Reduce the latency target from 20 msecs to 5 msecs.
Why? Larger latencies increase spread, which is good for scaling,
but bad for worst case latency.
We still have the ilog(nr_cpus) rule to scale up on bigger
server boxes.
Signed-off-by: Mike Galbraith <efault@gmx.de>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
LKML-Reference: <1252486344.28645.18.camel@marge.simson.net>
Set child_runs_first default to off.
It hurts 'optimal' make -j<NR_CPUS> workloads as make jobs
get preempted by child tasks, reducing parallelism.
Note, this patch might make existing races in user
applications more prominent than before - so breakages
might be bisected to this commit.
Child-runs-first is broken on SMP to begin with, and we
already had it off briefly in v2.6.23 so most of the
offenders ought to be fixed. Would be nice not to revert
this commit but fix those apps finally ...
[ made the sysctl independent of CONFIG_SCHED_DEBUG, in case
people want to work around broken apps. ]
A fork/exec load is usually "pass the baton", so the child
should never be placed behind the parent. With START_DEBIT we
make room for the new task, but with child_runs_first, that
room comes out of the _parent's_ hide. There's nothing to say
that the parent wasn't ahead of min_vruntime at fork() time,
which means that the "baton carrier", who is essentially the
parent in drag, can gain time and increase scheduling latencies
for waiters.
With NEW_FAIR_SLEEPERS + START_DEBIT + child_runs_first
enabled, we essentially pass the sleeper fairness off to the
child, which is fine, but if we don't base placement on the
parent's updated vruntime, we can end up compounding latency
woes if the child itself then does fork/exec. The debit
incurred at fork doesn't hurt the parent who is then going to
sleep and maybe exit, but the child who acquires the error
harms all comers.
This improves latencies of make -j<n> kernel build workloads.
Reported-by: Jens Axboe <jens.axboe@oracle.com>
LKML-Reference: <new-submission>
Now that SD_WAKE_IDLE doesn't make pipe-test suck anymore,
enable it by default for MC, CPU and NUMA domains.
wake_affine() would always fail under low-load situations where
both prev and this were idle, because adding a single task will
always be a significant imbalance, even if there's nothing
around that could balance it.
Deal with this by allowing imbalance when there's nothing you
can do about it.
select_task_rq_fair() incorrectly skips the wake_affine()
logic, remove this.
When prev_cpu == this_cpu, the code jumps straight to the
wake_idle() logic, this doesn't give the wake_affine() logic
the chance to pin the task to this cpu.
Start the re-tuning of the balancer by turning on newidle.
It improves hackbench performance and parallelism on a 4x4 box.
The "perf stat --repeat 10" measurements give us:
domain0 domain1
-SD_BALANCE_NEWIDLE -SD_BALANCE_NEWIDLE:
2041.273208 task-clock-msecs # 9.354 CPUs ( +- 0.363% )
+SD_BALANCE_NEWIDLE -SD_BALANCE_NEWIDLE:
2086.326925 task-clock-msecs # 11.934 CPUs ( +- 0.301% )
+SD_BALANCE_NEWIDLE +SD_BALANCE_NEWIDLE:
2115.289791 task-clock-msecs # 12.158 CPUs ( +- 0.263% )
Cc: Andreas Herrmann <andreas.herrmann3@amd.com>
Cc: Gautham R Shenoy <ego@in.ibm.com>
Cc: Balbir Singh <balbir@in.ibm.com>
Re-organize the flag settings so that it's visible at a glance
which sched-domains flags are set and which not.
With the new balancer code we'll need to re-tune these details
anyway, so make it cleaner to make fewer mistakes down the
road ;-)
This crash:
[ 1774.088275] divide error: 0000 [#1] SMP
[ 1774.100355] CPU 13
[ 1774.102498] Modules linked in:
[ 1774.105631] Pid: 30881, comm: hackbench Not tainted 2.6.31-rc8-tip-01308-g484d664-dirty #1629 X8DTN
[ 1774.114807] RIP: 0010:[<ffffffff81041c38>] [<ffffffff81041c38>]
sched_balance_self+0x19b/0x2d4
Triggers because update_group_power() modifies the sd tree and does
temporary calculations there - not considering that other CPUs
could observe intermediate values, such as the zero initial value.
Calculate it in a temporary variable instead. (we need no memory
barrier as these are all statistical values anyway)
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
LKML-Reference: <20090904092742.GA11014@elte.hu>
Its a source of fail, also, now that cpu_power is dynamical,
its a waste of time.
before:
<idle>-0 [000] 132.877936: find_busiest_group: avg_load: 0 group_load: 8241 power: 1
after:
bash-1689 [001] 137.862151: find_busiest_group: avg_load: 10636288 group_load: 10387 power: 1
[ v2: build fix from From: Andreas Herrmann ]
Tested-by: Andreas Herrmann <andreas.herrmann3@amd.com>
Acked-by: Andreas Herrmann <andreas.herrmann3@amd.com>
Acked-by: Gautham R Shenoy <ego@in.ibm.com>
LKML-Reference: <20090901083826.425896304@chello.nl>
sgs.group_capacity can now be 0, if for some reason
group->__cpu_power happens to be less than SCHED_LOAD_SCALE/2.
In that case, we need the following fix to make it work for
update_sd_power_savings_stats(). That's because both
sum_nr_running and group_capacity are unsigned longs.
When the capacity drops low, we want to migrate load away.
Allow the load-balancer to remove all tasks when we hit rock
bottom.
LKML-Reference: <20090901083826.342231003@chello.nl>
Keep an average on the amount of time spend on RT tasks and use
that fraction to scale down the cpu_power for regular tasks.
LKML-Reference: <20090901083826.287778431@chello.nl>
Recompute the cpu_power for each cpu during load-balance.
LKML-Reference: <20090901083826.162033479@chello.nl>
The idea is that multi-threading a core yields more work
capacity than a single thread, provide a way to express a
static gain for threads.
LKML-Reference: <20090901083826.073345955@chello.nl>
In order to prepare for a more dynamic cpu_power, update the
group sum while walking the sched domains during load-balance.
LKML-Reference: <20090901083825.985050292@chello.nl>
Do the placement thing using SD flags.
LKML-Reference: <20090901083825.897028974@chello.nl>
cpu_power is supposed to be a representation of the process
capacity of the cpu, not a value to randomly tweak in order to
affect placement.
Remove the placement hacks.
LKML-Reference: <20090901083825.810860576@chello.nl>
Merge reason: both topics are ready now, and we want to merge dependent
changes.
Add 3 schedstat tracepoints to help account for wait-time,
sleep-time and iowait-time.
They can also be used as a perf-counter source to profile tasks
on these clocks.
Cc: Arjan van de Ven <arjan@linux.intel.com>
[ build fix for the !CONFIG_SCHEDSTATS case ]
For counting how long an application has been waiting for
(disk) IO, there currently is only the HZ sample driven
information available, while for all other counters in this
class, a high resolution version is available via
CONFIG_SCHEDSTATS.
In order to make an improved bootchart tool possible, we also
need a higher resolution version of the iowait time.
This patch below adds this scheduler statistic to the kernel.
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
LKML-Reference: <4A64B813.1080506@linux.intel.com>
Merge reason: bump from rc5 to rc8, but also pick up TP_perf_assign()
API, a patch will be queued that depends on it.
... so that it does not share a common name with a function
within the same scope.
Signed-off-by: Anirban Sinha <asinha@zeugmasystems.com>
LKML-Reference: <DDFD17CC94A9BD49A82147DDF7D545C501EA98A6@exchange.ZeugmaSystems.local>
When re-computing the shares for each task group's cpu
representation we need the ratio of weight on each cpu vs the
total weight of the sched domain.
Since load-balancing is loosely (read not) synchronized, the
weight of individual cpus can change between doing the sum and
calculating the ratio.
The previous patch dealt with only one of the race scenarios,
this patch side steps them all by saving a snapshot of all the
individual cpu weights, thereby always working on a consistent
set.
Cc: torvalds@linux-foundation.org
Cc: jes@sgi.com
Cc: jens.axboe@oracle.com
Cc: Balbir Singh <balbir@linux.vnet.ibm.com>
Cc: Arjan van de Ven <arjan@infradead.org>
Cc: Yinghai Lu <yinghai@kernel.org>
LKML-Reference: <1251371336.18584.77.camel@twins>
The root cause is a duplicate section name (.text); is this legal?
[ Amerigo Wang: "AFAIK, yes." ]
However, there's a problem with commit
6d76013381ed28979cd122eb4b249a88b5e384fa in that if you fail to allocate
a mod->sect_attrs (in this case it's null because of the duplication),
it still gets used without checking in add_notes_attrs()
This should fix it
[ This patch leaves other problems, particularly the sections directory,
but recent parisc toolchains seem to produce these modules and this
prevents a crash and is a minimal change -- RR ]
Signed-off-by: James Bottomley <James.Bottomley@suse.de>
Tested-by: Helge Deller <deller@gmx.de>
The rarely-used symbol_put_addr() needs to use dereference_function_descriptor
on powerpc.
Reported-by: Paul Mackerras <paulus@samba.org>
Signed-off-by: Rusty Russell <rusty@rustcorp.com.au.
As soon as the framebuffer is registered, our methods may be called by the
kernel. This leads to a crash as xenfb_refresh() gets called before we have
the irq.
Connect to the backend before registering our framebuffer with the kernel.
[ Fixes bug http://bugzilla.kernel.org/show_bug.cgi?id=14059 ]
Signed-off-by: Michal Schmidt <mschmidt@redhat.com>
Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
* 'for-linus' of git://git.infradead.org/users/eparis/notify:
inotify: Ensure we alwasy write the terminating NULL.
inotify: fix locking around inotify watching in the idr
inotify: do not BUG on idr entries at inotify destruction
inotify: seperate new watch creation updating existing watches
We call lmb_end_of_DRAM() to test whether a DMA mask is ok on a machine
without IOMMU, but this function is marked as __init.
I don't think there's a clean way to get the top of RAM max_pfn doesn't
appear to include highmem or I missed (or we have a bug :-) so for now,
let's just avoid having a broken 2.6.31 by making this function
non-__init and we can revisit later.
git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs:
9p: update documentation pointers
9p: remove unnecessary v9fses->options which duplicates the mount string
net/9p: insulate the client against an invalid error code sent by a 9p server
9p: Add missing cast for the error return value in v9fs_get_inode
9p: Remove redundant inode uid/gid assignment
9p: Fix possible regressions when ->get_sb fails.
9p: Fix v9fs show_options
9p: Fix possible memleak in v9fs_inode_from fid.
9p: minor comment fixes
9p: Fix possible inode leak in v9fs_get_inode.
9p: Check for error in return value of v9fs_fid_add
Add a check in ip_append_data() for NULL *rtp to prevent future bugs in
callers from being exploitable.
Signed-off-by: Julien Tinnes <julien@cr0.org>
Signed-off-by: Tavis Ormandy <taviso@sdf.lonestar.org>
kAFS crashes when asked to read a symbolic link because page_getlink()
passes a NULL file pointer to read_mapping_page(), but afs_readpage()
expects a file pointer from which to extract a key.
Modify afs_readpage() to request the appropriate key from the calling
process's keyrings if a file struct is not supplied with one attached.
Acked-by: Anton Blanchard <anton@samba.org>
Some architectures initialize clocks and timers in late_time_init and
x86 wants to do the same to avoid FIXMAP hackery for calibrating the
TSC. That would result in undefined sched_clock readout and wreckaged
printk timestamps again. We probably have those already on archs which
do all their time/clock setup in late_time_init.
There is no harm to move that after late_time_init except that a few
more boot timestamps are stale. The scheduler is not active at that
point so no real wreckage is expected.
Before the rewrite copy_event_to_user always wrote a terqminating '\0'
byte to user space after the filename. Since the rewrite that
terminating byte was skipped if your filename is exactly a multiple of
event_size. Ouch!
So add one byte to name_size before we round up and use clear_user to
set userspace to zero like /dev/zero does instead of copying the
strange nul_inotify_event. I can't quite convince myself len_to_zero
will never exceed 16 and even if it doesn't clear_user should be more
efficient and a more accurate reflection of what the code is trying to
do.
Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com>
Signed-off-by: Eric Paris <eparis@redhat.com>
The are races around the idr storage of inotify watches. It's possible
that a watch could be found from sys_inotify_rm_watch() in the idr, but it
could be removed from the idr before that code does it's removal. Move the
locking and the refcnt'ing so that these have to happen atomically.
If an inotify watch is left in the idr when an fsnotify group is destroyed
this will lead to a BUG. This is not a dangerous situation and really
indicates a programming bug and leak of memory. This patch changes it to
use a WARN and a printk rather than killing people's boxes.
There is nothing known wrong with the inotify watch addition/modification
but this patch seperates the two code paths to make them each easy to
verify as correct.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6:
virtio: net refill on out-of-memory
smc91x: fix compilation on SMP
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc
* 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc:
powerpc/ps3: Update ps3_defconfig
powerpc/ps3: Add missing check for PS3 to rtc-ps3 platform device registration
Update ps3_defconfig.
o Refresh for 2.6.31.
o Remove MTD support.
o Add more HID drivers.
Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com>
On non-PS3, we get:
| kernel BUG at drivers/rtc/rtc-ps3.c:36!
because the rtc-ps3 platform device is registered unconditionally in a kernel
with builtin support for PS3.
Reported-by: Sachin Sant <sachinp@in.ibm.com>
Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com>
Acked-by: Geoff Levand <geoffrey.levand@am.sony.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6:
IMA: iint put in ima_counts_get and put
git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k:
m68k,m68knommu: Wire up rt_tgsigqueueinfo and perf_counter_open
m68k: Fix redefinition of pgprot_noncached
arch/m68k/include/asm/motorola_pgalloc.h: fix kunmap arg
m68k: cnt reaches -1, not 0
m68k: count can reach 51, not 50
If we change the inverted attribute to another value, the LED will not be
inverted until we change the GPIO state.
Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@holoscopio.com>
Cc: Samuel R. C. Vale <srcvale@holoscopio.com>
Cc: Richard Purdie <rpurdie@rpsys.net>
When setting the same GPIO number, multiple IRQ shared requests will be
done without freing the previous request. It will also try to free a
failed request or an already freed IRQ if 0 was written to the gpio file.
All these oops and leaks were fixed with the following solution: keep the
previous allocated GPIO (if any) still allocated in case the new request
fails. The alternative solution would desallocate the previous allocated
GPIO and set gpio as 0.
Signed-off-by: Samuel R. C. Vale <srcvale@holoscopio.com>
This failure is very common on many platforms. Handling it in the ACPI
processor driver is enough, and we don't need a warning message unless
CONFIG_ACPI_DEBUG is set.
Based on a patch from Zhang Rui.
Addresses http://bugzilla.kernel.org/show_bug.cgi?id=13389
Signed-off-by: Frans Pop <elendil@planet.nl>
Acked-by: Zhang Rui <rui.zhang@intel.com>
Cc: Len Brown <lenb@kernel.org>
Cc: "Rafael J. Wysocki" <rjw@sisk.pl>
If the BIOS reports an invalid throttling state (which seems to be
fairly common after system boot), a reset is done to state T0.
Because of a check in acpi_processor_get_throttling_ptc(), the reset
never actually gets executed, which results in the error reoccurring
on every access of for example /proc/acpi/processor/CPU0/throttling.
Add a 'force' option to acpi_processor_set_throttling() to ensure
the reset really takes effect.
This patch, together with the next one, fixes a regression introduced in
2.6.30, listed on the regression list. They have been available for 2.5
months now in bugzilla, but have not been picked up, despite various
reminders and without any reason given.
Google shows that numerous people are hitting this issue. The issue is in
itself relatively minor, but the bug in the code is clear.
The patches have been in all my kernels and today testing has shown that
throttling works correctly with the patches applied when the system
overheats (http://bugzilla.kernel.org/show_bug.cgi?id=13918#c14).
Summary:
Kernel panic arise when stack protection is enabled, since strncat will
add a null terminating byte '\0'; So in functions
like this one (wmi_query_block):
char wc[4]="WC";
strncat(method, block->object_id, 2);
the length of wc should be n+1 (wc[5]) or stack protection
fault will arise. This is not noticeable when stack protection is
disabled,but , isn't good either.
Config used: [CONFIG_CC_STACKPROTECTOR_ALL=y,
CONFIG_CC_STACKPROTECTOR=y]
Panic Trace
.... stack-protector: kernel stack corrupted in : fa7b182c
2.6.30-rc8-obelisco-generic
call_trace:
[<c04a6c40>] ? panic+0x45/0xd9
[<c012925d>] ? __stack_chk_fail+0x1c/0x40
[<fa7b182c>] ? wmi_query_block+0x15a/0x162 [wmi]
[<fa7e7000>] ? acer_wmi_init+0x00/0x61a [acer_wmi]
[<fa7e7135>] ? acer_wmi_init+0x135/0x61a [acer_wmi]
[<c0101159>] ? do_one_initcall+0x50+0x126
Addresses http://bugzilla.kernel.org/show_bug.cgi?id=13514
Signed-off-by: Costantino Leandro <lcostantino@gmail.com>
Signed-off-by: Carlos Corbacho <carlos@strangeworlds.co.uk>
Cc: Len Brown <len.brown@intel.com>
Cc: Bjorn Helgaas <bjorn.helgaas@hp.com>
Cc: <stable@kernel.org>
Jens reported early_ioremap messages with old ASUS board...
> [ 1.507461] pci 0000:00:09.0: Firmware left e100 interrupts enabled; disabling
> [ 1.532778] early_ioremap(3fffd080, 0000005c) [0] => Pid: 1, comm: swapper Not tainted 2.6.31-rc4 #36
> [ 1.561007] Call Trace:
> [ 1.568638] [<c136e48b>] ? printk+0x18/0x1d
> [ 1.581734] [<c15513ff>] __early_ioremap+0x74/0x1e9
> [ 1.596898] [<c15515aa>] early_ioremap+0x1a/0x1c
> [ 1.611270] [<c154a187>] __acpi_map_table+0x18/0x1a
> [ 1.626451] [<c135a7f8>] acpi_os_map_memory+0x1d/0x25
> [ 1.642129] [<c119459c>] acpi_tb_verify_table+0x20/0x49
> [ 1.658321] [<c1193e50>] acpi_get_table_with_size+0x53/0xa1
> [ 1.675553] [<c1193eae>] acpi_get_table+0x10/0x15
> [ 1.690192] [<c155cc19>] acpi_processor_init+0x23/0xab
> [ 1.706126] [<c1001043>] do_one_initcall+0x33/0x180
> [ 1.721279] [<c155cbf6>] ? acpi_processor_init+0x0/0xab
> [ 1.737479] [<c106893a>] ? register_irq_proc+0xaa/0xc0
> [ 1.753411] [<c10689b7>] ? init_irq_proc+0x67/0x80
> [ 1.768316] [<c15405e7>] kernel_init+0x120/0x176
> [ 1.782678] [<c15404c7>] ? kernel_init+0x0/0x176
> [ 1.797062] [<c10038b7>] kernel_thread_helper+0x7/0x10
> [ 1.812984] 00000080 + ffe00000
that is rather later.
acpi_gbl_permanent_mmap should be set in acpi_early_init()
if acpi is not disabled
and we have
> [ 0.000000] ASUS P2B-DS detected: force use of acpi=ht
just don't load acpi_processor_init...
Reported-and-tested-by: Jens Rosenboom <jens@leia.mcbone.net>
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
