If the attempt to map a page for DMA fails (eg, because we're out of
mapping space) then we must not hold on to the page we allocated for
DMA - doing so will result in a memory leak.
Cc: <stable@kernel.org>
Reported-by: Bryan Phillippe <bp@darkforest.org>
Tested-by: Bryan Phillippe <bp@darkforest.org>
We are seeing linker errors caused by sections being discarded, despite
the linker script trying to keep them. The result is (eg):
`.exit.text' referenced in section `.alt.smp.init' of drivers/built-in.o: defined in discarded section `.exit.text' of drivers/built-in.o
`.exit.text' referenced in section `.alt.smp.init' of net/built-in.o: defined in discarded section `.exit.text' of net/built-in.o
This is the relevent part of the linker script (reformatted to make it
clearer):
| SECTIONS
| * unwind exit sections must be discarded before the rest of the
| * unwind sections get included.
| /DISCARD/ : {
| *(.ARM.exidx.exit.text)
| *(.ARM.extab.exit.text)
| .exit.text : {
| *(.exit.text)
| *(.memexit.text)
| /DISCARD/ : {
| *(.exit.text)
| *(.memexit.text)
| *(.exit.data)
| *(.memexit.data)
| *(.memexit.rodata)
| *(.exitcall.exit)
| *(.discard)
| *(.discard.*)
Now, this is what the linker manual says about discarded output sections:
| The special output section name `/DISCARD/' may be used to discard
| input sections. Any input sections which are assigned to an output
| section named `/DISCARD/' are not included in the output file.
No questions, no exceptions. It doesn't say "unless they are listed
before the /DISCARD/ section." Now, this is what asn-generic/vmlinux.lds.S
says:
| * Default discarded sections.
| * Some archs want to discard exit text/data at runtime rather than
| * link time due to cross-section references such as alt instructions,
| * bug table, eh_frame, etc. DISCARDS must be the last of output
| * section definitions so that such archs put those in earlier section
| * definitions.
And guess what - the list _always_ includes .exit.text etc.
Now, what's actually happening is that the linker is reading the script,
and it finds the first /DISCARD/ output section at the beginning of the
script. It continues reading the script, and finds the 'DISCARD' macro
at the end, which having been postprocessed results in another
/DISCARD/ output section. As the linker already contains the earlier
/DISCARD/ output section, it adds it to that existing section, so it
effectively is placed at the start. This can be seen by using the -M
option to ld:
| Linker script and memory map
| 0xc037c080 jiffies = jiffies_64
| /DISCARD/
| *(.exit.text)
| *(.memexit.text)
| *(.exit.data)
| *(.memexit.data)
| *(.memexit.rodata)
| *(.exitcall.exit)
| *(.discard)
| *(.discard.*)
| 0xc0008000 . = 0xc0008000
| .head.text 0xc0008000 0x1d0
| 0xc0008000 _text = .
| *(.head.text)
| .head.text 0xc0008000 0x1d0 arch/arm/kernel/head.o
| 0xc0008000 stext
| .text 0xc0008200 0x2d78d0
| 0xc0008200 _stext = .
| 0xc0008200 __exception_text_start = .
| *(.exception.text)
| .exception.text
As you can see, all the discarded sections are grouped together - and
as a result of it being the first output section, they all appear before
any other section.
The result is that not only is the unwind information discarded (as
intended), but also the .exit.text, despite us wanting to have the
.exit.text preserved.
We can't move the unwind information elsewhere, because it'll then be
included even when we do actually discard the .exit.text (and similar)
sections.
So, work around this by avoiding the generic DISCARDS macro, and instead
conditionalize the sections to be discarded ourselves. This avoids the
ambiguity in how the linker assigns input sections to output sections,
making our script less dependent on undocumented linker behaviour.
Reported-by: Rob Herring <robherring2@gmail.com>
Tested-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
CALL scripts/checksyscalls.sh
<stdin>:46:1: warning: "__IGNORE_migrate_pages" redefined
In file included from <stdin>:2:
arch/arm/include/asm/unistd.h:482:1: warning: this is the location of the previous definition
This is caused because we define __IGNORE_migrate_pages to be 1, but
in the case of nommu, it's defined to be empty. Fix this by just
defining the __IGNORE_ symbols to be empty.
This patch implements a workaround for erratum 764369 affecting
Cortex-A9 MPCore with two or more processors (all current revisions).
Under certain timing circumstances, a data cache line maintenance
operation by MVA targeting an Inner Shareable memory region may fail to
proceed up to either the Point of Coherency or to the Point of
Unification of the system. This workaround adds a DSB instruction before
the relevant cache maintenance functions and sets a specific bit in the
diagnostic control register of the SCU.
Tested-by: Mark Rutland <mark.rutland@arm.com>
* 'for-linus' of git://github.com/dtor/input:
Input: wacom - fix touch parsing on newer Bamboos
Input: bcm5974 - add MacBookAir4,1 trackpad support
Input: wacom - add POINTER and DIRECT device properties
Input: adp5588-keys - remove incorrect modalias
Input: cm109 - fix checking return value of usb_control_msg
Input: wacom - advertise BTN_TOOL_PEN and BTN_STYLUS for PenPartner
Input: wacom - remove pressure for touch devices
* 'stable/bug.fixes' of git://oss.oracle.com/git/kwilk/xen:
xen/i386: follow-up to "replace order-based range checking of M2P table by linear one"
xen/irq: Alter the locking to use a mutex instead of a spinlock.
xen/e820: if there is no dom0_mem=, don't tweak extra_pages.
xen: disable PV spinlocks on HVM
* 'for-linus' of git://github.com/tiwai/sound:
ALSA: pcm - fix race condition in wait_for_avail()
ALSA: HDA: Cirrus - fix "Surround Speaker" volume control name
ALSA: hda - Terminate the recursive connection search properly
ASoC: Fix trivial build regression in Kirkwood I2S
ASoC: Blackfin: bf5xx-ad193x: Fix codec device name
ASoC: Fix reporting of partial jack updates
ASoC: imx: Fix build warning of unused 'card' variable
ASoC: Fix register cache sync register_writable WARN_ONs
ASoC: snd_soc_codec_{readable,writable}_register change default to true
ASoC: soc-dapm: Fix parameter comment for snd_soc_dapm_free
MAINTAINERS: Add some missed Wolfson files
ASoC: MPC5200: replace of_device with platform_device
On x86-64, they were just wasteful: with the explicitly added (now
unnecessary) padding, the size of the alternatives structure was 16
bytes, and an alignment of 8 bytes didn't hurt much.
However, it was still silly, since the natural size and alignment for
the structure is actually just 12 bytes, 4-byte aligned since commit
59e97e4d6fbc ("x86: Make alternative instruction pointers relative").
So removing the padding, and removing the extra alignment is just a good
idea.
On x86-32, the alignment of 4 bytes was correct, but was incorrectly
hardcoded as 8 bytes in <asm/alternative-asm.h>. That header file had
used to be an x86-64 only header file, but various unification efforts
have made it be used for x86-32 too (ie the unification of rwlock and
rwsem).
That in turn caused x86-32 boot failures, because the extra alignment
would result in random zero-filled words in the altinstructions section,
causing oopses early at boot when doing alternative instruction
replacement.
So just remove all the alignment noise entirely. It's wrong, and it's
unnecessary. The section itself is already properly aligned by the
linker scripts, and all additions to the section had better be of the
proper 12-byte format, keeping it aligned. So if the align directive
were to ever make a difference, that would be an indication of a serious
bug to begin with.
Reported-by: Werner Landgraf <w.landgraf@ru.r>
Acked-by: Andrew Lutomirski <luto@mit.edu>
* 'bugfixes' of git://git.linux-nfs.org/projects/trondmy/linux-nfs:
nfs: Do not allow multiple mounts on same mountpoint when using -o noac
NFS: Fix a typo in nfs_flush_multi
NFSv4: renewd needs to be able to handle the NFS4ERR_CB_PATH_DOWN error
NFSv4: The NFSv4.0 client must send RENEW calls if it holds a delegation
NFSv4: nfs4_proc_renew should be declared static
NFSv4: nfs4_proc_async_renew should use a GFP_NOFS allocation
* 'hwmon-for-linus' of git://github.com/groeck/linux:
hwmon: (coretemp) Initialize tmin
hwmon: (pmbus) Fix low limit temperature alarms
generic_check_addressable can't deal with hfsplus's larger than page
size allocation blocks, so simply opencode the checks that we actually
need in hfsplus_fill_super.
Signed-off-by: Christoph Hellwig <hch@tuxera.com>
Reported-by: Pavel Ivanov <paivanof@gmail.com>
Tested-by: Pavel Ivanov <paivanof@gmail.com>
Commit 6596528e391a ("hfsplus: ensure bio requests are not smaller than
the hardware sectors") changed the pointers used for volume header
allocations but failed to free the correct pointers in the error path
path of hfsplus_fill_super() and hfsplus_read_wrapper.
The second hunk came from a separate patch by Pavel Ivanov.
Signed-off-by: Seth Forshee <seth.forshee@canonical.com>
linear one"
The numbers obtained from the hypervisor really can't ever lead to an
overflow here, only the original calculation going through the order
of the range could have. This avoids the (as Jeremy points outs)
somewhat ugly NULL-based calculation here.
Signed-off-by: Jan Beulich <jbeulich@novell.com>
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
When we allocate/change the IRQ informations, we do not
need to use spinlocks. We can use a mutex (which is
what the generic IRQ code does for allocations/changes).
Fixes a slew of:
BUG: sleeping function called from invalid context at /linux/kernel/mutex.c:271
in_atomic(): 1, irqs_disabled(): 0, pid: 3216, name: xenstored
2 locks held by xenstored/3216:
#0: (&u->bind_mutex){......}, at: [<ffffffffa02e0920>] evtchn_ioctl+0x30/0x3a0 [xen_evtchn]
#1: (irq_mapping_update_lock){......}, at: [<ffffffff8138b274>] bind_evtchn_to_irq+0x24/0x90
Pid: 3216, comm: xenstored Not tainted 3.1.0-rc6-00021-g437a3d1 #2
Call Trace:
[<ffffffff81088d10>] __might_sleep+0x100/0x130
[<ffffffff81645c2f>] mutex_lock_nested+0x2f/0x50
[<ffffffff81627529>] __irq_alloc_descs+0x49/0x200
[<ffffffffa02e0920>] ? evtchn_ioctl+0x30/0x3a0 [xen_evtchn]
[<ffffffff8138b214>] xen_allocate_irq_dynamic+0x34/0x70
[<ffffffff8138b2ad>] bind_evtchn_to_irq+0x5d/0x90
[<ffffffffa02e03c0>] ? evtchn_bind_to_user+0x60/0x60 [xen_evtchn]
[<ffffffff8138c282>] bind_evtchn_to_irqhandler+0x32/0x80
[<ffffffffa02e03a9>] evtchn_bind_to_user+0x49/0x60 [xen_evtchn]
[<ffffffffa02e0a34>] evtchn_ioctl+0x144/0x3a0 [xen_evtchn]
[<ffffffff811b4070>] ? vfsmount_lock_local_unlock+0x50/0x80
[<ffffffff811a6a1a>] do_vfs_ioctl+0x9a/0x5e0
[<ffffffff811b476f>] ? mntput+0x1f/0x30
[<ffffffff81196259>] ? fput+0x199/0x240
[<ffffffff811a7001>] sys_ioctl+0xa1/0xb0
[<ffffffff8164ea82>] system_call_fastpath+0x16/0x1b
Reported-by: Jim Burns <jim_burn@bellsouth.net>
Acked-by: Ian Campbell <ian.campbell@citrix.com>
wait_for_avail() in pcm_lib.c has a race in it (observed in practice by an
Intel validation group).
The function is supposed to return once space in the buffer has become
available, or if some timeout happens. The entity that creates space (irq
handler of sound driver and some such) will do a wake up on a waitqueue
that this function registers for.
However there are two races in the existing code
1) If space became available between the caller noticing there was no
space and this function actually sleeping, the wakeup is missed and the
timeout condition will happen instead
2) If a wakeup happened but not sufficient space became available, the
code will loop again and wait for more space. However, if the second
wake comes in prior to hitting the schedule_timeout_interruptible(), it
will be missed, and potentially you'll wait out until the timeout
happens.
The fix consists of using more careful setting of the current state (so
that if a wakeup happens in the main loop window, the schedule_timeout()
falls through) and by checking for available space prior to going into the
schedule_timeout() loop, but after being on the waitqueue and having the
state set to interruptible.
[tiwai: the following changes have been added to Arjan's original patch:
- merged akpm's fix for waitqueue adding order into a single patch
- reduction of duplicated code of avail check
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
The found entries by find_get_pages() could be all swap entries. In
this case we skip the entries, but make sure the skipped entries are
accounted, so we don't keep looping.
Using nr_found > nr_skip to simplify code as suggested by Eric.
Reported-and-tested-by: Eric Dumazet <eric.dumazet@gmail.com>
Signed-off-by: Shaohua Li <shaohua.li@intel.com>
Building a kernel with hotplug disabled results in a link failure:
`bgpio_remove' referenced in section `___ksymtab_gpl+bgpio_remove' of drivers/built-in.o: defined in discarded section `.devexit.text' of drivers/built-in.o
This is because of bgpio_remove() is exported. It is illegal to export
symbols which are discarded either at link time or as part of an
init/exit section.
Fix this by dropping the __devexit attributation from bgpio_remove().
Also drop the __devinit attributation from bgpio_init().
Cc: Grant Likely <grant.likely@secretlab.ca>
Take cwq->gcwq->lock to avoid racing between drain_workqueue checking to
make sure the workqueues are empty and cwq_dec_nr_in_flight decrementing
and then incrementing nr_active when it activates a delayed work.
We discovered this when a corner case in one of our drivers resulted in
us trying to destroy a workqueue in which the remaining work would
always requeue itself again in the same workqueue. We would hit this
race condition and trip the BUG_ON on workqueue.c:3080.
Signed-off-by: Thomas Tuttle <ttuttle@chromium.org>
Acked-by: Tejun Heo <tj@kernel.org>
Acked-by: Boaz Harrosh <bharrosh@panasas.com>
Signed-off-by: Benny Halevy <bhalevy@tonian.com>
per_cpu(processors, n) can be NULL, resulting in:
Loading CPUFreq modules[ 437.661360] BUG: unable to handle kernel NULL pointer dereference at (null)
IP: [<ffffffffa0434314>] pcc_cpufreq_cpu_init+0x74/0x220 [pcc_cpufreq]
It's better to avoid the oops by failing the driver, and allowing the
system to boot.
Signed-off-by: Naga Chumbalkar <nagananda.chumbalkar@hp.com>
Cc: Dave Jones <davej@codemonkey.org.uk>
Cc: Len Brown <lenb@kernel.org>
The driver does not generate an alarm interrupt even though a time for
an alarm is set.
This results from disabling rtc_clk after setting the alarm time.
To generate an alarm interrupt the driver should maintain its enabled
state for rtc_clk the until alarm interrupt occurs. This patch permits
generation of an alarm interrupt.
[akpm@linux-foundation.org: make s3c_rtc_alarm_clk_lock local to s3c_rtc_alarm_clk_enable()]
Signed-off-by: Donggeun Kim <dg77.kim@samsung.com>
Signed-off-by: MyungJoo Ham <myungjoo.ham@samsung.com>
Fix regression introduced by commit 5ada28bf7675 ("led-class: always
implement blinking") which broke sysfs delay handling by not storing the
updated value. Consequently it was only possible to set one of the delays
through the sysfs interface as the other delay was automatically restored
to it's default value. Reading the parameters always gave the defaults.
Signed-off-by: Johan Hovold <jhovold@gmail.com>
Acked-by: Florian Fainelli <florian@openwrt.org>
Acked-by: Richard Purdie <richard.purdie@linuxfoundation.org>
Cc: <stable@kernel.org> [2.6.37+]
pti_control_frame_built_and_sent()
In drivers/misc/pti.c::pti_control_frame_built_and_sent() we assign 'comm'
to 'thread_name_p' if (!thread_name). The problem is that 'comm' then
goes out of scope and later we use 'thread_name_p' which now refers to an
out-of-scope variable. To fix that, simply move 'comm' up to have
function scope.
Signed-off-by: Jesper Juhl <jj@chaosbits.net>
Cc: Greg Kroah-Hartman <gregkh@suse.de>
Cc: J Freyensee <james_p_freyensee@linux.intel.com>
Cc: Jeremy Rocher <rocher.jeremy@gmail.com>
Cc: Sergei Trofimovich <slyfox@gentoo.org>
Fix these errors:
drivers/tty/serial/crisv10.c:4453: error: 'if_ser0' undeclared (first use in this function): 2 errors in 2 logs
drivers/tty/serial/crisv10.c:4453: error: (Each undeclared identifier is reported only once: 2 errors in 2 logs
drivers/tty/serial/crisv10.c:4453: error: for each function it appears in.): 2 errors in 2 logs
"if_ser0" is a typo, it should be "if_serial_0".
Signed-off-by: WANG Cong <xiyou.wangcong@gmail.com>
Cc: Mikael Starvik <starvik@axis.com>
Cc: Jesper Nilsson <jesper.nilsson@axis.com>
Xen backend drivers (e.g., blkback and netback) would sometimes fail to
map grant pages into the vmalloc address space allocated with
alloc_vm_area(). The GNTTABOP_map_grant_ref would fail because Xen could
not find the page (in the L2 table) containing the PTEs it needed to
update.
(XEN) mm.c:3846:d0 Could not find L1 PTE for address fbb42000
netback and blkback were making the hypercall from a kernel thread where
task->active_mm != &init_mm and alloc_vm_area() was only updating the page
tables for init_mm. The usual method of deferring the update to the page
tables of other processes (i.e., after taking a fault) doesn't work as a
fault cannot occur during the hypercall.
This would work on some systems depending on what else was using vmalloc.
Fix this by reverting ef691947d8a3 ("vmalloc: remove vmalloc_sync_all()
from alloc_vm_area()") and add a comment to explain why it's needed.
Signed-off-by: David Vrabel <david.vrabel@citrix.com>
Cc: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: Ian Campbell <Ian.Campbell@citrix.com>
Cc: Keir Fraser <keir.xen@gmail.com>
Cc: <stable@kernel.org> [3.0.x]
Revert the post-3.0 commit 82f9d486e59f5 ("memcg: add
memory.vmscan_stat").
The implementation of per-memcg reclaim statistics violates how memcg
hierarchies usually behave: hierarchically.
The reclaim statistics are accounted to child memcgs and the parent
hitting the limit, but not to hierarchy levels in between. Usually,
hierarchical statistics are perfectly recursive, with each level
representing the sum of itself and all its children.
Since this exports statistics to userspace, this may lead to confusion
and problems with changing things after the release, so revert it now,
we can try again later.
Signed-off-by: Johannes Weiner <jweiner@redhat.com>
Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp>
Cc: Ying Han <yinghan@google.com>
Cc: Balbir Singh <bsingharora@gmail.com>
Without swap, anonymous pages are not scanned. As such, they should not
count when considering force-scanning a small target if there is no swap.
Otherwise, targets are not force-scanned even when their effective scan
number is zero and the other conditions--kswapd/memcg--apply.
This fixes 246e87a93934 ("memcg: fix get_scan_count() for small
targets").
[akpm@linux-foundation.org: fix comment]
Reviewed-by: Michal Hocko <mhocko@suse.cz>
Acked-by: Mel Gorman <mel@csn.ul.ie>
Include linux/sched.h to fix below build error.
CC drivers/rtc/rtc-imxdi.o
drivers/rtc/rtc-imxdi.c: In function 'di_write_wait':
drivers/rtc/rtc-imxdi.c:168: error: 'TASK_INTERRUPTIBLE' undeclared (first use in this function)
drivers/rtc/rtc-imxdi.c:168: error: (Each undeclared identifier is reported only once
drivers/rtc/rtc-imxdi.c:168: error: for each function it appears in.)
drivers/rtc/rtc-imxdi.c:168: error: implicit declaration of function 'signal_pending'
drivers/rtc/rtc-imxdi.c:168: error: implicit declaration of function 'schedule_timeout'
drivers/rtc/rtc-imxdi.c: In function 'dryice_norm_irq':
drivers/rtc/rtc-imxdi.c:329: error: 'TASK_INTERRUPTIBLE' undeclared (first use in this function)
Cc: Baruch Siach <baruch@tkos.co.il>
Cc: Wan ZongShun <mcuos.com@gmail.com>
Cc: Alessandro Zummo <a.zummo@towertech.it>
Since GPIOLIB is optional on alpha, GENERIC_GPIO must not be selected by
default. If GPIOLIB is enabled, it will select GENERIC_GPIO.
See <http://bugs.debian.org/638696> for an example of what 'def_bool y'
breaks.
Reported-by: Michael Cree <mcree@orcon.net.nz>
Cc: Richard Henderson <rth@twiddle.net>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Matt Turner <mattst88@gmail.com>
Cc: Michael Cree <mcree@orcon.net.nz>
Cc: Mark Brown <broonie@opensource.wolfsonmicro.com>
richard@nod.at:
Fixes:
/usr/lib/gcc/x86_64-linux-gnu/4.4.5/../../../../lib/libc.a(strrchr.o): In function `rindex':
(.text+0x0): multiple definition of `strrchr'
If both STATIC_LINK and UML_NET_VDE are set to "y" libc's strrchr may
clash with the kernel implementation.
This workaround comes originally from Jeff Dike:
http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=494995#35
Signed-off-by: Richard Weinberger <richard@nod.at>
Cc: Jeff Dike <jdike@addtoit.com>
1) take subarch-specific stuff to subarch_ptrace()
2) PTRACE_{PEEK,POKE}{TEXT,DATA} is handled by ptrace_request() just fine...
It's 32bit-only, not 64bit-only... And while we are at it, it's
set_fpxregs(), not set_fpregs()...
while not doing free_irq() from irq handler is commendable, kfree() on the
data passed to said handler before free_irq() is Not Good(tm). Freeing
the stack it's being run on is also not nice... Solution: delay actually
freeing stuff.
... so set winch->fd to -1 before doing free_irq(), to avoid having
winch_interrupt() come from/during the latter and attempt to do
reactivate_fd() on something that's already gone.
tty->count is decremented only after ->close() had been called and
several tasks can hit it in parallel. As the result, using tty->count
to check if you are the last one is broken. We end up leaving line->tty
not reset to NULL and the next IRQ on that sucker will blow up trying to
dereference pointers from kfree'd struct tty.
Fix is obvious: we need to use a counter of our own.
Some time ago Jeff prepared 42daba316557 ("uml: stop saving process FP
state") for UML to stop saving the process FP state between task
switches. The assumption was that since with SKAS0 every guest process
runs inside a host process context the host OS will take care of keeping
the proper FP state.
Unfortunately this is not true for multi-threaded applications, where
all guest threads share a single host process context yet all may use
the FPU on their own. Although I haven't verified it I suspect things
to be even worse in SKAS3 mode where all guest processes run inside a
single host process.
The patch reintroduces the saving and restoring of the FP context
between task switches.
[richard@nod.at: Ingo posted this patch in 2009, sadly it was never applied
and got lost. Now in 2011 the problem was reported by Gunnar.]
Signed-off-by: Ingo van Lil <inguin@gmx.de>
Reported-by: <gunnarlindroth@hotmail.com>
Tested-by: <gunnarlindroth@hotmail.com>
Cc: Stanislav Meduna <stano@meduna.org>
I could use out_close1, but that seems to be the code path to close the fd
returned by os_create_unix_socket, and using it to close the fd returned
by mkstemp might lead to some confusion, so I don't do it.
Signed-off-by: Jonathan Neuschäfer <j.neuschaefer@gmx.net>
Commit b789ef518b2 ("slub: Add cmpxchg_double_slab()") tests for
cmpxchg_double support in the SLUB code and it breaks UML builds with
SLUB. Since UML does not support checking for CPU features, disable
CMPXCHG_DOUBLE just like CMPXCHG_LOCAL is disabled for UML.
Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@holoscopio.com>
Reviewed-by: Christoph Lameter <cl@linux.com>
Cc: Richard Weinberger <richard@nod.at>
The vmstat_text array is only defined for CONFIG_SYSFS or CONFIG_PROC_FS,
yet it is referenced for per-node vmstat with CONFIG_NUMA:
drivers/built-in.o: In function `node_read_vmstat':
node.c:(.text+0x1106df): undefined reference to `vmstat_text'
Introduced in commit fa25c503dfa2 ("mm: per-node vmstat: show proper
vmstats").
Define the array for CONFIG_NUMA as well.
[akpm@linux-foundation.org: remove unneeded ifdefs]
Signed-off-by: David Rientjes <rientjes@google.com>
Reported-by: Cong Wang <amwang@redhat.com>
Acked-by: Randy Dunlap <rdunlap@xenotime.net>
When compiling mm/mempolicy.c with struct user copy checks the following
warning is shown:
In file included from arch/x86/include/asm/uaccess.h:572,
from include/linux/uaccess.h:5,
from include/linux/highmem.h:7,
from include/linux/pagemap.h:10,
from include/linux/mempolicy.h:70,
from mm/mempolicy.c:68:
In function `copy_from_user',
inlined from `compat_sys_get_mempolicy' at mm/mempolicy.c:1415:
arch/x86/include/asm/uaccess_64.h:64: warning: call to `copy_from_user_overflow' declared with attribute warning: copy_from_user() buffer size is not provably correct
LD mm/built-in.o
Fix this by passing correct buffer size value.
Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
commit 9d8cebd4bcd7 ("mm: fix mbind vma merge problem") didn't really
fix the mbind vma merge problem due to wrong pgoff value passing to
vma_merge(), which made vma_merge() always return NULL.
Before the patch applied, we are getting a result like:
addr = 0x7fa58f00c000
[snip]
7fa58f00c000-7fa58f00d000 rw-p 00000000 00:00 0
7fa58f00d000-7fa58f00e000 rw-p 00000000 00:00 0
7fa58f00e000-7fa58f00f000 rw-p 00000000 00:00 0
here 7fa58f00c000->7fa58f00f000 we get 3 VMAs which are expected to be
merged described as described in commit 9d8cebd.
Re-testing the patched kernel with the reproducer provided in commit
9d8cebd, we get the correct result:
addr = 0x7ffa5aaa2000
[snip]
7ffa5aaa2000-7ffa5aaa6000 rw-p 00000000 00:00 0
7fffd556f000-7fffd5584000 rw-p 00000000 00:00 0 [stack]
Signed-off-by: Caspar Zhang <caspar@casparzhang.com>
Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk>
Cc: Lee Schermerhorn <lee.schermerhorn@hp.com>
Cc: Minchan Kim <minchan.kim@gmail.com>
* git://bedivere.hansenpartnership.com/git/scsi-rc-fixes-2.6: (25 commits)
[SCSI] bnx2i: Fixed the endian on TTT for NOP out transmission
[SCSI] libfc: fix referencing to fc_fcp_pkt from the frame pointer via fr_fsp()
[SCSI] libfc: block SCSI eh thread for blocked rports
[SCSI] libfc: fix fc_eh_host_reset
[SCSI] fcoe: Fix deadlock between fip's recv_work and rtnl
[SCSI] qla2xxx: Update version number to 8.03.07.07-k.
[SCSI] qla2xxx: Set the task attributes after memsetting fcp cmnd.
[SCSI] qla2xxx: Correct inadvertent loop state transitions during port-update handling.
[SCSI] qla2xxx: Save and restore irq in the response queue interrupt handler.
[SCSI] qla2xxx: Double check for command completion if abort mailbox command fails.
[SCSI] qla2xxx: Acquire hardware lock while manipulating dsd list.
[SCSI] qla2xxx: Fix qla24xx revision check while enabling interrupts.
[SCSI] qla2xxx: T10 DIF - Fix incorrect error reporting.
[SCSI] qla2xxx: T10 DIF - Handle uninitalized sectors.
[SCSI] hpsa: fix physical device lun and target numbering problem
[SCSI] hpsa: fix problem that OBDR devices are not detected
[SCSI] isci: add version number
[SCSI] isci: fix event-get pointer increment
[SCSI] isci: dynamic interrupt coalescing
[SCSI] isci: Leave requests alone if already terminating.
* 'for-linus' of git://oss.sgi.com/xfs/xfs:
xfs: fix a use after free in xfs_end_io_direct_write
We used to get the victim pinned by dentry_unhash() prior to commit
64252c75a219 ("vfs: remove dget() from dentry_unhash()") and ->rmdir()
and ->rename() instances relied on that; most of them don't care, but
ones that used d_delete() themselves do. As the result, we are getting
rmdir() oopses on NFS now.
Just grab the reference before locking the victim and drop it explicitly
after unlocking, same as vfs_rename_other() does.
Tested-by: Simon Kirby <sim@hostway.ca>
Cc: stable@kernel.org (3.0.x)
There is a window in which the ioend that we call inode_dio_wake on
in xfs_end_io_direct_write is already free. Fix this by storing
the inode pointer in a local variable.
This is a fix for the regression introduced in 3.1-rc by
"fs: move inode_dio_done to the end_io handler".
Signed-off-by: Alex Elder <aelder@sgi.com>
This patch fixes "Surround Speaker Playback Volume" being cut off.
(Commit b4dabfc452a10 was probably meant to fix this, but it fixed
only the "Switch" name, not the "Volume" name.)
Signed-off-by: David Henningsson <david.henningsson@canonical.com>
ttarget is initialized when the driver is loaded, but tmin is not.
As a result, tempX_max_hyst attributes read 0. Fix this.
Also use THERM_*_THRESHOLD* constants in these initializations instead
of hard-coding the constants.
Cc: "R, Durgadoss" <durgadoss.r@intel.com>
Cc: Guenter Roeck <guenter.roeck@ericsson.com>
Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
Include <linux/cryptohash.h> to pickup the declarations for sha_transform
and sha_init to quite the sparse noise:
warning: symbol 'sha_transform' was not declared. Should it be static?
warning: symbol 'sha_init' was not declared. Should it be static?
Acked-by: Mandeep Singh Baines <msb@chromium.org>
In pcie_find_smpss(), we have the following statement:
if (dev->is_hotplug_bridge && (!list_is_singular(&dev->bus->devices) ||
dev->bus->self->pcie_type != PCI_EXP_TYPE_ROOT_PORT))
The problem is that at least on my machine, this gets called for the
root complex (virtual P2P bridge), and dev->bus->self is NULL since
the parent bus for this is not itself anchor to a PCI device.
This adds the necessary NULL check.
Acked-by: Jon Mason <mason@myri.com>
