2008-10-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: sound/core/memalloc.c
2008-10-11Merge phase #4 (X2APIC, APIC unification, CPU identification unification) of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-v28-for-linus-phase4-D' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (186 commits) x86, debug: print more information about unknown CPUs x86 setup: handle more than 8 CPU flag words x86: cpuid, fix typo x86: move transmeta cap read to early_init_transmeta() x86: identify_cpu_without_cpuid v2 x86: extended "flags" to show virtualization HW feature in /proc/cpuinfo x86: move VMX MSRs to msr-index.h x86: centaur_64.c remove duplicated setting of CONSTANT_TSC x86: intel.c put workaround for old cpus together x86: let intel 64-bit use intel.c x86: make intel_64.c the same as intel.c x86: make intel.c have 64-bit support code x86: little clean up of intel.c/intel_64.c x86: make 64 bit to use amd.c x86: make amd_64 have 32 bit code x86: make amd.c have 64bit support code x86: merge header in amd_64.c x86: add srat_detect_node for amd64 x86: remove duplicated force_mwait x86: cpu make amd.c more like amd_64.c v2 ...
2008-10-11Merge branch 'x86/unify-cpu-detect' into x86-v28-for-linus-phase4-DIngo Molnar
Conflicts: arch/x86/kernel/cpu/common.c arch/x86/kernel/signal_64.c include/asm-x86/cpufeature.h
2008-10-11Merge branch 'x86/apic' into x86-v28-for-linus-phase4-BIngo Molnar
Conflicts: arch/x86/kernel/apic_32.c arch/x86/kernel/apic_64.c arch/x86/kernel/setup.c drivers/pci/intel-iommu.c include/asm-x86/cpufeature.h include/asm-x86/dma-mapping.h
2008-10-11Merge phase #3 (IOMMU) of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-v28-for-linus-phase3-B' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (74 commits) AMD IOMMU: use iommu_device_max_index, fix AMD IOMMU: use iommu_device_max_index x86: add PCI IDs for AMD Barcelona PCI devices x86/iommu: use __GFP_ZERO instead of memset for GART x86/iommu: convert GART need_flush to bool x86/iommu: make GART driver checkpatch clean x86 gart: remove unnecessary initialization x86: restore old GART alloc_coherent behavior revert "x86: make GART to respect device's dma_mask about virtual mappings" x86: export pci-nommu's alloc_coherent iommu: remove fullflush and nofullflush in IOMMU generic option x86: remove set_bit_string() iommu: export iommu_area_reserve helper function AMD IOMMU: use coherent_dma_mask in alloc_coherent add AMD IOMMU tree to MAINTAINERS file AMD IOMMU: use cmd_buf_size when freeing the command buffer AMD IOMMU: calculate IVHD size with a function AMD IOMMU: remove unnecessary cast to u64 in the init code AMD IOMMU: free domain bitmap with its allocation order AMD IOMMU: simplify dma_mask_to_pages ...
2008-10-11Merge phase #2 (PAT updates) of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-v28-for-linus-phase2-B' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (27 commits) x86, cpa: make the kernel physical mapping initialization a two pass sequence, fix x86, pat: cleanups x86: fix pagetable init 64-bit breakage x86: track memtype for RAM in page struct x86, cpa: srlz cpa(), global flush tlb after splitting big page and before doing cpa x86, cpa: remove cpa pool code x86, cpa: no need to check alias for __set_pages_p/__set_pages_np x86, cpa: dont use large pages for kernel identity mapping with DEBUG_PAGEALLOC x86, cpa: make the kernel physical mapping initialization a two pass sequence x86, cpa: remove USER permission from the very early identity mapping attribute x86, cpa: rename PTE attribute macros for kernel direct mapping in early boot x86: make sure the CPA test code's use of _PAGE_UNUSED1 is obvious linux-next: fix x86 tree build failure x86: have set_memory_array_{uc,wb} coalesce memtypes, fix agp: enable optimized agp_alloc_pages methods x86: have set_memory_array_{uc,wb} coalesce memtypes. x86: {reverve,free}_memtype() take a physical address x86: fix pageattr-test agp: add agp_generic_destroy_pages() agp: generic_alloc_pages() ...
2008-10-11Merge branch 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (236 commits) [ARM] 5300/1: fixup spitz reset during boot [ARM] 5295/1: make ZONE_DMA optional [ARM] 5239/1: Palm Zire 72 power management support [ARM] 5298/1: Drop desc_handle_irq() [ARM] 5297/1: [KS8695] Fix two compile-time warnings [ARM] 5296/1: [KS8695] Replace macro's with trailing underscores. [ARM] pxa: allow multi-machine PCMCIA builds [ARM] pxa: add preliminary CPUFREQ support for PXA3xx [ARM] pxa: add missing ACCR bit definitions to pxa3xx-regs.h [ARM] pxa: rename cpu-pxa.c to cpufreq-pxa2xx.c [ARM] pxa/zylonite: add support for USB OHCI [ARM] ohci-pxa27x: use ioremap() and offset for register access [ARM] ohci-pxa27x: introduce pxa27x_clear_otgph() [ARM] ohci-pxa27x: use platform_get_{irq,resource} for the resource [ARM] ohci-pxa27x: move OHCI controller specific registers into the driver [ARM] ohci-pxa27x: introduce flags to avoid direct access to OHCI registers [ARM] pxa: move I2S register and bit definitions into pxa2xx-i2s.c [ARM] pxa: simplify DMA register definitions [ARM] pxa: make additional DCSR bits valid for PXA3xx [ARM] pxa: move i2c register and bit definitions into i2c-pxa.c ... Fixed up conflicts in arch/arm/mach-versatile/core.c sound/soc/pxa/pxa2xx-ac97.c sound/soc/pxa/pxa2xx-i2s.c manually.
2008-10-11security: avoid calling a NULL function pointer in drivers/video/tvaudio.cArjan van de Ven
NULL function pointers are very bad security wise. This one got caught by kerneloops.org quite a few times, so it's happening in the field.... Fix is simple, check the function pointer for NULL, like 6 other places in the same function are already doing. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-11net: fix dummy 'nf_conntrack_event_cache()'Linus Torvalds
The dummy version of 'nf_conntrack_event_cache()' (used when the NF_CONNTRACK_EVENTS config option is not enabled) had not been updated when the calling convention changed. This was introduced by commit a71996fccce4b2086a26036aa3c915365ca36926 ("netfilter: netns nf_conntrack: pass conntrack to nf_conntrack_event_cache() not skb") Tssk. Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: Patrick McHardy <kaber@trash.net> Cc: David Miller <davem@davemloft.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-11Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1075 commits) myri10ge: update driver version number to 1.4.3-1.369 r8169: add shutdown handler r8169: preliminary 8168d support r8169: support additional 8168cp chipset r8169: change default behavior for mildly identified 8168c chipsets r8169: add a new 8168cp flavor r8169: add a new 8168c flavor (bis) r8169: add a new 8168c flavor r8169: sync existing 8168 device hardware start sequences with vendor driver r8169: 8168b Tx performance tweak r8169: make room for more specific 8168 hardware start procedure r8169: shuffle some registers handling around (8168 operation only) r8169: new phy init parameters for the 8168b r8169: update phy init parameters r8169: wake up the PHY of the 8168 af_key: fix SADB_X_SPDDELETE response ath9k: Fix return code when ath9k_hw_setpower() fails on reset ath9k: remove nasty FAIL macro from ath9k_hw_reset() gre: minor cleanups in netlink interface gre: fix copy and paste error ...
2008-10-11Merge git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6: [CIFS] Check that last search entry resume key is valid [CIFS] make sure we have the right resume info before calling CIFSFindNext [CIFS] clean up error handling in cifs_unlink [CIFS] fix some settings of cifsAttrs after calling SetFileInfo and SetPathInfo cifs: explicitly revoke SPNEGO key after session setup cifs: Convert cifs to new aops. [CIFS] update DOS attributes in cifsInode if we successfully changed them cifs: remove NULL termination from rename target in CIFSSMBRenameOpenFIle cifs: work around samba returning -ENOENT on SetFileDisposition call cifs: fix inverted NULL check after kmalloc [CIFS] clean up upcall handling for dns_resolver keys [CIFS] fix busy-file renames and refactor cifs_rename logic cifs: add function to set file disposition [CIFS] add constants for string lengths of keynames in SPNEGO upcall string cifs: move rename and delete-on-close logic into helper function cifs: have find_writeable_file prefer filehandles opened by same task cifs: don't use GFP_KERNEL with GFP_NOFS [CIFS] use common code for turning off ATTR_READONLY in cifs_unlink cifs: clean up variables in cifs_unlink
2008-10-11Merge branch 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linusLinus Torvalds
* 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linus: (49 commits) MIPS: RB532: provide GPIO_BUILTIN_NR and irq_to_gpio/gpio_to_irq MIPS: Move ptrace prototypes to ptrace.h MIPS: Ptrace support for HARDWARE_WATCHPOINTS MIPS: Scheduler support for HARDWARE_WATCHPOINTS. MIPS: Watch exception handling for HARDWARE_WATCHPOINTS. MIPS: Probe watch registers and report configuration. MIPS: Add HARDWARE_WATCHPOINTS definitions and support code. MIPS: Add HARDWARE_WATCHPOINTS configure option. MIPS: Replace use of <asm-generic/uaccess.h> with native implementations. MIPS: TXx9: Add TX4939 ATA support (v2) MIPS: Rewrite spinlocks to ticket locks. MIPS: IP checksums: Optimize adjust of sum on buffers of odd alignment. MIPS: IP checksums: Remove unncessary .set pseudos MIPS: IP checksums: Remove unncessary folding of sum to 16 bit. MIPS: Move headfiles to new location below arch/mips/include MIPS: Alchemy: rename directory MIPS: Optimize get_user and put_user for 64-bit MIPS: TXx9: Implement prom_free_prom_memory MIPS: TXx9: Add RBTX4939 board support MIPS: TXx9: Add TX4939 SoC support ...
2008-10-11Merge branch 'for-linus' of git://git.alsa-project.org/alsa-kernelLinus Torvalds
* 'for-linus' of git://git.alsa-project.org/alsa-kernel: (258 commits) ALSA: hda: VREF powerdown for headphones ALSA: hda: STAC_HP_M4 ALSA: ASoC: Check for machine type in GTA01 machine driver ALSA: mtpav - Fix race in probe ALSA: usb-audio: dynamic detection of MIDI interfaces in uaxx-quirk ALSA: Add a note on dependency of RTC stuff ALSA: ASoC: add new param mux to dapm_mux_update_power ALSA: Increase components array size ALSA: ASoC: Correct inverted Mic PGA Switch control in wm8510 driver ALSA: hda: comment typo fix ALSA: hda: comment typo fix ALSA: hda - Fix PCI SSID for ASROCK K18N78FullHD-hSLI ALSA: snd-usb-audio: support for Edirol UA-4FX device ALSA: usb - Fix possible Oops at USB-MIDI disconnection ALSA: hda - Fix another ALC889A (rev 0x100101) ALSA: hda: add more board-specific information for Realtek ALC662 rev1 ALSA: Correct Vladimir Barinov's e-mail address ALSA: cs46xx: Add PCI IDs for TerraTec and Hercules cards ALSA: hda: SPDIF stream muting support ALSA: hda: appletv support ...
2008-10-11Merge branch 'for-linus' of git://git390.osdl.marist.edu/pub/scm/linux-2.6Linus Torvalds
* 'for-linus' of git://git390.osdl.marist.edu/pub/scm/linux-2.6: (27 commits) [S390] Fix checkstack for s390 [S390] fix initialization of stp [S390] 3215: Remove tasklet. [S390] console flush on panic / reboot [S390] introduce dirty bit for kvm live migration [S390] Add ioctl support for EMC Symmetrix Subsystem Control I/O [S390] xpram: per device block request queues. [S390] dasd: fix message flood for unsolicited interrupts [S390] Move private simple udelay function to arch/s390/lib/delay.c. [S390] dcssblk: add >2G DCSSs support and stacked contiguous DCSSs support. [S390] ptrace changes [S390] s390: use sys_pause for 31bit pause entry point [S390] qdio enhanced SIGA (iqdio) support. [S390] cio: fix cio_tpi. [S390] cio: Correct use of ! and & [S390] cio: inline assembly cleanup [S390] bus_id -> dev_set_name() for css and ccw busses [S390] bus_id ->dev_name() conversions in qdio [S390] Use s390_root_dev_* in kvm_virtio. [S390] more bus_id -> dev_name conversions ...
2008-10-11Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq: [CPUFREQ] Fix BUG: using smp_processor_id() in preemptible code [CPUFREQ] Don't export governors for default governor [CPUFREQ][6/6] cpufreq: Add idle microaccounting in ondemand governor [CPUFREQ][5/6] cpufreq: Changes to get_cpu_idle_time_us(), used by ondemand governor [CPUFREQ][4/6] cpufreq_ondemand: Parameterize down differential [CPUFREQ][3/6] cpufreq: get_cpu_idle_time() changes in ondemand for idle-microaccounting [CPUFREQ][2/6] cpufreq: Change load calculation in ondemand for software coordination [CPUFREQ][1/6] cpufreq: Add cpu number parameter to __cpufreq_driver_getavg() [CPUFREQ] use deferrable delayed work init in conservative governor [CPUFREQ] drivers/cpufreq/cpufreq.c: Adjust error handling code involving cpufreq_cpu_put [CPUFREQ] add error handling for cpufreq_register_governor() error [CPUFREQ] acpi-cpufreq: add error handling for cpufreq_register_driver() error [CPUFREQ] Coding style fixes to arch/x86/kernel/cpu/cpufreq/powernow-k6.c [CPUFREQ] Coding style fixes to arch/x86/kernel/cpu/cpufreq/elanfreq.c
2008-10-11MIPS: RB532: provide GPIO_BUILTIN_NR and irq_to_gpio/gpio_to_irqFlorian Fainelli
This patchs defines the number of built-in the GPIOs present on the SoC as Documentation/gpio.txt recommends to do. Define irq_to_gpio/gpio_to_irq to return the right values so that it fixes a compilation error on drivers/gpio/gpiolib.c when enabling debugfs. Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-10-11MIPS: Move ptrace prototypes to ptrace.hRalf Baechle
2008-10-11MIPS: Ptrace support for HARDWARE_WATCHPOINTSDavid Daney
This is the final part of the watch register patch. Here we hook up ptrace so that the user space debugger (gdb), can set and read the registers. Signed-off-by: David Daney <ddaney@avtrex.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-10-11MIPS: Scheduler support for HARDWARE_WATCHPOINTS.David Daney
Here we hook up the scheduler. Whenever we switch to a new process, we check to see if the watch registers should be installed, and do it if needed. Signed-off-by: David Daney <ddaney@avtrex.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-10-11MIPS: Watch exception handling for HARDWARE_WATCHPOINTS.David Daney
Here we hook up the watch exception handler so that it sends SIGTRAP when the hardware watch registers are triggered. Signed-off-by: David Daney <ddaney@avtrex.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-10-11MIPS: Probe watch registers and report configuration.David Daney
Probe for watch register characteristics, and report them in /proc/cpuinfo. Signed-off-by: David Daney <ddaney@avtrex.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-10-11MIPS: Add HARDWARE_WATCHPOINTS definitions and support code.David Daney
This is the main support code for the patch. Here we just add the code, the following patches hook it up. Signed-off-by: David Daney <ddaney@avtrex.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org> create mode 100644 arch/mips/include/asm/watch.h create mode 100644 arch/mips/kernel/watch.c
2008-10-11MIPS: Add HARDWARE_WATCHPOINTS configure option.David Daney
This is automatically set for all MIPS32 and MIPS64 processors. Signed-off-by: David Daney <ddaney@avtrex.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-10-11MIPS: Replace use of <asm-generic/uaccess.h> with native implementations.Ralf Baechle
2008-10-11MIPS: TXx9: Add TX4939 ATA support (v2)Atsushi Nemoto
Add a helper routine to register tx4939ide driver and use it on RBTX4939 board. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-10-11MIPS: Rewrite spinlocks to ticket locks.Ralf Baechle
Based on patch by Chad Reese of Cavium Networks. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-10-11MIPS: IP checksums: Optimize adjust of sum on buffers of odd alignment.Ralf Baechle
2008-10-11MIPS: IP checksums: Remove unncessary .set pseudosRalf Baechle
They possibly silence meaningful warnings ... Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-10-11MIPS: IP checksums: Remove unncessary folding of sum to 16 bit.Ralf Baechle
2008-10-11MIPS: Move headfiles to new location below arch/mips/includeRalf Baechle
2008-10-11MIPS: Alchemy: rename directoryRalf Baechle
It's more than the au1000 these days. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-10-11MIPS: Optimize get_user and put_user for 64-bitRalf Baechle
A long for the error value leads to unnecessary sign extensions. This patch shrinks an ip27_defconfig kernel build with gcc 4.3.0 by 2256 bytes. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-10-11MIPS: TXx9: Implement prom_free_prom_memoryAtsushi Nemoto
Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-10-11MIPS: TXx9: Add RBTX4939 board supportAtsushi Nemoto
Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org> create mode 100644 arch/mips/txx9/rbtx4939/Makefile create mode 100644 arch/mips/txx9/rbtx4939/irq.c create mode 100644 arch/mips/txx9/rbtx4939/prom.c create mode 100644 arch/mips/txx9/rbtx4939/setup.c create mode 100644 include/asm-mips/txx9/rbtx4939.h
2008-10-11MIPS: TXx9: Add TX4939 SoC supportAtsushi Nemoto
Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org> create mode 100644 arch/mips/pci/pci-tx4939.c create mode 100644 arch/mips/txx9/generic/irq_tx4939.c create mode 100644 arch/mips/txx9/generic/setup_tx4939.c create mode 100644 include/asm-mips/txx9/tx4939.h
2008-10-11MIPS: TXx9: IOC LED supportAtsushi Nemoto
Add leds-gpio platform device for controlling LEDs connected to IOC on RBTX49XX and JMR3927 board. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-10-11MIPS: TXx9: Microoptimize interrupt handlersAtsushi Nemoto
The IOC interrupt status register on RBTX49XX only have 8 bits. Use 8-bit version of __fls() to optimize interrupt handlers. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-10-11MIPS: TXx9: stop_unused_modulesAtsushi Nemoto
TXx9 SoCs have pin multiplex. Stop some controller modules which can not be used due to pin configurations. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-10-11Documentation: Document the RB532 specific kmac tagFlorian Fainelli
The Routerboard 532 bootloader passes the korina ethernet MAC adapter address to the kernel on the command line. Document this in the kernel-parameters file. Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-10-11MIPS: RB532: Convert to GPIO libFlorian Fainelli
This patch converts the rb532 code to use gpio library and register its gpio chip. Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-10-11MIPS: RB532: Remove unused rc32434_sync_delay and rc32434_sync_udelayFlorian Fainelli
This patch removes these two unused functions : rc32434_sync_delay and rc32434_sync_udelay Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-10-11MIPS: RB532: Cleanup the headers againFlorian Fainelli
This patch cleans up headers and regroups informations to where they should reside. While moving, try to have a consistant naming for defines. Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-10-11MIPS: RB532: Remove obsolute reference to setup_serial_portFlorian Fainelli
We are no longer using setup_serial_port. So just remove it from the prom code. Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-10-11MIPS: RB532: Fix id usage in platform devicesFlorian Fainelli
When there is only platform device of the same type, id = -1 should be used, fix this. Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-10-11MIPS: RB532: replace raw volatile read with a readlFlorian Fainelli
This patch replaces a raw read using volatiles with a readl. Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-10-11MIPS: RB532: Remove gpio bootup stateFlorian Fainelli
We are no longer using gpio bootup state, so do not export it and do not parse the kernel command line tag for it. Instead we provide gpio-keys for the button the gpio bootup state was checking. Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-10-11MIPS: RB532: Use physical addresses for gpio and device controller registersFlorian Fainelli
This patch fixes the misuse of virtual addresses for the GPIO and third device controller which would lead to problems while accessing ioremap'd registers. Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-10-11MIPS: RB532: Cleanup and group definitions to their right placesFlorian Fainelli
This patch moves GPIO related definitions to gpio.h and IRQ related to irq.h Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-10-11MIPS: TXx9: Declare smsc_fdc37m81x_config_get() in smsc_fdc37m81x.hAtsushi Nemoto
2008-10-11MIPS: TXx9: Add __init tag for tx4938_pcic1_map_irq.Atsushi Nemoto
