On G965, I810_PGETBL_CTL is a mmio offset, but we wrongly take it
as pci config space offset in detecting GTT size. This one line patch
fixs this.
Signed-off-by: Wang Zhenyu <zhenyu.z.wang@intel.com>
Signed-off-by: Dave Jones <davej@redhat.com>
Update PCI id info for Intel 965GM chipset.
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6
* 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6:
[IA64] Fix wrong /proc/iomem on SGI Altix
[IA64] Altix: ioremap vga_console_iobase
[IA64] Fix typo/thinko in crash.c
[IA64] Fix get_model_name() for mixed cpu type systems
[IA64] min_low_pfn and max_low_pfn calculation fix
* master.kernel.org:/pub/scm/linux/kernel/git/herbert/crypto-2.6:
[CRYPTO] tcrypt: Fix error checking for comp allocation
[CRYPTO] doc: Fix typo in hash example
[CRYPTO] api: scatterwalk_copychunks() fails to advance through scatterlist
This patch fixes loading the tcrypt module while deflate isn't available
at all (isn't build).
Signed-off-by: Sebastian Siewior <linux-crypto@ml.breakpoint.cc>
there is a tiny bug in Documentation/crypto/api-intro.txt.
The file has the following example code:
struct scatterlist sg[2];
if (crypto_hash_digest(&desc, &sg, 2, result))
which does not match the declaration of crypto_hash_digest() in
include/linux/crypto.h.
(static inline int crypto_hash_digest(struct hash_desc *desc,
struct scatterlist *sg, unsigned int nbytes, u8 *out)
The code in the example passes the address of a pointer (an array actually) as
the second argument, while the function expects the pointer itself.
I have attached a patch to fix this.
In the loop in scatterwalk_copychunks(), if walk->offset is zero,
then scatterwalk_pagedone rounds that up to the nearest page boundary:
walk->offset += PAGE_SIZE - 1;
walk->offset &= PAGE_MASK;
which is a no-op in this case, so we don't advance to the next element
of the scatterlist array:
if (walk->offset >= walk->sg->offset + walk->sg->length)
scatterwalk_start(walk, sg_next(walk->sg));
and we end up copying the same data twice.
It appears that other callers of scatterwalk_{page}done first advance
walk->offset, so I believe that's the correct thing to do here.
This caused a bug in NFS when run with krb5p security, which would
cause some writes to fail with permissions errors--for example, writes
of less than 8 bytes (the des blocksize) at the start of a file.
A git-bisect shows the bug was originally introduced by
5c64097aa0f6dc4f27718ef47ca9a12538d62860, first in 2.6.19-rc1.
Signed-off-by: "J. Bruce Fields" <bfields@citi.umich.edu>
In sn_io_slot_fixup(), the parent is re-set from the bus to
io(port|mem)_resource because the address is changed in a way that it's not
child of the bus any more.
However, only the root is set but not the parent/child/sibling relationship in
the resource tree which causes 'cat /proc/iomem' to stop after this memory
area. Depding on the poition in the tree the iomem may be nearly completely
empty.
Signed-off-by: Bernhard Walle <bwalle@suse.de>
Acked-by: John Keller <jpk@sgi.com>
Signed-off-by: Tony Luck <tony.luck@intel.com>
When booting an SN system without specifing a console
(i.e., no "console=" on boot line), the system will hang during
boot at the point where /sbin/init is run.
The problem is that vga_console_iobase is not converted to a
virtual address before storing in io_space[0].mmio_base.
The conversion was happening in sn_scan_pcdp(), but not in
setup_vga_console().
Signed-off-by: John Keller <jpk@sgi.com>
Clearly should be checking for "val == DIE_INIT_SLAVE_ENTER".
Signed-off-by: Jay Lan <jlan@sgi.com>
Acked-by: Simon Horman <horms@verge.net.au>
If a system consists of mixed processor types, kmalloc()
can be called before the per-cpu data page is initialized.
If the slab contains sufficient memory, then kmalloc() works
ok. However, if the slabs are empty, slab calls the memory
allocator. This requires per-cpu data (NODE_DATA()) & the
cpu dies.
Also noted by Russ Anderson who had a very similar patch.
Signed-off-by: Jack Steiner <steiner@sgi.com>
We have seen bad_pte_print when testing crashdump on an SN machine in
recent 2.6.20 kernel. There are tons of bad pte print (pfn < max_low_pfn)
reports when the crash kernel boots up, all those reported bad pages
are inside initmem range; That is because if the crash kernel code and
data happens to be at the beginning of the 1st node. build_node_maps in
discontig.c will bypass reserved regions with filter_rsvd_memory. Since
min_low_pfn is calculated in build_node_map, so in this case, min_low_pfn
will be greater than kernel code and data.
Because pages inside initmem are freed and reused later, we saw
pfn_valid check fail on those pages.
I think this theoretically happen on a normal kernel. When I check
min_low_pfn and max_low_pfn calculation in contig.c and discontig.c.
I found more issues than this.
1. min_low_pfn and max_low_pfn calculation is inconsistent between
contig.c and discontig.c,
min_low_pfn is calculated as the first page number of boot memmap in
contig.c (Why? Though this may work at the most of the time, I don't
think it is the right logic). It is calculated as the lowest physical
memory page number bypass reserved regions in discontig.c.
max_low_pfn is calculated include reserved regions in contig.c. It is
calculated exclude reserved regions in discontig.c.
2. If kernel code and data region is happen to be at the begin or the
end of physical memory, when min_low_pfn and max_low_pfn calculation is
bypassed kernel code and data, pages in initmem will report bad.
3. initrd is also in reserved regions, if it is at the begin or at the
end of physical memory, kernel will refuse to reuse the memory. Because
the virt_addr_valid check in free_initrd_mem.
So it is better to fix and clean up those issues.
Calculate min_low_pfn and max_low_pfn in a consistent way.
Signed-off-by: Zou Nan hai <nanhai.zou@intel.com>
Acked-by: Jay Lan <jlan@sgi.com>
* master.kernel.org:/pub/scm/linux/kernel/git/davem/sparc-2.6:
[SPARC64]: store-init needs trailing membar.
* master.kernel.org:/pub/scm/linux/kernel/git/gregkh/usb-2.6:
USB: new Novatel device ids for option driver
USB: berry_charge: correct dbg string for second magic command
usblp: quirk flag and device entry for Seiko Epson M129C printer
airprime: USB ID for Novatel EV620 mini PCI-E card
USB: necessary update for mos7720 driver
USB: RAZR v3i unusual_devs
USB: two more device ids for dm9601 usbnet driver
USB: fix usb-serial regression
* 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linus:
[MIPS] Export except_vec_vi_{mori,lui,ori} as text symbols.
[MIPS] mips-boards: More liberal check for mips-board console
[MIPS] Misc fixes for plat_irq_dispatch functions
[MIPS] Qemu: Fix Symmetric Uniprocessor support.
[MIPS] VI: TRACE_IRQS_OFF clobbers $v0, so save & restore around call.
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/libata-dev
* 'upstream-linus' of master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/libata-dev:
pata_ixp4xx_cf: fix interrupt
pata_ixp4xx_cf: fix oops on detach
libata: kernel-doc fix
sata_inic162x: kill double region requests
drivers/ata/Kconfig: PATA_SCC depends on wrong platform
sata_sil24: Add Adaptec 1220SA PCI ID
libata: don't whine if ->prereset() returns -ENOENT
* master.kernel.org:/home/rmk/linux-2.6-arm:
[ARM] 4264/1: ldrex/strex syntax errors with recent compilers
[ARM] Fix breakage caused by 72486f1f8f0a2bc828b9d30cf4690cf2dd6807fc
* 'for-linus' of git://git390.osdl.marist.edu/pub/scm/linux-2.6:
[S390] zcrypt: fix possible race when unloading zcrypt driver modules
[S390] zcrypt: fix possible dead lock in AP bus module
[S390] Wire up sys_utimes.
[S390] reboot from and dump to SCSI under z/VM fails.
[S390] Wire up compat_sys_epoll_pwait.
[S390] strlcpy is smart enough
[S390] memory detection: fix off by one bug.
[S390] cio: qdio slsb setup
This moves all of the Novatel device ids to the option driver, where
they belong.
Thanks to Novatel for providing a list of all supported devices.
The manual says that it is required and we actually have crash reports
where loads see stale data due to not having membars here.
In one case the networking does:
memset(skb, 0, offsetof(struct sk_buff, truesize));
and then some code later checks skb->nohdr for zero, but it's still
the value that was there before the memset().
Note that arch/sparc64/lib/xor.S already got this right.
Otherwise objdump will screw up disassembly.
Allows overriding the MALTA/ATLAS/etc. default console setting with
non-serial console devices.
Signed-Off-By: Thiemo Seufer <ths@networkno.de>
o adds missing ST0_IM masks, which caused the logging of valid interrupts
as spurious
o stops pnx8550 to log every interrupt as spurious
o adds cause register masks for ip22/ip32, which caused handling of masked
interrupts
o removes some superfluous parentheses in the SNI interrupt code
Might be useful for SMP debugging.
Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
[Rewritten Kconfig bits to deal better fit in the usual pattern of doing
things - Ralf]
I was testing the berry_charge module with my Blackberry 8700c and had
great success, thanks. Looking at the code for my own learning I noticed
the following cut and paste error... just a nit.
Signed-off-by: Ken L Johnson <ken@novell.com>
This patch (as872) adds a device table entry and a new quirk flag to
the usblp driver for the Seiko Epson Receipt printer. This printer
returns Vendor-Specific values for bInterfaceClass and
bInterfaceSubClass, but the bInterfaceProtocol value is valid and it
works with usblp. The new quirks flag tells the driver to ignore the
Class and SubClass values in the interface descriptor.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Cc: Vojtech Pavlik <vojtech@suse.cz>
Add an ID to recognise the Novatel EV620 wireless adapter.
http://www.novatelwireless.com/products/expedite/ev620.html
It looks like a mini PCI-Express adapter. The mPCIE connector includes USB
pins... the card shows up to the system as a USB device, and powers itself
from the PCI bus.
The card I have isn't activated yet, so I can't get a PPP session up yet, but
I have tested basic serial communication successfully in both 2.6.18 and
2.6.20 kernels, once the product ID was added. (the driver changed quite a
bit between the two revs.) In both drivers, it responds to AT commands and
such.
Signed-off-by: Mark Glines <mark@glines.org>
Cc: Pete Zaitcev <zaitcev@redhat.com>
these devices have a shared interrupt endpoint. For serialcore to pass
an interrupt endpoint to a subdriver, the subdriver must define and
_export_ a fitting callback. The mos7720 driver failed to do so. This led
invariably to an oops upon open. This patch fixes it. The driver is useless
without it. Please try to get this into 2.6.21 and the stable kernels that
have this driver.
Signed-off-by: Oliver Neukum <oneukum@suse.de>
This adds an unusual_devs entry for the Motorola RAZR 3vi.
Signed-off-by: Phil Dibowitz <phil@ipom.com>
This patch for the linux-usb-devel tree adds two more
product ids to the dm9601 driver. These ids were found on
rebadged dm9601 devices in the wild.
Signed-off-by: Jon Dowland <jon@alcopop.org>
Acked-by: Peter Korsgaard <jacmet@sunsite.dk>
This patch reverts d9a7ecacac5f8274d2afce09aadcf37bdb42b93a since it
breaks drivers that need to access the ->port[] array in shutdown
(most of them).
Signed-Off: Jim Radford <radford@blackbean.org>
Acked-by: Mark Lord <mlord@pobox.com>
As per compact flash specifications, the default
irq mode upon cf insertion is pulse mode. this patch fixes
the driver to cope with that.
Signed-off-by: Alessandro Zummo <a.zummo@towertech.it>
Signed-off-by: Jeff Garzik <jeff@garzik.org>
pata_ixp4xx_cf dodged dont-clear-drvdata-in-LLD bombing run as it used
platform_set_drvdata() instead of dev_set_drvdata(). This causes OOPS
on devres host release. Kill it.
Signed-off-by: Tejun Heo <htejun@gmail.com>
Warning(linux-2621-rc3g7/drivers/ata/libata-core.c:842): No description found for parameter 'unknown'
Regions are requested twice during initialization causing the second
one to fail. This is regression introduced during iomap conversion.
PATA_SCC depends on PPC_CELLEB. (not PPC_IBM_CELL_BLADE)
Signed-off-by: Kou Ishizaki <kou.ishizaki@toshiba.co.jp>
Signed-off-by: Akira Iguchi <akira2.iguchi@toshiba.co.jp>
Add Adaptec 1220SA (SIL3132) to devices claimed by sata_sil24
Patch generated against 2.6.20.2
Signed-off-by: Jamie Clark <jclark@metaparadigm.com>
->prereset() returns -ENOENT to tell libata that the port is empty and
reset sequencing should be stopped. This is not an error condition.
Update ata_eh_reset() such that it sets device classes to ATA_DEV_NONE
and return success in on -ENOENT. This makes spurious error message
go away.
Move try_module_get() call into spin protected block to prevent zcrypt
driver module unload while submitting a request to driver.
Signed-off-by: Ralph Wuerthner <rwuerthn@de.ibm.com>
AP bus module uses bus_for_each_dev() in software interrupt context to
poll for completed requests which might cause dead locks. Solution: use
private AP device list for polling in software interrupt context.
We used wrong length values for ipl and dump hardware structures.
Since z/VM checks the ipl parameters more accurately than LPAR,
the operations fail there.
Signed-off-by: Michael Holzheu <holzheu@de.ibm.com>
strlcpy already accounts for the trailing zero in its length
computation, so there is no need to substract one to the buffer size.
diag 260 returns the address of the last addressable byte and not the
size of memory. Since we want the size we have to add 1 to the return
value.
Disable diag 260 for non z/Arch mode since it doesn't work there
anyway.
Make sure set_slsb problems are handled correctly in
qdio_do_qdio_fill_input() and qdio_do_qdio_fill_output.
Signed-off-by: Ursula Braun <braunu@de.ibm.com>
* master.kernel.org:/pub/scm/linux/kernel/git/lethal/sh-2.6:
serial: Fix sh-sci break interrupt/sysrq handling.
sh: Fix bogus regs pointer in do_IRQ().
sh: Fix SH-3 cache entry_mask and way_size calculation.
sh: Convert struct ioctls to static defines.
sh: Define missing __NR_readahead.
sh: Fix PCI BAR address-space wraparound.
Since d9a9cdfb078d755e648d53ec25b7370f84ee5729 <linux/sysfs.h> is using
ENOSYS without including <linux/errno.h> if CONFIG_SYSFS is disabled.
Fixed by including <linux/errno.h>.
These leaks were reported by: Catalin Marinas <catalin.marians@gmail.com>
and I have been able to very by inspection they are possible.
When converting tty_io.c to store pids as struct pid pointers instead
of pid_t values it appears I overlooked two places where we stop using
the pid value. The very obvious one is in do_tty_hangup, and the one
the less obvious one in __proc_set_tty.
When looking into the code __proc_set_tty only has pids that need to
be put because of failures of other parts of the code to properly
perform hangup processing. Fixing the leak here in __proc_set_tty
is easy and obviously correct so I am doing that first.
Fixing the places that should be performing hangup processing is much
less obviously correct. So those I'm aiming those patches at -mm.
for now, so the can age a while before they are merged.
