In ext4_{create,mknod,mkdir,symlink}(), don't start the journal handle
until the inode has been succesfully allocated. In order to do this,
we need to start the handle in the ext4_new_inode(). So create a new
variant of this function, ext4_new_inode_start_handle(), so the handle
can be created at the last possible minute, before we need to modify
the inode allocation bitmap block.
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
Operations which modify extended attributes may need extra journal
credits if inline data is used, since there is a chance that some
extended attributes may need to get pushed to an external attribute
block.
Changes to reflect this was made in xattr.c, but they were missed in
fs/ext4/acl.c. To fix this, abstract the calculation of the number of
credits needed for xattr operations to an inline function defined in
ext4_jbd2.h, and use it in acl.c and xattr.c.
Also move the function declarations used in inline.c from xattr.h
(where they are non-obviously hidden, and caused problems since
ext4_jbd2.h needs to use the function ext4_has_inline_data), and move
them to ext4.h.
Reviewed-by: Tao Ma <boyu.mt@taobao.com>
The ext4_unlink() and ext4_rmdir() don't actually release the blocks
associated with the file/directory. This gets done in a separate jbd2
handle called via ext4_evict_inode(). Thus, we don't need to reserve
lots of journal credits for the truncate.
Note that using too many journal credits is non-optimal because it can
leading to the journal transmit getting closed too early, before it is
strictly necessary.
The migration ioctl creates a temporary inode. Since this inode is
never linked to a directory, we don't need to reserve journal credits
required for modifying the directory.
Don't start the jbd2 transaction handle until after the directory
entry has been found, to minimize the amount of time that a handle is
held active.
held active.
The grab_cache_page_write_begin() function can potentially sleep for a
long time, since it may need to do memory allocation which can block
if the system is under significant memory pressure, and because it may
be blocked on page writeback. If it does take a long time to grab the
page, it's better that we not hold an active jbd2 handle.
So grab a handle on the page first, and _then_ start the transaction
handle.
This commit fixes the following long transaction handle hold time:
postmark-2917 [000] .... 196.435786: jbd2_handle_stats: dev 254,32
tid 570 type 2 line_no 2541 interval 311 sync 0 requested_blocks 1
dirtied_blocks 0
So we can better understand what bits of ext4 are responsible for
long-running jbd2 handles, use jbd2__journal_start() so we can pass
context information for logging purposes.
The recommended way for finding the longer-running handles is:
T=/sys/kernel/debug/tracing
EVENT=$T/events/jbd2/jbd2_handle_stats
echo "interval > 5" > $EVENT/filter
echo 1 > $EVENT/enable
./run-my-fs-benchmark
cat $T/trace > /tmp/problem-handles
This will list handles that were active for longer than 20ms. Having
longer-running handles is bad, because a commit started at the wrong
time could stall for those 20+ milliseconds, which could delay an
fsync() or an O_SYNC operation. Here is an example line from the
trace file describing a handle which lived on for 311 jiffies, or over
1.2 seconds:
dirtied_blocks 0
Move the jbd2 wrapper functions which start and stop handles out of
super.c, where they don't really logically belong, and into
ext4_jbd2.c.
Handles which stay open a long time are problematic when it comes time
to close down a transaction so it can be committed. These tracepoints
will help us determine which ones are the problematic ones, and to
validate whether changes makes things better or worse.
This reverts commit 93737456d68ddcb86232f669b83da673dd12e351.
The cow-snapshots effort is no longer active, so remove these extra
fields to shrink down the handle structure.
Track the delay between when we first request that the commit begin
and when it actually begins, so we can see how much of a gap exists.
In theory, this should just be the remaining scheduling quantuum of
the thread which requested the commit (assuming it was not a
synchronous operation which triggered the commit request) plus
scheduling overhead; however, it's possible that real time processes
might get in the way of letting the kjournald thread from executing.
The ext4 block allocator only maintains buddy bitmaps for chunks which
are less than or equal to one quarter of a block group. That is, for
a file aystem with a 1k blocksize, and where the number of blocks in a
block group is 8192 blocks, the largest chunk size tracked by buddy
bitmaps is 2048 blocks.
For a file system with a 4k blocksize, and where the number of blocks
in a block group is 32768 blocks, the largest chunk size tracked by
buddy bitmaps is 8192 blocks.
To work around this code, mballoc.c before this commit would truncate
allocation requests to the number of blocks in a block group minus 10.
Why 10? Aside from being a completely arbitrary number, it avoids
block allocation to be a power of two larger than 25% of the block
group. If you try to explicitly fallocate 50% of the block group
size, this will demonstrate the problem; the block allocation code
will scan the all of the blocks in the file system with cr==0 (since
the request is for a natural power of two), but then completely fail
for all blocks groups, since the buddy bitmaps don't track chunk sizes
of 50% of the block group.
To fix this, in these we use ext4_mb_complex_scan_group() instead of
ext4_mb_simple_scan_group().
Cc: Andreas Dilger <adilger@dilger.ca>
Check for incompatible mount options when using the ext4 file system
driver to mount ext2 or ext3 file systems.
If argument of inode_readahead_blk is too big, we just bail out
without printing any error. Fix this since it could confuse users.
The loop looking for correct mount option entry is more logical if it is
written rewritten as an empty loop looking for correct option entry and then
code handling the option. It also saves one level of indentation for a lot of
code so we can join a couple of split lines.
Several mount option (resuid, resgid, journal_dev, journal_ioprio) are
currently handled before we enter standard option handling loop. I don't
see a reason for this so move them to normal handling loop to make things
more regular.
It is unnecessary to check i<4 after the loop; just do it before the
break.
Signed-off-by: Cong Ding <dinggnu@gmail.com>
In ext4_mb_add_n_trim(), lg_prealloc_lock should be taken when
changing the lg_prealloc_list.
Signed-off-by: Niu Yawei <yawei.niu@intel.com>
Cc: stable@vger.kernel.org
Commit 2147b1a6a48 resulted in a new smatch warning:
> fs/ext4/move_extent.c:693 mext_replace_branches()
> warn: variable dereferenced before check 'dext' (see line 683)
Fix this by adding a check to make sure dext is non-NULL before we
derefrence it.
Signed-off-by: Akria Fujita <a-fujita@rs.jp.nec.com>
[ modified by tytso to make sure an ext4_error is called ]
Use WARN rather than printk followed by WARN_ON(1), for conciseness.
A simplified version of the semantic patch that makes this transformation
is as follows: (http://coccinelle.lip6.fr/)
// <smpl>
expression list es;
-printk(
+WARN(1,
es);
-WARN_ON(1);
// </smpl>
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
Don't send an extra wakeup to kjournald in the case where we
already have the proper target in j_commit_request, i.e. that
transaction has already been requested for commit.
commit deeeaf13 "jbd2: fix fsync() tid wraparound bug" changed
the logic leading to a wakeup, but it caused some extra wakeups
which were found to lead to a measurable performance regression.
Signed-off-by: Eric Sandeen <sandeen@redhat.com>
[tytso@mit.edu: reworked check to make it clearer]
Running AIO is pinning inode in memory using file reference. Once AIO
is completed using aio_complete(), file reference is put and inode can
be freed from memory. So we have to be sure that calling aio_complete()
is the last thing we do with the inode.
CC: stable@vger.kernel.org
Reviewed-by: Carlos Maiolino <cmaiolino@redhat.com>
Acked-by: Jeff Moyer <jmoyer@redhat.com>
brelse() and ext4_journal_force_commit() are both inlined and able
to handle NULL.
Signed-off-by: Guo Chao <yan@linux.vnet.ibm.com>
Reviewed-by: Darrick J. Wong <darrick.wong@oracle.com>
After commit 978fef9 (create __ext4_insert_dentry for dir entry
insertion), 'reclen' is not used anymore.
Commit b0336e8d (ext4: calculate and verify checksums of directory
leaf blocks) and commit dbe89444 (ext4: Calculate and verify checksums
for htree nodes) forget to release buffer when checksum failed, at
some places.
In two places we call WARN_ON() before we print out the debug message,
however we agreed that the WARN_ON() is unnecessary at those places so
remove them.
Also use ext4_warning() instead of ext4_msg() and printk().
Signed-off-by: Lukas Czerner <lczerner@redhat.com>
Remove unused variable flags from dump_completed_IO(). The code is
only exercised when EXT4FS_DEBUG is defined.
Reviewed-by: Zheng Liu <wenqing.lz@taobao.com>
So far ext4_writepage() skipped writing pages that had any delayed or
unwritten buffers attached. When blocksize < pagesize this breaks
data=ordered mode guarantees as we can have a page with one freshly
allocated buffer whose allocation is part of the committing
transaction and another buffer in the page which is delayed or
unwritten. So fix this problem by calling ext4_bio_writepage()
anyway. It will submit mapped buffers and leave others alone.
So far ext4_bio_writepage() unconditionally cleared dirty bit on all
buffers underlying the page. That implicitely assumes we can write all
buffers. So far that is true because callers call into
ext4_bio_writepage() make sure all buffers in the page are mapped but:
a) it's a data corruption bug waiting to happen
b) in data=ordered mode when blocksize < pagesize we do need to write
pages that may have only some of dirty buffers mapped.
So change ext4_bio_writepage() to skip buffers that cannot be written without
clearing their dirty bit.
The argument b_size of mpage_add_bh_to_extent() was bogus since it was
always == blocksize (which we can easily derive from inode->i_blkbits).
Also second branch of condition:
if (nrblocks >= EXT4_MAX_TRANS_DATA) {
} else if ((nrblocks + (b_size >> mpd->inode->i_blkbits)) >
was never taken because (b_size >> mpd->inode->i_blkbits) == 1.
ext4_writepage(), write_cache_pages_da(), and mpage_da_submit_io()
doesn't have to deal with the case when page doesn't have buffers. We
attach buffers to a page in ->write_begin() and ->page_mkwrite() which
covers all places where a page can become dirty.
The function splices i_completed_io_list to its private list
first. From that moment on we don't need any lock for working with
io_end structures because all io_end structure on the list are only
our own. So we can remove the other two lists in the function and free
io_end immediately after we are done with it.
CC: Dmitry Monakhov <dmonakhov@openvz.org>
It does not make much sense to have struct work in ext4_io_end_t
because we always use it for only one ext4_io_end_t per inode (the
first one in the i_completed_io list). So just move the structure to
inode itself. This also allows for a small simplification in
processing io_end structures.
We don't support delayed allocation in data=journal mode. So checking for it in
mpage_da_submit_io() doesn't make really sence. If we ever decide to extend
delayed allocation support to data=journal mode, adding
__ext4_journalled_writepage() call will be the least of problems we have to
solve. Most likely we'd have to implement separate writepages call anyways
because we don't have transaction credits for writing more than a single page
so mapping of page buffers would have to be done differently.
When we cannot write a page we should use redirty_page_for_writepage()
instead of plain set_page_dirty(). That tells writeback code we have
problems, redirties only the page (redirtying buffers is not needed),
and updates mm accounting of failed page writes.
Also move clearing of buffer dirty flag after io_submit_add_bh(). At that
moment we are sure buffer will be going to disk.
Currently we sometimes used block_write_full_page() and sometimes
ext4_bio_write_page() for writeback (depending on mount options and call
path). Let's always use ext4_bio_write_page() to simplify things a bit.
This patch add supports for indirect file support punching hole. It
is almost the same as ext4_ext_punch_hole. First, we invalidate all
pages between this hole, and then we try to deallocate all blocks of
this hole.
A recursive function is used to handle deallocation of blocks. In
this function, it iterates over the entries in inode's i_blocks or
indirect blocks, and try to free the block for each one of them.
After applying this patch, xfstest #255 will not pass w/o extent because
indirect-based file doesn't support unwritten extents.
Signed-off-by: Zheng Liu <wenqing.lz@taobao.com>
When usrjquota or grpjquota mount options are specified several times,
we leak memory storing the names. Free the memory correctly.
Signed-off-by: Chen Gang <gang.chen@asianux.com>
Otherwise, ext4 file systems with the quota featured enable will get a
very confusing "No such process" error message if the quota code is
built as a module and the quota_v2 module has not been loaded.
Acked-by: Jan Kara <jack@suse.cz>
In addition, print the error returned from ext4_enable_quotas()
This patch adds a tracepoint in ext4_punch_hole.
CC: Lukas Czerner <lczerner@redhat.com>
After we have finished extending the file system, we need to trigger a
the lazy inode table thread to zero out the inode tables.
Validate the bh pointer before using it, since
ext4_read_block_bitmap_nowait() might return NULL.
I've seen this in fsfuzz testing.
EXT4-fs error (device loop0): ext4_read_block_bitmap_nowait:385: comm touch: Cannot get buffer for block bitmap - block_group = 0, block_bitmap = 3925999616
BUG: unable to handle kernel NULL pointer dereference at (null)
IP: [<ffffffff8121de25>] ext4_wait_block_bitmap+0x25/0xe0
Call Trace:
[<ffffffff8121e1e5>] ext4_read_block_bitmap+0x35/0x60
[<ffffffff8125e9c6>] ext4_free_blocks+0x236/0xb80
[<ffffffff811d0d36>] ? __getblk+0x36/0x70
[<ffffffff811d0a5f>] ? __find_get_block+0x8f/0x210
[<ffffffff81191ef3>] ? kmem_cache_free+0x33/0x140
[<ffffffff812678e5>] ext4_xattr_release_block+0x1b5/0x1d0
[<ffffffff812679be>] ext4_xattr_delete_inode+0xbe/0x100
[<ffffffff81222a7c>] ext4_free_inode+0x7c/0x4d0
[<ffffffff812277b8>] ? ext4_mark_inode_dirty+0x88/0x230
[<ffffffff8122993c>] ext4_evict_inode+0x32c/0x490
[<ffffffff811b8cd7>] evict+0xa7/0x1c0
[<ffffffff811b8ed3>] iput_final+0xe3/0x170
[<ffffffff811b8f9e>] iput+0x3e/0x50
[<ffffffff812316fd>] ext4_add_nondir+0x4d/0x90
[<ffffffff81231d0b>] ext4_create+0xeb/0x170
[<ffffffff811aae9c>] vfs_create+0xac/0xd0
[<ffffffff811ac845>] lookup_open+0x185/0x1c0
[<ffffffff8129e3b9>] ? selinux_inode_permission+0xa9/0x170
[<ffffffff811acb54>] do_last+0x2d4/0x7a0
[<ffffffff811af743>] path_openat+0xb3/0x480
[<ffffffff8116a8a1>] ? handle_mm_fault+0x251/0x3b0
[<ffffffff811afc49>] do_filp_open+0x49/0xa0
[<ffffffff811bbaad>] ? __alloc_fd+0xdd/0x150
[<ffffffff8119da28>] do_sys_open+0x108/0x1f0
[<ffffffff8119db51>] sys_open+0x21/0x30
[<ffffffff81618959>] system_call_fastpath+0x16/0x1b
Also fix comment for ext4_read_block_bitmap_nowait()
Signed-off-by: Eryu Guan <guaneryu@gmail.com>
Because the function 'sb_getblk' seldomly fails to return NULL
value,it will be better to use 'unlikely' to optimize it.
Signed-off-by: Wang Shilong <wangsl-fnst@cn.fujitsu.com>
The only reason for sb_getblk() failing is if it can't allocate the
buffer_head. So ENOMEM is more appropriate than EIO. In addition,
make sure that the file system is marked as being inconsistent if
sb_getblk() fails.
Pull ARM fixes from Russell King.
* 'fixes' of git://git.linaro.org/people/rmk/linux-arm:
ARM: 7616/1: cache-l2x0: aurora: Use writel_relaxed instead of writel
ARM: 7615/1: cache-l2x0: aurora: Invalidate during clean operation with WT enable
ARM: 7614/1: mm: fix wrong branch from Cortex-A9 to PJ4b
ARM: 7612/1: imx: Do not select some errata that depends on !ARCH_MULTIPLATFORM
ARM: 7611/1: VIC: fix bug in VIC irqdomain code
ARM: 7610/1: versatile: bump IRQ numbers
ARM: 7609/1: disable errata work-arounds which access secure registers
ARM: 7608/1: l2x0: Only set .set_debug on PL310 r3p0 and earlier
git://git.kernel.org/pub/scm/linux/kernel/git/bp/bp
Pull EDAC fixes from Borislav Petkov:
"Two error path fixes causing a crash and a Kconfig fix for an issue
which spilled all EDAC suboptions into the 'Device Drivers' menu."
* tag 'edac_fixes_for_3.8' of git://git.kernel.org/pub/scm/linux/kernel/git/bp/bp:
EDAC: Cleanup device deregistering path
EDAC: Fix EDAC Kconfig menu
EDAC: Fix kernel panic on module unloading
