The usbcore headers: hcd.h and hub.h are shared between usbcore,
HCDs and a couple of other drivers (e.g. USBIP modules).
So, it makes sense to move them into a more public location and
to cleanup dependency of those modules on kernel internal headers.
This patch moves hcd.h from drivers/usb/core into include/linux/usb/
Signed-of-by: Eric Lescouet <eric@lescouet.org>
Cc: Alan Stern <stern@rowland.harvard.edu>
The length of the scatter gather list a driver can enqueue is limited by
the bus' sg_tablesize to 62 entries. Each entry will be described by at
least one transfer request block (TRB). If the entry's buffer crosses a
64KB boundary, then that entry will have to be described by two or more
TRBs. So even if the USB device driver respects sg_tablesize, the whole
scatter list may take more than 62 TRBs to describe, and won't fit on
the ring.
Don't assume that an empty ring means there is enough room on the
transfer ring. The old code would unconditionally queue this too-large
transfer, and over write the beginning of the transfer. This would mean
the cycle bit was unchanged in those overwritten transfers, causing the
hardware to think it didn't own the TRBs, and the host would seem to
hang.
Now drivers may see submit_urb() fail with -ENOMEM if the transfers are
too big to fit on the ring.
Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
Cc: stable <stable@kernel.org>
When a scatter-gather list is enqueued to the xHCI driver, it translates
each entry into a transfer request block (TRB). Only 63 TRBs can be
used per ring segment, and there must be one additional TRB reserved to
make sure the hardware does not think the ring is empty (so the enqueue
pointer doesn't equal the dequeue pointer). Limit the bus sg_tablesize
to 62 TRBs.
When the USB core installs a new interface, it unconditionally clears the
halts on all the endpoints on the new interface. Usually the xHCI host
needs to know when an endpoint is reset, so it can change its internal
endpoint state. In this case, it doesn't care, because the endpoints were
never halted in the first place.
To avoid issuing a redundant Reset Endpoint command, the xHCI driver looks
at xhci_virt_ep->stopped_td to determine if the endpoint was actually
halted. However, the functions that handle the stall never set that
variable to NULL after it dealt with the stall. So if an endpoint stalled
and a Reset Endpoint command completed, and then the class driver tried to
install a new alternate setting, the xHCI driver would access the old
xhci_virt_ep->stopped_td pointer. A similar problem occurs if the
endpoint has been stopped to cancel a transfer.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6:
rtnetlink: make SR-IOV VF interface symmetric
sctp: delete active ICMP proto unreachable timer when free transport
tcp: fix MD5 (RFC2385) support
* 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linus:
MIPS: Oprofile: Fix Loongson irq handler
MIPS: N32: Use compat version for sys_ppoll.
MIPS FPU emulator: allow Cause bits of FCSR to be writeable by ctc1
Now we have a set of nested attributes:
IFLA_VFINFO_LIST (NESTED)
IFLA_VF_INFO (NESTED)
IFLA_VF_MAC
IFLA_VF_VLAN
IFLA_VF_TX_RATE
This allows a single set to operate on multiple attributes if desired.
Among other things, it means a dump can be replayed to set state.
The current interface has yet to be released, so this seems like
something to consider for 2.6.34.
Signed-off-by: Chris Wright <chrisw@sous-sol.org>
transport may be free before ICMP proto unreachable timer expire, so
we should delete active ICMP proto unreachable timer when transport
is going away.
Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com>
Acked-by: Vlad Yasevich <vladislav.yasevich@hp.com>
TCP MD5 support uses percpu data for temporary storage. It currently
disables preemption so that same storage cannot be reclaimed by another
thread on same cpu.
We also have to make sure a softirq handler wont try to use also same
context. Various bug reports demonstrated corruptions.
Fix is to disable preemption and BH.
Reported-by: Bhaskar Dutta <bhaskie@gmail.com>
The interrupt enable bit for the performance counters is in the Control
Register $24, not in the counter register.
loongson2_perfcount_handler(), we need to use
Reported-by: Xu Hengyang <hengyang@mail.ustc.edu.cn>
Signed-off-by: Wu Zhangjin <wuzhangjin@gmail.com>
Cc: linux-mips@linux-mips.org
Patchwork: http://patchwork.linux-mips.org/patch/1198/
The sys_ppoll() takes struct 'struct timespec'. This is different for the
N32 and N64 ABIs. Use the compat version to do the proper conversions.
Signed-off-by: David Daney <ddaney@caviumnetworks.com>
To: linux-mips@linux-mips.org
Patchwork: http://patchwork.linux-mips.org/patch/1210/
In the FPU emulator code of the MIPS, the Cause bits of the FCSR register
are not currently writeable by the ctc1 instruction. In odd corner cases,
this can cause problems. For example, a case existed where a divide-by-zero
exception was generated by the FPU, and the signal handler attempted to
restore the FPU registers to their state before the exception occurred. In
this particular setup, writing the old value to the FCSR register would
cause another divide-by-zero exception to occur immediately. The solution
is to change the ctc1 instruction emulator code to allow the Cause bits of
the FCSR register to be writeable. This is the behaviour of the hardware
that the code is emulating.
This problem was found by Shane McDonald, but the credit for the fix goes
to Kevin Kissell. In Kevin's words:
I submit that the bug is indeed in that ctc_op: case of the emulator. The
Cause bits (17:12) are supposed to be writable by that instruction, but the
CTC1 emulation won't let them be updated by the instruction. I think that
actually if you just completely removed lines 387-388 [...] things would
work a good deal better. At least, it would be a more accurate emulation of
the architecturally defined FPU. If I wanted to be really, really pedantic
(which I sometimes do), I'd also protect the reserved bits that aren't
necessarily writable.
Signed-off-by: Shane McDonald <mcdonald.shane@gmail.com>
To: anemo@mba.ocn.ne.jp
To: kevink@paralogos.com
To: sshtylyov@mvista.com
Patchwork: http://patchwork.linux-mips.org/patch/1205/
* git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable:
Btrfs: check for read permission on src file in the clone ioctl
mempool_alloc() can return null in atomic case.
Signed-off-by: Denis Kirjanov <kirjanov@gmail.com>
Cc: Joern Engel <joern@logfs.org>
As we were using an internal dma flushing routine, this patch changes to
the DMA API flush_kernel_dcache_page(). Driver is able to compile now.
[akpm@linux-foundation.org: flush_kernel_dcache_page() comes before kunmap_atomic()]
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Cc: James Bottomley <James.Bottomley@HansenPartnership.com>
The existing code would have allowed you to clone a file that was
only open for writing
Signed-off-by: Chris Mason <chris.mason@oracle.com>
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6:
JFS: Free sbi memory in error path
fs/sysv: dereferencing ERR_PTR()
Fix double-free in logfs
Fix the regression created by "set S_DEAD on unlink()..." commit
* 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
perf record: Add a fallback to the reference relocation symbol
I spotted the missing kfree() while removing the BKL.
[akpm@linux-foundation.org: avoid multiple returns so it doesn't happen again]
Signed-off-by: Jan Blunck <jblunck@suse.de>
Cc: Dave Kleikamp <shaggy@austin.ibm.com>
I moved the dir_put_page() inside the if condition so we don't dereference
"page", if it's an ERR_PTR().
iput() is needed *until* we'd done successful d_alloc_root()
1) i_flags simply doesn't work for mount/unlink race prevention;
we may have many links to file and rm on one of those obviously
shouldn't prevent bind on top of another later on. To fix it
right way we need to mark _dentry_ as unsuitable for mounting
upon; new flag (DCACHE_CANT_MOUNT) is protected by d_flags and
i_mutex on the inode in question. Set it (with dont_mount(dentry))
in unlink/rmdir/etc., check (with cant_mount(dentry)) in places
in namespace.c that used to check for S_DEAD. Setting S_DEAD
is still needed in places where we used to set it (for directories
getting killed), since we rely on it for readdir/rmdir race
prevention.
2) rename()/mount() protection has another bogosity - we unhash
the target before we'd checked that it's not a mountpoint. Fixed.
3) ancient bogosity in pivot_root() - we locked i_mutex on the
right directory, but checked S_DEAD on the different (and wrong)
one. Noticed and fixed.
* master.kernel.org:/home/rmk/linux-2.6-arm:
ARM: 6126/1: ARM mpcore_wdt: fix build failure and other fixes
ARM: 6125/1: ARM TWD: move TWD registers to common header
ARM: 6110/1: Fix Thumb-2 kernel builds when UACCESS_WITH_MEMCPY is enabled
ARM: 6112/1: Use the Inner Shareable I-cache and BTB ops on ARMv7 SMP
ARM: 6111/1: Implement read/write for ownership in the ARMv6 DMA cache ops
ARM: 6106/1: Implement copy_to_user_page() for noMMU
ARM: 6105/1: Fix the __arm_ioremap_caller() definition in nommu.c
* 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86, mrst: Don't blindly access extended config space
If the kernel is large or the profiling step small, /proc/profile
leaks data and readprofile shows silly stats, until readprofile -r
has reset the buffer: clear the prof_buffer when it is vmalloc()ed.
Cc: stable@kernel.org
My old address will shut down in a couple of weeks: update the tree.
Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk>
Do not blindly access extended configuration space unless we actively
know we're on a Moorestown platform. The fixed-size BAR capability
lives in the extended configuration space, and thus is not applicable
if the configuration space isn't appropriately sized.
This fixes booting certain VMware configurations with CONFIG_MRST=y.
Moorestown will add a fake PCI-X 266 capability to advertise the
presence of extended configuration space.
Reported-and-tested-by: Petr Vandrovec <petr@vandrovec.name>
Acked-by: Jacob Pan <jacob.jun.pan@intel.com>
Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org>
LKML-Reference: <AANLkTiltKUa3TrKR1M51eGw8FLNoQJSLT0k0_K5X3-OJ@mail.gmail.com>
x86, cacheinfo: Turn off L3 cache index disable feature in virtualized environments
x86, k8: Fix build error when K8_NB is disabled
x86, amd: Check X86_FEATURE_OSVW bit before accessing OSVW MSRs
x86: Fix fake apicid to node mapping for numa emulation
environments
When running a quest kernel on xen we get:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000038
IP: [<ffffffff8142f2fb>] cpuid4_cache_lookup_regs+0x2ca/0x3df
PGD 0
Oops: 0000 [#1] SMP
last sysfs file:
CPU 0
Modules linked in:
Pid: 0, comm: swapper Tainted: G W 2.6.34-rc3 #1 /HVM domU
RIP: 0010:[<ffffffff8142f2fb>] [<ffffffff8142f2fb>] cpuid4_cache_lookup_regs+0x
2ca/0x3df
RSP: 0018:ffff880002203e08 EFLAGS: 00010046
RAX: 0000000000000000 RBX: 0000000000000003 RCX: 0000000000000060
RDX: 0000000000000000 RSI: 0000000000000040 RDI: 0000000000000000
RBP: ffff880002203ed8 R08: 00000000000017c0 R09: ffff880002203e38
R10: ffff8800023d5d40 R11: ffffffff81a01e28 R12: ffff880187e6f5c0
R13: ffff880002203e34 R14: ffff880002203e58 R15: ffff880002203e68
FS: 0000000000000000(0000) GS:ffff880002200000(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: 0000000000000038 CR3: 0000000001a3c000 CR4: 00000000000006f0
Process swapper (pid: 0, threadinfo ffffffff81a00000, task ffffffff81a44020)
Stack:
ffffffff810d7ecb ffff880002203e20 ffffffff81059140 ffff880002203e30
<0> ffffffff810d7ec9 0000000002203e40 000000000050d140 ffff880002203e70
<0> 0000000002008140 0000000000000086 ffff880040020140 ffffffff81068b8b
Call Trace:
<IRQ>
[<ffffffff810d7ecb>] ? sync_supers_timer_fn+0x0/0x1c
[<ffffffff81059140>] ? mod_timer+0x23/0x25
[<ffffffff810d7ec9>] ? arm_supers_timer+0x34/0x36
[<ffffffff81068b8b>] ? hrtimer_get_next_event+0xa7/0xc3
[<ffffffff81058e85>] ? get_next_timer_interrupt+0x19a/0x20d
[<ffffffff8142fa23>] get_cpu_leaves+0x5c/0x232
[<ffffffff8106a7b1>] ? sched_clock_local+0x1c/0x82
[<ffffffff8106a9a0>] ? sched_clock_tick+0x75/0x7a
[<ffffffff8107748c>] generic_smp_call_function_single_interrupt+0xae/0xd0
[<ffffffff8101f6ef>] smp_call_function_single_interrupt+0x18/0x27
[<ffffffff8100a773>] call_function_single_interrupt+0x13/0x20
<EOI>
[<ffffffff8143c468>] ? notifier_call_chain+0x14/0x63
[<ffffffff810295c6>] ? native_safe_halt+0xc/0xd
[<ffffffff810114eb>] ? default_idle+0x36/0x53
[<ffffffff81008c22>] cpu_idle+0xaa/0xe4
[<ffffffff81423a9a>] rest_init+0x7e/0x80
[<ffffffff81b10dd2>] start_kernel+0x40e/0x419
[<ffffffff81b102c8>] x86_64_start_reservations+0xb3/0xb7
[<ffffffff81b103c4>] x86_64_start_kernel+0xf8/0x107
Code: 14 d5 40 ff ae 81 8b 14 02 31 c0 3b 15 47 1c 8b 00 7d 0e 48 8b 05 36 1c 8b
00 48 63 d2 48 8b 04 d0 c7 85 5c ff ff ff 00 00 00 00 <8b> 70 38 48 8d 8d 5c ff
ff ff 48 8b 78 10 ba c4 01 00 00 e8 eb
RIP [<ffffffff8142f2fb>] cpuid4_cache_lookup_regs+0x2ca/0x3df
RSP <ffff880002203e08>
---[ end trace a7919e7f17c0a726 ]---
The L3 cache index disable feature of AMD CPUs has to be disabled if the
kernel is running as guest on top of a hypervisor because northbridge
devices are not available to the guest. Currently, this fixes a boot
crash on top of Xen. In the future this will become an issue on KVM as
well.
Check if northbridge devices are present and do not enable the feature
if there are none.
[ hpa: backported to 2.6.34 ]
Signed-off-by: Frank Arnold <frank.arnold@amd.com>
LKML-Reference: <1271945222-5283-3-git-send-email-bp@amd64.org>
Acked-by: Borislav Petkov <borislav.petkov@amd.com>
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
Cc: <stable@kernel.org>
K8_NB depends on PCI and when the last is disabled (allnoconfig) we fail
at the final linking stage due to missing exported num_k8_northbridges.
Add a header stub for that.
Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
LKML-Reference: <20100503183036.GJ26107@aftab>
* 'for-linus' of git://git.infradead.org/users/eparis/notify:
inotify: don't leak user struct on inotify release
inotify: race use after free/double free in inotify inode marks
inotify: clean up the inotify_add_watch out path
Inotify: undefined reference to `anon_inode_getfd'
Manual merge to remove duplicate "select ANON_INODES" from Kconfig file
git://git.kernel.org/pub/scm/linux/kernel/git/khilman/linux-davinci
* 'davinci-fixes-for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/khilman/linux-davinci:
DA830: fix USB 2.0 clock entry
DA8xx OHCI driver fails to load due to failing clk_get() call for the USB 2.0
clock. Arrange matching USB 2.0 clock by the clock name instead of the device.
(Adding another CLK() entry for "ohci.0" device won't do -- in the future I'll
also have to enable USB 2.0 clock to configure CPPI 4.1 module, in which case
I won't have any device at all.)
Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
inotify_new_group() receives a get_uid-ed user_struct and saves the
reference on group->inotify_data.user. The problem is that free_uid() is
never called on it.
Issue seem to be introduced by 63c882a0 (inotify: reimplement inotify
using fsnotify) after 2.6.30.
Signed-off-by: Pavel Emelyanov <xemul@openvz.org>
Eric Paris <eparis@parisplace.org>
Signed-off-by: Eric Paris <eparis@redhat.com>
There is a race in the inotify add/rm watch code. A task can find and
remove a mark which doesn't have all of it's references. This can
result in a use after free/double free situation.
Task A Task B
inotify_new_watch()
allocate a mark (refcnt == 1)
add it to the idr
inotify_rm_watch()
inotify_remove_from_idr()
fsnotify_put_mark()
refcnt hits 0, free
take reference because we are on idr
[at this point it is a use after free]
[time goes on]
refcnt may hit 0 again, double free
The fix is to take the reference BEFORE the object can be found in the
idr.
inotify_add_watch explictly frees the unused inode mark, but it can just
use the generic code. Just do that.
vhost: fix barrier pairing
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6:
mmap_min_addr check CAP_SYS_RAWIO only for write
* 'for-linus' of git://git.monstr.eu/linux-2.6-microblaze:
microblaze: Fix module loading on system with WB cache
microblaze: export assembly functions used by modules
microblaze: Remove powerpc code from Microblaze port
microblaze: Remove compilation warnings in cache macro
microblaze: fix get_user/put_user side-effects
microblaze: re-enable interrupts before calling schedule
git://git.kernel.org/pub/scm/linux/kernel/git/mst/vhost
Redirecting directly to lsm, here's the patch discussed on lkml:
http://lkml.org/lkml/2010/4/22/219
The mmap_min_addr value is useful information for an admin to see without
being root ("is my system vulnerable to kernel NULL pointer attacks?") and
its setting is trivially easy for an attacker to determine by calling
mmap() in PAGE_SIZE increments starting at 0, so trying to keep it private
has no value.
Only require CAP_SYS_RAWIO if changing the value, not reading it.
Comment from Serge :
Me, I like to write my passwords with light blue pen on dark blue
paper, pasted on my window - if you're going to get my password, you're
gonna get a headache.
Signed-off-by: Kees Cook <kees.cook@canonical.com>
Acked-by: Serge Hallyn <serue@us.ibm.com>
Signed-off-by: James Morris <jmorris@namei.org>
(cherry picked from commit 822cceec7248013821d655545ea45d1c6a9d15b3)
There is necessary to flush whole dcache. Icache work should be
done in kernel/module.c.
If host CPU is exposed to a guest the OSVW MSRs are not guaranteed
to be present and a GP fault occurs. Thus checking the feature flag is
essential.
Cc: <stable@kernel.org> # .32.x .33.x
Signed-off-by: Andreas Herrmann <andreas.herrmann3@amd.com>
LKML-Reference: <20100427101348.GC4489@alberich.amd.com>
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6:
mfd: Clean up after WM83xx AUXADC interrupt if it arrives late
* 'kvm-updates/2.6.34' of git://git.kernel.org/pub/scm/virt/kvm/kvm:
KVM: PPC: Keep index within boundaries in kvmppc_44x_emul_tlbwe()
KVM: VMX: blocked-by-sti must not defer NMI injections
KVM: x86: Call vcpu_load and vcpu_put in cpuid_update
KVM: SVM: Fix wrong intercept masks on 32 bit
KVM: convert ioapic lock to spinlock
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6:
serial: imx.c: fix CTS trigger level lower to avoid lost chars
tty: Fix unbalanced BKL handling in error path
serial: mpc52xx_uart: fix null pointer dereference
The imx CTS trigger level is left at its reset value that is 32
chars. Since the RX FIFO has 32 entries, when CTS is raised, the
FIFO already is full. However, some serial port devices first empty
their TX FIFO before stopping when CTS is raised, resulting in lost
chars.
This patch sets the trigger level lower so that other chars arrive
after CTS is raised, there is still room for 16 of them.
Signed-off-by: Valentin Longchamp<valentin.longchamp@epfl.ch>
Tested-by: Philippe Rétornaz<philippe.retornaz@epfl.ch>
Acked-by: Wolfram Sang<w.sang@pengutronix.de>
Arnd noted:
After the "retry_open:" label, we first get the tty_mutex
and then the BKL. However a the end of tty_open, we jump
back to retry_open with the BKL still held. If we run into
this case, the tty_open function will be left with the BKL
still held.
Signed-off-by: Alan Cox <alan@linux.intel.com>
Commit 6acc6833510db8f72b5ef343296d97480555fda9
introduced NULL pointer dereference and kernel crash
on ppc32 machines while booting. Fix this bug now.
Reported-by: Leonardo Chiquitto <leonardo.lists@gmail.com>
Tested-by: Leonardo Chiquitto <leonardo.lists@gmail.com>
