free_fdset(NULL, ...) is legal.
Add modalias attribute support for the almost forgotten now EISA bus and
(at least some) EISA-aware modules.
The modalias entry looks like (for an 3c509 NIC):
eisa:sTCM5093
and the in-module alias like:
eisa:sTCM5093*
The patch moves struct eisa_device_id declaration from include/linux/eisa.h
to include/linux/mod_devicetable.h (so that the former now #includes the
latter), adds proper MODULE_DEVICE_TABLE(eisa, ...) statements for all
drivers with EISA IDs I found (some drivers already have that DEVICE_TABLE
declared), and adds recognision of __mod_eisa_device_table to
scripts/mod/file2alias.c so that proper modules.alias will be generated.
There's no support for /lib/modules/$kver/modules.eisamap, as it's not used
by any existing tools, and because with in-kernel modalias mechanism those
maps are obsolete anyway.
The rationale for this patch is:
a) to make EISA bus to act as other busses with modalias
support, to unify driver loading
b) to foget about EISA finally - with this patch, kernel
(who still supports EISA) will be the only one who knows
how to choose the necessary drivers for this bus ;)
[akpm@osdl.org: fix the kbuild bit]
Signed-off-by: Michael Tokarev <mjt@tls.msk.ru>
Cc: Randy Dunlap <rdunlap@xenotime.net>
Acked-the-net-bits-by: Jeff Garzik <jeff@garzik.org>
Acked-the-tulip-bit-by: Valerie Henson <val_henson@linux.intel.com>
Cc: James Bottomley <James.Bottomley@steeleye.com>
Consistently use MAX_ERRNO when checking for errors in __syscall_return().
[ralf@linux-mips.org: build fix]
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net>
IA32 manual says if micorcode update's size is 0, then the size is
default size (2048 bytes). But this doesn't suggest all microcode
update's size should be above 2048 bytes to me. We actually had a
microcode update whose size is 1024 bytes. The patch just removed the
check.
Signed-off-by: Shaohua Li <shaohua.li@intel.com>
Cc: Tigran Aivazian <tigran@veritas.com>
Add sysfs support. Currently each CPU has three microcode related
attributes. One is 'version' which shows current ucode version of CPU.
Tools can use the attribute do validation or show CPU ucode status. one is
'reload' which allows manually reloading ucode. Another is
'processor_flags', which exports processor flags, so we can write tools to
check if CPU has latest ucode. Also add suspend/resume and CPU hotplug
support.
[akpm@osdl.org: cleanups, build fix]
[bunk@stusta.de: Kconfig fixes]
Acked-by: Tigran Aivazian <tigran@veritas.com>
Cc: Greg KH <greg@kroah.com>
Using request_firmware to pull ucode from userspace, so we don't need the
application 'microcode_ctl' to assist. We name each ucode file according
to CPU's info as intel-ucode/family-model-stepping. In this way we could
split ucode file as small one. This has a lot of advantages such as
selectively update and validate microcode for specific models, better
manage microcode file, easily write tools for administerators and so on.
with the changes, we should put all intel-ucode/xx-xx-xx microcode files
into the firmware dir (I had a tool to split previous big data file into
small one and later we will release new style data file). The init script
should be changed to just loading the driver without unloading
Clean up microcode update driver and make it more readable.
[akpm@osdl.org: cleanups]
Since the nolargeio option no longer has any effect, print a warning
instead of setting a write-only variable.
Cc: Jeff Mahoney <jeffm@suse.com>
Cc: Chris Mason <mason@suse.com>
Cc: Hans Reiser <reiser@namesys.com>
This eliminates the i_blksize field from struct inode. Filesystems that want
to provide a per-inode st_blksize can do so by providing their own getattr
routine instead of using the generic_fillattr() function.
Note that some filesystems were providing pretty much random (and incorrect)
values for i_blksize.
[bunk@stusta.de: cleanup]
[akpm@osdl.org: generic_fillattr() fix]
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
Move the i_cdev pointer in struct inode into a union.
Move the i_bdev pointer in struct inode into a union.
Move the i_pipe pointer into a union that will be shared with i_bdev and
i_cdev.
The following patches reduce the size of the VFS inode structure by 28 bytes
on a UP x86. (It would be more on an x86_64 system). This is a 10% reduction
in the inode size on a UP kernel that is configured in a production mode
(i.e., with no spinlock or other debugging functions enabled; if you want to
save memory taken up by in-core inodes, the first thing you should do is
disable the debugging options; they are responsible for a huge amount of bloat
in the VFS inode structure).
This patch:
The filesystem or device-specific pointer in the inode is inside a union,
which is pretty pointless given that all 30+ users of this field have been
using the void pointer. Get rid of the union and rename it to i_private, with
a comment to explain who is allowed to use the void pointer. This is just a
cleanup, but it allows us to reuse the union 'u' for something something where
the union will actually be used.
[judith@osdl.org: powerpc build fix]
Signed-off-by: Judith Lebzelter <judith@osdl.org>
get_blocks() was removed. So, this removes it on fat, and will take
advantage of the multi block mapping.
Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
Resetting the devices during driver initialization can be a costly
operation in terms of time (especially scsi devices). This option can be
used by drivers to know that user forcibly wants the devices to be reset
during initialization.
This option can be useful while kernel is booting in unreliable
environment. For ex. during kdump boot where devices are in unknown
random state and BIOS execution has been skipped.
Signed-off-by: Vivek Goyal <vgoyal@in.ibm.com>
For a long time now I have had a problem with not being able to return a
lookup failure on an existsing directory. In autofs this corresponds to a
mount failure on a autofs managed mount entry that is browsable (and so the
mount point directory exists).
While this problem has been present for a long time I've avoided resolving
it because it was not very visible. But now that autofs v5 has "mount and
expire on demand" of nested multiple mounts, such as is found when mounting
an export list from a server, solving the problem cannot be avoided any
longer.
I've tried very hard to find a way to do this entirely within the autofs4
module but have not been able to find a satisfactory way to achieve it.
So, I need to propose a change to the VFS.
Signed-off-by: Ian Kent <raven@themaw.net>
Fix an instance of ptr=alloc(sizeof(ptr)). Grepping showed no more instances
of this pattern.
Also fixed the formatting in the area.
Signed-off-by: Jeff Dike <jdike@addtoit.com>
um_timer shouldn't add local_offset to the host time since get_time already
did it. This threw off sleep when a settimeofday or equivalent had happened.
Some modules need strnlen_user_skas.
Move some foo_kern.c files to foo.c now that the old foo.c files are out
of the way.
Also cleaned up some whitespace and an emacs formatting comment.
fork on UML has always somewhat subtle. The underlying cause has been the
need to initialize a stack for the new process. The only portable way to
initialize a new stack is to set it as the alternate signal stack and take a
signal. The signal handler does whatever initialization is needed and jumps
back to the original stack, where the fork processing is finished. The basic
context switching mechanism is a jmp_buf for each process. You switch to a
new process by longjmping to its jmp_buf.
Now that UML has its own implementation of setjmp and longjmp, and I can poke
around inside a jmp_buf without fear that libc will change the structure, a
much simpler mechanism is possible. The jmpbuf can simply be initialized by
hand.
This eliminates -
the need to set up and remove the alternate signal stack
sending and handling a signal
the signal blocking needed around the stack switching, since
there is no stack switching
setting up the jmp_buf needed to jump back to the original
stack after the new one is set up
In addition, since jmp_buf is now defined by UML, and not by libc, it can be
embedded in the thread struct. This makes it unnecessary to have it exist on
the stack, where it used to be. It also simplifies interfaces, since the
switch jmp_buf used to be a void * inside the thread struct, and functions
which took it as an argument needed to define a jmp_buf variable and assign it
from the void *.
Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it>
Mark a symbol and file as being tt-mode only. This shrinks the binary
slightly when tt mode support is compiled out and makes it easier to identity
stuff when tt mode is removed.
Make checkstack work for UML. We need to pass the underlying architecture
name, rather than "um" to checkstack.pl.
Acked-by: Matt Mackall <mpm@selenic.com>
BB noticed that we had the wrong bus error handler.
Make __bb_init_func weak in order to avoid a link failure with some libcs
and/or gccs.
The UML/x86_64 headers were missing ptrace support for some segment registers.
The underlying problem was that the x86_64 kernel uses user_regs_struct
rather than the ptrace register definitions in ptrace. This patch switches
UML/x86_64 to using user_regs_struct for its definitions of the host's
registers.
ZONE_DMA might become dependent on CONFIG_ZONE_DMA, which UML doesn't define
(we're still arguing about this) So, let's change ZONE_DMA to ZONE_NORMAL.
This is prompted by optional-zone_dma-in-the-vm.patch, but should be harmless
on its own.
Cc: Christoph Lameter <clameter@engr.sgi.com>
Make lots of structures const in order to make it obvious that they need no
locking.
This spinlock can be taken on interrupt too, so spin_lock_irq[save] must be
used.
However, Documentation/networking/netdevices.txt explains we are called with
rtnl_lock() held - so we don't need to care about other concurrent opens.
Verified also in LDD3 and by direct checking. Also verified that the network
layer (through a state machine) guarantees us that nobody will close the
interface while it's being used. Please correct me if I'm wrong.
Also, we must check we don't sleep with irqs disabled!!! But anyway, this is
not news - we already can't sleep while holding a spinlock. Who says this is
guaranted really by the present code?
Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it>
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Jeff Garzik <jeff@garzik.org>
We have never used this flag and recently one user experienced a complaining
warning about this (there was a symbol in the positive half of the address space
IIRC). So fix it.
Signed-off-by: Hirokazu Takata <takata@linux-m32r.org>
Cc: Matthew Wilcox <matthew@wil.cx>
Fix to remove annoying gcc-4.1 warnings "value computed not used" for m32r;
Modify set_mb to cast to void for SMP.
Move the fallback arch_vma_name() to a sensible place (kernel/signal.c).
Currently it's in fs/proc/task_mmu.c, a file that is dependent on both
CONFIG_PROC_FS and CONFIG_MMU being enabled, but it's used from
kernel/signal.c from where it is called unconditionally.
[akpm@osdl.org: build fix]
Make futexes work under NOMMU conditions.
This can be tested by running this in one shell:
#define SYSERROR(X, Y) \
do { if ((long)(X) == -1L) { perror(Y); exit(1); }} while(0)
int main()
int shmid, tmp, *f, n;
shmid = shmget(23, 4, IPC_CREAT|0666);
SYSERROR(shmid, "shmget");
f = shmat(shmid, NULL, 0);
SYSERROR(f, "shmat");
n = *f;
printf("WAIT: %p{%x}\n", f, n);
tmp = futex(f, FUTEX_WAIT, n, NULL, NULL, 0);
SYSERROR(tmp, "futex");
printf("WAITED: %d\n", tmp);
tmp = shmdt(f);
SYSERROR(tmp, "shmdt");
exit(0);
And then this in the other shell:
int main()
int shmid, tmp, *f;
(*f)++;
printf("WAKE: %p{%x}\n", f, *f);
tmp = futex(f, FUTEX_WAKE, 1, NULL, NULL, 0);
printf("WOKE: %d\n", tmp);
tmp = shmdt(f);
exit(0);
The first program will set up a SYSV IPC SHM segment and wait on a futex in it
for the number at the start to change. The program will increment that number
and wake the first program up. This leads to output of the form:
SHELL 1 SHELL 2
# /dowait
WAIT: 0xc32ac000{0}
# /dowake
WAKE: 0xc32ac000{1}
WAITED: 0 WOKE: 1
Add documentation about using shared memory in NOMMU mode.
Make mremap() partially work for NOMMU kernels. It may resize a VMA provided
that it doesn't exceed the size of the slab object in which the storage is
allocated that the VMA refers to. Shareable VMAs may not be resized.
Moving VMAs (as permitted by MREMAP_MAYMOVE) is not currently supported.
This patch also makes use of the fact that the VMA list is now ordered to cut
it short when possible.
Order the per-mm_struct VMA list by address so that searching it can be cut
short when the appropriate address has been exceeded.
Implement /proc/pid/maps for NOMMU by reading the vm_area_list attached to
current->mm->context.vmlist.
Permit ptrace to modify a section that's non-shared but is marked
unwritable, such as is obtained by mapping the text segment of an ELF-FDPIC
executable binary with into a binary that's being ptraced[*].
[*] Under NOMMU conditions ptrace causes read-only MAP_PRIVATE mmaps to become
totally private copies because if a private mapping was actually shared
then the debugging setting breakpoints in it would potentially crash
other processes.
This is done by using the VM_MAYWRITE flag rather than the VM_WRITE flag
when deciding whether to permit a write.
Without this patch a debugger can't set breakpoints in the mapped text
sections of executables that are mapped read-only private, even if the
mmap() syscall has taken a private copy because PT_PTRACED is set.
In addition, VM_MAYREAD is used instead of VM_READ for similar reasons.
Check the VMA protections in get_user_pages() against what's being asked.
This checks to see that we don't accidentally write on a non-writable VMA or
permit an I/O mapping VMA to be accessed (which may lack page structs).
get_user_pages()
In NOMMU arch, if run "cat /proc/self/mem", data from physical address 0
are read. This behavior is different from MMU arch. In IA32, message
"cat: /proc/self/mem: Input/output error" is reported.
This issue is rootcaused by not validate the start address in NOMMU
function get_user_pages(). Following patch solves this issue.
Signed-off-by: Sonic Zhang <sonic.adi@gmail.com>
Use find_vma() in the NOMMU version of access_process_vm() rather than
reimplementing it.
Set the backing device info capabilities for /dev/mem and /dev/kmem to
permit direct sharing under no-MMU conditions and full mapping capabilities
under MMU conditions. Make the BDI used by these available to all directly
mappable character devices.
Also comment the capabilities for /dev/zero.
[akpm@osdl.org: ifdef reductions]
Check that access_process_vm() is accessing a valid mapping in the target
process.
This limits ptrace() accesses and accesses through /proc/<pid>/maps to only
those regions actually mapped by a program.
Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
The function is exported but not used from anywhere else. It's also marked as
"not for driver use" so noone out there should really care.
Signed-off-by: Rolf Eike Beer <eike-kernel@sf-tec.de>
The empty line between the short description and the first argument
description causes a section to appear twice in the generated manpage.
Also the short description should really be short: the script can't handle
multiple lines.
Acked-by: Randy Dunlap <rdunlap@xenotime.net>
Use NULL instead of 0 for pointer value, eliminate sparse warnings.
Implement the special memory driver (mspec) based on the do_no_pfn
approach. The driver is currently used only on SN2 hardware with special
fetchop support but could be beneficial on other architectures using the
uncached mode.
Signed-off-by: Jes Sorensen <jes@sgi.com>
Cc: Hugh Dickins <hugh@veritas.com>
Cc: Nick Piggin <nickpiggin@yahoo.com.au>
Implement do_no_pfn() for handling mapping of memory without a struct page
backing it. This avoids creating fake page table entries for regions which
are not backed by real memory.
This feature is used by the MSPEC driver and other users, where it is
highly undesirable to have a struct page sitting behind the page (for
instance if the page is accessed in cached mode via the struct page in
parallel to the the driver accessing it uncached, which can result in data
corruption on some architectures, such as ia64).
This version uses specific NOPFN_{SIGBUS,OOM} return values, rather than
expect all negative pfn values would be an error. It also bugs on cow
mappings as this would not work with the VM.
[akpm@osdl.org: micro-optimise]
