As fifo-depth property in dw_mmc device tree node is SOC
specific, move this property to exynos5250 SOC specific
file.
Signed-off-by: Yuvaraj Kumar C D <yuvaraj.cd@samsung.com>
Reviewed-by: Tomasz Figa <t.figa@samsung.com>
[kgene.kim@samsung.com: squashed fifo-depth patch for cros5250-common]
Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
According to ePAPR, chapter 2.3.4, the status property has
defined that it should be set to "disabled" when "the device
is not presently operational, but it might become operational
in the future".
So this patch disable dwmmc node by "status = disabled" in SOC
dts file and enable dwmmc node by "status = okay" in board specific
dts file.
Exynos5 series SOC's 5250 and 5420 have different versions of
DWMMC controller.So there is a new compatible string to distinguish
between them.So these nodes should be moved out of Exynos5 series
common device tree source to SOC specific device tree source.
git://git.kernel.org/pub/scm/linux/kernel/git/tyhicks/ecryptfs
Pull minor eCryptfs fix from Tyler Hicks:
"Quiet static checkers by removing unneeded conditionals"
* tag 'ecryptfs-3.13-rc1-quiet-checkers' of git://git.kernel.org/pub/scm/linux/kernel/git/tyhicks/ecryptfs:
eCryptfs: file->private_data is always valid
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound
Pull second set of sound fixes from Takashi Iwai:
"A collection of small fixes in HD-audio quirks and runtime PM, ASoC
rcar, abs8500 and other codecs. Most of commits are for stable
kernels, too"
* tag 'sound-fix2-3.13-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound:
ALSA: hda - Set current_headset_type to ALC_HEADSET_TYPE_ENUM (janitorial)
ALSA: hda - Provide missing pin configs for VAIO with ALC260
ALSA: hda - Add headset quirk for Dell Inspiron 3135
ALSA: hda - Fix the headphone jack detection on Sony VAIO TX
ALSA: hda - Fix missing bass speaker on ASUS N550
ALSA: hda - Fix unbalanced runtime PM notification at resume
ASoC: arizona: Set FLL to free-run before disabling
ALSA: hda - A casual Dell Headset quirk
ASoC: rcar: fixup dma_async_issue_pending() timing
ASoC: rcar: off by one in rsnd_scu_set_route()
ASoC: wm5110: Add post SYSCLK register patch for rev D chip
ASoC: ab8500: Revert to using custom I/O functions
ALSA: hda - Also enable mute/micmute LED control for "Lenovo dock" fixup
ALSA: firewire-lib: include sound/asound.h to refer to snd_pcm_format_t
ALSA: hda - Select FW_LOADER from CONFIG_SND_HDA_CODEC_CA0132_DSP
ALSA: hda - Enable mute/mic-mute LEDs for more Thinkpads with Realtek codec
ASoC: rcar: fixup mod access before checking
Pull DRM fixes from Dave Airlie:
"I was going to leave this until post -rc1 but sysfs fixes broke
hotplug in userspace, so I had to fix it harder, otherwise a set of
pulls from intel, radeon and vmware,
The vmware/ttm changes are bit larger but since its early and they are
unlikely to break anything else I put them in, it lets vmware work
with dri3"
* 'drm-fixes' of git://people.freedesktop.org/~airlied/linux: (36 commits)
drm/sysfs: fix hotplug regression since lifetime changes
drm/exynos: g2d: fix memory leak to userptr
drm/i915: Fix gen3 self-refresh watermarks
drm/ttm: Remove set_need_resched from the ttm fault handler
drm/ttm: Don't move non-existing data
drm/radeon: hook up backlight functions for CI and KV family.
drm/i915: Replicate BIOS eDP bpp clamping hack for hsw
drm/i915: Do not enable package C8 on unsupported hardware
drm/i915: Hold pc8 lock around toggling pc8.gpu_idle
drm/i915: encoder->get_config is no longer optional
drm/i915/tv: add ->get_config callback
drm/radeon/cik: Add macrotile mode array query
drm/radeon/cik: Return backend map information to userspace
drm/vmwgfx: Make vmwgfx dma buffers prime aware
drm/vmwgfx: Make surfaces prime-aware
drm/vmwgfx: Hook up the prime ioctls
drm/ttm: Add a minimal prime implementation for ttm base objects
drm/vmwgfx: Fix false lockdep warning
drm/ttm: Allow execbuf util reserves without ticket
drm/i915: restore the early forcewake cleanup
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci
Pull PCI updates from Bjorn Helgaas:
"Miscellaneous
- Remove duplicate disable from pcie_portdrv_remove() (Yinghai Lu)
- Fix whitespace, capitalization, and spelling errors (Bjorn Helgaas)"
* tag 'pci-v3.13-fixes-1' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci:
PCI: Remove duplicate pci_disable_device() from pcie_portdrv_remove()
PCI: Fix whitespace, capitalization, and spelling errors
git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending
Pull SCSI target updates from Nicholas Bellinger:
"Things have been quiet this round with mostly bugfixes, percpu
conversions, and other minor iscsi-target conformance testing changes.
The highlights include:
- Add demo_mode_discovery attribute for iscsi-target (Thomas)
- Convert tcm_fc(FCoE) to use percpu-ida pre-allocation
- Add send completion interrupt coalescing for ib_isert
- Convert target-core to use percpu-refcounting for se_lun
- Fix mutex_trylock usage bug in iscsit_increment_maxcmdsn
- tcm_loop updates (Hannes)
- target-core ALUA cleanups + prep for v3.14 SCSI Referrals support (Hannes)
v3.14 is currently shaping to be a busy development cycle in target
land, with initial support for T10 Referrals and T10 DIF currently on
the roadmap"
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: (40 commits)
iscsi-target: chap auth shouldn't match username with trailing garbage
iscsi-target: fix extract_param to handle buffer length corner case
iscsi-target: Expose default_erl as TPG attribute
target_core_configfs: split up ALUA supported states
target_core_alua: Make supported states configurable
target_core_alua: Store supported ALUA states
target_core_alua: Rename ALUA_ACCESS_STATE_OPTIMIZED
target_core_alua: spellcheck
target core: rename (ex,im)plict -> (ex,im)plicit
percpu-refcount: Add percpu-refcount.o to obj-y
iscsi-target: Do not reject non-immediate CmdSNs exceeding MaxCmdSN
iscsi-target: Convert iscsi_session statistics to atomic_long_t
target: Convert se_device statistics to atomic_long_t
target: Fix delayed Task Aborted Status (TAS) handling bug
iscsi-target: Reject unsupported multi PDU text command sequence
ib_isert: Avoid duplicate iscsit_increment_maxcmdsn call
iscsi-target: Fix mutex_trylock usage in iscsit_increment_maxcmdsn
target: Core does not need blkdev.h
target: Pass through I/O topology for block backstores
iser-target: Avoid using FRMR for single dma entry requests
git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging
Pull hwmon fixes from Guenter Roeck:
- acpi_power_meter: Fix return value check from call to
acpi_bus_get_device
- nct6775: Fix/improve NCT6791 support
- lm75: Add support for GMT G751
* tag 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging:
hwmon: (acpi_power_meter) Fix acpi_bus_get_device() return value check
hwmon: (nct6775) NCT6791 supports weight control only for CPUFAN
hwmon: (nct6775) Monitor additional temperature registers
hwmon: (lm75) Add support for GMT G751 chip
Pull networking fixes from David Miller:
1) Fix memory leaks and other issues in mwifiex driver, from Amitkumar
Karwar.
2) skb_segment() can choke on packets using frag lists, fix from
Herbert Xu with help from Eric Dumazet and others.
3) IPv4 output cached route instantiation properly handles races
involving two threads trying to install the same route, but we
forgot to propagate this logic to input routes as well. Fix from
Alexei Starovoitov.
4) Put protections in place to make sure that recvmsg() paths never
accidently copy uninitialized memory back into userspace and also
make sure that we never try to use more that sockaddr_storage for
building the on-kernel-stack copy of a sockaddr. Fixes from Hannes
Frederic Sowa.
5) R8152 driver transmit flow bug fixes from Hayes Wang.
6) Fix some minor fallouts from genetlink changes, from Johannes Berg
and Michael Opdenacker.
7) AF_PACKET sendmsg path can race with netdevice unregister notifier,
fix by using RCU to make sure the network device doesn't go away
from under us. Fix from Daniel Borkmann.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (43 commits)
gso: handle new frag_list of frags GRO packets
genetlink: fix genl_set_err() group ID
genetlink: fix genlmsg_multicast() bug
packet: fix use after free race in send path when dev is released
xen-netback: stop the VIF thread before unbinding IRQs
wimax: remove dead code
net/phy: Add the autocross feature for forced links on VSC82x4
net/phy: Add VSC8662 support
net/phy: Add VSC8574 support
net/phy: Add VSC8234 support
net: add BUG_ON if kernel advertises msg_namelen > sizeof(struct sockaddr_storage)
net: rework recvmsg handler msg_name and msg_namelen logic
bridge: flush br's address entry in fdb when remove the
net: core: Always propagate flag changes to interfaces
ipv4: fix race in concurrent ip_route_input_slow()
r8152: fix incorrect type in assignment
r8152: support stopping/waking tx queue
r8152: modify the tx flow
r8152: fix tx/rx memory overflow
netfilter: ebt_ip6: fix source and destination matching
Pull ARM fixes from Russell King:
"Some small fixes for this merge window, most of them quite self
explanatory - the biggest thing here is a fix for the ARMv7 LPAE
suspend/resume support"
* 'fixes' of git://git.linaro.org/people/rmk/linux-arm:
ARM: 7894/1: kconfig: select GENERIC_CLOCKEVENTS if HAVE_ARM_ARCH_TIMER
ARM: 7893/1: bitops: only emit .arch_extension mp if CONFIG_SMP
ARM: 7892/1: Fix warning for V7M builds
ARM: 7888/1: seccomp: not compatible with ARM OABI
ARM: 7886/1: make OABI default to off
ARM: 7885/1: Save/Restore 64-bit TTBR registers on LPAE suspend/resume
ARM: 7884/1: mm: Fix ECC mem policy printk
ARM: 7883/1: fix mov to mvn conversion in case of 64 bit phys_addr_t and BE
ARM: 7882/1: mm: fix __phys_to_virt to work with 64 bit phys_addr_t in BE case
ARM: 7881/1: __fixup_smp read of SCU config should do byteswap in BE case
ARM: Fix nommu.c build warning
Pull KVM fixes from Gleb Natapov.
* 'next' of git://git.kernel.org/pub/scm/virt/kvm/kvm:
KVM: kvm_clear_guest_page(): fix empty_zero_page usage
kvm: mmu: delay mmu audit activation
arm/arm64: KVM: Fix hyp mappings of vmalloc regions
Pull aio fixes from Benjamin LaHaise.
* git://git.kvack.org/~bcrl/aio-next:
aio: nullify aio->ring_pages after freeing it
aio: prevent double free in ioctx_alloc
aio: Fix a trinity splat
Pull nfsd bugfixes from Bruce Fields:
"A couple nfsd bugfixes"
* 'for-3.13' of git://linux-nfs.org/~bfields/linux:
nfsd4: fix xdr decoding of large non-write compounds
nfsd: make sure to balance get/put_write_access
nfsd: split up nfsd_setattr
git://git.kernel.org/pub/scm/linux/kernel/git/steve/gfs2-3.0-fixes
Pull GFS2 fixes from Steven Whitehouse:
"A couple of small, but important bug fixes for GFS2. The first one
fixes a possible NULL pointer dereference, and the second one resolves
a reference counting issue in one of the lesser used paths through
atomic_open"
* tag 'gfs2-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/steve/gfs2-3.0-fixes:
GFS2: Fix ref count bug relating to atomic_open
GFS2: fix potential NULL pointer dereference
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs
Pull btrfs fixes from Chris Mason:
"Almost all of these are bug fixes. Dave Sterba's documentation update
is the big exception because he removed our promises to set any
machine running Btrfs on fire"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs:
Documentation: filesystems: update btrfs tools section
Documentation: filesystems: add new btrfs mount options
btrfs: update kconfig help text
btrfs: fix bio_size_ok() for max_sectors > 0xffff
btrfs: Use trace condition for get_extent tracepoint
btrfs: fix typo in the log message
Btrfs: fix list delete warning when removing ordered root from the list
Btrfs: print bytenr instead of page pointer in check-int
Btrfs: remove dead codes from ctree.h
Btrfs: don't wait for ordered data outside desired range
Btrfs: fix lockdep error in async commit
Btrfs: avoid heavy operations in btrfs_commit_super
Btrfs: fix __btrfs_start_workers retval
Btrfs: disable online raid-repair on ro mounts
Btrfs: do not inc uncorrectable_errors counter on ro scrubs
Btrfs: only drop modified extents if we logged the whole inode
Btrfs: make sure to copy everything if we rename
Btrfs: don't BUG_ON() if we get an error walking backrefs
Pull second xfs update from Ben Myers:
"There are a couple of patches that I wasn't quite sure about in time
for our initial 3.13 pull request, a bugfix, and an update to add Dave
to MAINTAINERS:
Here we have a performance fix for inode iversion, increased inode
cluster size for v5 superblock filesystems, a fix for error handling
in xfs_bmap_add_attrfork, and a MAINTAINERS update to add Dave"
* tag 'xfs-for-linus-v3.13-rc1-2' of git://oss.sgi.com/xfs/xfs:
xfs: open code inc_inode_iversion when logging an inode
xfs: increase inode cluster size for v5 filesystems
xfs: fix unlock in xfs_bmap_add_attrfork
xfs: update maintainers
git://git.kernel.org/pub/scm/linux/kernel/git/penberg/linux
Pull SLAB changes from Pekka Enberg:
"The patches from Joonsoo Kim switch mm/slab.c to use 'struct page' for
slab internals similar to mm/slub.c. This reduces memory usage and
improves performance:
https://lkml.org/lkml/2013/10/16/155
Rest of the changes are bug fixes from various people"
* 'slab/next' of git://git.kernel.org/pub/scm/linux/kernel/git/penberg/linux: (21 commits)
mm, slub: fix the typo in mm/slub.c
mm, slub: fix the typo in include/linux/slub_def.h
slub: Handle NULL parameter in kmem_cache_flags
slab: replace non-existing 'struct freelist *' with 'void *'
slab: fix to calm down kmemleak warning
slub: proper kmemleak tracking if CONFIG_SLUB_DEBUG disabled
slab: rename slab_bufctl to slab_freelist
slab: remove useless statement for checking pfmemalloc
slab: use struct page for slab management
slab: replace free and inuse in struct slab with newly introduced active
slab: remove SLAB_LIMIT
slab: remove kmem_bufctl_t
slab: change the management method of free objects of the slab
slab: use __GFP_COMP flag for allocating slab pages
slab: use well-defined macro, virt_to_slab()
slab: overloading the RCU head over the LRU for RCU free
slab: remove cachep in struct slab_rcu
slab: remove nodeid in struct slab
slab: remove colouroff in struct slab
slab: change return type of kmem_getpages() to struct page
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc
Pull third set of powerpc updates from Benjamin Herrenschmidt:
"This is a small collection of random bug fixes and a few improvements
of Oops output which I deemed valuable enough to include as well.
The fixes are essentially recent build breakage and regressions, and a
couple of older bugs such as the DTL log duplication, the EEH issue
with PCI_COMMAND_MASTER and the problem with small contexts passed to
get/set_context with VSX enabled"
* 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc:
powerpc/signals: Mark VSX not saved with small contexts
powerpc/pseries: Fix SMP=n build of rng.c
powerpc: Make cpu_to_chip_id() available when SMP=n
powerpc/vio: Fix a dma_mask issue of vio
powerpc: booke: Fix build failures
powerpc: ppc64 address space capped at 32TB, mmap randomisation disabled
powerpc: Only print PACATMSCRATCH in oops when TM is active
powerpc/pseries: Duplicate dtl entries sometimes sent to userspace
powerpc: Remove a few lines of oops output
powerpc: Print DAR and DSISR on machine check oopses
powerpc: Fix __get_user_pages_fast() irq handling
powerpc/eeh: More accurate log
powerpc/eeh: Enable PCI_COMMAND_MASTER for PCI bridges
current_headset_type should be of the HEADSET_TYPE enum, not the
HEADSET_MODE enum. Since ALC_HEADSET_TYPE_UNKNOWN and ALC_HEADSET_MODE_UNKNOWN
are both 0, this patch is just janitorial.
Signed-off-by: David Henningsson <david.henningsson@canonical.com>
Some models (or maybe depending on BIOS version) of Sony VAIO with
ALC260 give no proper pin configurations as default, resulting in the
non-working speaker, etc. Just provide the whole pin configurations
via a fixup.
Reported-by: Matthew Markus <mmarkus@hearit.co>
Cc: <stable@vger.kernel.org>
Merge patches from Andrew Morton:
"13 fixes"
* emailed patches from Andrew Morton <akpm@linux-foundation.org>:
mm: place page->pmd_huge_pte to right union
MAINTAINERS: add keyboard driver to Hyper-V file list
x86, mm: do not leak page->ptl for pmd page tables
ipc,shm: correct error return value in shmctl (SHM_UNLOCK)
mm, mempolicy: silence gcc warning
block/partitions/efi.c: fix bound check
ARM: drivers/rtc/rtc-at91rm9200.c: disable interrupts at shutdown
mm: hugetlbfs: fix hugetlbfs optimization
kernel: remove CONFIG_USE_GENERIC_SMP_HELPERS cleanly
ipc,shm: fix shm_file deletion races
mm: thp: give transparent hugepage code a separate copy_page
checkpatch: fix "Use of uninitialized value" warnings
configfs: fix race between dentry put and lookup
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security
Pull security subsystem updates from James Morris:
"In this patchset, we finally get an SELinux update, with Paul Moore
taking over as maintainer of that code.
Also a significant update for the Keys subsystem, as well as
maintenance updates to Smack, IMA, TPM, and Apparmor"
and since I wanted to know more about the updates to key handling,
here's the explanation from David Howells on that:
"Okay. There are a number of separate bits. I'll go over the big bits
and the odd important other bit, most of the smaller bits are just
fixes and cleanups. If you want the small bits accounting for, I can
do that too.
(1) Keyring capacity expansion.
KEYS: Consolidate the concept of an 'index key' for key access
KEYS: Introduce a search context structure
KEYS: Search for auth-key by name rather than target key ID
Add a generic associative array implementation.
KEYS: Expand the capacity of a keyring
Several of the patches are providing an expansion of the capacity of a
keyring. Currently, the maximum size of a keyring payload is one page.
Subtract a small header and then divide up into pointers, that only gives
you ~500 pointers on an x86_64 box. However, since the NFS idmapper uses
a keyring to store ID mapping data, that has proven to be insufficient to
the cause.
Whatever data structure I use to handle the keyring payload, it can only
store pointers to keys, not the keys themselves because several keyrings
may point to a single key. This precludes inserting, say, and rb_node
struct into the key struct for this purpose.
I could make an rbtree of records such that each record has an rb_node
and a key pointer, but that would use four words of space per key stored
in the keyring. It would, however, be able to use much existing code.
I selected instead a non-rebalancing radix-tree type approach as that
could have a better space-used/key-pointer ratio. I could have used the
radix tree implementation that we already have and insert keys into it by
their serial numbers, but that means any sort of search must iterate over
the whole radix tree. Further, its nodes are a bit on the capacious side
for what I want - especially given that key serial numbers are randomly
allocated, thus leaving a lot of empty space in the tree.
So what I have is an associative array that internally is a radix-tree
with 16 pointers per node where the index key is constructed from the key
type pointer and the key description. This means that an exact lookup by
type+description is very fast as this tells us how to navigate directly to
the target key.
I made the data structure general in lib/assoc_array.c as far as it is
concerned, its index key is just a sequence of bits that leads to a
pointer. It's possible that someone else will be able to make use of it
also. FS-Cache might, for example.
(2) Mark keys as 'trusted' and keyrings as 'trusted only'.
KEYS: verify a certificate is signed by a 'trusted' key
KEYS: Make the system 'trusted' keyring viewable by userspace
KEYS: Add a 'trusted' flag and a 'trusted only' flag
KEYS: Separate the kernel signature checking keyring from module signing
These patches allow keys carrying asymmetric public keys to be marked as
being 'trusted' and allow keyrings to be marked as only permitting the
addition or linkage of trusted keys.
Keys loaded from hardware during kernel boot or compiled into the kernel
during build are marked as being trusted automatically. New keys can be
loaded at runtime with add_key(). They are checked against the system
keyring contents and if their signatures can be validated with keys that
are already marked trusted, then they are marked trusted also and can
thus be added into the master keyring.
Patches from Mimi Zohar make this usable with the IMA keyrings also.
(3) Remove the date checks on the key used to validate a module signature.
X.509: Remove certificate date checks
It's not reasonable to reject a signature just because the key that it was
generated with is no longer valid datewise - especially if the kernel
hasn't yet managed to set the system clock when the first module is
loaded - so just remove those checks.
(4) Make it simpler to deal with additional X.509 being loaded into the kernel.
KEYS: Load *.x509 files into kernel keyring
KEYS: Have make canonicalise the paths of the X.509 certs better to deduplicate
The builder of the kernel now just places files with the extension ".x509"
into the kernel source or build trees and they're concatenated by the
kernel build and stuffed into the appropriate section.
(5) Add support for userspace kerberos to use keyrings.
KEYS: Add per-user_namespace registers for persistent per-UID kerberos caches
KEYS: Implement a big key type that can save to tmpfs
Fedora went to, by default, storing kerberos tickets and tokens in tmpfs.
We looked at storing it in keyrings instead as that confers certain
advantages such as tickets being automatically deleted after a certain
amount of time and the ability for the kernel to get at these tokens more
easily.
To make this work, two things were needed:
(a) A way for the tickets to persist beyond the lifetime of all a user's
sessions so that cron-driven processes can still use them.
The problem is that a user's session keyrings are deleted when the
session that spawned them logs out and the user's user keyring is
deleted when the UID is deleted (typically when the last log out
happens), so neither of these places is suitable.
I've added a system keyring into which a 'persistent' keyring is
created for each UID on request. Each time a user requests their
persistent keyring, the expiry time on it is set anew. If the user
doesn't ask for it for, say, three days, the keyring is automatically
expired and garbage collected using the existing gc. All the kerberos
tokens it held are then also gc'd.
(b) A key type that can hold really big tickets (up to 1MB in size).
The problem is that Active Directory can return huge tickets with lots
of auxiliary data attached. We don't, however, want to eat up huge
tracts of unswappable kernel space for this, so if the ticket is
greater than a certain size, we create a swappable shmem file and dump
the contents in there and just live with the fact we then have an
inode and a dentry overhead. If the ticket is smaller than that, we
slap it in a kmalloc()'d buffer"
* 'for-linus2' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (121 commits)
KEYS: Fix keyring content gc scanner
KEYS: Fix error handling in big_key instantiation
KEYS: Fix UID check in keyctl_get_persistent()
KEYS: The RSA public key algorithm needs to select MPILIB
ima: define '_ima' as a builtin 'trusted' keyring
ima: extend the measurement list to include the file signature
kernel/system_certificate.S: use real contents instead of macro GLOBAL()
KEYS: fix error return code in big_key_instantiate()
KEYS: Fix keyring quota misaccounting on key replacement and unlink
KEYS: Fix a race between negating a key and reading the error set
KEYS: Make BIG_KEYS boolean
apparmor: remove the "task" arg from may_change_ptraced_domain()
apparmor: remove parent task info from audit logging
apparmor: remove tsk field from the apparmor_audit_struct
apparmor: fix capability to not use the current task, during reporting
Smack: Ptrace access check mode
ima: provide hash algo info in the xattr
ima: enable support for larger default filedata hash algorithms
ima: define kernel parameter 'ima_template=' to change configured default
ima: add Kconfig default measurement list template
Pull audit updates from Eric Paris:
"Nothing amazing. Formatting, small bug fixes, couple of fixes where
we didn't get records due to some old VFS changes, and a change to how
we collect execve info..."
Fixed conflict in fs/exec.c as per Eric and linux-next.
* git://git.infradead.org/users/eparis/audit: (28 commits)
audit: fix type of sessionid in audit_set_loginuid()
audit: call audit_bprm() only once to add AUDIT_EXECVE information
audit: move audit_aux_data_execve contents into audit_context union
audit: remove unused envc member of audit_aux_data_execve
audit: Kill the unused struct audit_aux_data_capset
audit: do not reject all AUDIT_INODE filter types
audit: suppress stock memalloc failure warnings since already managed
audit: log the audit_names record type
audit: add child record before the create to handle case where create fails
audit: use given values in tty_audit enable api
audit: use nlmsg_len() to get message payload length
audit: use memset instead of trying to initialize field by field
audit: fix info leak in AUDIT_GET requests
audit: update AUDIT_INODE filter rule to comparator function
audit: audit feature to set loginuid immutable
audit: audit feature to only allow unsetting the loginuid
audit: allow unsetting the loginuid (with priv)
audit: remove CONFIG_AUDIT_LOGINUID_IMMUTABLE
audit: loginuid functions coding style
selinux: apply selinux checks on new audit message types
I don't know what went wrong, mis-merge or something, but ->pmd_huge_pte
placed in wrong union within struct page.
In original patch[1] it's placed to union with ->lru and ->slab, but in
commit e009bb30c8df ("mm: implement split page table lock for PMD
level") it's in union with ->index and ->freelist.
That union seems also unused for pages with table tables and safe to
re-use, but it's not what I've tested.
Let's move it to original place. It fixes indentation at least. :)
[1] https://lkml.org/lkml/2013/10/7/288
Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Signed-off-by: Haiyang Zhang <haiyangz@microsoft.com>
Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Cc: "K. Y. Srinivasan" <kys@microsoft.com>
There are two code paths how page with pmd page table can be freed:
pmd_free() and pmd_free_tlb().
I've missed the second one and didn't add page table destructor call
there. It leads to leak of page->ptl for pmd page tables, if
dynamically allocated page->ptl is in use.
The patch adds the missed destructor and modifies documentation
accordingly.
Reported-by: Andrey Vagin <avagin@openvz.org>
Tested-by: Andrey Vagin <avagin@openvz.org>
Commit 2caacaa82a51 ("ipc,shm: shorten critical region for shmctl")
restructured the ipc shm to shorten critical region, but introduced a
path where the return value could be -EPERM, even if the operation
actually was performed.
Before the commit, the err return value was reset by the return value
from security_shm_shmctl() after the if (!ns_capable(...)) statement.
Now, we still exit the if statement with err set to -EPERM, and in the
case of SHM_UNLOCK, it is not reset at all, and used as the return value
from shmctl.
To fix this, we only set err when errors occur, leaving the fallthrough
case alone.
Signed-off-by: Jesper Nilsson <jesper.nilsson@axis.com>
Cc: Davidlohr Bueso <davidlohr@hp.com>
Cc: Michel Lespinasse <walken@google.com>
Cc: <stable@vger.kernel.org> [3.12.x]
Fengguang Wu reports that compiling mm/mempolicy.c results in a warning:
mm/mempolicy.c: In function 'mpol_to_str':
mm/mempolicy.c:2878:2: error: format not a string literal and no format arguments
Kees says this is because he is using -Wformat-security.
Silence the warning.
Signed-off-by: David Rientjes <rientjes@google.com>
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
Suggested-by: Kees Cook <keescook@chromium.org>
Use ARRAY_SIZE instead of sizeof to get proper max for label length.
Since this is just a read out of bounds it's not that bad, but the
problem becomes user-visible eg if one tries to use DEBUG_PAGEALLOC and
DEBUG_RODATA, at least with some enhancements from Hiroshi. Of course
the destination array can contain garbage when we read beyond the end of
source array so that would be another user-visible problem.
Signed-off-by: Antti P Miettinen <amiettinen@nvidia.com>
Reviewed-by: Hiroshi Doyu <hdoyu@nvidia.com>
Tested-by: Hiroshi Doyu <hdoyu@nvidia.com>
Cc: Will Drewry <wad@chromium.org>
Cc: Matt Fleming <matt.fleming@intel.com>
Acked-by: Davidlohr Bueso <davidlohr@hp.com>
Make sure RTC-interrupts are disabled at shutdown.
As the RTC is generally powered by backup power (VDDBU), its interrupts
are not disabled on wake-up, user, watchdog or software reset. This
could cause troubles on other systems (e.g. older kernels) if an
interrupt occurs before a handler has been installed at next boot.
Let us be well-behaved and disable them on clean shutdowns at least (as
do the RTT-based rtc-at91sam9 driver).
Signed-off-by: Johan Hovold <jhovold@gmail.com>
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Cc: Jean-Christophe Plagniol-Villard <plagnioj@jcrosoft.com>
Cc: Andrew Victor <linux@maxim.org.za>
Cc: Alessandro Zummo <a.zummo@towertech.it>
Commit 7cb2ef56e6a8 ("mm: fix aio performance regression for database
caused by THP") can cause dereference of a dangling pointer if
split_huge_page runs during PageHuge() if there are updates to the
tail_page->private field.
Also it is repeating compound_head twice for hugetlbfs and it is running
compound_head+compound_trans_head for THP when a single one is needed in
both cases.
The new code within the PageSlab() check doesn't need to verify that the
THP page size is never bigger than the smallest hugetlbfs page size, to
avoid memory corruption.
A longstanding theoretical race condition was found while fixing the
above (see the change right after the skip_unlock label, that is
relevant for the compound_lock path too).
By re-establishing the _mapcount tail refcounting for all compound
pages, this also fixes the below problem:
echo 0 >/sys/kernel/mm/hugepages/hugepages-2048kB/nr_hugepages
BUG: Bad page state in process bash pfn:59a01
page:ffffea000139b038 count:0 mapcount:10 mapping: (null) index:0x0
page flags: 0x1c00000000008000(tail)
Modules linked in:
CPU: 6 PID: 2018 Comm: bash Not tainted 3.12.0+ #25
Hardware name: Bochs Bochs, BIOS Bochs 01/01/2011
Call Trace:
dump_stack+0x55/0x76
bad_page+0xd5/0x130
free_pages_prepare+0x213/0x280
__free_pages+0x36/0x80
update_and_free_page+0xc1/0xd0
free_pool_huge_page+0xc2/0xe0
set_max_huge_pages.part.58+0x14c/0x220
nr_hugepages_store_common.isra.60+0xd0/0xf0
nr_hugepages_store+0x13/0x20
kobj_attr_store+0xf/0x20
sysfs_write_file+0x189/0x1e0
vfs_write+0xc5/0x1f0
SyS_write+0x55/0xb0
system_call_fastpath+0x16/0x1b
Signed-off-by: Khalid Aziz <khalid.aziz@oracle.com>
Signed-off-by: Andrea Arcangeli <aarcange@redhat.com>
Tested-by: Khalid Aziz <khalid.aziz@oracle.com>
Cc: Pravin Shelar <pshelar@nicira.com>
Cc: Ben Hutchings <bhutchings@solarflare.com>
Cc: Christoph Lameter <cl@linux.com>
Cc: Johannes Weiner <jweiner@redhat.com>
Cc: Minchan Kim <minchan@kernel.org>
Remove CONFIG_USE_GENERIC_SMP_HELPERS left by commit 0a06ff068f12
("kernel: remove CONFIG_USE_GENERIC_SMP_HELPERS").
Signed-off-by: Yuanhan Liu <yuanhan.liu@linux.intel.com>
When IPC_RMID races with other shm operations there's potential for
use-after-free of the shm object's associated file (shm_file).
Here's the race before this patch:
TASK 1 TASK 2
shm_rmid()
ipc_lock_object()
shmctl()
shp = shm_obtain_object_check()
shm_destroy()
shum_unlock()
fput(shp->shm_file)
ipc_lock_object()
shmem_lock(shp->shm_file)
<OOPS>
The oops is caused because shm_destroy() calls fput() after dropping the
ipc_lock. fput() clears the file's f_inode, f_path.dentry, and
f_path.mnt, which causes various NULL pointer references in task 2. I
reliably see the oops in task 2 if with shmlock, shmu
This patch fixes the races by:
1) set shm_file=NULL in shm_destroy() while holding ipc_object_lock().
2) modify at risk operations to check shm_file while holding
ipc_object_lock().
Example workloads, which each trigger oops...
Workload 1:
while true; do
id=$(shmget 1 4096)
shm_rmid $id &
shmlock $id &
wait
done
The oops stack shows accessing NULL f_inode due to racing fput:
_raw_spin_lock
shmem_lock
SyS_shmctl
Workload 2:
while true; do
id=$(shmget 1 4096)
shmat $id 4096 &
shm_rmid $id &
wait
done
The oops stack is similar to workload 1 due to NULL f_inode:
touch_atime
shmem_mmap
shm_mmap
mmap_region
do_mmap_pgoff
do_shmat
SyS_shmat
Workload 3:
while true; do
id=$(shmget 1 4096)
shmlock $id
shm_rmid $id &
shmunlock $id &
wait
done
The oops stack shows second fput tripping on an NULL f_inode. The
first fput() completed via from shm_destroy(), but a racing thread did
a get_file() and queued this fput():
locks_remove_flock
__fput
____fput
task_work_run
do_notify_resume
int_signal
Fixes: c2c737a0461e ("ipc,shm: shorten critical region for shmat")
Fixes: 2caacaa82a51 ("ipc,shm: shorten critical region for shmctl")
Signed-off-by: Greg Thelen <gthelen@google.com>
Cc: Manfred Spraul <manfred@colorfullife.com>
Cc: <stable@vger.kernel.org> # 3.10.17+ 3.11.6+
Right now, the migration code in migrate_page_copy() uses copy_huge_page()
for hugetlbfs and thp pages:
if (PageHuge(page) || PageTransHuge(page))
copy_huge_page(newpage, page);
So, yay for code reuse. But:
void copy_huge_page(struct page *dst, struct page *src)
struct hstate *h = page_hstate(src);
and a non-hugetlbfs page has no page_hstate(). This works 99% of the
time because page_hstate() determines the hstate from the page order
alone. Since the page order of a THP page matches the default hugetlbfs
page order, it works.
But, if you change the default huge page size on the boot command-line
(say default_hugepagesz=1G), then we might not even *have* a 2MB hstate
so page_hstate() returns null and copy_huge_page() oopses pretty fast
since copy_huge_page() dereferences the hstate:
if (unlikely(pages_per_huge_page(h) > MAX_ORDER_NR_PAGES)) {
Mel noticed that the migration code is really the only user of these
functions. This moves all the copy code over to migrate.c and makes
copy_huge_page() work for THP by checking for it explicitly.
I believe the bug was introduced in commit b32967ff101a ("mm: numa: Add
THP migration for the NUMA working set scanning fault case")
[akpm@linux-foundation.org: fix coding-style and comment text, per Naoya Horiguchi]
Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com>
Cc: Hillf Danton <dhillf@gmail.com>
Tested-by: Dave Jiang <dave.jiang@intel.com>
checkpatch is currently confused about some complex macros and references
undefined variables $stat and $cond.
Make sure these are defined before using them.
Reported-by: Gerhard Sittig <gsi@denx.de>
Acked-by: Andy Whitcroft <apw@canonical.com>
A race window in configfs, it starts from one dentry is UNHASHED and end
before configfs_d_iput is called. In this window, if a lookup happen,
since the original dentry was UNHASHED, so a new dentry will be
allocated, and then in configfs_attach_attr(), sd->s_dentry will be
updated to the new dentry. Then in configfs_d_iput(),
BUG_ON(sd->s_dentry != dentry) will be triggered and system panic.
sys_open: sys_close:
... fput
dput
dentry_kill
__d_drop <--- dentry unhashed here,
but sd->dentry still point
to this dentry.
lookup_real
configfs_lookup
configfs_attach_attr---> update sd->s_dentry
to new allocated dentry here.
d_kill
configfs_d_iput <--- BUG_ON(sd->s_dentry != dentry)
triggered here.
To fix it, change configfs_d_iput to not update sd->s_dentry if
sd->s_count > 2, that means there are another dentry is using the sd
beside the one that is going to be put. Use configfs_dirent_lock in
configfs_attach_attr to sync with configfs_d_iput.
With the following steps, you can reproduce the bug.
1. enable ocfs2, this will mount configfs at /sys/kernel/config and
fill configure in it.
2. run the following script.
while [ 1 ]; do cat /sys/kernel/config/cluster/$your_cluster_name/idle_timeout_ms > /dev/null; done &
Signed-off-by: Junxiao Bi <junxiao.bi@oracle.com>
Recently GRO started generating packets with frag_lists of frags.
This was not handled by GSO, thus leading to a crash.
Thankfully these packets are of a regular form and are easy to
handle. This patch handles them in two ways. For completely
non-linear frag_list entries, we simply continue to iterate over
the frag_list frags once we exhaust the normal frags. For frag_list
entries with linear parts, we call pskb_trim on the first part
of the frag_list skb, and then process the rest of the frags in
the usual way.
This patch also kills a chunk of dead frag_list code that has
obviously never ever been run since it ends up generating a bogus
GSO-segmented packet with a frag_list entry.
Future work is planned to split super big packets into TSO
ones.
Fixes: 8a29111c7ca6 ("net: gro: allow to build full sized skb")
Reported-by: Christoph Paasch <christoph.paasch@uclouvain.be>
Reported-by: Jerry Chu <hkchu@google.com>
Reported-by: Sander Eikelenboom <linux@eikelenboom.it>
Tested-by: Sander Eikelenboom <linux@eikelenboom.it>
Tested-by: Eric Dumazet <edumazet@google.com>
In the case that atomic_open calls finish_no_open() with
the dentry that was supplied to gfs2_atomic_open() an
extra reference count is required. This patch fixes that
issue preventing a bug trap triggering at umount time.
Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
Fix another really stupid bug - I introduced genl_set_err()
precisely to be able to adjust the group and reject invalid
ones, but then forgot to do so.
Unfortunately, I introduced a tremendously stupid bug into
genlmsg_multicast() when doing all those multicast group
changes: it adjusts the group number, but then passes it
to genlmsg_multicast_netns() which does that again.
Somehow, my tests failed to catch this, so add a warning
into genlmsg_multicast_netns() and remove the offending
group ID adjustment.
Also add a warning to the similar code in other functions
so people who misuse them are more loudly warned.
Salam reported a use after free bug in PF_PACKET that occurs when
we're sending out frames on a socket bound device and suddenly the
net device is being unregistered. It appears that commit 827d9780
introduced a possible race condition between {t,}packet_snd() and
packet_notifier(). In the case of a bound socket, packet_notifier()
can drop the last reference to the net_device and {t,}packet_snd()
might end up suddenly sending a packet over a freed net_device.
To avoid reverting 827d9780 and thus introducing a performance
regression compared to the current state of things, we decided to
hold a cached RCU protected pointer to the net device and maintain
it on write side via bind spin_lock protected register_prot_hook()
and __unregister_prot_hook() calls.
In {t,}packet_snd() path, we access this pointer under rcu_read_lock
through packet_cached_dev_get() that holds reference to the device
to prevent it from being freed through packet_notifier() while
we're in send path. This is okay to do as dev_put()/dev_hold() are
per-cpu counters, so this should not be a performance issue. Also,
the code simplifies a bit as we don't need need_rls_dev anymore.
Fixes: 827d978037d7 ("af-packet: Use existing netdev reference for bound sockets.")
Reported-by: Salam Noureddine <noureddine@aristanetworks.com>
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
Signed-off-by: Salam Noureddine <noureddine@aristanetworks.com>
Cc: Ben Greear <greearb@candelatech.com>
If the VIF thread is still running after unbinding the Tx and Rx IRQs
in xenvif_disconnect(), the thread may attempt to raise an event which
will BUG (as the irq is unbound).
Signed-off-by: David Vrabel <david.vrabel@citrix.com>
Acked-by: Wei Liu <wei.liu2@citrix.com>
This removes a code line that is between a "return 0;" and an error label.
This code line can never be reached.
Found by Coverity (CID: 1130529)
Signed-off-by: Michael Opdenacker <michael.opdenacker@free-electrons.com>
Acked-by: Johannes Berg <johannes@sipsolutions.net>
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless
John W. Linville says:
pull request: wireless 2013-11-21
Please pull this batch of fixes intended for the 3.13 stream!
For the Bluetooth bits, Gustavo says:
"A few fixes for 3.13. There is 3 fixes to the RFCOMM protocol. One
crash fix to L2CAP. A simple fix to a bad behaviour in the SMP
protocol."
On top of that...
Amitkumar Karwar sends a quintet of mwifiex fixes -- two fixes related
to failure handling, two memory leak fixes, and a NULL pointer fix.
Felix Fietkau corrects and earlier rt2x00 HT descriptor handling fix
to address a crash.
Geyslan G. Bem fixes a memory leak in brcmfmac.
Larry Finger address more pointer arithmetic errors in rtlwifi.
Luis R. Rodriguez provides a regulatory fix in the shared ath code.
Sujith Manoharan brings a couple ath9k initialization fixes.
Ujjal Roy offers one more mwifiex fix to avoid invalid memory accesses
when unloading the USB driver.
Pablo Neira Ayuso says:
netfilter fixes for net
The following patchset contains fixes for your net tree, they are:
* Remove extra quote from connlimit configuration in Kconfig, from
Randy Dunlap.
* Fix missing mss option in syn packets sent to the backend in our
new synproxy target, from Martin Topholm.
* Use window scale announced by client when sending the forged
syn to the backend, from Martin Topholm.
* Fix IPv6 address comparison in ebtables, from Luís Fernando
Cornachioni Estrozi.
* Fix wrong endianess in sequence adjustment which breaks helpers
in NAT configurations, from Phil Oester.
* Fix the error path handling of nft_compat, from me.
* Make sure the global conntrack counter is decremented after the
object has been released, also from me.
The tools mentioned have been obsoleted long ago, replace
with the current ones.
CC: linux-doc@vger.kernel.org
Signed-off-by: David Sterba <dsterba@suse.cz>
Signed-off-by: Chris Mason <chris.mason@fusionio.com>
Two new options were added in 3.12: commit and rescan_uuid_tree
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless into for-davem
