringing-up the network interface, and
conversely, upon bring down, power the GPHY down. In order to avoid
creating hardware hazards, make sure that the GPHY gets powered on
during bcmgenet_open() prior to the UniMAC being reset as the UniMAC may
start creating activity towards the GPHY if we reverse the steps.
Implement the GPHY power down sequence by setting all power down bits, putting
the GPHY in reset, and finally cutting the 25Mhz reference clock.
We were missing a number of extra steps and delays to power-up the GPHY, update
the sequence to reflect the proper procedure here.
In preparation for implementing the power down GPHY sequence, rename
bcmgenet_ephy_power_up to illustrate that it is not EPHY specific but
PHY agnostic, and add an "enable" argument.
The CK25_DIS bit controls whether a 25Mhz clock is fed to the GPHY or
not, in preparation for powering down the integrated GPHY when relevant,
make sure we clear that bit.
If bcmgenet_power_down() fails, we would want to propagate a return
value from bcmgenet_wol_power_down_cfg() to know about this.
Herbert Xu says:
rhashtable: Multiple rehashing
This series introduces multiple rehashing.
Recall that the original implementation in br_multicast used
two list pointers per hash node and therefore is limited to at
most one rehash at a time since you need one list pointer for
the old table and one for the new table.
Thanks to Josh Triplett's suggestion of using a single list pointer
we're no longer limited by that. So it is perfectly OK to have
an arbitrary number of tables in existence at any one time.
The reader and removal simply has to walk from the oldest table
to the newest table in order not to miss anything. Insertion
without lookup are just as easy as we simply go to the last table
that we can find and add the entry there.
However, insertion with uniqueness lookup is more complicated
because we need to ensure that two simultaneous insertions of the
same key do not both succeed. To achieve this, all insertions
including those without lookups are required to obtain the bucket
lock from the oldest hash table that is still alive. This is
determined by having the rehasher (there is only one rehashing
thread in the system) keep a pointer of where it is up to. If
a bucket has already been rehashed then it is dead, i.e., there
cannot be any more insertions to it, otherwise it is considered
alive. This guarantees that the same key cannot be inserted
in two different tables in parallel.
Patch 1 is actually a bug fix for the walker.
Patch 2-5 eliminates unnecessary out-of-line copies of jhash.
Patch 6 makes rhashtable_shrink shrink to fit.
Patch 7 introduces multiple rehashing. This means that if we
decide to grow then we will grow regardless of whether the previous
one has finished. However, this is still asynchronous meaning
that if insertions come fast enough we may still end up with a
table that is overutilised.
Patch 8 adds support for GFP_ATOMIC allocations of struct bucket_table.
Finally patch 9 enables immediate rehashing. This is done either
when the table reaches 100% utilisation, or when the chain length
exceeds 16 (the latter can be disabled on request, e.g., for
nft_hash.
With these patches the system should no longer have any trouble
dealing with fast insertions on a small table. In the worst
case you end up with a list of tables that's log N in length
while the rehasher catches up.
v3 restores rhashtable_shrink and fixes a number of bugs in the
multiple rehashing patches (7 and 9).
This patch reintroduces immediate rehash during insertion. If
we find during insertion that the table is full or the chain
length exceeds a set limit (currently 16 but may be disabled
with insecure_elasticity) then we will force an immediate rehash.
The rehash will contain an expansion if the table utilisation
exceeds 75%.
If this rehash fails then the insertion will fail. Otherwise the
insertion will be reattempted in the new hash table.
Acked-by: Thomas Graf <tgraf@suug.ch>
