2009-03-24USB: usbmon: Add binary API v1Pete Zaitcev
This patch adds an extension to the binary API so it reaches parity with existing text API (so-called "1u"). The extension delivers additional data, such as ISO descriptors and the interrupt interval. Signed-Off-By: Pete Zaitcev <zaitcev@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-24USB: ch341 serial: fix port number changed after resumeMing Lei
This patch fixes the following bug: .plug ch341 usb serial port into a hub port; .ch341 driver bound to the device and /dev/ttyUSB0 comes .open /dev/ttyUSB0 by minicom and we can use the serial successfully .suspend the ch341 usb serial device(such as: echo suspend > power/level) .resume the ch341 usb serial device (such as: echo on > power/level) .new port /dev/ttyUSB1 comes ,and the original /dev/ttyUSB0 still exists, but is no longer usable by minicom The patch adds suspend and resume callback to ch341 usb driver to prevent it from unbinding during suspend. The /dev/ttyUSB0 is not released until being closed, so /dev/ttyUSB1 comes after resume, and the original /dev/ttyUSB0 is no longer usable by minicom. It is really a mess for a minicom user. This patch also adds the reset_resume callback to make it usable after resuming from STR or hibernation, for generally STR or hibernation will make the vbus of root-hub lost. Finally enable the driver's supports_autosuspend, for the device is in working order with it. Signed-off-by: Ming Lei <tom.leiming@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-24USB: musb: partial DaVinci dm355 supportDavid Brownell
Partial support for DaVinci DM355, on the EVM board; peripheral mode should work, once mainline merges DM355 support. Missing: (a) renumbering the GPIO for DRVVBUS on the DM6446 EVM, when DAVINCI_N_GPIO increases; (b) disabling DM355_DEEPSLEEP.DRVVBUS_OVERRIDE so VBUS is driven according to the ID signal, if cpu_is_..._dm355() The new PHY control bits are ignored on DM6446. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Kevin Hilman <khilman@deeprootsystems.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-24USB: musb: only turn off vbus in OTG hostsAjay Kumar Gupta
Except on DaVinci, VBUS is now switched off as part of idling the USB link (after a_wait_bcon) whenever a device is disconnected from host. This is correct for OTG hosts, where either SRP or an ID interrupt could turn VBUS on again. However, for non-OTG hosts there's no way to turn VBUS on again, so the host becomes unusable. And the procfs entry which once allowed a manual workaround for this is now gone. This patch adds an is_otg_enabled() check before scheduling the switch-off timer in disconnect path, supporting a "classic host" mode where SRP is unavailable. [ dbrownell@users.sourceforge.net: tweak patch description ] Signed-off-by: Ajay Kumar Gupta <ajay.gupta@ti.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-24USB: musb: fix init oops crash with static FIFO configGiuseppe GORGOGLIONE
Correct musb_read_fifosize() and musb_configure_ep0() functions for the #ifndef BLACKFIN branch when the silicon uses static FIFO configuration. (Most current silicon configures this controller to use dynamic FIFO configuration; some parts from ST don't, like the STM STA2062.) Signed-off-by: Giuseppe GORGOGLIONE <giuseppe.gorgoglione@st.com> Signed-off-by: Felipe Balbi <felipe.balbi@nokia.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-24USB: musb: NAK timeout scheme on bulk RX endpointAjay Kumar Gupta
Fixes endpoint starvation issue when more than one bulk QH is multiplexed on the reserved bulk RX endpoint, which is normal for cases like serial and ethernet adapters. This patch sets the NAK timeout interval for such QHs, and when a timeout triggers the next QH will be scheduled. (This resembles the bulk scheduling done in hardware by EHCI, OHCI, and UHCI.) This scheme doesn't work for devices which are connected to a high to full speed tree (transaction translator) as there is no NAK timeout interrupt from the musb controller from such devices. Tested with PIO, Inventra DMA, CPPI DMA. [ dbrownell@users.sourceforge.net: fold in start_urb() update; clarify only for bulk RX; don't accidentally clear WZC bits ] Signed-off-by: Ajay Kumar Gupta <ajay.gupta@ti.com> Cc: Felipe Balbi <felipe.balbi@nokia.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-24USB: musb: rewrite host periodic endpoint allocationSergei Shtylyov
The current MUSB host code doesn't make use of all the available FIFOs in for periodic transfers since it wrongly assumes the RX and TX sides of any given hw_ep always share one FIFO. Change: use 'in_qh' and 'out_qh' fields of the 'struct musb_hw_ep' to check the endpoint's business; get rid of the now-unused 'periodic' array in the 'struct musb'. Also optimize a loop induction variable in the endpoint lookup code. (Based on a previous patch from Ajay Kumar Gupta <ajay.gupta@ti.com>) [ dbrownell@users.sourceforge.net: clarify description and origin of this fix; whitespace ] Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Felipe Balbi <felipe.balbi@nokia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-24USB: composite: avoid inconsistent lock stateFelipe Balbi
Avoid the following INFO from lock debugging: [ 369.126112] ================================= [ 369.132063] [ INFO: inconsistent lock state ] [ 369.136457] 2.6.28-maemo1 #1 [ 369.139387] --------------------------------- [ 369.143782] inconsistent {hardirq-on-W} -> {in-hardirq-W} usage. [ 369.149855] swapper/0 [HC1[1]:SC0[0]:HE0:SE1] takes: [ 369.154890] (&cdev->lock){+-..}, at: [<bf1979f0>] composite_disconnect+0x1c/0] [ 369.163404] {hardirq-on-W} state was registered at: [ 369.168348] [<c00788a8>] __lock_acquire+0x5d0/0x7d8 [ 369.173506] [<c0078b14>] lock_acquire+0x64/0x78 [ 369.178266] [<c0263a34>] _spin_lock+0x4c/0x80 [ 369.182905] [<bf19597c>] usb_function_deactivate+0x20/0x70 [g_nokia] [ 369.189527] [<bf1a0a88>] 0xbf1a0a88 [ 369.193281] [<bf19f450>] 0xbf19f450 [ 369.197004] [<bf19fa3c>] 0xbf19fa3c [ 369.200758] [<bf1a03a0>] 0xbf1a03a0 [ 369.204481] [<bf19f254>] 0xbf19f254 [ 369.208204] [<bf1a0158>] 0xbf1a0158 [ 369.211927] [<bf1a130c>] 0xbf1a130c [ 369.215650] [<c01c21f0>] usb_gadget_register_driver+0x12c/0x28c [ 369.221846] [<bf1a06bc>] 0xbf1a06bc [ 369.225569] [<bf1a06e8>] 0xbf1a06e8 [ 369.229322] [<c002c2dc>] __exception_text_end+0x64/0x19c [ 369.234877] [<c0081628>] sys_init_module+0x9c/0x194 [ 369.240004] [<c002c8e0>] ret_fast_syscall+0x0/0x2c [ 369.245039] [<ffffffff>] 0xffffffff [ 369.248793] irq event stamp: 218356 [ 369.252302] hardirqs last enabled at (218355): [<c003a77c>] omap3_enter_idle+8 [ 369.260420] hardirqs last disabled at (218356): [<c0264774>] __irq_svc+0x34/0x0 [ 369.267927] softirqs last enabled at (218348): [<c00585a4>] __do_softirq+0x134 [ 369.275892] softirqs last disabled at (218335): [<c005899c>] irq_exit+0x60/0xb0 [ 369.283308] [ 369.283308] other info that might help us debug this: [ 369.289930] no locks held by swapper/0. Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Felipe Balbi <felipe.balbi@nokia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-24USB: allow libusb to talk to unauthenticated WUSB devicesDavid Vrabel
To permit a userspace application to associate with WUSB devices using numeric association, control transfers to unauthenticated WUSB devices must be allowed. This requires that wusbcore correctly sets the device state to UNAUTHENTICATED, DEFAULT and ADDRESS and that control transfers can be performed to UNAUTHENTICATED devices. Signed-off-by: David Vrabel <david.vrabel@csr.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-24USB: usb-storage: added missing MODULE_LICENSE("GPL") for usb-storage ums-* ↵Maciej Grela
modules The lack of a MODULE_LICENSE macro in ums-* subdrivers prevented them from loading. Needs to be applied after Alan Stern's usb-storage subdriver separation patchset. Also added missing MODULE_DESCRIPTION and MODULE_AUTHOR entries. Signed-off-by: Maciej Grela <maciej.grela@gmail.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Acked-by: Matthew Dharm <mdharm-usb@one-eyed-alien.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-24usb-storage: make onetouch a separate moduleAlan Stern
This patch (as1217) converts usb-storage's onetouch subdriver into a separate module. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-24usb-storage: make karma a separate moduleAlan Stern
This patch (as1216) converts usb-storage's karma subdriver into a separate module. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-24usb-storage: make alauda a separate moduleAlan Stern
This patch (as1215) converts usb-storage's alauda subdriver into a separate module. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-24usb-storage: make jumpshot a separate moduleAlan Stern
This patch (as1214) converts usb-storage's jumpshot subdriver into a separate module. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-24usb-storage: make datafab a separate moduleAlan Stern
This patch (as1213) converts usb-storage's datafab subdriver into a separate module. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-24usb-storage: make freecom a separate moduleAlan Stern
This patch (as1212) converts usb-storage's freecom subdriver into a separate module. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-24usb-storage: make shuttle_usbat a separate moduleAlan Stern
This patch (as1211) converts usb-storage's shuttle_usbat subdriver into a separate module. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-24usb-storage: make cypress_atacb a separate moduleAlan Stern
This patch (as1210) converts usb-storage's cypress_atacb subdriver into a separate module. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-24usb-storage: make sddr55 a separate moduleAlan Stern
This patch (as1209) converts usb-storage's sddr55 subdriver into a separate module. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-24usb-storage: make isd200 a separate moduleAlan Stern
This patch (as1208) converts usb-storage's isd200 subdriver into a separate module. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-24usb-storage: make sddr09 a separate moduleAlan Stern
This patch (as1207) converts usb-storage's sddr09 subdriver into a separate module. An unexpected complication arises because of DPCM devices, in which one LUN uses the sddr09 transport and one uses the standard CB transport. Since these devices can be used even when USB_STORAGE_SDDR09 isn't configured, their entries in unusual_devs.h require special treatment. If SDDR09 isn't configured then the entries remain in unusual_devs.h; if it is then the entries are present in unusual_sddr09.h instead. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-24usb-storage: prepare for subdriver separationAlan Stern
This patch (as1206) is the first step in converting usb-storage's subdrivers into separate modules. It makes the following large-scale changes: Remove a bunch of unnecessary #ifdef's from usb_usual.h. Not truly necessary, but it does clean things up. Move the USB device-ID table (which is duplicated between libusual and usb-storage) into its own source file, usual-tables.c, and arrange for this to be linked with either libusual or usb-storage according to whether USB_LIBUSUAL is configured. Add to usual-tables.c a new usb_usual_ignore_device() function to detect whether a particular device needs to be managed by a subdriver and not by the standard handlers in usb-storage. Export a whole bunch of functions in usb-storage, renaming some of them because their names don't already begin with "usb_stor_". These functions will be needed by the new subdriver modules. Split usb-storage's probe routine into two functions. The subdrivers will call the probe1 routine, then fill in their transport and protocol settings, and then call the probe2 routine. Take the default cases and error checking out of get_transport() and get_protocol(), which run during probe1, and instead put a check for invalid transport or protocol values into the probe2 function. Add a new probe routine to be used for standard devices, i.e., those that don't need a subdriver. This new routine checks whether the device should be ignored (because it should be handled by ub or by a subdriver), and if not, calls the probe1 and probe2 functions. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> CC: Matthew Dharm <mdharm-usb@one-eyed-alien.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-24usb-serial: fix usb_serial_register bug when boot with nousb paramDave Young
With "nousb" cmdline booting, built-in serial drivers (ie. airecable) will trigger kernel oops. Indeed, if nousb, usb_serial_init will failed, and the usb serial bus type will not be registerd, then usb_serial_register call driver_register which try to register the driver to a not registered bus. Here add usb_disabled() check in usb_serial_register to fix it. Signed-off-by: Dave Young <hidave.darkstar@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-24USB: fix ehci printk formatsRandy Dunlap
Fix ehci printk formats: drivers/usb/host/ehci-q.c:351: warning: format '%d' expects type 'int', but argument 4 has type 'size_t' drivers/usb/host/ehci-q.c:351: warning: format '%d' expects type 'int', but argument 5 has type 'size_t' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-24USB: replace uses of __constant_{endian}Harvey Harrison
The base versions handle constant folding now. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-24USB: serial: add qualcomm wireless modem driverGreg Kroah-Hartman
Driver originally written by Qualcomm, but rewritten by me due to the totally different coding style. Cleaned up the probe logic to make a bit more sense, this is one wierd device. They could have prevented all of this by just writing sane firmware for the modem. Cc: Tamm Liu <tamml@qualcomm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-24USB: symbolserial: log the ioctl commandsGreg Kroah-Hartman
We need to figure out what userspace programs are expecting from this driver, so log them so we can try to get it right. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-24USB: serial: add symbol serial driverGreg Kroah-Hartman
This is for the Symbol 6608 barcode scanner in a fake "HID" mode. Thanks to Dalibor Grgec for working with me to get this to start to work properly. Cc: Dalibor Grgec <dalibor.grgec@zemris.fer.hr> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-24USB: Add platform device support for the ISP1760 USB chipCatalin Marinas
Currently, the driver only supports PCI and PPC_OF but there are boards like ARM RealView where this is a platform device. The patch adds the necessary functions and registration to the isp1760-if.c file and modifies the corresponding Makefile and Kconfig to be able to use this driver even if PCI and PPC_OF are not enabled. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Cc: Sebastian Siewior <bigeasy@linutronix.de> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-24USB: Make the isp1760_register function prototype more genericCatalin Marinas
The patch changes the prototype of the isp1760_register() function to use predefined types like phys_addr_t and resource_size_t rather than u64 Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Cc: Sebastian Siewior <bigeasy@linutronix.de> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-24USB: EHCI: add software retry for transaction errorsAlan Stern
This patch (as1204) adds a software retry mechanism to ehci-hcd. It gets invoked when the driver encounters transaction errors on an asynchronous endpoint. On many systems, hardware deficiencies cause such errors to occur if one device is unplugged while the host is communicating with another device. With the patch, the failed transactions are retried and generally succeed the second or third time through. This is based on code originally written by Koichiro Saito. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Tested by: Koichiro Saito <Saito.Koichiro@adniss.jp> CC: David Brownell <david-b@pacbell.net> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-24USB: fix USB_STORAGE_CYPRESS_ATACBBoaz Harrosh
commit 64a87b24: [SCSI] Let scsi_cmnd->cmnd use request->cmd buffer changed the scsi_eh_prep_cmnd logic by making it clear the ->cmnd buffer. But the sat to cypress atacb translation supposed the ->cmnd buffer wasn't modified. This patch makes it set the ->cmnd buffer after scsi_eh_prep_cmnd call. The problem and a fix was reported by Matthieu CASTET <castet.matthieu@free.fr> It also removes all the hackery fiddling of scsi_cmnd and scsi_eh_save by requesting from scsi_eh_prep_cmnd to prepare a read into ->sense_buffer, which is much more suitable a buffer for HW transfers, then after the command execution the regs read is copied into regs buffer before actual preparation of sense_buffer. Also fix an alien comment character to my utf-8 editor. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: Matthieu CASTET <castet.matthieu@free.fr> Cc: stable <stable@kernel.org> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: Matthew Dharm <mdharm-kernel@one-eyed-alien.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-24USB: EHCI: Make timer_action out-of-lineAlan Stern
This patch (as1205) moves timer_action() from ehci.h to ehci-hcd.c and makes it out-of-line. Over the years it has grown too big to be inline any more. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-24usb: kill prehistorical comments about USB_EHCI_HCDThierry Vignaud
Remove old comments about USB_EHCI_HCD. Cc: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-24USB: serial: refuse to open recently removed USB Serial devicesJames Woodcock
A USB-serial converter device is plugged into a system, and a process opens it's device node. If the device is physically removed whilst the process still has its device node open, then other processes can sucessfully open the now non-existent device's node. I would expect that open() on a device that has been physically removed should return ENODEV. This is manifesting itself with getty on my system. I do the following: 1. set up inittab to spawn getty on ttyUSB0, eg: T1:23:respawn:/sbin/getty -L ttyUSB0 115200 vt100 2. Plug in USB-serial converter cable 3. Wait for a login prompt on a terminal program attached to the serial cable 4. Login 5. Pull the USB-serial converter cable from the box 6. getty doesn't realise that ttyUSB0 no longer exists as /dev/ttyUSB0 can still be opened. 7. Re-insert the USB-serial converter cable 8. You should no longer get a login prompt over the serial cable, as the the USB-serial cable now shows up as /dev/ttyUSB1, and getty is trying to talk to /dev/ttyUSB0. The attached patch will cause open("/dev/ttyUSB0", O_RDONLY) to return ENODEV after the USB-serial converter has been pulled. The patch was created against 2.6.28.1. I can supply it against something else if needs be. It is fairly simple, so should be OK. I am using a pl2303 device, although I don't think that makes any difference. From: James Woodcock <James.Woodcock@ACULAB.COM> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-24USB: serial: remove recourse to generic methodOliver Neukum
This removes the fallback to the generic method. It is cleaner to explicitely request it. Introducing this was my mistake. This will be solved by an explicit test and the driver being allowed to request what it needs to be done upon resumption. Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-24USB: skeleton: Use dev_info instead of infoMatt Kraai
338b67b0c1a97ca705023a8189cf41aa0828d294 removed the info macro and replaced its uses with dev_info. This patch does so for usb-skeleton.c, which was missed. Signed-off-by: Matt Kraai <kraai@ftbfs.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-24usb_storage: make Kconfig note visible in the consoleBorislav Petkov
Make lines about usb_storage depending on SCSI visible when configuring the kernel in a 80x25 console Signed-off-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-24USB: serial: opticon: add serial line ioctlsGreg Kroah-Hartman
This lets userspace determine what the state of the RTS line is, which is what is needed to properly handle data flow for this device (it raises RTS when there is data to be sent from it.) Cc: Kees Stoop <kees.stoop@opticon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-24USB: serial: opticon: add write supportGreg Kroah-Hartman
This patch allows data to be sent to the scanner. Cc: Kees Stoop <kees.stoop@opticon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-24USB: otg: adding nop usb transceiverAjay Kumar Gupta
NOP transceiver is used by all the usb transceiver which are mostly autonomous and doesn't require any programming or which are built into the usb ip itself.NOP transceiver only allocates the memory for struct xceiv and calls otg_set_transceiver() so function call to otg_get_transceiver() will return a valid transceiver. NOP transceiver device should be registered by calling usb_nop_xceiv_register() from platform files. Signed-off-by: Ajay Kumar Gupta <ajay.gupta@ti.com> Cc: Felipe Balbi <felipe.balbi@nokia.com> Cc: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-24USB: ftdi_sio: remove pointless syslog spewDavid Brownell
Remove some pointless messages from the FTDI serial driver; I found these filling up syslog on one system. Also remove a pointless "break" after a "return" in the same area. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-24USB: add missing KERN_* constants to printksFrank Seidel
According to kerneljanitors todo list all printk calls (beginning a new line) should have an according KERN_* constant. Those are the missing peaces here for the usb subsystem. Signed-off-by: Frank Seidel <frank@f-seidel.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-24USB: serial: use generic method if no alternative is provided in usb serial ↵Oliver Neukum
layer This patch makes use of the generic method if a serial driver provides no implementation. This simplifies implementing suspend/resume support in serial drivers. Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-24USB: serial: export symbol of usb_serial_generic_resumeOliver Neukum
This exports a symbol for usb_serial_generic_resume, so that modules can use it. Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-24USB: serial generic resume function fixOliver Neukum
This removes an unnecessary check for autoresume from the generic resume method. The check has been obsoleted by the now delayed increase of the usage counter which makes the error this check prevented impossible. This change allows drivers which only use the bulk read URB the use of the generic method even if they support autosuspend. Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-24USB: serial: introduce a flag into the usb serial layer to tell drivers that ↵Oliver Neukum
their URBs are killed due to suspension This patch introduces a flag into the usb serial layer to tell drivers that their URBs are killed due to suspension. That is necessary to let drivers know whether they should report an error back. Signed-off-by: Oliver Neukum <oneukum@suse.de> Hi Greg, this is for 2.6.30. Patches to use this in drivers are under development. Regards Oliver
2009-03-24USB: count reaches -1, tested 0Roel Kluin
With a postfix decrement count will reach -1 rather than 0, so the warning will not be issued. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-24USB: suspend/resume for opticon driverOliver Neukum
this does the standard support for suspend/resume for the opticon driver. Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-24USB: suspend/resume support for option driverOliver Neukum
This patch implements suspend and resume methods for the option driver. With my hardware I can even suspend the system and keep up a connection for a short time. Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-Off-By: Matthias Urlichs <smurf@smurf.noris.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
