2012-09-25cputime: Make finegrained irqtime accounting generally availableFrederic Weisbecker
There is no known reason for this option to be unavailable on other archs than x86. They just need to call enable_sched_clock_irqtime() if they have a sufficiently finegrained clock to make it working. Move it to the general option and let the user choose between it and pure tick based or virtual cputime accounting. Note that virtual cputime accounting already performs a finegrained irqtime accounting. CONFIG_IRQ_TIME_ACCOUNTING is a kind of middle ground between tick and virtual based accounting. So CONFIG_IRQ_TIME_ACCOUNTING and CONFIG_VIRT_CPU_ACCOUNTING are mutually exclusive choices. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org>
2012-09-25cputime: Gather time/stats accounting config options into a single menuFrederic Weisbecker
This debloats a bit the general config menu and make these config options easier to find. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org>
2012-09-25ia64: Reuse system and user vtime accounting functions on task switchFrederic Weisbecker
To avoid code duplication. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org>
2012-09-25ia64: Consolidate user vtime accountingFrederic Weisbecker
Factorize the code that accounts user time into a single function to avoid code duplication. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org>
2012-09-25vtime: Consolidate system/idle context detectionFrederic Weisbecker
Move the code that finds out to which context we account the cputime into generic layer. Archs that consider the whole time spent in the idle task as idle time (ia64, powerpc) can rely on the generic vtime_account() and implement vtime_account_system() and vtime_account_idle(), letting the generic code to decide when to call which API. Archs that have their own meaning of idle time, such as s390 that only considers the time spent in CPU low power mode as idle time, can just override vtime_account(). Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org>
2012-09-25cputime: Use a proper subsystem naming for vtime related APIsFrederic Weisbecker
Use a naming based on vtime as a prefix for virtual based cputime accounting APIs: - account_system_vtime() -> vtime_account() - account_switch_vtime() -> vtime_task_switch() It makes it easier to allow for further declension such as vtime_account_system(), vtime_account_idle(), ... if we want to find out the context we account to from generic code. This also make it better to know on which subsystem these APIs refer to. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org>
2012-09-13sched: cpu_power: enable ARCH_POWERVincent Guittot
Heteregeneous ARM platform uses arch_scale_freq_power function to reflect the relative capacity of each core Signed-off-by: Vincent Guittot <vincent.guittot@linaro.org> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1341826026-6504-6-git-send-email-vincent.guittot@linaro.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2012-09-13sched/nohz: Clean up select_nohz_load_balancer()Alex Shi
There is no load_balancer to be selected now. It just sets the state of the nohz tick to stop. So rename the function, pass the 'cpu' as a parameter and then remove the useless call from tick_nohz_restart_sched_tick(). [ s/set_nohz_tick_stopped/nohz_balance_enter_idle/g s/clear_nohz_tick_stopped/nohz_balance_exit_idle/g ] Signed-off-by: Alex Shi <alex.shi@intel.com> Acked-by: Suresh Siddha <suresh.b.siddha@intel.com> Cc: Venkatesh Pallipadi <venki@google.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1347261059-24747-1-git-send-email-alex.shi@intel.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2012-09-13sched: Fix load avg vs. cpu-hotplugPeter Zijlstra
Commit f319da0c68 ("sched: Fix load avg vs cpu-hotplug") was an incomplete fix: In particular, the problem is that at the point it calls calc_load_migrate() nr_running := 1 (the stopper thread), so move the call to CPU_DEAD where we're sure that nr_running := 0. Also note that we can call calc_load_migrate() without serialization, we know the state of rq is stable since its cpu is dead, and we modify the global state using appropriate atomic ops. Suggested-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1346882630.2600.59.camel@twins Signed-off-by: Ingo Molnar <mingo@kernel.org>
2012-09-13sched: Remove __ARCH_WANT_INTERRUPTS_ON_CTXSWPeter Zijlstra
Now that the last architecture to use this has stopped doing so (ARM, thanks Catalin!) we can remove this complexity from the scheduler core. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Catalin Marinas <catalin.marinas@arm.com> Link: http://lkml.kernel.org/n/tip-g9p2a1w81xxbrze25v9zpzbf@git.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2012-09-13sched: Fix nohz_idle_balance()Vincent Guittot
On tickless systems, one CPU runs load balance for all idle CPUs. The cpu_load of this CPU is updated before starting the load balance of each other idle CPUs. We should instead update the cpu_load of the balance_cpu. Signed-off-by: Vincent Guittot <vincent.guittot@linaro.org> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Venkatesh Pallipadi <venki@google.com> Cc: Suresh Siddha <suresh.b.siddha@intel.com> Link: http://lkml.kernel.org/r/1347509486-8688-1-git-send-email-vincent.guittot@linaro.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2012-09-04sched: Remove useless code in yield_to()Michael Wang
It's impossible to enter the else branch if we have set skip_clock_update in task_yield_fair(), as yield_to_task_fair() will directly return true after invoke task_yield_fair(). Signed-off-by: Michael Wang <wangyun@linux.vnet.ibm.com> Acked-by: Mike Galbraith <efault@gmx.de> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/4FF2925A.9060005@linux.vnet.ibm.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2012-09-04sched: Add time unit suffix to sched sysctl knobsNamhyung Kim
Unlike others, sched_migration_cost, sched_time_avg and sched_shares_window doesn't have time unit as suffix. Add them. Signed-off-by: Namhyung Kim <namhyung@kernel.org> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1345083330-19486-1-git-send-email-namhyung@kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2012-09-04sched/debug: Limit sd->*_idx range on sysctlNamhyung Kim
Various sd->*_idx's are used for refering the rq's load average table when selecting a cpu to run. However they can be set to any number with sysctl knobs so that it can crash the kernel if something bad is given. Fix it by limiting them into the actual range. Signed-off-by: Namhyung Kim <namhyung@kernel.org> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1345104204-8317-1-git-send-email-namhyung@kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2012-09-04sched: Remove AFFINE_WAKEUPS feature flagNamhyung Kim
Commit beac4c7e4a1c ("sched: Remove AFFINE_WAKEUPS feature") removed use of the flag but left the definition. Get rid of it. Signed-off-by: Namhyung Kim <namhyung@kernel.org> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Link: http://lkml.kernel.org/r/1345090865-20851-1-git-send-email-namhyung@kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2012-09-04Merge branch 'sched/urgent' into sched/coreIngo Molnar
Merge in the current fixes branch, we are going to apply dependent patches. Signed-off-by: Ingo Molnar <mingo@kernel.org>
2012-09-04sched: Fix kernel-doc warnings in kernel/sched/fair.cRandy Dunlap
Fix two kernel-doc warnings in kernel/sched/fair.c: Warning(kernel/sched/fair.c:3660): Excess function parameter 'cpus' description in 'update_sg_lb_stats' Warning(kernel/sched/fair.c:3806): Excess function parameter 'cpus' description in 'update_sd_lb_stats' Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/50303714.3090204@xenotime.net Signed-off-by: Ingo Molnar <mingo@kernel.org>
2012-09-04sched: Unthrottle rt runqueues in __disable_runtime()Peter Boonstoppel
migrate_tasks() uses _pick_next_task_rt() to get tasks from the real-time runqueues to be migrated. When rt_rq is throttled _pick_next_task_rt() won't return anything, in which case migrate_tasks() can't move all threads over and gets stuck in an infinite loop. Instead unthrottle rt runqueues before migrating tasks. Additionally: move unthrottle_offline_cfs_rqs() to rq_offline_fair() Signed-off-by: Peter Boonstoppel <pboonstoppel@nvidia.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Turner <pjt@google.com> Link: http://lkml.kernel.org/r/5FBF8E85CA34454794F0F7ECBA79798F379D3648B7@HQMAIL04.nvidia.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2012-09-04sched: Add missing call to calc_load_exit_idle()Charles Wang
Azat Khuzhin reported high loadavg in Linux v3.6 After checking the upstream scheduler code, I found Peter's commit: 5167e8d5417b sched/nohz: Rewrite and fix load-avg computation -- again not fully applied, missing the call to calc_load_exit_idle(). After that idle exit in sampling window will always be calculated to non-idle, and the load will be higher than normal. This patch adds the missing call to calc_load_exit_idle(). Signed-off-by: Charles Wang <muming.wq@taobao.com> Cc: stable@kernel.org Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1345449754-27130-1-git-send-email-muming.wq@gmail.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2012-09-04sched: Fix load avg vs cpu-hotplugPeter Zijlstra
Rabik and Paul reported two different issues related to the same few lines of code. Rabik's issue is that the nr_uninterruptible migration code is wrong in that he sees artifacts due to this (Rabik please do expand in more detail). Paul's issue is that this code as it stands relies on us using stop_machine() for unplug, we all would like to remove this assumption so that eventually we can remove this stop_machine() usage altogether. The only reason we'd have to migrate nr_uninterruptible is so that we could use for_each_online_cpu() loops in favour of for_each_possible_cpu() loops, however since nr_uninterruptible() is the only such loop and its using possible lets not bother at all. The problem Rabik sees is (probably) caused by the fact that by migrating nr_uninterruptible we screw rq->calc_load_active for both rqs involved. So don't bother with fancy migration schemes (meaning we now have to keep using for_each_possible_cpu()) and instead fold any nr_active delta after we migrate all tasks away to make sure we don't have any skewed nr_active accounting. Reported-by: Rakib Mullick <rakib.mullick@gmail.com> Reported-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1345454817.23018.27.camel@twins Signed-off-by: Ingo Molnar <mingo@kernel.org>
2012-09-02Merge branch 'for-next' of git://git.samba.org/sfrench/cifs-2.6Linus Torvalds
Pull CIFS fixes from Steve French. * 'for-next' of git://git.samba.org/sfrench/cifs-2.6: CIFS: Fix cifs_do_create error hadnling cifs: print error code if smb signature verification fails CIFS: Fix log messages in packet checking for SMB2 CIFS: Protect i_nlink from being negative
2012-09-02Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) NLA_PUT* --> nla_put_* conversion got one case wrong in nfnetlink_log, fix from Patrick McHardy. 2) Missed error return check in ipw2100 driver, from Julia Lawall. 3) PMTU updates in ipv4 were setting the expiry time incorrectly, fix from Eric Dumazet. 4) SFC driver erroneously reversed src and dst when reporting filters via ethtool. 5) Memory leak in CAN protocol and wrong setting of IRQF_SHARED in sja1000 can platform driver, from Alexey Khoroshilov and Sven Schmitt. 6) Fix multicast traffic scaling regression in ipv4_dst_destroy, only take the lock when we really need to. From Eric Dumazet. 7) Fix non-root process spoofing in netlink, from Pablo Neira Ayuso. 8) CWND reduction in TCP is done incorrectly during non-SACK recovery, fix from Yuchung Cheng. 9) Revert netpoll change, and fix what was actually a driver specific problem. From Amerigo Wang. This should cure bootup hangs with netconsole some people reported. 10) Fix xen-netfront invoking __skb_fill_page_desc() with a NULL page pointer. From Ian Campbell. 11) SIP NAT fix for expectiontation creation, from Pablo Neira Ayuso. 12) __ip_rt_update_pmtu() needs RCU locking, from Eric Dumazet. 13) Fix usbnet deadlock on resume, can't use GFP_KERNEL in this situation. From Oliver Neukum. 14) The davinci ethernet driver triggers an OOPS on removal because it frees an MDIO object before unregistering it. Fix from Bin Liu. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (41 commits) net: qmi_wwan: add several new Gobi devices fddi: 64 bit bug in smt_add_para() net: ethernet: fix kernel OOPS when remove davinci_mdio module net/xfrm/xfrm_state.c: fix error return code net: ipv6: fix error return code net: qmi_wwan: new device: Foxconn/Novatel E396 usbnet: fix deadlock in resume cs89x0 : packet reception not working netfilter: nf_conntrack: fix racy timer handling with reliable events bnx2x: Correct the ndo_poll_controller call bnx2x: Move netif_napi_add to the open call ipv4: must use rcu protection while calling fib_lookup bnx2x: fix 57840_MF pci id net: ipv4: ipmr_expire_timer causes crash when removing net namespace e1000e: DoS while TSO enabled caused by link partner with small MSS l2tp: avoid to use synchronize_rcu in tunnel free function gianfar: fix default tx vlan offload feature flag netfilter: nf_nat_sip: fix incorrect handling of EBUSY for RTCP expectation xen-netfront: use __pskb_pull_tail to ensure linear area is big enough on RX netfilter: nfnetlink_log: fix error return code in init path ...
2012-09-01net: qmi_wwan: add several new Gobi devicesBjørn Mork
Gobi devices are composite, needing both the qcserial and qmi_wwan drivers to support all functions. Re-syncing the list of supported devices with qcserial. Cc: Aleksander Morgado <aleksander@lanedo.com> Cc: Thomas Tuttle <ttuttle@chromium.org> Signed-off-by: Bjørn Mork <bjorn@mork.no> Signed-off-by: David S. Miller <davem@tempietto.lan>
2012-09-01fddi: 64 bit bug in smt_add_para()Dan Carpenter
The intent was to set 4 bytes of data so that's why the sp_len is set to 4 on the next line. The cast to u_long pointer clears 8 bytes on 64 bit arches. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: David S. Miller <davem@tempietto.lan>
2012-09-01Linux 3.6-rc4v3.6-rc4Linus Torvalds
2012-09-01time: Move ktime_t overflow checking into timespec_valid_strictJohn Stultz
Andreas Bombe reported that the added ktime_t overflow checking added to timespec_valid in commit 4e8b14526ca7 ("time: Improve sanity checking of timekeeping inputs") was causing problems with X.org because it caused timeouts larger then KTIME_T to be invalid. Previously, these large timeouts would be clamped to KTIME_MAX and would never expire, which is valid. This patch splits the ktime_t overflow checking into a new timespec_valid_strict function, and converts the timekeeping codes internal checking to use this more strict function. Reported-and-tested-by: Andreas Bombe <aeb@debian.org> Cc: Zhouping Liu <zliu@redhat.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Prarit Bhargava <prarit@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: stable@vger.kernel.org Signed-off-by: John Stultz <john.stultz@linaro.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-08-31Merge git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull KVM bugfixes from Marcelo Tosatti. * git://git.kernel.org/pub/scm/virt/kvm/kvm: KVM: x86: fix KVM_GET_MSR for PV EOI kvm: Fix nonsense handling of compat ioctl
2012-08-31Merge tag 'parisc-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jejb/parisc-2.6 Pull PARISC fixes from James Bottomley: "This is a set of two bug fixes. One is the ATOMIC problem which is now causing a compile failure in certain situations. The other is mishandling of PER_LINUX32 which may also cause user visible effects. Signed-off-by: James Bottomley <JBottomley@Parallels.com>" * tag 'parisc-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/parisc-2.6: [PARISC] fix personality flag check in copy_thread() [PARISC] Redefine ATOMIC_INIT and ATOMIC64_INIT to drop the casts
2012-08-31Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux Pull s390 fixes from Martin Schwidefsky: "A couple of s390 bug fixes for 3.5-rc4" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: s390/32: Don't clobber personality flags on exec s390/smp: add missing smp_store_status() for !SMP s390/dasd: fix ioctl return value s390: Always use "long" for ssize_t to match size_t
2012-08-31net: ethernet: fix kernel OOPS when remove davinci_mdio moduleBin Liu
davinci mdio device is not unregistered from mdiobus when removing the module, which causes BUG_ON() when free the device from mdiobus. Calling mdiobus_unregister() before mdiobus_free() fixes the issue. Signed-off-by: Bin Liu <b-liu@ti.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-31net/xfrm/xfrm_state.c: fix error return codeJulia Lawall
Initialize return variable before exiting on an error path. A simplified version of the semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> ( if@p1 (\(ret < 0\|ret != 0\)) { ... return ret; } | ret@p1 = 0 ) ... when != ret = e1 when != &ret *if(...) { ... when != ret = e2 when forall return ret; } // </smpl> Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-31net: ipv6: fix error return codeJulia Lawall
Initialize return variable before exiting on an error path. The initial initialization of the return variable is also dropped, because that value is never used. A simplified version of the semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> ( if@p1 (\(ret < 0\|ret != 0\)) { ... return ret; } | ret@p1 = 0 ) ... when != ret = e1 when != &ret *if(...) { ... when != ret = e2 when forall return ret; } // </smpl> Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-31net: qmi_wwan: new device: Foxconn/Novatel E396Aleksander Morgado
Foxconn-branded Novatel E396, Gobi3k modem. Cc: Dan Williams <dcbw@redhat.com> Cc: Bjørn Mork <bjorn@mork.no> Cc: Ben Chan <benchan@google.com> Signed-off-by: Aleksander Morgado <aleksander@lanedo.com> Acked-by: Bjørn Mork <bjorn@mork.no> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-31usbnet: fix deadlock in resumeOliver Neukum
A usbnet device can share a multifunction device with a storage device. If the storage device is autoresumed the usbnet devices also needs to be autoresumed. Allocating memory with GFP_KERNEL can deadlock in this case. This should go back into all kernels that have commit 65841fd5132c3941cdf5df09e70df3ed28323212 That is 3.5 Signed-off-by: Oliver Neukum <oneukum@suse.de> CC: stable@kernel.org Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-31cs89x0 : packet reception not workingJaccon Bastiaansen
The RxCFG register of the CS89x0 could be configured incorrectly (because of misplaced parentheses), resulting in the disabling of packet reception. Signed-off-by: Jaccon Bastiaansen <jaccon.bastiaansen@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-31Merge branch 'master' of git://1984.lsi.us.es/nfDavid S. Miller
2012-08-31netfilter: nf_conntrack: fix racy timer handling with reliable eventsPablo Neira Ayuso
Existing code assumes that del_timer returns true for alive conntrack entries. However, this is not true if reliable events are enabled. In that case, del_timer may return true for entries that were just inserted in the dying list. Note that packets / ctnetlink may hold references to conntrack entries that were just inserted to such list. This patch fixes the issue by adding an independent timer for event delivery. This increases the size of the ecache extension. Still we can revisit this later and use variable size extensions to allocate this area on demand. Tested-by: Oliver Smith <olipro@8.c.9.b.0.7.4.0.1.0.0.2.ip6.arpa> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2012-08-30bnx2x: Correct the ndo_poll_controller callMerav Sicron
This patch correct poll_bnx2x (ndo_poll_controller call) which was not functioning well with MSI-X. Signed-off-by: Merav Sicron <meravs@broadcom.com> Signed-off-by: Dmitry Kravkov <dmitry@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-30bnx2x: Move netif_napi_add to the open callMerav Sicron
Move netif_napi_add for all queues from the probe call to the open call, to avoid the case that napi objects are added for queues that may eventually not be initialized and activated. With the former behavior, the driver could crash when netpoll was calling ndo_poll_controller. Signed-off-by: Merav Sicron <meravs@broadcom.com> Signed-off-by: Dmitry Kravkov <dmitry@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-30ipv4: must use rcu protection while calling fib_lookupEric Dumazet
Following lockdep splat was reported by Pavel Roskin : [ 1570.586223] =============================== [ 1570.586225] [ INFO: suspicious RCU usage. ] [ 1570.586228] 3.6.0-rc3-wl-main #98 Not tainted [ 1570.586229] ------------------------------- [ 1570.586231] /home/proski/src/linux/net/ipv4/route.c:645 suspicious rcu_dereference_check() usage! [ 1570.586233] [ 1570.586233] other info that might help us debug this: [ 1570.586233] [ 1570.586236] [ 1570.586236] rcu_scheduler_active = 1, debug_locks = 0 [ 1570.586238] 2 locks held by Chrome_IOThread/4467: [ 1570.586240] #0: (slock-AF_INET){+.-...}, at: [<ffffffff814f2c0c>] release_sock+0x2c/0xa0 [ 1570.586253] #1: (fnhe_lock){+.-...}, at: [<ffffffff815302fc>] update_or_create_fnhe+0x2c/0x270 [ 1570.586260] [ 1570.586260] stack backtrace: [ 1570.586263] Pid: 4467, comm: Chrome_IOThread Not tainted 3.6.0-rc3-wl-main #98 [ 1570.586265] Call Trace: [ 1570.586271] [<ffffffff810976ed>] lockdep_rcu_suspicious+0xfd/0x130 [ 1570.586275] [<ffffffff8153042c>] update_or_create_fnhe+0x15c/0x270 [ 1570.586278] [<ffffffff815305b3>] __ip_rt_update_pmtu+0x73/0xb0 [ 1570.586282] [<ffffffff81530619>] ip_rt_update_pmtu+0x29/0x90 [ 1570.586285] [<ffffffff815411dc>] inet_csk_update_pmtu+0x2c/0x80 [ 1570.586290] [<ffffffff81558d1e>] tcp_v4_mtu_reduced+0x2e/0xc0 [ 1570.586293] [<ffffffff81553bc4>] tcp_release_cb+0xa4/0xb0 [ 1570.586296] [<ffffffff814f2c35>] release_sock+0x55/0xa0 [ 1570.586300] [<ffffffff815442ef>] tcp_sendmsg+0x4af/0xf50 [ 1570.586305] [<ffffffff8156fc60>] inet_sendmsg+0x120/0x230 [ 1570.586308] [<ffffffff8156fb40>] ? inet_sk_rebuild_header+0x40/0x40 [ 1570.586312] [<ffffffff814f4bdd>] ? sock_update_classid+0xbd/0x3b0 [ 1570.586315] [<ffffffff814f4c50>] ? sock_update_classid+0x130/0x3b0 [ 1570.586320] [<ffffffff814ec435>] do_sock_write+0xc5/0xe0 [ 1570.586323] [<ffffffff814ec4a3>] sock_aio_write+0x53/0x80 [ 1570.586328] [<ffffffff8114bc83>] do_sync_write+0xa3/0xe0 [ 1570.586332] [<ffffffff8114c5a5>] vfs_write+0x165/0x180 [ 1570.586335] [<ffffffff8114c805>] sys_write+0x45/0x90 [ 1570.586340] [<ffffffff815d2722>] system_call_fastpath+0x16/0x1b Signed-off-by: Eric Dumazet <edumazet@google.com> Reported-by: Pavel Roskin <proski@gnu.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-30bnx2x: fix 57840_MF pci idYuval Mintz
Commit c3def943c7117d42caaed3478731ea7c3c87190e have added support for new pci ids of the 57840 board, while failing to change the obsolete value in 'pci_ids.h'. This patch does so, allowing the probe of such devices. Signed-off-by: Yuval Mintz <yuvalmin@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-30net: ipv4: ipmr_expire_timer causes crash when removing net namespaceFrancesco Ruggeri
When tearing down a net namespace, ipv4 mr_table structures are freed without first deactivating their timers. This can result in a crash in run_timer_softirq. This patch mimics the corresponding behaviour in ipv6. Locking and synchronization seem to be adequate. We are about to kfree mrt, so existing code should already make sure that no other references to mrt are pending or can be created by incoming traffic. The functions invoked here do not cause new references to mrt or other race conditions to be created. Invoking del_timer_sync guarantees that ipmr_expire_timer is inactive. Both ipmr_expire_process (whose completion we may have to wait in del_timer_sync) and mroute_clean_tables internally use mfc_unres_lock or other synchronizations when needed, and they both only modify mrt. Tested in Linux 3.4.8. Signed-off-by: Francesco Ruggeri <fruggeri@aristanetworks.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-30e1000e: DoS while TSO enabled caused by link partner with small MSSBruce Allan
With a low enough MSS on the link partner and TSO enabled locally, the networking stack can periodically send a very large (e.g. 64KB) TCP message for which the driver will attempt to use more Tx descriptors than are available by default in the Tx ring. This is due to a workaround in the code that imposes a limit of only 4 MSS-sized segments per descriptor which appears to be a carry-over from the older e1000 driver and may be applicable only to some older PCI or PCIx parts which are not supported in e1000e. When the driver gets a message that is too large to fit across the configured number of Tx descriptors, it stops the upper stack from queueing any more and gets stuck in this state. After a timeout, the upper stack assumes the adapter is hung and calls the driver to reset it. Remove the unnecessary limitation of using up to only 4 MSS-sized segments per Tx descriptor, and put in a hard failure test to catch when attempting to check for message sizes larger than would fit in the whole Tx ring. Refactor the remaining logic that limits the size of data per Tx descriptor from a seemingly arbitrary 8KB to a limit based on the dynamic size of the Tx packet buffer as described in the hardware specification. Also, fix the logic in the check for space in the Tx ring for the next largest possible packet after the current one has been successfully queued for transmit, and use the appropriate defines for default ring sizes in e1000_probe instead of magic values. This issue goes back to the introduction of e1000e in 2.6.24 when it was split off from e1000. Reported-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: Bruce Allan <bruce.w.allan@intel.com> Cc: Stable <stable@vger.kernel.org> [2.6.24+] Tested-by: Aaron Brown <aaron.f.brown@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-30l2tp: avoid to use synchronize_rcu in tunnel free functionxeb@mail.ru
Avoid to use synchronize_rcu in l2tp_tunnel_free because context may be atomic. Signed-off-by: Dmitry Kozlov <xeb@mail.ru> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-30gianfar: fix default tx vlan offload feature flagClaudiu Manoil
Commit - "b852b72 gianfar: fix bug caused by 87c288c6e9aa31720b72e2bc2d665e24e1653c3e" disables by default (on mac init) the hw vlan tag insertion. The "features" flags were not updated to reflect this, and "ethtool -K" shows tx-vlan-offload to be "on" by default. Cc: Sebastian Poehn <sebastian.poehn@belden.com> Signed-off-by: Claudiu Manoil <claudiu.manoil@freescale.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-30netfilter: nf_nat_sip: fix incorrect handling of EBUSY for RTCP expectationPablo Neira Ayuso
We're hitting bug while trying to reinsert an already existing expectation: kernel BUG at kernel/timer.c:895! invalid opcode: 0000 [#1] SMP [...] Call Trace: <IRQ> [<ffffffffa0069563>] nf_ct_expect_related_report+0x4a0/0x57a [nf_conntrack] [<ffffffff812d423a>] ? in4_pton+0x72/0x131 [<ffffffffa00ca69e>] ip_nat_sdp_media+0xeb/0x185 [nf_nat_sip] [<ffffffffa00b5b9b>] set_expected_rtp_rtcp+0x32d/0x39b [nf_conntrack_sip] [<ffffffffa00b5f15>] process_sdp+0x30c/0x3ec [nf_conntrack_sip] [<ffffffff8103f1eb>] ? irq_exit+0x9a/0x9c [<ffffffffa00ca738>] ? ip_nat_sdp_media+0x185/0x185 [nf_nat_sip] We have to remove the RTP expectation if the RTCP expectation hits EBUSY since we keep trying with other ports until we succeed. Reported-by: Rafal Fitt <rafalf@aplusc.com.pl> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2012-08-30xen-netfront: use __pskb_pull_tail to ensure linear area is big enough on RXIan Campbell
I'm slightly concerned by the "only in exceptional circumstances" comment on __pskb_pull_tail but the structure of an skb just created by netfront shouldn't hit any of the especially slow cases. This approach still does slightly more work than the old way, since if we pull up the entire first frag we now have to shuffle everything down where before we just received into the right place in the first place. Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Mel Gorman <mgorman@suse.de> Cc: xen-devel@lists.xensource.com Cc: netdev@vger.kernel.org Cc: linux-kernel@vger.kernel.org Tested-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Acked-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-30Merge branch 'drm-fixes' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull drm fixes from Dave Airlie: "A bunch of scattered fixes ati/intel/nouveau, couple of core ones, nothing too shocking or different." * 'drm-fixes' of git://people.freedesktop.org/~airlied/linux: drm: Add EDID_QUIRK_FORCE_REDUCED_BLANKING for ASUS VW222S gma500: Consider CRTC initially active. drm/radeon: fix dig encoder selection on DCE61 drm/radeon: fix double free in radeon_gpu_reset drm/radeon: force dma32 to fix regression rs4xx,rs6xx,rs740 drm/radeon: rework panel mode setup drm/radeon/atom: powergating fixes for DCE6 drm/radeon/atom: rework DIG modesetting on DCE3+ drm/radeon: don't disable plls that are in use by other crtcs drm/radeon: add proper checking of RESOLVE_BOX command for r600-r700 drm/radeon: initialize tracked CS state drm/radeon: fix reading CB_COLORn_MASK from the CS drm/nvc0/copy: check PUNITS to determine which copy engines are disabled i915: Quirk no_lvds on Gigabyte GA-D525TUD ITX motherboard drm/i915: Use the correct size of the GTT for placing the per-process entries drm: Check for invalid cursor flags drm: Initialize object type when using DRM_MODE() macro drm/i915: fix color order for BGR formats on IVB drm/i915: fix wrong order of parameters in port checking functions
2012-08-30s390/32: Don't clobber personality flags on execHeiko Carstens
In native 32 bit mode the personality flags were not correctly inherited. This is the s390 version of 59e4c3a2 "powerpc/32: Don't clobber personality flags on exec". Reported-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2012-08-30drm: Add EDID_QUIRK_FORCE_REDUCED_BLANKING for ASUS VW222SPaul Menzel
Connecting an ASUS VW222S [1] over VGA a garbled screen is shown with vertical stripes in the top half. In commit bc42aabc [2] commit bc42aabc6a01b92b0f961d65671564e0e1cd7592 Author: Adam Jackson <ajax@redhat.com> Date: Wed May 23 16:26:54 2012 -0400 drm/edid/quirks: ViewSonic VA2026w Adam Jackson added the quirk `EDID_QUIRK_FORCE_REDUCED_BLANKING` which is also needed for this ASUS monitor. All log files and output from `xrandr` is included in the referenced Bugzilla report #17629. Please note that this monitor only has a VGA (D-Sub) connector [1]. [1] http://www.asus.com/Display/LCD_Monitors/VW222S/ [2] http://git.kernel.org/?p=linux/kernel/git/torvalds/linux.git;a=commit;h=bc42aabc6a01b92b0f961d65671564e0e1cd7592 Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=17629 Signed-off-by: Paul Menzel <paulepanter@users.sourceforge.net> Cc: <dri-devel@lists.freedesktop.org> Cc: Adam Jackson <ajax@redhat.com> Cc: Ian Pilcher <arequipeno@gmail.com> Cc: <stable@vger.kernel.org> Signed-off-by: Dave Airlie <airlied@redhat.com>
