This patch added the 5785 device ID and ASIC revision to the code.
Signed-off-by: Matt Carlson <mcarlson@broadcom.com>
Signed-off-by: Michael Chan <mchan@broadcom.com>
Signed-off-by: Benjamin Li <benli@broadcom.com>
This patch introduces the libphy support.
This patch introduces code to register and unregister the tg3 mdio bus
with the system.
This patch introduces the TG3_FLG3_USE_PHYLIB flag and applies it to
some select places. This work makes later patches a little easier to
read.
This patch applies cleanups that would otherwise clutter later
patches.
This patch moves some functions towards the top of the file to avoid
unnecessary function prototypes.
Signed-off-by: Alan Cox <alan@redhat.com>
I've pushed it down as far as I dare at this point. Someone familiar with
the internal PPP semantics can probably push it further. Another step to
eliminating the old BKL ioctl usage.
drivers/net/cpmac.c
net/mac80211/mlme.c
Herbert Xu points out that the use of seperate feature bits for features
to be propagated to VLAN devices is going to get messy real soon.
Replace the VLAN feature bits by a bitmask of feature flags to be
propagated and restore the old GSO_SHIFT/MASK values.
Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6
fmvj18x_cs: The manfid of "NextCom NC5310 rev B" is MANF_ID_FUJITSU.
but this card is MBH10302 based card.
use ConfigBase to detect the cardtype for this card.
Signed-off-by: Komuro <komurojun-mbn@nifty.com>
keep bit7,8 of XIRCREG42_SWC1 in set_multicast_list.
If alloc_skb failed, the recieved packet will be dropped. Do not increase
rx_bytes for dropped packet.
Signed-off-by: Wang Chen <wangchen@cn.fujitsu.com>
Use standard routine for queue purging.
Commit cac1f3c8 factored out the code for get_phy_id so that it
could be reused in multiple places. Turns out that some of the
users can be modular, so we need to export this symbol as well.
The purpose of nla_parse_nested_compat() is to parse attributes which
contain a struct followed by a stream of nested attributes. So far,
it called nla_parse_nested() to parse the stream of nested attributes
which was wrong, as nla_parse_nested() expects a container attribute
as data which holds the attribute stream. It needs to call
nla_parse() directly while pointing at the next possible alignment
point after the struct in the beginning of the attribute.
With this patch, I can no longer reproduce the reported leftover
warnings.
Signed-off-by: Thomas Graf <tgraf@suug.ch>
Acked-by: Patrick McHardy <kaber@trash.net>
WAN: protect protocol list in hdlc.c with RTNL.
Signed-off-by: Krzysztof Hałasa <khc@pm.waw.pl>
The following code appears in the function fs_init_instance in the file drivers/net/fs_enet/fs_enet-main.c.
if (fep->ops == NULL) {
printk(KERN_ERR DRV_MODULE_NAME
": %s No matching ops found (%d).\n",
ndev->name, fpi->fs_no);
err = -EINVAL;
goto err;
This code implies that at the point of err, fep->ops can be NULL, so an
extra test is needed before dereferencing this value.
This problem was found using the following semantic match
(http://www.emn.fr/x-info/coccinelle/)
// <smpl>
expression E, E1;
identifier f;
statement S1,S2,S3;
* if (E == NULL)
... when != if (E == NULL) S1 else S2
when != E = E1
* E->f
... when any
return ...;
else S3
// </smpl>
- Updated version number
Signed-off-by: Sreenivasa Honnur <sreenivasa.honnur@neterion.com>
Signed-off-by: Ramkrishna Vepa <ram.vepa@neterion.com>
- Added napi support when MSIX is enabled.
- Moved test_msi function from s2io_open to probe function.
- Move all the transmit completions to a single msi-x (alarm) vector.
- Enable the continuous timer interrupt for only one transmit fifo.
Signed-off-by: Santosh Rastapur <santosh.rastapur@neterion.com>
The lifespan of the device covers the request_irq .. free_irq interval.
The cast of a void * pointer is not needed either.
Signed-off-by: Francois Romieu <romieu@fr.zoreil.com>
Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com>
Signed-off-by: Bryan Wu <cooloney@kernel.org>
* Resolve some locking issues using atomic_inc/atomic_dec
* move status code in cpmac_check_status
* unmark the BROKEN flag in Kconfig
* move code which should have been in platform code in
arch/mips/ar7/platform.c
* fixed an IRQ storm which lets the kernel hang
* fixed a double call to netif_start_queue which causes a kernel panic
* don't fail to register the PHY, works on many devices now
Signed-off-by: Matteo Croce <matteo@openwrt.org>
Signed-off-by: Felix Fietkau <nbd@openwrt.org>
The use of unsigned long causes the driver to fail on 32-bit systems
which support 64-bit resources.
Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
Add support for Apple USB Ethernet Adapter.
http://store.apple.com/1-800-MY-APPLE/WebObjects/AppleStore.woa/wa/RSLID?nplm=MB442Z/A
Signed-off-by: Aurelien Nephtali <aurelien@sitadelle.com>
Acked-by: Greg KH <greg@kroah.com>
Cc: David Brownell <david-b@pacbell.net>
This patch adds netpoll support for the uli526x ethernet driver --
simply call the interrupt handler for polling.
To do this without disable_irq()/enable_irq() pair we should fully
protect the handler. Luckily, it's already using irqsave spinlock,
the only unprotected place is interrupts re-enabling write. It was
safe to re-enable interrupts without holding the spinlock, but with
netpoll possibility now it doesn't seem so.
Patch was tested using netconsole and KGDBoE.
Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
We were passing NULL as the device. When we actually start supporting
more interesting memory configurations, this will break things, so
we proactively are fixing the bug.
Signed-off-by: Andy Fleming <afleming@freescale.com>
PHYLIB was first marked as BROKEN on S390, then the enclosing menu marked
as non-S390, then the two dependencies merged with the conversion to
menuconfig. Reduce to non-S390.
Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org>
IPv4 would work with this driver only with static arp table entries,
the patch reverts a padto introduced in
commit 26a17b7bbb36a8552d531bc1ad08472fb5aa3007
sc92031: start transmit return value bugfix
The padto does not work because the driver code evaluates `len' later on and
there are cases where skb->len is not updated accordingly.
This was observed with ARP frames (skb->len = 42 bytes, !skb_cloned(),
skb_tailroom = 84 bytes). Then in skb_pad(), the first condition is true, where
skb->len is not updated. As a consequence, the driver uses 42 bytes instead of
the 60 bytes, and the ARP frame never makes it onto the wire.
Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk>
Use netdev_alloc_skb. This sets skb->dev and allows arch specific
allocation. Also simplify and cleanup the alignment code.
nv_open() resets multicast settings, call nv_set_multicast(dev)
to restore them. (Maybe this should rather be moved into nv_open())
Signed-off-by: Tobias Diedrich <ranma+kernel@tdiedrich.de>
This patch makes the needlessly global
myri10ge_get_firmware_capabilities() static.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi>
Cc: Ramkrishna Vepa <ram.vepa@neterion.com>
Cc: Rastapur Santosh <santosh.rastapur@neterion.com>
Cc: Sivakumar Subramani <sivakumar.subramani@neterion.com>
Cc: Sreenivasa Honnur <sreenivasa.honnur@neterion.com>
Fixes the following use after free oops:
ehea: Reboot: freeing all eHEA resources
Unable to handle kernel paging request for data at address 0x6b6b6b6b6b6b6c5b
Faulting instruction address: 0xd000000000354488
cpu 0x0: Vector: 300 (Data Access) at [c00000002ec6f310]
pc: d000000000354488: .ehea_shutdown_single_port+0x50/0x78 [ehea]
lr: d00000000035447c: .ehea_shutdown_single_port+0x44/0x78 [ehea]
sp: c00000002ec6f590
msr: 8000000000009032
dar: 6b6b6b6b6b6b6c5b
dsisr: 40000000
current = 0xc0000000281412e0
paca = 0xc0000000006df300
pid = 10930, comm = reboot
enter ? for help
[c00000002ec6f590] d00000000035d64c .ehea_remove+0x44/0x124 [ehea] (unreliable)
[c00000002ec6f630] c000000000319f88 .of_platform_device_remove+0x40/0x58
[c00000002ec6f6a0] c000000000291018 .__device_release_driver+0xb0/0xf0
[c00000002ec6f730] c000000000291120 .driver_detach+0xc8/0xfc
[c00000002ec6f7c0] c00000000028fe24 .bus_remove_driver+0xb4/0x114
[c00000002ec6f850] c000000000291768 .driver_unregister+0x54/0x74
[c00000002ec6f8e0] c00000000031a0c8 .of_unregister_driver+0x14/0x28
[c00000002ec6f950] c000000000023ba0 .ibmebus_unregister_driver+0x10/0x24
[c00000002ec6f9c0] d000000000354180 .ehea_reboot_notifier+0x30/0x4c [ehea]
[c00000002ec6fa40] c0000000003c95a8 .notifier_call_chain+0x5c/0xcc
[c00000002ec6fae0] c000000000082cd4 .__blocking_notifier_call_chain+0x70/0xb0
[c00000002ec6fb90] c000000000075cf8 .kernel_restart_prepare+0x24/0x58
[c00000002ec6fc10] c000000000075f0c .kernel_restart+0x20/0x6c
[c00000002ec6fc90] c000000000078674 .sys_reboot+0x1d4/0x290
[c00000002ec6fe30] c0000000000086ac syscall_exit+0x0/0x40
Some devices running some WinCE firmware (with SC_* Samsung processors
according to the SynCE project, verified on a HTC P3600 device) fail to
register because they apparently need extra time to respond correctly to
requests. Increase the existing delay to satisfy them. Based on code
from the SynCE project, on a suggestion of David Brownell.
This patch Works For Me(tm).
Signed-off-by: Pierre Ynard <linkfanel@yahoo.fr>
Acked-by: David Brownell <david-b@pacbell.net>
Cc: Greg KH <greg@kroah.com>
Cc: Jeff Garzik <jeff@garzik.org>
When dev_name() is changed to return `const char *':
drivers/net/tokenring/olympic.c: In function 'olympic_probe':
drivers/net/tokenring/olympic.c:234: warning: assignment discards qualifiers from pointer target type
drivers/net/tokenring/3c359.c: In function 'xl_probe':
drivers/net/tokenring/3c359.c:318: warning: assignment discards qualifiers from pointer target type
pci_name() will be changed to return `const char *':
drivers/net/pcnet32.c: In function 'pcnet32_probe1':
drivers/net/pcnet32.c:1884: warning: passing argument 2 of 'pcnet32_alloc_ring' discards qualifiers from pointer target type
use cancel_delayed_work_sync()
Cc: Ben Dooks <ben-linux@fluff.org>
Cc: Enrico Scholz <enrico.scholz@sigma-chemnitz.de>
If device has to be reset by sky2_restart, then need to restore
the VLAN acceleration settings.
This driver has diverged from the out-of-tree driver to which the version
number originally applied. It should be identified primarily by kernel
version.
Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
