Pull drm fixes from Dave Airlie:
"Some final radeon and i915 fixes, black screens mostly"
* 'drm-fixes' of git://people.freedesktop.org/~airlied/linux:
drm/radeon/cik: use a separate counter for CP init timeout
drm/i915/hdmi: fix hdmi audio state readout
drm/i915: Don't leak command parser tables on suspend/resume
drm/radeon: add PX quirk for asus K53TK
drm/radeon: add a backlight quirk for Amilo Xi 2550
drm/radeon: add a module parameter for backlight control (v2)
drm/radeon: Update IH_RB_RPTR register after each processed interrupt
drm/radeon: Make IH ring overflow debugging output more useful
drm/radeon: Clear RB_OVERFLOW bit earlier
into drm-fixes
- fix a backlight regression resulting in dark screen
- add a PX quirk to avoid a hang with runtime pm
- fix an init issue on the CIK compute rings
- fix IH ring buffer overflows gracefully
* 'drm-fixes-3.17' of git://people.freedesktop.org/~agd5f/linux:
git://anongit.freedesktop.org/drm-intel into drm-fixes
a couple of small fixes for 3.17 still.
* tag 'drm-intel-fixes-2014-09-24' of git://anongit.freedesktop.org/drm-intel:
Pull networking fixes from David Miller:
"Here is a quick pull request primarily meant to address the deconfig
fallout from changing SCSI_NETLINK from being used via 'select' to
being used via 'depends'.
I applied a set of 5 patches written by Michal Marek, and then I
carefully audited all of the remaining config files, basically:
1) I scanned every arch config file, and if it mentioned CONFIG_INET
or CONFIG_UNIX, I made sure it had CONFIG_NET=y
2) After that, I scanned every arch config file, and if it did not
have CONFIG_NET=y I made sure it did not reference any networking
config options.
Finally, we have some late breaking wireless fixes in here from John
Linville and co"
[ And there's a sparc bpf fix snuck in too ]
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net:
sparc: bpf_jit: fix loads from negative offsets
parisc: Update defconfigs which were missing CONFIG_NET.
powerpc: Update defconfigs which were missing CONFIG_NET.
s390: Update defconfigs which were missing CONFIG_NET.
mips: Update some more defconfigs which were missing CONFIG_NET.
sparc: Set CONFIG_NET=y in defconfigs
sh: Set CONFIG_NET=y in defconfigs
powerpc: Set CONFIG_NET=y in defconfigs
parisc: Set CONFIG_NET=y in defconfigs
mips: Set CONFIG_NET=y in defconfigs
brcmfmac: Fix off by one bug in brcmf_count_20mhz_channels()
ath9k: Fix NULL pointer dereference on early irq
net: rfkill: gpio: Fix clock status
NFC: st21nfca: Fix potential depmod dependency cycle
NFC: st21nfcb: Fix depmod dependency cycle
NFC: microread: Potential overflows in microread_target_discovered()
- fix BPF_LD|ABS|IND from negative offsets:
make sure to sign extend lower 32 bits in 64-bit register
before calling C helpers from JITed code, otherwise 'int k'
argument of bpf_internal_load_pointer_neg_helper() function
will be added as large unsigned integer, causing packet size
check to trigger and abort the program.
It's worth noting that JITed code for 'A = A op K' will affect
upper 32 bits differently depending whether K is simm13 or not.
Since small constants are sign extended, whereas large constants
are stored in temp register and zero extended.
That is ok and we don't have to pay a penalty of sign extension
for every sethi, since all classic BPF instructions have 32-bit
semantics and we only need to set correct upper bits when
transitioning from JITed code into C.
- though instructions 'A &= 0' and 'A *= 0' are odd, JIT compiler
should not optimize them out
Signed-off-by: Alexei Starovoitov <ast@plumgrid.com>
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless
John W. Linville says:
pull request: wireless 2014-09-23
Please consider pulling this one last batch of fixes intended for the 3.17 stream!
For the NFC bits, Samuel says:
"Hopefully not too late for a handful of NFC fixes:
- 2 potential build failures for ST21NFCA and ST21NFCB, triggered by a
depmod dependenyc cycle.
- One potential buffer overflow in the microread driver."
On top of that...
Emil Goode provides a fix for a brcmfmac off-by-one regression which
was introduced in the 3.17 cycle.
Loic Poulain fixes a polarity mismatch for a variable assignment
inside of rfkill-gpio.
Wojciech Dubowik prevents a NULL pointer dereference in ath9k.
Commit df568d8e ("scsi: Use 'depends' with LIBFC instead of
'select'.") removed what happened to be the only instance of 'select
NET'. Defconfigs that were relying on the select now lack networking
support.
support.
support.
support.
Commit 5d6be6a5 ("scsi_netlink : Make SCSI_NETLINK dependent on NET
instead of selecting NET") removed what happened to be the only instance
of 'select NET'. Defconfigs that were relying on the select now lack
networking support.
Cc: sparclinux@vger.kernel.org
networking support.
Cc: linux-sh@vger.kernel.org
networking support.
Cc: linuxppc-dev@lists.ozlabs.org
networking support.
Cc: linux-parisc@vger.kernel.org
networking support.
Cc: linux-mips@linux-mips.org
Pull one last block fix from Jens Axboe:
"We've had an issue with scsi-mq where probing takes forever. This was
bisected down to the percpu changes for blk_mq_queue_enter(), and the
fact we now suffer an RCU grace period when killing a queue. SCSI
creates and destroys tons of queues, so this let to 10s of seconds of
stalls at boot for some.
Tejun has a real fix for this, but it's too involved for 3.17. So
this is a temporary workaround to expedite the queue killing until we
can fold in the real fix for 3.18 when that merge window opens"
* 'for-linus' of git://git.kernel.dk/linux-block:
blk-mq, percpu_ref: implement a kludge for SCSI blk-mq stall during probe
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci
Pull PCI fixes from Bjorn Helgaas:
"Here are a few fixes that should be in v3.17.
- Reverting "Don't scan random busses" covers up a CardBus regression
having to do with allocating CardBus bus numbers.
- Reverting "Make sure bus numbers stay within parents bounds" covers
up an ACPI _CRS bug that makes us reconfigure a bridge, causing a
broken device behind it to stop responding.
- The pciehp timeout change fixes some code we added in v3.17.
Without the fix, we can send a new hotplug command too early,
before the timeout has expired.
I hope for better fixes for the reverts, but those will have to come
after v3.17"
* tag 'pci-v3.17-fixes-3' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci:
PCI: pciehp: Fix pcie_wait_cmd() timeout
Revert "PCI: Make sure bus number resources stay within their parents bounds"
Revert "PCI: Don't scan random busses in pci_scan_bridge()"
Pull crypto fixes from Herbert Xu:
"This fixes three issues:
- if ccp is loaded on a machine without ccp, it will incorrectly
activate causing all requests to fail. Fixed by preventing ccp
from loading if hardware isn't available.
- not all IRQs were enabled for the qat driver, leading to potential
stalls when it is used
- disabled buggy AVX CTR implementation in aesni"
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6:
crypto: aesni - disable "by8" AVX CTR optimization
crypto: ccp - Check for CCP before registering crypto algs
crypto: qat - Enable all 32 IRQs
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media
Pull media fixes from Mauro Carvalho Chehab:
"For some last time fixes:
- a regression detected on Kernel 3.16 related to VBI Teletext
application breakage on drivers using videobuf2 (see
https://bugzilla.kernel.org/show_bug.cgi?id=84401). The bug was
noticed on saa7134 (migrated to VB2 on 3.16), but also affects
em28xx (migrated on 3.9 to VB2);
- two additional sanity checks at videobuf2;
- two fixups to restore proper VBI support at the em28xx driver;
- two Kernel oops fixups (at cx24123 and cx2341x drivers);
- a bug at adv7604 where an if was doing just the opposite as it
would be expected;
- some documentation fixups to match the behavior defined at the
Kernel"
* tag 'media/v3.17-rc7' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media:
[media] em28xx-v4l: get rid of field "users" in struct em28xx_v4l2"
[media] em28xx: fix VBI handling logic
[media] DocBook media: improve the poll() documentation
[media] DocBook media: fix the poll() 'no QBUF' documentation
[media] vb2: fix VBI/poll regression
[media] cx2341x: fix kernel oops
[media] cx24123: fix kernel oops due to missing parent pointer
[media] adv7604: fix inverted condition
[media] media/radio: fix radio-miropcm20.c build with io.h header file
[media] vb2: fix plane index sanity check in vb2_plane_cookie()
[media] DocBook media: update version number and V4L2 changes
[media] DocBook media: fix fieldname in struct v4l2_subdev_selection
[media] vb2: fix vb2 state check when start_streaming fails
[media] videobuf2-core.h: fix comment
[media] videobuf2-core: add comments before the WARN_ON
[media] videobuf2-dma-sg: fix for wrong GFP mask to sg_alloc_table_from_pages
Pull bugfixes for md/raid1 from Neil Brown:
"It is amazing how much easier it is to find bugs when you know one is
there. Two bug reports resulted in finding 7 bugs!
All are tagged for -stable. Those that can't cause (rare) data
corruption, cause lockups.
Particularly, but not only, fixing new "resync" code"
* tag 'md/3.17-more-fixes' of git://git.neil.brown.name/md:
md/raid1: fix_read_error should act on all non-faulty devices.
md/raid1: count resync requests in nr_pending.
md/raid1: update next_resync under resync_lock.
md/raid1: Don't use next_resync to determine how far resync has progressed
md/raid1: make sure resync waits for conflicting writes to complete.
md/raid1: clean up request counts properly in close_sync()
md/raid1: be more cautious where we read-balance during resync.
md/raid1: intialise start_next_window for READ case to avoid hang
blk-mq uses percpu_ref for its usage counter which tracks the number
of in-flight commands and used to synchronously drain the queue on
freeze. percpu_ref shutdown takes measureable wallclock time as it
involves a sched RCU grace period. This means that draining a blk-mq
takes measureable wallclock time. One would think that this shouldn't
matter as queue shutdown should be a rare event which takes place
asynchronously w.r.t. userland.
Unfortunately, SCSI probing involves synchronously setting up and then
tearing down a lot of request_queues back-to-back for non-existent
LUNs. This means that SCSI probing may take more than ten seconds
when scsi-mq is used.
This will be properly fixed by implementing a mechanism to keep
q->mq_usage_counter in atomic mode till genhd registration; however,
that involves rather big updates to percpu_ref which is difficult to
apply late in the devel cycle (v3.17-rc6 at the moment). As a
stop-gap measure till the proper fix can be implemented in the next
cycle, this patch introduces __percpu_ref_kill_expedited() and makes
blk_mq_freeze_queue() use it. This is heavy-handed but should work
for testing the experimental SCSI blk-mq implementation.
Reported-by: Christoph Hellwig <hch@infradead.org>
Link: http://lkml.kernel.org/g/20140919113815.GA10791@lst.de
Fixes: add703fda981 ("blk-mq: use percpu_ref for mq usage count")
Cc: Kent Overstreet <kmo@daterainc.com>
Tested-by: Christoph Hellwig <hch@lst.de>
Signed-off-by: Jens Axboe <axboe@fb.com>
The "by8" implementation introduced in commit 22cddcc7df8f ("crypto: aes
- AES CTR x86_64 "by8" AVX optimization") is failing crypto tests as it
handles counter block overflows differently. It only accounts the right
most 32 bit as a counter -- not the whole block as all other
implementations do. This makes it fail the cryptomgr test #4 that
specifically tests this corner case.
As we're quite late in the release cycle, just disable the "by8" variant
for now.
Reported-by: Romain Francoise <romain@orebokech.com>
Signed-off-by: Mathias Krause <minipli@googlemail.com>
Cc: Chandramouli Narayanan <mouli@linux.intel.com>
If the ccp is built as a built-in module, then ccp-crypto (whether
built as a module or a built-in module) will be able to load and
it will register its crypto algorithms. If the system does not have
a CCP this will result in -ENODEV being returned whenever a command
is attempted to be queued by the registered crypto algorithms.
Add an API, ccp_present(), that checks for the presence of a CCP
on the system. The ccp-crypto module can use this to determine if it
should register it's crypto alogorithms.
Cc: stable@vger.kernel.org
Reported-by: Scot Doyle <lkml14@scotdoyle.com>
Signed-off-by: Tom Lendacky <thomas.lendacky@amd.com>
Tested-by: Scot Doyle <lkml14@scotdoyle.com>
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband
Pull infiniband/rdma fixes from Roland Dreier:
"Last late set of InfiniBand/RDMA fixes for 3.17:
- fixes for the new memory region re-registration support
- iSER initiator error path fixes
- grab bag of small fixes for the qib and ocrdma hardware drivers
- larger set of fixes for mlx4, especially in RoCE mode"
* tag 'rdma-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: (26 commits)
IB/mlx4: Fix VF mac handling in RoCE
IB/mlx4: Do not allow APM under RoCE
IB/mlx4: Don't update QP1 in native mode
IB/mlx4: Avoid accessing netdevice when building RoCE qp1 header
mlx4: Fix mlx4 reg/unreg mac to work properly with 0-mac addresses
IB/core: When marshaling uverbs path, clear unused fields
IB/mlx4: Avoid executing gid task when device is being removed
IB/mlx4: Fix lockdep splat for the iboe lock
IB/mlx4: Get upper dev addresses as RoCE GIDs when port comes up
IB/mlx4: Reorder steps in RoCE GID table initialization
IB/mlx4: Don't duplicate the default RoCE GID
IB/mlx4: Avoid null pointer dereference in mlx4_ib_scan_netdevs()
IB/iser: Bump version to 1.4.1
IB/iser: Allow bind only when connection state is UP
IB/iser: Fix RX/TX CQ resource leak on error flow
RDMA/ocrdma: Use right macro in query AH
RDMA/ocrdma: Resolve L2 address when creating user AH
mlx4: Correct error flows in rereg_mr
IB/qib: Correct reference counting in debugfs qp_stats
IPoIB: Remove unnecessary port query
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound
Pull sound fixes from Takashi Iwai:
"One fix is about a buggy computation in PCM API function Clemens
spotted out, but the impact must be really small as no one really uses
it in user-space side.
The rest are a trivial fix for a HD-audio model and a USB-audio
device-specific regression fix, so all look fairly safe to apply"
* tag 'sound-3.17-rc7' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound:
ALSA: snd-usb-caiaq: Fix LED commands for Kore controller
ALSA: pcm: fix fifo_size frame calculation
ALSA: hda - Add fixup model name lookup for Lemote A1205
Pull final block fixes from Jens Axboe:
"This week and last we've been fixing some corner cases related to
blk-mq, mostly. I ended up pulling most of that out of for-linus
yesterday, which is why the branch looks fresh. The rest were
postponed for 3.18.
This pull request contains:
- Fix from Christoph, avoiding a stack overflow when FUA insertion
would recursive infinitely.
- Fix from David Hildenbrand on races between the timeout handler and
uninitialized requests. Fixes a real issue that virtio_blk has run
into.
- A few fixes from me:
- Ensure that request deadline/timeout is ordered before the
request is marked as started.
- A potential oops on out-of-memory, when we scale the queue
depth of the device and retry.
- A hang fix on requeue from SCSI, where the hardware queue
would be stopped when we attempt to re-run it (and hence
nothing would happen, stalling progress).
- A fix for commit 2da78092, where the cleanup path was moved
to RCU, but a debug might_sleep() was inadvertently left in
the code. This causes warnings for people"
genhd: fix leftover might_sleep() in blk_free_devt()
blk-mq: use blk_mq_start_hw_queues() when running requeue work
blk-mq: fix potential oops on out-of-memory in __blk_mq_alloc_rq_maps()
blk-mq: avoid infinite recursion with the FUA flag
blk-mq: Avoid race condition with uninitialized requests
blk-mq: request deadline must be visible before marking rq as started
git://git.kernel.org/pub/scm/linux/kernel/git/deller/parisc-linux
Pull parisc fixes from Helge Deller:
"We avoid using -mfast-indirect-calls for 64bit kernel builds to
prevent building an unbootable kernel due to latest gcc changes.
In the pdc_stable/firmware-access driver we fix a few possible stack
overflows and we now call secure_computing_strict() instead of
secure_computing() which fixes upcoming SECCOMP patches in the
for-next trees"
* 'parisc-3.17-7' of git://git.kernel.org/pub/scm/linux/kernel/git/deller/parisc-linux:
parisc: Only use -mfast-indirect-calls option for 32-bit kernel builds
parisc: pdc_stable.c: Avoid potential stack overflows
parisc: pdc_stable.c: Cleaning up unnecessary use of memset in conjunction with strncpy
parisc: ptrace: use secure_computing_strict()
In spite of what the GCC manual says, the -mfast-indirect-calls has
never been supported in the 64-bit parisc compiler. Indirect calls have
always been done using function descriptors irrespective of the
-mfast-indirect-calls option.
Recently, it was noticed that a function descriptor was always requested
when the -mfast-indirect-calls option was specified. This caused
problems when the option was used in application code and doesn't make
any sense because the whole point of the option is to avoid using a
function descriptor for indirect calls.
Fixing this broke 64-bit kernel builds.
I will fix GCC but for now we need the attached change. This results in
the same kernel code as before.
Signed-off-by: John David Anglin <dave.anglin@bell.net>
Cc: stable@vger.kernel.org # v3.0+
Signed-off-by: Helge Deller <deller@gmx.de>
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux
Pull ia64 defconfig update from Tony Luck:
"Need to rebuild defconfig files to cope with removal of "select NET"
in drivers/scsi/Kconfig"
* tag 'please-pull-defconfig' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux:
[IA64] refresh arch/ia64/configs/* using "make savedefconfig"
git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging
Pull hwmon fixes from Guenter Roeck:
- Fix a resource leak in tmp103 driver
- Add support for two more processors to fam15h_power driver
- Also fix a bug in the same driver to only report the power level on
chips which actually support reporting it
* tag 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging:
hwmon: (tmp103) Fix resource leak bug in tmp103 temperature sensor driver
hwmon: (fam15h_power) Add support for two more processors
hwmon: (fam15h_power) Make actual power reporting conditional
Prompted by a change to drivers/scsi/Kconfig which used to do a
"select NET" but now does a "depends on NET". This meant that some
configurations ended up without CONFIG_NET=y
Signed-off-by Tony Luck <tony.luck@intel.com>
Pull another kvm fix from Paolo Bonzini:
"Another fix for 3.17 arrived at just the wrong time, after I had sent
yesterday's pull request. Normally I would have waited for some other
patches to pile up, but since 3.17 might be short here it is"
* tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm:
arm/arm64: KVM: Fix unaligned access bug on gicv2 access
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup
Pull cgroup fix from Tejun Heo:
"One late fix for cgroup.
I was waiting for another set of fixes for a long-standing obscure
cpuset bug but am not sure whether they'll be ready before v3.17
release. This one is a simple fix for a mutex unlock balance bug in
an allocation failure path in pidlist_array_load().
The bug was introduced in v3.14 and the fix is tagged for -stable"
* 'for-3.17-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup:
cgroup: fix unbalanced locking
In the brcmf_count_20mhz_channels function we are looping through a list
of channels received from firmware. Since the index of the first channel
is 0 the condition leads to an off by one bug. This is causing us to hit
the WARN_ON_ONCE(1) calls in the brcmu_d11n_decchspec function, which is
how I discovered the bug.
Introduced by:
commit b48d891676f756d48b4d0ee131e4a7a5d43ca417
("brcmfmac: rework wiphy structure setup")
Acked-by: Arend van Spriel <arend@broadcom.com>
Signed-off-by: Emil Goode <emilgoode@gmail.com>
Otherwise we may fail to init the second compute ring.
Noticed-by: Christian König <christian.koenig@amd.com>
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
Check the correct bit for audio. Seems like a copy-paste error from the
start:
commit 9ed109a7b445e3f073d8ea72f888ec80c0532465
Author: Daniel Vetter <daniel.vetter@ffwll.ch>
Date: Thu Apr 24 23:54:52 2014 +0200
drm/i915: Track has_audio in the pipe config
Reported-by: Martin Andersen <martin.x.andersen@gmail.com>
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=82756
Cc: stable@vger.kernel.org # 3.16+
Cc: Daniel Vetter <daniel.vetter@ffwll.ch>
Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Signed-off-by: Jani Nikula <jani.nikula@intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/kvmarm/kvmarm into kvm-master
Fixes unaligned access to the gicv2 virtual cpu status.
Ring init and cleanup are not balanced because we re-init the rings on
resume without having cleaned them up on suspend. This leads to the
driver leaking the parser's hash tables with a kmemleak signature such
as this:
unreferenced object 0xffff880405960980 (size 32):
comm "systemd-udevd", pid 516, jiffies 4294896961 (age 10202.044s)
hex dump (first 32 bytes):
d0 85 46 c0 ff ff ff ff 00 00 00 00 00 00 00 00 ..F.............
98 60 28 04 04 88 ff ff 00 00 00 00 00 00 00 00 .`(.............
backtrace:
[<ffffffff81816f9e>] kmemleak_alloc+0x4e/0xb0
[<ffffffff811fa678>] kmem_cache_alloc_trace+0x168/0x2f0
[<ffffffffc03e20a5>] i915_cmd_parser_init_ring+0x2a5/0x3e0 [i915]
[<ffffffffc04088a2>] intel_init_ring_buffer+0x202/0x470 [i915]
[<ffffffffc040c998>] intel_init_vebox_ring_buffer+0x1e8/0x2b0 [i915]
[<ffffffffc03eff59>] i915_gem_init_hw+0x2f9/0x3a0 [i915]
[<ffffffffc03f0057>] i915_gem_init+0x57/0x1d0 [i915]
[<ffffffffc045e26a>] i915_driver_load+0xc0a/0x10e0 [i915]
[<ffffffffc02e0d5d>] drm_dev_register+0xad/0x100 [drm]
[<ffffffffc02e3b9f>] drm_get_pci_dev+0x8f/0x200 [drm]
[<ffffffffc03c934b>] i915_pci_probe+0x3b/0x60 [i915]
[<ffffffff81436725>] local_pci_probe+0x45/0xa0
[<ffffffff81437a69>] pci_device_probe+0xd9/0x130
[<ffffffff81524f4d>] driver_probe_device+0x12d/0x3e0
[<ffffffff815252d3>] __driver_attach+0x93/0xa0
[<ffffffff81522e1b>] bus_for_each_dev+0x6b/0xb0
This patch extends the current convention of checking whether a
resource is already allocated before allocating it during ring init.
Longer term it might make sense to only init the rings once.
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=83794
Tested-by: Kari Suvanto <kari.tj.suvanto@gmail.com>
Signed-off-by: Brad Volkin <bradley.d.volkin@intel.com>
This reverts commit 9cb0e394234d244fe5a97e743ec9dd7ddff7e64b.
It causes my Sony Vaio Pro 11 to immediately reboot at startup.
Acked-by: Ingo Molnar <mingo@kernel.org>
Cc: Peter Anvin <hpa@zytor.com>
Cc: Maarten Lankhorst <maarten.lankhorst@canonical.com>
Cc: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Cc: Matt Fleming <matt.fleming@intel.com>
pcie_poll_cmd() take msecs instead of jiffies, so convert timeout to msecs.
Fixes: 40b960831cfa ("PCI: pciehp: Compute timeout from hotplug command start time")
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
1) If the user gives us a msg_namelen of 0, don't try to interpret
anything pointed to by msg_name. From Ani Sinha.
2) Fix some bnx2i/bnx2fc randconfig compilation errors.
The gist of the issue is that we firstly have drivers that span both
SCSI and networking. And at the top of that chain of dependencies
we have things like SCSI_FC_ATTRS and SCSI_NETLINK which are
selected.
But since select is a sledgehammer and ignores dependencies,
everything to select's SCSI_FC_ATTRS and/or SCSI_NETLINK has to also
explicitly select their dependencies and so on and so forth.
Generally speaking 'select' is supposed to only be used for child
nodes, those which have no dependencies of their own. And this
whole chain of dependencies in the scsi layer violates that rather
strongly.
So just make SCSI_NETLINK depend upon it's dependencies, and so on
and so forth for the things selecting it (either directly or
indirectly).
From Anish Bhatt and Randy Dunlap.
3) Fix generation of blackhole routes in IPSEC, from Steffen Klassert.
4) Actually notice netdev feature changes in rtl_open() code, from
Hayes Wang.
5) Fix divide by zero in bond enslaving, from Nikolay Aleksandrov.
6) Missing memory barrier in sunvnet driver, from David Stevens.
7) Don't leave anycast addresses around when ipv6 interface is
destroyed, from Sabrina Dubroca.
8) Don't call efx_{arch}_filter_sync_rx_mode before addr_list_lock is
initialized in SFC driver, from Edward Cree.
9) Fix missing DMA error checking in 3c59x, from Neal Horman.
10) Openvswitch doesn't emit OVS_FLOW_CMD_NEW notifications accidently,
fix from Samuel Gauthier.
11) pch_gbe needs to select NET_PTP_CLASSIFY otherwise we can get a
build error.
12) Fix macvlan regression wherein we stopped emitting
broadcast/multicast frames over software devices. From Nicolas
Dichtel.
13) Fix infiniband bug due to unintended overflow of skb->cb[], from
Eric Dumazet. And add an assertion so this doesn't happen again.
14) dm9000_parse_dt() should return error pointers, not NULL. From
Tobias Klauser.
15) IP tunneling code uses this_cpu_ptr() in preemptible contexts, fix
from Eric Dumazet.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (87 commits)
net: bcmgenet: call bcmgenet_dma_teardown in bcmgenet_fini_dma
net: bcmgenet: fix TX reclaim accounting for fragments
ipv4: do not use this_cpu_ptr() in preemptible context
dm9000: Return an ERR_PTR() in all error conditions of dm9000_parse_dt()
r8169: fix an if condition
r8152: disable ALDPS
ipoib: validate struct ipoib_cb size
net: sched: shrink struct qdisc_skb_cb to 28 bytes
tg3: Work around HW/FW limitations with vlan encapsulated frames
macvlan: allow to enqueue broadcast pkt on virtual device
pch_gbe: 'select' NET_PTP_CLASSIFY.
scsi: Use 'depends' with LIBFC instead of 'select'.
openvswitch: restore OVS_FLOW_CMD_NEW notifications
genetlink: add function genl_has_listeners()
lib: rhashtable: remove second linux/log2.h inclusion
net: allow macvlans to move to net namespace
3c59x: Fix bad offset spec in skb_frag_dma_map
3c59x: Add dma error checking and recovery
sparc: bpf_jit: fix support for ldx/stx mem and SKF_AD_VLAN_TAG
can: at91_can: add missing prepare and unprepare of the clock
git://git.linaro.org/people/mike.turquette/linux
Pull clock layer fixes from Mike Turquette:
"The fixes for the clock tree are mostly run-time bugs in clock
drivers.
The fixes for TI DRA7 remove divide-by-zero errors. The recently
merged AT91 clock driver fixes some bad error checking and the QCOM
driver fix restores audio for that platform, a clear regression. A
list iteration bug in the framework core was hit recently and is fixed
up here. Finally a compilation warning is fixed for efm32gg, which is
also a regression fix"
* tag 'clk-fixes-for-linus' of git://git.linaro.org/people/mike.turquette/linux:
clk/efm32gg: fix dt init prototype
clk: prevent erronous parsing of children during rate change
clk: rockchip: Fix the clocks for i2c1 and i2c2
clk: qcom: Fix sdc 144kHz frequency entry
clk: at91: fix num_parents test in at91sam9260 slow clk implementation
clk: ti: dra7-atl: Provide error check for incoming parameters in set_rate
clk: ti: divider: Provide error check for incoming parameters in set_rate
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-fs
Pull fs-cache fixes from David Howells:
- Put a timeout in releasepage() to deal with a recursive hang between
the memory allocator, writeback, ext4 and fscache under memory
pressure.
- Fix a pair of refcount bugs in the fscache error handling.
- Remove a couple of unused pagevecs.
- The cachefiles requirement that the base directory support rename
should permit rename2 as an alternative - otherwise certain
filesystems cannot now be used as backing stores (such as ext4).
* tag 'fscache-fixes-20140917' of git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-fs:
CacheFiles: Handle rename2
cachefiles: remove two unused pagevecs.
FS-Cache: refcount becomes corrupt under vma pressure.
FS-Cache: Reduce cookie ref count if submit fails.
FS-Cache: Timeout for releasepage()
Florian Fainelli says:
net: bcmgenet: TX reclaim and DMA fixes
This patch set contains one fix for an accounting problem while reclaiming
transmitted buffers having fragments, and the second fix is to make sure
that the DMA shutdown is properly controlled.
We should not be manipulaging the DMA_CTRL registers directly by writing
0 to them to disable DMA. This is an operation that needs to be timed to
make sure the DMA engines have been properly stopped since their state
machine stops on a packet boundary, not immediately.
Make sure that tha bcmgenet_fini_dma() calls bcmgenet_dma_teardown() to
ensure a proper DMA engine state. As a result, we need to reorder the
function bodies to resolve the use dependency.
Fixes: 1c1008c793fa ("net: bcmgenet: add main driver file")
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
The GENET driver supports SKB fragments, and succeeds in transmitting
them properly, but when reclaiming these transmitted fragments, we will
only update the count of free buffer descriptors by 1, even for SKBs
with fragments. This leads to the networking stack thinking it has more
room than the hardware has when pushing new SKBs, and backing off
consequently because we return NETDEV_TX_BUSY.
Fix this by accounting for the SKB nr_frags plus one (itself) and update
ring->free_bds accordingly with that value for each iteration loop in
__bcmgenet_tx_reclaim().
this_cpu_ptr() in preemptible context is generally bad
Sep 22 05:05:55 br kernel: [ 94.608310] BUG: using smp_processor_id()
in
preemptible [00000000] code: ip/2261
Sep 22 05:05:55 br kernel: [ 94.608316] caller is
tunnel_dst_set.isra.28+0x20/0x60 [ip_tunnel]
Sep 22 05:05:55 br kernel: [ 94.608319] CPU: 3 PID: 2261 Comm: ip Not
tainted
3.17.0-rc5 #82
We can simply use raw_cpu_ptr(), as preemption is safe in these
contexts.
Should fix https://bugzilla.kernel.org/show_bug.cgi?id=84991
Reported-by: Joe <joe9mail@gmail.com>
Fixes: 9a4aa9af447f ("ipv4: Use percpu Cache route in IP tunnels")
Acked-by: Tom Herbert <therbert@google.com>
Seems to have problems turning the dGPU on/off.
bug:
https://bugzilla.kernel.org/show_bug.cgi?id=51381
Only the acpi backlight seems to work. Using the
radeon backlight controller causes the backlight to
go off.
bug:
https://bugs.freedesktop.org/show_bug.cgi?id=81382
Add a module parameter to disable the radeon GPU backlight
controller to override the automatic detection. Some
laptops seems to indicate that they use the integrated
controller, but appear to actually use an external
controller.
bug:
v2: fix module parameter description
