2009-07-10Doc: move Documentation/exception.txt into x86 subdirAmerigo Wang
exception.txt only explains the code on x86, so it's better to move it into Documentation/x86 directory. And also rename it to exception-tables.txt which looks much more reasonable. This patch is on top of the previous one. Signed-off-by: WANG Cong <amwang@redhat.com> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-10Doc: update Documentation/exception.txtAmerigo Wang
Update Documentation/exception.txt. Remove trailing whitespaces in it. Signed-off-by: WANG Cong <amwang@redhat.com> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-10fuse: Fix build errorLarry Finger
When building v2.6.31-rc2-344-g69ca06c, the following build errors are found due to missing includes: CC [M] fs/fuse/dev.o fs/fuse/dev.c: In function ‘request_end’: fs/fuse/dev.c:289: error: ‘BLK_RW_SYNC’ undeclared (first use in this function) ... fs/nfs/write.c: In function ‘nfs_set_page_writeback’: fs/nfs/write.c:207: error: ‘BLK_RW_ASYNC’ undeclared (first use in this function) Signed-off-by: Larry Finger@lwfinger.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-10Merge branch 'for-linus' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-linus' of git://git.kernel.dk/linux-2.6-block: cfq-iosched: reset oom_cfqq in cfq_set_request() block: fix sg SG_DXFER_TO_FROM_DEV regression block: call blk_scsi_ioctl_init() Fix congestion_wait() sync/async vs read/write confusion
2009-07-10Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ryusuke/nilfs2 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ryusuke/nilfs2: nilfs2: fix disorder in cp count on error during deleting checkpoints nilfs2: fix lockdep warning between regular file and inode file nilfs2: fix incorrect KERN_CRIT messages in case of write failures nilfs2: fix hang problem of log writer which occurs after write failures nilfs2: remove unlikely directive causing mis-conversion of error code
2009-07-10Merge branch 'core-fixes-for-linus-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-fixes-for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: dma-debug: Fix the overlap() function to be correct and readable oprofile: reset bt_lost_no_mapping with other stats x86/oprofile: rename kernel parameter for architectural perfmon to arch_perfmon signals: declare sys_rt_tgsigqueueinfo in syscalls.h rcu: Mark Hierarchical RCU no longer experimental dma-debug: Put all hash-chain locks into the same lock class dma-debug: fix off-by-one error in overlap function
2009-07-10Merge branch 'perfcounters-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perfcounters-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (50 commits) perf report: Add "Fractal" mode output - support callchains with relative overhead rate perf_counter tools: callchains: Manage the cumul hits on the fly perf report: Change default callchain parameters perf report: Use a modifiable string for default callchain options perf report: Warn on callchain output request from non-callchain file x86: atomic64: Inline atomic64_read() again x86: atomic64: Clean up atomic64_sub_and_test() and atomic64_add_negative() x86: atomic64: Improve atomic64_xchg() x86: atomic64: Export APIs to modules x86: atomic64: Improve atomic64_read() x86: atomic64: Code atomic(64)_read and atomic(64)_set in C not CPP x86: atomic64: Fix unclean type use in atomic64_xchg() x86: atomic64: Make atomic_read() type-safe x86: atomic64: Reduce size of functions x86: atomic64: Improve atomic64_add_return() x86: atomic64: Improve cmpxchg8b() x86: atomic64: Improve atomic64_read() x86: atomic64: Move the 32-bit atomic64_t implementation to a .c file x86: atomic64: The atomic64_t data type should be 8 bytes aligned on 32-bit too perf report: Annotate variable initialization ...
2009-07-10sched: optimize cond_resched()Peter Zijlstra
Optimize cond_resched() by removing one conditional. Currently cond_resched() checks system_state == SYSTEM_RUNNING in order to avoid scheduling before the scheduler is running. We can however, as per suggestion of Matt, use PREEMPT_ACTIVE to accomplish that very same. Suggested-by: Matt Mackall <mpm@selenic.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Matt Mackall <mpm@selenic.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-10sched: INIT_PREEMPT_COUNTPeter Zijlstra
Pull the initial preempt_count value into a single definition site. Maintainers for: alpha, ia64 and m68k, please have a look, your arch code is funny. The header magic is a bit odd, but similar to the KERNEL_DS one, CPP waits with expanding these macros until the INIT_THREAD_INFO macro itself is expanded, which is in arch/*/kernel/init_task.c where we've already included sched.h so we're good. Cc: tony.luck@intel.com Cc: rth@twiddle.net Cc: geert@linux-m68k.org Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Matt Mackall <mpm@selenic.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-10dma-debug: Fix the overlap() function to be correct and readableIngo Molnar
Linus noticed how unclean and buggy the overlap() function is: - It uses convoluted (and bug-causing) positive checks for range overlap - instead of using a more natural negative check. - Even the positive checks are buggy: a positive intersection check has four natural cases while we checked only for three, missing the (addr < start && addr2 == end) case for example. - The variables are mis-named, making it non-obvious how the check was done. - It needlessly uses u64 instead of unsigned long. Since these are kernel memory pointers and we explicitly exclude highmem ranges anyway we cannot ever overflow 32 bits, even if we could. (and on 64-bit it doesnt matter anyway) All in one, this function needs a total revamp. I used Linus's suggestions minus the paranoid checks (we cannot overflow really because if we get totally bad DMA ranges passed far more things break in the systems than just DMA debugging). I also fixed a few other small details i noticed. Reported-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Joerg Roedel <joerg.roedel@amd.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-07-10Merge branch 'tracing-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'tracing-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: tracing: Fix trace_print_seq() kprobes: No need to unlock kprobe_insn_mutex tracing/fastboot: Document the need of initcall_debug trace_export: Repair missed fields tracing: Fix stack tracer sysctl handling
2009-07-10cfq-iosched: reset oom_cfqq in cfq_set_request()Vivek Goyal
In case memory is scarce, we now default to oom_cfqq. Once memory is available again, we should allocate a new cfqq and stop using oom_cfqq for a particular io context. Once a new request comes in, check if we are using oom_cfqq, and if yes, try to allocate a new cfqq. Tested the patch by forcing the use of oom_cfqq and upon next request thread realized that it was using oom_cfqq and it allocated a new cfqq. Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-07-10block: fix sg SG_DXFER_TO_FROM_DEV regressionFUJITA Tomonori
I overlooked SG_DXFER_TO_FROM_DEV support when I converted sg to use the block layer mapping API (2.6.28). Douglas Gilbert explained SG_DXFER_TO_FROM_DEV: http://www.spinics.net/lists/linux-scsi/msg37135.html = The semantics of SG_DXFER_TO_FROM_DEV were: - copy user space buffer to kernel (LLD) buffer - do SCSI command which is assumed to be of the DATA_IN (data from device) variety. This would overwrite some or all of the kernel buffer - copy kernel (LLD) buffer back to the user space. The idea was to detect short reads by filling the original user space buffer with some marker bytes ("0xec" it would seem in this report). The "resid" value is a better way of detecting short reads but that was only added this century and requires co-operation from the LLD. = This patch changes the block layer mapping API to support this semantics. This simply adds another field to struct rq_map_data and enables __bio_copy_iov() to copy data from user space even with READ requests. It's better to add the flags field and kills null_mapped and the new from_user fields in struct rq_map_data but that approach makes it difficult to send this patch to stable trees because st and osst drivers use struct rq_map_data (they were converted to use the block layer in 2.6.29 and 2.6.30). Well, I should clean up the block layer mapping API. zhou sf reported this regiression and tested this patch: http://www.spinics.net/lists/linux-scsi/msg37128.html http://www.spinics.net/lists/linux-scsi/msg37168.html Reported-by: zhou sf <sxzzsf@gmail.com> Tested-by: zhou sf <sxzzsf@gmail.com> Cc: stable@kernel.org Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-07-10block: call blk_scsi_ioctl_init()FUJITA Tomonori
Currently, blk_scsi_ioctl_init() is not called since it lacks an initcall marking. This causes the command table to be unitialized, hence somce commands are block when they should not have been. This fixes a regression introduced by commit 018e0446890661504783f92388ecce7138c1566d Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-07-10Fix congestion_wait() sync/async vs read/write confusionJens Axboe
Commit 1faa16d22877f4839bd433547d770c676d1d964c accidentally broke the bdi congestion wait queue logic, causing us to wait on congestion for WRITE (== 1) when we really wanted BLK_RW_ASYNC (== 0) instead. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-07-10oprofile: reset bt_lost_no_mapping with other statsMaynard Johnson
The bt_lost_no_mapping is not getting reset at the start of a profiling run, thus the oprofiled.log shows erroneous values for this statistic. The attached patch fixes this problem. Signed-off-by: Maynard Johnson <maynardj@us.ibm.com> Signed-off-by: Robert Richter <robert.richter@amd.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-07-09Merge git://git.kernel.org/pub/scm/linux/kernel/git/wim/linux-2.6-watchdogLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/wim/linux-2.6-watchdog: [WATCHDOG] w83627hf_wdt.c: add support for the W83627EHF support [WATCHDOG] SA1100 watchdog maximum timeout [WATCHDOG] w83697ug, fix lock imbalance [WATCHDOG] drivers/watchdog/bcm47xx_wdt.c: Remove unnecessary semicolons
2009-07-09mx3fb: fix regression with uninitalized fb_info->mm_lock mutexKrzysztof Helt
Remove call to the mx3fb_set_par() and the mx3fb_blank() before the register_framebuffer(). This fixes a problem with uninitialized the fb_info->mm_lock mutex introduced by the commit 537a1bf059f " fbdev: add mutex for fb_mmap locking" Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-09sm501fb: fix regression with uninitalized fb_info->mm_lock mutexKrzysztof Helt
Remove call to the fb_set_par() before the register_framebuffer(). This fixes a problem with uninitialized the fb_info->mm_lock mutex introduced by the commit 537a1bf059f " fbdev: add mutex for fb_mmap locking" Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-09Merge git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6: cifs: when ATTR_READONLY is set, only clear write bits on non-directories cifs: remove cifsInodeInfo->inUse counter cifs: convert cifs_get_inode_info and non-posix readdir to use cifs_iget [CIFS] update cifs version number cifs: add and use CIFSSMBUnixSetFileInfo for setattr calls cifs: make a separate function for filling out FILE_UNIX_BASIC_INFO cifs: rename CIFSSMBUnixSetInfo to CIFSSMBUnixSetPathInfo cifs: add pid of initiating process to spnego upcall info cifs: fix regression with O_EXCL creates and optimize away lookup cifs: add new cifs_iget function and convert unix codepath to use it
2009-07-09Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (29 commits) cxgb3: Fix crash caused by stashing wrong netdev_queue ixgbe: Fix coexistence of FCoE and Flow Director in 82599 memory barrier: adding smp_mb__after_lock net: adding memory barrier to the poll and receive callbacks netpoll: Fix carrier detection for drivers that are using phylib includecheck fix: include/linux, rfkill.h p54: tx refused but queue active Atheros Kconfig needs to be dependent on WLAN_80211 mac80211: fix docbook mac80211_hwsim: avoid NULL access ssb: Add support for 4318E b43: Add support for 4318E zd1211rw: adding SONY IFU-WLM2 (054c:0257) as a zd1211b device zd1211rw: 07b8:6001 is a ZD1211B r6040: bump driver version to 0.24 and date to 08 July 2009 r6040: restore MIER register correctly when IRQ line is shared ipv4: Fix fib_trie rebalancing, part 4 (root thresholds) davinci_emac: fix kernel oops when changing MAC address while interface is down igb: set lan id prior to configuring phy mac80211: minstrel: avoid accessing negative indices in rix_to_ndx() ...
2009-07-09Fix compile error in bmac.cDave Jones
Looks like the change in ad361c9884e809340f6daca80d56a9e9c871690a wasn't compile tested. Signed-off-by: Dave Jones <davej@redhat.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-10x86/oprofile: rename kernel parameter for architectural perfmon to arch_perfmonRobert Richter
The short name of the achitecture is 'arch_perfmon'. This patch changes the kernel parameter to use this name. Cc: Andi Kleen <andi@firstfloor.org> Signed-off-by: Robert Richter <robert.richter@amd.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-07-09cxgb3: Fix crash caused by stashing wrong netdev_queueRoland Dreier
Commit c3a8c5b6 ("cxgb3: move away from LLTX") exposed a bug in how cxgb3 looks up the netdev_queue it stashes away in a qset during initialization. For multiport devices, the TX queue index it uses is offset by the first_qset index of each port. This leads to a crash once LLTX is removed, since hard_start_xmit is called with one TX queue lock held, while the TX reclaim timer task grabs a different (wrong) TX queue lock when it frees skbs. Fix this by removing the first_qset offset used to look up the TX queue passed into t3_sge_alloc_qset() from setup_sge_qsets(). Signed-off-by: Roland Dreier <rolandd@cisco.com> Acked-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-09ixgbe: Fix coexistence of FCoE and Flow Director in 82599Yi Zou
Fix coexistence of Fiber Channel over Ethernet (FCoE) and Flow Director (FDIR) in 82599 and remove the disabling of FDIR when FCoE is enabled. Currently, FDIR is turned off when FCoE is enabled under the assumption that FCoE is always enabled with DCB being turned on. However, FDIR does not have to be turned off all the time when FCoE is enabled since FCoE can be enabled without DCB being turned on, e.g., use link pause only. This patch makes sure that when DCB is turned on or off, FDIR is turned on or off correspondingly; and when FCoE is enabled, it does not disable FDIR, rather, it will have FDIR set up properly so FCoE and FDIR can coexist regardless of DCB being on or off. Signed-off-by: Yi Zou <yi.zou@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-09memory barrier: adding smp_mb__after_lockJiri Olsa
Adding smp_mb__after_lock define to be used as a smp_mb call after a lock. Making it nop for x86, since {read|write|spin}_lock() on x86 are full memory barriers. Signed-off-by: Jiri Olsa <jolsa@redhat.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-09net: adding memory barrier to the poll and receive callbacksJiri Olsa
Adding memory barrier after the poll_wait function, paired with receive callbacks. Adding fuctions sock_poll_wait and sk_has_sleeper to wrap the memory barrier. Without the memory barrier, following race can happen. The race fires, when following code paths meet, and the tp->rcv_nxt and __add_wait_queue updates stay in CPU caches. CPU1 CPU2 sys_select receive packet ... ... __add_wait_queue update tp->rcv_nxt ... ... tp->rcv_nxt check sock_def_readable ... { schedule ... if (sk->sk_sleep && waitqueue_active(sk->sk_sleep)) wake_up_interruptible(sk->sk_sleep) ... } If there was no cache the code would work ok, since the wait_queue and rcv_nxt are opposit to each other. Meaning that once tp->rcv_nxt is updated by CPU2, the CPU1 either already passed the tp->rcv_nxt check and sleeps, or will get the new value for tp->rcv_nxt and will return with new data mask. In both cases the process (CPU1) is being added to the wait queue, so the waitqueue_active (CPU2) call cannot miss and will wake up CPU1. The bad case is when the __add_wait_queue changes done by CPU1 stay in its cache, and so does the tp->rcv_nxt update on CPU2 side. The CPU1 will then endup calling schedule and sleep forever if there are no more data on the socket. Calls to poll_wait in following modules were ommited: net/bluetooth/af_bluetooth.c net/irda/af_irda.c net/irda/irnet/irnet_ppp.c net/mac80211/rc80211_pid_debugfs.c net/phonet/socket.c net/rds/af_rds.c net/rfkill/core.c net/sunrpc/cache.c net/sunrpc/rpc_pipe.c net/tipc/socket.c Signed-off-by: Jiri Olsa <jolsa@redhat.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-09cifs: when ATTR_READONLY is set, only clear write bits on non-directoriesJeff Layton
cifs: when ATTR_READONLY is set, only clear write bits on non-directories On windows servers, ATTR_READONLY apparently either has no meaning or serves as some sort of queue to certain applications for unrelated behavior. This MS kbase article has details: http://support.microsoft.com/kb/326549/ Don't clear the write bits directory mode when ATTR_READONLY is set. Reported-by: pouchat@peewiki.net Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2009-07-09cifs: remove cifsInodeInfo->inUse counterJeff Layton
cifs: remove cifsInodeInfo->inUse counter It was purported to be a refcounter of some sort, but was never used that way. It never served any purpose that wasn't served equally well by the I_NEW flag. Signed-off-by: Jeff Layton <jlayton@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Steve French <sfrench@us.ibm.com>
2009-07-09cifs: convert cifs_get_inode_info and non-posix readdir to use cifs_igetJeff Layton
cifs: convert cifs_get_inode_info and non-posix readdir to use cifs_iget Rather than allocating an inode and filling it out, have cifs_get_inode_info fill out a cifs_fattr and call cifs_iget. This means a pretty hefty reorganization of cifs_get_inode_info. For the readdir codepath, add a couple of new functions for filling out cifs_fattr's from different FindFile response infolevels. Finally, remove cifs_new_inode since there are no more callers. Signed-off-by: Jeff Layton <jlayton@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Steve French <sfrench@us.ibm.com>
2009-07-09[CIFS] update cifs version numberSteve French
2009-07-09cifs: add and use CIFSSMBUnixSetFileInfo for setattr callsJeff Layton
cifs: add and use CIFSSMBUnixSetFileInfo for setattr calls When there's an open filehandle, SET_FILE_INFO is apparently preferred over SET_PATH_INFO. Add a new variant that sets a FILE_UNIX_INFO_BASIC infolevel via SET_FILE_INFO and switch cifs_setattr_unix to use the new call when there's an open filehandle available. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2009-07-09cifs: make a separate function for filling out FILE_UNIX_BASIC_INFOJeff Layton
cifs: make a separate function for filling out FILE_UNIX_BASIC_INFO The SET_FILE_INFO variant will need to do the same thing here. Break this code out into a separate function that both variants can call. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2009-07-09cifs: rename CIFSSMBUnixSetInfo to CIFSSMBUnixSetPathInfoJeff Layton
cifs: rename CIFSSMBUnixSetInfo to CIFSSMBUnixSetPathInfo ...in preparation of adding a SET_FILE_INFO variant. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2009-07-09cifs: add pid of initiating process to spnego upcall infoJeff Layton
cifs: add pid of initiating process to spnego upcall info This will allow the upcall to poke in /proc/<pid>/environ and get the value of the $KRB5CCNAME env var for the process. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2009-07-09[WATCHDOG] w83627hf_wdt.c: add support for the W83627EHF supportSlobodan Tomić
Add support for the W83627EHF/EF and W83627EHG/EG chipsets. Signed-off-by: Slobodan Tomić <stomic@gmail.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2009-07-09[WATCHDOG] SA1100 watchdog maximum timeoutRaphael Assenat
This patch replaces the hardcoded 255 seconds limit for a real limit based on oscr_freq. Also, the 'firmware_version' field is changed to '1' to allow the user space application to easily detect that this driver supports a higher maximum timeout. Signed-off-by: Raphael Assenat <raph@8D.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2009-07-09[WATCHDOG] w83697ug, fix lock imbalanceJiri Slaby
Don't forget to unlock io_lock when w83697ug_select_wd_register fails in wdt_ctrl. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2009-07-09[WATCHDOG] drivers/watchdog/bcm47xx_wdt.c: Remove unnecessary semicolonsJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2009-07-08Merge branch 'fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq * 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq: [CPUFREQ] Fix compile failure in cpufreq.c
2009-07-08netpoll: Fix carrier detection for drivers that are using phylibAnton Vorontsov
Using early netconsole and gianfar driver this error pops up: netconsole: timeout waiting for carrier It appears that net/core/netpoll.c:netpoll_setup() is using cond_resched() in a loop waiting for a carrier. The thing is that cond_resched() is a no-op when system_state != SYSTEM_RUNNING, and so drivers/net/phy/phy.c's state_queue is never scheduled, therefore link detection doesn't work. I belive that the main problem is in cond_resched()[1], but despite how the cond_resched() story ends, it might be a good idea to call msleep(1) instead of cond_resched(), as suggested by Andrew Morton. [1] http://lkml.org/lkml/2009/7/7/463 Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-08Merge branch 'master' of ↵David S. Miller
2009-07-08fealnx: Fix build breakage -- PR_CONT should be KERN_CONTRoland Dreier
Commit ad361c98 ("Remove multiple KERN_ prefixes from printk formats") broke the build for fealnx because it added some "printk(PR_CONT ..." calls, when PR_CONT doesn't exist; it should be "printk(KERN_CONT ..." Signed-off-by: Roland Dreier <rolandd@cisco.com> Cc: Joe Perches <joe@perches.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-08[CPUFREQ] Fix compile failure in cpufreq.cDave Jones
managed_policy is out of scope for the non-smp case. Declare it locally where used (twice) Signed-off-by: Dave Jones <davej@redhat.com>
2009-07-08cifs: fix regression with O_EXCL creates and optimize away lookupJeff Layton
cifs: fix regression with O_EXCL creates and optimize away lookup Signed-off-by: Jeff Layton <jlayton@redhat.com> Tested-by: Shirish Pargaonkar <shirishp@gmail.com> CC: Stable Kernel <stable@kernel.org> Signed-off-by: Steve French <sfrench@us.ibm.com>
2009-07-08atmel_lcdfb: fix regression with uninitalized fb_info->mm_lock mutexKrzysztof Helt
Remove not needed locking of the fb_info->mm_lock mutex before a frambuffer is registered. This fixes a problem with uninitialized the fb_info->mm_lock mutex introduced by the commit 537a1bf059f " fbdev: add mutex for fb_mmap locking" Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-08fsl-diu-fb: fix regression with uninitalized fb_info->mm_lock mutexKrzysztof Helt
Remove call to the fsl_diu_set_par before the register_framebuffer(). This fixes a problem with uninitialized the fb_info->mm_lock mutex introduced by the commit 537a1bf059f " fbdev: add mutex for fb_mmap locking" Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Tested-by: "Kai Jiang" <b18973@freescale.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-08includecheck fix: include/linux, rfkill.hJaswinder Singh Rajput
fix the following 'make includecheck' warning: include/linux/rfkill.h: linux/types.h is included more than once. Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-08p54: tx refused but queue activeLarry Finger
In the mainline kernel, p54usb will fail because the TX queue length can become < 0. This problem has been reported as Bugzilla #13725. The failure is expressed by the following message in the logs: WARNING: at net/mac80211/tx.c:1325 ieee80211_tx+0x23c/0x298 [mac80211]() Hardware name: HP Pavilion dv2700 Notebook PC tx refused but queue active This problem has been recently observed in the wireless-testing tree, where a full solution is being tested. That fix is too invasive for 2.6.31-rcX, but the simple change supplied here will prevent the failure. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-08Atheros Kconfig needs to be dependent on WLAN_80211Jay Sternberg
Atheros top level menu needs a "depends WLAN_80211" to properly indent within menuconfig and xconfig interfaces. This is purely a visual issue but it effects all subsequent drivers. The issue is the top level menu does not include a dependency on WLAN_80211 so within the tree structure, Atheros is at the same level as WLAN_80211 but when WLAN_80211 collapsed, the menu disappears along with all subsequent drives, so it is really a subordinate. Signed-off-by: Jay Sternberg <jay.e.sternberg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
