2012-03-28Merge branch 'kvm-updates/3.4' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull kvm updates from Avi Kivity: "Changes include timekeeping improvements, support for assigning host PCI devices that share interrupt lines, s390 user-controlled guests, a large ppc update, and random fixes." This is with the sign-off's fixed, hopefully next merge window we won't have rebased commits. * 'kvm-updates/3.4' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (130 commits) KVM: Convert intx_mask_lock to spin lock KVM: x86: fix kvm_write_tsc() TSC matching thinko x86: kvmclock: abstract save/restore sched_clock_state KVM: nVMX: Fix erroneous exception bitmap check KVM: Ignore the writes to MSR_K7_HWCR(3) KVM: MMU: make use of ->root_level in reset_rsvds_bits_mask KVM: PMU: add proper support for fixed counter 2 KVM: PMU: Fix raw event check KVM: PMU: warn when pin control is set in eventsel msr KVM: VMX: Fix delayed load of shared MSRs KVM: use correct tlbs dirty type in cmpxchg KVM: Allow host IRQ sharing for assigned PCI 2.3 devices KVM: Ensure all vcpus are consistent with in-kernel irqchip settings KVM: x86 emulator: Allow PM/VM86 switch during task switch KVM: SVM: Fix CPL updates KVM: x86 emulator: VM86 segments must have DPL 3 KVM: x86 emulator: Fix task switch privilege checks arch/powerpc/kvm/book3s_hv.c: included linux/sched.h twice KVM: x86 emulator: correctly mask pmc index bits in RDPMC instruction emulation KVM: mmu_notifier: Flush TLBs before releasing mmu_lock ...
2012-03-28Merge git://github.com/rustyrussell/linuxLinus Torvalds
Pull module and param updates from Rusty Russell: "I'm getting married next week, and then honeymoon until 6th May. I'll be offline from next week, except to post the compulsory pictures if Alex shaves her head..." I'm sure Rusty can take time off from his honeymoon if something comes up. And here's the explanation about head shaving: http://baldalex.org/ in case you wondered and wanted to support another insane caper or Rusty's involving shaving. What *is* it with Rusty and shaving, anyway? * git://github.com/rustyrussell/linux: module: Remove module size limit module: move __module_get and try_module_get() out of line. params: <level>_initcall-like kernel parameters module_param: remove support for bool parameters which are really int. module: add kernel param to force disable module load
2012-03-28Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security Pull an Apparmor bugfix from James Morris. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: apparmor: Fix change_onexec when called from a confined task
2012-03-28Merge branch 'linux_next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-edac Pull EDAC fixes from Mauro Carvalho Chehab: "A series of EDAC driver fixes. It also has one core fix at the documentation, and a rename patch, fixing the name of the struct that contains the rank information." * 'linux_next' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-edac: edac: rename channel_info to rank_info i5400_edac: Avoid calling pci_put_device() twice edac: i5100 ack error detection register after each read edac: i5100 fix erroneous define for M1Err edac: sb_edac: Fix a wrong value setting for the previous value edac: sb_edac: Fix a INTERLEAVE_MODE() misuse edac: sb_edac: Let the driver depend on PCI_MMCONFIG edac: Improve the comments to better describe the memory concepts edac/ppc4xx_edac: Fix compilation Fix sb_edac compilation with 32 bits kernels
2012-03-28Merge branch 'for_linus' of git://cavan.codon.org.uk/platform-drivers-x86Linus Torvalds
Pull x86 platform driver updates from Matthew Garrett: "Some significant updates to samsung-laptop, additional hardware support for Toshibas, misc updates to various hardware and a new backlight driver for some Apple machines." Fix up trivial conflicts: geode Geos update happening next to net5501 support, and MSIC thermal platform support added twice. * 'for_linus' of git://cavan.codon.org.uk/platform-drivers-x86: (77 commits) acer-wmi: add quirk table for video backlight vendor mode drivers/platform/x86/amilo-rfkill.c::amilo_rfkill_probe() avoid NULL deref samsung-laptop: unregister ACPI video module for some well known laptops acer-wmi: No wifi rfkill on Sony machines thinkpad-acpi: recognize Lenovo as version string in newer V-series BIOS asus-wmi: don't update power and brightness when using scalar eeepc-wmi: split et2012 specific hacks eeepc-wmi: refine quirks handling asus-nb-wmi: set panel_power correctly asus-wmi: move WAPF variable into quirks_entry asus-wmi: store backlight power status for AIO machine asus-wmi: add scalar board brightness adj. support samsung-laptop: cleanup return type: mode_t vs umode_t drivers, samsung-laptop: fix usage of isalnum drivers, samsung-laptop: fix initialization of sabi_data in sabi_set_commandb asus-wmi: on/off bit is not set when reading the value eeepc-wmi: add extra keymaps for EP121 asus-nb-wmi: ignore useless keys acer-wmi: support Lenovo ideapad S205 Brazos wifi switch acer-wmi: fix out of input parameter size when set ...
2012-03-28Merge branch 'i2c-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging Pull i2c updates from Jean Delvare. Fix up trivial conflict in drivers/i2c/busses/i2c-gpio.c due to include file cleanup clashing with DT support addition (which did the same cleanup) * 'i2c-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging: i2c-algo-bit: Don't resched on clock stretching i2c: Update the FSF address i2c: Convert drivers/i2c/muxes/* to use module_i2c_driver() i2c-i801: Use usleep_range to wait for command completion i2c-i801: Add device IDs for Intel Lynx Point i2c-isch: Decrease delay in command completion check loop i2c-gpio: Use linux/gpio.h rather than asm/gpio.h
2012-03-28Merge tag 'gpio-for-linus' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
Pull GPIO changes for v3.4 from Grant Likely: "Primarily gpio device driver changes with some minor side effects under arch/arm and arch/x86. Also includes a few core changes such as explicitly supporting (electrical) open source and open drain outputs and some help for parsing gpio devicetree properties." Fix up context conflict due to Laxman Dewangan adding sleep control for the tps65910 driver separately for gpio's and regulators. * tag 'gpio-for-linus' of git://git.secretlab.ca/git/linux-2.6: (34 commits) gpio/ep93xx: Remove unused inline function and useless pr_err message gpio/sodaville: Mark broken due to core irqdomain migration gpio/omap: fix redundant decoding of gpio offset gpio/omap: fix incorrect update to context.irqenable1 gpio/omap: fix incorrect context restore logic in omap_gpio_runtime_* gpio/omap: fix missing dataout context save in _set_gpio_dataout_reg gpio/omap: fix _set_gpio_irqenable implementation gpio/omap: fix trigger type to unsigned gpio/omap: fix wakeup_en register update in _set_gpio_wakeup() gpio: tegra: tegra_gpio_config shouldn't be __init gpio/davinci: fix enabling unbanked GPIO IRQs gpio/davinci: fix oops on unbanked gpio irq request gpio/omap: Fix section warning for omap_mpuio_alloc_gc() ARM: tegra: export tegra_gpio_{en,dis}able gpio/gpio-stmpe: Fix the value returned by _get_value routine Documentation/gpio.txt: Explain expected pinctrl interaction GPIO: LPC32xx: Add output reading to GPO P3 GPIO: LPC32xx: Fix missing bit selection mask gpio/omap: fix wakeups on level-triggered GPIOs gpio/omap: Fix IRQ handling for SPARSE_IRQ ...
2012-03-28Merge tag 'mfd_3.4-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6 Pull MFD changes from Samuel Ortiz: - 4 new drivers: Freescale i.MX on-chip Anatop, Ricoh's RC5T583 and TI's TPS65090 and TPS65217. - New variants support (8420, 8520 ab9540), cleanups and bug fixes for the abx500 and db8500 ST-E chipsets. - Some minor fixes and update for the wm8994 from Mark. - The beginning of a long term TWL cleanup effort coming from the TI folks. - Various fixes and cleanups for the s5m, TPS659xx, pm860x, and MAX8997 drivers. Fix up trivial conflicts due to duplicate patches and header file cleanups (<linux/device.h> removal etc). * tag 'mfd_3.4-1' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6: (97 commits) gpio/twl: Add DT support to gpio-twl4030 driver gpio/twl: Allocate irq_desc dynamically for SPARSE_IRQ support mfd: Detach twl6040 from the pmic mfd driver mfd: Replace twl-* pr_ macros by the dev_ equivalent and do various cleanups mfd: Micro-optimization on twl4030 IRQ handler mfd: Make twl4030 SIH SPARSE_IRQ capable mfd: Move twl-core IRQ allocation into twl[4030|6030]-irq files mfd: Remove references already defineid in header file from twl-core mfd: Remove unneeded header from twl-core mfd: Make twl-core not depend on pdata->irq_base/end ARM: OMAP2+: board-omap4-*: Do not use anymore TWL6030_IRQ_BASE in board files mfd: Return twl6030_mmc_card_detect IRQ for board setup Revert "mfd: Add platform data for MAX8997 haptic driver" mfd: Add support for TPS65090 mfd: Add some da9052-i2c section annotations mfd: Build rtc5t583 only if I2C config is selected to y. mfd: Add anatop mfd driver mfd: Fix compilation error in tps65910.h mfd: Add 8420 variant to db8500-prcmu mfd: Add 8520 PRCMU variant to db8500-prcmu ...
2012-03-28Merge git://www.linux-watchdog.org/linux-watchdogLinus Torvalds
Pull watchdog updates from Wim Van Sebroeck: - Removal of the Documentation/watchdog/00-INDEX file - Fix boot status reporting for imx2_wdt - clean-up sp805_wdt, pnx4008_wdt and mpcore_wdt - convert printk in watchdog drivers to pr_ functions - change nowayout module parameter to bool for every watchdog device - conversion of jz4740_wdt, pnx4008_wdt, max63xx_wdt, softdog, ep93xx_wdt, coh901327 and txx9wdt to new watchdog API - Add support for the WDIOC_GETTIMELEFT ioctl call to the new watchdog API - Change the new watchdog API so that the driver updates the timeout value - two fixes for the xen_wdt driver Fix up conflicts in ep93xx driver due to the same patches being merged through separate branches. * git://www.linux-watchdog.org/linux-watchdog: (33 commits) watchdog: txx9wdt: fix timeout watchdog: Convert txx9wdt driver to watchdog framework watchdog: coh901327_wdt.c: fix timeout watchdog: coh901327: convert to use watchdog core watchdog: Add support for WDIOC_GETTIMELEFT IOCTL in watchdog core watchdog: ep93xx_wdt: timeout is an unsigned int value. watchdog: ep93xx_wdt: Fix timeout after conversion to watchdog core watchdog: Convert ep93xx driver to watchdog core watchdog: sp805: Use devm routines watchdog: sp805: replace readl/writel with lighter _relaxed variants watchdog: sp805: Fix documentation style comment watchdog: mpcore_wdt: Allow platform_get_irq() to fail watchdog: mpcore_wdt: Use devm routines watchdog: mpcore_wdt: Rename dev to pdev for pointing to struct platform_device watchdog: xen: don't clear is_active when xen_wdt_stop() failed watchdog: xen: don't unconditionally enable the watchdog during resume watchdog: fix compiler error for missing parenthesis watchdog: ep93xx_wdt.c: fix platform probe watchdog: ep93xx: Convert the watchdog driver into a platform device. watchdog: fix set_timeout operations ...
2012-03-28Merge tag 'dm-3.4-changes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/agk/linux-dm Pull device-mapper changes for 3.4 from Alasdair Kergon: - Update thin provisioning to support read-only external snapshot origins and discards. - A new target, dm verity, for device content validation. - Mark dm uevent and dm raid as no-longer-experimental. - Miscellaneous other fixes and clean-ups. * tag 'dm-3.4-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/agk/linux-dm: (27 commits) dm: add verity target dm bufio: prefetch dm thin: add pool target flags to control discard dm thin: support discards dm thin: prepare to support discard dm thin: use dm_target_offset dm thin: support read only external snapshot origins dm thin: relax hard limit on the maximum size of a metadata device dm persistent data: remove space map ref_count entries if redundant dm thin: commit outstanding data every second dm: reject trailing characters in sccanf input dm raid: handle failed devices during start up dm thin metadata: pass correct space map to dm_sm_root_size dm persistent data: remove redundant value_size arg from value_ptr dm mpath: detect invalid map_context dm: clear bi_end_io on remapping failure dm table: simplify call to free_devices dm thin: correct comments dm raid: no longer experimental dm uevent: no longer experimental ...
2012-03-28Merge branch 'drm-fixes' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull drm fixes from Dave Airlie: "gma500 build fix + some regression fixes for nouveau/radeon" * 'drm-fixes' of git://people.freedesktop.org/~airlied/linux: drm/radeon: Only warn if the intra-domain offset actually exceeds the limit. drm/radeon/kms: add htile support to the cs checker v3 drm/radeon/kms/atom: force bpc to 8 for now drm/nouveau/i2c: fix thinko/regression on really old chipsets drm/nouveau: default to 8bpc for non-LVDS panels if EDID isn't useful drm/nouveau: fix thinko causing init to fail on cards without accel gma500: medfield: fix build without CONFIG_BACKLIGHT_CLASS_DEVICE
2012-03-28Merge tag 'common-clk-api' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull "drivers/clk: common clock framework" from Olof Johansson: "This branch contains patches from Mike Turquette adding a common clock framework to be shared across platforms. This is part of the work towards building a common zImage for several ARM platforms." * tag 'common-clk-api' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: clk: make CONFIG_COMMON_CLK invisible clk: basic clock hardware types clk: introduce the common clock framework Documentation: common clk API
2012-03-28Merge tag 'dt2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull "ARM: More device tree support updates" from Olof Johansson: "This branch contains a number of updates for device tree support on several ARM platforms, in particular: * AT91 continues the device tree conversion adding support for a number of on-chip drivers and other functionality * ux500 adds probing of some of the core SoC blocks through device tree * Initial device tree support for ST SPEAr600 platforms * kirkwood continues the conversion to device-tree probing" Manually merge arch/arm/mach-ux500/Kconfig due to MACH_U8500 rename, and drivers/usb/gadget/at91_udc.c due to header file include cleanups. Also do an "evil merge" for the MACH_U8500 config option rename that the affected RMI4 touchscreen driver in staging. It's called MACH_MOP500 now, and it was missed during previous merges. * tag 'dt2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (48 commits) ARM: SPEAr600: Add device-tree support to SPEAr600 boards ARM: ux500: Provide local timer support for Device Tree ARM: ux500: Enable PL022 SSP Controller in Device Tree ARM: ux500: Enable PL310 Level 2 Cache Controller in Device Tree ARM: ux500: Enable PL011 AMBA UART Controller for Device Tree ARM: ux500: Enable Cortex-A9 GIC (Generic Interrupt Controller) in Device Tree ARM: ux500: db8500: list most devices in the snowball device tree ARM: ux500: split dts file for snowball into generic part ARM: ux500: combine the board init functions for DT boot ARM: ux500: Initial Device Tree support for Snowball ARM: ux500: CONFIG: Enable Device Tree support for future endeavours ARM: kirkwood: use devicetree for rtc-mv ARM: kirkwood: rtc-mv devicetree bindings ARM: kirkwood: fdt: define uart[01] as disabled, enable uart0 ARM: kirkwood: fdt: facilitate new boards during fdt migration ARM: kirkwood: fdt: absorb kirkwood_init() ARM: kirkwood: fdt: use mrvl ticker symbol ARM: orion: wdt: use resource vice direct access ARM: Kirkwood: Remove tclk from kirkwood_asoc_platform_data. ARM: orion: spi: remove enable_clock_fix which is not used ...
2012-03-28Merge tag 'soc2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull "ARM: More SoC support updates" from Olof Johansson: "This branch contains a handful of updates of SoC base code that had dependencies on other external trees that have now been merged: * Support for the new EXYNOS5250 SoC from Samsung * SMP and power domain support for Tegra3 from NVIDIA * ux500 updates for exporting SoC information through sysfs" Fix up trivial merge conflicts as per Olof. * tag 'soc2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (30 commits) ARM: mach-shmobile: ap4evb: Reserve DMA memory for the frame buffer ARM: EXYNOS: Fix compilation error with mach-exynos4-dt board ARM: dts: add initial dts file for EXYNOS5250, SMDK5250 ARM: EXYNOS: add support device tree enabled board file for EXYNOS5 ARM: EXYNOS: add support ARCH_EXYNOS5 for EXYNOS5 SoCs ARM: EXYNOS: add support get_core_count() for EXYNOS5250 ARM: EXYNOS: support EINT for EXYNOS4 and EXYNOS5 ARM: EXYNOS: add interrupt definitions for EXYNOS5250 ARM: EXYNOS: add support for EXYNOS5250 SoC ARM: EXYNOS: add support uart for EXYNOS4 and EXYNOS5 ARM: EXYNOS: add initial setup-i2c0 for EXYNOS5 ARM: EXYNOS: add clock part for EXYNOS5250 SoC ARM: EXYNOS: use exynos_init_uarts() instead of exynos4_init_uarts() ARM: EXYNOS: to declare static for mach-exynos/common.c ARM: EXYNOS: Add clkdev lookup entry for lcd clock ARM: dt: Explicitly configure all serial ports on Tegra Cardhu ARM: tegra: support for secondary cores on Tegra30 ARM: tegra: support for Tegra30 CPU powerdomains ARM: tegra: add support for Tegra30 powerdomains ARM: tegra: export tegra_powergate_is_powered() ...
2012-03-28Merge tag 'drivers2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull "ARM: More SoC driver updates" from Olof Johansson: "This branch contains a handful of driver updates, mostly to the LPC32xx platform but also for Samsung EXYNOS and Davinci. It had a few context conflicts against patches already merged through fixes-non-critical. We should have resolved this early during the development cycle by pulling them in as a dependency, instead I did it after the fact this time." * tag 'drivers2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: gpio/samsung: use ioremap() for EXYNOS4 GPIOlib gpio/samsung: add support GPIOlib for EXYNOS5250 ARM: EXYNOS: add support GPIO for EXYNOS5250 ARM: LPC32xx: Ethernet support ARM: LPC32xx: USB Support ARM: davinci: dm644x evm: add support for VPBE display ARM: davinci: dm644x: add support for v4l2 video display ARM: EXYNOS: Hook up JPEG PD to generic PD infrastructure ARM: EXYNOS: Hook up G2D PD to generic PD infrastructure arm: lpc32xx: phy3250: add rtc & touch device ARM: LPC32xx: clock.c: Clock registration fixes ARM: LPC32xx: clock.c: jiffies wrapping ARM: LPC32xx: clock.c: Missing header file ARM: LPC32XX: Remove broken non-static declaration ARM: LPC32xx: clock.c: Fix mutex lock issues ARM: LPC32xx: clock.c: warning fix ARM: LPC32xx: Added lpc32xx_defconfig
2012-03-28dm: add verity targetMikulas Patocka
This device-mapper target creates a read-only device that transparently validates the data on one underlying device against a pre-generated tree of cryptographic checksums stored on a second device. Two checksum device formats are supported: version 0 which is already shipping in Chromium OS and version 1 which incorporates some improvements. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Mandeep Singh Baines <msb@chromium.org> Signed-off-by: Will Drewry <wad@chromium.org> Signed-off-by: Elly Jones <ellyjones@chromium.org> Cc: Milan Broz <mbroz@redhat.com> Cc: Olof Johansson <olofj@chromium.org> Cc: Steffen Klassert <steffen.klassert@secunet.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2012-03-28dm bufio: prefetchMikulas Patocka
This patch introduces a new function dm_bufio_prefetch. It prefetches the specified range of blocks into dm-bufio cache without waiting for i/o completion. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2012-03-28dm thin: add pool target flags to control discardJoe Thornber
Add dm thin target arguments to control discard support. ignore_discard: Disables discard support no_discard_passdown: Don't pass discards down to the underlying data device, but just remove the mapping within the thin provisioning target. Signed-off-by: Joe Thornber <ejt@redhat.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2012-03-28dm thin: support discardsJoe Thornber
Support discards in the thin target. On discard the corresponding mapping(s) are removed from the thin device. If the associated block(s) are no longer shared the discard is passed to the underlying device. All bios other than discards now have an associated deferred_entry that is saved to the 'all_io_entry' in endio_hook. When non-discard IO completes and associated mappings are quiesced any discards that were deferred, via ds_add_work() in process_discard(), will be queued for processing by the worker thread. Signed-off-by: Joe Thornber <ejt@redhat.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com> drivers/md/dm-thin.c | 173 ++++++++++++++++++++++++++++++++++++++++++++++---- drivers/md/dm-thin.c | 172 ++++++++++++++++++++++++++++++++++++++++++++++----- 1 file changed, 158 insertions(+), 14 deletions(-)
2012-03-28dm thin: prepare to support discardJoe Thornber
This patch contains the ground work needed for dm-thin to support discard. - Adds endio function that replaces shared_read_endio. - Introduce an explicit 'quiesced' flag into the new_mapping structure. Before, this was implicitly indicated by m->list being empty. - The map_info->ptr remains constant for the duration of a bio's trip through the thin target. Make it easier to reason about it. Signed-off-by: Joe Thornber <ejt@redhat.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2012-03-28dm thin: use dm_target_offsetAlasdair G Kergon
Use dm_target_offset wrapper instead of referencing the awkward ti->begin explicitly. Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2012-03-28dm thin: support read only external snapshot originsJoe Thornber
Support the use of an external _read only_ device as an origin for a thin device. Any read to an unprovisioned area of the thin device will be passed through to the origin. Writes trigger allocation of new blocks as usual. One possible use case for this would be VM hosts that want to run guests on thinly-provisioned volumes but have the base image on another device (possibly shared between many VMs). Signed-off-by: Joe Thornber <ejt@redhat.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2012-03-28dm thin: relax hard limit on the maximum size of a metadata deviceMike Snitzer
The thin metadata format can only make use of a device that is <= THIN_METADATA_MAX_SECTORS (currently 15.9375 GB). Therefore, there is no practical benefit to using a larger device. However, it may be that other factors impose a certain granularity for the space that is allocated to a device (E.g. lvm2 can impose a coarse granularity through the use of large, >= 1 GB, physical extents). Rather than reject a larger metadata device, during thin-pool device construction, switch to allowing it but issue a warning if a device larger than THIN_METADATA_MAX_SECTORS_WARNING (16 GB) is provided. Any space over 15.9375 GB will not be used. Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2012-03-28dm persistent data: remove space map ref_count entries if redundantJoe Thornber
Save space by removing entries from the space map ref_count tree if they're no longer needed. Ref counts are stored in two places: a bitmap if the ref_count is below 3, or a btree of uint32_t if 3 or above. When a ref_count that was above 3 drops below we can remove it from the tree and save some metadata space. This removal was commented out before because I was unsure why this was causing under-populated btree nodes. Earlier patches have fixed this issue. Signed-off-by: Joe Thornber <ejt@redhat.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2012-03-28dm thin: commit outstanding data every secondJoe Thornber
Commit unwritten data every second to prevent too much building up. Released blocks don't become available until after the next commit (for crash resilience). Prior to this patch commits were only triggered by a message to the target or a REQ_{FLUSH,FUA} bio. This allowed far too big a position to build up. The interval is hard-coded to 1 second. This is a sensible setting. I'm not making this user configurable, since there isn't much to be gained by tweaking this - and a lot lost by setting it far too high. Signed-off-by: Joe Thornber <ejt@redhat.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2012-03-28dm: reject trailing characters in sccanf inputMikulas Patocka
Device mapper uses sscanf to convert arguments to numbers. The problem is that the way we use it ignores additional unmatched characters in the scanned string. For example, this `if (sscanf(string, "%d", &number) == 1)' will match a number, but also it will match number with some garbage appended, like "123abc". As a result, device mapper accepts garbage after some numbers. For example the command `dmsetup create vg1-new --table "0 16384 linear 254:1bla 34816bla"' will pass without an error. This patch fixes all sscanf uses in device mapper. It appends "%c" with a pointer to a dummy character variable to every sscanf statement. The construct `if (sscanf(string, "%d%c", &number, &dummy) == 1)' succeeds only if string is a null-terminated number (optionally preceded by some whitespace characters). If there is some character appended after the number, sscanf matches "%c", writes the character to the dummy variable and returns 2. We check the return value for 1 and consequently reject numbers with some garbage appended. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Acked-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2012-03-28dm raid: handle failed devices during start upJonathan E Brassow
The dm-raid code currently fails to create a RAID array if any of the superblocks cannot be read. This was an oversight as there is already code to handle this case if the values ('- -') were provided for the failed array position. With this patch, if a superblock cannot be read, the array position's fields are initialized as though '- -' was set in the table. That is, the device is failed and the position should not be used, but if there is sufficient redundancy, the array should still be activated. Signed-off-by: Jonathan Brassow <jbrassow@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2012-03-28dm thin metadata: pass correct space map to dm_sm_root_sizeJoe Thornber
Fix a harmless typo. The root is a chunk of data that gets written to the superblock. This data is used to recreate the space map when opening a metadata area. We have two space maps; one tracking space on the metadata device and one of the data device. Both of these use the same format for their root, so this typo was harmless. Signed-off-by: Joe Thornber <ejt@redhat.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2012-03-28dm persistent data: remove redundant value_size arg from value_ptrJoe Thornber
Now that the value_size is held within every node of the btrees we can remove this argument from value_ptr(). For the last few months a BUG_ON has been checking this argument is the same as that held in the node. No issues were reported. So this is a safe change. Signed-off-by: Joe Thornber <ejt@redhat.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2012-03-28dm mpath: detect invalid map_contextJun'ichi Nomura
The map_context pointer should always be set. However, we have reports that upon requeuing it is not set correctly. So add set and clear functions with a BUG_ON() to track the issue properly. Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Cc: Mike Snitzer <snitzer@redhat.com> Acked-by: Hannes Reinecke <hare@suse.de> Tested-by: Heiko Carstens <heiko.carstens@de.ibm.com> Acked-by: Dave Wysochanski <dwysocha@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2012-03-28dm: clear bi_end_io on remapping failureHannes Reinecke
As a precaution, set bi_end_io to NULL when failing to remap. Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2012-03-28dm table: simplify call to free_devicesHannes Reinecke
free_devices in dm_table.c already uses list_for_each(), so we don't need to check if the list is empty. Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2012-03-28dm thin: correct commentsJoe Thornber
Remove documentation for unimplemented 'trim' message. I'd planned a 'trim' target message for shrinking thin devices, but this is better handled via the discard ioctl. Signed-off-by: Joe Thornber <ejt@redhat.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2012-03-28dm raid: no longer experimentalAlasdair G Kergon
The dm raid module (using md) is becoming the preferred way of creating long-lived mirrors through userspace LVM so remove the EXPERIMENTAL tag. Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2012-03-28dm uevent: no longer experimentalAlasdair G Kergon
Drop EXPERIMENTAL tag from dm-uevent. It's not changed for a while and some userspace tools are relying upon it. Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2012-03-28dm: add persistent data to MAINTAINERSAlasdair G Kergon
Update device-mapper MAINTAINERS entry to mention quilt working tree location and persistent-data subdirectory. Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2012-03-28dm: document sysfs entriesMilan Broz
Describe attributes provided by device-mapper in /sys/block. Signed-off-by: Milan Broz <mbroz@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2012-03-28dm persistent data: fix btree rebalancing after removeJoe Thornber
When we remove an entry from a node we sometimes rebalance with it's two neighbours. This wasn't being done correctly; in some cases entries have to move all the way from the right neighbour to the left neighbour, or vice versa. This patch pretty much re-writes the balancing code to fix it. This code is barely used currently; only when you delete a thin device, and then only if you have hundreds of them in the same pool. Once we have discard support, which removes mappings, this will be used much more heavily. Signed-off-by: Joe Thornber <ejt@redhat.com> Cc: stable@kernel.org Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2012-03-28dm thin: fix stacked bi_next usageJoe Thornber
Avoid using the bi_next field for the holder of a cell when deferring bios because a stacked device below might change it. Store the holder in a new field in struct cell instead. When a cell is created, the bio that triggered creation (the holder) was added to the same bio list as subsequent bios. In some cases we pass this holder bio directly to devices underneath. If those devices use the bi_next field there will be trouble... This also simplifies some code that had to work out which bio was the holder. Signed-off-by: Joe Thornber <ejt@redhat.com> Cc: stable@kernel.org Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2012-03-28dm crypt: add missing error handlingMikulas Patocka
Always set io->error to -EIO when an error is detected in dm-crypt. There were cases where an error code would be set only if we finish processing the last sector. If there were other encryption operations in flight, the error would be ignored and bio would be returned with success as if no error happened. This bug is present in kcryptd_crypt_write_convert, kcryptd_crypt_read_convert and kcryptd_async_done. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Cc: stable@kernel.org Reviewed-by: Milan Broz <mbroz@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2012-03-28dm crypt: fix mempool deadlockMikulas Patocka
This patch fixes a possible deadlock in dm-crypt's mempool use. Currently, dm-crypt reserves a mempool of MIN_BIO_PAGES reserved pages. It allocates first MIN_BIO_PAGES with non-failing allocation (the allocation cannot fail and waits until the mempool is refilled). Further pages are allocated with different gfp flags that allow failing. Because allocations may be done in parallel, this code can deadlock. Example: There are two processes, each tries to allocate MIN_BIO_PAGES and the processes run simultaneously. It may end up in a situation where each process allocates (MIN_BIO_PAGES / 2) pages. The mempool is exhausted. Each process waits for more pages to be freed to the mempool, which never happens. To avoid this deadlock scenario, this patch changes the code so that only the first page is allocated with non-failing gfp mask. Allocation of further pages may fail. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Cc: stable@kernel.org Signed-off-by: Milan Broz <mbroz@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2012-03-28dm exception store: fix init error pathAndrei Warkentin
Call the correct exit function on failure in dm_exception_store_init. Signed-off-by: Andrei Warkentin <andrey.warkentin@gmail.com> Acked-by: Mike Snitzer <snitzer@redhat.com> Cc: stable@kernel.org Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2012-03-28Merge tag 'writeback-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/wfg/linux Pull trivial writeback fixes from Wu Fengguang: "They've been tested in linux-next for 20 days actually." * tag 'writeback-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/wfg/linux: writeback: Remove outdated comment fs: Remove bogus wait in write_inode_now()
2012-03-28Merge tag 'ext4_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4 Pull ext4 updates for 3.4 from Ted Ts'o: "Ext4 commits for 3.3 merge window; mostly cleanups and bug fixes The changes to export dirty_writeback_interval are from Artem's s_dirt cleanup patch series. The same is true of the change to remove the s_dirt helper functions which never got used by anyone in-tree. I've run these changes by Al Viro, and am carrying them so that Artem can more easily fix up the rest of the file systems during the next merge window. (Originally we had hopped to remove the use of s_dirt from ext4 during this merge window, but his patches had some bugs, so I ultimately ended dropping them from the ext4 tree.)" * tag 'ext4_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (66 commits) vfs: remove unused superblock helpers mm: export dirty_writeback_interval ext4: remove useless s_dirt assignment ext4: write superblock only once on unmount ext4: do not mark superblock as dirty unnecessarily ext4: correct ext4_punch_hole return codes ext4: remove restrictive checks for EOFBLOCKS_FL ext4: always set then trimmed blocks count into len ext4: fix trimmed block count accunting ext4: fix start and len arguments handling in ext4_trim_fs() ext4: update s_free_{inodes,blocks}_count during online resize ext4: change some printk() calls to use ext4_msg() instead ext4: avoid output message interleaving in ext4_error_<foo>() ext4: remove trailing newlines from ext4_msg() and ext4_error() messages ext4: add no_printk argument validation, fix fallout ext4: remove redundant "EXT4-fs: " from uses of ext4_msg ext4: give more helpful error message in ext4_ext_rm_leaf() ext4: remove unused code from ext4_ext_map_blocks() ext4: rewrite punch hole to use ext4_ext_remove_space() jbd2: cleanup journal tail after transaction commit ...
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client Pull Ceph updates for 3.4-rc1 from Sage Weil: "Alex has been busy. There are a range of rbd and libceph cleanups, especially surrounding device setup and teardown, and a few critical fixes in that code. There are more cleanups in the messenger code, virtual xattrs, a fix for CRC calculation/checks, and lots of other miscellaneous stuff. There's a patch from Amon Ott to make inos behave a bit better on 32-bit boxes, some decode check fixes from Xi Wang, and network throttling fix from Jim Schutt, and a couple RBD fixes from Josh Durgin. No new functionality, just a lot of cleanup and bug fixing." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: (65 commits) rbd: move snap_rwsem to the device, rename to header_rwsem ceph: fix three bugs, two in ceph_vxattrcb_file_layout() libceph: isolate kmap() call in write_partial_msg_pages() libceph: rename "page_shift" variable to something sensible libceph: get rid of zero_page_address libceph: only call kernel_sendpage() via helper libceph: use kernel_sendpage() for sending zeroes libceph: fix inverted crc option logic libceph: some simple changes libceph: small refactor in write_partial_kvec() libceph: do crc calculations outside loop libceph: separate CRC calculation from byte swapping libceph: use "do" in CRC-related Boolean variables ceph: ensure Boolean options support both senses libceph: a few small changes libceph: make ceph_tcp_connect() return int libceph: encapsulate some messenger cleanup code libceph: make ceph_msgr_wq private libceph: encapsulate connection kvec operations libceph: move prepare_write_banner() ...
2012-03-28Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs Pull ext3, UDF, and quota fixes from Jan Kara: "A couple of ext3 & UDF fixes and also one improvement in quota locking." * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs: ext3: fix start and len arguments handling in ext3_trim_fs() udf: Fix deadlock in udf_release_file() udf: Fix file entry logicalBlocksRecorded udf: Fix handling of i_blocks quota: Make quota code not call tty layer with dqptr_sem held udf: Init/maintain file entry checkpoint field ext3: Update ctime in ext3_splice_branch() only when needed ext3: Don't call dquot_free_block() if we don't update anything udf: Remove unnecessary OOM messages
2012-03-28Merge tag 'for-linus-3.4-merge-window' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs Pull 9p changes for the 3.4 merge window from Eric Van Hensbergen. * tag 'for-linus-3.4-merge-window' of git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs: 9p: statfs should not override server f_type net/9p: handle flushed Tclunk/Tremove net/9p: don't allow Tflush to be interrupted
2012-03-28vfs: fix d_ancestor() case in d_materialize_uniqueMichel Lespinasse
In d_materialise_unique() there are 3 subcases to the 'aliased dentry' case; in two subcases the inode i_lock is properly released but this does not occur in the -ELOOP subcase. This seems to have been introduced by commit 1836750115f2 ("fix loop checks in d_materialise_unique()"). Signed-off-by: Michel Lespinasse <walken@google.com> Cc: stable@vger.kernel.org # v3.0+ [ Added a comment, and moved the unlock to where we generate the -ELOOP, which seems to be more natural. You probably can't actually trigger this without a buggy network file server - d_materialize_unique() is for finding aliases on non-local filesystems, and the d_ancestor() case is for a hardlinked directory loop. But we should be robust in the case of such buggy servers anyway. ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-28drm/radeon: Only warn if the intra-domain offset actually exceeds the limit.Michel Dänzer
Fixes spurious warnings. Tested-by: Dave Jones <davej@redhat.com> Tested-by: Steven Rostedt <rostedt@goodmis.org> Tested-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Michel Dänzer <michel.daenzer@amd.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-03-27Merge branch 'fixes-non-critical' into next/drivers2Olof Johansson
fixes-non-critical has already been merged upstream, and there are a handful of annoying context conflicts that it makes sense to resolve before sending up. Part of this is because there was parallel development going on between more urgent fixes and general driver fixups, it should settle down once the lpc32xx platform reaches a more steady state. Conflicts: arch/arm/mach-lpc32xx/clock.c arch/arm/mach-lpc32xx/common.h Signed-off-by: Olof Johansson <olof@lixom.net>
