2012-01-07Merge branch 'driver-core-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core * 'driver-core-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (73 commits) arm: fix up some samsung merge sysdev conversion problems firmware: Fix an oops on reading fw_priv->fw in sysfs loading file Drivers:hv: Fix a bug in vmbus_driver_unregister() driver core: remove __must_check from device_create_file debugfs: add missing #ifdef HAS_IOMEM arm: time.h: remove device.h #include driver-core: remove sysdev.h usage. clockevents: remove sysdev.h arm: convert sysdev_class to a regular subsystem arm: leds: convert sysdev_class to a regular subsystem kobject: remove kset_find_obj_hinted() m86k: gpio - convert sysdev_class to a regular subsystem mips: txx9_sram - convert sysdev_class to a regular subsystem mips: 7segled - convert sysdev_class to a regular subsystem sh: dma - convert sysdev_class to a regular subsystem sh: intc - convert sysdev_class to a regular subsystem power: suspend - convert sysdev_class to a regular subsystem power: qe_ic - convert sysdev_class to a regular subsystem power: cmm - convert sysdev_class to a regular subsystem s390: time - convert sysdev_class to a regular subsystem ... Fix up conflicts with 'struct sysdev' removal from various platform drivers that got changed: - arch/arm/mach-exynos/cpu.c - arch/arm/mach-exynos/irq-eint.c - arch/arm/mach-s3c64xx/common.c - arch/arm/mach-s3c64xx/cpu.c - arch/arm/mach-s5p64x0/cpu.c - arch/arm/mach-s5pv210/common.c - arch/arm/plat-samsung/include/plat/cpu.h - arch/powerpc/kernel/sysfs.c and fix up cpu_is_hotpluggable() as per Greg in include/linux/cpu.h
2012-01-06Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k: (21 commits) m68k/mac: Make CONFIG_HEARTBEAT unavailable on Mac m68k/serial: Remove references to obsolete serial config options m68k/net: Remove obsolete IRQ_FLG_* users m68k: Don't comment out syscalls used by glibc m68k/atari: Move declaration of atari_SCC_reset_done to header file m68k/serial: Remove references to obsolete CONFIG_SERIAL167 m68k/hp300: Export hp300_ledstate m68k: Initconst section fixes m68k/mac: cleanup macro case mac_scsi: fix mac_scsi on some powerbooks m68k/mac: fix powerbook 150 adb_type m68k/mac: fix baboon irq disable and shutdown m68k/mac: oss irq fixes m68k/mac: fix nubus slot irq disable and shutdown m68k/mac: enable via_alt_mapping on performa 580 m68k/mac: cleanup forward declarations m68k/mac: cleanup mac_irq_pending m68k/mac: cleanup mac_clear_irq m68k/mac: early console m68k/mvme16x: Add support for EARLY_PRINTK ... Fix up trivial conflict in arch/m68k/Kconfig.debug due to new EARLY_PRINTK config option addition clashing with movement of the BOOTPARAM options.
git://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm * 'for-linus' of git://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm: (207 commits) ARM: 7267/1: Remove BUILD_BUG_ON from asm/bug.h ARM: 7269/1: mach-sa1100: fix sched_clock breakage ARM: 7198/1: arm/imx6: add restart support for imx6q ARM: restart: remove the now empty arch_reset() ARM: restart: remove comments about adding code to arch_reset() ARM: restart: lpc32xx & u300: remove unnecessary printk ARM: restart: plat-samsung: remove plat/reset.h and s5p_reset_hook ARM: restart: w90x900: use new restart hook ARM: restart: Versatile Express: use new restart hook ARM: restart: versatile: use new restart hook ARM: restart: u300: use new restart hook ARM: restart: tegra: use new restart hook ARM: restart: spear: use new restart hook ARM: restart: shark: use new restart hook ARM: restart: sa1100: use new restart hook ARM: 7252/1: restart: S5PV210: use new restart hook ARM: 7251/1: restart: S5PC100: use new restart hook ARM: 7250/1: restart: S5P64X0: use new restart hook ARM: 7266/1: restart: S3C64XX: use new restart hook ARM: 7265/1: restart: S3C24XX: use new restart hook ... Fix up trivial conflict in arch/arm/mm/init.c due to removal of memblock_init() clashing with the movement of the sorting of the meminfo array.
2012-01-06Merge branch 'amba-modalias' of ↵Linus Torvalds
git://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm * 'amba-modalias' of git://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm: sound: aaci: Enable module alias autogeneration for AMBA drivers watchdog: sp805: Enable module alias autogeneration for AMBA drivers fbdev: amba: Enable module alias autogeneration for AMBA drivers serial: pl011: Enable module alias autogeneration for AMBA drivers serial: pl010: Enable module alias autogeneration for AMBA drivers spi: pl022: Enable module alias autogeneration for AMBA drivers rtc: pl031: Enable module alias autogeneration for AMBA drivers rtc: pl030: Enable module alias autogeneration for AMBA drivers mmc: mmci: Enable module alias autogeneration for AMBA drivers input: ambakmi: Enable module alias autogeneration for AMBA drivers gpio: pl061: Enable module alias autogeneration for AMBA drivers dmaengine: pl330: Enable module alias autogeneration for AMBA drivers dmaengine: pl08x: Enable module alias autogeneration for AMBA drivers hwrng: nomadik: Enable module alias autogeneration for AMBA drivers ARM: amba: Auto-generate AMBA driver module aliases during modpost ARM: amba: Move definition of struct amba_id to mod_devicetable.h
2012-01-06Merge branch 'pstore' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux * 'pstore' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux: pstore: gracefully handle NULL pstore_info functions pstore: pass reason to backend write callback
2012-01-06Merge branch 'misc-3.3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux * 'misc-3.3' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux: ia64: pcibr: Use kmemdup rather than duplicating its implementation ia64: sn: Use kmemdup rather than duplicating its implementation ia64: tioca: Use kmemdup rather than duplicating its implementation [IA64] Merge overlapping reserved regions at boot
2012-01-06Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gerg/m68knommu * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gerg/m68knommu: (56 commits) m68k: allow ColdFire 547x and 548x CPUs to be built with MMU enabled m68k/Kconfig: Separate classic m68k and coldfire early m68k: add ColdFire with MMU enabled support to the m68k mem init code m68k: do not use m68k startup or interrupt code for ColdFire CPUs m68k: add ColdFire FPU support for the V4e ColdFire CPUs m68k: adjustments to stack frame for ColdFire with MMU enabled m68k: use non-MMU linker script for ColdFire MMU builds m68k: ColdFire with MMU enabled uses same clocking code as non-MMU m68k: add code to setup a ColdFire 54xx platform when MMU enabled m68k: use non-MMU entry.S code when compiling for ColdFire CPU m68k: create ColdFire MMU pgalloc code m68k: compile appropriate mm arch files for ColdFire MMU support m68k: ColdFire V4e MMU paging init code and miss handler m68k: use ColdFire MMU read/write bit flags when ioremapping m68k: modify cache push and clear code for ColdFire with MMU enable m68k: use tracehook_report_syscall_entry/exit for ColdFire MMU ptrace path m68k: ColdFire V4e MMU context support code m68k: MMU enabled ColdFire needs 8k ELF alignment m68k: set ColdFire MMU page size m68k: define PAGE_OFFSET_RAW for ColdFire CPU with MMU enabled ...
2012-01-06Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (185 commits) powerpc: fix compile error with 85xx/p1010rdb.c powerpc: fix compile error with 85xx/p1023_rds.c powerpc/fsl: add MSI support for the Freescale hypervisor arch/powerpc/sysdev/fsl_rmu.c: introduce missing kfree powerpc/fsl: Add support for Integrated Flash Controller powerpc/fsl: update compatiable on fsl 16550 uart nodes powerpc/85xx: fix PCI and localbus properties in p1022ds.dts powerpc/85xx: re-enable ePAPR byte channel driver in corenet32_smp_defconfig powerpc/fsl: Update defconfigs to enable some standard FSL HW features powerpc: Add TBI PHY node to first MDIO bus sbc834x: put full compat string in board match check powerpc/fsl-pci: Allow 64-bit PCIe devices to DMA to any memory address powerpc: Fix unpaired probe_hcall_entry and probe_hcall_exit offb: Fix setting of the pseudo-palette for >8bpp offb: Add palette hack for qemu "standard vga" framebuffer offb: Fix bug in calculating requested vram size powerpc/boot: Change the WARN to INFO for boot wrapper overlap message powerpc/44x: Fix build error on currituck platform powerpc/boot: Change the load address for the wrapper to fit the kernel powerpc/44x: Enable CRASH_DUMP for 440x ... Fix up a trivial conflict in arch/powerpc/include/asm/cputime.h due to the additional sparse-checking code for cputime_t.
2012-01-06Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1958 commits) net: pack skb_shared_info more efficiently net_sched: red: split red_parms into parms and vars net_sched: sfq: extend limits cnic: Improve error recovery on bnx2x devices cnic: Re-init dev->stats_addr after chip reset net_sched: Bug in netem reordering bna: fix sparse warnings/errors bna: make ethtool_ops and strings const xgmac: cleanups net: make ethtool_ops const vmxnet3" make ethtool ops const xen-netback: make ops structs const virtio_net: Pass gfp flags when allocating rx buffers. ixgbe: FCoE: Add support for ndo_get_fcoe_hbainfo() call netdev: FCoE: Add new ndo_get_fcoe_hbainfo() call igb: reset PHY after recovering from PHY power down igb: add basic runtime PM support igb: Add support for byte queue limits. e1000: cleanup CE4100 MDIO registers access e1000: unmap ce4100_gbe_mdio_base_virt in e1000_remove ...
2012-01-06Merge branch 'x86-mce-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip * 'x86-mce-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86: add IRQ context simulation in module mce-inject x86, mce, therm_throt: Don't report power limit and package level thermal throttle events in mcelog x86, MCE: Drain mcelog buffer x86, mce: Add wrappers for registering on the decode chain
2012-01-06Merge branch 'x86-microcode-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip * 'x86-microcode-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86, microcode, AMD: Update copyrights x86, microcode, AMD: Exit early on success x86, microcode, AMD: Simplify ucode verification x86, microcode, AMD: Add a reusable buffer x86, microcode, AMD: Add a vendor-specific exit function
2012-01-06Merge branch 'x86-rdrand-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip * 'x86-rdrand-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: random: Use arch_get_random_int instead of cycle counter if avail
2012-01-06Merge branch 'x86-cpu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip * 'x86-cpu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86, centaur: Enable cx8 for VIA Eden too
2012-01-06Merge branch 'x86-cleanups-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip * 'x86-cleanups-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86: Use "do { } while(0)" for empty lock_cmos()/unlock_cmos() macros x86: Use "do { } while(0)" for empty flush_tlb_fix_spurious_fault() macro x86, CPU: Drop superfluous get_cpu_cap() prototype arch/x86/mm/pageattr.c: Quiet sparse noise; local functions should be static arch/x86/kernel/ptrace.c: Quiet sparse noise x86: Use kmemdup() in copy_thread(), rather than duplicating its implementation x86: Replace the EVT_TO_HPET_DEV() macro with an inline function
2012-01-06Merge branch 'x86-asm-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip * 'x86-asm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (21 commits) x86: Fix atomic64_xxx_cx8() functions x86: Fix and improve cmpxchg_double{,_local}() x86_64, asm: Optimise fls(), ffs() and fls64() x86, bitops: Move fls64.h inside __KERNEL__ x86: Fix and improve percpu_cmpxchg{8,16}b_double() x86: Report cpb and eff_freq_ro flags correctly x86/i386: Use less assembly in strlen(), speed things up a bit x86: Use the same node_distance for 32 and 64-bit x86: Fix rflags in FAKE_STACK_FRAME x86: Clean up and extend do_int3() x86: Call do_notify_resume() with interrupts enabled x86/div64: Add a micro-optimization shortcut if base is power of two x86-64: Cleanup some assembly entry points x86-64: Slightly shorten line system call entry and exit paths x86-64: Reduce amount of redundant code generated for invalidate_interruptNN x86-64: Slightly shorten int_ret_from_sys_call x86, efi: Convert efi_phys_get_time() args to physical addresses x86: Default to vsyscall=emulate x86-64: Set siginfo and context on vsyscall emulation faults x86: consolidate xchg and xadd macros ...
2012-01-06Merge branch 'x86-apic-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip * 'x86-apic-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86: Skip cpus with apic-ids >= 255 in !x2apic_mode x86, x2apic: Allow "nox2apic" to disable x2apic mode setup by BIOS x86, x2apic: Fallback to xapic when BIOS doesn't setup interrupt-remapping x86, acpi: Skip acpi x2apic entries if the x2apic feature is not present x86, apic: Add probe() for apic_flat x86: Simplify code by removing a !SMP #ifdefs from 'struct cpuinfo_x86' x86: Convert per-cpu counter icr_read_retry_count into a member of irq_stat x86: Add per-cpu stat counter for APIC ICR read tries pci, x86/io-apic: Allow PCI_IOAPIC to be user configurable on x86 x86: Fix the !CONFIG_NUMA build of the new CPU ID fixup code support x86: Add NumaChip support x86: Add x86_init platform override to fix up NUMA core numbering x86: Make flat_init_apic_ldr() available
2012-01-06Merge branch 'timers-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip * 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86, tsc: Skip TSC synchronization checks for tsc=reliable clocksource: Convert tcb_clksrc to use clocksource_register_hz/khz clocksource: cris: Convert to clocksource_register_khz clocksource: xtensa: Convert to clocksource_register_hz/khz clocksource: um: Convert to clocksource_register_hz/khz clocksource: parisc: Convert to clocksource_register_hz/khz clocksource: m86k: Convert to clocksource_register_hz/khz time: x86: Replace LATCH with PIT_LATCH in i8253 clocksource driver time: x86: Remove CLOCK_TICK_RATE from acpi_pm clocksource driver time: x86: Remove CLOCK_TICK_RATE from mach_timer.h time: x86: Remove CLOCK_TICK_RATE from tsc code time: Fix spelling mistakes in new comments time: fix bogus comment in timekeeping_get_ns_raw
2012-01-06Merge branch 'driver-core-next' into Linux 3.2Greg Kroah-Hartman
This resolves the conflict in the arch/arm/mach-s3c64xx/s3c6400.c file, and it fixes the build error in the arch/x86/kernel/microcode_core.c file, that the merge did not catch. The microcode_core.c patch was provided by Stephen Rothwell <sfr@canb.auug.org.au> who was invaluable in the merge issues involved with the large sysdev removal process in the driver-core tree. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-06arm: fix up some samsung merge sysdev conversion problemsKukjin Kim
Following should be fixed in your driver-core/driver-core-next. From: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-06Merge branch 'sched-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip * 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (40 commits) sched/tracing: Add a new tracepoint for sleeptime sched: Disable scheduler warnings during oopses sched: Fix cgroup movement of waking process sched: Fix cgroup movement of newly created process sched: Fix cgroup movement of forking process sched: Remove cfs bandwidth period check in tg_set_cfs_period() sched: Fix load-balance lock-breaking sched: Replace all_pinned with a generic flags field sched: Only queue remote wakeups when crossing cache boundaries sched: Add missing rcu_dereference() around ->real_parent usage [S390] fix cputime overflow in uptime_proc_show [S390] cputime: add sparse checking and cleanup sched: Mark parent and real_parent as __rcu sched, nohz: Fix missing RCU read lock sched, nohz: Set the NOHZ_BALANCE_KICK flag for idle load balancer sched, nohz: Fix the idle cpu check in nohz_idle_balance sched: Use jump_labels for sched_feat sched/accounting: Fix parameter passing in task_group_account_field sched/accounting: Fix user/system tick double accounting sched/accounting: Re-use scheduler statistics for the root cgroup ... Fix up conflicts in - arch/ia64/include/asm/cputime.h, include/asm-generic/cputime.h usecs_to_cputime64() vs the sparse cleanups - kernel/sched/fair.c, kernel/time/tick-sched.c scheduler changes in multiple branches
2012-01-06Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (106 commits) perf kvm: Fix copy & paste error in description perf script: Kill script_spec__delete perf top: Fix a memory leak perf stat: Introduce get_ratio_color() helper perf session: Remove impossible condition check perf tools: Fix feature-bits rework fallout, remove unused variable perf script: Add generic perl handler to process events perf tools: Use for_each_set_bit() to iterate over feature flags perf tools: Unify handling of features when writing feature section perf report: Accept fifos as input file perf tools: Moving code in some files perf tools: Fix out-of-bound access to struct perf_session perf tools: Continue processing header on unknown features perf tools: Improve macros for struct feature_ops perf: builtin-record: Document and check that mmap_pages must be a power of two. perf: builtin-record: Provide advice if mmap'ing fails with EPERM. perf tools: Fix truncated annotation perf script: look up thread using tid instead of pid perf tools: Look up thread names for system wide profiling perf tools: Fix comm for processes with named threads ...
2012-01-06Merge branch 'core-rcu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip * 'core-rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (64 commits) cpu: Export cpu_up() rcu: Apply ACCESS_ONCE() to rcu_boost() return value Revert "rcu: Permit rt_mutex_unlock() with irqs disabled" docs: Additional LWN links to RCU API rcu: Augment rcu_batch_end tracing for idle and callback state rcu: Add rcutorture tests for srcu_read_lock_raw() rcu: Make rcutorture test for hotpluggability before offlining CPUs driver-core/cpu: Expose hotpluggability to the rest of the kernel rcu: Remove redundant rcu_cpu_stall_suppress declaration rcu: Adaptive dyntick-idle preparation rcu: Keep invoking callbacks if CPU otherwise idle rcu: Irq nesting is always 0 on rcu_enter_idle_common rcu: Don't check irq nesting from rcu idle entry/exit rcu: Permit dyntick-idle with callbacks pending rcu: Document same-context read-side constraints rcu: Identify dyntick-idle CPUs on first force_quiescent_state() pass rcu: Remove dynticks false positives and RCU failures rcu: Reduce latency of rcu_prepare_for_idle() rcu: Eliminate RCU_FAST_NO_HZ grace-period hang rcu: Avoid needlessly IPIing CPUs at GP end ...
2012-01-06Merge branch 'core-printk-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip * 'core-printk-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: printk, lockdep: Switch to tracked irq ops printk, lockdep: Remove superfluous preempt_disable() printk, lockdep: Disable lock debugging on zap_locks()
2012-01-06Merge branch 'core-memblock-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip * 'core-memblock-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (52 commits) memblock: Reimplement memblock allocation using reverse free area iterator memblock: Kill early_node_map[] score: Use HAVE_MEMBLOCK_NODE_MAP s390: Use HAVE_MEMBLOCK_NODE_MAP mips: Use HAVE_MEMBLOCK_NODE_MAP ia64: Use HAVE_MEMBLOCK_NODE_MAP SuperH: Use HAVE_MEMBLOCK_NODE_MAP sparc: Use HAVE_MEMBLOCK_NODE_MAP powerpc: Use HAVE_MEMBLOCK_NODE_MAP memblock: Implement memblock_add_node() memblock: s/memblock_analyze()/memblock_allow_resize()/ and update users memblock: Track total size of regions automatically powerpc: Cleanup memblock usage memblock: Reimplement memblock_enforce_memory_limit() using __memblock_remove() memblock: Make memblock functions handle overflowing range @size memblock: Reimplement __memblock_remove() using memblock_isolate_range() memblock: Separate out memblock_isolate_range() from memblock_set_node() memblock: Kill memblock_init() memblock: Kill sentinel entries at the end of static region arrays memblock: Add __memblock_dump_all() ...
2012-01-06Merge branch 'core-locking-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip * 'core-locking-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: lockdep/waitqueues: Add better annotation lockdep, bug: Exclude TAINT_OOT_MODULE from disabling lock debugging lockdep: Print lock name in lockdep_init_error() init/main.c: Execute lockdep_init() as early as possible lockdep, kmemcheck: Annotate ->lock in lockdep_init_map() lockdep, rtmutex, bug: Show taint flags on error lockdep, bug: Exclude TAINT_FIRMWARE_WORKAROUND from disabling lockdep lockdep: Always try to set ->class_cache in register_lock_class() lockdep_init_map()
2012-01-06Merge branch 'core-debugobjects-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip * 'core-debugobjects-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: timer: Use debugobjects to catch deletion of uninitialized timers timer: Setup uninitialized timer with a stub callback debugobjects: Extend to assert that an object is initialized debugobjects: Be smarter about static objects
2012-01-05vfs: fix up ENOIOCTLCMD error handlingLinus Torvalds
We're doing some odd things there, which already messes up various users (see the net/socket.c code that this removes), and it was going to add yet more crud to the block layer because of the incorrect error code translation. ENOIOCTLCMD is not an error return that should be returned to user mode from the "ioctl()" system call, but it should *not* be translated as EINVAL ("Invalid argument"). It should be translated as ENOTTY ("Inappropriate ioctl for device"). That EINVAL confusion has apparently so permeated some code that the block layer actually checks for it, which is sad. We continue to do so for now, but add a big comment about how wrong that is, and we should remove it entirely eventually. In the meantime, this tries to keep the changes localized to just the EINVAL -> ENOTTY fix, and removing code that makes it harder to do the right thing. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-05net: pack skb_shared_info more efficientlyIan Campbell
nr_frags can be 8 bits since 256 is plenty of fragments. This allows it to be packed with tx_flags. Also by moving ip6_frag_id and dataref (both 4 bytes) next to each other we can avoid a hole between ip6_frag_id and frag_list on 64 bit systems. Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-01-05net_sched: red: split red_parms into parms and varsEric Dumazet
This patch splits the red_parms structure into two components. One holding the RED 'constant' parameters, and one containing the variables. This permits a size reduction of GRED qdisc, and is a preliminary step to add an optional RED unit to SFQ. SFQRED will have a single red_parms structure shared by all flows, and a private red_vars per flow. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> CC: Dave Taht <dave.taht@gmail.com> CC: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-01-05net_sched: sfq: extend limitsEric Dumazet
SFQ as implemented in Linux is very limited, with at most 127 flows and limit of 127 packets. [ So if 127 flows are active, we have one packet per flow ] This patch brings to SFQ following features to cope with modern needs. - Ability to specify a smaller per flow limit of inflight packets. (default value being at 127 packets) - Ability to have up to 65408 active flows (instead of 127) - Ability to have head drops instead of tail drops (to drop old packets from a flow) Example of use : No more than 20 packets per flow, max 8000 flows, max 20000 packets in SFQ qdisc, hash table of 65536 slots. tc qdisc add ... sfq \ flows 8000 \ depth 20 \ headdrop \ limit 20000 \ divisor 65536 Ram usage : 2 bytes per hash table entry (instead of previous 1 byte/entry) 32 bytes per flow on 64bit arches, instead of 384 for QFQ, so much better cache hit ratio. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> CC: Dave Taht <dave.taht@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-01-05cnic: Improve error recovery on bnx2x devicesMichael Chan
When a bnx2x device encounters parity errors, it will not respond to all SPQ messages. As a result, the shutdown sequence before reset can take a long time as the ulp drivers (bnx2i/bnx2fc) have to wait for timeout of all such messages. To improve this scenario, when bnx2x returns error on the SPQ, we'll send an immediate response to the ulp drivers to avoid such lengthy timeouts. Adjust the return code of relevant functions to return error only if the message cannot be sent on the SPQ so that we'll generate an error completion to the ulp drivers. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-01-05cnic: Re-init dev->stats_addr after chip resetMichael Chan
because bnx2x frees the old and allocates new memory during chip reset. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-01-05net_sched: Bug in netem reorderingHagen Paul Pfeifer
Not now, but it looks you are correct. q->qdisc is NULL until another additional qdisc is attached (beside tfifo). See 50612537e9ab2969312. The following patch should work. From: Hagen Paul Pfeifer <hagen@jauu.net> netem: catch NULL pointer by updating the real qdisc statistic Reported-by: Vijay Subramanian <subramanian.vijay@gmail.com> Signed-off-by: Hagen Paul Pfeifer <hagen@jauu.net> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-01-05bna: fix sparse warnings/errorsstephen hemminger
This fixes a several sparse warnings. * the __iomem tag was being used incorrectly (needs to be a prefix) * several variables should have been static since local to one file * the firmware was not being forwared declared and was const one place and not the other Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-01-05bna: make ethtool_ops and strings conststephen hemminger
2012-01-05xgmac: cleanupsstephen hemminger
Make local function static, make ethtool_ops const. Compile tested only. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-01-05net: make ethtool_ops conststephen hemminger
Auditing all usage of ethtool_ops found several drivers that are not declaring the struct const when it should be. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-01-05vmxnet3" make ethtool ops conststephen hemminger
All tables of function pointers should be const to make hacks more difficult. Compile tested only. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Acked-by: Shreyas N Bhatewara <sbhatewara@vmware.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-01-05xen-netback: make ops structs conststephen hemminger
All tables of function pointers should be const to make hacks more difficult. Compile tested only. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Acked-by: Ian Campbell <ian.campbell@citrix.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-01-05virtio_net: Pass gfp flags when allocating rx buffers.Mike Waychison
Currently, the refill path for RX buffers will always allocate the buffers as GFP_ATOMIC, even if we are in process context. This will fail to apply memory pressure as the worker thread will not contribute to the freeing of memory. Fix this by changing add_recvbuf_small to use the gfp variant allocator, __netdev_alloc_skb_ip_align(). Signed-off-by: Mike Waychison <mikew@google.com> Acked-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-01-05ixgbe: FCoE: Add support for ndo_get_fcoe_hbainfo() callNeerav Parikh
This patch implements support for ndo_get_fcoe_hbainfo() call in the ixgbe driver. This function will be called by the FCoE protocol stack to obtain device specific information from the underlying device configured to do FCoE. Signed-off-by: Neerav Parikh <Neerav.Parikh@intel.com> Tested-by: Ross Brattain <ross.b.brattain@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-01-05netdev: FCoE: Add new ndo_get_fcoe_hbainfo() callNeerav Parikh
This adds a new ndo_get_fcoe_hbainfo() call in net_device_ops for FCoE protocol stack. If supported by the underlying device, the FCoE protocol stack will call this to get device specific information from the underlying device. This information will then be utilized by the FCoE protocol stack to register Fiber Channel HBA attributes with the Fiber Channel Management Service via Fabric Device Management Interface (FDMI) as per the T11 FC-GS specification. Changes in v2: - As per comments from David Miller aligning the parameters of the ndo_get_fcoe_hbainfo() Signed-off-by: Neerav Parikh <Neerav.Parikh@intel.com> Tested-by: Ross Brattain <ross.b.brattain@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-01-05igb: reset PHY after recovering from PHY power downKoki Sanagi
According to 82576_Datasheet.pdf, PHY setting is lost after PHY power down. So resetting PHY is needed when recovering from PHY power down to set a default setting to PHY register. Owing to this lack, NIC doesn't link up in some rare situation. Signed-off-by: Koki Sanagi <sanagi.koki@jp.fujitsu.com> Tested-by: Aaron Brown <aaron.f.brown@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-01-05igb: add basic runtime PM supportYan, Zheng
Use the runtime power management framework to add basic runtime PM support to the igb driver. Namely, make the driver suspend the device when the link is off and set it up for generating a wakeup event after the link has been detected again. This feature is disabled by default. Based on e1000e's runtime PM code. Changes since v1: Don't suspend the device when shutting down the interface. Avoid race between runtime suspending and ethtool operations. Signed-off-by: Zheng Yan <zheng.z.yan@intel.com> Tested-by: Aaron Brown <aaron.f.brown@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-01-05igb: Add support for byte queue limits.Eric Dumazet
This adds support for byte queue limits (BQL) Since this driver collects bytes count in 'bytecount' field, use it also in igb_tx_map() Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> CC: Alexander Duyck <alexander.h.duyck@intel.com> Tested-by: Aaron Brown <aaron.f.brown@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-01-05e1000: cleanup CE4100 MDIO registers accessFlorian Fainelli
A global variable is currently used to hold the virtual address of the CE4100 MDIO base register address. Store the address in the e1000_hw structure and update macros accordingly. Signed-off-by: Florian Fainelli <ffainelli@freebox.fr> Tested-by: Aaron Brown <aaron.f.brown@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-01-05e1000: unmap ce4100_gbe_mdio_base_virt in e1000_removeFlorian Fainelli
We are not unmapping ce4100_gbe_mdio_base_virt in exit path in case we are running on a CE4100 adapter, fix that. Signed-off-by: Florian Fainelli <ffainelli@freebox.fr> Tested-by: Aaron Brown <aaron.f.brown@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-01-05e1000: fix lockdep splat in shutdown handlerJesse Brandeburg
As reported by Steven Rostedt, e1000 has a lockdep splat added during the recent merge window. The issue is that cancel_delayed_work is called while holding our private mutex. There is no reason that I can see to hold the mutex during pci shutdown, it was more just paranoia that I put the mutex_lock around the call to e1000_down. In a quick survey lots of drivers handle locking differently when being called by the pci layer. The assumption here is that we don't need the mutexes' protection in this function because the driver could not be unloaded while in the shutdown handler which is only called at reboot or poweroff. Reported-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com> Tested-by: Steven Rostedt <rostedt@goodmis.org> Tested-by: Aaron Brown <aaron.f.brown@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-01-05Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next into for-davem Conflicts: drivers/net/wireless/b43legacy/dma.c
2012-01-05ath6kl: revert USB supportJohn W. Linville
The ath6kl driver is causing build failures when the ath6kl bits are not built as modules. A better fix is forthcoming in a future release, but for now lets revert the problematic code. This reverts the following commits: fde57764ef8751b9aca11b6f6221ac5555bda699 d70385a26ad9a122a5450d066550470107b6bc38 59d954dda4b9b3f3e61d4b87a2b26952b8c4c09d Signed-off-by: John W. Linville <linville@tuxdriver.com>
