Add support for ethtool -C with verification of user parameters.
Signed-off-by: Michael Chan <mchan@broadcom.com>
Makes IPv4 ip_rcv registration happen last in af_inet.
Missing PCI_REV_DESC define.
Current behaviour is to not report an error if a rate
estimator is created together with a qdisc and the
configuration of the rate estimator is bogus. This leads
to unexpected behaviour because the user is not notified.
New behaviour is to report the error and let the whole
qdisc creation operation fail so the user is able to fix
his mistake.
Signed-off-by: Thomas Graf <tgraf@suug.ch>
Adds qdisc_alloc() to share code between qdisc_create()
and qdisc_create_dflt(). Hides the qdisc alignment behind
macros and makes use of them.
Reduce local_df to a bit field and ip_summed to a 2 bits
field thus saving 13 bits. Move bit fields, packet type,
and protocol into the spare area between the priority
and the destructor. Saves 4 bytes on both, 32bit and
64bit architectures.
As suggested by Herbert Xu:
Since we don't require anything to be in the linear packet range
anymore make len cover the entire packet.
skb_header_pointer handles linear and non-linear data, no need to handle
linear data again.
Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
This is the code to load packet data into a register:
k = fentry->k;
if (k < 0) {
} else {
u32 _tmp, *p;
p = skb_header_pointer(skb, k, 4, &_tmp);
if (p != NULL) {
A = ntohl(*p);
continue;
skb_header_pointer checks if the requested data is within the
linear area:
int hlen = skb_headlen(skb);
if (offset + len <= hlen)
return skb->data + offset;
When offset is within [INT_MAX-len+1..INT_MAX] the addition will
result in a negative number which is <= hlen.
I couldn't trigger a crash on my AMD64 with 2GB of memory, but a
coworker tried on his x86 machine and it crashed immediately.
This patch fixes the check in skb_header_pointer to handle large
positive offsets similar to skb_copy_bits. Invalid data can still
be accessed using negative offsets (also similar to skb_copy_bits),
anyone using negative offsets needs to verify them himself.
Thanks to Thomas Vögtle <thomas.voegtle@coreworks.de> for verifying the
problem by crashing his machine and providing me with an Oops.
Add __attribute__((packed)) to ensure that the stat64 structure is
correctly laid out no matter which ABI the kernel is compiled for.
These didn't match my sed expression correctly, fix them up manually.
Initialise the spinlock for port being used by the console early, but
don't re-initialise it again later.
Patch from Catalin Marinas
The range for the ARMv6 block cache operations is inclusive but the
kernel doesn't re-calculate the end address, causing a page fault when
used (this only happens with support for cache aliasing, otherwise the
blk_flush_kern_dcache_page() is not called). This patch subtracts
L1_CACHE_BYTES from the end address.
Patch from Ben Dooks
The request_irq() function is called by s3c24xx uart driver with
the local IRQs disabled. The request_irq() function can allocate
memory via kmalloc(), and this may sleep causing a warning about
sleeping in an invalid context.
Signed-off-by: Ben Dooks <ben-linux@fluff.org>
Remove the pointless machine description macros, favouring C99
initialisers instead.
This patch kills the dead CONFIG_BLK_DEV_IDE_TCQ entry.
Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@elka.pw.edu.pl>
Rob Punkunus recently submitted a patch to enable support for MCP51/MCP55 in
the amd74xx driver. This patch was whitespace-corrupted and didn't apply to
2.6.12 since MCP51 support was merged in the 2.6.12-rc series.
Gentoo would like to support this hardware for our upcoming release media, so
I fixed the patch, and here it is :)
Signed-off-by: Daniel Drake <dsd@gentoo.org>
* printk("\n") is misplaced, resulting in stray empty line in kernel log
* cleanups nerby: some back-to-back printks are combined, etc
mark the __init section __devinit.
Splitted up from the Debian kernel patch.
Signed-off-by: maximilian attems <janitor@sternwelten.at>
see the thread about the pci hotplug crash on a stratus box.
http://marc.theaimsgroup.com/?l=linux-kernel&m=111930108613386&w=2
That zero just means that nothing else found any irq information either.
This fixes the bug that caused BUG_ON(!irqs_disabled()) to trigger in
run_posix_cpu_timers() on alpha/smp. We didn't disable interrupts
properly before calling smp_percpu_timer_interrupt().
We *do* disable interrupts everywhere except this unfortunate
smp_percpu_timer_interrupt(). Fixed thus.
This patch contains the following possible cleanups:
- make some needlessly global code static
- remove the unneeded global function DBG_REG
Wait 0.5 seconds before scanning for cards after an insertion interrupt.
The electrical connection needs this time to stabilise for some cards.
Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
Use msleep() instead of schedule_timeout() to guarantee the task
delays as expected. Neither signals nor wait-queue events are
important at this point in the code, I believe.
Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com>
Signed-off-by: Domen Puncer <domen@coderock.org>
Use do_div() instead.
Make the magic address values in head.S more obvious as to where
they came from. Wrap all debug code in CONFIG_DEBUG_LL.
The omnimeter_defconfig does not define any machines and
seems to have no other support in the current kernel.
This patch removes the config file, as this is the only
thing currently mentioning the ominmeter.
Patch from Todd Poynor
Add definition of K0DB4 SDCLK<0,3> divide-by-4 control/status bit in the
MDREFR register for Intel XScale PXA27x.
Signed-off-by: Todd Poynor <tpoynor@mvista.com>
Add support for PXA27x Standby mode, a low-power mode that retains CPU
and some peripheral state (the existing "sleep" mode is a power-power
mode that retains less state). Activated via:
echo -n standby > /sys/power/state
Fixup for the recent slab leak fix
Cc: Pekka Enberg <penberg@cs.helsinki.fi>
Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
