2015-06-30MAINTAINERS: move Jens Osterkamp to CREDITSJoe Perches
Jens' email address bounces, so move his name and entry to CREDITS. Signed-off-by: Joe Perches <joe@perches.com> Cc: Ishizaki Kou <kou.ishizaki@toshiba.co.jp> Cc: Jens Osterkamp <jens@linux.vnet.ibm.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30MAINTAINERS: remove unused nbd.h patternJoe Perches
Commit 13e71d69cc74 ("nbd: Remove kernel internal header") deleted the file, remove the pattern. Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Markus Pargmann <mpa@pengutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30MAINTAINERS: update brcm gpio filename patternJoe Perches
Commit 23a71fd616bf ("dt-bindings: brcm: rationalize Broadcom documentation naming") renamed the file, update the pattern. Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Scott Branden <sbranden@broadcom.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30MAINTAINERS: update brcm dts patternJoe Perches
Commit 8c0b9ee8665c ("MIPS: Move device-trees into vendor sub-directories") moved the files, update the pattern. Signed-off-by: Joe Perches <joe@perches.com> Cc: Andrew Bresticker <abrestic@chromium.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30MAINTAINERS: update sound soc intel patternsJoe Perches
Commit 2106241a6803 ("ASoC: Intel: create common folder and move common files in") moved the files around. Update the patterns. Signed-off-by: Joe Perches <joe@perches.com> Cc: Jie Yang <yang.jie@intel.com> Acked-by: Jie Yang <yang.jie@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30MAINTAINERS: remove website for parideSudip Mukherjee
The webpage mentioned is not working, Signed-off-by: Sudip Mukherjee <sudip@vectorindia.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30MAINTAINERS: update Emulex ocrdma email addressesLaurent Navet
@emulex.com addresses respond to use @avagotech.com. Signed-off-by: Laurent Navet <laurent.navet@gmail.com> Acked-By: Devesh Sharma <devesh.sharma@avagotech.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30bcache: use kvfree() in various placesPekka Enberg
Use kvfree() instead of open-coding it. Signed-off-by: Pekka Enberg <penberg@kernel.org> Cc: Kent Overstreet <kmo@daterainc.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30libcxgbi: use kvfree() in cxgbi_free_big_mem()Pekka Enberg
Use kvfree() instead of open-coding it. Signed-off-by: Pekka Enberg <penberg@kernel.org> Cc: "James E.J. Bottomley" <JBottomley@odin.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30target: use kvfree() in session alloc and freePekka Enberg
Use kvfree() instead of open-coding it. Signed-off-by: Pekka Enberg <penberg@kernel.org> Cc: "Nicholas A. Bellinger" <nab@linux-iscsi.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30IB/ehca: use kvfree() in ipz_queue_{cd}tor()Pekka Enberg
Use kvfree() instead of open-coding it. Signed-off-by: Pekka Enberg <penberg@kernel.org> Cc: Hoang-Nam Nguyen <hnguyen@de.ibm.com> Cc: Christoph Raisch <raisch@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30drm/nouveau/gem: use kvfree() in u_free()Pekka Enberg
Use kvfree() instead of open-coding it. Signed-off-by: Pekka Enberg <penberg@kernel.org> Cc: David Airlie <airlied@linux.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30drm: use kvfree() in drm_free_large()Pekka Enberg
2015-06-30cxgb4: use kvfree() in t4_free_mem()Pekka Enberg
Use kvfree() instead of open-coding it. Signed-off-by: Pekka Enberg <penberg@kernel.org> Cc: Hariprasad S <hariprasad@chelsio.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30cxgb3: use kvfree() in cxgb_free_mem()Pekka Enberg
Use kvfree() instead of open-coding it. Signed-off-by: Pekka Enberg <penberg@kernel.org> Cc: Santosh Raspatur <santosh@chelsio.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30kernel/relay.c: use kvfree() in relay_free_page_array()Pekka Enberg
Use kvfree() instead of open-coding it. Signed-off-by: Pekka Enberg <penberg@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30printk: improve the description of /dev/kmsg line formatAntonio Ospite
The comment about /dev/kmsg does not mention the additional values which may actually be exported, fix that. Also move up the part of the comment instructing the users to ignore these additional values, this way the reading is more fluent and logically compact. Signed-off-by: Antonio Ospite <ao2@ao2.it> Cc: Joe Perches <joe@perches.com> Cc: Jonathan Corbet <corbet@lwn.net> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30arch/unicore32/kernel/fpu-ucf64.c: remove unnecessary KERN_ERRMasanari Iida
Signed-off-by: Masanari Iida <standby24x7@gmail.com> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30drivers/scsi/scsi_debug.c: resolve sg buffer const-ness issueDave Gordon
do_device_access() takes a separate parameter to indicate the direction of data transfer, which it used to use to select the appropriate function out of sg_pcopy_{to,from}_buffer(). However these two functions now have So this patch makes it bypass these wrappers and call the underlying function sg_copy_buffer() directly; this has the same calling style as do_device_access() i.e. a separate direction-of-transfer parameter and no pointers-to-const, so skipping the wrappers not only eliminates the warning, it also make the code simpler :) [akpm@linux-foundation.org: fix very broken build] Signed-off-by: Dave Gordon <david.s.gordon@intel.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30lib/scatterlist: mark input buffer parameters as 'const'Dave Gordon
The 'buf' parameter of sg(p)copy_from_buffer() can and should be const-qualified, although because of the shared implementation of _to_buffer() and _from_buffer(), we have to cast this away internally. This means that callers who have a 'const' buffer containing the data to be copied to the sg-list no longer have to cast away the const-ness themselves. It also enables improved coverage by code analysis tools. Signed-off-by: Dave Gordon <david.s.gordon@intel.com> Cc: Akinobu Mita <akinobu.mita@gmail.com> Cc: "Martin K. Petersen" <martin.petersen@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30lib/scatterlist.c: fix kerneldoc for sg_pcopy_{to,from}_buffer()Dave Gordon
The kerneldoc for the functions doesn't match the code; the last two parameters (buflen, skip) have been transposed, which is confusing, especially as they're both integral types and the compiler won't warn about swapping them. These functions and the kerneldoc were introduced in commit: df642cea lib/scatterlist: introduce sg_pcopy_from_buffer() ... Author: Akinobu Mita <akinobu.mita@gmail.com> Date: Mon Jul 8 16:01:54 2013 -0700 The only difference between sg_pcopy_{from,to}_buffer() and sg_copy_{from,to}_buffer() is an additional argument that specifies the number of bytes to skip the SG list before copying. The functions have the extra argument at the end, but the kerneldoc lists it in penultimate position. Signed-off-by: Dave Gordon <david.s.gordon@intel.com> Reviewed-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: "Martin K. Petersen" <martin.petersen@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30ipc,sysv: return -EINVAL upon incorrect id/seqnumDavidlohr Bueso
In ipc_obtain_object_check we return -EIDRM when a bogus sequence number is detected via ipc_checkid, while the ipc manpages state the following return codes for such errors: EIDRM <ID> points to a removed identifier. EINVAL Invalid <ID> value, or unaligned, etc. EIDRM should only be returned upon a RMID call (->deleted check), and thus return EINVAL for wrong seq. This difference in semantics has also caused real bugs, ie: https://bugzilla.redhat.com/show_bug.cgi?id=246509 Signed-off-by: Davidlohr Bueso <dbueso@suse.de> Cc: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30ipc,sysv: make return -EIDRM when racing with RMID consistentDavidlohr Bueso
The ipc_lock helper is used by all forms of sysv ipc to acquire the ipc object's spinlock. Upon error (bogus identifier), we always return -EINVAL, whether the problem be in the idr path or because we raced with a task performing RMID. For the later, however, all ipc related manpages, state the that for: EIDRM <ID> points to a removed identifier. And return: EINVAL Invalid <ID> value, or unaligned, etc. Which (EINVAL) should only return once the ipc resource is deleted. For all types of ipc this is done immediately upon a RMID command. However, shared memory behaves slightly different as it can merely mark a segment for deletion, and delay the actual freeing until there are no more active consumers. Per shmctl(IPC_RMID) manpage: "" Mark the segment to be destroyed. The segment will only actually be destroyed after the last process detaches it (i.e., when the shm_nattch member of the associated structure shmid_ds is zero). "" Unlike ipc_lock, paths that behave "correctly", at least per the manpage, involve controlling the ipc resource via *ctl(), doing the exact same validity check as ipc_lock after right acquiring the spinlock: if (!ipc_valid_object()) { err = -EIDRM; goto out_unlock; } Thus make ipc_lock consistent with the rest of ipc code and return -EIDRM in ipc_lock when !ipc_valid_object(). Signed-off-by: Davidlohr Bueso <dbueso@suse.de> Cc: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30ipc: rename ipc_obtain_objectDavidlohr Bueso
... to ipc_obtain_object_idr, which is more meaningful and makes the code slightly easier to follow. Signed-off-by: Davidlohr Bueso <dbueso@suse.de> Cc: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30ipc,msg: provide barrier pairings for lockless receiveDavidlohr Bueso
We currently use a full barrier on the sender side to to avoid receiver tasks disappearing on us while still performing on the sender side wakeup. We lack however, the proper CPU-CPU interactions pairing on the receiver side which busy-waits for the message. Similarly, we do not need a full smp_mb, and can relax the semantics for the writer and reader sides of the message. This is safe as we are only ordering loads and stores to r_msg. And in both smp_wmb and smp_rmb, there are no stores after the calls _anyway_. This obviously applies for pipelined_send and expunge_all, for EIRDM when destroying a queue. Signed-off-by: Davidlohr Bueso <dbueso@suse.de> Cc: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30ipc,shm: move BUG_ON check into shm_lockDavidlohr Bueso
Upon every shm_lock call, we BUG_ON if an error was returned, indicating racing either in idr or in shm_destroy. Move this logic into the locking. [akpm@linux-foundation.org: simplify code] Signed-off-by: Davidlohr Bueso <dbueso@suse.de> Cc: Manfred Spraul <manfred@colorfullife.com> Cc: Davidlohr Bueso <dave@stgolabs.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30ipc/util.c: use kvfree() in ipc_rcu_free()Pekka Enberg
2015-06-30arc: use for_each_sg()Akinobu Mita
This replaces the plain loop over the sglist array with for_each_sg() macro which consists of sg_next() function calls. Since arc doesn't select ARCH_HAS_SG_CHAIN, it is not necessary to use for_each_sg() in order to loop over each sg element. But this can help find problems with drivers that do not properly initialize their sg tables when CONFIG_DEBUG_SG is enabled. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Acked-by: Vineet Gupta <vgupta@synopsys.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30devpts: if initialization failed, don't crash when opening /dev/ptmxJosh Triplett
If devpts failed to initialize, it would store an ERR_PTR in the global devpts_mnt. A subsequent open of /dev/ptmx would call devpts_new_index, which would dereference devpts_mnt and crash. Avoid storing invalid values in devpts_mnt; leave it NULL instead. Make both devpts_new_index and devpts_pty_new fail gracefully with ENODEV in that case, which then becomes the return value to the userspace open call on /dev/ptmx. [akpm@linux-foundation.org: remove unneeded static] Signed-off-by: Josh Triplett <josh@joshtriplett.org> Reported-by: Fengguang Wu <fengguang.wu@intel.com> Reviewed-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30scripts/gdb: remove useless global instructionThiébaud Weksteen
Signed-off-by: Thiébaud Weksteen <thiebaud@weksteen.fr> Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30scripts/gdb: add ps commandThiébaud Weksteen
2015-06-30scripts/gdb: fix PEP8 complianceThiébaud Weksteen
2015-06-30scripts/gdb: fix typo in exception nameThiébaud Weksteen
2015-06-30scripts/gdb: enable completion for lx-list-check parameterJan Kiszka
Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Cc: Thiébaud Weksteen <thiebaud@weksteen.fr> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30scripts/gdb: also allow list_head pointer as lx-list-check paramterJan Kiszka
This makes the usage more flexible. Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Cc: Thiébaud Weksteen <thiebaud@weksteen.fr> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30scripts/gdb: add command to check list consistencyThiébaud Weksteen
Add a gdb script to verify the consistency of lists. Signed-off-by: Thiébaud Weksteen <thiebaud@weksteen.fr> Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30memstick: remove deprecated use of pci apiQuentin Lambert
Replace occurences of the pci api by appropriate call to the dma api. A simplified version of the semantic patch that finds this problem is as follows: (http://coccinelle.lip6.fr) @deprecated@ idexpression id; position p; @@ ( pci_dma_supported@p ( id, ...) | pci_alloc_consistent@p ( id, ...) ) @bad1@ idexpression id; position deprecated.p; @@ ...when != &id->dev when != pci_get_drvdata ( id ) when != pci_enable_device ( id ) ( pci_dma_supported@p ( id, ...) | pci_alloc_consistent@p ( id, ...) ) @depends on !bad1@ idexpression id; expression direction; position deprecated.p; @@ ( - pci_dma_supported@p ( id, + dma_supported ( &id->dev, ... + , GFP_ATOMIC ) | - pci_alloc_consistent@p ( id, + dma_alloc_coherent ( &id->dev, ... + , GFP_ATOMIC ) ) Signed-off-by: Quentin Lambert <lambert.quentin@gmail.com> Cc: Maxim Levitsky <maximlevitsky@gmail.com> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30fs/affs/symlink.c: remove unneeded err variableFabian Frederick
err is only assigned to -EIO. Return that value at the end of fail context. Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30fs/affs/amigaffs.c: remove unneeded initializationFabian Frederick
bh is initialized unconditionally in affs_remove_link() Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30fs/affs/inode.c: remove unneeded initializationFabian Frederick
bh is initialized unconditionally in affs_add_entry() Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30fs/adfs: remove unneeded castFiro Yang
kmem_cache_alloc() returns void*. Signed-off-by: Firo Yang <firogm@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30gcov: add support for GCC 5.1Lorenzo Stoakes
Fix kernel gcov support for GCC 5.1. Similar to commit a992bf836f9 ("gcov: add support for GCC 4.9"), this patch takes into account the existence of a new gcov counter (see gcc's gcc/gcov-counter.def.) Firstly, it increments GCOV_COUNTERS (to 10), which makes the data structure struct gcov_info compatible with GCC 5.1. Secondly, a corresponding counter function __gcov_merge_icall_topn (Top N value tracking for indirect calls) is included in base.c with the other gcov counters unused for kernel profiling. Signed-off-by: Lorenzo Stoakes <lstoakes@gmail.com> Cc: Andrey Ryabinin <a.ryabinin@samsung.com> Cc: Yuan Pengfei <coolypf@qq.com> Tested-by: Peter Oberparleiter <oberpar@linux.vnet.ibm.com> Reviewed-by: Peter Oberparleiter <oberpar@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30kernel/panic/kexec: fix "crash_kexec_post_notifiers" option issue in oops pathHATAYAMA Daisuke
Commit f06e5153f4ae2e ("kernel/panic.c: add "crash_kexec_post_notifiers" option for kdump after panic_notifers") introduced "crash_kexec_post_notifiers" kernel boot option, which toggles wheather panic() calls crash_kexec() before panic_notifiers and dump kmsg or after. The problem is that the commit overlooks panic_on_oops kernel boot option. If it is enabled, crash_kexec() is called directly without going through panic() in oops path. To fix this issue, this patch adds a check to "crash_kexec_post_notifiers" in the condition of kexec_should_crash(). Also, put a comment in kexec_should_crash() to explain not obvious things on this patch. Signed-off-by: HATAYAMA Daisuke <d.hatayama@jp.fujitsu.com> Acked-by: Baoquan He <bhe@redhat.com> Tested-by: Hidehiro Kawai <hidehiro.kawai.ez@hitachi.com> Reviewed-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Vivek Goyal <vgoyal@redhat.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Hidehiro Kawai <hidehiro.kawai.ez@hitachi.com> Cc: Baoquan He <bhe@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30kernel/panic: call the 2nd crash_kexec() only if crash_kexec_post_notifiers ↵HATAYAMA Daisuke
is enabled For compatibility with the behaviour before the commit f06e5153f4ae2e ("kernel/panic.c: add "crash_kexec_post_notifiers" option for kdump after panic_notifers"), the 2nd crash_kexec() should be called only if crash_kexec_post_notifiers is enabled. Note that crash_kexec() returns immediately if kdump crash kernel is not loaded, so in this case, this patch makes no functionality change, but the point is to make it explicit, from the caller panic() side, that the 2nd crash_kexec() does nothing. Signed-off-by: HATAYAMA Daisuke <d.hatayama@jp.fujitsu.com> Suggested-by: Ingo Molnar <mingo@kernel.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Vivek Goyal <vgoyal@redhat.com> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Hidehiro Kawai <hidehiro.kawai.ez@hitachi.com> Cc: Baoquan He <bhe@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30x86/kexec: prepend elfcorehdr instead of appending it to the crash-kernel ↵KarimAllah Ahmed
command-line. Any parameter passed after '--' in the kernel command-line will not be parsed by the kernel at all, instead it will be passed directly to init process. Currently the kernel appends elfcorehdr=<paddr> to the cmdline passed from kexec load, and if this command-line is used to pass parameters to init process this means that 'elfcorehdr' will not be parsed as a kernel parameter at all which will be a problem for vmcore subsystem since it will know nothing about the location of the ELF structure! Prepending 'elfcorehdr' instead of appending it fixes this problem since it ensures that it always comes before '--' and so it's always parsed as a kernel command-line parameter. Even with this patch things can still go wrong if 'CONFIG_CMDLINE' was also used to embedd a command-line to the crash dump kernel and this command-line contains '--' since the current behavior of the kernel is to actually append the boot loader command-line to the embedded command-line. Signed-off-by: KarimAllah Ahmed <karahmed@amazon.de> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Acked-by: Vivek Goyal <vgoyal@redhat.com> Cc: Haren Myneni <hbabu@us.ibm.com> Cc: Eric Biederman <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30fs: document seq_open()'s usage of file->private_dataYann Droneaud
seq_open() stores its struct seq_file in file->private_data, thus it must not be modified by user of seq_file. Link: http://lkml.kernel.org/r/cover.1433193673.git.ydroneaud@opteya.com Signed-off-by: Yann Droneaud <ydroneaud@opteya.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30fs: allocate structure unconditionally in seq_open()Yann Droneaud
Since patch described below, from v2.6.15-rc1, seq_open() could use a struct seq_file already allocated by the caller if the pointer to the structure is stored in file->private_data before calling the function. Commit 1abe77b0fc4b485927f1f798ae81a752677e1d05 Author: Al Viro <viro@zeniv.linux.org.uk> Date: Mon Nov 7 17:15:34 2005 -0500 [PATCH] allow callers of seq_open do allocation themselves Allow caller of seq_open() to kmalloc() seq_file + whatever else they want and set ->private_data to it. seq_open() will then abstain from doing allocation itself. As there's no more use for such feature, as it could be easily replaced by calls to seq_open_private() (see commit 39699037a5c9 ("[FS] seq_file: Introduce the seq_open_private()")) and seq_release_private() (see v2.6.0-test3), support for this uncommon feature can be removed from seq_open(). Link: http://lkml.kernel.org/r/cover.1433193673.git.ydroneaud@opteya.com Signed-off-by: Yann Droneaud <ydroneaud@opteya.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30fs: use seq_open_private() for proc_mountsYann Droneaud
A patchset to remove support for passing pre-allocated struct seq_file to seq_open(). Such feature is undocumented and prone to error. In particular, if seq_release() is used in release handler, it will kfree() a pointer which was not allocated by seq_open(). So this patchset drops support for pre-allocated struct seq_file: it's only of use in proc_namespace.c and can be easily replaced by using seq_open_private()/seq_release_private(). Additionally, it documents the use of file->private_data to hold pointer to struct seq_file by seq_open(). This patch (of 3): Since patch described below, from v2.6.15-rc1, seq_open() could use a struct seq_file already allocated by the caller if the pointer to the structure is stored in file->private_data before calling the function. Commit 1abe77b0fc4b485927f1f798ae81a752677e1d05 Author: Al Viro <viro@zeniv.linux.org.uk> Date: Mon Nov 7 17:15:34 2005 -0500 [PATCH] allow callers of seq_open do allocation themselves Allow caller of seq_open() to kmalloc() seq_file + whatever else they want and set ->private_data to it. seq_open() will then abstain from doing allocation itself. Such behavior is only used by mounts_open_common(). In order to drop support for such uncommon feature, proc_mounts is converted to use seq_open_private(), which take care of allocating the proc_mounts structure, making it available through ->private in struct seq_file. Conversely, proc_mounts is converted to use seq_release_private(), in order to release the private structure allocated by seq_open_private(). Then, ->private is used directly instead of proc_mounts() macro to access to the proc_mounts structure. Link: http://lkml.kernel.org/r/cover.1433193673.git.ydroneaud@opteya.com Signed-off-by: Yann Droneaud <ydroneaud@opteya.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30mm: meminit: finish initialisation of struct pages before basic setupMel Gorman
Waiman Long reported that 24TB machines hit OOM during basic setup when struct page initialisation was deferred. One approach is to initialise memory on demand but it interferes with page allocator paths. This patch creates dedicated threads to initialise memory before basic setup. It then blocks on a rw_semaphore until completion as a wait_queue and counter is overkill. This may be slower to boot but it's simplier overall and also gets rid of a section mangling which existed so kswapd could do the initialisation. [akpm@linux-foundation.org: include rwsem.h, use DECLARE_RWSEM, fix comment, remove unneeded cast] Signed-off-by: Mel Gorman <mgorman@suse.de> Cc: Waiman Long <waiman.long@hp.com Cc: Nathan Zimmer <nzimmer@sgi.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Scott Norton <scott.norton@hp.com> Tested-by: Daniel J Blueman <daniel@numascale.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30mm: meminit: remove mminit_verify_page_linksMel Gorman
mminit_verify_page_links() is an extremely paranoid check that was introduced when memory initialisation was being heavily reworked. Profiles indicated that up to 10% of parallel memory initialisation was spent on checking this for every page. The cost could be reduced but in practice this check only found problems very early during the initialisation rewrite and has found nothing since. This patch removes an expensive unnecessary check. Signed-off-by: Mel Gorman <mgorman@suse.de> Tested-by: Nate Zimmer <nzimmer@sgi.com> Tested-by: Waiman Long <waiman.long@hp.com> Tested-by: Daniel J Blueman <daniel@numascale.com> Acked-by: Pekka Enberg <penberg@kernel.org> Cc: Robin Holt <robinmholt@gmail.com> Cc: Nate Zimmer <nzimmer@sgi.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Waiman Long <waiman.long@hp.com> Cc: Scott Norton <scott.norton@hp.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
