2013-01-28Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking updates from David Miller: "Much more accumulated than I would have liked due to an unexpected bout with a nasty flu: 1) AH and ESP input don't set ECN field correctly because the transport head of the SKB isn't set correctly, fix from Li RongQing. 2) If netfilter conntrack zones are disabled, we can return an uninitialized variable instead of the proper error code. Fix from Borislav Petkov. 3) Fix double SKB free in ath9k driver beacon handling, from Felix Feitkau. 4) Remove bogus assumption about netns cleanup ordering in nf_conntrack, from Pablo Neira Ayuso. 5) Remove a bogus BUG_ON in the new TCP fastopen code, from Eric Dumazet. It uses spin_is_locked() in it's test and is therefore unsuitable for UP. 6) Fix SELINUX labelling regressions added by the tuntap multiqueue changes, from Paul Moore. 7) Fix CRC errors with jumbo frame receive in tg3 driver, from Nithin Nayak Sujir. 8) CXGB4 driver sets interrupt coalescing parameters only on first queue, rather than all of them. Fix from Thadeu Lima de Souza Cascardo. 9) Fix regression in the dispatch of read/write registers in dm9601 driver, from Tushar Behera. 10) ipv6_append_data miscalculates header length, from Romain KUNTZ. 11) Fix PMTU handling regressions on ipv4 routes, from Steffen Klassert, Timo Teräs, and Julian Anastasov. 12) In 3c574_cs driver, add necessary parenthesis to "x << y & z" expression. From Nickolai Zeldovich. 13) macvlan_get_size() causes underallocation netlink message space, fix from Eric Dumazet. 14) Avoid division by zero in xfrm_replay_advance_bmp(), from Nickolai Zeldovich. Amusingly the zero check was already there, we were just performing it after the modulus :-) 15) Some more splice bug fixes from Eric Dumazet, which fix things mostly eminating from how we now more aggressively use high-order pages in SKBs. 16) Fix size calculation bug when freeing hash tables in the IPSEC xfrm code, from Michal Kubecek. 17) Fix PMTU event propagation into socket cached routes, from Steffen Klassert. 18) Fix off by one in TX buffer release in netxen driver, from Eric Dumazet. 19) Fix rediculous memory allocation requirements introduced by the tuntap multiqueue changes, from Jason Wang. 20) Remove bogus AMD platform workaround in r8169 driver that causes major problems in normal operation, from Timo Teräs. 21) virtio-net set affinity and select queue don't handle discontiguous cpu numbers properly, fix from Wanlong Gao. 22) Fix a route refcounting issue in loopback driver, from Eric Dumazet. There's a similar fix coming that we might add to the macvlan driver as well. 23) Fix SKB leaks in batman-adv's distributed arp table code, from Matthias Schiffer. 24) r8169 driver gives descriptor ownership back the hardware before we're done reading the VLAN tag out of it, fix from Francois Romieu. 25) Checksums not calculated properly in GRE tunnel driver fix from Pravin B Shelar. 26) Fix SCTP memory leak on namespace exit." * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (101 commits) dm9601: support dm9620 variant SCTP: Free the per-net sysctl table on net exit. v2 net: phy: icplus: fix broken INTR pin settings net: phy: icplus: Use the RGMII interface mode to configure clock delays IP_GRE: Fix kernel panic in IP_GRE with GRE csum. sctp: set association state to established in dupcook_a handler ip6mr: limit IPv6 MRT_TABLE identifiers r8169: fix vlan tag read ordering. net: cdc_ncm: use IAD provided by the USB core batman-adv: filter ARP packets with invalid MAC addresses in DAT batman-adv: check for more types of invalid IP addresses in DAT batman-adv: fix skb leak in batadv_dat_snoop_incoming_arp_reply() net: loopback: fix a dst refcounting issue virtio-net: reset virtqueue affinity when doing cpu hotplug virtio-net: split out clean affinity function virtio-net: fix the set affinity bug when CPU IDs are not consecutive can: pch_can: fix invalid error codes can: ti_hecc: fix invalid error codes can: c_can: fix invalid error codes r8169: remove the obsolete and incorrect AMD workaround ...
2013-01-28dm9601: support dm9620 variantPeter Korsgaard
dm9620 is a newer variant of dm9601 with more features (usb 2.0, checksum offload, ..), but it can also be put in a dm9601 compatible mode, allowing us to reuse the existing driver. This does mean that the extended features like checksum offload cannot be used, but that's hardly critical on a 100mbps interface. Thanks to Sławek Wernikowski <slawek@wernikowski.net> for providing me with a dm9620 based device to test. Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-01-28SCTP: Free the per-net sysctl table on net exit. v2Vlad Yasevich
Per-net sysctl table needs to be explicitly freed at net exit. Otherwise we see the following with kmemleak: unreferenced object 0xffff880402d08000 (size 2048): comm "chrome_sandbox", pid 18437, jiffies 4310887172 (age 9097.630s) hex dump (first 32 bytes): b2 68 89 81 ff ff ff ff 20 04 04 f8 01 88 ff ff .h...... ....... 04 00 00 00 a4 01 00 00 00 00 00 00 00 00 00 00 ................ backtrace: [<ffffffff815b4aad>] kmemleak_alloc+0x21/0x3e [<ffffffff81110352>] slab_post_alloc_hook+0x28/0x2a [<ffffffff81113fad>] __kmalloc_track_caller+0xf1/0x104 [<ffffffff810f10c2>] kmemdup+0x1b/0x30 [<ffffffff81571e9f>] sctp_sysctl_net_register+0x1f/0x72 [<ffffffff8155d305>] sctp_net_init+0x100/0x39f [<ffffffff814ad53c>] ops_init+0xc6/0xf5 [<ffffffff814ad5b7>] setup_net+0x4c/0xd0 [<ffffffff814ada5e>] copy_net_ns+0x6d/0xd6 [<ffffffff810938b1>] create_new_namespaces+0xd7/0x147 [<ffffffff810939f4>] copy_namespaces+0x63/0x99 [<ffffffff81076733>] copy_process+0xa65/0x1233 [<ffffffff81077030>] do_fork+0x10b/0x271 [<ffffffff8100a0e9>] sys_clone+0x23/0x25 [<ffffffff815dda73>] stub_clone+0x13/0x20 [<ffffffffffffffff>] 0xffffffffffffffff I fixed the spelling of sysctl_header so the code actually compiles. -- EWB. Reported-by: Martin Mokrejs <mmokrejs@fold.natur.cuni.cz> Signed-off-by: Vlad Yasevich <vyasevich@gmail.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-01-28net: phy: icplus: fix broken INTR pin settingsGiuseppe CAVALLARO
This patch fixes the setting of the INTR pin that is valid for IP101 A/G device and not for the IP1001. Reported-by: Anunay Saxena <anunay.saxena@st.com> Signed-off-by: Giuseppe Cavallaro <peppe.cavallaro@st.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-01-28net: phy: icplus: Use the RGMII interface mode to configure clock delaysStuart Menefy
Like several other PHY devices which support RGMII, the IC+1001 allows additional delays to by added to the RX_CLK and TX_CLK signals to compensate for skew between the clock and data signals. Previously this was always enabled, but this change makes use of the different RGMII interface modes to allow the user to specify whether this should be enabled. Signed-off-by: Stuart Menefy <stuart.menefy@st.com> Signed-off-by: Giuseppe Cavallaro <peppe.cavallaro@st.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-01-28IP_GRE: Fix kernel panic in IP_GRE with GRE csum.Pravin B Shelar
Due to IP_GRE GSO support, GRE can recieve non linear skb which results in panic in case of GRE_CSUM. Following patch fixes it by using correct csum API. Bug introduced in commit 6b78f16e4bdde3936b (gre: add GSO support) Signed-off-by: Pravin B Shelar <pshelar@nicira.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-01-27sctp: set association state to established in dupcook_a handlerXufeng Zhang
While sctp handling a duplicate COOKIE-ECHO and the action is 'Association restart', sctp_sf_do_dupcook_a() will processing the unexpected COOKIE-ECHO for peer restart, but it does not set the association state to SCTP_STATE_ESTABLISHED, so the association could stuck in SCTP_STATE_SHUTDOWN_PENDING state forever. This violates the sctp specification: RFC 4960 5.2.4. Handle a COOKIE ECHO when a TCB Exists Action A) In this case, the peer may have restarted. ..... After this, the endpoint shall enter the ESTABLISHED state. To resolve this problem, adding a SCTP_CMD_NEW_STATE cmd to the command list before SCTP_CMD_REPLY cmd, this will set the restart association to SCTP_STATE_ESTABLISHED state properly and also avoid I-bit being set in the DATA chunk header when COOKIE_ACK is bundled with DATA chunks. Signed-off-by: Xufeng Zhang <xufeng.zhang@windriver.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Acked-by: Vlad Yasevich <vyasevich@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-01-27ip6mr: limit IPv6 MRT_TABLE identifiersDan Carpenter
We did this for IPv4 in b49d3c1e1c "net: ipmr: limit MRT_TABLE identifiers" but we need to do it for IPv6 as well. On IPv6 the name is "pim6reg" instead of "pimreg" so there is one less digit allowed. The strcpy() is in ip6mr_reg_vif(). Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-01-27r8169: fix vlan tag read ordering.françois romieu
Control of receive descriptor must not be returned to ethernet chipset before vlan tag processing is done. VLAN tag receive word is now reset both in normal and error path. Signed-off-by: Francois Romieu <romieu@fr.zoreil.com> Spotted-by: Timo Teras <timo.teras@iki.fi> Cc: Hayes Wang <hayeswang@realtek.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-01-27net: cdc_ncm: use IAD provided by the USB coreBjørn Mork
commit 9992c2e (net: cdc_ncm: workaround for missing CDC Union) added code to lookup an IAD for the interface we are probing. This is redundant. The USB core has already done the lookup and saved the result in the USB interface struct. Use that instead. Cc: Greg Suarez <gsuarez@smithmicro.com> Cc: Alexey Orishko <alexey.orishko@stericsson.com> Signed-off-by: Bjørn Mork <bjorn@mork.no> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-01-27Merge tag 'batman-adv-fix-for-davem' of git://git.open-mesh.org/linux-mergeDavid S. Miller
Included changes ares: - fix an skb memleak in DAT - fix the ARP filtering routine in DAT by preventing bogus entries to overwrite already existing ones in the local cache. - fix the ARP filtering routine in DAT by preventing it to parse and add to the cache bogus entries Signed-off-by: David S. Miller <davem@davemloft.net>
2013-01-27batman-adv: filter ARP packets with invalid MAC addresses in DATMatthias Schiffer
We never want multicast MAC addresses in the Distributed ARP Table, so it's best to completely ignore ARP packets containing them where we expect unicast addresses. Signed-off-by: Matthias Schiffer <mschiffer@universe-factory.net> Acked-by: Antonio Quartulli <ordex@autistici.org> Signed-off-by: Marek Lindner <lindner_marek@yahoo.de> Signed-off-by: Antonio Quartulli <ordex@autistici.org>
2013-01-27batman-adv: check for more types of invalid IP addresses in DATMatthias Schiffer
There are more types of IP addresses that may appear in ARP packets that we don't want to process. While some of these should never appear in sane ARP packets, a 0.0.0.0 source is used for duplicate address detection and thus seen quite often. Signed-off-by: Matthias Schiffer <mschiffer@universe-factory.net> Acked-by: Antonio Quartulli <ordex@autistici.org> Signed-off-by: Marek Lindner <lindner_marek@yahoo.de> Signed-off-by: Antonio Quartulli <ordex@autistici.org>
2013-01-27batman-adv: fix skb leak in batadv_dat_snoop_incoming_arp_reply()Matthias Schiffer
The callers of batadv_dat_snoop_incoming_arp_reply() assume the skb has been freed when it returns true; fix this by calling kfree_skb before returning as it is done in batadv_dat_snoop_incoming_arp_request(). Signed-off-by: Matthias Schiffer <mschiffer@universe-factory.net> Signed-off-by: Marek Lindner <lindner_marek@yahoo.de> Acked-by: Antonio Quartulli <ordex@autistici.org> Signed-off-by: Antonio Quartulli <ordex@autistici.org>
2013-01-27Merge branch 'for-davem' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless John W. Linville says: ==================== This is a batch of fixes intende for the 3.8 stream. Regarding the iwlwifi bits, Johannes says this: "Please pull to get a single fix from Emmanuel for a bug I introduced due to misunderstanding the code." Regarding the mac80211 bits, Johannes says this: "I have a few small fixes for you: * some mesh frames would cause encryption warnings -- fixes from Bob * scanning would pretty much break an association if we transmitted anything to the AP while scanning -- fix from Stanislaw * mode injection was broken by channel contexts -- fix from Felix * FT roaming was broken: hardware crypto would get disabled by it" Along with that, a handful of other fixes confined to specific drivers. Avinash Patil fixes a typo in a NULL check in mwifiex. Larry Finger fixes a build warning in rtlwifi. Seems safe... Stanislaw Gruszka fixes iwlegacy to prevent microcode errors when switching from IBSS mode to STA mode. Felix Fietkau provides a trio of ath9k fixes related to proper tuning. Please let me know if there are problems! ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2013-01-27net: loopback: fix a dst refcounting issueEric Dumazet
Ben Greear reported crashes in ip_rcv_finish() on a stress test involving many macvlans. We tracked the bug to a dst use after free. ip_rcv_finish() was calling dst->input() and got garbage for dst->input value. It appears the bug is in loopback driver, lacking a skb_dst_force() before calling netif_rx(). As a result, a non refcounted dst, normally protected by a RCU read_lock section, was escaping this section and could be freed before the packet being processed. [<ffffffff813a3c4d>] loopback_xmit+0x64/0x83 [<ffffffff81477364>] dev_hard_start_xmit+0x26c/0x35e [<ffffffff8147771a>] dev_queue_xmit+0x2c4/0x37c [<ffffffff81477456>] ? dev_hard_start_xmit+0x35e/0x35e [<ffffffff8148cfa6>] ? eth_header+0x28/0xb6 [<ffffffff81480f09>] neigh_resolve_output+0x176/0x1a7 [<ffffffff814ad835>] ip_finish_output2+0x297/0x30d [<ffffffff814ad6d5>] ? ip_finish_output2+0x137/0x30d [<ffffffff814ad90e>] ip_finish_output+0x63/0x68 [<ffffffff814ae412>] ip_output+0x61/0x67 [<ffffffff814ab904>] dst_output+0x17/0x1b [<ffffffff814adb6d>] ip_local_out+0x1e/0x23 [<ffffffff814ae1c4>] ip_queue_xmit+0x315/0x353 [<ffffffff814adeaf>] ? ip_send_unicast_reply+0x2cc/0x2cc [<ffffffff814c018f>] tcp_transmit_skb+0x7ca/0x80b [<ffffffff814c3571>] tcp_connect+0x53c/0x587 [<ffffffff810c2f0c>] ? getnstimeofday+0x44/0x7d [<ffffffff810c2f56>] ? ktime_get_real+0x11/0x3e [<ffffffff814c6f9b>] tcp_v4_connect+0x3c2/0x431 [<ffffffff814d6913>] __inet_stream_connect+0x84/0x287 [<ffffffff814d6b38>] ? inet_stream_connect+0x22/0x49 [<ffffffff8108d695>] ? _local_bh_enable_ip+0x84/0x9f [<ffffffff8108d6c8>] ? local_bh_enable+0xd/0x11 [<ffffffff8146763c>] ? lock_sock_nested+0x6e/0x79 [<ffffffff814d6b38>] ? inet_stream_connect+0x22/0x49 [<ffffffff814d6b49>] inet_stream_connect+0x33/0x49 [<ffffffff814632c6>] sys_connect+0x75/0x98 This bug was introduced in linux-2.6.35, in commit 7fee226ad2397b (net: add a noref bit on skb dst) skb_dst_force() is enforced in dev_queue_xmit() for devices having a qdisc. Reported-by: Ben Greear <greearb@candelatech.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Tested-by: Ben Greear <greearb@candelatech.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-01-27virtio-net: reset virtqueue affinity when doing cpu hotplugWanlong Gao
Add a cpu notifier to virtio-net, so that we can reset the virtqueue affinity if the cpu hotplug happens. It improve the performance through enabling or disabling the virtqueue affinity after doing cpu hotplug. Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: "Michael S. Tsirkin" <mst@redhat.com> Cc: Jason Wang <jasowang@redhat.com> Cc: Eric Dumazet <erdnetdev@gmail.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: virtualization@lists.linux-foundation.org Cc: netdev@vger.kernel.org Signed-off-by: Wanlong Gao <gaowanlong@cn.fujitsu.com> Acked-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-01-27virtio-net: split out clean affinity functionWanlong Gao
Split out the clean affinity function to virtnet_clean_affinity(). Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: "Michael S. Tsirkin" <mst@redhat.com> Cc: Jason Wang <jasowang@redhat.com> Cc: Eric Dumazet <erdnetdev@gmail.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: virtualization@lists.linux-foundation.org Cc: netdev@vger.kernel.org Signed-off-by: Wanlong Gao <gaowanlong@cn.fujitsu.com> Acked-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-01-27virtio-net: fix the set affinity bug when CPU IDs are not consecutiveWanlong Gao
As Michael mentioned, set affinity and select queue will not work very well when CPU IDs are not consecutive, this can happen with hot unplug. Fix this bug by traversal the online CPUs, and create a per cpu variable to find the mapping from CPU to the preferable virtual-queue. Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: "Michael S. Tsirkin" <mst@redhat.com> Cc: Jason Wang <jasowang@redhat.com> Cc: Eric Dumazet <erdnetdev@gmail.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: virtualization@lists.linux-foundation.org Cc: netdev@vger.kernel.org Signed-off-by: Wanlong Gao <gaowanlong@cn.fujitsu.com> Acked-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-01-26can: pch_can: fix invalid error codesOlivier Sobrie
Errors in CAN protocol (location) are reported in data[3] of the can frame instead of data[2]. Cc: linux-stable <stable@vger.kernel.org> Signed-off-by: Olivier Sobrie <olivier@sobrie.be> Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
2013-01-26can: ti_hecc: fix invalid error codesOlivier Sobrie
Errors in CAN protocol (location) are reported in data[3] of the can frame instead of data[2]. Cc: linux-stable <stable@vger.kernel.org> Cc: Anant Gole <anantgole@ti.com> Signed-off-by: Olivier Sobrie <olivier@sobrie.be> Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
2013-01-26can: c_can: fix invalid error codesOlivier Sobrie
Errors in CAN protocol (location) are reported in data[3] of the can frame instead of data[2]. Cc: linux-stable <stable@vger.kernel.org> Cc: Bhupesh Sharma <bhupesh.sharma@st.com> Signed-off-by: Olivier Sobrie <olivier@sobrie.be> Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
2013-01-25Linux 3.8-rc5v3.8-rc5Linus Torvalds
2013-01-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs Pull btrfs fixes from Chris Mason: "It turns out that we had two crc bugs when running fsx-linux in a loop. Many thanks to Josef, Miao Xie, and Dave Sterba for nailing it all down. Miao also has a new OOM fix in this v2 pull as well. Ilya fixed a regression Liu Bo found in the balance ioctls for pausing and resuming a running balance across drives. Josef's orphan truncate patch fixes an obscure corruption we'd see during xfstests. Arne's patches address problems with subvolume quotas. If the user destroys quota groups incorrectly the FS will refuse to mount. The rest are smaller fixes and plugs for memory leaks." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs: (30 commits) Btrfs: fix repeated delalloc work allocation Btrfs: fix wrong max device number for single profile Btrfs: fix missed transaction->aborted check Btrfs: Add ACCESS_ONCE() to transaction->abort accesses Btrfs: put csums on the right ordered extent Btrfs: use right range to find checksum for compressed extents Btrfs: fix panic when recovering tree log Btrfs: do not allow logged extents to be merged or removed Btrfs: fix a regression in balance usage filter Btrfs: prevent qgroup destroy when there are still relations Btrfs: ignore orphan qgroup relations Btrfs: reorder locks and sanity checks in btrfs_ioctl_defrag Btrfs: fix unlock order in btrfs_ioctl_rm_dev Btrfs: fix unlock order in btrfs_ioctl_resize Btrfs: fix "mutually exclusive op is running" error code Btrfs: bring back balance pause/resume logic btrfs: update timestamps on truncate() btrfs: fix btrfs_cont_expand() freeing IS_ERR em Btrfs: fix a bug when llseek for delalloc bytes behind prealloc extents Btrfs: fix off-by-one in lseek ...
2013-01-24Merge branch 'for-next' of git://git.samba.org/sfrench/cifs-2.6Linus Torvalds
Pull cifs fixes from Steve French: "Two small cifs fixes" * 'for-next' of git://git.samba.org/sfrench/cifs-2.6: fs/cifs/cifs_dfs_ref.c: fix potential memory leakage cifs: fix srcip_matches() for ipv6
2013-01-24Merge git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull kvm fixlet from Marcelo Tosatti. * git://git.kernel.org/pub/scm/virt/kvm/kvm: KVM: PPC: Emulate dcbf
2013-01-24Merge branch 'fixes' of git://git.linaro.org/people/rmk/linux-armLinus Torvalds
Pull ARM fixes from Russell King: "A number of fixes: Patrik found a problem with preempt counting in the VFP assembly functions which can cause the preempt count to be upset. Nicolas fixed a problem with the parsing of the DT when it straddles a 1MB boundary. Subhash Jadavani reported a problem with sparsemem and our highmem support for cache maintanence for DMA areas, and TI found a bug in their strongly ordered memory mapping type. Also, three fixes by way of Will Deacon's tree from Dave Martin for instruction compatibility and Marc Zyngier to fix hypervisor boot mode issues." * 'fixes' of git://git.linaro.org/people/rmk/linux-arm: ARM: 7629/1: mm: Fix missing XN flag for for MT_MEMORY_SO ARM: DMA: Fix struct page iterator in dma_cache_maint() to work with sparsemem ARM: 7628/1: head.S: map one extra section for the ATAG/DTB area ARM: 7627/1: Predicate preempt logic on PREEMP_COUNT not PREEMPT alone ARM: virt: simplify __hyp_stub_install epilog ARM: virt: boot secondary CPUs through the right entry point ARM: virt: Avoid bx instruction for compatibility with <=ARMv4
2013-01-24Merge tag 'fixes-for-linus2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC fixes from Olof Johansson: "Here's a long-pending fixes pull request for arm-soc (I didn't send one in the -rc4 cycle). The larger deltas are from: - A fixup of error paths in the mvsdio driver - Header file move for a driver that hadn't been properly converted to multiplatform on i.MX, which was causing build failures when included - Device tree updates for at91 dealing mostly with their new pinctrl setup merged in 3.8 and mistakes in those initial configs The rest are the normal mix of small fixes all over the place; sunxi, omap, imx, mvebu, etc, etc." * tag 'fixes-for-linus2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (40 commits) mfd: vexpress-sysreg: Don't skip initialization on probe ARM: vexpress: Enable A7 cores in V2P-CA15_A7's Device Tree ARM: vexpress: extend the MPIDR range used for pen release check ARM: at91/dts: correct comment in at91sam9x5.dtsi for mii ARM: at91/at91_dt_defconfig: add at91sam9n12 SoC to DT defconfig ARM: at91/at91_dt_defconfig: remove memory specification to cmdline ARM: at91/dts: add macb mii pinctrl config for kizbox ARM: at91: rm9200: remake the BGA as default version ARM: at91: fix gpios on i2c-gpio for RM9200 DT ARM: at91/at91sam9x5 DTS: add SCK USART pins ARM: at91/at91sam9x5 DTS: correct wrong PIO BANK values on u(s)arts ARM: at91/at91-pinctrl documentation: fix typo and add some details ARM: kirkwood: fix missing #interrupt-cells property mmc: mvsdio: use devm_ API to simplify/correct error paths. clk: mvebu/clk-cpu.c: fix memory leakage ARM: OMAP2+: omap4-panda: add UART2 muxing for WiLink shared transport ARM: OMAP2+: DT node Timer iteration fix ARM: OMAP2+: Fix section warning for omap_init_ocp2scp() ARM: OMAP2+: fix build break for omapdrm ARM: OMAP2: Fix missing omap2xxx_clkt_vps_late_init function calls ...
2013-01-24Merge tag 'pm+acpi-for-3.8-rc5' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull ACPI and power management fixes from Rafael Wysocki: - Two cpuidle initialization fixes from Konrad Rzeszutek Wilk. - cpufreq regression fixes for AMD processors from Borislav Petkov, Stefan Bader, and Matthew Garrett. - ACPI cpufreq fix from Thomas Schlichter. - cpufreq and devfreq fixes related to incorrect usage of operating performance points (OPP) framework and RCU from Nishanth Menon. - APEI workaround for incorrect BIOS information from Lans Zhang. * tag 'pm+acpi-for-3.8-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: cpufreq: Add module aliases for acpi-cpufreq ACPI: Check MSR valid bit before using P-state frequencies PM / devfreq: exynos4_bus: honor RCU lock usage PM / devfreq: add locking documentation for recommended_opp cpufreq: cpufreq-cpu0: use RCU locks around usage of OPP cpufreq: OMAP: use RCU locks around usage of OPP ACPI, APEI: Fixup incorrect 64-bit access width firmware bug ACPI / processor: Get power info before updating the C-states powernow-k8: Add a kconfig dependency on acpi-cpufreq ACPI / cpuidle: Fix NULL pointer issues when cpuidle is disabled intel_idle: Don't register CPU notifier if we are not running.
2013-01-24Merge tag 'regmap-fix-3.8-rc4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regmap Pull regmap fixes from Mark Brown: "One more oversight in the debugfs code was reported and fixed, plus a documentation fix." * tag 'regmap-fix-3.8-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regmap: regmap: fix small typo in regmap_bulk_write comment regmap: debugfs: Fix seeking from the cache
2013-01-24Merge branch 'fixes' of git://git.infradead.org/users/vkoul/slave-dmaLinus Torvalds
Pull slave-dmaengine fixes from Vinod Koul: "A few fixes on slave dmanengine. There are trivial fixes in imx-dma, tegra-dma & ioat driver" * 'fixes' of git://git.infradead.org/users/vkoul/slave-dma: dma: tegra: implement flags parameters for cyclic transfer dmaengine: imx-dma: Disable use of hw_chain to fix sg_dma transfers. ioat: Fix DMA memory sync direction correct flag
2013-01-24Merge branch 'i2c-embedded/for-current' of ↵Linus Torvalds
git://git.pengutronix.de/git/wsa/linux Pill i2c fixes from Wolfram Sang: "Here are a few, typical driver fixes for the I2C subsystem" * 'i2c-embedded/for-current' of git://git.pengutronix.de/git/wsa/linux: i2c-designware: add missing MODULE_LICENSE i2c: omap: fix draining irq handling i2c: omap: errata i462: fix incorrect ack for arbitration lost interrupt i2c: muxes: fix wrong use of sizeof(ptr) i2c: sirf: register i2c_client from dt child-nodes in probe entry i2c: mxs: Fix type of error code i2c: mxs: Fix misuse init_completion
2013-01-24Btrfs: fix repeated delalloc work allocationMiao Xie
btrfs_start_delalloc_inodes() locks the delalloc_inodes list, fetches the first inode, unlocks the list, triggers btrfs_alloc_delalloc_work/ btrfs_queue_worker for this inode, and then it locks the list, checks the head of the list again. But because we don't delete the first inode that it deals with before, it will fetch the same inode. As a result, this function allocates a huge amount of btrfs_delalloc_work structures, and OOM happens. Fix this problem by splice this delalloc list. Reported-by: Alex Lyakas <alex.btrfs@zadarastorage.com> Signed-off-by: Miao Xie <miaox@cn.fujitsu.com> Signed-off-by: Josef Bacik <jbacik@fusionio.com>
2013-01-24Btrfs: fix wrong max device number for single profileMiao Xie
The max device number of single profile is 1, not 0 (0 means 'as many as possible'). Fix it. Cc: Liu Bo <bo.li.liu@oracle.com> Signed-off-by: Miao Xie <miaox@cn.fujitsu.com> Reviewed-by: Liu Bo <bo.li.liu@oracle.com> Signed-off-by: Josef Bacik <jbacik@fusionio.com>
2013-01-24Btrfs: fix missed transaction->aborted checkMiao Xie
First, though the current transaction->aborted check can stop the commit early and avoid unnecessary operations, it is too early, and some transaction handles don't end, those handles may set transaction->aborted after the check. Second, when we commit the transaction, we will wake up some worker threads to flush the space cache and inode cache. Those threads also allocate some transaction handles and may set transaction->aborted if some serious error happens. So we need more check for ->aborted when committing the transaction. Fix it. Signed-off-by: Miao Xie <miaox@cn.fujitsu.com> Signed-off-by: Josef Bacik <jbacik@fusionio.com>
2013-01-24Btrfs: Add ACCESS_ONCE() to transaction->abort accessesMiao Xie
We may access and update transaction->aborted on the different CPUs without lock, so we need ACCESS_ONCE() wrapper to prevent the compiler from creating unsolicited accesses and make sure we can get the right value. Signed-off-by: Miao Xie <miaox@cn.fujitsu.com> Signed-off-by: Josef Bacik <jbacik@fusionio.com>
2013-01-24Btrfs: put csums on the right ordered extentJosef Bacik
I noticed a WARN_ON going off when adding csums because we were going over the amount of csum bytes that should have been allowed for an ordered extent. This is a leftover from when we used to hold the csums privately for direct io, but now we use the normal ordered sum stuff so we need to make sure and check if we've moved on to another extent so that the csums are added to the right extent. Without this we could end up with csums for bytenrs that don't have extents to cover them yet. Thanks, Signed-off-by: Josef Bacik <jbacik@fusionio.com>
2013-01-24Btrfs: use right range to find checksum for compressed extentsLiu Bo
For compressed extents, the range of checksum is covered by disk length, and the disk length is different with ram length, so we need to use disk length instead to get us the right checksum. Signed-off-by: Liu Bo <bo.li.liu@oracle.com> Signed-off-by: Josef Bacik <jbacik@fusionio.com>
2013-01-24Btrfs: fix panic when recovering tree logJosef Bacik
A user reported a BUG_ON(ret) that occured during tree log replay. Ret was -EAGAIN, so what I think happened is that we removed an extent that covered a bitmap entry and an extent entry. We remove the part from the bitmap and return -EAGAIN and then search for the next piece we want to remove, which happens to be an entire extent entry, so we just free the sucker and return. The problem is ret is still set to -EAGAIN so we trip the BUG_ON(). The user used btrfs-zero-log so I'm not 100% sure this is what happened so I've added a WARN_ON() to catch the other possibility. Thanks, Reported-by: Jan Steffens <jan.steffens@gmail.com> Signed-off-by: Josef Bacik <jbacik@fusionio.com>
2013-01-24Btrfs: do not allow logged extents to be merged or removedJosef Bacik
We drop the extent map tree lock while we're logging extents, so somebody could come in and merge another extent into this one and screw up our logging, or they could even remove us from the list which would keep us from logging the extent or freeing our ref on it, so we need to make sure to not clear LOGGING until after the extent is logged, and then we can merge it to adjacent extents. Thanks, Signed-off-by: Josef Bacik <jbacik@fusionio.com>
2013-01-24Merge branch 'vexpress/fixes' of git://git.linaro.org/people/pawelmoll/linux ↵Olof Johansson
into fixes From Pawel Moll: - makes the V2P-CA15_A7 (a.k.a. TC2) work with 3.8 kernels - improves vexpress-sysreg.c behaviour on arm64 platforms * 'vexpress/fixes' of git://git.linaro.org/people/pawelmoll/linux: mfd: vexpress-sysreg: Don't skip initialization on probe ARM: vexpress: Enable A7 cores in V2P-CA15_A7's Device Tree ARM: vexpress: extend the MPIDR range used for pen release check
2013-01-24Merge tag 'at91-fixes' of git://github.com/at91linux/linux-at91 into fixesOlof Johansson
From Nicolas Ferre: Here are fixes for AT91 that are mainly related to device tree. One RM9200 setup option is the only C code change. Some documentation changes can clarify the pinctrl use. Then, some defconfig modifications are allowing the affected platforms to boot. * tag 'at91-fixes' of git://github.com/at91linux/linux-at91: ARM: at91/dts: correct comment in at91sam9x5.dtsi for mii ARM: at91/at91_dt_defconfig: add at91sam9n12 SoC to DT defconfig ARM: at91/at91_dt_defconfig: remove memory specification to cmdline ARM: at91/dts: add macb mii pinctrl config for kizbox ARM: at91: rm9200: remake the BGA as default version ARM: at91: fix gpios on i2c-gpio for RM9200 DT ARM: at91/at91sam9x5 DTS: add SCK USART pins ARM: at91/at91sam9x5 DTS: correct wrong PIO BANK values on u(s)arts ARM: at91/at91-pinctrl documentation: fix typo and add some details
2013-01-24mfd: vexpress-sysreg: Don't skip initialization on probePawel Moll
The vexpress-sysreg driver does not have to be initialized early, when the platform doesn't require this. Unfortunately in such case it wasn't initialized correctly - master site lookup and config bridge registration were missing. Fixed now. Signed-off-by: Pawel Moll <pawel.moll@arm.com>
2013-01-24ARM: vexpress: Enable A7 cores in V2P-CA15_A7's Device TreePawel Moll
As the kernel is able to cope with multiple clusters, uncomment the A7 cores in the Device Tree for V2P-CA15_A7 tile, making all 5 cores available to the user. Signed-off-by: Pawel Moll <pawel.moll@arm.com>
2013-01-24ARM: vexpress: extend the MPIDR range used for pen release checkLorenzo Pieralisi
In ARM multi-cluster systems the MPIDR affinity level 0 cannot be used as a single cpu identifier, affinity levels 1 and 2 must be taken into account as well. This patch extends the MPIDR usage to affinity levels 1 and 2 in versatile secondary cores start up code in order to compare the passed pen_release value with the full-blown affinity mask. Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com> Signed-off-by: Liviu Dudau <liviu.dudau@arm.com> Acked-by: Nicolas Pitre <nico@linaro.org> Signed-off-by: Pawel Moll <pawel.moll@arm.com>
2013-01-24Merge remote-tracking branch 'regmap/fix/debugfs' into tmpMark Brown
2013-01-23Merge tag 'imx-fixes-3.8-3' of ↵Olof Johansson
git://git.linaro.org/people/shawnguo/linux-2.6 into fixes From Shawn Guo: This is yet another critical imxfb fixes held off by absence of FB maintainer for some time. * tag 'imx-fixes-3.8-3' of git://git.linaro.org/people/shawnguo/linux-2.6: video: imxfb: Do not crash on reboot
2013-01-23Merge tag 'mvebu_fixes_for_v3.8-rc5' of ↵Olof Johansson
git://git.infradead.org/users/jcooper/linux into fixes From Jason Cooper: mvebu fixes for v3.8-rc5 - fix memory leak in mvebu/clk-cpu.c - use devm_ to correct/simplify error paths in mvsdio - add missing #interrupt-cells property in kirkwood * tag 'mvebu_fixes_for_v3.8-rc5' of git://git.infradead.org/users/jcooper/linux: ARM: kirkwood: fix missing #interrupt-cells property mmc: mvsdio: use devm_ API to simplify/correct error paths. clk: mvebu/clk-cpu.c: fix memory leakage
2013-01-23Merge tag 'usb-3.8-rc4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb Pull more USB fixes from Greg Kroah-Hartman: "Here are some more USB fixes for the 3.8-rc4 tree. Some gadget driver fixes, and finally resolved the ehci-mxc driver build issues (it's just some code moving around and being deleted)." * tag 'usb-3.8-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: USB: EHCI: fix build error in ehci-mxc USB: EHCI: add a name for the platform-private field USB: EHCI: fix incorrect configuration test USB: EHCI: Move definition of EHCI_STATS to ehci.h USB: UHCI: fix IRQ race during initialization usb: gadget: FunctionFS: Fix missing braces in parse_opts usb: dwc3: gadget: fix ep->maxburst for ep0 ARM: i.MX clock: Change the connection-id for fsl-usb2-udc usb: gadget: fsl_mxc_udc: replace MX35_IO_ADDRESS to ioremap usb: gadget: fsl-mxc-udc: replace cpu_is_xxx() with platform_device_id usb: musb: cppi_dma: drop '__init' annotation
2013-01-23Merge tag 'char-misc-3.8-rc4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc Pull drivers/misc fix from Greg Kroah-Hartman: "Here is a single revert for the ti-st misc driver, fixing problem that was introduced in 3.7-rc1 that has been bothering people." * tag 'char-misc-3.8-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: Revert "drivers/misc/ti-st: remove gpio handling"
