2006-03-24[PATCH] rio driver rework continued #5Alan Cox
Final polish. There is no more save_flags/cli type locking left. We also no longer use the pcicopy function and file so they can go. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] rio driver rework continued #4Alan Cox
Third large chunk of code cleanup. The split between this and #3 and #4 is fairly arbitary and due to the message length limit on the list. These patches continue the process of ripping out macros and typedefs while cleaning up lots of 32bit assumptions. Several inlines for compatibility also get removed and that causes a lot of noise. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] rio driver rework continued #3Alan Cox
Second large chunk of code cleanup. The split between this and #3 and #4 is fairly arbitary and due to the message length limit on the list. These patches continue the process of ripping out macros and typedefs while cleaning up lots of 32bit assumptions. Several inlines for compatibility also get removed and that causes a lot of noise. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] rio driver rework continued #2Alan Cox
First large chunk of code cleanup. The split between this and #3 and #4 is fairly arbitary and due to the message length limit on the list. These patches continue the process of ripping out macros and typedefs while cleaning up lots of 32bit assumptions. Several inlines for compatibility also get removed and that causes a lot of noise. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] rio driver rework continued #1Alan Cox
More header cleanups, strip out typedefs and remove cruft. There are a lot of magic macros that can go and also a great deal of abuse of volatile that is not needed any more as this patch set cleans up the misuse of pointer access to ISA and PCI space. It now builds cleanly on 64bit, although there is more work left to do Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] rioboot: post-LindentAlan Cox
After the indent we can now clean up unused code, and fix all myriad cases that don't use readb/writeb properly. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] rioboot: lindentAlan Cox
This is the result of indent -kr -i8 -bri0 -l255 Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] rio: more header cleanupAlan Cox
Strip some of the typedef mess out Remove a small subset of unused defines and the like. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] Fix "value computed not used" warningsTakashi Iwai
Fixes for annoying gcc-4.1 compile warnings "value computed not used". Simply cast to void. (akpm: Linus will go ballistic...) Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] deprecate the kernel_thread exportChristoph Hellwig
Announce that the kernel_thread export will be removed in half a year, after all it's users have been converted to the kthread_ API, which I plan to do over the next month. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] ide: Allow IDE interface to specify its not capable of 32-bit operationsKumar Gala
In some embedded systems the IDE hardware interface may only support 16-bit or smaller accesses. Allow the interface to specify if this is the case and don't allow the drive or user to override the setting. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] show MCP menu only on ARCH_SA1100Adrian Bunk
On architectures like i386, the "Multimedia Capabilities Port drivers" menu is visible, but it can't be visited since it contains nothing usable for !ARCH_SA1100. This patch therefore shows this menu only on ARCH_SA1100. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] Conditionalize compat_sys_newfstatatKyle McMartin
If we don't want sys_newfstatat because __ARCH_WANT_STAT64 is defined, then we certainly don't want compat_sys_newfstatat either. Signed-off-by: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] console_setup() depends (wrongly?) on CONFIG_PRINTKJohn Z. Bohach
It appears that console_setup() code only gets compiled into the kernel if CONFIG_PRINTK is enabled. One detrimental side-effect of this is that serial8250_console_setup() never gets invoked when CONFIG_PRINTK is not set, resulting in baud rate not being read/parsed from command line (i.e. console=ttyS0,115200n8 is ignored, at least the baud rate part...) Attached patch moves console_setup() code from inside #ifdef CONFIG_PRINTK to outside (in printk.c), removing dependence on said config. option. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] Updated Documentation/nfsroot.txtNico Schottelius
I today booted the first time my embedded device using Linux 2.6.15.2, which was booted by pxelinux, which then bootet itself from the nfsroot. This went pretty fine, but when I was reading through Documentation/nfsroot.txt I saw that there are some more modern versions available of loading the kernel and passing parameters. Signed-off-by: Nico Schottelius <nico-kernel@schottelius.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] mmc: Secure Digital Host Controller Interface driverPierre Ossman
Driver for the Secure Digital Host Controller Interface specification. Signed-off-by: Pierre Ossman <drzeus@drzeus.cx> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] Secure Digital Host Controller id and regsPierre Ossman
Class code and register definitions for the Secure Digital Host Controller standard. Signed-off-by: Pierre Ossman <drzeus@drzeus.cx> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] msync(): use do_fsync()Andrew Morton
No need to duplicate all that code. Cc: Hugh Dickins <hugh@veritas.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] fsync: extract internal codeAndrew Morton
Pull the guts out of do_fsync() - we can use it elsewhere. Cc: Hugh Dickins <hugh@veritas.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] msync: fix return valueAndrew Morton
msync() does a strange thing. Essentially: vma = find_vma(); for ( ; ; ) { if (!vma) return -ENOMEM; ... vma = vma->vm_next; } so an msync() request which starts within or before a valid VMA and which ends within or beyond the final VMA will incorrectly return -ENOMEM. Fix. Cc: Hugh Dickins <hugh@veritas.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] msync(MS_SYNC): don't hold mmap_sem while syncingAndrew Morton
It seems bad to hold mmap_sem while performing synchronous disk I/O. Alter the msync(MS_SYNC) code so that the lock is released while we sync the file. Cc: Hugh Dickins <hugh@veritas.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] msync(): perform dirty page levellingAndrew Morton
It seems sensible to perform dirty page throttling in msync: as the application dirties pages we can kick off pdflush early, or even force the msync() caller to perform writeout, or even throttle the msync() caller. The main effect of this is to start disk writeback earlier if we've just discovered that a large amount of pagecache has been dirtied. (Otherwise it wouldn't happen for up to five seconds, next time pdflush wakes up). It also will cause the page-dirtying process to get panalised for dirtying those pages rather than whacking someone else with the problem. We should do this for munmap() and possibly even exit(), too. We drop the mmap_sem while performing the dirty page balancing. It doesn't seem right to hold mmap_sem for that long. Note that this patch only affects MS_ASYNC. MS_SYNC will be syncing all the dirty pages anyway. We note that msync(MS_SYNC) does a full-file-sync inside mmap_sem, and always has. We can fix that up... The patch also tightens up the mmap_sem coverage in sys_msync(): no point in taking it while we perform the incoming arg checking. Cc: Hugh Dickins <hugh@veritas.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] set_page_dirty() return value fixesAndrew Morton
We need set_page_dirty() to return true if it actually transitioned the page from a clean to dirty state. This wasn't right in a couple of places. Do a kernel-wide audit, fix things up. This leaves open the possibility of returning a negative errno from set_page_dirty() sometime in the future. But we don't do that at present. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] balance_dirty_pages_ratelimited: take nr_pages argAndrew Morton
Modify balance_dirty_pages_ratelimited() so that it can take a number-of-pages-which-I-just-dirtied argument. For msync(). Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] HOTPLUG_CPU: avoid hitting too many cachelines in recalc_bh_state()Eric Dumazet
Instead of using for_each_cpu(i), we can use for_each_online_cpu(i). When a CPU goes offline (ie removed from online map), it might have a non null bh_accounting.nr, so this patch adds a transfer of this counter to an online CPU counter. We already have a hotcpu_notifier, (function buffer_cpu_notify()), where we can do this bh_accounting. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] sound: remove PC98-specific OPL3_HW_OPL3_PC98Arthur Othieno
OPL3_HW_OPL3_PC98 #define isn't used anywhere; previously in sound/drivers/opl3/opl3_lib.c and sound/isa/cs423x/pc98.c, the latter of which went away with the rest of PC98 subarch. Signed-off-by: Arthur Othieno <apgo@patchbomb.org> Cc: Jaroslav Kysela <perex@perex.cz> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] block: floppy98 removal, really.Arthur Othieno
floppy98 went out together with the rest of PC98 subarch. Remove stale Makefile entry that remained. Signed-off-by: Arthur Othieno <apgo@patchbomb.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] shmdt: check address alignmentHugh Dickins
SUSv3 says the shmdt() function shall fail with EINVAL if the value of shmaddr is not the data segment start address of a shared memory segment: our sys_shmdt needs to reject a shmaddr which is not page-aligned. Does it have the potential to break existing apps? Hugh says "sys_shmdt() just does the wrong (unexpected) thing with a misaligned address: it'll fail on what you might expect it to succeed on, and only succeed on what it should definitely fail on. "That is, I think it behaves as if shmaddr gets rounded up, when the only understandable behaviour would be if it rounded it down. "Which does mean you'd have to be devious to see anything but EINVAL from a misaligned shmaddr there, so it's not terribly important." Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] sb_set_blocksize cleanupCoywolf Qi Hunt
sb_set_blocksize() cleanup: make sb_set_blocksize() use blksize_bits(). Signed-off-by: Coywolf Qi Hunt <qiyong@fc-cn.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] early_printk: cleanup trailiing whitespaceRandy Dunlap
Remove all trailing tabs and spaces. No other changes. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] fadvise(): write commandsAndrew Morton
Add two new linux-specific fadvise extensions(): LINUX_FADV_ASYNC_WRITE: start async writeout of any dirty pages between file offsets `offset' and `offset+len'. Any pages which are currently under writeout are skipped, whether or not they are dirty. LINUX_FADV_WRITE_WAIT: wait upon writeout of any dirty pages between file offsets `offset' and `offset+len'. By combining these two operations the application may do several things: LINUX_FADV_ASYNC_WRITE: push some or all of the dirty pages at the disk. LINUX_FADV_WRITE_WAIT, LINUX_FADV_ASYNC_WRITE: push all of the currently dirty pages at the disk. LINUX_FADV_WRITE_WAIT, LINUX_FADV_ASYNC_WRITE, LINUX_FADV_WRITE_WAIT: push all of the currently dirty pages at the disk, wait until they have been written. It should be noted that none of these operations write out the file's metadata. So unless the application is strictly performing overwrites of already-instantiated disk blocks, there are no guarantees here that the data will be available after a crash. To complete this suite of operations I guess we should have a "sync file metadata only" operation. This gives applications access to all the building blocks needed for all sorts of sync operations. But sync-metadata doesn't fit well with the fadvise() interface. Probably it should be a new syscall: sys_fmetadatasync(). The patch also diddles with the meaning of `endbyte' in sys_fadvise64_64(). It is made to represent that last affected byte in the file (ie: it is inclusive). Generally, all these byterange and pagerange functions are inclusive so we can easily represent EOF with -1. As Ulrich notes, these two functions are somewhat abusive of the fadvise() concept, which appears to be "set the future policy for this fd". But these commands are a perfect fit with the fadvise() impementation, and several of the existing fadvise() commands are synchronous and don't affect future policy either. I think we can live with the slight incongruity. Cc: Michael Kerrisk <mtk-manpages@gmx.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] filemap_fdatawrite_range() api: clarify -end parameterAndrew Morton
I had trouble understanding working out whether filemap_fdatawrite_range()'s `end' parameter describes the last-byte-to-be-written or the last-plus-one. Clarify that in comments. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] CONFIG_UNWIND_INFOJan Beulich
As a foundation for reliable stack unwinding, this adds a config option (available to all architectures except IA64 and those where the module loader might have problems with the resulting relocations) to enable the generation of frame unwind information. Signed-off-by: Jan Beulich <jbeulich@novell.com> Cc: Miles Bader <uclinux-v850@lsi.nec.co.jp> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Paul Mundt <lethal@linux-sh.org>, Cc: Andi Kleen <ak@muc.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] abstract type/size specification for assemblyJan Beulich
Provide abstraction for generating type and size information of assembly routines and data, while permitting architectures to override these defaults. Signed-off-by: Jan Beulich <jbeulich@novell.com> Cc: "Russell King" <rmk@arm.linux.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: "Andi Kleen" <ak@suse.de> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Miles Bader <uclinux-v850@lsi.nec.co.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] fast ext3_statfsAlex Tomas
Under I/O load it may take up to a dozen seconds to read all group descriptors. This is what ext3_statfs() does. At the same time, we already maintain global numbers of free inodes/blocks. Why don't we use them instead of group reading and summing? Cc: Ravikiran G Thirumalai <kiran@scalex86.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] remove ipmi pm_power_off redefinitionOlaf Hering
Use the global define of pm_power_off Signed-off-by: Olaf Hering <olh@suse.de> Cc: Corey Minyard <minyard@acm.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] isofs: remove unused debugging macrosPekka Enberg
Remove unused debugging macros from isofs. The referred debug functions do not exist in the kernel. Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] s/;;/;/gAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] cpuset: remove useless local variable initializationPaul Jackson
Remove a useless variable initialization in cpuset __cpuset_zone_allowed(). The local variable 'allowed' is unconditionally set before use, later on in the code, so does not need to be initialized. Not that it seems to matter to the code generated any, as the compiler optimizes out the superfluous assignment anyway. Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] cpuset: memory_spread_slab drop useless PF_SPREAD_PAGE checkPaul Jackson
The hook in the slab cache allocation path to handle cpuset memory spreading for tasks in cpusets with 'memory_spread_slab' enabled has a modest performance bug. The hook calls into the memory spreading handler alternate_node_alloc() if either of 'memory_spread_slab' or 'memory_spread_page' is enabled, even though the handler does nothing (albeit harmlessly) for the page case Fix - drop PF_SPREAD_PAGE from the set of flag bits that are used to trigger a call to alternate_node_alloc(). The page case is handled by separate hooks -- see the calls conditioned on cpuset_do_page_mem_spread() in mm/filemap.c Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] cpuset: don't need to mark cpuset_mems_generation atomicPaul Jackson
Drop the atomic_t marking on the cpuset static global cpuset_mems_generation. Since all access to it is guarded by the global manage_mutex, there is no need for further serialization of this value. Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] cpuset: remove unnecessary NULL checkPaul Jackson
Remove a no longer needed test for NULL cpuset pointer, with a little comment explaining why the test isn't needed. Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] cpuset memory spread slab cache hooksPaul Jackson
Change the kmem_cache_create calls for certain slab caches to support cpuset memory spreading. See the previous patches, cpuset_mem_spread, for an explanation of cpuset memory spreading, and cpuset_mem_spread_slab_cache for the slab cache support for memory spreading. The slab caches marked for now are: dentry_cache, inode_cache, some xfs slab caches, and buffer_head. This list may change over time. In particular, other file system types that are used extensively on large NUMA systems may want to allow for spreading their directory and inode slab cache entries. Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] cpuset memory spread slab cache optimizationsPaul Jackson
The hooks in the slab cache allocator code path for support of NUMA mempolicies and cpuset memory spreading are in an important code path. Many systems will use neither feature. This patch optimizes those hooks down to a single check of some bits in the current tasks task_struct flags. For non NUMA systems, this hook and related code is already ifdef'd out. The optimization is done by using another task flag, set if the task is using a non-default NUMA mempolicy. Taking this flag bit along with the PF_SPREAD_PAGE and PF_SPREAD_SLAB flag bits added earlier in this 'cpuset memory spreading' patch set, one can check for the combination of any of these special case memory placement mechanisms with a single test of the current tasks task_struct flags. This patch also tightens up the code, to save a few bytes of kernel text space, and moves some of it out of line. Due to the nested inlines called from multiple places, we were ending up with three copies of this code, which once we get off the main code path (for local node allocation) seems a bit wasteful of instruction memory. Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] cpuset memory spread slab cache implementationPaul Jackson
Provide the slab cache infrastructure to support cpuset memory spreading. See the previous patches, cpuset_mem_spread, for an explanation of cpuset memory spreading. This patch provides a slab cache SLAB_MEM_SPREAD flag. If set in the kmem_cache_create() call defining a slab cache, then any task marked with the process state flag PF_MEMSPREAD will spread memory page allocations for that cache over all the allowed nodes, instead of preferring the local (faulting) node. On systems not configured with CONFIG_NUMA, this results in no change to the page allocation code path for slab caches. On systems with cpusets configured in the kernel, but the "memory_spread" cpuset option not enabled for the current tasks cpuset, this adds a call to a cpuset routine and failed bit test of the processor state flag PF_SPREAD_SLAB. For tasks so marked, a second inline test is done for the slab cache flag SLAB_MEM_SPREAD, and if that is set and if the allocation is not in_interrupt(), this adds a call to to a cpuset routine that computes which of the tasks mems_allowed nodes should be preferred for this allocation. ==> This patch adds another hook into the performance critical code path to allocating objects from the slab cache, in the ____cache_alloc() chunk, below. The next patch optimizes this hook, reducing the impact of the combined mempolicy plus memory spreading hooks on this critical code path to a single check against the tasks task_struct flags word. This patch provides the generic slab flags and logic needed to apply memory spreading to a particular slab. A subsequent patch will mark a few specific slab caches for this placement policy. Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] cpuset memory spread: slab cache formatPaul Jackson
Rewrap the overly long source code lines resulting from the previous patch's addition of the slab cache flag SLAB_MEM_SPREAD. This patch contains only formatting changes, and no function change. Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] cpuset memory spread: slab cache filesystemsPaul Jackson
Mark file system inode and similar slab caches subject to SLAB_MEM_SPREAD memory spreading. If a slab cache is marked SLAB_MEM_SPREAD, then anytime that a task that's in a cpuset with the 'memory_spread_slab' option enabled goes to allocate from such a slab cache, the allocations are spread evenly over all the memory nodes (task->mems_allowed) allowed to that task, instead of favoring allocation on the node local to the current cpu. The following inode and similar caches are marked SLAB_MEM_SPREAD: file cache ==== ===== fs/adfs/super.c adfs_inode_cache fs/affs/super.c affs_inode_cache fs/befs/linuxvfs.c befs_inode_cache fs/bfs/inode.c bfs_inode_cache fs/block_dev.c bdev_cache fs/cifs/cifsfs.c cifs_inode_cache fs/coda/inode.c coda_inode_cache fs/dquot.c dquot fs/efs/super.c efs_inode_cache fs/ext2/super.c ext2_inode_cache fs/ext2/xattr.c (fs/mbcache.c) ext2_xattr fs/ext3/super.c ext3_inode_cache fs/ext3/xattr.c (fs/mbcache.c) ext3_xattr fs/fat/cache.c fat_cache fs/fat/inode.c fat_inode_cache fs/freevxfs/vxfs_super.c vxfs_inode fs/hpfs/super.c hpfs_inode_cache fs/isofs/inode.c isofs_inode_cache fs/jffs/inode-v23.c jffs_fm fs/jffs2/super.c jffs2_i fs/jfs/super.c jfs_ip fs/minix/inode.c minix_inode_cache fs/ncpfs/inode.c ncp_inode_cache fs/nfs/direct.c nfs_direct_cache fs/nfs/inode.c nfs_inode_cache fs/ntfs/super.c ntfs_big_inode_cache_name fs/ntfs/super.c ntfs_inode_cache fs/ocfs2/dlm/dlmfs.c dlmfs_inode_cache fs/ocfs2/super.c ocfs2_inode_cache fs/proc/inode.c proc_inode_cache fs/qnx4/inode.c qnx4_inode_cache fs/reiserfs/super.c reiser_inode_cache fs/romfs/inode.c romfs_inode_cache fs/smbfs/inode.c smb_inode_cache fs/sysv/inode.c sysv_inode_cache fs/udf/super.c udf_inode_cache fs/ufs/super.c ufs_inode_cache net/socket.c sock_inode_cache net/sunrpc/rpc_pipe.c rpc_inode_cache The choice of which slab caches to so mark was quite simple. I marked those already marked SLAB_RECLAIM_ACCOUNT, except for fs/xfs, dentry_cache, inode_cache, and buffer_head, which were marked in a previous patch. Even though SLAB_RECLAIM_ACCOUNT is for a different purpose, it marks the same potentially large file system i/o related slab caches as we need for memory spreading. Given that the rule now becomes "wherever you would have used a SLAB_RECLAIM_ACCOUNT slab cache flag before (usually the inode cache), use the SLAB_MEM_SPREAD flag too", this should be easy enough to maintain. Future file system writers will just copy one of the existing file system slab cache setups and tend to get it right without thinking. Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] cpuset memory spread page cache implementation and hooksPaul Jackson
Change the page cache allocation calls to support cpuset memory spreading. See the previous patch, cpuset_mem_spread, for an explanation of cpuset memory spreading. On systems without cpusets configured in the kernel, this is no change. On systems with cpusets configured in the kernel, but the "memory_spread" cpuset option not enabled for the current tasks cpuset, this adds a call to a cpuset routine and failed bit test of the processor state flag PF_SPREAD_PAGE. On tasks in cpusets with "memory_spread" enabled, this adds a call to a cpuset routine that computes which of the tasks mems_allowed nodes should be preferred for this allocation. If memory spreading applies to a particular allocation, then any other NUMA mempolicy does not apply. Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] cpuset memory spread basic implementationPaul Jackson
This patch provides the implementation and cpuset interface for an alternative memory allocation policy that can be applied to certain kinds of memory allocations, such as the page cache (file system buffers) and some slab caches (such as inode caches). The policy is called "memory spreading." If enabled, it spreads out these kinds of memory allocations over all the nodes allowed to a task, instead of preferring to place them on the node where the task is executing. All other kinds of allocations, including anonymous pages for a tasks stack and data regions, are not affected by this policy choice, and continue to be allocated preferring the node local to execution, as modified by the NUMA mempolicy. There are two boolean flag files per cpuset that control where the kernel allocates pages for the file system buffers and related in kernel data structures. They are called 'memory_spread_page' and 'memory_spread_slab'. If the per-cpuset boolean flag file 'memory_spread_page' is set, then the kernel will spread the file system buffers (page cache) evenly over all the nodes that the faulting task is allowed to use, instead of preferring to put those pages on the node where the task is running. If the per-cpuset boolean flag file 'memory_spread_slab' is set, then the kernel will spread some file system related slab caches, such as for inodes and dentries evenly over all the nodes that the faulting task is allowed to use, instead of preferring to put those pages on the node where the task is running. The implementation is simple. Setting the cpuset flags 'memory_spread_page' or 'memory_spread_cache' turns on the per-process flags PF_SPREAD_PAGE or PF_SPREAD_SLAB, respectively, for each task that is in the cpuset or subsequently joins that cpuset. In subsequent patches, the page allocation calls for the affected page cache and slab caches are modified to perform an inline check for these flags, and if set, a call to a new routine cpuset_mem_spread_node() returns the node to prefer for the allocation. The cpuset_mem_spread_node() routine is also simple. It uses the value of a per-task rotor cpuset_mem_spread_rotor to select the next node in the current tasks mems_allowed to prefer for the allocation. This policy can provide substantial improvements for jobs that need to place thread local data on the corresponding node, but that need to access large file system data sets that need to be spread across the several nodes in the jobs cpuset in order to fit. Without this patch, especially for jobs that might have one thread reading in the data set, the memory allocation across the nodes in the jobs cpuset can become very uneven. A couple of Copyright year ranges are updated as well. And a couple of email addresses that can be found in the MAINTAINERS file are removed. Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] cpuset use combined atomic_inc_return callsPaul Jackson
Replace pairs of calls to <atomic_inc, atomic_read>, with a single call atomic_inc_return, saving a few bytes of source and kernel text. Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
