Merge reason: We'll be queueing dependent changes.
perf_arch_fetch_caller_regs() is exported for the overriden x86
version, but not for the generic weak version.
As a general rule, weak functions should not have their symbol
exported in the same file they are defined.
So let's export it on trace_event_perf.c as it is used by trace
events only.
This fixes:
ERROR: ".perf_arch_fetch_caller_regs" [fs/xfs/xfs.ko] undefined!
ERROR: ".perf_arch_fetch_caller_regs" [arch/powerpc/platforms/cell/spufs/spufs.ko] undefined!
-v2: And also only build it if trace events are enabled.
-v3: Fix changelog mistake
Cc: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com>
LKML-Reference: <1268697902-9518-1-git-send-regression-fweisbec@gmail.com>
If x86_pmu.hw_config() fails a fixed error code (-EOPNOTSUPP) is
returned even if a different error was reported. This patch fixes
this.
Signed-off-by: Robert Richter <robert.richter@amd.com>
Acked-by: Cyrill Gorcunov <gorcunov@gmail.com>
Acked-by: Lin Ming <ming.m.lin@intel.com>
Cc: acme@redhat.com
Cc: eranian@google.com
Cc: gorcunov@openvz.org
Cc: peterz@infradead.org
Cc: fweisbec@gmail.com
LKML-Reference: <20100316160733.GR1585@erda.amd.com>
The dso_short_width has to start as zero, as we're calculating
the maximum short DSO name length, somehow I missed this one.
Reported-by: Frédéric Weisbecker <fweisbec@gmail.com>
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Frédéric Weisbecker <fweisbec@gmail.com>
LKML-Reference: <1268774926-27488-1-git-send-email-acme@infradead.org>
Hide CONFIG_OPTPROBES and set if the arch supports optimized
kprobes (IOW, HAVE_OPTPROBES=y), since this option doesn't
change the major behavior of kprobes, and workarounds for minor
changes are documented.
Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com>
Cc: systemtap <systemtap@sources.redhat.com>
Cc: DLE <dle-develop@lists.sourceforge.net>
Cc: Dieter Ries <mail@dieterries.net>
Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com>
Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
LKML-Reference: <20100315170054.31593.3153.stgit@localhost6.localdomain6>
Use original address for looking up the location of variables
for dwarf_getlocation_addr() instead of CU-based address.
LKML-Reference: <20100315170235.31852.91195.stgit@localhost6.localdomain6>
Fix dereference offset to intmax_t from uintmax_t, because
it can have negative values (for example local variable's offset
from frame pointer).
LKML-Reference: <20100315170228.31852.71946.stgit@localhost6.localdomain6>
When profiling C++ workloads the symbol name length can be
really big, so cap it before it garbles the result.
This builds upon the autosizing already present where we choose
to use the short, basename of DSOs instead of its long, full
pathname.
Reported-by: Pavel Krauz <krauz@cngroup.cz>
LKML-Reference: <1268676230-9261-1-git-send-email-acme@infradead.org>
Reported-by: Cyrill Gorcunov <gorcunov@openvz.org>
Signed-off-by: Lin Ming <ming.m.lin@intel.com>
LKML-Reference: <1268705556.3379.8.camel@minggr.sh.intel.com>
events only.
This fixes:
Before this patch we would not find a vmlinux, then try to pass
objdump "[kernel.kallsyms]" as the filename, it would get
confused and produce no output:
[root@doppio ~]# perf annotate n_tty_write
Percent | Source code & Disassembly of [kernel.kallsyms]
Now we check that and emit meaningful warning:
Can't annotate n_tty_write: No vmlinux file was found in the
path: [0] vmlinux
[1] /boot/vmlinux
[2] /boot/vmlinux-2.6.34-rc1-tip+
[3] /lib/modules/2.6.34-rc1-tip+/build/vmlinux
[4] /usr/lib/debug/lib/modules/2.6.34-rc1-tip+/vmlinux
[root@doppio ~]#
This bug was introduced when we added automatic search for
vmlinux, before that time the user had to specify a vmlinux
file.
v2: Print the warning just for the first symbol found when no
symbol name is specified, otherwise it will spam the screen
repeating the warning for each symbol.
Reported-by: Ingo Molnar <mingo@elte.hu>
Cc: <stable@kernel.org>
LKML-Reference: <1268669073-6856-1-git-send-email-acme@infradead.org>
Before this patch this message would very briefly appear on the
screen and then the screen would get updates only on the top,
for number of interrupts received, etc, but no annotation would
be performed:
[root@doppio linux-2.6-tip]# perf top -s n_tty_write > /tmp/bla
objdump: '[kernel.kallsyms]': No such file
Now this is what the user gets:
path: [0] vmlinux
[1] /boot/vmlinux
[2] /boot/vmlinux-2.6.33-rc5
[3] /lib/modules/2.6.33-rc5/build/vmlinux
[4] /usr/lib/debug/lib/modules/2.6.33-rc5/vmlinux
file.
Reported-by: David S. Miller <davem@davemloft.net>
LKML-Reference: <1268664418-28328-2-git-send-email-acme@infradead.org>
When forking its target, perf record can capture data from
before the target application is started. Perf stat uses the
enable_on_exec flag in the event attributes to keep from
displaying events from before the target program starts, this
patch adds the same functionality to perf record when it is will
fork the target process.
Signed-off-by: Eric B Munson <ebmunson@us.ibm.com>
LKML-Reference: <1268664418-28328-1-git-send-email-acme@infradead.org>
This should turn on instruction counting on P4s, which was missing in
the first version of the new PMU driver.
It's inaccurate for now, we still need dependant event to tag mops
before we can count them precisely. The result is that the number of
instruction may be lifted up.
Signed-off-by: Cyrill Gorcunov <gorcunov@openvz.org>
LKML-Reference: <1268629102.3355.11.camel@minggr.sh.intel.com>
Ingo reported:
| There's a build failure on -tip with the P4 driver, on UP 32-bit, if
| PERF_EVENTS is enabled but UP_APIC is disabled:
| arch/x86/built-in.o: In function `p4_pmu_handle_irq':
| perf_event.c:(.text+0xa756): undefined reference to `apic'
| perf_event.c:(.text+0xa76e): undefined reference to `apic'
So we have to unmask LVTPC only if we're configured to have one.
CC: Lin Ming <ming.m.lin@intel.com>
CC: Peter Zijlstra <peterz@infradead.org>
LKML-Reference: <20100313081116.GA5179@lenovo>
Set need_dwarf if lazy matching pattern is specified, because
lazy matching requires real source path for which we must use
debuginfo.
LKML-Reference: <20100312232224.2017.54550.stgit@localhost6.localdomain6>
Fix probe_point array-size overrun problem. In some cases (e.g.
inline function), one user-specified probe-point can be
translated to many probe address, and it overruns pre-defined
array-size. This also removes redundant MAX_PROBES macro
definition.
LKML-Reference: <20100312232217.2017.45017.stgit@localhost6.localdomain6>
[ Note that only root can create new probes. Eventually we should remove
the MAX_PROBES limit, but that is a larger patch not eligible to
perf/urgent treatment. ]
The use_browser needs to be in a file that is always built and
also we need a browser__show_help stub in that case.
Reported-by: Anton Blanchard <anton@samba.org>
LKML-Reference: <1268438710-32697-1-git-send-email-acme@infradead.org>
Merge reason: The new P4 driver is stable and ready now for more
testing.
[root@doppio ~]# perf report -i newt.data | head -10
# Samples: 11999679868
# Overhead Command Shared Object Symbol
63.61% perf libslang.so.2.1.4 [.] SLsmg_write_chars
6.30% perf perf [.] symbols__find
2.19% perf libnewt.so.0.52.10 [.] newtListboxAppendEntry
2.08% perf libslang.so.2.1.4 [.] SLsmg_write_chars@plt
1.99% perf libc-2.10.2.so [.] _IO_vfprintf_internal
[root@doppio ~]#
Not good, the newt form for report works, but slang has to eat
the cost of the additional callgraph lines everytime it prints a
line, and the callgraph doesn't appear on the screen, so move
the callgraph printing to a separate function and don't use it
in newt.c.
Newt tree widgets are being investigated to properly support
callgraphs, but till that gets merged, lets remove this huge
overhead and show at least the symbol overheads for a callgraph
rich perf.data with good performance.
LKML-Reference: <1268408808-13595-2-git-send-email-acme@infradead.org>
For consistency, use the newt API more fully.
LKML-Reference: <1268408808-13595-1-git-send-email-acme@infradead.org>
These are keys people expect when pressed to exit the current
widget, so have associate all of them to this semantic.
Suggested-by: Ingo Molnar <mingo@elte.hu>
LKML-Reference: <1268401692-9361-1-git-send-email-acme@infradead.org>
Newt has widespread availability and provides a rather simple
API as can be seen by the size of this patch.
The work needed to support it will benefit other frontends too.
In this initial patch it just checks if the output is a tty, if
not it falls back to the previous behaviour, also if
newt-devel/libnewt-dev is not installed the previous behaviour
is maintaned.
Pressing enter on a symbol will annotate it, ESC in the
annotation window will return to the report symbol list.
More work will be done to remove the special casing in
color_fprintf, stop using fmemopen/FILE in the printing of
hist_entries, etc.
Also the annotation doesn't need to be done via spawning "perf
annotate" and then browsing its output, we can do better by
calling directly the builtin-annotate.c functions, that would
then be moved to tools/perf/util/annotate.c and shared with perf
top, etc
But lets go by baby steps, this patch already improves perf
usability by allowing to quickly do annotations on symbols from
the report screen and provides a first experimentation with
libnewt/TUI integration of tools.
Tested on RHEL5 and Fedora12 X86_64 and on Debian PARISC64 to
browse a perf.data file collected on a Fedora12 x86_64 box.
Cc: Avi Kivity <avi@redhat.com>
LKML-Reference: <1268349164-5822-5-git-send-email-acme@infradead.org>
We need those to properly size the browser widht in the newt
TUI.
LKML-Reference: <1268349164-5822-4-git-send-email-acme@infradead.org>
Just like we do for pr_debug, so that we can have a single point
where to redirect to the currently used output system, be it
stdio or newt.
LKML-Reference: <1268349164-5822-3-git-send-email-acme@infradead.org>
Will be used by the newt code too.
LKML-Reference: <1268349164-5822-2-git-send-email-acme@infradead.org>
LKML-Reference: <1268349164-5822-1-git-send-email-acme@infradead.org>
Merge reason: We want to queue up a dependent patch.
In case of not assigned x86_pmu and software events NULL dereference may
being hit via x86_pmu::schedule_events method.
Fix it by checking if x86_pmu is initialized at all.
Cc: Lin Ming <ming.m.lin@intel.com>
Cc: Stephane Eranian <eranian@google.com>
Cc: Robert Richter <robert.richter@amd.com>
LKML-Reference: <20100311215016.GG25162@lenovo>
[acme@mica linux-2.6-tip]$ perf record -a -f
Fatal: Permission error - are you root?
Consider tweaking /proc/sys/kernel/perf_event_paranoid.
LKML-Reference: <1268333592-30872-2-git-send-email-acme@infradead.org>
Fixing this symptom:
Bus error
I.e. if for some reason no data is collected, in this case a non
root user trying to do systemwide profiling, no data will be
collected, and then we end up trying to mmap a zero sized file
and access the file header, b00m.
LKML-Reference: <1268333592-30872-1-git-send-email-acme@infradead.org>
The netburst PMU is way different from the "architectural
perfomance monitoring" specification that current CPUs use.
P4 uses a tuple of ESCR+CCCR+COUNTER MSR registers to handle
perfomance monitoring events.
A few implementational details:
1) We need a separate x86_pmu::hw_config helper in struct
x86_pmu since register bit-fields are quite different from P6,
Core and later cpu series.
2) For the same reason is a x86_pmu::schedule_events helper
introduced.
3) hw_perf_event::config consists of packed ESCR+CCCR values.
It's allowed since in reality both registers only use a half
of their size. Of course before making a real write into a
particular MSR we need to unpack the value and extend it to
a proper size.
4) The tuple of packed ESCR+CCCR in hw_perf_event::config
doesn't describe the memory address of ESCR MSR register
so that we need to keep a mapping between these tuples
used and available ESCR (various P4 events may use same
ESCRs but not simultaneously), for this sake every active
event has a per-cpu map of hw_perf_event::idx <--> ESCR
addresses.
5) Since hw_perf_event::idx is an offset to counter/control register
we need to lift X86_PMC_MAX_GENERIC up, otherwise kernel
strips it down to 8 registers and event armed may never be turned
off (ie the bit in active_mask is set but the loop never reaches
this index to check), thanks to Peter Zijlstra
Restrictions:
- No cascaded counters support (do we ever need them?)
- No dependent events support (so PERF_COUNT_HW_INSTRUCTIONS
doesn't work for now)
- There are events with same counters which can't work simultaneously
(need to use intersected ones due to broken counter 1)
- No PERF_COUNT_HW_CACHE_ events yet
Todo:
- Implement dependent events
- Need proper hashing for event opcodes (no linear search, good for
debugging stage but not in real loads)
- Some events counted during a clock cycle -- need to set threshold
for them and count every clock cycle just to get summary statistics
(ie to behave the same way as other PMUs do)
- Need to swicth to use event_constraints
- To support RAW events we need to encode a global list of P4 events
into p4_templates
- Cache events need to be added
Event support status matrix:
Event status
cycles works
cache-references works
cache-misses works
branch-misses works
bus-cycles partially (does not work on 64bit cpu with HT enabled)
instruction doesnt work (needs dependent event [mop tagging])
branches doesnt work
LKML-Reference: <20100311165439.GB5129@lenovo>
This patch is an optimization in perf_event_task_sched_in() to avoid
scheduling the events twice in a row.
Without it, the perf_disable()/perf_enable() pair is invoked twice,
thereby pinned events counts while scheduling flexible events and we go
throuh hw_perf_enable() twice.
By encapsulating, the whole sequence into perf_disable()/perf_enable() we
ensure, hw_perf_enable() is going to be invoked only once because of the
refcount protection.
Signed-off-by: Stephane Eranian <eranian@google.com>
LKML-Reference: <1268288765-5326-1-git-send-email-eranian@google.com>
Export perf_trace_regs and perf_arch_fetch_caller_regs since module will
use these.
Signed-off-by: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com>
[ use EXPORT_PER_CPU_SYMBOL_GPL() ]
LKML-Reference: <4B989C1B.2090407@cn.fujitsu.com>
What happens is that we schedule badly like:
<...>-1987 [019] 280.252808: x86_pmu_start: event-46/1300c0: idx: 0
<...>-1987 [019] 280.252811: x86_pmu_start: event-47/1300c0: idx: 1
<...>-1987 [019] 280.252812: x86_pmu_start: event-48/1300c0: idx: 2
<...>-1987 [019] 280.252813: x86_pmu_start: event-49/1300c0: idx: 3
<...>-1987 [019] 280.252814: x86_pmu_start: event-50/1300c0: idx: 32
<...>-1987 [019] 280.252825: x86_pmu_stop: event-46/1300c0: idx: 0
<...>-1987 [019] 280.252826: x86_pmu_stop: event-47/1300c0: idx: 1
<...>-1987 [019] 280.252827: x86_pmu_stop: event-48/1300c0: idx: 2
<...>-1987 [019] 280.252828: x86_pmu_stop: event-49/1300c0: idx: 3
<...>-1987 [019] 280.252829: x86_pmu_stop: event-50/1300c0: idx: 32
<...>-1987 [019] 280.252834: x86_pmu_start: event-47/1300c0: idx: 1
<...>-1987 [019] 280.252834: x86_pmu_start: event-48/1300c0: idx: 2
<...>-1987 [019] 280.252835: x86_pmu_start: event-49/1300c0: idx: 3
<...>-1987 [019] 280.252836: x86_pmu_start: event-50/1300c0: idx: 32
<...>-1987 [019] 280.252837: x86_pmu_start: event-51/1300c0: idx: 32 *FAIL*
This happens because we only iterate the n_running events in the first
pass, and reset their index to -1 if they don't match to force a
re-assignment.
Now, in our RR example, n_running == 0 because we fully unscheduled, so
event-50 will retain its idx==32, even though in scheduling it will have
gotten idx=0, and we don't trigger the re-assign path.
The easiest way to fix this is the below patch, which simply validates
the full assignment in the second pass.
Reported-by: Stephane Eranian <eranian@google.com>
LKML-Reference: <1268311069.5037.31.camel@laptop>
Fix:
arch/powerpc/kernel/perf_event.c:1334: error: 'power_pmu_notifier' undeclared (first use in this function)
arch/powerpc/kernel/perf_event.c:1334: error: (Each undeclared identifier is reported only once
arch/powerpc/kernel/perf_event.c:1334: error: for each function it appears in.)
arch/powerpc/kernel/perf_event.c:1334: error: implicit declaration of function 'power_pmu_notifier'
arch/powerpc/kernel/perf_event.c:1334: error: implicit declaration of function 'register_cpu_notifier'
Due to commit 3f6da390 (perf: Rework and fix the arch CPU-hotplug hooks).
LKML-Reference: <new-submission>
Without this change, the install path is relative to
prefix/DESTDIR where prefix is automatically set to $HOME.
This can produce unexpected results. For example:
make -C tools/perf DESTDIR=/home/jkacur/tmp install-man
creates the directory: /home/jkacur/home/jkacur/tmp/share/...
instead of the expected: /home/jkacur/tmp/share/...
Signed-off-by: John Kacur <jkacur@redhat.com>
Cc: Tom Zanussi <tzanussi@gmail.com>
Cc: Kyle McMartin <kyle@redhat.com>
LKML-Reference: <1268312220-12880-1-git-send-email-jkacur@redhat.com>
execution slot
From : Ananth N Mavinakayanahalli <ananth@in.ibm.com>
When freeing the instruction slot, the arithmetic to calculate
the index of the slot in the page needs to account for the total
size of the instruction on the various architectures.
Calculate the index correctly when freeing the out-of-line
execution slot.
Reported-by: Sachin Sant <sachinp@in.ibm.com>
Reported-by: Heiko Carstens <heiko.carstens@de.ibm.com>
Signed-off-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com>
LKML-Reference: <4B9667AB.9050507@redhat.com>
At present, the perf subcommands that do system-wide monitoring
(perf stat, perf record and perf top) don't work properly unless
the online cpus are numbered 0, 1, ..., N-1. These tools ask
for the number of online cpus with sysconf(_SC_NPROCESSORS_ONLN)
and then try to create events for cpus 0, 1, ..., N-1.
This creates problems for systems where the online cpus are
numbered sparsely. For example, a POWER6 system in
single-threaded mode (i.e. only running 1 hardware thread per
core) will have only even-numbered cpus online.
This fixes the problem by reading the /sys/devices/system/cpu/online
file to find out which cpus are online. The code that does that is in
tools/perf/util/cpumap.[ch], and consists of a read_cpu_map()
function that sets up a cpumap[] array and returns the number of
online cpus. If /sys/devices/system/cpu/online can't be read or
can't be parsed successfully, it falls back to using sysconf to
ask how many cpus are online and sets up an identity map in cpumap[].
The perf record, perf stat and perf top code then calls
read_cpu_map() in the system-wide monitoring case (instead of
sysconf) and uses cpumap[] to get the cpu numbers to pass to
perf_event_open.
Cc: Arnaldo Carvalho de Melo <acme@infradead.org>
LKML-Reference: <20100310093609.GA3959@brick.ozlabs.ibm.com>
Anton Blanchard found that he could reliably make the kernel hit a
BUG_ON in the slab allocator by taking a cpu offline and then online
while a system-wide perf record session was running.
The reason is that when the cpu comes up, we completely reinitialize
the ctx field of the struct perf_cpu_context for the cpu. If there is
a system-wide perf record session running, then there will be a struct
perf_event that has a reference to the context, so its refcount will
be 2. (The perf_event has been removed from the context's group_entry
and event_entry lists by perf_event_exit_cpu(), but that doesn't
remove the perf_event's reference to the context and doesn't decrement
the context's refcount.)
When the cpu comes up, perf_event_init_cpu() gets called, and it calls
__perf_event_init_context() on the cpu's context. That resets the
refcount to 1. Then when the perf record session finishes and the
perf_event is closed, the refcount gets decremented to 0 and the
context gets kfreed after an RCU grace period. Since the context
wasn't kmalloced -- it's part of a per-cpu variable -- bad things
happen.
In fact we don't need to completely reinitialize the context when the
cpu comes up. It's sufficient to initialize the context once at boot,
but we need to do it for all possible cpus.
This moves the context initialization to happen at boot time. With
this, we don't trash the refcount and the context never gets kfreed,
and we don't hit the BUG_ON.
Tested-by: Anton Blanchard <anton@samba.org>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Drop the obsolete "profile" naming used by perf for trace events.
Perf can now do more than simple events counting, so generalize
the API naming.
Cc: Masami Hiramatsu <mhiramat@redhat.com>
Cc: Jason Baron <jbaron@redhat.com>
We are taking a wrong regs snapshot when a trace event triggers.
Either we use get_irq_regs(), which gives us the interrupted
registers if we are in an interrupt, or we use task_pt_regs()
which gives us the state before we entered the kernel, assuming
we are lucky enough to be no kernel thread, in which case
task_pt_regs() returns the initial set of regs when the kernel
thread was started.
What we want is different. We need a hot snapshot of the regs,
so that we can get the instruction pointer to record in the
sample, the frame pointer for the callchain, and some other
things.
Let's use the new perf_fetch_caller_regs() for that.
Comparison with perf record -e lock: -R -a -f -g
Before:
perf [kernel] [k] __do_softirq
--- __do_softirq
|--55.16%-- __open
--44.84%-- __write_nocancel
After:
perf [kernel] [k] perf_tp_event
--- perf_tp_event
|--41.07%-- lock_acquire
| |--39.36%-- _raw_spin_lock
| | |--7.81%-- hrtimer_interrupt
| | | smp_apic_timer_interrupt
The old case was producing unreliable callchains. Now having
right frame and instruction pointers, we have the trace we
want.
Also syscalls and kprobe events already have the right regs,
let's use them instead of wasting a retrieval.
v2: Follow the rename perf_save_regs() -> perf_fetch_caller_regs()
Cc: Archs <linux-arch@vger.kernel.org>
Events that trigger overflows by interrupting a context can
use get_irq_regs() or task_pt_regs() to retrieve the state
when the event triggered. But this is not the case for some
other class of events like trace events as tracepoints are
executed in the same context than the code that triggered
the event.
It means we need a different api to capture the regs there,
namely we need a hot snapshot to get the most important
informations for perf: the instruction pointer to get the
event origin, the frame pointer for the callchain, the code
segment for user_mode() tests (we always use __KERNEL_CS as
trace events always occur from the kernel) and the eflags
for further purposes.
v2: rename perf_save_regs to perf_fetch_caller_regs as per
Masami's suggestion.
We were using the frame pointer based stack walker on every
contexts in x86-32, but not in x86-64 where we only use the
seven-league boots on the exception stacks.
Use it also on irq and process stacks. This utterly accelerate
the captures.
There are rcu locked read side areas in the path where we submit
a trace event. And these rcu_read_(un)lock() trigger lock events,
which create recursive events.
One pair in do_perf_sw_event:
__lock_acquire
|--96.11%-- lock_acquire
| |--27.21%-- do_perf_sw_event
| | perf_tp_event
| | |--49.62%-- ftrace_profile_lock_release
| | | lock_release
| | | |--33.85%-- _raw_spin_unlock
Another pair in perf_output_begin/end:
__lock_acquire
|--23.40%-- perf_output_begin
| | __perf_event_overflow
| | perf_swevent_overflow
| | perf_swevent_add
| | perf_swevent_ctx_event
| | do_perf_sw_event
| | perf_tp_event
| | |--55.37%-- ftrace_profile_lock_acquire
| | | lock_acquire
| | | |--37.31%-- _raw_spin_lock
The problem is not that much the trace recursion itself, as we have a
recursion protection already (though it's always wasteful to recurse).
But the trace events are outside the lockdep recursion protection, then
each lockdep event triggers a lock trace, which will trigger two
other lockdep events. Here the recursive lock trace event won't
be taken because of the trace recursion, so the recursion stops there
but lockdep will still analyse these new events:
To sum up, for each lockdep events we have:
lock_*()
trace lock_acquire
----- rcu_read_lock()
| lock_acquire()
| trace_lock_acquire() (stopped)
| lockdep analyze
----- rcu_read_unlock()
lock_release
trace_lock_release() (stopped)
lockdep analyze
And you can repeat the above two times as we have two rcu read side
sections when we submit an event.
This is fixed in this patch by moving the lock trace event under
the lockdep recursion protection.
Cc: Hitoshi Mitake <mitake@dcl.info.waseda.ac.jp>
Cc: Li Zefan <lizf@cn.fujitsu.com>
Cc: Lai Jiangshan <laijs@cn.fujitsu.com>
Cc: Jens Axboe <jens.axboe@oracle.com>
If -vv is used just the map table will be printed, -vvv will
print the symbol table too, with it we can see that we have a
bug where some samples are not being resolved to a map when we
get them in the perf.data stream, but after we have it all
processed, we can find the right map, some reordering probably
is happening.
Upcoming patches will provide ways to ask for most PERF_SAMPLE_
conditional samples to be taken for !PERF_RECORD_SAMPLE events
too, then we'll be able to ask for PERF_SAMPLE_TIME and
PERF_SAMPLE_CPU to help diagnose this.
LKML-Reference: <1268161097-17761-1-git-send-email-acme@infradead.org>
Perf report does not handle multiple events being reported, even
though perf record stores them properly on disk. This patch
addresses that issue by adding the logic to perf report to use
the event stream id that is saved by record and the new data
structures to seperate the event streams and report them
individually.
LKML-Reference: <1267804269-22660-6-git-send-email-acme@infradead.org>
histogram tree
Now that report can store historgrams for multiple events we
need to be able to do the post processing work for each
histogram. This patch changes the post processing functions so
that they can be called individually for each event's histogram.
[ Guarantee bisectabilty by fixing up builtin-report.c ]
LKML-Reference: <1267804269-22660-5-git-send-email-acme@infradead.org>
This patch adds the structures necessary to count each event
type independently in perf report.
LKML-Reference: <1267804269-22660-4-git-send-email-acme@infradead.org>
In order to minimize the impact of storing multiple events in a
report this function will now take the root of the histogram
tree so that the logic for selecting the proper tree can be
inserted before the call.
LKML-Reference: <1267804269-22660-3-git-send-email-acme@infradead.org>
