cifs_convert_flags returns 0x20197 in the default case. It's not
immediately evident where that number comes from, so change it
to be an or'ed set of flags. The compiler will boil it down anyway.
(Thanks to Guenter Kukkukk for clarifying the flags).
Signed-off-by: Steve French <sfrench@us.ibm.com>
Do the following series of operations on a CIFS share:
opendir(dir)
readdir(dir)
unlink(file in dir)
rewinddir(dir)
readdir(dir)
If the readdir read all entries in the directory this will make CIFS throw an error like this:
CIFS VFS: Send error in FindClose = -9
CIFS requests "Close at end of search" of the server by setting this bit when issuing FindFirst or FindNext. Therefore when all search entries are returned, the server may return "end of search" and close the search implicitly when this bit is set by the client on the request. We check for this when a readdir is explicitly closed - but when the client notices that a directory has changed after the last operation, we attempt to close the directory before reopening by reissuing a second FindFirst. But, the directory may already been implicitly closed (due to end of search) because the first readdir finished. So we only want to issue a FindClose call in this case when we don't expect it to already be closed.
Signed-off-by: Jeff Layton <jlayton@redhat.com>
all other codepaths in this function return negative values on errors
Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com>
When CIFSFindNext gets back an -EBADF from a call, it sets the return
code of the function to 0 and eventually exits. Doing this makes the
cleanup at the end of the function skip freeing the SMB buffer, so
we need to make sure we free the buffer explicitly when doing this.
If we don't you end up with errors like this when unplugging the cifs
kernel module:
slab error in kmem_cache_destroy(): cache `cifs_request': Can't free all objects
[<c046bdbf>] kmem_cache_destroy+0x61/0xf3
[<e0f03045>] cifs_destroy_request_bufs+0x14/0x28 [cifs]
[<e0f2016e>] exit_cifs+0x1e/0x80 [cifs]
[<c043aeae>] sys_delete_module+0x192/0x1b8
[<c04451fd>] audit_syscall_entry+0x14b/0x17d
[<c0405413>] syscall_call+0x7/0xb
when unix extensions and cifsacl support are disabled. These
permissions changes are "ephemeral" however. They are lost whenever
a share is mounted and unmounted, or when memory pressure forces
the inode out of the cache.
Because of this, we'd like to introduce a behavior change to make
CIFS behave more like local DOS/Windows filesystems. When unix
extensions and cifsacl support aren't enabled, then don't silently
ignore changes to permission bits that can't be reflected on the
server.
Still, there may be people relying on the current behavior for
certain applications. This patch adds a new "dynperm" (and a
corresponding "nodynperm") mount option that will be intended
to make the client fall back to legacy behavior when setting
these modes.
Because it's not correct with a non-preemptable BKL and just causes
PREEMPT kernels to have longer latencies than non-PREEMPT ones (which is
obviously not the point of it at all).
Of course, that config option actually got removed as an option earlier,
so for now this basically disables it entirely, but if BKL preemption is
ever resurrected it will be a meaningful optimization. And in the
meantime, it at least documents the intent of the code, while not doing
the wrong thing.
* git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6:
[CIFS] don't allow demultiplex thread to exit until kthread_stop is called
[CIFS] when not using unix extensions, check for and set ATTR_READONLY on create and mkdir
[CIFS] add local struct inode pointer to cifs_setattr
[CIFS] cifs_find_tcp_session cleanup
We should not go through the task pointer to get at the thread info,
since it's usually cheaper to just access the thread info directly.
So don't make the code look up 'current', when we can just use the
thread info accessor functions directly. This generally avoids one
level of indirection and tends to work better together with code that
also looks at other thread flags (eg preempt_count).
* git://git.kernel.org/pub/scm/linux/kernel/git/hpa/linux-2.6-inttypes:
types: s390: fix #ifdef reversal in <asm-s390/types.h>
* 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linus: (28 commits)
[MIPS] Pb1000: bury the remnants of the PCI code
[MIPS] Fix build failure in mips oprofile code
[MIPS] fix warning message on SMP kernels
[MIPS] markeins: build fix
[MIPS] ELF handling - use SELFMAG instead of numeric constant
[MIPS] Get rid of __ilog2
[MIPS] Fix __fls for non-MIPS32/MIPS64 cpus
[MIPS] XXS1500 code style cleanup
[MIPS] MTX-1 code style cleanup
[MIPS] Pb1200/DBAu1200 code style cleanup
[MIPS] Pb1550 code style cleanup
[MIPS] Pb1500 code style cleanup
[MIPS] Pb1100 code style cleanup
[MIPS] Pb1000 code style cleanup
[MIPS] DBAu1xx0 code style cleanup
[MIPS] Alchemy PCI code style cleanup
[MIPS] Alchemy common code style cleanup
[MIPS] Alchemy common headers style cleanup
[MIPS] Add empty argument parenthesis to GCC_IMM_ASM
[MIPS] msp_hwbutton.c: minor irq handler cleanups
The #ifdef for the integer types was reversed; the standard pattern in
these files are:
#ifndef __s390x__
/* 32-bit code */
#else
/* 64-bit code */
#endif
Stick with the original pattern, but make sure the 32-bit code
actually comes first!
Reported by Al Viro.
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
This patch fixes a warning-as-error induced build failure of 64bit MIPS
kernels.
Signed-off-by: Thiemo Seufer <ths@networkno.de>
This patch fixes a (harmless) warning message.
This patch fixes the following build errror caused by
commit 7dffa3c673fbcf835cd7be80bb4aec8ad3f51168
(ntp: handle leap second via timer):
<-- snip -->
CC arch/mips/emma2rh/markeins/setup.o
/home/bunk/linux/kernel-2.6/git/linux-2.6/arch/mips/emma2rh/markeins/setup.c:79: error: conflicting types for 'clock'
/home/bunk/linux/kernel-2.6/git/linux-2.6/include/linux/clocksource.h:96: error: previous declaration of 'clock' was here
make[2]: *** [arch/mips/emma2rh/markeins/setup.o] Error 1
<-- snip -->
[Ralf: reformated to 80 colums after the fix and marked emma2rh_clock as
__initdata]
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Signed-off-by: Cyrill Gorcunov <gorcunov@gmail.com>
56a6b1eb7bfb5ace0b5cb9c149f502fbd101b8ab was a bit too conservative and
left __ilog2 around which is only used as an internal function for other
bitops.
Only MIPS32 and MIPS64 CPUs implement clz/dclz. Therefore don't export
__ilog2() for non MIPS32/MIPS64 cpus and use generic __fls bitop code for
these cpus.
Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de>
Fix several errors and warnings given by checkpatch.pl:
- use of C99 // comments;
- using simple_strtol() where strict_strtol() could be used.
In addition to these changes, also do the following:
- remove needless parentheses;
- remove unneeded numeric literal type cast;
- insert spaces between operator and its operands;
- remove excess new lines;
- remove space after the type cast's closing parenthesis;
- insert missing space before closing brace in the structure initializer;
- fix typos, capitalize acronyms, etc. in the comments;
- update MontaVista copyright;
- remove Pete Popov's old email address...
Fix many errors and warnings given by checkpatch.pl:
- space after opening and before closing parentheses;
- leading spaces instead of tabs;
- brace not on the same line with 'else' in the 'if' statement;
statement;
- printk() without KERN_* facility level;
- including <asm/gpio.h> instead of <linux/gpio.h>.
- replace tab between the function type and name with space in
mtx1_pci_idsel() declaration;
- insert missing space before closing brace in the array/structure
initializers;
- initialization of a 'static' variable to 0;
- missing space between 'for' and opening parenthesis;
- macros with complex values not enclosed in parentheses;
- unnecessary braces for single-statement block;
- using simple_strtol() where strict_strtol() could be used;
- line over 80 characters.
- mention DBAu1200 board in the Makefile;
- replace the group of #include/#ifdef directives by a single
#include <au1xxx.h> since this header contains the needed stuff;
- properly indent the blocks;
- insert spaces between operator and its operands, remove excess spaces
there;
- remove needless parentheses and add some for clarity;
- replace numeric literals/expressions with the matching macros;
- reduce pb1200_setup_cascade() to the single 'return' statement;
- reduce the number of printed empty lines in the so-called CPLD
workaround;
- remove #undef AU1X00_EXTERNAL_INT since that macro is not defined
anywhere;
- replace spaces after the macro name with tabs in the #define directives;
- remove excess tabs after the macro name in the #define directives;
- fix typo in the BCSR_RESETS_PWMR1mUX macro's name;
- group all Pb1200 PCMCIA definitions together;
- put the function's result type and name/parameters on the same line;
- insert missing and remove excess new lines;
- make the multi-line comment style consistent with the kernel style
elsewhere by adding empty first line and/or adding space/asterisk on
their left side;
- fix typos/errors, capitalize acronyms, etc. in the comments;
- combine some comments;
Fix a few errors and warnings given by checkpatch.pl:
- replace numeric literals with the matching macros;
- properly indent the code and the array initializers;
- insert spaces between operator and its operands, also remove excess spaces
there;
- insert missing space before closing brace in the array initializers;
- replace spaces after the macro name with tabs in the #define directives, also
sometimes insert space there for better looks;
- make the multi-line comment style consistent with the kernel style elsewhere
by adding empty first line;
- remove useless #if dirctive from board_setup();
- remove unneeded type casts;
- make hexadecimal literals all lower case;
also sometimes insert space there for better looks;
- space between asterisk and variable name;
- properly indent the code;
and sometimes insert spaces there;
elsewhere by adding empty first line;
- brace not on the same line with condition in the 'switch' statement;
- properly indent the 'switch' statement;
- remove unneeded numeric literal type casts;
- replace spaces after the macro name with tabs in the #define directives, and
by adding empty first/last line;
- initialize variable instead of assigning value later where it makes sense;
there;
Fix 15 errors and 4 warnings given by checkpatch.pl:
- space between the asterisk and variable name;
- combine the nested 'if' statements into one when possible;
- add missing and remove excess spaces between operator and its operands;
- fix printk() format specifiers mismatching the argument types;
- properly indent multi-line expressions;
- missing space between the type and asterisk in a variable declaration;
- space between the asterisk and function/variable name;
- missing spaces around assignement/comparison operator;
- brace not on the same line with condition (or 'else') in the 'if'/'switch'
statement;
- missing space between 'if'/'for'/'while' and opening parenthesis;
- use of assignement in 'if' statement's condition;
- EXPORT_SYMBOL() not following its function immediately;
- adding new 'typedef' (where including <linux/types.h> will do);
- use of 'extern' in the .c file (where it can be avoided by including header);
- insert missing space after opening brace and/or before closing brace in the
structure initializers;
- remove commented out code;
- remove useless initializers and code;
- fix broken/excess indentation;
- add missing spaces between operator and its operands;
- group 'else' and 'if' together where possible;
- make au1xxx_platform_init() 'static';
- regroup variable declarations in pm_do_freq() for prettier look;
by adding empty first line and/or adding space on their left side;
- make two-line comments that only have one line of text one-line;
- fix/remove obsolete references in the comments;
- reformat some comments;
- add comment about the CPU:counter clock ratio to calc_clock();
- remove Pete Popov's and Steve Longerbeam's old email addresses...
- opening brace following 'struct' not on the same line;
- space between asterisk and function name;
- including <asm/io.h> instead of <linux/io.h> and <asm/irq.h> instead of
<linux/irq.h>;
- use of '__inline__' instead of 'inline';
- space between function name and opening parenthesis;
- replace spaces after the macro name with tabs in the #define directives and
after the type in the structure field declarations;
- remove excess tabs after the macro name in the #define directives and in the
'extern' variable declarations;
- remove excess spaces between # and define for the SSI_*_MASK macros to align
with other such macros;
- put '||' operator on the same line with its first operand;
- properly indent multi-line function prototypes;
by adding empty first line and/or adding space/asterisk on their left side;
- convert the large multi-line comment in au1xxx_ide.h into several one-liners,
replace spaces with tabs there;
This is to clarify that GCC_IMM_ASM does not take an argument as the
context of the macro's invocation seems to imply.
As suggested by Maciej W. Rozycki (macro@linux-mips.org).
- remove always-true test
- neaten request_irq() indentation
This change's main purpose is to prepare for the patchset in
jgarzik/misc-2.6.git#irq-remove, that explores removal of the
never-used 'irq' argument in each interrupt handler.
This patch removes the no longer used export of __kmap_atomic_to_page.
This was dropped by
commit a0d9e2d891e4cf54676c430da63bd4a17d1cdb80 (lmo)
commit b6f1f0dea1469e0c956eb89399916d60dd2a3808 (ko)
Author: Franck Bui-Huu <vagabon.xyz@gmail.com>
Date: Fri Aug 11 17:51:48 2006 +0200
do_brk's return value was stored in an unsigned long variable before being
tested for less than zero making the test always fail. Also do_brk's
called irix_map_prda_page wasn't forwarding do_brk() success.
Bug checking the return value of do_brk() and initial fix for it found
by Roel Kluin <12o3l@tiscali.nl>.
Signed-off-by: Kevin D. Kissell <kevink@mips.com>
Still won't play nicely with esotheric configurations such as discontig
memory ...
Signed-off-by: Roel Kluin <12o3l@tiscali.nl>
Acked-By: Thomas Bogendoerfer <tsbogend@alpha.franken.de>
The Alchemy platform code registers the SMBus device using the virtual
address of its registers instead of the physical one -- fix this, taking
into account that actually the whole megabyte is decoded by any of the
programmable serial controllers (one of which is SMBus), and that all the
Alchemy peripherals are directly mappable into KSEG1 kernel space and
therefore ioremap() call would just boil down to CKSEG1ADDR() invocation.
This patch fixes bug #10627 which caused the compilation error below.
CC [M] drivers/usb/c67x00/c67x00-ll-hpi.o
drivers/usb/c67x00/c67x00-ll-hpi.c: In function `ll_recv_msg':
drivers/usb/c67x00/c67x00-ll-hpi.c:243: erreur: `HZ' undeclared (first use in this function)
drivers/usb/c67x00/c67x00-ll-hpi.c:243: erreur: (Each undeclared identifier is reported only once
drivers/usb/c67x00/c67x00-ll-hpi.c:243: erreur: for each function it appears in.)
Signed-off-by: Fernando Luis Vazquez Cao <fernando@oss.ntt.co.jp>
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc
* 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc:
[POWERPC] ppc: More compile fixes
[POWERPC] ppc: Don't run prom_init_check for arch/ppc builds
[POWERPC] ppc: Include <asm/cacheflush.h> in kernel/ppc_ksyms.c
[POWERPC] ppc: Use ebony_defconfig for defconfig
[POWERPC] Fix default cputable entries for e200 and e500 families
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6:
sparc64: Work around memory probing bug in openfirmware.
sparc32: fix rtrap.S typo
sparc32: Fix build.
Signed-off-by: Alan Cox <alan@redhat.com>
Strip assumes that the tty drivers always have a set_termios method which
may not be true. Check this when binding to the tty so that we don't oops
later.
This fixes a few more miscellaneous compile problems with ARCH=ppc.
1. Don't compile devres.c on ARCH=ppc, it doesn't have ioremap_flags.
2. Include <asm/irq.h> in setup.c for the __DO_IRQ_CANON definition.
3. Include <linux/proc_fs.h> in residual.c for the
definition of create_proc_read_entry.
4. Fix xchg_ptr to be a static inline to eliminate a compiler warning.
arch/ppc doesn't have prom_init.o (anymore).
Signed-off-by: Segher Boessenkool <segher@kernel.crashing.org>
It needs it:
arch/ppc/kernel/ppc_ksyms.c:152: error: '__flush_icache_range'
undeclared here (not in a function)
and a few more like that.
We used to use common_defconfig, but it was removed some time ago.
Commit 76bc080ef5a34aedb63e1691f28c6b42f3468e4e ("POWERPC] Make default
cputable entries reflect selected CPU family") added default entries
for the e200 and e500 families, but missed a closing brace on those
entries, as pointed out by David Gibson. This adds the closing braces.
