Rework the "performance" MPS option to configure the device MPS with the
smaller of the device MPSS or the bridge MPS (which is assumed to be
properly configured at this point to the largest allowable MPS based on
its parent bus).
Also, rework the MRRS setting to report an inability to set the MRRS to
a valid setting.
Signed-off-by: Jon Mason <mason@myri.com>
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Intel 5000 and 5100 series memory controllers have a known issue if read
completion coalescing is enabled and the PCI-E Maximum Payload Size is
set to 256B. To work around this issue, disable read completion
coalescing in the memory controller and root complexes. Unfortunately,
it must always be disabled, even if no 256B MPS devices are present, due
to the possibility of one being hotplugged.
Links to erratas:
http://www.intel.com/content/dam/doc/specification-update/5000-chipset-memory-controller-hub-specification-update.pdf
http://www.intel.com/content/dam/doc/specification-update/5100-memory-controller-hub-chipset-specification-update.pdf
Thanks to Jesse Brandeburg and Ben Hutchings for providing insight into
the problem.
Tested-and-Reported-by: Avi Kivity <avi@redhat.com>
Devices supporting Process Address Space Identifiers
(PASIDs) can use an IOMMU to access multiple IO address
spaces at the same time. A PCIe device indicates support for
this feature by implementing the PASID capability. This
patch adds support for the capability to the Linux kernel.
Reviewed-by: Bjorn Helgaas <bhelgaas@google.com>
Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
Implement the necessary functions to handle PRI capabilities
on PCIe devices. With PRI devices behind an IOMMU can signal
page fault conditions to software and recover from such
faults.
This patch makes the ATS functions usable for modules.
They will be used by a module implementing some advanced
AMD IOMMU features.
ATS does not depend on IOV support, so move the code into
its own file. This file will also include support for the
PRI and PASID capabilities later.
Also give ATS its own Kconfig variable to allow selecting it
without IOV support.
The result returned by acpi_dev_run_wake() is always either -EINVAL
or -ENODEV, while obviously it should return 0 on success. The
problem is that the leftover error variable, that's not really used
in the function, is initialized with -ENODEV and then returned
without modification.
To fix this issue remove the error variable from acpi_dev_run_wake()
and make the function return 0 on success as appropriate.
I originally submitted a patch to workaround this by pushing all Ejection
Requests and Device Checks onto the kacpi_hotplug queue.
http://marc.info/?l=linux-acpi&m=131678270930105&w=2
The patch is still insufficient in that Bus Checks also need to be added.
Rather than add all events, including non-PCI-hotplug events, to the
hotplug queue, mjg suggested that a better approach would be to modify
the acpiphp driver so only acpiphp events would be added to the
It's a longer patch, but at least we maintain the benefit of having separate
queues in ACPI. This, of course, is still only a workaround the problem.
As Bjorn and mjg pointed out, we have to refactor a lot of this code to do
the right thing but at this point it is a better to have this code working.
The acpi core places all events on the kacpi_notify queue. When the acpiphp
driver is loaded and a PCI card with a PCI-to-PCI bridge is removed the
following call sequence occurs:
cleanup_p2p_bridge()
-> cleanup_bridge()
-> acpi_remove_notify_handler()
-> acpi_os_wait_events_complete()
-> flush_workqueue(kacpi_notify_wq)
which is the queue we are currently executing on and the process will hang.
Move all hotplug acpiphp events onto the kacpi_hotplug workqueue. In
handle_hotplug_event_bridge() and handle_hotplug_event_func() we can simply
push the rest of the work onto the kacpi_hotplug queue and then avoid the
deadlock.
Signed-off-by: Prarit Bhargava <prarit@redhat.com>
Cc: mjg@redhat.com
Cc: bhelgaas@google.com
Cc: linux-acpi@vger.kernel.org
The land of PCI power management is a land of sorrow and ugliness,
especially in the area of signaling events by devices. There are
devices that set their PME Status bits, but don't really bother
to send a PME message or assert PME#. There are hardware vendors
who don't connect PME# lines to the system core logic (they know
who they are). There are PCI Express Root Ports that don't bother
to trigger interrupts when they receive PME messages from the devices
below. There are ACPI BIOSes that forget to provide _PRW methods for
devices capable of signaling wakeup. Finally, there are BIOSes that
do provide _PRW methods for such devices, but then don't bother to
call Notify() for those devices from the corresponding _Lxx/_Exx
GPE-handling methods. In all of these cases the kernel doesn't have
a chance to receive a proper notification that it should wake up a
device, so devices stay in low-power states forever. Worse yet, in
some cases they continuously send PME Messages that are silently
ignored, because the kernel simply doesn't know that it should clear
the device's PME Status bit.
This problem was first observed for "parallel" (non-Express) PCI
devices on add-on cards and Matthew Garrett addressed it by adding
code that polls PME Status bits of such devices, if they are enabled
to signal PME, to the kernel. Recently, however, it has turned out
that PCI Express devices are also affected by this issue and that it
is not limited to add-on devices, so it seems necessary to extend
the PME polling to all PCI devices, including PCI Express and planar
ones. Still, it would be wasteful to poll the PME Status bits of
devices that are known to receive proper PME notifications, so make
the kernel (1) poll the PME Status bits of all PCI and PCIe devices
enabled to signal PME and (2) disable the PME Status polling for
devices for which correct PME notifications are received.
Tested-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
Commit 15bed0f2f added a quirk for the e823 Ricoh card reader to lower the
base frequency. However, the quirk first checks to see if the proprietary
MMC controller is disabled, and returns if so. On some devices, such as the
Lenovo X220, the MMC controller is already disabled by firmware it seems,
but the frequency change is still needed so sdhci-pci can talk to the cards.
Since the MMC controller is disabled, the frequency fixup was never being run
on these machines.
This moves the e823 check above the MMC controller check so that it always
gets run.
This fixes https://bugzilla.redhat.com/show_bug.cgi?id=722509
Signed-off-by: Josh Boyer <jwboyer@redhat.com>
The "powernv" platform of the powerpc architecture needs to assign PCI
resources using a specific algorithm to fit some HW constraints of
the IBM "IODA" architecture (related to the ability to create error
handling domains that encompass specific segments of MMIO space).
For doing so, it wants to call pci_setup_bridge() from architecture
specific resource management in order to configure bridges after all
resources have been assigned. So make it non-static.
As with any other such change, the goal is to prevent inadvertent
writes to these structures (assuming DEBUG_RODATA is enabled), and to
separate data (possibly frequently) written to from such never getting
modified.
Reviewed-by: Ingo Molnar <mingo@elte.hu>
Signed-off-by: Jan Beulich <jbeulich@novell.com>
Using legacy interrupts and TLPs > 256 bytes on the SFC4000 (all
revisions) may cause interrupt messages to be replayed. In some
systems this results in a non-recoverable MCE. Early boards using the
SFC4000 set the maximum payload size supported (MPSS) to 1024 bytes
and we should override that.
There are probably other devices with similar issues, so give this
quirk a generic name.
Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
These will be shared between the sfc driver and a PCI quirk.
* 'gpio/merge' of git://git.secretlab.ca/git/linux-2.6:
gpio-pca953x: fix gpio_base
gpio/omap: fix build error with certain OMAP1 configs
* 'for-linus' of git://oss.sgi.com/xfs/xfs:
xfs: revert to using a kthread for AIL pushing
xfs: force the log if we encounter pinned buffers in .iop_pushbuf
xfs: do not update xa_last_pushed_lsn for locked items
* 'stable' of git://github.com/cmetcalf-tilera/linux-tile:
tile: revert change from <asm/atomic.h> to <linux/atomic.h> in asm files
* 'x86-urgent-for-linus' of git://tesla.tglx.de/git/linux-2.6-tip:
x86: Default to vsyscall=native for now
SFI tables reside in RAM and should not be modified once they are
written. Current code went to set pentry->irq to zero which causes
subsequent reads to fail with invalid SFI table checksum. This will
break kexec as the second kernel fails to validate SFI tables.
To fix this we use temporary variable for irq number.
Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Reviewed-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
Cc: stable@kernel.org
gpio_base was set to 0 if no system platform data or open firmware
platform data was provided. This led to conflicts, if any other gpiochip
with a gpiobase of 0 was instantiated already. Setting it to -1 will
automatically use the first one available.
Signed-off-by: Hartmut Knaack <knaack.h@gmx.de>
With commit f64ad1a0e21a, "gpio/omap: cleanup _set_gpio_wakeup(), remove
ifdefs", access to build time conditionally omitted 'suspend_wakeup'
member of the 'gpio_bank' structure has been placed unconditionally in
function _set_gpio_wakeup(), which is always built. This resulted in the
driver compilation broken for certain OMAP1, i.e., non-OMAP16xx,
configurations.
Really required or not in previously excluded cases, define this
structure member unconditionally as a fix.
Tested with a custom OMAP1510 only configuration.
Signed-off-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl>
Acked-by: Kevin Hilman <khilman@ti.com>
Tested-by: Aaro Koskinen <aaro.koskinen@iki.fi>
The 32-bit TILEPro support uses some #defines in <asm/atomic_32.h>
for atomic support routines in assembly. To make this more explicit,
I've turned those includes into includes of <asm/atomic_32.h>, which
should hopefully make it clear that they shouldn't be bombed into
<linux/atomic.h> in any cleanups.
Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net:
mscan: too much data copied to CAN frame due to 16 bit accesses
gro: refetch inet6_protos[] after pulling ext headers
bnx2x: fix cl_id allocation for non-eth clients for NPAR mode
mlx4_en: fix endianness with blue frame support
Fix file references in drivers/ide/
There are a lot of file references to now moved or deleted files in the
whole tree, especially in documentation and Kconfig files. This patch
fixes the references in drivers/ide/.
Signed-off-by: Johann Felix Soden <johfel@users.sourceforge.net>
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net>
* 'btrfs-3.0' of git://github.com/chrismason/linux:
Btrfs: make sure not to defrag extents past i_size
Btrfs: fix recursive auto-defrag
Currently we have a few issues with the way the workqueue code is used to
implement AIL pushing:
- it accidentally uses the same workqueue as the syncer action, and thus
can be prevented from running if there are enough sync actions active
in the system.
- it doesn't use the HIGHPRI flag to queue at the head of the queue of
work items
At this point I'm not confident enough in getting all the workqueue flags and
tweaks right to provide a perfectly reliable execution context for AIL
pushing, which is the most important piece in XFS to make forward progress
when the log fills.
Revert back to use a kthread per filesystem which fixes all the above issues
at the cost of having a task struct and stack around for each mounted
filesystem. In addition this also gives us much better ways to diagnose
any issues involving hung AIL pushing and removes a small amount of code.
Reported-by: Stefan Priebe <s.priebe@profihost.ag>
Tested-by: Stefan Priebe <s.priebe@profihost.ag>
Reviewed-by: Dave Chinner <dchinner@redhat.com>
Signed-off-by: Alex Elder <aelder@sgi.com>
We need to check for pinned buffers even in .iop_pushbuf given that inode
items flush into the same buffers that may be pinned directly due operations
on the unlinked inode list operating directly on buffers. To do this add a
return value to .iop_pushbuf that tells the AIL push about this and use
the existing log force mechanisms to unpin it.
If an item was locked we should not update xa_last_pushed_lsn and thus skip
it when restarting the AIL scan as we need to be able to lock and write it
out as soon as possible. Otherwise heavy lock contention might starve AIL
pushing too easily, especially given the larger backoff once we moved
xa_last_pushed_lsn all the way to the target lsn.
The btrfs file defrag code will loop through the extents and
force COW on them. But there is a concurrent truncate in the middle of
the defrag, it might end up defragging the same range over and over
again.
The problem is that writepage won't go through and do anything on pages
past i_size, so the cow won't happen, so the file will appear to still
be fragmented. defrag will end up hitting the same extents again and
again.
In the worst case, the truncate can actually live lock with the defrag
because the defrag keeps creating new ordered extents which the truncate
code keeps waiting on.
The fix here is to make defrag check for i_size inside the main loop,
instead of just once before the looping starts.
Signed-off-by: Chris Mason <chris.mason@oracle.com>
This UML breakage:
linux-2.6.30.1[3800] vsyscall fault (exploit attempt?) ip:ffffffffff600000 cs:33 sp:7fbfb9c498 ax:ffffffffff600000 si:0 di:606790
linux-2.6.30.1[3856] vsyscall fault (exploit attempt?) ip:ffffffffff600000 cs:33 sp:7fbfb13168 ax:ffffffffff600000 si:0 di:606790
Is caused by commit 3ae36655 ("x86-64: Rework vsyscall emulation and add
vsyscall= parameter") - the vsyscall emulation code is not fully cooked
yet as UML relies on some rather fragile SIGSEGV semantics.
Linus suggested in https://lkml.org/lkml/2011/8/9/376 to default
to vsyscall=native for now, this patch implements that.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Acked-by: Andrew Lutomirski <luto@mit.edu>
Cc: H. Peter Anvin <hpa@linux.intel.com>
Link: http://lkml.kernel.org/r/20111005214047.GE14406@localhost.pp.htv.fi
Follow those steps:
# mount -o autodefrag /dev/sda7 /mnt
# dd if=/dev/urandom of=/mnt/tmp bs=200K count=1
# sync
# dd if=/dev/urandom of=/mnt/tmp bs=8K count=1 conv=notrunc
and then it'll go into a loop: writeback -> defrag -> writeback ...
It's because writeback writes [8K, 200K] and then writes [0, 8K].
I tried to make writeback know if the pages are dirtied by defrag,
but the patch was a bit intrusive. Here I simply set writeback_index
when we defrag a file.
Signed-off-by: Li Zefan <lizf@cn.fujitsu.com>
Due to the 16 bit access to mscan registers there's too much data copied to
the zero initialized CAN frame when having an odd number of bytes to copy.
This patch ensures that only the requested bytes are copied by using an
8 bit access for the remaining byte.
Reported-by: Andre Naujoks <nautsch@gmail.com>
Signed-off-by: Oliver Hartkopp <socketcan@hartkopp.net>
Signed-off-by: Wolfgang Grandegger <wg@grandegger.com>
ipv6_gro_receive() doesn't update the protocol ops after pulling
the ext headers. It looks like a typo.
Signed-off-by: Zheng Yan <zheng.z.yan@intel.com>
There are some consolidations of NPAR configuration
when FCoE and iSCSI L2 clients will get the same id,
in this case FCoE ring will be non-functional.
Signed-off-by: Dmitry Kravkov <dmitry@broadcom.com>
Signed-off-by: Eilon Greenstein <eilong@broadcom.com>
The doorbell register was being unconditionally swapped. In x86, that
meant it was being swapped to BE and written to the descriptor and to
memory, depending on the case of blue frame support or writing to
doorbell register. On PPC, this meant it was being swapped to LE and
then swapped back to BE while writing to the register. But in the blue
frame case, it was being written as LE to the descriptor.
The fix is not to swap doorbell unconditionally, write it to the
register as BE and convert it to BE when writing it to the descriptor.
Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@linux.vnet.ibm.com>
Reported-by: Richard Hendrickson <richhend@us.ibm.com>
Cc: Eli Cohen <eli@dev.mellanox.co.il>
Cc: Yevgeny Petrilin <yevgenyp@mellanox.co.il>
* git://git.samba.org/sfrench/cifs-2.6:
[CIFS] Fix first time message on mount, ntlmv2 upgrade delayed to 3.2
* 'fixes' of git://git.linaro.org/people/arnd/arm-soc:
ARM: mach-ux500: enable fix for ARM errata 754322
ARM: OMAP: musb: Remove a redundant omap4430_phy_init call in usb_musb_init
ARM: OMAP: Fix i2c init for twl4030
ARM: OMAP4: MMC: fix power and audio issue, decouple USBC1 from MMC1
This fixes a compilation error in cpu-tegra.c which was introduced in
dc8d966bccde ("ARM: convert PCI defines to variables") which removed the
now obsolete mach/hardware.h from the mach-tegra subtree.
Signed-off-by: Marc Dietrich <marvin24@gmx.de>
Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com>
* 'drm-fixes' of git://people.freedesktop.org/~airlied/linux:
drm/radeon/kms: use hardcoded dig encoder to transmitter mapping for DCE4.1
drm/radeon/kms: fix dp_detect handling for DP bridge chips
drm/radeon/kms: retry aux transactions if there are status flags
A couple of changes to the Tegra maintainership setup:
I'm very glad to bring on Stephen Warren on board as a maintainer. The
work he has done so far is excellent, and the fact that he works for
Nvidia means he has long-term interest in the platform.
Erik Gilling did an astounding amount of work on getting things up and
running but has been a silent partner on the maintainership side for a
while, and is stepping down. Thanks for your contributions so far, Erik.
Finally, update the git URL since I'll take over running the main repo
for a while.
Overall maintainership model isn't changing much at this time: We'll all
three review patches as appropriate, and one of us will collect the main
repo (me at this time).
Cc: Erik Gilling <konkers@android.com>
Acked-by: Colin Cross <ccross@android.com>
* 'upstream' of git://git.linux-mips.org/pub/scm/upstream-linus: (29 commits)
MIPS: Call oops_enter, oops_exit in die
staging/octeon: Software should check the checksum of no tcp/udp packets
MIPS: Octeon: Enable C0_UserLocal probing.
MIPS: No branches in delay slots for huge pages in handle_tlbl
MIPS: Don't clobber CP0_STATUS value for CONFIG_MIPS_MT_SMTC
MIPS: Octeon: Select CONFIG_HOLES_IN_ZONE
MIPS: PM: Use struct syscore_ops instead of sysdevs for PM (v2)
MIPS: Compat: Use 32-bit wrapper for compat_sys_futex.
MIPS: Do not use EXTRA_CFLAGS
MIPS: Alchemy: DB1200: Disable cascade IRQ in handler
SERIAL: Lantiq: Set timeout in uart_port
MIPS: Lantiq: Fix setting the PCI bus speed on AR9
MIPS: Lantiq: Fix external interrupt sources
MIPS: tlbex: Fix build error in R3000 code.
MIPS: Alchemy: Include Au1100 in PM code.
MIPS: Alchemy: Fix typo in MAC0 registration
MIPS: MSP71xx: Fix build error.
MIPS: Handle __put_user() sleeping.
MIPS: Allow forced irq threading
MIPS: i8259: Mark cascade interrupt non-threaded
Microsoft has a bug with ntlmv2 that requires use of ntlmssp, but
we didn't get the required information on when/how to use ntlmssp to
old (but once very popular) legacy servers (various NT4 fixpacks
for example) until too late to merge for 3.1. Will upgrade
to NTLMv2 in NTLMSSP in 3.2
Signed-off-by: Steve French <smfrench@gmail.com>
Reviewed-by: Jeff Layton <jlayton@redhat.com>
This applies ARM errata fix 754322 for all ux500 platforms.
Signed-off-by: srinidhi kasagar <srinidhi.kasagar@stericsson.com>
* git://github.com/davem330/net:
net: fix typos in Documentation/networking/scaling.txt
bridge: leave carrier on for empty bridge
netfilter: Use proper rwlock init function
tcp: properly update lost_cnt_hint during shifting
tcp: properly handle md5sig_pool references
macvlan/macvtap: Fix unicast between macvtap interfaces in bridge mode
In summary, this DMI quirk uses the _CRS info by default for the ASUS
M2V-MX SE by turning on `pci=use_crs` and is similar to the quirk
added by commit 2491762cfb47 ("x86/PCI: use host bridge _CRS info on
ASRock ALiveSATA2-GLAN") whose commit message should be read for further
information.
Since commit 3e3da00c01d0 ("x86/pci: AMD one chain system to use pci
read out res") Linux gives the following oops:
parport0: PC-style at 0x378, irq 7 [PCSPP,TRISTATE]
HDA Intel 0000:20:01.0: PCI INT A -> GSI 17 (level, low) -> IRQ 17
HDA Intel 0000:20:01.0: setting latency timer to 64
BUG: unable to handle kernel paging request at ffffc90011c08000
IP: [<ffffffffa0578402>] azx_probe+0x3ad/0x86b [snd_hda_intel]
PGD 13781a067 PUD 13781b067 PMD 1300ba067 PTE 800000fd00000173
Oops: 0009 [#1] SMP
last sysfs file: /sys/module/snd_pcm/initstate
CPU 0
Modules linked in: snd_hda_intel(+) snd_hda_codec snd_hwdep snd_pcm_oss snd_mixer_oss snd_pcm snd_seq_midi snd_rawmidi snd_seq_midi_event tpm_tis tpm snd_seq tpm_bios psmouse parport_pc snd_timer snd_seq_device parport processor evdev snd i2c_viapro thermal_sys amd64_edac_mod k8temp i2c_core soundcore shpchp pcspkr serio_raw asus_atk0110 pci_hotplug edac_core button snd_page_alloc edac_mce_amd ext3 jbd mbcache sha256_generic cryptd aes_x86_64 aes_generic cbc dm_crypt dm_mod raid1 md_mod usbhid hid sg sd_mod crc_t10dif sr_mod cdrom ata_generic uhci_hcd sata_via pata_via libata ehci_hcd usbcore scsi_mod via_rhine mii nls_base [last unloaded: scsi_wait_scan]
Pid: 1153, comm: work_for_cpu Not tainted 2.6.37-1-amd64 #1 M2V-MX SE/System Product Name
RIP: 0010:[<ffffffffa0578402>] [<ffffffffa0578402>] azx_probe+0x3ad/0x86b [snd_hda_intel]
RSP: 0018:ffff88013153fe50 EFLAGS: 00010286
RAX: ffffc90011c08000 RBX: ffff88013029ec00 RCX: 0000000000000006
RDX: 0000000000000000 RSI: 0000000000000246 RDI: 0000000000000246
RBP: ffff88013341d000 R08: 0000000000000000 R09: 0000000000000040
R10: 0000000000000286 R11: 0000000000003731 R12: ffff88013029c400
R13: 0000000000000000 R14: 0000000000000000 R15: ffff88013341d090
FS: 0000000000000000(0000) GS:ffff8800bfc00000(0000) knlGS:00000000f7610ab0
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: ffffc90011c08000 CR3: 0000000132f57000 CR4: 00000000000006f0
Process work_for_cpu (pid: 1153, threadinfo ffff88013153e000, task ffff8801303c86c0)
Stack:
0000000000000005 ffffffff8123ad65 00000000000136c0 ffff88013029c400
ffff8801303c8998 ffff88013341d000 ffff88013341d090 ffff8801322d9dc8
ffff88013341d208 0000000000000000 0000000000000000 ffffffff811ad232
Call Trace:
[<ffffffff8123ad65>] ? __pm_runtime_set_status+0x162/0x186
[<ffffffff811ad232>] ? local_pci_probe+0x49/0x92
[<ffffffff8105afc5>] ? do_work_for_cpu+0x0/0x1b
[<ffffffff8105afd0>] ? do_work_for_cpu+0xb/0x1b
[<ffffffff8105fd3f>] ? kthread+0x7a/0x82
[<ffffffff8100a824>] ? kernel_thread_helper+0x4/0x10
[<ffffffff8105fcc5>] ? kthread+0x0/0x82
[<ffffffff8100a820>] ? kernel_thread_helper+0x0/0x10
Code: f4 01 00 00 ef 31 f6 48 89 df e8 29 dd ff ff 85 c0 0f 88 2b 03 00 00 48 89 ef e8 b4 39 c3 e0 8b 7b 40 e8 fc 9d b1 e0 48 8b 43 38 <66> 8b 10 66 89 14 24 8b 43 14 83 e8 03 83 f8 01 77 32 31 d2 be
RIP [<ffffffffa0578402>] azx_probe+0x3ad/0x86b [snd_hda_intel]
RSP <ffff88013153fe50>
---[ end trace 8d1f3ebc136437fd ]---
Trusting the ACPI _CRS information (`pci=use_crs`) fixes this problem.
$ dmesg | grep -i crs # with the quirk
PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
The match has to be against the DMI board entries though since the vendor entries are not populated.
DMI: System manufacturer System Product Name/M2V-MX SE, BIOS 0304 10/30/2007
This quirk should be removed when `pci=use_crs` is enabled for machines
from 2006 or earlier or some other solution is implemented.
Using coreboot [1] with this board the problem does not exist but this
quirk also does not affect it either. To be safe though the check is
tightened to only take effect when the BIOS from American Megatrends is
used.
15:13 < ruik> but coreboot does not need that
15:13 < ruik> because i have there only one root bus
15:13 < ruik> the audio is behind a bridge
$ sudo dmidecode
BIOS Information
Vendor: American Megatrends Inc.
Version: 0304
Release Date: 10/30/2007
[1] http://www.coreboot.org/
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=30552
Cc: stable@kernel.org (2.6.34)
Cc: x86@kernel.org
Signed-off-by: Paul Menzel <paulepanter@users.sourceforge.net>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org>
The second hunk fixes rps_sock_flow_table but has to re-wrap the paragraph.
Signed-off-by: Benjamin Poirier <benjamin.poirier@gmail.com>
This resolves a regression seen by some users of bridging.
Some users use the bridge like a dummy device.
They expect to be able to put an IPv6 address on the device
with no ports attached. Although there are better ways of doing
this, there is no reason to not allow it.
Note: the bridge still will reflect the state of ports in the
bridge if there are any added.
* 'for-linus' of http://people.redhat.com/agk/git/linux-dm:
dm crypt: always disable discard_zeroes_data
dm: raid fix write_mostly arg validation
dm table: avoid crash if integrity profile changes
dm: flakey fix corrupt_bio_byte error path
* 'for-linus' of git://neil.brown.name/md:
md: Avoid waking up a thread after it has been freed.
