2010-10-29new helper: mount_bdev()Al Viro
... and switch of the obvious get_sb_bdev() users to ->mount() Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-29beginning of transtion: ->mount()Al Viro
eventual replacement for ->get_sb() - does *not* get vfsmount, return ERR_PTR(error) or root of subtree to be mounted. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-29fix open/umount raceAl Viro
nameidata_to_filp() drops nd->path or transfers it to opened file. In the former case it's a Bad Idea(tm) to do mnt_drop_write() on nd->path.mnt, since we might race with umount and vfsmount in question might be gone already. Fix: don't drop it, then... IOW, have nameidata_to_filp() grab nd->path in case it transfers it to file and do path_drop() in callers. After they are through with accessing nd->path... Reported-by: Miklos Szeredi <miklos@szeredi.hu> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-29a couple of open-coded ihold() introduced by nfs mergeAl Viro
2010-10-28Merge branch 'stable/xen-pcifront-0.8.2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen and branch 'for-linus' of git://xenbits.xen.org/people/sstabellini/linux-pvhvm * 'for-linus' of git://xenbits.xen.org/people/sstabellini/linux-pvhvm: xen: register xen pci notifier xen: initialize cpu masks for pv guests in xen_smp_init xen: add a missing #include to arch/x86/pci/xen.c xen: mask the MTRR feature from the cpuid xen: make hvc_xen console work for dom0. xen: add the direct mapping area for ISA bus access xen: Initialize xenbus for dom0. xen: use vcpu_ops to setup cpu masks xen: map a dummy page for local apic and ioapic in xen_set_fixmap xen: remap MSIs into pirqs when running as initial domain xen: remap GSIs as pirqs when running as initial domain xen: introduce XEN_DOM0 as a silent option xen: map MSIs into pirqs xen: support GSI -> pirq remapping in PV on HVM guests xen: add xen hvm acpi_register_gsi variant acpi: use indirect call to register gsi in different modes xen: implement xen_hvm_register_pirq xen: get the maximum number of pirqs from xen xen: support pirq != irq * 'stable/xen-pcifront-0.8.2' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: (27 commits) X86/PCI: Remove the dependency on isapnp_disable. xen: Update Makefile with CONFIG_BLOCK dependency for biomerge.c MAINTAINERS: Add myself to the Xen Hypervisor Interface and remove Chris Wright. x86: xen: Sanitse irq handling (part two) swiotlb-xen: On x86-32 builts, select SWIOTLB instead of depending on it. MAINTAINERS: Add myself for Xen PCI and Xen SWIOTLB maintainer. xen/pci: Request ACS when Xen-SWIOTLB is activated. xen-pcifront: Xen PCI frontend driver. xenbus: prevent warnings on unhandled enumeration values xenbus: Xen paravirtualised PCI hotplug support. xen/x86/PCI: Add support for the Xen PCI subsystem x86: Introduce x86_msi_ops msi: Introduce default_[teardown|setup]_msi_irqs with fallback. x86/PCI: Export pci_walk_bus function. x86/PCI: make sure _PAGE_IOMAP it set on pci mappings x86/PCI: Clean up pci_cache_line_size xen: fix shared irq device passthrough xen: Provide a variant of xen_poll_irq with timeout. xen: Find an unbound irq number in reverse order (high to low). xen: statically initialize cpu_evtchn_mask_p ... Fix up trivial conflicts in drivers/pci/Makefile
2010-10-28Merge branch 'packaging' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'packaging' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: scripts/package: don't break if %{_smp_mflags} isn't set kbuild, deb-pkg: Check if KBUILD_IMAGE exists before copying it
2010-10-28Merge branch 'misc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'misc' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: (39 commits) Revert "namespace: add source file location exceptions" Coccinelle: Add contextual message Coccinelle: Fix documentation Coccinelle: Find doubled arguments to boolean or bit operators. Coccinelle: Find nested lock+irqsave functions that use the same flags variables. namespace: add source file location exceptions scripts/extract-ikconfig: add support for bzip2, lzma and lzo kbuild: check return value of asprintf() scripts/namespace.pl: improve to get more correct results scripts/namespace.pl: some bug fixes scripts/namespace.pl: update file exclusion list scripts/namespace.pl: fix wrong source path Coccinelle: Use the -no_show_diff option for org and report mode Coccinelle: Add a new mode named 'chain' Coccinelle: Use new comment format to explain kfree.cocci Coccinelle: Improve user information with a new kind of comment Coccinelle: Update documentation MAINTAINERS: Coccinelle: Update email address Documentation/kbuild: modules.txt cleanup Documentation/kbuild: major edit of modules.txt sections 5-8 ...
2010-10-28Merge branch 'kconfig' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'kconfig' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: (38 commits) kbuild: convert `arch/tile' to the kconfig mainmenu upgrade README: cite nconfig Revert "kconfig: Temporarily disable dependency warnings" kconfig: Use PATH_MAX instead of 128 for path buffer sizes. kconfig: Fix realloc usage() kconfig: Propagate const kconfig: Don't go out from read config loop when you read new symbol kconfig: fix menuconfig on debian lenny kbuild: migrate all arch to the kconfig mainmenu upgrade kconfig: expand file names kconfig: use the file's name of sourced file kconfig: constify file name kconfig: don't emit warning upon rootmenu's prompt redefinition kconfig: replace KERNELVERSION usage by the mainmenu's prompt kconfig: delay gconf window initialization kconfig: expand by default the rootmenu's prompt kconfig: add a symbol string expansion helper kconfig: regen parser kconfig: implement the `mainmenu' directive kconfig: allow PACKAGE to be defined on the compiler's command-line ... Fix up trivial conflict in arch/mn10300/Kconfig
2010-10-28Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6 * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6: (73 commits) power: Revert "power_supply: Mark twl4030_charger as broken" mfd: Fix a memory leak when unload mc13xxx-core module mfd: Fix resource reclaim for max8998 mfd: Remove unneeded ret value checking for max8998 register updates mfd: Add free max8998->ono irq in max8998_irq_exit() mfd: Fix resource reclaim in pcf50633_remove() omap4: pandaboard: fix up mmc card detect logic mfd: Fix ezx_pcap_probe error path mfd: Fix off-by-one value range checking for tps6507x mfd: Remove __devinitdata from tc6393xb_mmc_resources mfd: Add WM831x SPI support mfd: Factor out WM831x I2C I/O from the core driver mfd: Remove DEBUG defines from mc13xxx-core mfd: Fix jz4740_adc_set_enabled mfd: Add TPS658621C device ID mfd: Fix twl-irq function declaration warnings regulator: max8998 BUCK1/2 voltage change with use of GPIOs mfd: Voltages and GPIOs platform_data definitions for max8998 regulator: max8998 BUCK1/2 internal voltages and indexes defined mfd: Support for ICs compliant with max8998 ...
2010-10-28Merge git://git.kernel.org/pub/scm/linux/kernel/git/wim/linux-2.6-watchdogLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/wim/linux-2.6-watchdog: watchdog: iTCO_wdt.c: remove extra pci_dev_put()'s from init code watchdog: add support for Broadcom BCM63xx built-in watchdog watchdog: f71808e_wdt: add support for the F71889FG watchdog: MachZ: fix debug macro watchdog: it8712f_wdt: Add module parameter for alternative reset sources watchdog: it8712f_wdt: Add comments for config/control register names watchdog: it87_wdt: Add support for watchdogs with 8b timers watchdog: it87_wdt: Add support for IT8720F watchdog watchdog: Use static const char * const where possible watchdog: iTCO_wdt: Cleanup warning messages watchdog: iTCO_wdt: TCO Watchdog patch for Intel Patsburg DeviceIDs
2010-10-28Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: ext4: BUG_ON fix: check if page has buffers before calling page_buffers()
2010-10-28watchdog: iTCO_wdt.c: remove extra pci_dev_put()'s from init codePrarit Bhargava
The iTCO_wdt driver erroneously releases the pci_dev, and causes PCI hotremove to fail because of an incorrect usage count. The probe for this driver does a for_each_pci_dev() which gets a reference for a pci_dev when iTCO_wdt_init() is successful. The for_each_pci_dev() loop puts a reference for a pci_dev when iTCO_wdt_init() fails, so the iTCO_wdt_init() does not need to do any pci_dev_put()'s. The only pci_dev_put() that is required is in the iTCO_wdt_cleanup() function. Signed-off-by: Prarit Bhargava <prarit@redhat.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2010-10-29power: Revert "power_supply: Mark twl4030_charger as broken"Samuel Ortiz
The missing definitions are now in. This reverts commit 23886839a752401aba66517bff8a8b91549279ce. Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-10-29mfd: Fix a memory leak when unload mc13xxx-core moduleAxel Lin
Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-10-29mfd: Fix resource reclaim for max8998Axel Lin
Properly free irq and unregister max8998->rtc device in max8998_i2c_probe() error path and max8998_i2c_remove(). Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-10-29mfd: Remove unneeded ret value checking for max8998 register updatesAxel Lin
i2c_smbus_write_byte_data() returns zero or negative value, therefore no need to check if ret is greater than zero or not. Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-10-29mfd: Add free max8998->ono irq in max8998_irq_exit()Axel Lin
2010-10-29mfd: Fix resource reclaim in pcf50633_remove()Axel Lin
Calling sysfs_remove_group() to remove sysfs entries and unregister bl_pdev in pcf50633_remove(). Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Harald Welte <laforge@gnumonks.org> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-10-29omap4: pandaboard: fix up mmc card detect logicMenon, Nishanth
For MMC1 Controller, card detect interrupt source is twl6030 which is non-gpio. The card detect call back function provides card present/absent status by reading MMC Control register present on twl6030. This functionality was introduced in mfd tree on track to kernel.org Sync pandaboard to the same and make mmc work. Cc: Tony Lindgren <tony@atomide.com> Cc: Madhusudhan Chikkature <madhu.cr@ti.com> Cc: Adrian Hunter <adrian.hunter@nokia.com> Cc: Samuel Ortiz <sameo@linux.intel.com> Acked-by: Kishore Kadiyala <kishore.kadiyala@ti.com> Signed-off-by: Nishanth Menon <nm@ti.com> Tested-by: Jarkko Nikula <jhnikula@gmail.com> Acked-by: Madhusudhan Chikkature <madhu.cr@ti.com> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-10-29mfd: Fix ezx_pcap_probe error pathAxel Lin
return -ENOMEM if create_singlethread_workqueue failed. Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-10-29mfd: Fix off-by-one value range checking for tps6507xAxel Lin
If bytes == (TPS6507X_MAX_REGISTER + 1), we have a buffer overflow when doing memcpy(&msg[1], src, bytes). Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-10-29mfd: Remove __devinitdata from tc6393xb_mmc_resourcesMarek Vasut
This static struct resource tc6393xb_mmc_resources[] is used in resume function, therefore the data can not be wiped after init. Also, this causes a section mismatch. Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Acked-by: Ian Molton <ian@mnementh.co.uk> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-10-29mfd: Add WM831x SPI supportMark Brown
Implement support for controlling WM831x and WM832x devices using SPI. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-10-29mfd: Factor out WM831x I2C I/O from the core driverMark Brown
In preparation for the addition of SPI support for the WM831x move the I2C specific code into a separate file with a separate Kconfig option so the I2C support can be excluded from the build. Also update the 1133-EV1 PMIC module support for SMDK6410 to use the new symbol. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-10-29mfd: Remove DEBUG defines from mc13xxx-coreSamuel Ortiz
DEBUG and VERBOSE_DEBUG are not used. Reported-by: David Jander <david@protonic.nl> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-10-29mfd: Fix jz4740_adc_set_enabledAxel Lin
When enabled is false, clear BIT(engine) of JZ_REG_ADC_ENABLE register. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-10-29mfd: Add TPS658621C device IDAndrew Chew
The interface for this device should be identical to that of the TPS658521A. Signed-off-by: Andrew Chew <achew@nvidia.com> Acked-by: Mike Rapoport <mike@compulab.co.il> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-10-29mfd: Fix twl-irq function declaration warningsG, Manjunath Kondaiah
Fixes following sparse warnings for twl4030 and twl6030 irq files. drivers/mfd/twl4030-irq.c:783:5: warning: symbol 'twl4030_init_irq' was not declared. Should it be static? drivers/mfd/twl4030-irq.c:863:5: warning: symbol 'twl4030_exit_irq' was not declared. Should it be static? drivers/mfd/twl4030-irq.c:873:5: warning: symbol 'twl4030_init_chip_irq' was not declared. Should it be static? drivers/mfd/twl6030-irq.c:226:5: warning: symbol 'twl6030_init_irq' was not declared. Should it be static? drivers/mfd/twl6030-irq.c:290:5: warning: symbol 'twl6030_exit_irq' was not declared. Should it be static? Signed-off-by: G, Manjunath Kondaiah <manjugk@ti.com> Cc: linux-arm-kernel@lists.infradead.org Cc: Tony Lindgren <tony@atomide.com> Cc: Nishanth Menon <nm@ti.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-10-29regulator: max8998 BUCK1/2 voltage change with use of GPIOsLukasz Majewski
max8998_pmic_probe: - modified to check if valid pins are defined at platform data - maximal voltage values (predefined at platform data) are uploaded to max8998 device max8998_set_voltage_buck: - BUCK1/2 voltages change between values already defined - Checks if valid GPIO pins are passed from platform data - If requested voltage cannot be satisfied from already defined values, then one of free slots is used - Predefined maximum voltages (as defined at platform data) are always available Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-10-29mfd: Voltages and GPIOs platform_data definitions for max8998Lukasz Majewski
2010-10-29regulator: max8998 BUCK1/2 internal voltages and indexes definedLukasz Majewski
BUCK1/2 internal voltages and indexes defined in the struct max8998_data max_get_voltage_register now uses index values to chose proper register More generic BUCK1/2 registers names provided Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-10-29mfd: Support for ICs compliant with max8998Lukasz Majewski
2010-10-29regulator: Separate set_voltage for max8998 ldo and buckLukasz Majewski
2010-10-29mfd: Fix TWL4030 COR bit polarity for BCI SIH blockGrazvydas Ignotas
The chip TRM documentation contradicts itself about this bit, page 174 of swcu050e says bit should be 0 for clear-on-read behavior, while page 487 says it should be 1. Testing shows it should be 1, so set the .set_cor flag accordingly. This is needed for upcoming BCI charging driver to function. Signed-off-by: Grazvydas Ignotas <notasas@gmail.com> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-10-29mfd: Add devices platform data when the cell data size is not 0Brian Harring
When the cell data_size is 0, the resulting platform_data pointer will be set to ZERO_SIZE_PTR. That could be misleading for device drivers running a NULL check on thei platform_data pointer before dereferencing it. Signed-off-by: Brian Harring <ferringb@gmail.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-10-29mfd: Add twl4030_bci platform_data backGrazvydas Ignotas
Now that we have twl4030 charger driver, add back it's platform_data (which was removed by f7ea2dc59ed46dcd0f1cfaccda02211f4507207b as unused). Signed-off-by: Grazvydas Ignotas <notasas@gmail.com> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-10-29rtc: Add support for the rtc found in the MC13892 PMICUwe Kleine-König
The mfd driver for MC13783 recently got support for MC13892 and was renamed accordingly from mc13783-core to mc13xxx-core. Do the same for rtc-mc13783. The only relevant change is to use platform id's to tell the platform bus that this driver is responsible for mc13892-rtc devices, too. Acked-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-10-29mfd: Adding twl6030 mmc card detect support for MMC1kishore kadiyala
Adding card detect callback function and card detect configuration function for MMC1 Controller on OMAP4. Card detect configuration function does initial configuration of the MMC Control & PullUp-PullDown registers of Phoenix. For MMC1 Controller, card detect interrupt source is twl6030 which is non-gpio. The card detect call back function provides card present/absent status by reading MMC Control register present on twl6030. Since OMAP4 doesn't use any GPIO line as used in OMAP3 for card detect, the suspend/resume initialization which was done in omap_hsmmc_gpio_init previously is moved to the probe thus making it generic for both OMAP3 & OMAP4. Cc: Tony Lindgren <tony@atomide.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Madhusudhan Chikkature <madhu.cr@ti.com> Cc: Adrian Hunter <adrian.hunter@nokia.com> Signed-off-by: Kishore Kadiyala <kishore.kadiyala@ti.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-10-29mfd: Add mc13892 support to mc13xxxUwe Kleine-König
mc13892 is the companion PMIC for Freescale's i.MX51. It's similar enough to mc13782 to support it in a single driver. This patch introduces enough compatibility cruft to keep all users of the superseded mc13783 driver unchanged. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-10-29mfd: Remove deprecated mc13783 functionsUwe Kleine-König
The last user is gone since v2.6.34-rc1~40 Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-10-29mfd: Remove obsolete mc13783 private dataUwe Kleine-König
The regulator driver was converted to get the needed data directly from platform_data by a10099b (regulator/mc13783: various cleanups) so regulators and num_regulators can go away. Then apart from the flag indicating that the adc does a conversion, flags is only a copy of the flags member of platform_data. This flag isn't needed to be returned by mc13783_get_flags, so mc13783_get_flags now gets the flags from platform_data, too and the driver private member is renamed for clearity. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-10-29gpio: Add VIA VX855 GPIO driverDaniel Drake
This is needed for supporting the upcoming VX855 camera and OLPC DCON drivers, as well as the advanced viafb features on non-OLPC hardware based on this chip. Based on earlier work by Harald Welte. Signed-off-by: Daniel Drake <dsd@laptop.org> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-10-29mfd: Add VIA VX855 multi-function device supportDaniel Drake
This device has GPIO, SPI and I2C capabilities. The hardware can be found in the OLPC XO-1.5 laptop. Based on earlier work by Harald Welte. Signed-off-by: Daniel Drake <dsd@laptop.org> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-10-29mfd: Allow for bypass of cell resource conflict checkDaniel Drake
The upcoming VIA VX855 MFD driver needs to communicate resources to subdevices where the resources may be claimed by ACPI. Add a flag to mfd_cell to request that resources are not policed. Signed-off-by: Daniel Drake <dsd@laptop.org> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-10-29input: Monitor both onkey up and down eventHaojian Zhuang
Remove original 3-second ONKEY event. Detect ONKEY changing event directly. So both UP and DOWN event of ONKEY in max8925 are monitered. Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com> Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-10-29leds: Remove auto blink in 88pm860xHaojian Zhuang
88pm860x supports auto-blink LED in hardware. It messed with timer trigger. Now disable the auto-blink function. Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com> Cc: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-10-29mfd: Add WM8325 supportMark Brown
The WM8325 is a PMIC for low power, high performance applications. From a software point of view the device is identical to the WM8320, all the differences are at the hardware level. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-10-29mfd: Declare abx500_remove_ops()Mark Brown
Otherwise sparse warns about a public symbol with no declaration and the compiler can't spot if the callers and users have different signatures for the function. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-10-29mfd: Fix twl-core sparse warningG, Manjunath Kondaiah
Fixes below sparse warning. drivers/mfd/twl-core.c:258:20: warning: symbol 'twl_map' was not declared. Should it be static? Signed-off-by: G, Manjunath Kondaiah <manjugk@ti.com> Cc: linux-arm-kernel@lists.infradead.org Cc: Tony Lindgren <tony@atomide.com> Cc: Nishanth Menon <nm@ti.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-10-29mfd: Use DMA for timberdale's ks8842Richard Röjfors
This patch defines platform data for the ks8842 int the timberdale MFD. The platform data contains DMA channels to be used by the driver. Signed-off-by: Richard Röjfors <richard.rojfors@pelagicore.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
