git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild
Pull kbuild misc changes from Michal Marek:
"In the non-critical part of kbuild, I have
- Some make coccicheck improvements and two new tests
- Support for a cleaner html output in scripts/kernel-doc, named
html5 (no, it does not play videos, yet)
BTW, Randy wants to route further kernel-doc patches through the
kbuild tree."
* 'misc' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild:
Update SmPL/Coccinelle section of MAINTAINERS
coccicheck: Add the rep+ctxt mode
scripts/coccinelle/tests/odd_ptr_err.cocci: semantic patch for IS_ERR/PTR_ERR inconsistency
scripts/tags.sh: Add magic for pci access functions
scripts/coccinelle: ptr_ret: Add ternary operator version
scripts/kernel-doc: drop maintainer
scripts/kernel-doc: added support for html5
Pull kconfig changes from Michal Marek:
"kconfig in v3.7 is going to
- initialize ncurses only once in menuconfig
- be able to jump to a search result in menuconfig
- change the misnomer oldnoconfig to a more meaningful name
olddefconfig, keeping the old name as alias"
* 'kconfig' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild:
kconfig: replace 'oldnoconfig' with 'olddefconfig', and keep the old name as an alias
menuconfig: Assign jump keys per-page instead of globally
menuconfig: Do not open code textbox scroll up/down
menuconfig: Add jump keys to search results
menuconfig: Extend dialog_textbox so that it can return to a scrolled position
menuconfig: Extend dialog_textbox so that it can exit on arbitrary keypresses
menuconfig: Remove superfluous conditionnal
kconfig: document oldnoconfig to what it really does in conf.c
kconfig/mconf.c: revision of curses initialization.
Pull kbuild changes from Michal Marek:
"The main part of kbuild for v3.7 contains:
- Fix for scripts/Makefile.modpost to not choke on a '.ko' substring
in the build directory path
- Two warning fixes (modpost and main Makefile)
- __compiletime_error works also with gcc 4.3
- make tar{gz,bz2,xz}-pkg uses default compression settings instead
of saving as many bytes as possible (this should actually be in the
misc branch, I don't know why I applied it here)."
* 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild:
compiler-gcc4.h: correct verion check for __compiletime_error
modpost: Permit .GCC.command.line sections
Kbuild: use normal compression settings for tar*-pkg
scripts/Makefile.modpost: error in finding modules from .mod files.
kbuild: Remove useless warning while appending KCFLAGS
Pull fbdev updates from Florian Tobias Schandinat:
"This includes:
- large updates for OMAP
- basic OMAP5 DSS support for DPI and DSI outputs
- large cleanups and restructuring
- some update to Exynos and da8xx-fb
- removal of the pnx4008 driver (arch removed)
- various other small patches"
Fix up some trivial conflicts (mostly just include line changes, but
also some due to the renaming of the deferred work functions by Tejun).
* tag 'fbdev-updates-for-3.7' of git://github.com/schandinat/linux-2.6: (193 commits)
gbefb: fix compile error
video: mark nuc900fb_map_video_memory as __devinit
video/mx3fb: set .owner to prevent module unloading while being used
video: exynos_dp: use clk_prepare_enable and clk_disable_unprepare
drivers/video/exynos/exynos_mipi_dsi.c: fix error return code
drivers/video/savage/savagefb_driver.c: fix error return code
video: s3c-fb: use clk_prepare_enable and clk_disable_unprepare
da8xx-fb: save and restore LCDC context across suspend/resume cycle
da8xx-fb: add pm_runtime support
video/udlfb: fix line counting in fb_write
OMAPDSS: add missing include for string.h
OMAPDSS: DISPC: Configure color conversion coefficients for writeback
OMAPDSS: DISPC: Add manager like functions for writeback
OMAPDSS: DISPC: Configure writeback FIFOs
OMAPDSS: DISPC: Configure writeback specific parameters in dispc_wb_setup()
OMAPDSS: DISPC: Configure overlay-like parameters in dispc_wb_setup
OMAPDSS: DISPC: Add function to set channel in for writeback
OMAPDSS: DISPC: Don't set chroma resampling bit for writeback
OMAPDSS: DISPC: Downscale chroma if plane is writeback
OMAPDSS: DISPC: Configure input and output sizes for writeback
git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs
Pull v9fs update from Eric Van Hensbergen.
* tag 'for-linus-merge-3.7' of git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs:
9P: Fix race between p9_write_work() and p9_fd_request()
9P: Fix race in p9_write_work()
9P: fix test at the end of p9_write_work()
9P: Fix race in p9_read_work()
9p: don't use __getname/__putname for uname/aname
net/9p: Check errno validity
fs/9p: avoid debug OOPS when reading a long symlink
__attribute__((error(msg))) was introduced in gcc 4.3 (not 4.4) and as I
was unable to find any gcc bugs pertaining to it, I'm presuming that it
has functioned as advertised since 4.3.0.
Signed-off-by: Daniel Santos <daniel.santos@pobox.com>
Tested-by: David Rientjes <rientjes@google.com>
Allow .GCC.command.line sections in modules to prevent modpost warnings:
WARNING: sound/usb/snd-usbmidi-lib.o (.GCC.command.line): unexpected non-allocatable section.
Did you forget to use "ax"/"aw" in a .S file?
Note that for example <linux/init.h> contains
section definitions for use in .S files.
Signed-off-by: Jonathan Kliegman <kliegs@chromium.org>
Race scenario:
thread A thread B
p9_write_work() p9_fd_request()
if (list_empty
(&m->unsent_req_list))
spin_lock(&client->lock);
req->status = REQ_STATUS_UNSENT;
list_add_tail(..., &m->unsent_req_list);
spin_unlock(&client->lock);
if (n & POLLOUT &&
!test_and_set_bit(Wworksched, &m->wsched)
schedule_work(&m->wq);
--> not done because Wworksched is set
clear_bit(Wworksched, &m->wsched);
return;
--> nobody will take care of sending the new request.
This is not very likely to happen though, because p9_write_work()
being called with an empty unsent_req_list is not frequent.
But this also means that taking the lock earlier will not be costly.
Signed-off-by: Simon Derr <simon.derr@bull.net>
Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
This patch updates some email addresses and the new
mailing list address.
Signed-off-by: Nicolas Palix <nicolas.palix@imag.fr>
Acked-by: Julia Lawall <julia.lawall@lip6.fr>
This adds a 'rep+ctxt' mode which prints the warning
message followed by the context.
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
Pull i2c-embedded changes from Wolfram Sang:
"The changes for i2c-embedded include:
- massive rework of the omap driver
- massive rework of the at91 driver. In fact, the old driver gets
removed; I am okay with this approach since the old driver was
depending on BROKEN and its limitations made it practically
unusable, so people used bitbanging instead. But even if there are
users, there is no platform_data or module parameter which would
need to be converted. It is just another driver doing I2C
transfers, just way better. Modifications of arch/arm/at91 related
files have proper acks from the maintainer.
- new driver for R-Car I2C
- devicetree and generic_clock conversions and fixes
- usual driver fixes and changes.
The rework patches have come a long way and lots of people have been
involved in creating/testing them. Most patches have been in
linux-next at least since 3.6-rc5. A few have been added in the last
week, I have to admit.
An unexpected (but welcome :)) peak in private life is the cause for
that. The "late" patches shouldn't cause any merge conflicts and I
will have a special eye on them during the stabilization phase. This
is an exception and I want to have the patches in place properly in
time again for the next kernels."
* 'i2c-embedded/for-next' of git://git.pengutronix.de/git/wsa/linux: (44 commits)
MXS: Implement DMA support into mxs-i2c
i2c: add Renesas R-Car I2C driver
i2c: s3c2410: use clk_prepare_enable and clk_disable_unprepare
ARM: OMAP: convert I2C driver to PM QoS for MPU latency constraints
i2c: nomadik: Add Device Tree support to the Nomadik I2C driver
i2c: algo: pca: Fix chip reset function for PCA9665
i2c: mpc: Wait for STOP to hit the bus
i2c: davinci: preparation for switch to common clock framework
omap-i2c: fix incorrect log message when using a device tree
i2c: omap: sanitize exit path
i2c: omap: switch over to autosuspend API
i2c: omap: remove unnecessary pm_runtime_suspended check
i2c: omap: switch to threaded IRQ support
i2c: omap: remove redundant status read
i2c: omap: get rid of the "complete" label
i2c: omap: resize fifos before each message
i2c: omap: simplify IRQ exit path
i2c: omap: always return IRQ_HANDLED
i2c: omap: simplify errata check
i2c: omap: bus: add a receiver flag
Pull ARM SoC fixes from Olof Johansson:
"A series of fixes (and in some cases, some cleanups):
Via Tony Lindgren:
- A collection of OMAP regression fixes, in particular because
firmware no longer sets up all pin states before starting the
kernel.
- cpufreq fixes for OMAP (Rafael is on vacation and this was
pre-agreed).
- A longer series of misc regression fixes and cleanups, warning
removals, etc for OMAP
From Arnd Bergmann:
- A series of warning fixes for various platforms (defconfig builds)
Misc:
- A couple of tegra fixes, one for i.MX, some vt8500 fixes, etc."
* tag 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (73 commits)
ARM: pxa: armcore: fix PCI PIO warnings
ARM: integrator: use __iomem pointers for MMIO, part 2
ARM: assabet: fix bogus warning in get_assabet_scr (again)
ARM: shmobile: mark shmobile_init_late as __init
ARM: integrator_cp: fix build failure
ARM: OMAP4/AM335x: hwmod: fix disable_module regression in hardreset handling
ARM: OMAP3: fix workaround for EMU clockdomain
arm/omap: Replace board_ref_clock with enum values
ARM: OMAP2+: remove duplicated include from board-omap3stalker.c
arch/arm/plat-omap/omap-pm-noop.c: Remove unecessary semicolon
arch/arm/mach-omap2: Remove unecessary semicolon
arch/arm/mach-omap1/devices.c: Remove unecessary semicolon
ARM/dts: omap5-evm: pinmux configuration for audio
ARM/dts: Add pinctrl driver entries for omap5
ARM/dts: omap4-panda: pinmux configuration for audio
ARM/dts: omap4-sdp: pinmux configuration for audio
ARM/dts: omap5-evm: Disable unused McBSP3
ARM/dts: omap4-sdp: Disable unused McBSP3
ARM/dts: omap4-panda: Disable unused audio IPs
ARM: OMAP: board-omap4panda: Pin mux configuration for audio needs
In autofs4_d_automount(), if a mount fail occurs the AUTOFS_INF_PENDING
mount pending flag is not cleared.
One effect of this is when using the "browse" option, directory entry
attributes show up with all "?"s due to the incorrect callback and
subsequent failure return (when in fact no callback should be made).
Signed-off-by: Ian Kent <ikent@redhat.com>
Cc: stable@vger.kernel.org
Merge misc fixes from Andrew Morton:
"Followups, fixes and some random stuff I found on the internet."
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (11 patches)
perf: fix duplicate header inclusion
memcg, kmem: fix build error when CONFIG_INET is disabled
rtc: kconfig: fix RTC_INTF defaults connected to RTC_CLASS
rapidio: fix comment
lib/kasprintf.c: use kmalloc_track_caller() to get accurate traces for kvasprintf
rapidio: update for destination ID allocation
rapidio: update asynchronous discovery initialization
rapidio: use msleep in discovery wait
mm: compaction: fix bit ranges in {get,clear,set}_pageblock_skip()
arch/powerpc/platforms/pseries/hotplug-memory.c: section removal cleanups
arch/powerpc/platforms/pseries/hotplug-memory.c: fix section handling code
The patch "drivers/video/gbefb.c: use devm_ functions" caused a
compile error.
drivers/video/gbefb.c:1159:16: error: implicit declaration of function
'devm_ioremap' [-Werror=implicit-function-declaration]
drivers/video/gbefb.c:1179:3: error: implicit declaration of function
'devm_ioremap_nocache' [-Werror=implicit-function-declaration]
Fix it by including linux/io.h which defines those functions.
Reported-by: Geert Uytterhoeven <geert@linux-m68k.org>
Signed-off-by: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
Cc: Damien Cassou <damien.cassou@lifl.fr>
Pull block IO update from Jens Axboe:
"Core block IO bits for 3.7. Not a huge round this time, it contains:
- First series from Kent cleaning up and generalizing bio allocation
and freeing.
- WRITE_SAME support from Martin.
- Mikulas patches to prevent O_DIRECT crashes when someone changes
the block size of a device.
- Make bio_split() work on data-less bio's (like trim/discards).
- A few other minor fixups."
Fixed up silent semantic mis-merge as per Mikulas Patocka and Andrew
Morton. It is due to the VM no longer using a prio-tree (see commit
6b2dbba8b6ac: "mm: replace vma prio_tree with an interval tree").
So make set_blocksize() use mapping_mapped() instead of open-coding the
internal VM knowledge that has changed.
* 'for-3.7/core' of git://git.kernel.dk/linux-block: (26 commits)
block: makes bio_split support bio without data
scatterlist: refactor the sg_nents
scatterlist: add sg_nents
fs: fix include/percpu-rwsem.h export error
percpu-rw-semaphore: fix documentation typos
fs/block_dev.c:1644:5: sparse: symbol 'blkdev_mmap' was not declared
blockdev: turn a rw semaphore into a percpu rw semaphore
Fix a crash when block device is read and block size is changed at the same time
block: fix request_queue->flags initialization
block: lift the initial queue bypass mode on blk_register_queue() instead of blk_init_allocated_queue()
block: ioctl to zero block ranges
block: Make blkdev_issue_zeroout use WRITE SAME
block: Implement support for WRITE SAME
block: Consolidate command flag and queue limit checks for merges
block: Clean up special command handling logic
block/blk-tag.c: Remove useless kfree
block: remove the duplicated setting for congestion_threshold
block: reject invalid queue attribute values
block: Add bio_clone_bioset(), bio_clone_kmalloc()
block: Consolidate bio_alloc_bioset(), bio_kmalloc()
git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394
Pull a firewire fix from Stefan Richter:
"Fixes an old bug of the /dev/fw* ioctl ABI."
* tag 'firewire-fix' of git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394:
firewire: cdev: fix user memory corruption (i386 userland on amd64 kernel)
Pull vfio fixes from Alex Williamson:
"This includes a fix for PCI BAR mmaps after recent mm changes, fixing
an interrupt race, and fixing a consistency bug in interrupt state
when switching interrupt modes."
* tag 'vfio-for-v3.7-rc1' of git://github.com/awilliam/linux-vfio:
vfio: Fix PCI INTx disable consistency
vfio: Move PCI INTx eventfd setting earlier
vfio: Fix PCI mmap after b3b9c293
#include <stdbool.h> somehow got duplicated on its way to linus's tree
(probably as a conflict resolution as things got sent through multiple
trees)
Signed-off-by: Michel Lespinasse <walken@google.com>
Cc: Adrian Hunter <adrian.hunter@intel.com>
Commit e1aab161e013 ("socket: initial cgroup code.") causes a build
error when CONFIG_INET is disabled in Linus' tree:
net/built-in.o: In function `sk_update_clone':
net/core/sock.c:1336: undefined reference to `sock_update_memcg'
sock_update_memcg() is only defined when CONFIG_INET is enabled, so fix
it by defining the dummy function without this option.
Signed-off-by: David Rientjes <rientjes@google.com>
Reported-by: Randy Dunlap <rdunlap@xenotime.net>
Cc: Glauber Costa <glommer@parallels.com>
Cc: Fengguang Wu <fengguang.wu@intel.com>
Commit 6b8029fab641 ("rtc: kconfig: remove unnecessary dependencies")
removed various 'depends on RTC_CLASS' dependencies but also removed a
few 'default RTC_CLASS' statements, which actually changed default
behavior.
This resulted in the various RTC interfaces (sysfs, proc, dev) all being
disabled by default, even when RTC_CLASS is enabled:
# CONFIG_RTC_INTF_SYSFS is not set
# CONFIG_RTC_INTF_PROC is not set
# CONFIG_RTC_INTF_DEV is not set
which is different from previous behavior (all of these where enabled.)
To fix, add back the 'default RTC_CLASS' statments to each of the
RTC_INTF_* options.
I noticed this because some RTC tests started failing on my TI OMAP
platforms because /dev/rtc0 was not present anymore, even though the
driver was present and RTC_CLASS was enabled.
Signed-off-by: Kevin Hilman <khilman@ti.com>
Acked-by: Venu Byravarasu <vbyravarasu@nvidia.com>
The resource index for the mailboxes was incorrect.
Signed-off-by: Chad Reese <kreese@caviumnetworks.com>
Acked-by: Alexandre Bounine <alexandre.bounine@idt.com>
kvasprintf
Previously kvasprintf() allocation was being done through kmalloc(),
thus producing an inaccurate trace report.
This is a common problem: in order to get accurate callsite tracing, a
lib/utils function shouldn't allocate kmalloc but instead use
kmalloc_track_caller.
Signed-off-by: Ezequiel Garcia <elezegarcia@gmail.com>
Address comments provided by Andrew Morton:
https://lkml.org/lkml/2012/10/3/550
- Keeps consistent kerneldoc compatible comments style for new static
functions.
- Removes unnecessary complexity from destination ID allocation
routine.
- Uses kcalloc() for code clarity.
Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com>
Cc: Matt Porter <mporter@kernel.crashing.org>
Cc: Li Yang <leoli@freescale.com>
Update discovery process initialization based on Andrew Morton's comments:
https://lkml.org/lkml/2012/10/3/552.
This update processes all enumerating mports first and schedules discovery
work after that. If the initialization routine fails to allocate resources
needed to execute discovery, it abandons discovery for all ports.
Use msleep() for code clarity as suggested by Andrew Morton in his
comments for the original patch: https://lkml.org/lkml/2012/10/3/546.
{get,clear,set}_pageblock_skip() use incorrect bit ranges (please compare
to bit ranges used by {get,set}_pageblock_flags() used for migration
types) and can overwrite pageblock migratetype of the next pageblock in
the bitmap.
Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
Tested-by: Thierry Reding <thierry.reding@avionic-design.de>
Acked-by: Minchan Kim <minchan@kernel.org>
Followups to d760afd4d257 ("memory-hotplug: suppress "Trying to free
nonexistent resource <XXXXXXXXXXXXXXXX-YYYYYYYYYYYYYYYY>" warning").
- use unsigned long type, as overflows are conceivable
- rename `i' to the less-misleading and more informative `section'
Fix
arch/powerpc/platforms/pseries/hotplug-memory.c: In function 'pseries_remove_memblock':
arch/powerpc/platforms/pseries/hotplug-memory.c:103:17: error: unused variable 'pfn' [-Werror=unused-variable]
Caused by commit d760afd4d257 ("memory-hotplug: suppress "Trying to free
Cc: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
Tested-by: Stephen Rothwell <sfr@canb.auug.org.au>
Tested-by: Nathan Fontenot <nfont@linux.vnet.ibm.com>
Tested-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging
Pull hwmon updates from Jean Delvare:
"Only trivial things this time"
* 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging:
hwmon: Drop needless includes of <linux/delay.h>
hwmon: Add missing inclusions of <linux/err.h>
hwmon: Add missing inclusions of <linux/jiffies.h>
hwmon: Fix spelling of Celsius
hwmon: Update Alexey Fisher's name
The virq_disabled flag tracks the userspace view of INTx masking
across interrupt mode changes, but we're not consistently applying
this to the interrupt and masking handler notion of the device.
Currently if the user sets DisINTx while in MSI or MSIX mode, then
returns to INTx mode (ex. rebooting a qemu guest), the hardware has
DisINTx+, but the management of INTx thinks it's enabled, making it
impossible to actually clear DisINTx. Fix this by updating the
handler state when INTx is re-enabled.
Signed-off-by: Alex Williamson <alex.williamson@redhat.com>
We need to be ready to recieve an interrupt as soon as we call
request_irq, so our eventfd context setting needs to be moved
earlier. Without this, an interrupt from our device or one
sharing the interrupt line can pass a NULL into eventfd_signal
and oops.
Our mmap path mistakely relied on vma->vm_pgoff to get set in
remap_pfn_range. After b3b9c293, that path only applies to
copy-on-write mappings. Set it in our own code.
Pull NFS client updates from Trond Myklebust:
"Features include:
- Remove CONFIG_EXPERIMENTAL dependency from NFSv4.1
Aside from the issues discussed at the LKS, distros are shipping
NFSv4.1 with all the trimmings.
- Fix fdatasync()/fsync() for the corner case of a server reboot.
- NFSv4 OPEN access fix: finally distinguish correctly between
open-for-read and open-for-execute permissions in all situations.
- Ensure that the TCP socket is closed when we're in CLOSE_WAIT
- More idmapper bugfixes
- Lots of pNFS bugfixes and cleanups to remove unnecessary state and
make the code easier to read.
- In cases where a pNFS read or write fails, allow the client to
resume trying layoutgets after two minutes of read/write-
through-mds.
- More net namespace fixes to the NFSv4 callback code.
- More net namespace fixes to the NFSv3 locking code.
- More NFSv4 migration preparatory patches.
Including patches to detect network trunking in both NFSv4 and
NFSv4.1
- pNFS block updates to optimise LAYOUTGET calls."
* tag 'nfs-for-3.7-1' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: (113 commits)
pnfsblock: cleanup nfs4_blkdev_get
NFS41: send real read size in layoutget
NFS41: send real write size in layoutget
NFS: track direct IO left bytes
NFSv4.1: Cleanup ugliness in pnfs_layoutgets_blocked()
NFSv4.1: Ensure that the layout sequence id stays 'close' to the current
NFSv4.1: Deal with seqid wraparound in the pNFS return-on-close code
NFSv4 set open access operation call flag in nfs4_init_opendata_res
NFSv4.1: Remove the dependency on CONFIG_EXPERIMENTAL
NFSv4 reduce attribute requests for open reclaim
NFSv4: nfs4_open_done first must check that GETATTR decoded a file type
NFSv4.1: Deal with wraparound when updating the layout "barrier" seqid
NFSv4.1: Deal with wraparound issues when updating the layout stateid
NFSv4.1: Always set the layout stateid if this is the first layoutget
NFSv4.1: Fix another refcount issue in pnfs_find_alloc_layout
NFSv4: don't put ACCESS in OPEN compound if O_EXCL
NFSv4: don't check MAY_WRITE access bit in OPEN
NFS: Set key construction data for the legacy upcall
NFSv4.1: don't do two EXCHANGE_IDs on mount
NFS: nfs41_walk_client_list(): re-lock before iterating
These drivers use no sleep or delay functions so they don't need to
include <linux/delay.h>.
Acked-by: Guenter Roeck <linux@roeck-us.net>
Cc: Rudolf Marek <r.marek@assembler.cz>
These drivers use IS_ERR so they should include <linux/err.h>.
Acked-by: Luca Tettamanti <kronos.it@gmail.com>
Cc: Henrik Rydberg <rydberg@euromail.se>
Many hwmon drivers use jiffies but omit the inclusion of the header
file. Fix that, and also fix one driver which was including the header
file but didn't need it.
Cc: Marc Hulsman <m.hulsman@tudelft.nl>
Signed-off-by: Peter Meerwald <pmeerw@pmeerw.net>
My name was change after migration.
Signed-off-by: Oleksij Rempel <bug-track@fisher-privat.net>
Pull pwm changes from Thierry Reding:
"All legacy PWM providers have now been moved to the PWM subsystem.
The plan for 3.8 is to adapt all board files to provide a lookup table
for PWM devices in order to get rid of the global namespace.
Subsequently, users of the legacy pwm_request() and pwm_free()
functions can be migrated to the new pwm_get() and pwm_put()
functions. Once this has been completed, the legacy API and the
compatibility code in the core can be removed.
In addition to the above, these changes also add support for
configuring the polarity of a PWM signal (currently only supported on
ECAP and EHRPWM) and include a much needed rework of the i.MX driver.
Managed functions to obtain and release a PWM device (devm_pwm_get()
and devm_pwm_put()) have been added and the pwm-backlight driver has
been updated to use them. If the PWM subsystem hasn't been enabled,
dummy functions are provided that allow the subsystem to safely
compile out.
Some common checks on input parameters have been moved to the core and
removed from the drivers. Finally, a small fix corrects the
description of the PWM specifier's second cell in the device tree
representation."
* tag 'for-3.7-rc1' of git://gitorious.org/linux-pwm/linux-pwm: (23 commits)
pwm: dt: Fix description of second PWM cell
pwm: Check for negative duty-cycle and period
pwm: Add Ingenic JZ4740 support
MIPS: JZ4740: Export timer API
pwm: Move PUV3 PWM driver to PWM framework
unicore32: pwm: Use managed resource allocations
unicore32: pwm: Remove unnecessary indirection
unicore32: pwm: Use module_platform_driver()
unicore32: pwm: Properly remap memory-mapped registers
pwm-backlight: Use devm_pwm_get() instead of pwm_get()
pwm: Move AB8500 PWM driver to PWM framework
pwm: Fix compilation error when CONFIG_PWM is not defined
pwm: i.MX: fix clock lookup
pwm: i.MX: use per clock unconditionally
pwm: i.MX: add devicetree support
pwm: i.MX: Use module_platform_driver
pwm: i.MX: add functions to enable/disable pwm.
pwm: i.MX: remove unnecessary if in pwm_[en|dis]able
pwm: i.MX: factor out SoC specific functions
pwm: pwm-tiehrpwm: Add support for configuring polarity of PWM
git://git.kernel.org/pub/scm/linux/kernel/git/cooloney/linux-leds
Pull LED subsystem update from Bryan Wu.
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/cooloney/linux-leds: (24 commits)
leds: add output driver configuration for pca9633 led driver
leds: lm3642: Use regmap_update_bits() in lm3642_chip_init()
leds: Add new LED driver for lm3642 chips
leds-lp5523: Fix riskiness of the page fault
leds-lp5523: turn off the LED engines on unloading the driver
leds-lm3530: Fix smatch warnings
leds-lm3530: Use devm_regulator_get function
leds: leds-gpio: adopt pinctrl support
leds: Add new LED driver for lm355x chips
leds-lp5523: use the i2c device id rather than fixed name
leds-lp5523: add new device id for LP55231
leds-lp5523: support new LP55231 device
leds: triggers: send uevent when changing triggers
leds-lp5523: minor code style fixes
leds-lp5523: change the return type of lp5523_set_mode()
leds-lp5523: set the brightness to 0 forcely on removing the driver
leds-lp5523: add channel name in the platform data
leds: leds-gpio: Use of_get_child_count() helper
leds: leds-gpio: Use platform_{get,set}_drvdata
leds: leds-gpio: use of_match_ptr()
git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending
Pull scsi target updates from Nicholas Bellinger:
"Things have been calm for the most part with no new fabric drivers in
flight for v3.7 (we're up to eight now !), so this update is primarily
focused on addressing a few long-standing items within target-core and
iscsi-target fabric code.
The highlights include:
- target: Simplify fabric sense data length handling (roland)
- qla2xxx: Fix endianness of task management response code (roland)
- target: fix truncation of mode data, support zero allocation length
(paolo)
- target: Properly support zero-length commands in normal processing
path (paolo)
- iscsi-target: Correctly set 0xffffffff field within ISCSI_OP_REJECT
PDU (ronnie + nab)
- iscsi-target: Add explicit set of cache_dynamic_acls=1 for TPG
demo-mode (ronnie + nab)
- target/file: Re-enable optional fd_buffered_io=1 operation (nab +
hch)
- iscsi-target: Add MaxXmitDataSegmenthLength forr target ->
initiator MDRSL declaration (nab)
- target: Add target_submit_cmd_map_sgls for SGL fabric memory
passthrough (nab + hch)
- tcm_loop: Convert I/O path to use target_submit_cmd_map_sgls (hch +
nab)
- tcm_vhost: Convert I/O path to use target_submit_cmd_map_sgls (nab
+ hch)
The last series for adding a new target_submit_cmd_map_sgls() fabric
caller (as requested by hch) that accepts pre-allocated SGL memory
(using existing logic), along with converting tcm_loop + tcm_vhost has
only been in -next for the last days, but has gotten enough review
+testing and is clear enough a mechanical change that I think it's
reasonable to merge for -rc1 code.
Thanks again to everyone who contributed this round! Extra special
thanks to Roland (PureStorage) for tracking down the qla2xxx target
TMR response code endian issue, and to Paolo (Redhat) for resolving
the long standing zero-length CDB issues within target-core between
virtual and pSCSI backends."
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: (44 commits)
iscsi-target: Bump defaults for nopin_timeout + nopin_response_timeout values
iscsit: proper endianess conversions
iscsit: use the itt_t abstract type
iscsit: add missing endianess conversion in iscsit_check_inaddr_any
iscsit: remove incorrect unlock in iscsit_build_sendtargets_resp
iscsit: mark various functions static
target/iscsi: precedence bug in iscsit_set_dataout_sequence_values()
target/usb-gadget: strlen() doesn't count the terminator
target/usb-gadget: remove duplicate initialization
target: Add control CDB READ payload zero work-around
target: Add target_submit_cmd_map_sgls for SGL fabric memory passthrough
iscsi-target: Add explicit set of cache_dynamic_acls=1 for TPG demo-mode
iscsi-target: Change iscsi_target_seq_pdu_list.c to honor MaxXmitDataSegmentLength
iscsi-target: Add MaxXmitDataSegmentLength connection recovery check
iscsi-target: Convert incoming PDU payload checks to MaxXmitDataSegmentLength
iscsi-target: Enable MaxXmitDataSegmentLength operation in login path
iscsi-target: Add base MaxXmitDataSegmentLength code
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux
Pull second s390 update from Martin Schwidefsky:
"The big thing in this pull request is the UAPI patch from David, and
worth mentioning is the page table dumper. The rest are small
improvements and bug fixes."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux:
s390/entry: fix svc number for TIF_SYSCALL system call restart
s390/mm,vmem: fix vmem_add_mem()/vmem_remove_range()
s390/vmalloc: have separate modules area
s390/zcrypt: remove duplicated include from zcrypt_pcixcc.c
s390/css_chars: remove superfluous ifdef
s390/chsc: make headers usable
s390/mm: let kernel text section always begin at 1MB
s390/mm: fix mapping of read-only kernel text section
s390/mm: add page table dumper
s390: add support to start the kernel in 64 bit mode.
s390/mm,pageattr: remove superfluous EXPORT_SYMBOLs
s390/mm,pageattr: add more page table walk sanity checks
s390/mm: fix pmd_huge() usage for kernel mapping
s390/dcssblk: cleanup device attribute usage
s390/mm: use pfmf instruction to initialize storage keys
s390/facilities: cleanup PFMF and HPAGE machine facility detection
UAPI: (Scripted) Disintegrate arch/s390/include/asm
Pull nouveau drm fixes from Dave Airlie:
"Just a bunch of nouveau fixes, Ben wants to get some alternate
versions into stable."
* 'drm-fixes' of git://people.freedesktop.org/~airlied/linux:
drm/nouveau/timer: bump ptimer's alarm delay from u32 to u64
drm/nouveau/fan: fix a typo in PWM's input clock calculation
drm/nv50/clk: wire up pll_calc hook
drm/nouveau: remove unused _nouveau_parent_ctor
drm/nouveau/bios: fix shadowing of ACPI ROMs larger than 64KiB
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal
Pull generic execve() changes from Al Viro:
"This introduces the generic kernel_thread() and kernel_execve()
functions, and switches x86, arm, alpha, um and s390 over to them."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: (26 commits)
s390: convert to generic kernel_execve()
s390: switch to generic kernel_thread()
s390: fold kernel_thread_helper() into ret_from_fork()
s390: fold execve_tail() into start_thread(), convert to generic sys_execve()
um: switch to generic kernel_thread()
x86, um/x86: switch to generic sys_execve and kernel_execve
x86: split ret_from_fork
alpha: introduce ret_from_kernel_execve(), switch to generic kernel_execve()
alpha: switch to generic kernel_thread()
alpha: switch to generic sys_execve()
arm: get rid of execve wrapper, switch to generic execve() implementation
arm: optimized current_pt_regs()
arm: introduce ret_from_kernel_execve(), switch to generic kernel_execve()
arm: split ret_from_fork, simplify kernel_thread() [based on patch by rmk]
new helper: current_pt_regs()
preparation for generic kernel_thread()
um: kill thread->forking
um: let signal_delivered() do SIGTRAP on singlestepping into handler
into fbdev-next
Omapdss driver changes for the 3.7 merge window.
Notable changes:
* Basic writeback support for DISPC level. Writeback is not yet usable, though,
as we need higher level code to actually expose the writeback feature to
userspace.
* Rewriting the omapdss output drivers. We're trying to remove the hard links
between the omapdss and the panels, and this rewrite work moves us closer to
that goal.
* Cleanup and restructuring patches that have been made while working on device
tree support for omapdss. Device tree support is still some way ahead, but
these patches are good cleanups in themselves.
* Basic OMAP5 DSS support for DPI and DSI outputs.
* Workaround for the problem that GFX overlay's fifo is too small for high
resolution scenarios, causing underflows.
* Cleanups that remove dependencies to omap platform code.
git://git.kernel.org/pub/scm/linux/kernel/git/rw/uml
Pull UML changes from Richard Weinberger:
"UML receives this time only cleanups.
The most outstanding change is the 'include "foo.h"' do 'include
<foo.h>' conversion done by Al Viro.
It touches many files, that's why the diffstat is rather big."
* 'for-linus-37rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rw/uml:
typo in UserModeLinux-HOWTO
hppfs: fix the return value of get_inode()
hostfs: drop vmtruncate
um: get rid of pointless include "..." where include <...> will do
um: move sysrq.h out of include/shared
um/x86: merge 32 and 64 bit variants of ptrace.h
um/x86: merge 32 and 64bit variants of checksum.h
Pull networking updates from David Miller:
1) UAPI changes for networking from David Howells
2) A netlink dump is an operation we can sleep within, and therefore we
need to make sure the dump provider module doesn't disappear on us
meanwhile. Fix from Gao Feng.
3) Now that tunnels support GRO, we have to be more careful in
skb_gro_reset_offset() otherwise we OOPS, from Eric Dumazet.
4) We can end up processing packets for VLANs we aren't actually
configured to be on, fix from Florian Zumbiehl.
5) Fix routing cache removal regression in redirects and IPVS. The
core issue on the IPVS side is that it wants to rewrite who the
nexthop is and we have to explicitly accomodate that case. From
Julian Anastasov.
6) Error code return fixes all over the networking drivers from Peter
Senna Tschudin.
7) Fix routing cache removal regressions in IPSEC, from Steffen
Klassert.
8) Fix deadlock in RDS during pings, from Jeff Liu.
9) Neighbour packet queue can trigger skb_under_panic() because we do
not reset the network header of the SKB in the right spot. From
Ramesh Nagappa.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (61 commits)
RDS: fix rds-ping spinlock recursion
netdev/phy: Prototype of_mdio_find_bus()
farsync: fix support for over 30 cards
be2net: Remove code that stops further access to BE NIC based on UE bits
pch_gbe: Fix build error by selecting all the possible dependencies.
e1000e: add device IDs for i218
ixgbe/ixgbevf: Limit maximum jumbo frame size to 9.5K to avoid Tx hangs
ixgbevf: Set the netdev number of Tx queues
UAPI: (Scripted) Disintegrate include/linux/tc_ematch
UAPI: (Scripted) Disintegrate include/linux/tc_act
UAPI: (Scripted) Disintegrate include/linux/netfilter_ipv6
UAPI: (Scripted) Disintegrate include/linux/netfilter_ipv4
UAPI: (Scripted) Disintegrate include/linux/netfilter_bridge
UAPI: (Scripted) Disintegrate include/linux/netfilter_arp
UAPI: (Scripted) Disintegrate include/linux/netfilter/ipset
UAPI: (Scripted) Disintegrate include/linux/isdn
UAPI: (Scripted) Disintegrate include/linux/caif
net: fix typo in freescale/ucc_geth.c
vxlan: fix more sparse warnings
Pull sparc update from David Miller:
"This is just the UAPI commits for sparc via David Howells."
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc:
UAPI: (Scripted) Disintegrate arch/sparc/include/asm
