2007-04-27Merge branch 'e1000-fixes' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6 * 'e1000-fixes' of master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6: e1000: FIX: Stop raw interrupts disabled nag from RT e1000: FIX: firmware handover bits e1000: FIX: be ready for incoming irq at pci_request_irq
2007-04-27Merge branch 'for-linus' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/roland/infiniband * 'for-linus' of master.kernel.org:/pub/scm/linux/kernel/git/roland/infiniband: (49 commits) IB: Set class_dev->dev in core for nice device symlink IB/ehca: Implement modify_port IB/umad: Clarify documentation of transaction ID IPoIB/cm: spin_lock_irqsave() -> spin_lock_irq() replacements IB/mad: Change SMI to use enums rather than magic return codes IB/umad: Implement GRH handling for sent/received MADs IB/ipoib: Use ib_init_ah_from_path to initialize ah_attr IB/sa: Set src_path_bits correctly in ib_init_ah_from_path() IB/ucm: Simplify ib_ucm_event() RDMA/ucma: Simplify ucma_get_event() IB/mthca: Simplify CQ cleaning in mthca_free_qp() IB/mthca: Fix mthca_write_mtt() on HCAs with hidden memory IB/mthca: Update HCA firmware revisions IB/ipath: Fix WC format drift between user and kernel space IB/ipath: Check that a UD work request's address handle is valid IB/ipath: Remove duplicate stuff from ipath_verbs.h IB/ipath: Check reserved memory keys IB/ipath: Fix unit selection when all CPU affinity bits set IB/ipath: Don't allow QPs 0 and 1 to be opened multiple times IB/ipath: Disable IB link earlier in shutdown sequence ...
2007-04-27Merge master.kernel.org:/pub/scm/linux/kernel/git/davem/sparc-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/davem/sparc-2.6: (67 commits) [SCSI] SUNESP: Complete driver rewrite to version 2.0 [SPARC64]: Convert PCI over to generic struct iommu/strbuf. [SPARC]: device_node name constification fallout [SPARC64]: Convert SBUS over to generic iommu/strbuf structs. [SPARC64]: Add generic iommu and strbuf structs to iommu.h [SPARC64]: Consolidate {sbus,pci}_iommu_arena. [SPARC]: Make device_node name and type const [SPARC64]: constify some paramaters of OF routines [TIGON3]: of_get_property() returns const. [SPARC64]: Fix PCI rework to adhere to of_get_property() const return. [SPARC64]: Document and fix calculation of pages_avail. [SPARC64]: Make sure pbm->prom_node is setup easly enough in psycho.c [SPARC64]: Use bootmem_bootmap_pages() in choose_bootmap_pfn(). [SPARC64]: Add proper header file extern for cmdline_memory_size. [SPARC64]: Kill sparc_ultra_dump_{i,d}tlb() [SPARC64]: Use DECLARE_BITMAP and BITS_TO_LONGS in mm/init.c [SPARC64]: Give move verbose show_mem() output just like i386. [SPARC64]: Mark show_mem() printk's with KERN_INFO. [SPARC64]: Kill kvaddr_to_phys() and friends. [SPARC64]: Privatize sun4u_get_pte() and fix name. ...
2007-04-27Merge master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6: (448 commits) [IPV4] nl_fib_lookup: Initialise res.r before fib_res_put(&res) [IPV6]: Fix thinko in ipv6_rthdr_rcv() changes. [IPV4]: Add multipath cached to feature-removal-schedule.txt [WIRELESS] cfg80211: Clarify locking comment. [WIRELESS] cfg80211: Fix locking in wiphy_new. [WEXT] net_device: Don't include wext bits if not required. [WEXT]: Misc code cleanups. [WEXT]: Reduce inline abuse. [WEXT]: Move EXPORT_SYMBOL statements where they belong. [WEXT]: Cleanup early ioctl call path. [WEXT]: Remove options. [WEXT]: Remove dead debug code. [WEXT]: Clean up how wext is called. [WEXT]: Move to net/wireless [AFS]: Eliminate cmpxchg() usage in vlocation code. [RXRPC]: Fix pointers passed to bitops. [RXRPC]: Remove bogus atomic_* overrides. [AFS]: Fix u64 printing in debug logging. [AFS]: Add "directory write" support. [AFS]: Implement the CB.InitCallBackState3 operation. ...
2007-04-27Merge branch 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linusLinus Torvalds
* 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linus: (22 commits) [MIPS] Don't force frame pointers for lockdep on MIPS [MIPS] update vr41xx Kconfig [MIPS] remove 2 select entries for VR41xx [MIPS] rename VR41XX to VR4100 series [MIPS] Use DEFINE_SPINLOCK instead of SPIN_LOCK_UNLOCKED. [MIPS] Replace old fashioned "__typeof" with "__typeof__". [MIPS] Remove unused _THREAD_SIZE_ORDER from asm-offset.c. [MIPS] Change PCI host bridge setup/resources [MIPS] Register PCI host bridge resource earlier [MIPS] Remove pnx8550-v2pci_defconfig [MIPS] Add bcm1480 ZBus trace support, fix wait related bugs [MIPS] Updated Sibyte headers [MIPS] Remove unused argument from kunmap_coherent(). [MIPS] Malta: Delete unused prototype of mips_timer_interrupt. [MIPS] Select ZONE_DMA only if GENERIC_ISA_DMA selected [MIPS] MIPS Tech: Get rid of volatile in core code. [MIPS] IP22: Get rid of volatile in IP22 core code. [MIPS] JMR3927 cleanup [MIPS] merge GT64111 PCI routines and GT64120 PCI_0 routines [MIPS] Cobalt: Split PCI codes from setup.c ...
2007-04-27Merge branch 'for-linus' of git://git390.osdl.marist.edu/pub/scm/linux-2.6Linus Torvalds
* 'for-linus' of git://git390.osdl.marist.edu/pub/scm/linux-2.6: (38 commits) [S390] SPIN_LOCK_UNLOCKED cleanup in drivers/s390 [S390] Clean up smp code in preparation for some larger changes. [S390] Remove debugging junk. [S390] Switch etr from tasklet to workqueue. [S390] split page_test_and_clear_dirty. [S390] Processor degradation notification. [S390] vtime: cleanup per_cpu usage. [S390] crypto: cleanup. [S390] sclp: fix coding style. [S390] vmlogrdr: stop IUCV connection in vmlogrdr_release. [S390] sclp: initialize early. [S390] ctc: kmalloc->kzalloc/casting cleanups. [S390] zfcpdump support. [S390] dasd: Add ipldev parameter. [S390] dasd: Add sysfs attribute status and generate uevents. [S390] Improved kernel stack overflow checking. [S390] Get rid of console setup functions. [S390] No execute support cleanup. [S390] Minor fault path optimization. [S390] Use generic bug. ...
2007-04-27Merge branch 'for-linus' of git://www.atmel.no/~hskinnemoen/linux/kernel/avr32Linus Torvalds
* 'for-linus' of git://www.atmel.no/~hskinnemoen/linux/kernel/avr32: (21 commits) [AVR32] Fix compile error with gcc 4.1 avr32: remove unneeded cast in atomic.h AVR32: Remove useless config option "GENERIC_BUST_SPINLOCK". [AVR32] Optimize the TLB miss handler [AVR32] Board code for ATNGW100 [AVR32] Use memcpy/memset in memcpy_{from,to}_io and memset_io [AVR32] Get rid of board_setup_fbmem() [AVR32] Reserve framebuffer memory in early_parse_fbmem() [AVR32] Simplify early handling of memory regions [AVR32] Move setup_bootmem() from mm/init.c to kernel/setup.c [AVR32] Make I/O access macros work with external devices [AVR32] Fix NMI handler [AVR32] Clean up exception handling code [AVR32] Clean up cpu identification and add features bitmap [AVR32] Clean up asm/sysreg.h [AVR32] Don't enable clocks with no users [AVR32] Put cpu in sleep 0 when idle. [AVR32] Change system timer from count-compare to Timer/Counter 0 [AVR32] Add mach-specific Kconfig [AVR32] Add nwait and tdf parameters to SMC configuration ...
2007-04-27Change default dirty-writeback limitsLinus Torvalds
Do this really early in the 2.6.22-rc series, so that we'll get feedback. And don't change by half measures. Just cut the default dirty limit to a quarter of what it was, and see if anybody even notices. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-27[MIPS] Don't force frame pointers for lockdep on MIPSFranck Bui-Huu
Stacktrace support on MIPS doesn't use frame pointers. Since this option considerably increases the size of the kernel code, force lockdep to not use it. Signed-off-by: Franck Bui-Huu <fbuihuu@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-04-27[MIPS] update vr41xx KconfigYoichi Yuasa
This patch has updated vr41xx/Kconfig. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-04-27[MIPS] remove 2 select entries for VR41xxYoichi Yuasa
This patch has removed 2 select entries for VR41xx. These entries are selected in arch/mips/vr41xx/Kconfig. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-04-27[MIPS] rename VR41XX to VR4100 seriesYoichi Yuasa
This patch has renamed VR41XX to VR4100 series. That's better. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-04-27[MIPS] Use DEFINE_SPINLOCK instead of SPIN_LOCK_UNLOCKED.Milind Arun Choudhary
Signed-off-by: Milind Arun Choudhary <milindchoudhary@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-04-27[MIPS] Replace old fashioned "__typeof" with "__typeof__".Robert P. J. Day
[Robert's original log message said this was a bug but it isn't, it's just very old fashioned syntax that is not (no longer?) documented in the gcc documentation. So for the sake of uniformity I'm applying his patch but with a modified log message. -- Ralf] Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-04-27[MIPS] Remove unused _THREAD_SIZE_ORDER from asm-offset.c.Ralf Baechle
2007-04-27[MIPS] Change PCI host bridge setup/resourcesThomas Bogendoerfer
PCI host bridge setup for SNI RM machines with PCI is quite broken, now that Linux does it's resource setup own its own. It will use IO addresses, which are needed by the EISA config detection and assigns PCI memory addresses, which overlap with ISA legacy addresses (video ram). Below is a patch, which changes the way how the PCI memory addresses are used and sets the minimum IO address to give enough IO space for 8 EISA slots). This patch needs the other PCI resource change, I've posted. Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-04-27[MIPS] Register PCI host bridge resource earlierThomas Bogendoerfer
PCI based SNI RM machines have their EISA bus behind an Intel PCI/EISA bridge. So the PCI IO range must start at 0x0000. Changing that will break the PCI bus, because i8259.c already has registered it's IO addresses before the PCI bus gets initialized. Below is a patch, which will register the PCI host bridge resources inside register_pci_controller(). It also changes i8259.c to use insert_region(), because request_resource() will fail, if the IO space of the PIT hanging of the PCI host bridge (maybe passing the resource parent to init_i8259_irqs() is a cleaner fix for that). Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-04-27[MIPS] Remove pnx8550-v2pci_defconfigYoichi Yuasa
2007-04-27[MIPS] Add bcm1480 ZBus trace support, fix wait related bugsMark Mason
Make ZBus tracing generic - moving it to a common direcotry under arch/mips/sibyte, add bcm1480 support and fix some wait related bugs (thanks to Ralf for assistance on that). Signed-off-by: Mark Mason <mason@broadcom.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-04-27[MIPS] Updated Sibyte headersMark Mason
This is an update to the earlier patch for the sibyte headers, and superceeds the previous patch. Changes were necessary to get the tbprof driver working on the bcm1480. Patch to update Sibyte header files to match master versions maintained at Broadcom. This patch also corrects some whitespace problems, and (hopefully) shouldn't introduce any new ones. Signed-off-by: Mark Mason <mason@broadcom.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-04-27[MIPS] Remove unused argument from kunmap_coherent().Ralf Baechle
2007-04-27[MIPS] Malta: Delete unused prototype of mips_timer_interrupt.Ralf Baechle
2007-04-27[MIPS] Select ZONE_DMA only if GENERIC_ISA_DMA selectedAtsushi Nemoto
Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-04-27[MIPS] MIPS Tech: Get rid of volatile in core code.Ralf Baechle
2007-04-27[MIPS] IP22: Get rid of volatile in IP22 core code.Ralf Baechle
2007-04-27[MIPS] JMR3927 cleanupAtsushi Nemoto
* Kill dead codes * Rearrange irq chip handlers * Minimize defconfig Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-04-27[MIPS] merge GT64111 PCI routines and GT64120 PCI_0 routinesYoichi Yuasa
This patch has merged GT64111 PCI routines and GT64120 PCI_0 routines. GT64111 PCI is almost the same as GT64120's PCI_0. This patch don't change GT64120 PCI routines. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-04-27[MIPS] Cobalt: Split PCI codes from setup.cYoichi Yuasa
It's removed #ifdef CONFIG_PCI/#endif from cobalt setup.c . Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-04-27[MIPS] Cobalt: clean up include filesYoichi Yuasa
2007-04-27[MIPS] Fix AP/SP to work in the reality of modern kernels.Ralf Baechle
2007-04-27[S390] SPIN_LOCK_UNLOCKED cleanup in drivers/s390Milind Arun Choudhary
SPIN_LOCK_UNLOCKED cleanup,use __SPIN_LOCK_UNLOCKED instead. Signed-off-by: Milind Arun Choudhary <milindchoudhary@gmail.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2007-04-27[S390] Clean up smp code in preparation for some larger changes.Heiko Carstens
Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2007-04-27[S390] Remove debugging junk.Martin Schwidefsky
arch/s390/appldata/appldata_base.c has some confusing debugging code left over to allow compiling it as a module. In practice, it cannot be configured as module and there is no need to keep that code. Signed-off-by: Gerald Schaefer <geraldsc@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2007-04-27[S390] Switch etr from tasklet to workqueue.Martin Schwidefsky
The clock synchronization of the ETR code requires an smp_call_function to synchronize all cpus. Calling smp_call_function from a tasklet is illegal. Replace the tasklet with a job on the global workqueue. ETR work is rare and can be postponed to a be done by a kernel thread. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2007-04-27[S390] split page_test_and_clear_dirty.Martin Schwidefsky
The page_test_and_clear_dirty primitive really consists of two operations, page_test_dirty and the page_clear_dirty. The combination of the two is not an atomic operation, so it makes more sense to have two separate operations instead of one. In addition to the improved readability of the s390 version of SetPageUptodate, it now avoids the page_test_dirty operation which is an insert-storage-key-extended (iske) instruction which is an expensive operation. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2007-04-27[S390] Processor degradation notification.Heiko Carstens
Generate uevents for all cpus if cpu capability changes. This can happen e.g. because the cpus are overheating. The cpu capability can be read via /sys/devices/system/cpu/cpuN/capability. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2007-04-27[S390] vtime: cleanup per_cpu usage.Jan Glauber
Replace per_cpu(... , smp_processor_id()) with __get_cpu_var() Signed-off-by: Jan Glauber <jan.glauber@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2007-04-27[S390] crypto: cleanup.Jan Glauber
Cleanup code and remove obsolete documentation. Signed-off-by: Jan Glauber <jan.glauber@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2007-04-27[S390] sclp: fix coding style.Stefan Haberland
Use only capital letters for defines. Cc: Peter Oberparleiter <peter.oberparleiter@de.ibm.com> Signed-off-by: Stefan Haberland <stefan.haberland@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2007-04-27[S390] vmlogrdr: stop IUCV connection in vmlogrdr_release.Ursula Braun
Reopen of /dev/account failed. The IUCV path has to be terminated in vmlogrdr_release. Signed-off-by: Ursula Braun <braunu@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2007-04-27[S390] sclp: initialize early.Peter Oberparleiter
Add explicit sclp initialization for those sclp users that do not register with the interface. Signed-off-by: Peter Oberparleiter <peter.oberparleiter@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2007-04-27[S390] ctc: kmalloc->kzalloc/casting cleanups.Ahmed S. Darwish
A patch for the CTC / ESCON network driver. Switch from kmalloc to kzalloc when appropriate, remove some unnecessary kmalloc casts too. Since I have no s390 machine, I didn't compile it but I examined it carefully. Signed-off-by: "Ahmed S. Darwish" <darwish.07@gmail.com> Cc: Frank Pavlic <fpavlic@de.ibm.com> Cc: Ursula Braun <braunu@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2007-04-27[S390] zfcpdump support.Michael Holzheu
s390 machines provide hardware support for creating Linux dumps on SCSI disks. For creating a dump a special purpose dump Linux is used. The first 32 MB of memory are saved by the hardware before the dump Linux is booted. Via an SCLP interface, the saved memory can be accessed from Linux. This patch exports memory and registers of the crashed Linux to userspace via a debugfs file. For more information refer to Documentation/s390/zfcpdump.txt, which is included in this patch. Signed-off-by: Michael Holzheu <holzheu@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2007-04-27[S390] dasd: Add ipldev parameter.Peter Oberparleiter
Specifying 'ipldev' in the dasd= kernel parameter will automatically activate the boot device for use by the dasd driver. Signed-off-by: Peter Oberparleiter <peter.oberparleiter@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2007-04-27[S390] dasd: Add sysfs attribute status and generate uevents.Horst Hummel
This patch adds a sysfs-attribute 'status' to make the DASD device-status accessible from user-space. In addition, the DASD driver generates an uevent(CHANGE) for the ccw-device on each device-status change. This enables user-space applications (e.g. udev) to do related processing. Signed-off-by: Horst Hummel <horst.hummel@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2007-04-27[S390] Improved kernel stack overflow checking.Martin Schwidefsky
Recent cvs versions of gcc have support for an improved stack overflow checking that calculates the size of the guard size for each function. If the compiler accepts -mstack-size without -mstack-guard then the new stack check is available. We always want to use the new stack checker. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2007-04-27[S390] Get rid of console setup functions.Heiko Carstens
We get this: Section mismatch: reference to .init.text:con3270_consetup from .data between 'con3270' (at offset 0x45c8) and 'con3270_fn' Section mismatch: reference to .init.text:con3215_consetup from .data between 'con3215' (at offset 0x4678) and 'raw3215_ccw_driver' Since there is no difference between a non present console setup function and one that returns only 0 remove them. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2007-04-27[S390] No execute support cleanup.Martin Schwidefsky
Simplify the signal_return function that checks for the two special system calls sigreturn and rt_sigreturn. No need to do a page table walk, a call to copy_from_user while disabled page faults will work as well. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2007-04-27[S390] Minor fault path optimization.Martin Schwidefsky
The minor fault path has grown a lot in terms of cycles. In particular the kprobes hook is very costly. Optimize the path to save a couple of cycles. If kprobes is enabled more than 300 cycles can be avoided if kprobes_running() is false. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2007-04-27[S390] Use generic bug.Heiko Carstens
Generic bug implementation for s390. Will increase the value of the console output on BUG() statements since registers r0-r5,r14 will not be clobbered by a printk() call that was previously done before the illegal instruction of BUG() was hit. Also implements an architecture specific WARN_ON(). Output of that could be increased but requires common code change. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
